[U-Boot] [PATCH] imx: mkimage_fit_atf: Fix DTC warnings
When generating the flash.bin binary the following DTC warnings are seen:
u-boot.itb.tmp: Warning (unit_address_vs_reg): Node /images/uboot@1 has a unit name, but no reg property u-boot.itb.tmp: Warning (unit_address_vs_reg): Node /images/atf@1 has a unit name, but no reg property u-boot.itb.tmp: Warning (unit_address_vs_reg): Node /images/fdt@1 has a unit name, but no reg property u-boot.itb.tmp: Warning (unit_address_vs_reg): Node /configurations/config@1 has a unit name, but no reg property
Fix them by removing the meaningless @1 entries.
Signed-off-by: Fabio Estevam festevam@gmail.com --- arch/arm/mach-imx/mkimage_fit_atf.sh | 26 +++++++++++++------------- 1 file changed, 13 insertions(+), 13 deletions(-)
diff --git a/arch/arm/mach-imx/mkimage_fit_atf.sh b/arch/arm/mach-imx/mkimage_fit_atf.sh index 38c9858e84..fc9342543a 100755 --- a/arch/arm/mach-imx/mkimage_fit_atf.sh +++ b/arch/arm/mach-imx/mkimage_fit_atf.sh @@ -53,7 +53,7 @@ cat << __HEADER_EOF description = "Configuration to load ATF before U-Boot";
images { - uboot@1 { + uboot { description = "U-Boot (64-bit)"; data = /incbin/("$BL33"); type = "standalone"; @@ -61,7 +61,7 @@ cat << __HEADER_EOF compression = "none"; load = <$BL33_LOAD_ADDR>; }; - atf@1 { + atf { description = "ARM Trusted Firmware"; data = /incbin/("$BL31"); type = "firmware"; @@ -74,7 +74,7 @@ __HEADER_EOF
if [ -f $BL32 ]; then cat << __HEADER_EOF - tee@1 { + tee { description = "TEE firmware"; data = /incbin/("$BL32"); type = "firmware"; @@ -90,7 +90,7 @@ cnt=1 for dtname in $* do cat << __FDT_IMAGE_EOF - fdt@$cnt { + fdt { description = "$(basename $dtname .dtb)"; data = /incbin/("$dtname"); type = "flat_dt"; @@ -103,7 +103,7 @@ done cat << __CONF_HEADER_EOF }; configurations { - default = "config@1"; + default = "config";
__CONF_HEADER_EOF
@@ -112,20 +112,20 @@ for dtname in $* do if [ -f $BL32 ]; then cat << __CONF_SECTION_EOF - config@$cnt { + config { description = "$(basename $dtname .dtb)"; - firmware = "uboot@1"; - loadables = "atf@1", "tee@1"; - fdt = "fdt@$cnt"; + firmware = "uboot"; + loadables = "atf", "tee"; + fdt = "fdt"; }; __CONF_SECTION_EOF else cat << __CONF_SECTION1_EOF - config@$cnt { + config { description = "$(basename $dtname .dtb)"; - firmware = "uboot@1"; - loadables = "atf@1"; - fdt = "fdt@$cnt"; + firmware = "uboot"; + loadables = "atf"; + fdt = "fdt"; }; __CONF_SECTION1_EOF fi
Hi Fabio,
Subject: [PATCH] imx: mkimage_fit_atf: Fix DTC warnings
images {
uboot@1 {
atf@1 {
tee@1 {
fdt@$cnt {
fdt {
This is not correct. The file is expected to add more than one fdt files.
Regards, Peng.
default = "config";
__CONF_HEADER_EOF
config@$cnt {
fdt = "fdt@$cnt";
firmware = "uboot";
};fdt = "fdt";
config@$cnt {
fdt = "fdt@$cnt";
firmware = "uboot";
loadables = "atf";
};fdt = "fdt";
__CONF_SECTION1_EOF fi -- 2.17.1
Fabio Estevam
Peng Fan
