[U-Boot] [PATCH] mmc: Delete unused driver ftsdc021_sdhci
CONFIG_FTSDC021 is not defined anywhere. So ftsdc021_sdhci.c is never compiled.
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com --- drivers/mmc/Makefile | 1 - drivers/mmc/ftsdc021_sdhci.c | 33 --------------------------------- 2 files changed, 34 deletions(-) delete mode 100644 drivers/mmc/ftsdc021_sdhci.c
diff --git a/drivers/mmc/Makefile b/drivers/mmc/Makefile index 1ed26ca..a7ae38d 100644 --- a/drivers/mmc/Makefile +++ b/drivers/mmc/Makefile @@ -9,7 +9,6 @@ obj-$(CONFIG_BFIN_SDH) += bfin_sdh.o obj-$(CONFIG_DAVINCI_MMC) += davinci_mmc.o obj-$(CONFIG_FSL_ESDHC) += fsl_esdhc.o obj-$(CONFIG_FTSDC010) += ftsdc010_mci.o -obj-$(CONFIG_FTSDC021) += ftsdc021_sdhci.o obj-$(CONFIG_GENERIC_MMC) += mmc.o obj-$(CONFIG_GENERIC_ATMEL_MCI) += gen_atmel_mci.o obj-$(CONFIG_MMC_SPI) += mmc_spi.o diff --git a/drivers/mmc/ftsdc021_sdhci.c b/drivers/mmc/ftsdc021_sdhci.c deleted file mode 100644 index 1f6cdba..0000000 --- a/drivers/mmc/ftsdc021_sdhci.c +++ /dev/null @@ -1,33 +0,0 @@ -/* - * (C) Copyright 2013 Faraday Technology - * Kuo-Jung Su dantesu@faraday-tech.com - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <malloc.h> -#include <sdhci.h> - -#ifndef CONFIG_FTSDC021_CLOCK -#define CONFIG_FTSDC021_CLOCK clk_get_rate("MMC") -#endif - -int ftsdc021_sdhci_init(u32 regbase) -{ - struct sdhci_host *host = NULL; - uint32_t freq = CONFIG_FTSDC021_CLOCK; - - host = calloc(1, sizeof(struct sdhci_host)); - if (!host) { - puts("sdh_host malloc fail!\n"); - return 1; - } - - host->name = "FTSDC021"; - host->ioaddr = (void __iomem *)regbase; - host->quirks = 0; - add_sdhci(host, freq, 0); - - return 0; -}
Hi Masahiro:
Sorry, it's my bad to send out FTSDC021 patch before committing the corresponding platforms. The corresponding Faraday SoC platforms should be soon committed into u-boot-arm. (I wish...)
P.S: This also applies to
1. spi:ftssp010 2. i2c: fti2c010 3. net:ftmac110 4. usb: ehci: faraday fotg210/fusbh200 5. usb: gadget: fotg210
Best Wishes Dante Su
2014/1/8 Masahiro Yamada yamada.m@jp.panasonic.com:
- (C) Copyright 2013 Faraday Technology
- Kuo-Jung Su dantesu@faraday-tech.com
if (!host) {
return 1;
host->quirks = 0;
1.8.3.2
Hello Kuo-Jung
OK. I retract this patch.
Tom, please reject this patch.
Best Regards Masahiro Yamada
2014/1/9 Masahiro Yamada yamada.m@jp.panasonic.com:
Hello Kuo-Jung
Thanks for your understanding
Kuo-Jung Su
Masahiro Yamada
