[U-Boot] [PATCH] i2c: imx_lpi2c: add ipg clk
The controller needs two clk, per clk and ipg clk, so let's add ipg clk.
Signed-off-by: Peng Fan peng.fan@nxp.com --- drivers/i2c/imx_lpi2c.c | 11 +++++++++++ include/imx_lpi2c.h | 1 + 2 files changed, 12 insertions(+)
diff --git a/drivers/i2c/imx_lpi2c.c b/drivers/i2c/imx_lpi2c.c index 4586d4331f..2de99d019e 100644 --- a/drivers/i2c/imx_lpi2c.c +++ b/drivers/i2c/imx_lpi2c.c @@ -471,6 +471,17 @@ static int imx_lpi2c_probe(struct udevice *bus) dev_err(bus, "Failed to enable per clk\n"); return ret; } + + ret = clk_get_by_name(bus, "ipg", &i2c_bus->ipg_clk); + if (ret) { + dev_err(bus, "Failed to get ipg clk\n"); + return ret; + } + ret = clk_enable(&i2c_bus->ipg_clk); + if (ret) { + dev_err(bus, "Failed to enable ipg clk\n"); + return ret; + } } else { /* To i.MX7ULP, only i2c4-7 can be handled by A7 core */ ret = enable_i2c_clk(1, bus->seq); diff --git a/include/imx_lpi2c.h b/include/imx_lpi2c.h index 2700e5f876..3ce9edaf10 100644 --- a/include/imx_lpi2c.h +++ b/include/imx_lpi2c.h @@ -18,6 +18,7 @@ struct imx_lpi2c_bus { struct i2c_pads_info *pads_info; struct udevice *bus; struct clk per_clk; + struct clk ipg_clk; };
struct imx_lpi2c_reg {
Hi Peng,
On Wed, 24 Jul 2019 08:54:16 +0000 Peng Fan peng.fan@nxp.com wrote: ...
if (ret) {
return ret;
imx8dx/imx8qxp device trees do not have ipg clock in I2C nodes, here probing will fail. Should we add I2C ipg clock to imx8x dts files? Or is it required only for imx8qm?
-- Anatolij
Subject: Re: [PATCH] i2c: imx_lpi2c: add ipg clk
Hi Peng,
if (ret) {
return ret;
The dts should be fixed. Seems upstream Linux also not have ipg clk, downstream has it. Let's fix Linux first.
Thanks, Peng.
-- Anatolij
Anatolij Gustschin
Peng Fan
