[U-Boot-Users] Compiling relocatable code and DATA for PPC
I have been trying to find out right options to configure gcc to produce data and code relocatable code for mpc5xx. The -fpic -meabi -msdata=eabi -G10000 does code as relocatable but data is still absolute. -fpic is incompatible with -msdata=eabi so they can't be used at same time.
based on gcc documentations -msdata=eabi -G10000 should put data so long that it is smaller than valu give in -G option to relative to r2 or r3 but i have not suceeded to do it.
I have been using gcc for producing absolute code for PPC many, many years but now i have need to load dynamically code for non mmu PPC (mpc555). All examples that i have found uses static addresses. Also using google i have not found any answers.
I have tried many forums to find answer but i am still trying to find it. Also i am happy to get pointers to forums/places where i can continue my search.
Kate
If this is for U-Boot, why don't you just the pre-configured options? They work fine.
This sounds as if you do not understand what relocatable means. Of course relocatable code may use absolute addressing. "relocatable" is different from "position independent".
What is your environment? U-Boot?
You will either have to use PIC (which is not what U-Boot does), or use a static link address (which is what U-Boot does for standalone applications), or use relocatable code that you can (manually) relocate to a target address of your choice (which is what U-Boot does for the U-Boot code itself).
The thing that i like to use is PIC and PID ( position independent data and code ). U-boot allows to load my code in any address and i really don't like to manually relocate it. I like to have ready compiled code parts in mass media ( flash ) and i like to to allow load them to any free address.
There is this same problem allways if you use non-mmu processor like MPC555 and you like to load more than just one fixed program into memory. You should remember that the applications loaded with u-boot are not allways just "stand-alone" apps or Linux. Based on my knowledge there is not even Linux for mpc555. I our case i like to load my open source rtos kernel ( Katix ) and then applications for it.
Becouse u-boot runs in many non-mmu processors i was just thinking that some u-boot user has had same problem and find already answer.
I have searched all around internet to find answer but not yet find one. -fpic should make program code position independent and -msdata=eabi -G20000 should put all static data smaller than 20000 bytes to relative to r2(const data) or r13 . For some reason gcc says that -msdata=eabi and -fpic are incompatible and even -msdata=eabi does not make data references as register relative.
Kate
Kate Alhola
