Re: [U-Boot-Users] DBGFLASGS in MPC8272ADS
4 Nov
2004
4 Nov
'04
5:13 p.m.
In message <1099582987.418a4e0b80676@webmail.televes.com:443> you wrote:
However, all this stuff doesn't explain or solves the other problem ... why the -DDEBUG flag doesn't works?
Most probably because someone was clever and added (but never tested) debug statements to code that is running before console output is available. If you try to use printf() too early (i. e. before the serial port has been initialized and assigned) you will run into trouble.
See us @ Embedded/Electronica Munich, Nov 09 - 12, Hall A.6 Booth 513
Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de
You Don't Have To Be 'Damned' To Work Here, But It Helps!!!
- Terry Pratchett, _Eric_
7495
