[U-Boot] [PATCH] fs: btrfs: Fix unaligned memory accesses
Loading files stored with lzo compression from a btrfs filesystem was producing unaligned memory accesses, which were causing a data abort and a reset on an Orange Pi Zero.
The change in hash.c is not triggered by any error but follows the same pattern. Please confirm.
Fixed according to doc/README.unaligned-memory-access.txt
Signed-off by: Alberto Sánchez Molero alsamolero@gmail.com --- fs/btrfs/compression.c | 5 +++-- fs/btrfs/hash.c | 3 ++- 2 files changed, 5 insertions(+), 3 deletions(-)
diff --git a/fs/btrfs/compression.c b/fs/btrfs/compression.c index a59ff5a..4e685a0 100644 --- a/fs/btrfs/compression.c +++ b/fs/btrfs/compression.c @@ -9,6 +9,7 @@ #include "btrfs.h" #include <linux/lzo.h> #include <u-boot/zlib.h> +#include <asm/unaligned.h>
static u32 decompress_lzo(const u8 *cbuf, u32 clen, u8 *dbuf, u32 dlen) { @@ -19,7 +20,7 @@ static u32 decompress_lzo(const u8 *cbuf, u32 clen, u8 *dbuf, u32 dlen) if (clen < 4) return -1;
- tot_len = le32_to_cpu(*(u32 *) cbuf); + tot_len = le32_to_cpu(get_unaligned((u32 *) cbuf)); cbuf += 4; clen -= 4; tot_len -= 4; @@ -32,7 +33,7 @@ static u32 decompress_lzo(const u8 *cbuf, u32 clen, u8 *dbuf, u32 dlen) res = 0;
while (tot_len > 4) { - in_len = le32_to_cpu(*(u32 *) cbuf); + in_len = le32_to_cpu(get_unaligned((u32 *) cbuf)); cbuf += 4; clen -= 4;
diff --git a/fs/btrfs/hash.c b/fs/btrfs/hash.c index f8a50e5..1c75ea8 100644 --- a/fs/btrfs/hash.c +++ b/fs/btrfs/hash.c @@ -8,6 +8,7 @@
#include "btrfs.h" #include <u-boot/crc.h> +#include <asm/unaligned.h>
static u32 btrfs_crc32c_table[256];
@@ -34,5 +35,5 @@ u32 btrfs_csum_data(char *data, u32 seed, size_t len)
void btrfs_csum_final(u32 crc, void *result) { - *((u32 *) result) = cpu_to_le32(~crc); + put_unaligned(cpu_to_le32(~crc), (u32 *) result); }
On Sat, Jan 20, 2018 at 1:17 AM, Alberto Sánchez Molero alsamolero@gmail.com wrote:
Awesome!
Marek, this fixes the issue i was also seeing on the Beagle's with lzo compression.
Tested-by: Robert Nelson robertcnelson@gmail.com
- tot_len = le32_to_cpu(get_unaligned((u32 *) cbuf)); cbuf += 4; clen -= 4; tot_len -= 4;
- put_unaligned(cpu_to_le32(~crc), (u32 *) result);
2.16.0 _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de https://lists.denx.de/listinfo/u-boot
Hi Alberto, Thanks. I just forwarded this to Robert Nelson who encountered this issue. You can add Reviewed-by: Marek Behun marek.behun@nic.cz
Marek
On Sat, 20 Jan 2018 09:17:57 +0200 Alberto Sánchez Molero alsamolero@gmail.com wrote:
Weird, wonder how my email failed to go thru.
I've been running a few boards with btrfs/lzo enable this week, with this patch on top of v2018.01 and everythink looks great!
Regards,
Signed-off-by: Alberto Sánchez Molero alsamolero@gmail.com Tested-by: Robert Nelson robertcnelson@gmail.com
Marek Behún
Robert Nelson
