[PATCH v2] imx8*_venice_defconfig: configure default MMC env device
When booting from USB/SDP mmc_get_env_dev() returns CONFIG_SYS_MMC_ENV_DEV as the MMC env device (while booting from MMC will call board_mmc_get_env_dev() to get this). Configure CONFIG_SYS_MMC_ENV_DEV for SDHC3 (devno=2) as all Gateworks Venice boards use SDHC3 as eMMC so that persistent env works when booting from USB/SDP.
Reviewed-by: Fabio Estevam festevam@denx.de Signed-off-by: Tim Harvey tharvey@gateworks.com --- v2: - add Fabio's Reviewed-by tag - fixed spelling error in commit log --- configs/imx8mm_venice_defconfig | 1 + configs/imx8mn_venice_defconfig | 1 + configs/imx8mp_venice_defconfig | 1 + 3 files changed, 3 insertions(+)
diff --git a/configs/imx8mm_venice_defconfig b/configs/imx8mm_venice_defconfig index ac0cee9705b0..05be8e4a20b5 100644 --- a/configs/imx8mm_venice_defconfig +++ b/configs/imx8mm_venice_defconfig @@ -75,6 +75,7 @@ CONFIG_SPL_OF_CONTROL=y CONFIG_OF_LIST="imx8mm-venice imx8mm-venice-gw71xx-0x imx8mm-venice-gw72xx-0x imx8mm-venice-gw73xx-0x imx8mm-venice-gw7901 imx8mm-venice-gw7902 imx8mm-venice-gw7903" CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_SYS_MMC_ENV_DEV=2 CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y CONFIG_USE_ETHPRIME=y CONFIG_ETHPRIME="eth0" diff --git a/configs/imx8mn_venice_defconfig b/configs/imx8mn_venice_defconfig index 935de023161a..09287a5ae3f1 100644 --- a/configs/imx8mn_venice_defconfig +++ b/configs/imx8mn_venice_defconfig @@ -78,6 +78,7 @@ CONFIG_SPL_OF_CONTROL=y CONFIG_OF_LIST="imx8mn-venice imx8mn-venice-gw7902" CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_SYS_MMC_ENV_DEV=2 CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y CONFIG_USE_ETHPRIME=y CONFIG_ETHPRIME="eth0" diff --git a/configs/imx8mp_venice_defconfig b/configs/imx8mp_venice_defconfig index 7fdde41b6da5..9013a1164e9b 100644 --- a/configs/imx8mp_venice_defconfig +++ b/configs/imx8mp_venice_defconfig @@ -77,6 +77,7 @@ CONFIG_SPL_OF_CONTROL=y CONFIG_OF_LIST="imx8mp-venice imx8mp-venice-gw74xx" CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_SYS_MMC_ENV_DEV=2 CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_IP_DEFRAG=y
Reviewed-by: Peng Fan peng.fan@nxp.com
v2:
When booting from USB/SDP mmc_get_env_dev() returns CONFIG_SYS_MMC_ENV_DEV as the MMC env device (while booting from MMC will call board_mmc_get_env_dev() to get this). Configure CONFIG_SYS_MMC_ENV_DEV for SDHC3 (devno=2) as all Gateworks Venice boards use SDHC3 as eMMC so that persistent env works when booting from USB/SDP. Reviewed-by: Fabio Estevam festevam@denx.de Signed-off-by: Tim Harvey tharvey@gateworks.com Reviewed-by: Peng Fan peng.fan@nxp.com
Best regards, Stefano Babic
Peng Fan
sbabic@denx.de
Tim Harvey
