[PATCH] bootcount: make i2c version ready for DM driver
If the board already uses DM_I2C we need to use the dm i2c calls.
Signed-off-by: Holger Brunck holger.brunck@ch.abb.com CC: Heiko Schocher hs@denx.de CC: Marek Vasut marex@denx.de --- drivers/bootcount/bootcount_i2c.c | 21 +++++++++++++++++++++ 1 file changed, 21 insertions(+)
diff --git a/drivers/bootcount/bootcount_i2c.c b/drivers/bootcount/bootcount_i2c.c index 496741d63f..24b9bd2fed 100644 --- a/drivers/bootcount/bootcount_i2c.c +++ b/drivers/bootcount/bootcount_i2c.c @@ -14,11 +14,21 @@ void bootcount_store(ulong a) { unsigned char buf[3]; int ret; +#ifdef CONFIG_DM_I2C + struct udevice *eedev = NULL; +#endif
buf[0] = BC_MAGIC; buf[1] = (a & 0xff); +#ifdef CONFIG_DM_I2C + ret = i2c_get_chip_for_busnum(0, CONFIG_SYS_I2C_RTC_ADDR, + 1, &eedev); + if (ret == 0) + ret = dm_i2c_write(eedev, CONFIG_SYS_BOOTCOUNT_ADDR, buf, 2); +#else ret = i2c_write(CONFIG_SYS_I2C_RTC_ADDR, CONFIG_SYS_BOOTCOUNT_ADDR, CONFIG_BOOTCOUNT_ALEN, buf, 2); +#endif if (ret != 0) puts("Error writing bootcount\n"); } @@ -27,9 +37,20 @@ ulong bootcount_load(void) { unsigned char buf[3]; int ret; +#ifdef CONFIG_DM_I2C + struct udevice *eedev = NULL;
+ ret = i2c_get_chip_for_busnum(0, CONFIG_SYS_I2C_RTC_ADDR, + 1, &eedev); + if (ret) { + puts("Error getting i2c bus for bootcount\n"); + return 0; + } + ret = dm_i2c_read(eedev, CONFIG_SYS_BOOTCOUNT_ADDR, buf, 2); +#else ret = i2c_read(CONFIG_SYS_I2C_RTC_ADDR, CONFIG_SYS_BOOTCOUNT_ADDR, CONFIG_BOOTCOUNT_ALEN, buf, 2); +#endif if (ret != 0) { puts("Error loading bootcount\n"); return 0;
Hello Holger,
Am 22.01.2020 um 09:33 schrieb Holger Brunck:
- struct udevice *eedev = NULL;
- ret = i2c_get_chip_for_busnum(0, CONFIG_SYS_I2C_RTC_ADDR,
1, &eedev);
Hmm... with DM/DTS approach I think we should get rid of CONFIG_SYS_I2C_RTC_ADDR define. Also I can think about i2c bootcounters not on RTC instead on PMIC (PFUZE100 for example has also embedded memory, if no battery is connected to the PMIC you can use for bootcounter purposes)
So I thought first to add something like MFD in linux here. A subdevice is the RTC part the other part is the "memory device" ... and a part of this memory than gets reserved for the "bootcounter" device. The bootcounter device itself than only uses mfd->read/write functions or may even better regmap_read/write ...
This would result in a bootounter device you can use on I2C RTC/PMIC/... and may SPI based devices which have some memory. May with regmap approach we can also handle I/O memory based devices ... and have one DM based bootcount driver. Also this embedded memory in I2C devices can be used for other purposes in a clean way ...
But this is not a "made in 1 day" change.
And may to much effort for a bootloader ... ?
So simply looked into drivers/bootcounter and found an already DM based I2C RTC implementation which should fit for you too!
Please look into: u-boot:/drivers/bootcount/rtc.c u-boot:doc/device-tree-bindings/chosen.txt
/ { chosen { u-boot,bootcount-device = &bootcount-rv3029; };
bootcount-rv3029: bootcount@0 { compatible = "u-boot,bootcount-rtc"; rtc = &rv3029; offset = <0x38>; };
i2c2 { rv3029: rtc@56 { compatible = "mc,rv3029"; reg = <0x56>; }; }; };
If your I2C RTC device driver already supports read8/write8 ops, it should work out of the box... of course with adapted DTS settings from above example...
pollux:u-boot hs [master] $ grep -lr write8 drivers/rtc/ drivers/rtc/s35392a.c drivers/rtc/isl1208.c drivers/rtc/mc146818.c drivers/rtc/ds3232.c drivers/rtc/rx8010sj.c drivers/rtc/sandbox_rtc.c drivers/rtc/rv3029.c drivers/rtc/rtc-uclass.c pollux:u-boot hs [master] $
If your rtc is in this list, please try above dm based bootcount driver.
Thanks!
bye, Heiko
Heiko Schocher
Holger Brunck
