[U-Boot] Ethernet on i.MX8MM with mainline U-Boot
Hi Peng,
I tried to get Ethernet running on i.MX8MM with mainline U-Boot and your latest patches for SoC-support. I added the missing clocks, but something still seems to be wrong. It seems like the clock parents are not set correctly.
If I run "dm tree", I see that the enet_axi is a child of clock-osc-24m, but I would expect it to be under sys_pll1_266m as specified in the devicetree.
Do you have an idea what could be wrong or some working code to look at?
Thanks for your help!
Regards, Frieder
Hi Frider,
-----Original Message----- From: Schrempf Frieder frieder.schrempf@kontron.de Sent: 2019年9月17日 21:49 To: Peng Fan peng.fan@nxp.com Cc: u-boot@lists.denx.de Subject: Ethernet on i.MX8MM with mainline U-Boot
Hi Peng,
I think it might be clk_set_defaults not work for U-Boot proper. I have not tried enet. Will give a look.
Regards, Peng.
Regards, Frieder
Peng Fan
Schrempf Frieder
