[PATCH 1/1] efi_loader: free load options after execution
When be launch a binary via bootefi the bootargs environment variable is used to set the load options in the loaded image protocol.
Free memory allocated for load options when the UEFI binary exits.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- cmd/bootefi.c | 53 ++++++++++++++++++++------------------------------- 1 file changed, 21 insertions(+), 32 deletions(-)
diff --git a/cmd/bootefi.c b/cmd/bootefi.c index 78c8b8dbd1..bb8224437e 100644 --- a/cmd/bootefi.c +++ b/cmd/bootefi.c @@ -28,11 +28,13 @@ static struct efi_device_path *bootefi_device_path; /** * Set the load options of an image from an environment variable. * - * @handle: the image handle - * @env_var: name of the environment variable - * Return: status code + * @handle: the image handle + * @env_var: name of the environment variable + * @load_options: pointer to load options (output) + * Return: status code */ -static efi_status_t set_load_options(efi_handle_t handle, const char *env_var) +static efi_status_t set_load_options(efi_handle_t handle, const char *env_var, + u16 **load_options) { struct efi_loaded_image *loaded_image_info; size_t size; @@ -40,6 +42,7 @@ static efi_status_t set_load_options(efi_handle_t handle, const char *env_var) u16 *pos; efi_status_t ret;
+ *load_options = NULL; ret = EFI_CALL(systab.boottime->open_protocol( handle, &efi_guid_loaded_image, @@ -64,6 +67,7 @@ static efi_status_t set_load_options(efi_handle_t handle, const char *env_var) return EFI_OUT_OF_RESOURCES; } pos = loaded_image_info->load_options; + *load_options = pos; utf8_utf16_strcpy(&pos, env); loaded_image_info->load_options_size = size * 2;
@@ -298,9 +302,10 @@ static efi_status_t do_bootefi_exec(efi_handle_t handle) efi_status_t ret; efi_uintn_t exit_data_size = 0; u16 *exit_data = NULL; + u16 *load_options;
/* Transfer environment variable as load options */ - ret = set_load_options(handle, "bootargs"); + ret = set_load_options(handle, "bootargs", &load_options); if (ret != EFI_SUCCESS) return ret;
@@ -314,12 +319,7 @@ static efi_status_t do_bootefi_exec(efi_handle_t handle)
efi_restore_gd();
- /* - * FIXME: Who is responsible for - * free(loaded_image_info->load_options); - * Once efi_exit() is implemented correctly, - * handle itself doesn't exist here. - */ + free(load_options);
return ret; } -- 2.24.1
