[U-Boot] [PATCH v3 00/10] ARM: sunxi: Add basic support for Allwinner A31 (sun6i)
Hi everyone,
This is v3 of the A31 support series. This series add basic (UART and MMC) support for Allwinner's A31 SoC. The patches, excluding the first one, were cherry-picked from u-boot-sunxi. Due to the difference between u-boot mainline and u-boot-sunxi, some patches were rearranged or squashed to better fit the current state of u-boot, and not introduce any build breaks. It follows Ian's initial merge method of sun7i support: introducing various components first, then enabling them in the last commit. I tried to keep the commits separate, thus retaining the original author and Signed-off-bys.
Patch 1 updates the current UART pinmuxing code to use macros for pull-up values. This is for existing platforms, but is included as it would conflict with patch 7.
Patch 2 adds a wrapper around "func(USB, usb, 0)" in BOOT_TARGET_DEVICES to deal with breakage when USB support is not enabled.
Patch 3 adds memory addresses for some hardware blocks new in sun6i.
Patch 4 adds support for the new PRCM (power reset and clock management) block, which also contains PLL bias voltage control.
Patch 5 adds support for the clock module. This patch is a bunch of different sun6i related patches on the clock code, from when sun6i support was introduced to u-boot-sunxi, up to its current form. This is done to avoid various conflicts and needlessly introducing then removing macros.
Patch 6 adds mmc support on sun6i.
Patch 7 adds uart0 pin macros.
Patch 8 adds uart0 muxing on sun6i.
Patch 9 enables sun6i support.
Patch 10 adds a defconfig for the Colombus board, which is an A31 evaluation board.
Changes since v2:
- Added Maxime Ripard as maintainer of Colombus board
Changes since v1:
- Added macros for sun6i uart pinmuxes (patch 7)
- Use gpio macros when muxing uarts (patch 1, 8)
- Clarify what is enabled in PRCM (patch 4)
- Dropped old comments in commit message from Hans (patch 4)
- Use setbits helpers in PRCM code (patch 4)
- Drop SPL code block from clock code (patch 5)
- Make mmc code use fifo in register structure definition, and add reserved area to adjust for sun6i's different fifo address (patch 6)
- Rewrite patch 9 commit message to reflect what is supported
- Split out Colombus board defconfig into separate patch (patch 10)
Cheers ChenYu
Chen-Yu Tsai (5): ARM: sunxi: Use macro values for setting UART GPIO pull-ups ARM: sunxi: Fix build break when CONFIG_USB_EHCI is not defined ARM: sun6i: Add clock support ARM: sun6i: Define UART0 pins for A31 ARM: sun6i: Add Colombus board defconfig
Hans de Goede (1): ARM: sunxi-mmc: Add mmc support for sun6i / A31
Maxime Ripard (2): ARM: sun6i: Setup the A31 UART0 muxing ARM: sunxi: Add basic A31 support
Oliver Schinagl (2): ARM: sun6i: Add base address for the new controllers in A31 ARM: sun6i: Add support for the power reset control module found on the A31
arch/arm/Kconfig | 3 + arch/arm/cpu/armv7/sunxi/Makefile | 2 + arch/arm/cpu/armv7/sunxi/board.c | 10 +- arch/arm/cpu/armv7/sunxi/clock_sun6i.c | 70 ++++++++ arch/arm/cpu/armv7/sunxi/cpu_info.c | 2 + arch/arm/cpu/armv7/sunxi/prcm.c | 33 ++++ arch/arm/include/asm/arch-sunxi/clock.h | 4 + arch/arm/include/asm/arch-sunxi/clock_sun6i.h | 205 ++++++++++++++++++++++ arch/arm/include/asm/arch-sunxi/cpu.h | 9 + arch/arm/include/asm/arch-sunxi/gpio.h | 3 + arch/arm/include/asm/arch-sunxi/mmc.h | 5 +- arch/arm/include/asm/arch-sunxi/prcm.h | 238 ++++++++++++++++++++++++++ board/sunxi/Kconfig | 10 +- board/sunxi/MAINTAINERS | 5 + configs/Colombus_defconfig | 4 + drivers/mmc/sunxi_mmc.c | 11 +- include/configs/sun6i.h | 26 +++ include/configs/sunxi-common.h | 8 +- 18 files changed, 638 insertions(+), 10 deletions(-) create mode 100644 arch/arm/cpu/armv7/sunxi/clock_sun6i.c create mode 100644 arch/arm/cpu/armv7/sunxi/prcm.c create mode 100644 arch/arm/include/asm/arch-sunxi/clock_sun6i.h create mode 100644 arch/arm/include/asm/arch-sunxi/prcm.h create mode 100644 configs/Colombus_defconfig create mode 100644 include/configs/sun6i.h
We have already defined macros for pull-up/down values in the GPIO header. Use them instead of magic numbers when configuring the UART pins.
Signed-off-by: Chen-Yu Tsai wens@csie.org Acked-by: Ian Campbell ijc@hellion.org.uk --- arch/arm/cpu/armv7/sunxi/board.c | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/arch/arm/cpu/armv7/sunxi/board.c b/arch/arm/cpu/armv7/sunxi/board.c index f2cedbb..95a74c5 100644 --- a/arch/arm/cpu/armv7/sunxi/board.c +++ b/arch/arm/cpu/armv7/sunxi/board.c @@ -53,15 +53,15 @@ int gpio_init(void) #if CONFIG_CONS_INDEX == 1 && (defined(CONFIG_SUN4I) || defined(CONFIG_SUN7I)) sunxi_gpio_set_cfgpin(SUNXI_GPB(22), SUN4I_GPB22_UART0_TX); sunxi_gpio_set_cfgpin(SUNXI_GPB(23), SUN4I_GPB23_UART0_RX); - sunxi_gpio_set_pull(SUNXI_GPB(23), 1); + sunxi_gpio_set_pull(SUNXI_GPB(23), SUNXI_GPIO_PULL_UP); #elif CONFIG_CONS_INDEX == 1 && defined(CONFIG_SUN5I) sunxi_gpio_set_cfgpin(SUNXI_GPB(19), SUN5I_GPB19_UART0_TX); sunxi_gpio_set_cfgpin(SUNXI_GPB(20), SUN5I_GPB20_UART0_RX); - sunxi_gpio_set_pull(SUNXI_GPB(20), 1); + sunxi_gpio_set_pull(SUNXI_GPB(20), SUNXI_GPIO_PULL_UP); #elif CONFIG_CONS_INDEX == 2 && defined(CONFIG_SUN5I) sunxi_gpio_set_cfgpin(SUNXI_GPG(3), SUN5I_GPG3_UART1_TX); sunxi_gpio_set_cfgpin(SUNXI_GPG(4), SUN5I_GPG4_UART1_RX); - sunxi_gpio_set_pull(SUNXI_GPG(4), 1); + sunxi_gpio_set_pull(SUNXI_GPG(4), SUNXI_GPIO_PULL_UP); #else #error Unsupported console port number. Please fix pin mux settings in board.c #endif
BOOT_TARGET_DEVICES includes USB unconditionally. This breaks when CONFIG_CMD_USB is not defined. Use a secondary macro to conditionally include it when CONFIG_EHCI is enabled, as we do for CONFIG_AHCI.
Signed-off-by: Chen-Yu Tsai wens@csie.org Acked-by: Ian Campbell ijc@hellion.org.uk --- include/configs/sunxi-common.h | 8 +++++++- 1 file changed, 7 insertions(+), 1 deletion(-)
diff --git a/include/configs/sunxi-common.h b/include/configs/sunxi-common.h index 1d947d7..a31656e 100644 --- a/include/configs/sunxi-common.h +++ b/include/configs/sunxi-common.h @@ -233,10 +233,16 @@ #define BOOT_TARGET_DEVICES_SCSI(func) #endif
+#ifdef CONFIG_USB_EHCI +#define BOOT_TARGET_DEVICES_USB(func) func(USB, usb, 0) +#else +#define BOOT_TARGET_DEVICES_USB(func) +#endif + #define BOOT_TARGET_DEVICES(func) \ func(MMC, mmc, 0) \ BOOT_TARGET_DEVICES_SCSI(func) \ - func(USB, usb, 0) \ + BOOT_TARGET_DEVICES_USB(func) \ func(PXE, pxe, na) \ func(DHCP, dhcp, na)
A31 has several new and changed memory address. This patch adds them.
Signed-off-by: Oliver Schinagl oliver@schinagl.nl Signed-off-by: Hans de Goede hdegoede@redhat.com Signed-off-by: Chen-Yu Tsai wens@csie.org Acked-by: Ian Campbell ijc@hellion.org.uk --- arch/arm/include/asm/arch-sunxi/cpu.h | 9 +++++++++ 1 file changed, 9 insertions(+)
diff --git a/arch/arm/include/asm/arch-sunxi/cpu.h b/arch/arm/include/asm/arch-sunxi/cpu.h index a987e51d..313e6c8 100644 --- a/arch/arm/include/asm/arch-sunxi/cpu.h +++ b/arch/arm/include/asm/arch-sunxi/cpu.h @@ -95,6 +95,11 @@ #define SUNXI_MALI400_BASE 0x01c40000 #define SUNXI_GMAC_BASE 0x01c50000
+#define SUNXI_DRAM_COM_BASE 0x01c62000 +#define SUNXI_DRAM_CTL_BASE 0x01c63000 +#define SUNXI_DRAM_PHY_CH1_BASE 0x01c65000 +#define SUNXI_DRAM_PHY_CH2_BASE 0x01c66000 + /* module sram */ #define SUNXI_SRAM_C_BASE 0x01d00000
@@ -105,6 +110,10 @@ #define SUNXI_MP_BASE 0x01e80000 #define SUNXI_AVG_BASE 0x01ea0000
+#define SUNXI_PRCM_BASE 0x01f01400 +#define SUNXI_R_PIO_BASE 0x01f02c00 +#define SUNXI_P2WI_BASE 0x01f03400 + /* CoreSight Debug Module */ #define SUNXI_CSDM_BASE 0x3f500000
The A31 has a new module called PRCM, or Power, Reset Control Module. This module controls clocks and resets for RTC block modules, and also PLL biasing in the main clock module.
This patch adds the register definitions, and also enables the clocks and resets for the RTC block PIO (pin controller) and P2WI (push-pull 2 wire interface) which is used to talk to the PMIC.
Signed-off-by: Oliver Schinagl oliver@schinagl.nl Signed-off-by: Hans de Goede hdegoede@redhat.com [wens@csie.org: spacing fixes reported by checkpatch.pl] [wens@csie.org: Use setbits helper in PRCM init function] [wens@csie.org: rephrase commit message to explain what the hardware supports and what we actually enable] Signed-off-by: Chen-Yu Tsai wens@csie.org Acked-by: Ian Campbell ijc@hellion.org.uk --- arch/arm/cpu/armv7/sunxi/Makefile | 1 + arch/arm/cpu/armv7/sunxi/prcm.c | 33 +++++ arch/arm/include/asm/arch-sunxi/prcm.h | 238 +++++++++++++++++++++++++++++++++ 3 files changed, 272 insertions(+) create mode 100644 arch/arm/cpu/armv7/sunxi/prcm.c create mode 100644 arch/arm/include/asm/arch-sunxi/prcm.h
diff --git a/arch/arm/cpu/armv7/sunxi/Makefile b/arch/arm/cpu/armv7/sunxi/Makefile index e9721b2..f0473d2 100644 --- a/arch/arm/cpu/armv7/sunxi/Makefile +++ b/arch/arm/cpu/armv7/sunxi/Makefile @@ -11,6 +11,7 @@ obj-y += timer.o obj-y += board.o obj-y += clock.o obj-y += pinmux.o +obj-$(CONFIG_SUN6I) += prcm.o obj-$(CONFIG_SUN4I) += clock_sun4i.o obj-$(CONFIG_SUN5I) += clock_sun4i.o obj-$(CONFIG_SUN7I) += clock_sun4i.o diff --git a/arch/arm/cpu/armv7/sunxi/prcm.c b/arch/arm/cpu/armv7/sunxi/prcm.c new file mode 100644 index 0000000..7b3ee89 --- /dev/null +++ b/arch/arm/cpu/armv7/sunxi/prcm.c @@ -0,0 +1,33 @@ +/* + * Sunxi A31 Power Management Unit + * + * (C) Copyright 2013 Oliver Schinagl oliver@schinagl.nl + * http://linux-sunxi.org + * + * Based on sun6i sources and earlier U-Boot Allwinner A10 SPL work + * + * (C) Copyright 2006-2013 + * Allwinner Technology Co., Ltd. <www.allwinnertech.com> + * Berg Xing bergxing@allwinnertech.com + * Tom Cubie tangliang@allwinnertech.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <errno.h> +#include <asm/io.h> +#include <asm/arch/cpu.h> +#include <asm/arch/prcm.h> +#include <asm/arch/sys_proto.h> + +void prcm_init_apb0(void) +{ + struct sunxi_prcm_reg *prcm = + (struct sunxi_prcm_reg *)SUNXI_PRCM_BASE; + + setbits_le32(&prcm->apb0_gate, PRCM_APB0_GATE_P2WI | + PRCM_APB0_GATE_PIO); + setbits_le32(&prcm->apb0_reset, PRCM_APB0_RESET_P2WI | + PRCM_APB0_RESET_PIO); +} diff --git a/arch/arm/include/asm/arch-sunxi/prcm.h b/arch/arm/include/asm/arch-sunxi/prcm.h new file mode 100644 index 0000000..1b40f09 --- /dev/null +++ b/arch/arm/include/asm/arch-sunxi/prcm.h @@ -0,0 +1,238 @@ +/* + * Sunxi A31 Power Management Unit register definition. + * + * (C) Copyright 2013 Oliver Schinagl oliver@schinagl.nl + * http://linux-sunxi.org + * Allwinner Technology Co., Ltd. <www.allwinnertech.com> + * Berg Xing bergxing@allwinnertech.com + * Tom Cubie tangliang@allwinnertech.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef _SUNXI_PRCM_H +#define _SUNXI_PRCM_H + +#define __PRCM_CPUS_CFG_PRE(n) (((n) & 0x3) << 4) +#define PRCM_CPUS_CFG_PRE_MASK __PRCM_CPUS_CFG_PRE(0x3) +#define __PRCM_CPUS_CFG_PRE_DIV(n) (((n) >> 1) - 1) +#define PRCM_CPUS_CFG_PRE_DIV(n) \ + __PRCM_CPUS_CFG_PRE(__PRCM_CPUS_CFG_CLK_PRE(n)) +#define __PRCM_CPUS_CFG_POST(n) (((n) & 0x1f) << 8) +#define PRCM_CPUS_CFG_POST_MASK __PRCM_CPUS_CFG_POST(0x1f) +#define __PRCM_CPUS_CFG_POST_DIV(n) ((n) - 1) +#define PRCM_CPUS_CFG_POST_DIV(n) \ + __PRCM_CPUS_CFG_POST_DIV(__PRCM_CPUS_CFG_POST_DIV(n)) +#define __PRCM_CPUS_CFG_CLK_SRC(n) (((n) & 0x3) << 16) +#define PRCM_CPUS_CFG_CLK_SRC_MASK __PRCM_CPUS_CFG_CLK_SRC(0x3) +#define __PRCM_CPUS_CFG_CLK_SRC_LOSC 0x0 +#define __PRCM_CPUS_CFG_CLK_SRC_HOSC 0x1 +#define __PRCM_CPUS_CFG_CLK_SRC_PLL6 0x2 +#define __PRCM_CPUS_CFG_CLK_SRC_PDIV 0x3 +#define PRCM_CPUS_CFG_CLK_SRC_LOSC \ + __PRCM_CPUS_CFG_CLK_SRC(__PRCM_CPUS_CFG_CLK_SRC_LOSC) +#define PRCM_CPUS_CFG_CLK_SRC_HOSC \ + __PRCM_CPUS_CFG_CLK_SRC(__PRCM_CPUS_CFG_CLK_SRC_HOSC) +#define PRCM_CPUS_CFG_CLK_SRC_PLL6 \ + __PRCM_CPUS_CFG_CLK_SRC(__PRCM_CPUS_CFG_CLK_SRC_PLL6) +#define PRCM_CPUS_CFG_CLK_SRC_PDIV \ + __PRCM_CPUS_CFG_CLK_SRC(__PRCM_CPUS_CFG_CLK_SRC_PDIV) + +#define __PRCM_APB0_RATIO(n) (((n) & 0x3) << 0) +#define PRCM_APB0_RATIO_DIV_MASK __PRCM_APB0_RATIO_DIV(0x3) +#define __PRCM_APB0_RATIO_DIV(n) (((n) >> 1) - 1) +#define PRCM_APB0_RATIO_DIV(n) \ + __PRCM_APB0_RATIO(__PRCM_APB0_RATIO_DIV(n)) + +#define PRCM_CPU_CFG_NEON_CLK_EN (0x1 << 0) +#define PRCM_CPU_CFG_CPU_CLK_EN (0x1 << 1) + +#define PRCM_APB0_GATE_PIO (0x1 << 0) +#define PRCM_APB0_GATE_IR (0x1 << 1) +#define PRCM_APB0_GATE_TIMER01 (0x1 << 2) +#define PRCM_APB0_GATE_P2WI (0x1 << 3) +#define PRCM_APB0_GATE_UART (0x1 << 4) +#define PRCM_APB0_GATE_1WIRE (0x1 << 5) +#define PRCM_APB0_GATE_I2C (0x1 << 6) + +#define PRCM_APB0_RESET_PIO (0x1 << 0) +#define PRCM_APB0_RESET_IR (0x1 << 1) +#define PRCM_APB0_RESET_TIMER01 (0x1 << 2) +#define PRCM_APB0_RESET_P2WI (0x1 << 3) +#define PRCM_APB0_RESET_UART (0x1 << 4) +#define PRCM_APB0_RESET_1WIRE (0x1 << 5) +#define PRCM_APB0_RESET_I2C (0x1 << 6) + +#define PRCM_PLL_CTRL_PLL_BIAS (0x1 << 0) +#define PRCM_PLL_CTRL_HOSC_GAIN_ENH (0x1 << 1) +#define __PRCM_PLL_CTRL_USB_CLK_SRC(n) (((n) & 0x3) << 4) +#define PRCM_PLL_CTRL_USB_CLK_SRC_MASK \ + __PRCM_PLL_CTRL_USB_CLK_SRC(0x3) +#define __PRCM_PLL_CTRL_USB_CLK_0 0x0 +#define __PRCM_PLL_CTRL_USB_CLK_1 0x1 +#define __PRCM_PLL_CTRL_USB_CLK_2 0x2 +#define __PRCM_PLL_CTRL_USB_CLK_3 0x3 +#define PRCM_PLL_CTRL_USB_CLK_0 \ + __PRCM_PLL_CTRL_USB_CLK_SRC(__PRCM_PLL_CTRL_USB_CLK_0) +#define PRCM_PLL_CTRL_USB_CLK_1 \ + __PRCM_PLL_CTRL_USB_CLK_SRC(__PRCM_PLL_CTRL_USB_CLK_1) +#define PRCM_PLL_CTRL_USB_CLK_2 \ + __PRCM_PLL_CTRL_USB_CLK_SRC(__PRCM_PLL_CTRL_USB_CLK_2) +#define PRCM_PLL_CTRL_USB_CLK_3 \ + __PRCM_PLL_CTRL_USB_CLK_SRC(__PRCM_PLL_CTRL_USB_CLK_3) +#define __PRCM_PLL_CTRL_INT_PLL_IN_SEL(n) (((n) & 0x3) << 12) +#define PRCM_PLL_CTRL_INT_PLL_IN_SEL_MASK \ + __PRCM_PLL_CTRL_INT_PLL_IN_SEL(0x3) +#define PRCM_PLL_CTRL_INT_PLL_IN_SEL(n) \ + __PRCM_PLL_CTRL_INT_PLL_IN_SEL(n) +#define __PRCM_PLL_CTRL_HOSC_CLK_SEL(n) (((n) & 0x3) << 20) +#define PRCM_PLL_CTRL_HOSC_CLK_SEL_MASK \ + __PRCM_PLL_CTRL_HOSC_CLK_SEL(0x3) +#define __PRCM_PLL_CTRL_HOSC_CLK_0 0x0 +#define __PRCM_PLL_CTRL_HOSC_CLK_1 0x1 +#define __PRCM_PLL_CTRL_HOSC_CLK_2 0x2 +#define __PRCM_PLL_CTRL_HOSC_CLK_3 0x3 +#define PRCM_PLL_CTRL_HOSC_CLK_0 \ + __PRCM_PLL_CTRL_HOSC_CLK_SEL(__PRCM_PLL_CTRL_HOSC_CLK_0) +#define PRCM_PLL_CTRL_HOSC_CLK_1 \ + __PRCM_PLL_CTRL_HOSC_CLK_SEL(__PRCM_PLL_CTRL_HOSC_CLK_1) +#define PRCM_PLL_CTRL_HOSC_CLK_2 \ + __PRCM_PLL_CTRL_HOSC_CLK_SEL(__PRCM_PLL_CTRL_HOSC_CLK_2) +#define PRCM_PLL_CTRL_HOSC_CLK_3 \ + __PRCM_PLL_CTRL_HOSC_CLK_SEL(__PRCM_PLL_CTRL_HOSC_CLK_3) +#define PRCM_PLL_CTRL_PLL_TST_SRC_EXT (0x1 << 24) +#define PRCM_PLL_CTRL_LDO_DIGITAL_EN (0x1 << 0) +#define PRCM_PLL_CTRL_LDO_ANALOG_EN (0x1 << 1) +#define PRCM_PLL_CTRL_EXT_OSC_EN (0x1 << 2) +#define PRCM_PLL_CTRL_CLK_TST_EN (0x1 << 3) +#define PRCM_PLL_CTRL_IN_PWR_HIGH (0x1 << 15) /* 3.3 for hi 2.5 for lo */ +#define __PRCM_PLL_CTRL_VDD_LDO_OUT(n) (((n) & 0x7) << 16) +#define PRCM_PLL_CTRL_LDO_OUT_MASK \ + __PRCM_PLL_CTRL_LDO_OUT(0x7) +/* When using the low voltage 20 mV steps, and high voltage 30 mV steps */ +#define PRCM_PLL_CTRL_LDO_OUT_L(n) \ + __PRCM_PLL_CTRL_VDD_LDO_OUT((((n) - 1000) / 20) & 0x7) +#define PRCM_PLL_CTRL_LDO_OUT_H(n) \ + __PRCM_PLL_CTRL_VDD_LDO_OUT((((n) - 1160) / 30) & 0x7) +#define PRCM_PLL_CTRL_LDO_OUT_LV(n) \ + __PRCM_PLL_CTRL_VDD_LDO_OUT((((n) & 0x7) * 20) + 1000) +#define PRCM_PLL_CTRL_LDO_OUT_HV(n) \ + __PRCM_PLL_CTRL_VDD_LDO_OUT((((n) & 0x7) * 30) + 1160) +#define PRCM_PLL_CTRL_LDO_KEY (0xa7 << 24) + +#define PRCM_CLK_1WIRE_GATE (0x1 << 31) + +#define __PRCM_CLK_MOD0_M(n) (((n) & 0xf) << 0) +#define PRCM_CLK_MOD0_M_MASK __PRCM_CLK_MOD0_M(0xf) +#define __PRCM_CLK_MOD0_M_X(n) (n - 1) +#define PRCM_CLK_MOD0_M(n) __PRCM_CLK_MOD0_M(__PRCM_CLK_MOD0_M_X(n)) +#define PRCM_CLK_MOD0_OUT_PHASE(n) (((n) & 0x7) << 8) +#define PRCM_CLK_MOD0_OUT_PHASE_MASK(n) PRCM_CLK_MOD0_OUT_PHASE(0x7) +#define _PRCM_CLK_MOD0_N(n) (((n) & 0x3) << 16) +#define PRCM_CLK_MOD0_N_MASK __PRCM_CLK_MOD_N(0x3) +#define __PRCM_CLK_MOD0_N_X(n) (((n) >> 1) - 1) +#define PRCM_CLK_MOD0_N(n) __PRCM_CLK_MOD0_N(__PRCM_CLK_MOD0_N_X(n)) +#define PRCM_CLK_MOD0_SMPL_PHASE(n) (((n) & 0x7) << 20) +#define PRCM_CLK_MOD0_SMPL_PHASE_MASK PRCM_CLK_MOD0_SMPL_PHASE(0x7) +#define PRCM_CLK_MOD0_SRC_SEL(n) (((n) & 0x7) << 24) +#define PRCM_CLK_MOD0_SRC_SEL_MASK PRCM_CLK_MOD0_SRC_SEL(0x7) +#define PRCM_CLK_MOD0_GATE_EN (0x1 << 31) + +#define PRCM_APB0_RESET_PIO (0x1 << 0) +#define PRCM_APB0_RESET_IR (0x1 << 1) +#define PRCM_APB0_RESET_TIMER01 (0x1 << 2) +#define PRCM_APB0_RESET_P2WI (0x1 << 3) +#define PRCM_APB0_RESET_UART (0x1 << 4) +#define PRCM_APB0_RESET_1WIRE (0x1 << 5) +#define PRCM_APB0_RESET_I2C (0x1 << 6) + +#define __PRCM_CLK_OUTD_M(n) (((n) & 0x7) << 8) +#define PRCM_CLK_OUTD_M_MASK __PRCM_CLK_OUTD_M(0x7) +#define __PRCM_CLK_OUTD_M_X() ((n) - 1) +#define PRCM_CLK_OUTD_M(n) __PRCM_CLK_OUTD_M(__PRCM_CLK_OUTD_M_X(n)) +#define __PRCM_CLK_OUTD_N(n) (((n) & 0x7) << 20) +#define PRCM_CLK_OUTD_N_MASK __PRCM_CLK_OUTD_N(0x7) +#define __PRCM_CLK_OUTD_N_X(n) (((n) >> 1) - 1) +#define PRCM_CLK_OUTD_N(n) __PRCM_CLK_OUTD_N(__PRCM_CLK_OUTD_N_X(n) +#define __PRCM_CLK_OUTD_SRC_SEL(n) (((n) & 0x3) << 24) +#define PRCM_CLK_OUTD_SRC_SEL_MASK __PRCM_CLK_OUTD_SRC_SEL(0x3) +#define __PRCM_CLK_OUTD_SRC_LOSC2 0x0 +#define __PRCM_CLK_OUTD_SRC_LOSC 0x1 +#define __PRCM_CLK_OUTD_SRC_HOSC 0x2 +#define __PRCM_CLK_OUTD_SRC_ERR 0x3 +#define PRCM_CLK_OUTD_SRC_LOSC2 \ +#deifne __PRCM_CLK_OUTD_SRC_SEL(__PRCM_CLK_OUTD_SRC_LOSC2) +#define PRCM_CLK_OUTD_SRC_LOSC \ +#deifne __PRCM_CLK_OUTD_SRC_SEL(__PRCM_CLK_OUTD_SRC_LOSC) +#define PRCM_CLK_OUTD_SRC_HOSC \ +#deifne __PRCM_CLK_OUTD_SRC_SEL(__PRCM_CLK_OUTD_SRC_HOSC) +#define PRCM_CLK_OUTD_SRC_ERR \ +#deifne __PRCM_CLK_OUTD_SRC_SEL(__PRCM_CLK_OUTD_SRC_ERR) +#define PRCM_CLK_OUTD_EN (0x1 << 31) + +#define PRCM_CPU0_PWROFF (0x1 << 0) +#define PRCM_CPU1_PWROFF (0x1 << 1) +#define PRCM_CPU2_PWROFF (0x1 << 2) +#define PRCM_CPU3_PWROFF (0x1 << 3) +#define PRCM_CPU_ALL_PWROFF (0xf << 0) + +#define PRCM_VDD_SYS_DRAM_CH0_PAD_HOLD_PWROFF (0x1 << 0) +#define PRCM_VDD_SYS_DRAM_CH1_PAD_HOLD_PWROFF (0x1 << 1) +#define PRCM_VDD_SYS_AVCC_A_PWROFF (0x1 << 2) +#define PRCM_VDD_SYS_CPU0_VDD_PWROFF (0x1 << 3) + +#define PRCM_VDD_GPU_PWROFF (0x1 << 0) + +#define PRCM_VDD_SYS_RESET (0x1 << 0) + +#define PRCM_CPU1_PWR_CLAMP(n) (((n) & 0xff) << 0) +#define PRCM_CPU1_PWR_CLAMP_MASK PRCM_CPU1_PWR_CLAMP(0xff) + +#define PRCM_CPU2_PWR_CLAMP(n) (((n) & 0xff) << 0) +#define PRCM_CPU2_PWR_CLAMP_MASK PRCM_CPU2_PWR_CLAMP(0xff) + +#define PRCM_CPU3_PWR_CLAMP(n) (((n) & 0xff) << 0) +#define PRCM_CPU3_PWR_CLAMP_MASK PRCM_CPU3_PWR_CLAMP(0xff) + +#ifndef __ASSEMBLY__ +struct sunxi_prcm_reg { + u32 cpus_cfg; /* 0x000 */ + u8 res0[0x8]; /* 0x004 */ + u32 apb0_ratio; /* 0x00c */ + u32 cpu0_cfg; /* 0x010 */ + u32 cpu1_cfg; /* 0x014 */ + u32 cpu2_cfg; /* 0x018 */ + u32 cpu3_cfg; /* 0x01c */ + u8 res1[0x8]; /* 0x020 */ + u32 apb0_gate; /* 0x028 */ + u8 res2[0x14]; /* 0x02c */ + u32 pll_ctrl0; /* 0x040 */ + u32 pll_ctrl1; /* 0x044 */ + u8 res3[0x8]; /* 0x048 */ + u32 clk_1wire; /* 0x050 */ + u32 clk_ir; /* 0x054 */ + u8 res4[0x58]; /* 0x058 */ + u32 apb0_reset; /* 0x0b0 */ + u8 res5[0x3c]; /* 0x0b4 */ + u32 clk_outd; /* 0x0f0 */ + u8 res6[0xc]; /* 0x0f4 */ + u32 cpu_pwroff; /* 0x100 */ + u8 res7[0xc]; /* 0x104 */ + u32 vdd_sys_pwroff; /* 0x110 */ + u8 res8[0x4]; /* 0x114 */ + u32 gpu_pwroff; /* 0x118 */ + u8 res9[0x4]; /* 0x11c */ + u32 vdd_pwr_reset; /* 0x120 */ + u8 res10[0x20]; /* 0x124 */ + u32 cpu1_pwr_clamp; /* 0x144 */ + u32 cpu2_pwr_clamp; /* 0x148 */ + u32 cpu3_pwr_clamp; /* 0x14c */ + u8 res11[0x30]; /* 0x150 */ + u32 dram_pwr; /* 0x180 */ + u8 res12[0xc]; /* 0x184 */ + u32 dram_tst; /* 0x190 */ +}; + +void prcm_init_apb0(void); +#endif /* __ASSEMBLY__ */ +#endif /* _PRCM_H */
This patch adds the basic clocks support for the Allwinner A31 (sun6i) processor. This code will not been compiled until the build is hooked up in a later patch. It has been split out to keep the patches manageable.
This includes changes from the following commits from u-boot-sunxi:
a92051b ARM: sunxi: Add sun6i clock controller structure 1f72c6f ARM: sun6i: Setup the UART0 clocks 5f2e712 ARM: sunxi: Enable pll6 by default on all models 2be2f2a ARM: sunxi-mmc: Add mmc support for sun6i / A31 12e1633 ARM: sun6i: Add initial clock setup for SPL 1a9c9c6 ARM: sunxi: Split clock code into common, sun4i and sun6i code 0b194ee ARM: sun6i: Properly setup the PLL LDO in clock_init_safe b54c626 sunxi: avoid sr32 for APB1 clock setup. 68fe29c sunxi: remove magic numbers from clock_get_pll{5,6} c89867d sunxi: clocks: clock_get_pll5 prototype and coding style 501ab1e ARM: sunxi: Fix sun6i PLL6 settings 37f669b ARM: sunxi: Fix macro names for mmc and uart reset offsets 61de1e6 ARM: sunxi: Correct comment for MBUS1 register in sun6i clock definitions
Signed-off-by: Maxime Ripard maxime.ripard@free-electrons.com Signed-off-by: Ian Campbell ijc@hellion.org.uk Signed-off-by: Hans de Goede hdegoede@redhat.com [wens@csie.org: styling fixes reported by checkpatch.pl] [wens@csie.org: drop unsupported SPL code block and unused gpio.h header] Signed-off-by: Chen-Yu Tsai wens@csie.org Cc: Tom Cubie Mr.hipboi@gmail.com Acked-by: Ian Campbell ijc@hellion.org.uk --- arch/arm/cpu/armv7/sunxi/Makefile | 1 + arch/arm/cpu/armv7/sunxi/clock_sun6i.c | 70 +++++++++ arch/arm/include/asm/arch-sunxi/clock.h | 4 + arch/arm/include/asm/arch-sunxi/clock_sun6i.h | 205 ++++++++++++++++++++++++++ 4 files changed, 280 insertions(+) create mode 100644 arch/arm/cpu/armv7/sunxi/clock_sun6i.c create mode 100644 arch/arm/include/asm/arch-sunxi/clock_sun6i.h
diff --git a/arch/arm/cpu/armv7/sunxi/Makefile b/arch/arm/cpu/armv7/sunxi/Makefile index f0473d2..2a42dca 100644 --- a/arch/arm/cpu/armv7/sunxi/Makefile +++ b/arch/arm/cpu/armv7/sunxi/Makefile @@ -14,6 +14,7 @@ obj-y += pinmux.o obj-$(CONFIG_SUN6I) += prcm.o obj-$(CONFIG_SUN4I) += clock_sun4i.o obj-$(CONFIG_SUN5I) += clock_sun4i.o +obj-$(CONFIG_SUN6I) += clock_sun6i.o obj-$(CONFIG_SUN7I) += clock_sun4i.o
ifndef CONFIG_SPL_BUILD diff --git a/arch/arm/cpu/armv7/sunxi/clock_sun6i.c b/arch/arm/cpu/armv7/sunxi/clock_sun6i.c new file mode 100644 index 0000000..8387b93 --- /dev/null +++ b/arch/arm/cpu/armv7/sunxi/clock_sun6i.c @@ -0,0 +1,70 @@ +/* + * sun6i specific clock code + * + * (C) Copyright 2007-2012 + * Allwinner Technology Co., Ltd. <www.allwinnertech.com> + * Tom Cubie tangliang@allwinnertech.com + * + * (C) Copyright 2013 Luke Kenneth Casson Leighton lkcl@lkcl.net + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/clock.h> +#include <asm/arch/sys_proto.h> + +void clock_init_uart(void) +{ + struct sunxi_ccm_reg *const ccm = + (struct sunxi_ccm_reg *)SUNXI_CCM_BASE; + + /* uart clock source is apb2 */ + writel(APB2_CLK_SRC_OSC24M| + APB2_CLK_RATE_N_1| + APB2_CLK_RATE_M(1), + &ccm->apb2_div); + + /* open the clock for uart */ + setbits_le32(&ccm->apb2_gate, + CLK_GATE_OPEN << (APB2_GATE_UART_SHIFT + + CONFIG_CONS_INDEX - 1)); + + /* deassert uart reset */ + setbits_le32(&ccm->apb2_reset_cfg, + 1 << (APB2_RESET_UART_SHIFT + + CONFIG_CONS_INDEX - 1)); + + /* Dup with clock_init_safe(), drop once sun6i SPL support lands */ + writel(PLL6_CFG_DEFAULT, &ccm->pll6_cfg); +} + +int clock_twi_onoff(int port, int state) +{ + struct sunxi_ccm_reg *const ccm = + (struct sunxi_ccm_reg *)SUNXI_CCM_BASE; + + if (port > 3) + return -1; + + /* set the apb clock gate for twi */ + if (state) + setbits_le32(&ccm->apb2_gate, + CLK_GATE_OPEN << (APB2_GATE_TWI_SHIFT+port)); + else + clrbits_le32(&ccm->apb2_gate, + CLK_GATE_OPEN << (APB2_GATE_TWI_SHIFT+port)); + + return 0; +} + +unsigned int clock_get_pll6(void) +{ + struct sunxi_ccm_reg *const ccm = + (struct sunxi_ccm_reg *)SUNXI_CCM_BASE; + uint32_t rval = readl(&ccm->pll6_cfg); + int n = ((rval & CCM_PLL6_CTRL_N_MASK) >> CCM_PLL6_CTRL_N_SHIFT) + 1; + int k = ((rval & CCM_PLL6_CTRL_K_MASK) >> CCM_PLL6_CTRL_K_SHIFT) + 1; + return 24000000 * n * k / 2; +} diff --git a/arch/arm/include/asm/arch-sunxi/clock.h b/arch/arm/include/asm/arch-sunxi/clock.h index 5669f39..8f5d860 100644 --- a/arch/arm/include/asm/arch-sunxi/clock.h +++ b/arch/arm/include/asm/arch-sunxi/clock.h @@ -15,7 +15,11 @@ #define CLK_GATE_CLOSE 0x0
/* clock control module regs definition */ +#ifdef CONFIG_SUN6I +#include <asm/arch/clock_sun6i.h> +#else #include <asm/arch/clock_sun4i.h> +#endif
#ifndef __ASSEMBLY__ int clock_init(void); diff --git a/arch/arm/include/asm/arch-sunxi/clock_sun6i.h b/arch/arm/include/asm/arch-sunxi/clock_sun6i.h new file mode 100644 index 0000000..1397b35 --- /dev/null +++ b/arch/arm/include/asm/arch-sunxi/clock_sun6i.h @@ -0,0 +1,205 @@ +/* + * sun6i clock register definitions + * + * (C) Copyright 2007-2011 + * Allwinner Technology Co., Ltd. <www.allwinnertech.com> + * Tom Cubie tangliang@allwinnertech.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef _SUNXI_CLOCK_SUN6I_H +#define _SUNXI_CLOCK_SUN6I_H + +struct sunxi_ccm_reg { + u32 pll1_cfg; /* 0x00 pll1 control */ + u32 reserved0; + u32 pll2_cfg; /* 0x08 pll2 control */ + u32 reserved1; + u32 pll3_cfg; /* 0x10 pll3 control */ + u32 reserved2; + u32 pll4_cfg; /* 0x18 pll4 control */ + u32 reserved3; + u32 pll5_cfg; /* 0x20 pll5 control */ + u32 reserved4; + u32 pll6_cfg; /* 0x28 pll6 control */ + u32 reserved5; + u32 pll7_cfg; /* 0x30 pll7 control */ + u32 reserved6; + u32 pll8_cfg; /* 0x38 pll8 control */ + u32 reserved7; + u32 mipi_pll_cfg; /* 0x40 MIPI pll control */ + u32 pll9_cfg; /* 0x44 pll9 control */ + u32 pll10_cfg; /* 0x48 pll10 control */ + u32 reserved8; + u32 cpu_axi_cfg; /* 0x50 CPU/AXI divide ratio */ + u32 ahb1_apb1_div; /* 0x54 AHB1/APB1 divide ratio */ + u32 apb2_div; /* 0x58 APB2 divide ratio */ + u32 axi_gate; /* 0x5c axi module clock gating */ + u32 ahb_gate0; /* 0x60 ahb module clock gating 0 */ + u32 ahb_gate1; /* 0x64 ahb module clock gating 1 */ + u32 apb1_gate; /* 0x68 apb1 module clock gating */ + u32 apb2_gate; /* 0x6c apb2 module clock gating */ + u32 reserved9[4]; + u32 nand0_clk_cfg; /* 0x80 nand0 clock control */ + u32 nand1_clk_cfg; /* 0x84 nand1 clock control */ + u32 sd0_clk_cfg; /* 0x88 sd0 clock control */ + u32 sd1_clk_cfg; /* 0x8c sd1 clock control */ + u32 sd2_clk_cfg; /* 0x90 sd2 clock control */ + u32 sd3_clk_cfg; /* 0x94 sd3 clock control */ + u32 ts_clk_cfg; /* 0x98 transport stream clock control */ + u32 ss_clk_cfg; /* 0x9c security system clock control */ + u32 spi0_clk_cfg; /* 0xa0 spi0 clock control */ + u32 spi1_clk_cfg; /* 0xa4 spi1 clock control */ + u32 spi2_clk_cfg; /* 0xa8 spi2 clock control */ + u32 spi3_clk_cfg; /* 0xac spi3 clock control */ + u32 i2s0_clk_cfg; /* 0xb0 I2S0 clock control*/ + u32 i2s1_clk_cfg; /* 0xb4 I2S1 clock control */ + u32 reserved10[2]; + u32 spdif_clk_cfg; /* 0xc0 SPDIF clock control */ + u32 reserved11[2]; + u32 usb_clk_cfg; /* 0xcc USB clock control */ + u32 gmac_clk_cfg; /* 0xd0 GMAC clock control */ + u32 reserved12[7]; + u32 mdfs_clk_cfg; /* 0xf0 MDFS clock control */ + u32 dram_clk_cfg; /* 0xf4 DRAM configuration clock control */ + u32 reserved13[2]; + u32 dram_clk_gate; /* 0x100 DRAM module gating */ + u32 be0_clk_cfg; /* 0x104 BE0 module clock */ + u32 be1_clk_cfg; /* 0x108 BE1 module clock */ + u32 fe0_clk_cfg; /* 0x10c FE0 module clock */ + u32 fe1_clk_cfg; /* 0x110 FE1 module clock */ + u32 mp_clk_cfg; /* 0x114 MP module clock */ + u32 lcd0_ch0_clk_cfg; /* 0x118 LCD0 CH0 module clock */ + u32 lcd1_ch0_clk_cfg; /* 0x11c LCD1 CH0 module clock */ + u32 reserved14[3]; + u32 lcd0_ch1_clk_cfg; /* 0x12c LCD0 CH1 module clock */ + u32 lcd1_ch1_clk_cfg; /* 0x130 LCD1 CH1 module clock */ + u32 csi0_clk_cfg; /* 0x134 CSI0 module clock */ + u32 csi1_clk_cfg; /* 0x138 CSI1 module clock */ + u32 ve_clk_cfg; /* 0x13c VE module clock */ + u32 adda_clk_cfg; /* 0x140 ADDA module clock */ + u32 avs_clk_cfg; /* 0x144 AVS module clock */ + u32 dmic_clk_cfg; /* 0x148 Digital Mic module clock*/ + u32 reserved15; + u32 hdmi_clk_cfg; /* 0x150 HDMI module clock */ + u32 ps_clk_cfg; /* 0x154 PS module clock */ + u32 mtc_clk_cfg; /* 0x158 MTC module clock */ + u32 mbus0_clk_cfg; /* 0x15c MBUS0 module clock */ + u32 mbus1_clk_cfg; /* 0x160 MBUS1 module clock */ + u32 reserved16; + u32 mipi_dsi_clk_cfg; /* 0x168 MIPI DSI clock control */ + u32 mipi_csi_clk_cfg; /* 0x16c MIPI CSI clock control */ + u32 reserved17[4]; + u32 iep_drc0_clk_cfg; /* 0x180 IEP DRC0 module clock */ + u32 iep_drc1_clk_cfg; /* 0x184 IEP DRC1 module clock */ + u32 iep_deu0_clk_cfg; /* 0x188 IEP DEU0 module clock */ + u32 iep_deu1_clk_cfg; /* 0x18c IEP DEU1 module clock */ + u32 reserved18[4]; + u32 gpu_core_clk_cfg; /* 0x1a0 GPU core clock config */ + u32 gpu_mem_clk_cfg; /* 0x1a4 GPU memory clock config */ + u32 gpu_hyd_clk_cfg; /* 0x1a0 GPU HYD clock config */ + u32 reserved19[21]; + u32 pll_lock; /* 0x200 PLL Lock Time */ + u32 pll1_lock; /* 0x204 PLL1 Lock Time */ + u32 reserved20[6]; + u32 pll1_bias_cfg; /* 0x220 PLL1 Bias config */ + u32 pll2_bias_cfg; /* 0x224 PLL2 Bias config */ + u32 pll3_bias_cfg; /* 0x228 PLL3 Bias config */ + u32 pll4_bias_cfg; /* 0x22c PLL4 Bias config */ + u32 pll5_bias_cfg; /* 0x230 PLL5 Bias config */ + u32 pll6_bias_cfg; /* 0x234 PLL6 Bias config */ + u32 pll7_bias_cfg; /* 0x238 PLL7 Bias config */ + u32 pll8_bias_cfg; /* 0x23c PLL8 Bias config */ + u32 mipi_bias_cfg; /* 0x240 MIPI Bias config */ + u32 pll9_bias_cfg; /* 0x244 PLL9 Bias config */ + u32 pll10_bias_cfg; /* 0x248 PLL10 Bias config */ + u32 reserved21[13]; + u32 pll1_pattern_cfg; /* 0x280 PLL1 Pattern config */ + u32 pll2_pattern_cfg; /* 0x284 PLL2 Pattern config */ + u32 pll3_pattern_cfg; /* 0x288 PLL3 Pattern config */ + u32 pll4_pattern_cfg; /* 0x28c PLL4 Pattern config */ + u32 pll5_pattern_cfg; /* 0x290 PLL5 Pattern config */ + u32 pll6_pattern_cfg; /* 0x294 PLL6 Pattern config */ + u32 pll7_pattern_cfg; /* 0x298 PLL7 Pattern config */ + u32 pll8_pattern_cfg; /* 0x29c PLL8 Pattern config */ + u32 mipi_pattern_cfg; /* 0x2a0 MIPI Pattern config */ + u32 pll9_pattern_cfg; /* 0x2a4 PLL9 Pattern config */ + u32 pll10_pattern_cfg; /* 0x2a8 PLL10 Pattern config */ + u32 reserved22[5]; + u32 ahb_reset0_cfg; /* 0x2c0 AHB1 Reset 0 config */ + u32 ahb_reset1_cfg; /* 0x2c4 AHB1 Reset 1 config */ + u32 ahb_reset2_cfg; /* 0x2c8 AHB1 Reset 2 config */ + u32 reserved23; + u32 apb1_reset_cfg; /* 0x2d0 APB1 Reset config */ + u32 reserved24; + u32 apb2_reset_cfg; /* 0x2d8 APB2 Reset config */ +}; + +/* apb2 bit field */ +#define APB2_CLK_SRC_LOSC (0x0 << 24) +#define APB2_CLK_SRC_OSC24M (0x1 << 24) +#define APB2_CLK_SRC_PLL6 (0x2 << 24) +#define APB2_CLK_SRC_MASK (0x3 << 24) +#define APB2_CLK_RATE_N_1 (0x0 << 16) +#define APB2_CLK_RATE_N_2 (0x1 << 16) +#define APB2_CLK_RATE_N_4 (0x2 << 16) +#define APB2_CLK_RATE_N_8 (0x3 << 16) +#define APB2_CLK_RATE_N_MASK (3 << 16) +#define APB2_CLK_RATE_M(m) (((m)-1) << 0) +#define APB2_CLK_RATE_M_MASK (0x1f << 0) + +/* apb2 gate field */ +#define APB2_GATE_UART_SHIFT (16) +#define APB2_GATE_UART_MASK (0xff << APB2_GATE_UART_SHIFT) +#define APB2_GATE_TWI_SHIFT (0) +#define APB2_GATE_TWI_MASK (0xf << APB2_GATE_TWI_SHIFT) + +/* cpu_axi_cfg bits */ +#define AXI_DIV_SHIFT 0 +#define ATB_DIV_SHIFT 8 +#define CPU_CLK_SRC_SHIFT 16 + +#define AXI_DIV_1 0 +#define AXI_DIV_2 1 +#define AXI_DIV_3 2 +#define AXI_DIV_4 3 +#define ATB_DIV_1 0 +#define ATB_DIV_2 1 +#define ATB_DIV_4 2 +#define CPU_CLK_SRC_OSC24M 1 +#define CPU_CLK_SRC_PLL1 2 + +#define PLL1_CFG_DEFAULT 0x90011b21 + +#define PLL6_CFG_DEFAULT 0x90041811 + +#define CCM_PLL6_CTRL_N_SHIFT 8 +#define CCM_PLL6_CTRL_N_MASK (0x1f << CCM_PLL6_CTRL_N_SHIFT) +#define CCM_PLL6_CTRL_K_SHIFT 4 +#define CCM_PLL6_CTRL_K_MASK (0x3 << CCM_PLL6_CTRL_K_SHIFT) + +#define AHB_GATE_OFFSET_MMC3 11 +#define AHB_GATE_OFFSET_MMC2 10 +#define AHB_GATE_OFFSET_MMC1 9 +#define AHB_GATE_OFFSET_MMC0 8 +#define AHB_GATE_OFFSET_MMC(n) (AHB_GATE_OFFSET_MMC0 + (n)) + +#define CCM_MMC_CTRL_OSCM24 (0x0 << 24) +#define CCM_MMC_CTRL_PLL6 (0x1 << 24) + +#define CCM_MMC_CTRL_ENABLE (0x1 << 31) + +#define AHB_RESET_OFFSET_MMC3 11 +#define AHB_RESET_OFFSET_MMC2 10 +#define AHB_RESET_OFFSET_MMC1 9 +#define AHB_RESET_OFFSET_MMC0 8 +#define AHB_RESET_OFFSET_MMC(n) (AHB_RESET_OFFSET_MMC0 + (n)) + +/* apb2 reset */ +#define APB2_RESET_UART_SHIFT (16) +#define APB2_RESET_UART_MASK (0xff << APB2_RESET_UART_SHIFT) +#define APB2_RESET_TWI_SHIFT (0) +#define APB2_RESET_TWI_MASK (0xf << APB2_RESET_TWI_SHIFT) + +#endif /* _SUNXI_CLOCK_SUN6I_H */
The mmc hardware on sun6i has an extra reset control that needs to be de-asserted prior to usage. Also the FIFO address is different.
Signed-off-by: Hans de Goede hdegoede@redhat.com [wens@csie.org: use setbits_le32 for reset control, drop obsolete changes, rewrite different FIFO address handling, add commit message] Signed-off-by: Chen-Yu Tsai wens@csie.org Acked-by: Ian Campbell ijc@hellion.org.uk --- arch/arm/include/asm/arch-sunxi/mmc.h | 5 ++++- drivers/mmc/sunxi_mmc.c | 11 +++++++---- 2 files changed, 11 insertions(+), 5 deletions(-)
diff --git a/arch/arm/include/asm/arch-sunxi/mmc.h b/arch/arm/include/asm/arch-sunxi/mmc.h index 53196e3..6a31184 100644 --- a/arch/arm/include/asm/arch-sunxi/mmc.h +++ b/arch/arm/include/asm/arch-sunxi/mmc.h @@ -43,7 +43,10 @@ struct sunxi_mmc { u32 chda; /* 0x90 */ u32 cbda; /* 0x94 */ u32 res1[26]; - u32 fifo; /* 0x100 FIFO access address */ +#if defined(CONFIG_SUN6I) + u32 res2[64]; +#endif + u32 fifo; /* 0x100 (0x200 on sun6i) FIFO access address */ };
#define SUNXI_MMC_CLK_POWERSAVE (0x1 << 17) diff --git a/drivers/mmc/sunxi_mmc.c b/drivers/mmc/sunxi_mmc.c index bc2c4b3..8f4b50b 100644 --- a/drivers/mmc/sunxi_mmc.c +++ b/drivers/mmc/sunxi_mmc.c @@ -19,7 +19,6 @@ struct sunxi_mmc_host { unsigned mmc_no; uint32_t *mclkreg; - unsigned database; unsigned fatal_err; unsigned mod_clk; struct sunxi_mmc *reg; @@ -57,7 +56,6 @@ static int mmc_resource_init(int sdc_no) printf("Wrong mmc number %d\n", sdc_no); return -1; } - mmchost->database = (unsigned int)mmchost->reg + 0x100; mmchost->mmc_no = sdc_no;
return 0; @@ -75,6 +73,11 @@ static int mmc_clk_io_on(int sdc_no) /* config ahb clock */ setbits_le32(&ccm->ahb_gate0, 1 << AHB_GATE_OFFSET_MMC(sdc_no));
+#if defined(CONFIG_SUN6I) + /* unassert reset */ + setbits_le32(&ccm->ahb_reset0_cfg, 1 << AHB_RESET_OFFSET_MMC(sdc_no)); +#endif + /* config mod clock */ pll_clk = clock_get_pll6(); /* should be close to 100 MHz but no more, so round up */ @@ -194,9 +197,9 @@ static int mmc_trans_data_by_cpu(struct mmc *mmc, struct mmc_data *data) }
if (reading) - buff[i] = readl(mmchost->database); + buff[i] = readl(&mmchost->reg->fifo); else - writel(buff[i], mmchost->database); + writel(buff[i], &mmchost->reg->fifo); }
UART0 is the default debug/console UART on the A31.
Signed-off-by: Chen-Yu Tsai wens@csie.org Acked-by: Ian Campbell ijc@hellion.org.uk --- arch/arm/include/asm/arch-sunxi/gpio.h | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/arch/arm/include/asm/arch-sunxi/gpio.h b/arch/arm/include/asm/arch-sunxi/gpio.h index f7f3d8c..ba7e69b 100644 --- a/arch/arm/include/asm/arch-sunxi/gpio.h +++ b/arch/arm/include/asm/arch-sunxi/gpio.h @@ -132,6 +132,9 @@ enum sunxi_gpio_number {
#define SUN4I_GPH22_SDC1 5
+#define SUN6I_GPH20_UART0_TX 2 +#define SUN6I_GPH21_UART0_RX 2 + #define SUN4I_GPI4_SDC3 2
/* GPIO pin pull-up/down config */
From: Maxime Ripard maxime.ripard@free-electrons.com
Signed-off-by: Maxime Ripard maxime.ripard@free-electrons.com Signed-off-by: Hans de Goede hdegoede@redhat.com [wens@csie.org: commit message was "ARM: sunxi: Setup the A31 UART0 muxing"] [wens@csie.org: reorder #ifs by SUN?I] [wens@csie.org: replace magic numbers with GPIO definitions] Signed-off-by: Chen-Yu Tsai wens@csie.org Acked-by: Ian Campbell ijc@hellion.org.uk --- arch/arm/cpu/armv7/sunxi/board.c | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/arch/arm/cpu/armv7/sunxi/board.c b/arch/arm/cpu/armv7/sunxi/board.c index 95a74c5..b6d63db 100644 --- a/arch/arm/cpu/armv7/sunxi/board.c +++ b/arch/arm/cpu/armv7/sunxi/board.c @@ -58,6 +58,10 @@ int gpio_init(void) sunxi_gpio_set_cfgpin(SUNXI_GPB(19), SUN5I_GPB19_UART0_TX); sunxi_gpio_set_cfgpin(SUNXI_GPB(20), SUN5I_GPB20_UART0_RX); sunxi_gpio_set_pull(SUNXI_GPB(20), SUNXI_GPIO_PULL_UP); +#elif CONFIG_CONS_INDEX == 1 && defined(CONFIG_SUN6I) + sunxi_gpio_set_cfgpin(SUNXI_GPH(20), SUN6I_GPH20_UART0_TX); + sunxi_gpio_set_cfgpin(SUNXI_GPH(21), SUN6I_GPH21_UART0_RX); + sunxi_gpio_set_pull(SUNXI_GPH(21), SUNXI_GPIO_PULL_UP); #elif CONFIG_CONS_INDEX == 2 && defined(CONFIG_SUN5I) sunxi_gpio_set_cfgpin(SUNXI_GPG(3), SUN5I_GPG3_UART1_TX); sunxi_gpio_set_cfgpin(SUNXI_GPG(4), SUN5I_GPG4_UART1_RX);
Add a new sun6i machine that supports UART and MMC.
Signed-off-by: Maxime Ripard maxime.ripard@free-electrons.com Signed-off-by: Hans de Goede hdegoede@redhat.com [wens@csie.org: use SPDX labels, adapt to Kconfig system, drop ifdef around mmc and smp code, drop MACH_TYPE] Signed-off-by: Chen-Yu Tsai wens@csie.org Acked-by: Ian Campbell ijc@hellion.org.uk --- arch/arm/Kconfig | 3 +++ arch/arm/cpu/armv7/sunxi/cpu_info.c | 2 ++ board/sunxi/Kconfig | 10 +++++++++- include/configs/sun6i.h | 26 ++++++++++++++++++++++++++ 4 files changed, 40 insertions(+), 1 deletion(-) create mode 100644 include/configs/sun6i.h
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 3efede2..e3e7e78 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -444,6 +444,9 @@ config TARGET_SUN4I config TARGET_SUN5I bool "Support sun5i"
+config TARGET_SUN6I + bool "Support sun6i" + config TARGET_SUN7I bool "Support sun7i"
diff --git a/arch/arm/cpu/armv7/sunxi/cpu_info.c b/arch/arm/cpu/armv7/sunxi/cpu_info.c index 5cf35ac..40c4e13 100644 --- a/arch/arm/cpu/armv7/sunxi/cpu_info.c +++ b/arch/arm/cpu/armv7/sunxi/cpu_info.c @@ -23,6 +23,8 @@ int print_cpuinfo(void) case 7: puts("CPU: Allwinner A10s (SUN5I)\n"); break; default: puts("CPU: Allwinner A1X (SUN5I)\n"); } +#elif defined CONFIG_SUN6I + puts("CPU: Allwinner A31 (SUN6I)\n"); #elif defined CONFIG_SUN7I puts("CPU: Allwinner A20 (SUN7I)\n"); #else diff --git a/board/sunxi/Kconfig b/board/sunxi/Kconfig index bcd0a55..05defac 100644 --- a/board/sunxi/Kconfig +++ b/board/sunxi/Kconfig @@ -12,6 +12,14 @@ config SYS_CONFIG_NAME
endif
+if TARGET_SUN6I + +config SYS_CONFIG_NAME + string + default "sun6i" + +endif + if TARGET_SUN7I
config SYS_CONFIG_NAME @@ -19,7 +27,7 @@ config SYS_CONFIG_NAME
endif
-if TARGET_SUN4I || TARGET_SUN5I || TARGET_SUN7I +if TARGET_SUN4I || TARGET_SUN5I || TARGET_SUN6I || TARGET_SUN7I
config SYS_CPU default "armv7" diff --git a/include/configs/sun6i.h b/include/configs/sun6i.h new file mode 100644 index 0000000..93a1d96 --- /dev/null +++ b/include/configs/sun6i.h @@ -0,0 +1,26 @@ +/* + * (C) Copyright 2012-2013 Henrik Nordstrom henrik@henriknordstrom.net + * (C) Copyright 2013 Luke Kenneth Casson Leighton lkcl@lkcl.net + * (C) Copyright 2013 Maxime Ripard maxime.ripard@free-electrons.com + * + * Configuration settings for the Allwinner A31 (sun6i) CPU + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +/* + * A31 specific configuration + */ +#define CONFIG_SUN6I /* sun6i SoC generation */ + +#define CONFIG_SYS_PROMPT "sun6i# " + +/* + * Include common sunxi configuration where most the settings are + */ +#include <configs/sunxi-common.h> + +#endif /* __CONFIG_H */
The Colombus board is an A31 evaluation board from WITS Technology.
Maxime has kindly agreed to maintain this board.
[1] http://lists.denx.de/pipermail/u-boot/2014-September/190043.html
Signed-off-by: Chen-Yu Tsai wens@csie.org Cc: Maxime Ripard maxime.ripard@free-electrons.com --- board/sunxi/MAINTAINERS | 5 +++++ configs/Colombus_defconfig | 4 ++++ 2 files changed, 9 insertions(+) create mode 100644 configs/Colombus_defconfig
diff --git a/board/sunxi/MAINTAINERS b/board/sunxi/MAINTAINERS index 6c4226e..7afe45e 100644 --- a/board/sunxi/MAINTAINERS +++ b/board/sunxi/MAINTAINERS @@ -45,3 +45,8 @@ M: Iain Paton ipaton0@gmail.com S: Maintained F: board/sunxi/dram_a20_olinuxino_l2.c F: configs/A20-OLinuXino-Lime2_defconfig + +COLOMBUS BOARD +M: Maxime Ripard maxime.ripard@free-electrons.com +S: Maintained +F: configs/Colombus_defconfig diff --git a/configs/Colombus_defconfig b/configs/Colombus_defconfig new file mode 100644 index 0000000..16800de --- /dev/null +++ b/configs/Colombus_defconfig @@ -0,0 +1,4 @@ +CONFIG_SYS_EXTRA_OPTIONS="COLOMBUS" +CONFIG_ARM=y +CONFIG_TARGET_SUN6I=y +CONFIG_FDTFILE="sun6i-a31-colombus.dtb"
Acked-by: Maxime Ripard maxime.ripard@free-electrons.com
Thanks!
I'll apply these to u-boot-sunxi#next once I get a spare moment, probably over the w/e.
Cheers, Ian
Thanks. I'll do basic sun8i next.
Now done.
Cool, thanks!
Cheers, Ian.
Chen-Yu Tsai
Ian Campbell
Maxime Ripard
