On the OMAP3 EVM board, I have four partition on my Onenand flash of which /dev/mtd4 is a JFFS2 partition.
After booting up linux, I use the following command to mount the jffs2 empty partition.
Linux#> mount -t jffs2 /dev/mtdblock4 /mnt
Then I do a reboot .
When u-boot boots up it gives bad erase block for all the blocks used by /dev/mtd4.
The reason is the JFFS2 filesystem is putting some signature at location 0x0 and 0x1 of OOB locations of every block.
Is there a way this can be avoided ?
Regards Mani
Pillai, Manikandan said the following on 03/16/2009 01:35 PM:
A) mount -t jffs2 /dev/mtdblock4 /mnt umount /mnt sync reboot
this gives the garbage collector time to put the cleanmarkers in place.
B) is the kernel's oob layout and ECC strategy (h/w vs s/w ecc) same as that used for u-boot?
Regards, Nishanth Menon
The cleanmarkers are being written in location 0x0 and 0x1 of the OOB space And they are the problem since when u-boot comes up it does a scan and decided That since these OOB locations do not contain 0xff, the blocks are bad.
Regards Manikandan
-----Original Message----- From: Nishanth Menon [mailto:menon.nishanth@gmail.com] Sent: Monday, March 16, 2009 5:09 PM To: Pillai, Manikandan Cc: u-boot@lists.denx.de Subject: Re: [U-Boot] U-boot and JFFS2
partition.
/dev/mtd4.
of every block.
Pillai, Manikandan said the following on 03/16/2009 01:41 PM:
offset 0 and 1 in a x16 large page micron device is reserved for badblock marker - u-boot is checking the correct location and if those locations dont have 0xff, it is noted as bad blocks. if cleanmarker is being written there, you'd need to fix the kernel board file etc.. Regards, Nishanth Menon
offset 0 and 1 in a x16 large page micron device is reserved for badblock marker - u-boot is checking the correct location and if those locations dont have 0xff, it is noted as bad blocks - This is no issue with u-boot as far as I can see but on the other hand the clean markers are also supposed to be in the same location.
I am not clear on the other part of the answer. Do you mean to say I need to fix the kernel code for cleanmarker issue ? Is it like I can give an offset for the Cleanmarker to be written ?
regards Mani
-----Original Message----- From: Nishanth Menon [mailto:menon.nishanth@gmail.com] Sent: Monday, March 16, 2009 5:15 PM To: Pillai, Manikandan Cc: u-boot@lists.denx.de Subject: Re: [U-Boot] U-boot and JFFS2
decided
Pillai, Manikandan said the following on 03/17/2009 06:41 AM:
Why do you say that? ooblayout free is used if I am not wrong to store cleanmarkers. have you compared the layouts of the kernel Vs u-boot? if there is a delta, I suppose a good idea is to fix the kernel board file (we've had more than enough oob discussions for omap3 gpmc i suppose on u-boot ml ;) )..
I believe you can, essentially coz you can choose where the ecc region is, jffs2 should store cleanmarkers in free area. Regards, Nishanth Menon
Nishanth Menon
Pillai, Manikandan
