[U-Boot] [PATCH] sunxi: Add Wexler TAB7200 support
This patch add support for Wexler TAB7200 tablet.
The Wexler TAB7200 is a A20 based tablet with 7 inch display(800x480), capacitive touchscreen(5 fingers), 1G RAM, 4G NAND, micro SD card slot, mini HDMI port, 3.5mm audio plug, 1 USB OTG port and 1 USB 2.0 port.
Signed-off-by: Aleksei Mamlin mamlinav@gmail.com --- board/sunxi/MAINTAINERS | 5 +++++ configs/Wexler_TAB7200_defconfig | 13 +++++++++++++ 2 files changed, 18 insertions(+) create mode 100644 configs/Wexler_TAB7200_defconfig
diff --git a/board/sunxi/MAINTAINERS b/board/sunxi/MAINTAINERS index 3e6ce88..53a9fea 100644 --- a/board/sunxi/MAINTAINERS +++ b/board/sunxi/MAINTAINERS @@ -130,3 +130,8 @@ TZX-Q8-713B7 BOARD M: Paul Kocialkowski contact@paulk.fr S: Maintained F: configs/TZX-Q8-713B7_defconfig + +WEXLER-TAB7200 BOARD +M: Aleksei Mamlin mamlinav@gmail.com +S: Maintained +F: configs/Wexler_TAB7200_defconfig diff --git a/configs/Wexler_TAB7200_defconfig b/configs/Wexler_TAB7200_defconfig new file mode 100644 index 0000000..6c15dc8 --- /dev/null +++ b/configs/Wexler_TAB7200_defconfig @@ -0,0 +1,13 @@ +CONFIG_SPL=y +CONFIG_SYS_EXTRA_OPTIONS="AXP209_POWER,USB_EHCI" +CONFIG_FDTFILE="sun7i-a20-wexler-tab7200.dtb" +CONFIG_VIDEO_LCD_MODE="x:800,y:480,depth:24,pclk_khz:33000,le:45,ri:210,up:22,lo:22,hs:1,vs:1,sync:3,vmode:0" +CONFIG_VIDEO_LCD_POWER="PH8" +CONFIG_VIDEO_LCD_BL_EN="PH7" +CONFIG_VIDEO_LCD_BL_PWM="PB2" ++S:CONFIG_ARM=y ++S:CONFIG_ARCH_SUNXI=y ++S:CONFIG_MACH_SUN7I=y ++S:CONFIG_DRAM_CLK=384 ++S:CONFIG_DRAM_ZQ=127 ++S:CONFIG_DRAM_EMR1=4
Thanks, I've queued this up in u-boot-sunxi/next for merging upstream.
Regards,
Hans
Aleksei Mamlin
Hans de Goede
