[U-Boot] [PATCH] ARM: socfpga: Update README with BSP/header generation instructions
This patch adds back the steps to manually (re)build a Quartus FPGA project, generate the required BSP glue, and update u-boot headers for mainline SPL support (updated from an earlier patch submitted by Stefan Roese). Requires Quartus toolchain and current U-Boot.
Signed-off-by: Steve Arnold stephen.arnold42@gmail.com Cc: Dinh Nguyen dinguyen@kernel.org Cc: Stefan Roese sr@denx.de Cc: Marek Vasut marex@denx.de --- doc/README.socfpga | 141 +++++++++++++++++++++++++++++++++++++++++++++++++++-- 1 file changed, 136 insertions(+), 5 deletions(-)
diff --git a/doc/README.socfpga b/doc/README.socfpga index cb805cfd3a..4783fdc52f 100644 --- a/doc/README.socfpga +++ b/doc/README.socfpga @@ -1,18 +1,149 @@ - --------------------------------------------- +---------------------------------------- SOCFPGA Documentation for U-Boot and SPL --------------------------------------------- +----------------------------------------
This README is about U-Boot and SPL support for Altera's ARM Cortex-A9MPCore based SOCFPGA. To know more about the hardware itself, please refer to www.altera.com.
--------------------------------------------- socfpga_dw_mmc --------------------------------------------- +-------------- + Here are macro and detailed configuration required to enable DesignWare SDMMC controller support within SOCFPGA
#define CONFIG_SYS_MMC_MAX_BLK_COUNT 256 -> Using smaller max blk cnt to avoid flooding the limited stack in OCRAM + +----------------------------------------------------------------------------------- +Generating the header files for SPL intergration as a replacement for the Preloader +----------------------------------------------------------------------------------- + +This text has been updated based on testing with Quartus Lite 16.1 and a rebuilt +DE1_SOC_Linux_FB demo project (https://github.com/VCTLabs/DE1_SOC_Linux_FB). The +FB project can now be built manually (as below) or with the project Makefile. + +Note: it *should* work from Quartus 14.0.200 onwards. + +Rebuilding your Quartus project +------------------------------- + +Using the cli +~~~~~~~~~~~~~ + +First run the embedded command shell, using your path to the Quartus install: + + $ ${HOME}/intelFPGA/16.1/embedded/embedded_command_shell.sh + +Then (if necessary) update the IP cores in the project, generate HDL code, and +build the project: + + $ cd path/to/project/dir + $ qsys-generate soc_system.qsys --upgrade-ip-cores + $ qsys-generate soc_system.qsys --synthesis=[VERILOG|VHDL] + $ quartus_map <project_name> + $ quartus_fit <project_name> + $ quartus_asm <project_name> + +Convert the .sof file to a firmware blob: + + $ quartus_cpf -c <project_name>.sof soc_system.rbf + +Now you can skip the GUI section. + +Using the Qsys GUI +~~~~~~~~~~~~~~~~~~ + + 1) Navigate to your project directory + 2) Run Quartus II + 3) Open Project (Ctrl+J), select <project_name>.qpf + 4) Run QSys [Tools->QSys] + 4.1) In the Open dialog, select 'mcv_hps.qsys' + 4.2) In the Open System dialog, wait until completion and press 'Close' + 4.3) In the Qsys window, click on 'Generate HDL...' in bottom right corner + 4.3.1) In the 'Generation' window, click 'Generate' + 4.3.2) In the 'Generate' dialog, wait until completion and click 'Close' + 4.4) In the QSys window, click 'Finish' + 4.4.1) In the 'Quartus II' pop up window, click 'OK' + 5) Back in Quartus II main window, do the following + 5.1) Use Processing -> Start -> Start Analysis & Synthesis (Ctrl+K) + 5.2) Use Processing -> Start Compilation (Ctrl+L) + ... this may take some time, have patience ... + + 6) Launch a separate terminal window + 6.1) Change directory to 'software/spl_bsp' + 6.2) Export path to embedded command shell and friends + $ export PATH=path/to/quartus/embedded/:$PATH + 6.3) Start embedded command shell (ECS) + $ embedded_command_shell.sh + 6.4) Prepare BSP by launching the BSP editor from ECS + => bsp-editor + 6.5) In BSP editor + 6.5.1) Use File -> Open + 6.5.2) Select 'settings.bsp' file + 6.5.4) Click Generate + 6.5.5) Click Exit + +Generate BSP dir +~~~~~~~~~~~~~~~~ + +You can run the bsp editor GUI above, but the easy way for u-boot is to run the +following command from the project directory: + + $ /path/to/bsb/tools/bsp-create-settings --type spl --bsp-dir build \ + --preloader-settings-dir hps_isw_handoff/soc_system_hps_0/ \ + --settings build/settings.bsp + +Now you can use the "build" dir above (ie, where the settings.bsp file is) in +the following u-boot command to update the board headers. Once these headers +are updated for a given project build, u-boot should be configured for the +project board (eg, de0-nano-sockit) and then build the normal spl build. + + +Update U-Boot headers +~~~~~~~~~~~~~~~~~~~~~ + +Now the necessary files are generated. And U-Boot can be used to generate +the SPL header files. For this, please use the following script from the +u-boot source tree: + + $ ./arch/arm/mach-socfpga/qts-filter.sh \ + <soc_type> \ + <input_qts_dir> \ + <input_bsp_dir> \ + <output_dir> + +Process QTS-generated headers into U-Boot compatible ones. + + soc_type - Type of SoC, either 'cyclone5' or 'arria5'. + input_qts_dir - Directory with compiled Quartus project + and containing the Quartus project file (QPF). + input_bsp_dir - Directory with generated bsp containing + the settings.bsp file. + output_dir - Directory to store the U-Boot compatible + headers. + +This will generate the following 4 files: + +iocsr_config.h +pinmux_config.h +pll_config.h +sdram_config.h + +These files need to be copied into "qts" directory in the board directory +(see output argument of qts-filter.sh command above). + +Here is the example for the DE-0 Nano SocKit: + +$ ll board/terasic/de0-nano-soc/qts/ +total 44 +drwxrwxr-x 2 stefan stefan 4096 Okt 20 07:07 ./ +drwxrwxr-x 3 stefan stefan 4096 Okt 21 13:06 ../ +-rw-rw-r-- 1 stefan stefan 8826 Okt 20 07:07 iocsr_config.h +-rw-rw-r-- 1 stefan stefan 4398 Okt 20 07:07 pinmux_config.h +-rw-rw-r-- 1 stefan stefan 3192 Okt 20 07:07 pll_config.h +-rw-rw-r-- 1 stefan stefan 9031 Okt 20 07:07 sdram_config.h + +Now your board is ready for full mainline support including U-Boot SPL. +The Preloader will not be needed any more.
On 03/10/2017 09:03 PM, Steve Arnold wrote:
Hi!
lots of nitpicks below, but it really is starting to get into a good shape, thanks for the work and sorry for my delayed reply.
^ '- back? It's not like we ever had those in ...
Which was based on earlier docs by me, but do we really need that info in commit message ?
socfpga_dw_mmc
"integration" (type) , but you can reword it in much shorter way
Generating the handoff header files for U-Boot SPL
This text is assuming quartus 16.1 , but newer versions will probably work just fine too.
You should make it clear that the user should use his own quartus project for his own board here.
+Using the cli
command line instead of cli please
- $ ${HOME}/intelFPGA/16.1/embedded/embedded_command_shell.sh
Replace ${HOME} with /path/to/ , since the tools are usually not installed in ~
- $ cd path/to/project/dir
- $ qsys-generate soc_system.qsys --upgrade-ip-cores
- $ qsys-generate soc_system.qsys --synthesis=[VERILOG|VHDL]
- $ quartus_map <project_name>
- $ quartus_fit <project_name>
- $ quartus_asm <project_name>
You can replace the last three with
$ quartus_sh --flow compile <project name>
- $ quartus_cpf -c <project_name>.sof soc_system.rbf
Convert the .sof file (SRAM object file) to .rbf file (Raw bit file):
OK
- Navigate to your project directory
- Run Quartus II
- Open Project (Ctrl+J), select <project_name>.qpf
- Run QSys [Tools->QSys]
- 4.1) In the Open dialog, select 'mcv_hps.qsys'
probably not mcv_hps.qsys , right ?
- 4.2) In the Open System dialog, wait until completion and press 'Close'
- 4.3) In the Qsys window, click on 'Generate HDL...' in bottom right corner
- 4.4) In the QSys window, click 'Finish'
- Back in Quartus II main window, do the following
- 5.1) Use Processing -> Start -> Start Analysis & Synthesis (Ctrl+K)
- 5.2) Use Processing -> Start Compilation (Ctrl+L)
- ... this may take some time, have patience ...
- Launch a separate terminal window
Here you're entering the embedded command shell again, see the command line section above , we should make sure this bit of documentation is not duplicated.
- 6.1) Change directory to 'software/spl_bsp'
- 6.2) Export path to embedded command shell and friends
- 6.3) Start embedded command shell (ECS)
- 6.4) Prepare BSP by launching the BSP editor from ECS
=> bsp-editor
- 6.5) In BSP editor
6.5.5) Click Exit
+Generate BSP dir
Generate BSP handoff files ?
Shouldn't this be part of the command line section above ? Since the GUI section documents this functionality using GUI tool
It has nothing to do with u-boot , this is still bsp-editor :)
- $ /path/to/bsb/tools/bsp-create-settings --type spl --bsp-dir build \
s/dir/directory/
There is no de0-nano-sockit, there's either sockit or de0-nano , pick one.
Handoff files please , not headers .
The qts-filter script (which is part of U-Boot tree) is used to process the handoff files generated by bsp-editor .
- $ ./arch/arm/mach-socfpga/qts-filter.sh \
<soc_type> \
<input_qts_dir> \
<input_bsp_dir> \
<output_dir>
- soc_type - Type of SoC, either 'cyclone5' or 'arria5'.
- input_qts_dir - Directory with compiled Quartus project
- input_bsp_dir - Directory with generated bsp containing
- output_dir - Directory to store the U-Boot compatible
headers.
That's DE0-Nano-SoC , not SoCkit ;-)
The sizes don't match what's in mainline u-boot ;-)
Steve Arnold
