[PATCH] ARM: zynq: Fix addresses in partition definitions
Node name should be <name>@<address> which is not how partitions are described.
arch/arm/dts/zynq-cse-qspi.dtsi | 10 +++++----- arch/arm/dts/zynq-topic-miami.dts | 10 +++++----- 2 files changed, 10 insertions(+), 10 deletions(-)
diff --git a/arch/arm/dts/zynq-cse-qspi.dtsi b/arch/arm/dts/zynq-cse-qspi.dtsi index 65af4081ff4f..eb0e29e6cb6e 100644 --- a/arch/arm/dts/zynq-cse-qspi.dtsi +++ b/arch/arm/dts/zynq-cse-qspi.dtsi @@ -67,23 +67,23 @@ spi-max-frequency = <50000000>; #address-cells = <1>; #size-cells = <1>; - partition@qspi-fsbl-uboot { + partition@0 { label = "qspi-fsbl-uboot"; reg = <0x0 0x100000>; }; - partition@qspi-linux { + partition@100000 { label = "qspi-linux"; reg = <0x100000 0x500000>; }; - partition@qspi-device-tree { + partition@600000 { label = "qspi-device-tree"; reg = <0x600000 0x20000>; }; - partition@qspi-rootfs { + partition@620000 { label = "qspi-rootfs"; reg = <0x620000 0x5E0000>; }; - partition@qspi-bitstream { + partition@c00000 { label = "qspi-bitstream"; reg = <0xC00000 0x400000>; }; diff --git a/arch/arm/dts/zynq-topic-miami.dts b/arch/arm/dts/zynq-topic-miami.dts index f6f10fe1a15d..ab6bde95fed9 100644 --- a/arch/arm/dts/zynq-topic-miami.dts +++ b/arch/arm/dts/zynq-topic-miami.dts @@ -44,23 +44,23 @@ spi-max-frequency = <100000000>; #address-cells = <1>; #size-cells = <1>; - partition@qspi-u-boot-spl { + partition@0 { label = "qspi-u-boot-spl"; reg = <0x00000 0x10000>; }; - partition@qspi-u-boot-img { + partition@10000 { label = "qspi-u-boot-img"; reg = <0x10000 0x60000>; }; - partition@qspi-device-tree { + partition@70000 { label = "qspi-device-tree"; reg = <0x70000 0x10000>; }; - partition@qspi-linux { + partition@80000 { label = "qspi-linux"; reg = <0x80000 0x400000>; }; - partition@qspi-rootfs { + partition@480000 { label = "qspi-rootfs"; reg = <0x480000 0x1b80000>; };
st 19. 2. 2020 v 11:28 odesÃlatel Michal Simek michal.simek@xilinx.com napsal:
-- 2.25.0
Applied. M
Michal Simek
Michal Simek
