[U-Boot] [PATCH v2] serial: sh: Add support for R7S72100 (RZ/A1)
Add support for RZ/A1 series SoCs.
Signed-off-by: Chris Brandt chris.brandt@renesas.com
--- v2: * Rebased against current tree --- drivers/serial/serial_sh.h | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/drivers/serial/serial_sh.h b/drivers/serial/serial_sh.h index 1b8d742f1c..1ea95509d7 100644 --- a/drivers/serial/serial_sh.h +++ b/drivers/serial/serial_sh.h @@ -226,7 +226,8 @@ struct uart_port { # define SCSCR_INIT(port) 0x38 /* TIE=0,RIE=0,TE=1,RE=1,REIE=1 */ #elif defined(CONFIG_R8A7790) || defined(CONFIG_R8A7791) || \ defined(CONFIG_R8A7792) || defined(CONFIG_R8A7793) || \ - defined(CONFIG_R8A7794) || defined(CONFIG_RCAR_GEN3) + defined(CONFIG_R8A7794) || defined(CONFIG_RCAR_GEN3) || \ + defined(CONFIG_R7S72100) # if defined(CONFIG_SCIF_A) # define SCIF_ORER 0x0200 # else
Applied, thanks !
btw. are you planning to do DT/DM conversion of the RZ/A1 ?
v2:
- Rebased against current tree
- defined(CONFIG_R8A7794) || defined(CONFIG_RCAR_GEN3) || \
- defined(CONFIG_R7S72100)
On Friday, January 19, 2018 1, Marek Vasut wrote:
Applied, thanks !
Thank you!
DM, yes. DT, no
We're working on adding DM to RZ/A's I2C and timer drivers now. Then we'll try submitting it.
But as for DT, I think that's still a bit overkill for RZ/A series.
Chris
Applied, thanks !
Thank you!
DM, yes. DT, no
Cool!
Why so?
Why so?
Honestly, I don't see the value in it for small embedded systems.
u-boot has a specific job and is compiled for a specific board. There is no need for multi board booting.
I think moving things DM is OK, but that's because it's all done in the same code that gets compiled today (no separate build steps).
And...then you have 3 things to customize: 1. config file (legacy .h file) because not everything is moved into Kconfig 2. menuconfig (for the stuff that has been moved) 3. DT (for a few things)
Chris
Why so?
For now at least, it'd be real neat to have one u-boot build for generic rz/a1 , concatenate DT to it and be done with a board port.
- config file (legacy .h file) because not everything is moved into Kconfig
- menuconfig (for the stuff that has been moved)
- DT (for a few things)
Chris
I think there is always going to be 'low level weird stuff' specific for each board, so you'll never be able to do it all with a DT (for an actual product that is).
Even in our Linux BSP, I still always have a board-xxx.c file for anything not easily handled in DT.
Chris
I wonder if we really cannot get to the point where we can have a universal build, add DT to it and be done with a board port. That'd be real cool and it'd make things easy for people using the chip ... :)
Then I'd be out of a job!
You can still write the DTs ;-)
Chris Brandt
Chris Brandt
