[U-Boot] [PATCH v5 1/2] common: Rewrite hiding the end of memory
As the name may be confusing, the CONFIG_SYS_MEM_TOP_HIDE reserves some memory from the end of ram, tracked by gd->ram_size. It is not always the top of u-boot visible memory. Rewrite the macro with a weak function to provide flexibility for complex calcuation. Legacy use of this macro is still supported.
Signed-off-by: York Sun yorksun@freescale.com
Changes in v5: Separated as a new patch
Changes in v4: None Changes in v3: None Changes in v2: None
README | 2 +- common/board_f.c | 23 +++++++++++++++-------- 2 files changed, 16 insertions(+), 9 deletions(-)
diff --git a/README b/README index 6ea1af2..4aa2aae 100644 --- a/README +++ b/README @@ -3877,7 +3877,7 @@ Configuration Settings: the RAM base is not zero, or RAM is divided into banks, this variable needs to be recalcuated to get the address.
-- CONFIG_SYS_MEM_TOP_HIDE (PPC only): +- CONFIG_SYS_MEM_TOP_HIDE: If CONFIG_SYS_MEM_TOP_HIDE is defined in the board config header, this specified memory area will get subtracted from the top (end) of RAM and won't get "touched" at all by U-Boot. By diff --git a/common/board_f.c b/common/board_f.c index e13657f..51d8814 100644 --- a/common/board_f.c +++ b/common/board_f.c @@ -317,6 +317,15 @@ __weak ulong board_get_usable_ram_top(ulong total_size) return gd->ram_top; }
+__weak phys_size_t board_reserve_ram_top(phys_size_t ram_size) +{ +#ifdef CONFIG_SYS_MEM_TOP_HIDE + return ram_size - CONFIG_SYS_MEM_TOP_HIDE; +#else + return ram_size; +#endif +} + static int setup_dest_addr(void) { debug("Monitor len: %08lX\n", gd->mon_len); @@ -333,19 +342,17 @@ static int setup_dest_addr(void) */ gd->secure_ram = gd->ram_size; #endif -#if defined(CONFIG_SYS_MEM_TOP_HIDE) /* * Subtract specified amount of memory to hide so that it won't * get "touched" at all by U-Boot. By fixing up gd->ram_size * the Linux kernel should now get passed the now "corrected" - * memory size and won't touch it either. This should work - * for arch/ppc and arch/powerpc. Only Linux board ports in - * arch/powerpc with bootwrapper support, that recalculate the - * memory size from the SDRAM controller setup will have to - * get fixed. + * memory size and won't touch it either. This has been used + * by arch/powerpc exclusively. Now ARMv8 takes advantage of + * thie mechanism. If memory is split into banks, addresses + * need to be calculated. */ - gd->ram_size -= CONFIG_SYS_MEM_TOP_HIDE; -#endif + gd->ram_size = board_reserve_ram_top(gd->ram_size); + #ifdef CONFIG_SYS_SDRAM_BASE gd->ram_top = CONFIG_SYS_SDRAM_BASE; #endif
MC and debug server are not board-specific. Move reserving memory to SoC file, using the new board_reserve_ram_top function. Reduce debug server memory by 2MB to make room for secure memory.
In the system with MC and debug server, the top of u-boot memory is not the end of memory. PRAM is not used for this reservation.
Changes in v5: Separated changes in board_f.c
Changes in v4: Rebase to current master branch
Changes in v3: Rename CONFIG_SYS_MC_RESERV_MEM_ALIGN to CONFIG_SYS_MC_RSV_MEM_ALIGN Check for unused CONFIG_SYS_MEM_TOP_HIDE if board_reserve_ram_top is used Use gd->ram_size = board_reserve_ram_top(gd->ram_size) format Use phys_size_t instead of ulong for ram_size calculation
Changes in v2: Revise commit message.
README | 4 ++-- arch/arm/cpu/armv8/fsl-layerscape/cpu.c | 21 +++++++++++++++++++++ board/freescale/ls2080a/ls2080a.c | 17 ----------------- board/freescale/ls2080aqds/ls2080aqds.c | 17 ----------------- board/freescale/ls2080ardb/ls2080ardb.c | 17 ----------------- include/configs/ls2080a_common.h | 9 ++------- 6 files changed, 25 insertions(+), 60 deletions(-)
diff --git a/README b/README index 4aa2aae..43f307f 100644 --- a/README +++ b/README @@ -5056,8 +5056,8 @@ This firmware often needs to be loaded during U-Boot booting. - CONFIG_SYS_DEBUG_SERVER_DRAM_BLOCK_MIN_SIZE Define minimum DDR size required for debug server image
-- CONFIG_SYS_MEM_TOP_HIDE_MIN - Define minimum DDR size to be hided from top of the DDR memory +- CONFIG_SYS_MC_RSV_MEM_ALIGN + Define alignment of reserved memory MC requires
Reproducible builds ------------------- diff --git a/arch/arm/cpu/armv8/fsl-layerscape/cpu.c b/arch/arm/cpu/armv8/fsl-layerscape/cpu.c index 87ccaf1..6ea28ed 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/cpu.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/cpu.c @@ -636,3 +636,24 @@ void reset_cpu(ulong addr) val |= 0x02; scfg_out32(rstcr, val); } + +phys_size_t board_reserve_ram_top(phys_size_t ram_size) +{ + phys_size_t ram_top = ram_size; + +#ifdef CONFIG_SYS_MEM_TOP_HIDE +#error CONFIG_SYS_MEM_TOP_HIDE not to be used together with this function +#endif +/* Carve the Debug Server private DRAM block from the end of DRAM */ +#ifdef CONFIG_FSL_DEBUG_SERVER + ram_top -= debug_server_get_dram_block_size(); +#endif + +/* Carve the MC private DRAM block from the end of DRAM */ +#ifdef CONFIG_FSL_MC_ENET + ram_top -= mc_get_dram_block_size(); + ram_top &= ~(CONFIG_SYS_MC_RSV_MEM_ALIGN - 1); +#endif + + return ram_top; +} diff --git a/board/freescale/ls2080a/ls2080a.c b/board/freescale/ls2080a/ls2080a.c index 827fbf0..7bce8b0 100644 --- a/board/freescale/ls2080a/ls2080a.c +++ b/board/freescale/ls2080a/ls2080a.c @@ -68,23 +68,6 @@ int arch_misc_init(void) } #endif
-unsigned long get_dram_size_to_hide(void) -{ - unsigned long dram_to_hide = 0; - -/* Carve the Debug Server private DRAM block from the end of DRAM */ -#ifdef CONFIG_FSL_DEBUG_SERVER - dram_to_hide += debug_server_get_dram_block_size(); -#endif - -/* Carve the MC private DRAM block from the end of DRAM */ -#ifdef CONFIG_FSL_MC_ENET - dram_to_hide += mc_get_dram_block_size(); -#endif - - return roundup(dram_to_hide, CONFIG_SYS_MEM_TOP_HIDE_MIN); -} - int board_eth_init(bd_t *bis) { int error = 0; diff --git a/board/freescale/ls2080aqds/ls2080aqds.c b/board/freescale/ls2080aqds/ls2080aqds.c index 1f99072..aa256a2 100644 --- a/board/freescale/ls2080aqds/ls2080aqds.c +++ b/board/freescale/ls2080aqds/ls2080aqds.c @@ -253,23 +253,6 @@ int arch_misc_init(void) } #endif
-unsigned long get_dram_size_to_hide(void) -{ - unsigned long dram_to_hide = 0; - -/* Carve the Debug Server private DRAM block from the end of DRAM */ -#ifdef CONFIG_FSL_DEBUG_SERVER - dram_to_hide += debug_server_get_dram_block_size(); -#endif - -/* Carve the MC private DRAM block from the end of DRAM */ -#ifdef CONFIG_FSL_MC_ENET - dram_to_hide += mc_get_dram_block_size(); -#endif - - return roundup(dram_to_hide, CONFIG_SYS_MEM_TOP_HIDE_MIN); -} - #ifdef CONFIG_FSL_MC_ENET void fdt_fixup_board_enet(void *fdt) { diff --git a/board/freescale/ls2080ardb/ls2080ardb.c b/board/freescale/ls2080ardb/ls2080ardb.c index 2ae9d6c..c63b639 100644 --- a/board/freescale/ls2080ardb/ls2080ardb.c +++ b/board/freescale/ls2080ardb/ls2080ardb.c @@ -219,23 +219,6 @@ int arch_misc_init(void) } #endif
-unsigned long get_dram_size_to_hide(void) -{ - unsigned long dram_to_hide = 0; - -/* Carve the Debug Server private DRAM block from the end of DRAM */ -#ifdef CONFIG_FSL_DEBUG_SERVER - dram_to_hide += debug_server_get_dram_block_size(); -#endif - -/* Carve the MC private DRAM block from the end of DRAM */ -#ifdef CONFIG_FSL_MC_ENET - dram_to_hide += mc_get_dram_block_size(); -#endif - - return roundup(dram_to_hide, CONFIG_SYS_MEM_TOP_HIDE_MIN); -} - #ifdef CONFIG_FSL_MC_ENET void fdt_fixup_board_enet(void *fdt) { diff --git a/include/configs/ls2080a_common.h b/include/configs/ls2080a_common.h index 969aed6..4ae7d11 100644 --- a/include/configs/ls2080a_common.h +++ b/include/configs/ls2080a_common.h @@ -195,10 +195,9 @@ unsigned long long get_qixis_addr(void); * 512MB aligned, so the min size to hide is 512MB. */ #if defined(CONFIG_FSL_MC_ENET) || defined(CONFIG_FSL_DEBUG_SERVER) -#define CONFIG_SYS_DEBUG_SERVER_DRAM_BLOCK_MIN_SIZE (256UL * 1024 * 1024) +#define CONFIG_SYS_DEBUG_SERVER_DRAM_BLOCK_MIN_SIZE (254UL * 1024 * 1024) #define CONFIG_SYS_LS_MC_DRAM_BLOCK_MIN_SIZE (256UL * 1024 * 1024) -#define CONFIG_SYS_MEM_TOP_HIDE_MIN (512UL * 1024 * 1024) -#define CONFIG_SYS_MEM_TOP_HIDE get_dram_size_to_hide() +#define CONFIG_SYS_MC_RSV_MEM_ALIGN (512UL * 1024 * 1024) #endif
/* PCIe */ @@ -290,10 +289,6 @@ unsigned long long get_qixis_addr(void); #define CONFIG_AUTO_COMPLETE #define CONFIG_SYS_MAXARGS 64 /* max command args */
-#ifndef __ASSEMBLY__ -unsigned long get_dram_size_to_hide(void); -#endif - #define CONFIG_PANIC_HANG /* do not reset board on panic */
#define CONFIG_SPL_BSS_START_ADDR 0x80100000
Applied to fsl-qoriq master. Awaiting upstream.
York
York
York Sun
