[U-Boot] [PATCH] socrates: change default mtest address range
Running mtest command on socrates without specifying an address range crashes the board. This patch changes default mtest address range to prevent this behavior.
Signed-off-by: Anatolij Gustschin agust@denx.de --- include/configs/socrates.h | 4 ++-- 1 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/include/configs/socrates.h b/include/configs/socrates.h index 28e8fd2..bbb9d18 100644 --- a/include/configs/socrates.h +++ b/include/configs/socrates.h @@ -87,8 +87,8 @@ #define CFG_INIT_DBCR DBCR_IDM /* Enable Debug Exceptions */
#undef CFG_DRAM_TEST /* memory test, takes time */ -#define CFG_MEMTEST_START 0x00000000 -#define CFG_MEMTEST_END 0x10000000 +#define CFG_MEMTEST_START 0x00400000 +#define CFG_MEMTEST_END 0x00C00000
/* * Base addresses -- Note these are effective addresses where the
Dear Anatolij Gustschin,
Applied, thanks.
Andy, I hope this is OK with you - the patch affects only this single board.
Anatolij Gustschin
