[U-Boot] [PATCH] usb: gadget: ci_udc: implement usb_ep_ops dequeue callback
Implement endpoint dequeue callback function.
Without this function, uboot will hang when executing fastboot comamnd. See following flow: "fastboot_tx_write_str->fastboot_tx_write->usb_ep_dequeue->ep->ops->dequeue" without implement ci_udc dequeue function, ep->ops->dequeue is NULL, then uboot will hang.
Tested on mx6qsabresd board with fastboot enabled.
Signed-off-by: Peng Fan Peng.Fan@freescale.com Cc: "Łukasz Majewski" l.majewski@samsung.com Cc: Marek Vasut marex@denx.de --- drivers/usb/gadget/ci_udc.c | 28 ++++++++++++++++++++++++++++ 1 file changed, 28 insertions(+)
diff --git a/drivers/usb/gadget/ci_udc.c b/drivers/usb/gadget/ci_udc.c index 3e8eb87..f9374b3 100644 --- a/drivers/usb/gadget/ci_udc.c +++ b/drivers/usb/gadget/ci_udc.c @@ -87,6 +87,7 @@ static int ci_ep_enable(struct usb_ep *ep, static int ci_ep_disable(struct usb_ep *ep); static int ci_ep_queue(struct usb_ep *ep, struct usb_request *req, gfp_t gfp_flags); +static int ci_ep_dequeue(struct usb_ep *ep, struct usb_request *req); static struct usb_request * ci_ep_alloc_request(struct usb_ep *ep, unsigned int gfp_flags); static void ci_ep_free_request(struct usb_ep *ep, struct usb_request *_req); @@ -99,6 +100,7 @@ static struct usb_ep_ops ci_ep_ops = { .enable = ci_ep_enable, .disable = ci_ep_disable, .queue = ci_ep_queue, + .dequeue = ci_ep_dequeue, .alloc_request = ci_ep_alloc_request, .free_request = ci_ep_free_request, }; @@ -525,6 +527,32 @@ static void ci_ep_submit_next_request(struct ci_ep *ci_ep) writel(bit, &udc->epprime); }
+static int ci_ep_dequeue(struct usb_ep *_ep, struct usb_request *_req) +{ + struct ci_ep *ci_ep = container_of(_ep, struct ci_ep, ep); + struct ci_req *ci_req; + + list_for_each_entry(ci_req, &ci_ep->queue, queue) { + if (&ci_req->req == _req) + break; + } + + if (&ci_req->req != _req) + return -EINVAL; + + list_del_init(&ci_req->queue); + + if (ci_req->req.status == -EINPROGRESS) { + ci_req->req.status = -ECONNRESET; + if (ci_req->req.complete) + ci_req->req.complete(_ep, _req); + } + + debug("callback completed\n"); + + return 0; +} + static int ci_ep_queue(struct usb_ep *ep, struct usb_request *req, gfp_t gfp_flags) {
Without this function, uboot will hang when executing fastboot comamnd. See following flow: "fastboot_tx_write_str->fastboot_tx_write->usb_ep_dequeue->ep->ops->dequeue " without implement ci_udc dequeue function, ep->ops->dequeue is NULL, then uboot will hang.
- .dequeue = ci_ep_dequeue, .alloc_request = ci_ep_alloc_request, .free_request = ci_ep_free_request,
- struct ci_ep *ci_ep = container_of(_ep, struct ci_ep, ep);
- struct ci_req *ci_req;
- list_for_each_entry(ci_req, &ci_ep->queue, queue) {
break;
- if (&ci_req->req != _req)
return -EINVAL;
- list_del_init(&ci_req->queue);
- if (ci_req->req.status == -EINPROGRESS) {
- debug("callback completed\n");
Please fix this useless debug() statement, either remove it, or at least make it print __func__ so one can identify where this came from.
Looks good otherwise:
Is there no need to reprogram the HW to abort the transfer?
I checked linux udc driver drivers/usb/gadget/udc/fsl_qe_udc.c qe_ep_dequeue->done->usb_gadget_giveback_request->"req->complete(ep, req)" I did not see code to reprogram the HW to abort the transfer.
Regards, Peng. --
Do you have further comments? I checked other gadget drivers in drivers/usb/gadget/, I did not see drivers that reprogram the HW to abort the transfer. For now, I do not think out a scenario to reprogram the HW to abort the transfer
Regards, Peng.
Regards, Peng. --
Marek, what are the semantics of this function? Is it supposed to simply update SW state to make U-Boot not care about the transaction, or is it supposed to actually stop the HW performing the transaction on the USB bus?
If it's the former, then the patch is likely fine. If it's the latter, then I think the function does need actually need to do something to make the HW stop, or we can't implement this particular function.
Hi Stephen,
sorry for the delayed reply, I had to dig into the code myself.
Hi Stephen,
Without this function, uboot will hang when executing fastboot comamnd. See following flow: "fastboot_tx_write_str->fastboot_tx_write->usb_ep_dequeue->ep->ops->d equeue " without implement ci_udc dequeue function, ep->ops->dequeue is NULL, then uboot will hang.
Yes, that's correct.
No, it's not supposed to kill the transaction in hardware.
Do we need this for the current release or is this for -next ?
Best regards, Marek Vasut
Hi Stephen,
Hi Stephen,
On Thursday, August 27, 2015 at 01:00:50 PM, Peng Fan wrote: > Implement endpoint dequeue callback function. > > Without this function, uboot will hang when executing fastboot > comamnd. See following flow: > "fastboot_tx_write_str->fastboot_tx_write->usb_ep_dequeue->ep->ops->d > equeue " without implement ci_udc dequeue function, ep->ops->dequeue > is NULL, then uboot will hang. > > Tested on mx6qsabresd board with fastboot enabled. > > diff --git a/drivers/usb/gadget/ci_udc.c > b/drivers/usb/gadget/ci_udc.c > > +static int ci_ep_dequeue(struct usb_ep *_ep, struct usb_request > *_req) > > + if (ci_req->req.status == -EINPROGRESS) { > + ci_req->req.status = -ECONNRESET; > + if (ci_req->req.complete) > + ci_req->req.complete(_ep, _req); > + }
OK, the patch seems fine then.
I assume that's a question for Peng?
Hi Stephen,
Hi Stephen,
On 08/27/2015 05:08 AM, Marek Vasut wrote: > On Thursday, August 27, 2015 at 01:00:50 PM, Peng Fan wrote: >> Implement endpoint dequeue callback function. >> >> Without this function, uboot will hang when executing fastboot >> comamnd. See following flow: >> "fastboot_tx_write_str->fastboot_tx_write->usb_ep_dequeue->ep->ops->d >> equeue " without implement ci_udc dequeue function, ep->ops->dequeue >> is NULL, then uboot will hang. >> >> Tested on mx6qsabresd board with fastboot enabled. >> >> diff --git a/drivers/usb/gadget/ci_udc.c >> b/drivers/usb/gadget/ci_udc.c >> >> +static int ci_ep_dequeue(struct usb_ep *_ep, struct usb_request >> *_req) >> >> + if (ci_req->req.status == -EINPROGRESS) { >> + ci_req->req.status = -ECONNRESET; >> + if (ci_req->req.complete) >> + ci_req->req.complete(_ep, _req); >> + }
Since this is a bug fix, I think this patch should be in current release. Without this patch, boards which want to enable fastboot using ci_udc driver will hang.
Regards, Peng.
Hi Marek,
Hi Stephen,
Hi Stephen,
On Thu, Aug 27, 2015 at 10:06:14AM -0600, Stephen Warren wrote: > On 08/27/2015 05:08 AM, Marek Vasut wrote: >> On Thursday, August 27, 2015 at 01:00:50 PM, Peng Fan wrote: >>> Implement endpoint dequeue callback function. >>> >>> Without this function, uboot will hang when executing fastboot >>> comamnd. See following flow: >>> "fastboot_tx_write_str->fastboot_tx_write->usb_ep_dequeue->ep->ops->d >>> equeue " without implement ci_udc dequeue function, ep->ops->dequeue >>> is NULL, then uboot will hang. >>> >>> Tested on mx6qsabresd board with fastboot enabled. >>> >>> diff --git a/drivers/usb/gadget/ci_udc.c >>> b/drivers/usb/gadget/ci_udc.c >>> >>> +static int ci_ep_dequeue(struct usb_ep *_ep, struct usb_request >>> *_req) >>> >>> + if (ci_req->req.status == -EINPROGRESS) { >>> + ci_req->req.status = -ECONNRESET; >>> + if (ci_req->req.complete) >>> + ci_req->req.complete(_ep, _req); >>> + } > > Is there no need to reprogram the HW to abort the transfer?
If you have plan to pick the bug fix, please pick V2. https://patchwork.ozlabs.org/patch/511739/
Thanks, Peng.
Regards, Peng.
On Wednesday, September 09, 2015 at 06:30:20 AM, Peng Fan wrote:
Hi Marek,
Hi!
Hi Stephen,
On Fri, Aug 28, 2015 at 08:05:36AM +0800, Peng Fan wrote: > Hi Stephen, > > On Thu, Aug 27, 2015 at 10:06:14AM -0600, Stephen Warren wrote: >> On 08/27/2015 05:08 AM, Marek Vasut wrote: >>> On Thursday, August 27, 2015 at 01:00:50 PM, Peng Fan wrote: >>>> Implement endpoint dequeue callback function. >>>> >>>> Without this function, uboot will hang when executing fastboot >>>> comamnd. See following flow: >>>> "fastboot_tx_write_str->fastboot_tx_write->usb_ep_dequeue->ep->op >>>> s->d equeue " without implement ci_udc dequeue function, >>>> ep->ops->dequeue is NULL, then uboot will hang. >>>> >>>> Tested on mx6qsabresd board with fastboot enabled. >>>> >>>> diff --git a/drivers/usb/gadget/ci_udc.c >>>> b/drivers/usb/gadget/ci_udc.c >>>> >>>> +static int ci_ep_dequeue(struct usb_ep *_ep, struct usb_request >>>> *_req) >>>> >>>> + if (ci_req->req.status == -EINPROGRESS) { >>>> + ci_req->req.status = -ECONNRESET; >>>> + if (ci_req->req.complete) >>>> + ci_req->req.complete(_ep, _req); >>>> + } >> >> Is there no need to reprogram the HW to abort the transfer? > > I checked linux udc driver drivers/usb/gadget/udc/fsl_qe_udc.c > qe_ep_dequeue->done->usb_gadget_giveback_request->"req->complete(ep, > req)" I did not see code to reprogram the HW to abort the transfer.
Aye aye, sir! One applied patch, coming right up!
break;
return -EINVAL;
Will remove it and send out v2 with your Reviewed-by Tag.
Thanks, Peng. --
Peng Fan
Peng Fan
Stephen Warren
