[U-Boot] [PATCH] mx6: Add workaround for ARM errata
Add workaround for the following ARM errata: 743622 and 751472.
The motivation for this change is the following kernel commit 62e4d357a (ARM: 7609/1: disable errata work-arounds which access secure registers), which removes the errata from multiplatform kernel.
Since imx has been converted to multiplatform in the kernel, we need to apply such workaround into the bootloader.
Workaround code has been taken from arch/arm/mm/proc-v7.S from 3.7.1 kernel.
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- Following patch has been proposed into arm kernel mailing list: http://www.spinics.net/lists/arm-kernel/msg214840.html
arch/arm/cpu/armv7/mx6/lowlevel_init.S | 10 ++++++++++ 1 file changed, 10 insertions(+)
diff --git a/arch/arm/cpu/armv7/mx6/lowlevel_init.S b/arch/arm/cpu/armv7/mx6/lowlevel_init.S index acadef2..bf06152 100644 --- a/arch/arm/cpu/armv7/mx6/lowlevel_init.S +++ b/arch/arm/cpu/armv7/mx6/lowlevel_init.S @@ -20,6 +20,16 @@
#include <linux/linkage.h>
+.macro init_arm_errata + /* ARM erratum ID #743622 */ + mrceq p15, 0, r10, c15, c0, 1 /* read diagnostic register */ + orreq r10, r10, #1 << 6 /* set bit #6 */ + /* ARM erratum ID #751472 */ + orrlt r10, r10, #1 << 11 /* set bit #11 */ + mcrlt p15, 0, r10, c15, c0, 1 /* write diagnostic register */ +.endm + ENTRY(lowlevel_init) + init_arm_errata mov pc, lr ENDPROC(lowlevel_init)
Fabio Estevam
