[U-Boot] [PATCH 1/2] drivers: net: fsl-mc: Define PHY_RESET_R function
DPAA2 platforms boot the Management Complex based on the u-boot env variable "mcinitcmd". Instead of doing this step on each platform individually, define a reset_phy function in the MC driver, since it's semantically tied to it and it gets called at a later moment, when all board PHY devices have been initialized.
Signed-off-by: Bogdan Purcareata bogdan.purcareata@nxp.com Signed-off-by: Heinz Wrobel heinz.wrobel@nxp.com --- board/freescale/ls2080aqds/eth.c | 8 -------- board/freescale/ls2080ardb/eth_ls2080rdb.c | 7 +------ drivers/net/fsl-mc/mc.c | 18 ++++++++++++++++++ include/configs/ls2080a_common.h | 5 +++++ 4 files changed, 24 insertions(+), 14 deletions(-)
diff --git a/board/freescale/ls2080aqds/eth.c b/board/freescale/ls2080aqds/eth.c index 59361e9..23feb9b 100644 --- a/board/freescale/ls2080aqds/eth.c +++ b/board/freescale/ls2080aqds/eth.c @@ -834,7 +834,6 @@ void ls2080a_handle_phy_interface_xsgmii(int i) int board_eth_init(bd_t *bis) { int error; - char *mc_boot_env_var; #ifdef CONFIG_FSL_MC_ENET struct ccsr_gur __iomem *gur = (void *)CONFIG_SYS_FSL_GUTS_ADDR; int serdes1_prtcl = (in_le32(&gur->rcwsr[28]) & @@ -902,9 +901,6 @@ int board_eth_init(bd_t *bis) } }
- mc_boot_env_var = getenv(MC_BOOT_ENV_VAR); - if (mc_boot_env_var) - run_command_list(mc_boot_env_var, -1, 0); error = cpu_eth_init(bis);
if (hwconfig_f("xqsgmii", env_hwconfig)) { @@ -918,7 +914,3 @@ int board_eth_init(bd_t *bis) error = pci_eth_init(bis); return error; } - -#ifdef CONFIG_FSL_MC_ENET - -#endif diff --git a/board/freescale/ls2080ardb/eth_ls2080rdb.c b/board/freescale/ls2080ardb/eth_ls2080rdb.c index ba584c8..0a8500b 100644 --- a/board/freescale/ls2080ardb/eth_ls2080rdb.c +++ b/board/freescale/ls2080ardb/eth_ls2080rdb.c @@ -20,11 +20,9 @@
DECLARE_GLOBAL_DATA_PTR;
-#define MC_BOOT_ENV_VAR "mcinitcmd" int board_eth_init(bd_t *bis) { #if defined(CONFIG_FSL_MC_ENET) - char *mc_boot_env_var; int i, interface; struct memac_mdio_info mdio_info; struct mii_dev *dev; @@ -98,11 +96,8 @@ int board_eth_init(bd_t *bis) } }
- mc_boot_env_var = getenv(MC_BOOT_ENV_VAR); - if (mc_boot_env_var) - run_command_list(mc_boot_env_var, -1, 0); cpu_eth_init(bis); -#endif /* CONFIG_FMAN_ENET */ +#endif /* CONFIG_FSL_MC_ENET */
#ifdef CONFIG_PHY_AQUANTIA /* diff --git a/drivers/net/fsl-mc/mc.c b/drivers/net/fsl-mc/mc.c index 9f69d75..afaf285 100644 --- a/drivers/net/fsl-mc/mc.c +++ b/drivers/net/fsl-mc/mc.c @@ -26,6 +26,7 @@
#define MC_MEM_SIZE_ENV_VAR "mcmemsize" #define MC_BOOT_TIMEOUT_ENV_VAR "mcboottimeout" +#define MC_BOOT_ENV_VAR "mcinitcmd"
DECLARE_GLOBAL_DATA_PTR; static int mc_boot_status = -1; @@ -1362,3 +1363,20 @@ U_BOOT_CMD( "fsl_mc lazyapply DPL [DPL_addr] - Apply DPL file on exit\n" "fsl_mc start aiop [FW_addr] - Start AIOP\n" ); + +#if defined(CONFIG_RESET_PHY_R) +void reset_phy(void) +{ +#if defined(CONFIG_FSL_MC_ENET) + char *mc_boot_env_var; + /* The MC may only be initialized in the reset PHY function + * because otherwise U-Boot has not yet set up all the MAC + * address info properly. Without MAC addresses, the MC code + * can not properly initialize the DPC. + */ + mc_boot_env_var = getenv(MC_BOOT_ENV_VAR); + if (mc_boot_env_var) + run_command_list(mc_boot_env_var, -1, 0); +#endif /* CONFIG_FSL_MC_ENET */ +} +#endif /* CONFIG_RESET_PHY_R */ diff --git a/include/configs/ls2080a_common.h b/include/configs/ls2080a_common.h index 427f623..266ef02 100644 --- a/include/configs/ls2080a_common.h +++ b/include/configs/ls2080a_common.h @@ -149,6 +149,11 @@ unsigned long long get_qixis_addr(void); #define CONFIG_SYS_LS_MC_AIOP_IMG_MAX_LENGTH 0x200000 #define CONFIG_SYS_LS_MC_DRAM_AIOP_IMG_OFFSET 0x07000000
+/* Define phy_reset function to boot the MC based on mcinitcmd. + * This happens late enough to properly fixup u-boot env MAC addresses. + */ +#define CONFIG_RESET_PHY_R + /* * Carve out a DDR region which will not be used by u-boot/Linux *
Previous to MC v10.x, port mac address was specified via DPL. Since newer MC versions are compatible with old style DPLs, make the u-boot env mac addresses visible there. This applies only to DPLs that have an older version.
DPLs use 32 bit values for specifying MAC addresses. U-boot environment variables take precedence over the MAC addresses already visible in the DPL/DPC.
Signed-off-by: Bogdan Purcareata bogdan.purcareata@nxp.com Signed-off-by: Heinz Wrobel heinz.wrobel@nxp.com --- drivers/net/fsl-mc/mc.c | 260 ++++++++++++++++++++++++++++++++++++------------ 1 file changed, 197 insertions(+), 63 deletions(-)
diff --git a/drivers/net/fsl-mc/mc.c b/drivers/net/fsl-mc/mc.c index afaf285..aaa887f 100644 --- a/drivers/net/fsl-mc/mc.c +++ b/drivers/net/fsl-mc/mc.c @@ -155,19 +155,144 @@ int parse_mc_firmware_fit_image(u64 mc_fw_addr, } #endif
-static int mc_fixup_dpc_mac_addr(void *blob, int noff, int dpmac_id, - struct eth_device *eth_dev) +#define MC_DT_INCREASE_SIZE 64 + +enum mc_fixup_type { + MC_FIXUP_DPL, + MC_FIXUP_DPC +}; + +static int mc_fixup_mac_addr(void *blob, int nodeoffset, + const char *propname, struct eth_device *eth_dev, + enum mc_fixup_type type) { - int nodeoffset, err = 0; + int err = 0, len, size, i; + unsigned char env_enetaddr[ARP_HLEN]; + unsigned int enetaddr_32[ARP_HLEN]; + void *val; + + switch (type) { + case MC_FIXUP_DPL: + /* DPL likes its addresses on 32 * ARP_HLEN bits */ + for (i = 0; i < ARP_HLEN; i++) + enetaddr_32[i] = cpu_to_fdt32(eth_dev->enetaddr[i]); + val = enetaddr_32; + len = sizeof(enetaddr_32); + break; + + case MC_FIXUP_DPC: + val = eth_dev->enetaddr; + len = ARP_HLEN; + break; + } + + /* MAC address property present */ + if (fdt_get_property(blob, nodeoffset, propname, NULL)) { + /* u-boot MAC addr randomly assigned - leave the present one */ + if (!eth_getenv_enetaddr_by_index("eth", eth_dev->index, + env_enetaddr)) + return err; + } else { + size = MC_DT_INCREASE_SIZE + strlen(propname) + len; + /* make room for mac address property */ + err = fdt_increase_size(blob, size); + if (err) { + printf("fdt_increase_size: err=%s\n", + fdt_strerror(err)); + return err; + } + } + + err = fdt_setprop(blob, nodeoffset, propname, val, len); + if (err) { + printf("fdt_setprop: err=%s\n", fdt_strerror(err)); + return err; + } + + return err; +} + +#define is_dpni(s) (s != NULL ? !strncmp(s, "dpni@", 5) : 0) + +const char *dpl_get_connection_endpoint(void *blob, char *endpoint) +{ + int connoffset = fdt_path_offset(blob, "/connections"), off; + const char *s1, *s2; + + for (off = fdt_first_subnode(blob, connoffset); + off >= 0; + off = fdt_next_subnode(blob, off)) { + s1 = fdt_stringlist_get(blob, off, "endpoint1", 0, NULL); + s2 = fdt_stringlist_get(blob, off, "endpoint2", 0, NULL); + + if (!s1 || !s2) + continue; + + if (strcmp(endpoint, s1) == 0) + return s2; + + if (strcmp(endpoint, s2) == 0) + return s1; + } + + return NULL; +} + +static int mc_fixup_dpl_mac_addr(void *blob, int dpmac_id, + struct eth_device *eth_dev) +{ + int objoff = fdt_path_offset(blob, "/objects"); + int dpmacoff = -1, dpnioff = -1; + const char *endpoint; char mac_name[10]; - const char link_type_mode[] = "FIXED_LINK"; - unsigned char env_enetaddr[6]; + int err; + + sprintf(mac_name, "dpmac@%d", dpmac_id); + dpmacoff = fdt_subnode_offset(blob, objoff, mac_name); + if (dpmacoff < 0) + /* dpmac not defined in DPL, so skip it. */ + return 0; + + printf("Fixing up mac addr for %s\n", mac_name); + err = mc_fixup_mac_addr(blob, dpmacoff, "mac_addr", eth_dev, + MC_FIXUP_DPL); + if (err) { + printf("Error fixing up dpmac mac_addr in DPL\n"); + return err; + } + + /* Now we need to figure out if there is any + * DPNI connected to this MAC, so we walk the + * connection list + */ + endpoint = dpl_get_connection_endpoint(blob, mac_name); + if (!is_dpni(endpoint)) + return 0; + + /* let's see if we can fixup the DPNI as well */ + printf("Checking connection %s <=> %s\n", mac_name, endpoint); + dpnioff = fdt_subnode_offset(blob, objoff, endpoint); + if (dpnioff < 0) + /* DPNI not defined in DPL in the objects area */ + return 0; + + return mc_fixup_mac_addr(blob, dpnioff, "mac_addr", eth_dev, + MC_FIXUP_DPL); +} + +static int mc_fixup_dpc_mac_addr(void *blob, int dpmac_id, + struct eth_device *eth_dev) +{ + int nodeoffset = fdt_path_offset(blob, "/board_info/ports"), noff; + int err = 0; + char mac_name[10]; + const char link_type_mode[] = "MAC_LINK_TYPE_FIXED";
sprintf(mac_name, "mac@%d", dpmac_id);
/* node not found - create it */ - nodeoffset = fdt_subnode_offset(blob, noff, (const char *) mac_name); - if (nodeoffset < 0) { + noff = fdt_subnode_offset(blob, nodeoffset, (const char *)mac_name); + if (noff < 0) { err = fdt_increase_size(blob, 200); if (err) { printf("fdt_increase_size: err=%s\n", @@ -175,10 +300,15 @@ static int mc_fixup_dpc_mac_addr(void *blob, int noff, int dpmac_id, return err; }
- nodeoffset = fdt_add_subnode(blob, noff, mac_name); + noff = fdt_add_subnode(blob, nodeoffset, mac_name); + if (noff < 0) { + printf("fdt_add_subnode: err=%s\n", + fdt_strerror(err)); + return err; + }
/* add default property of fixed link */ - err = fdt_appendprop_string(blob, nodeoffset, + err = fdt_appendprop_string(blob, noff, "link_type", link_type_mode); if (err) { printf("fdt_appendprop_string: err=%s\n", @@ -187,49 +317,53 @@ static int mc_fixup_dpc_mac_addr(void *blob, int noff, int dpmac_id, } }
- /* port_mac_address property present in DPC */ - if (fdt_get_property(blob, nodeoffset, "port_mac_address", NULL)) { - /* MAC addr randomly assigned - leave the one in DPC */ - eth_getenv_enetaddr_by_index("eth", eth_dev->index, - env_enetaddr); - if (is_zero_ethaddr(env_enetaddr)) - return err; + return mc_fixup_mac_addr(blob, noff, "port_mac_address", eth_dev, + MC_FIXUP_DPC); +}
- /* replace DPC MAC address with u-boot env one */ - err = fdt_setprop(blob, nodeoffset, "port_mac_address", - eth_dev->enetaddr, 6); - if (err) { - printf("fdt_setprop mac: err=%s\n", fdt_strerror(err)); - return err; - } +static int mc_fixup_mac_addrs(void *blob, enum mc_fixup_type type) +{ + int i, err = 0, ret = 0; + char ethname[10]; + struct eth_device *eth_dev;
- return 0; - } + for (i = WRIOP1_DPMAC1; i < NUM_WRIOP_PORTS; i++) { + /* port not enabled */ + if ((wriop_is_enabled_dpmac(i) != 1) || + (wriop_get_phy_address(i) == -1)) + continue;
- /* append port_mac_address property to mac node in DPC */ - err = fdt_increase_size(blob, 80); - if (err) { - printf("fdt_increase_size: err=%s\n", fdt_strerror(err)); - return err; - } + sprintf(ethname, "DPMAC%d@%s", i, + phy_interface_strings[wriop_get_enet_if(i)]);
- err = fdt_appendprop(blob, nodeoffset, - "port_mac_address", eth_dev->enetaddr, 6); - if (err) { - printf("fdt_appendprop: err=%s\n", fdt_strerror(err)); - return err; + eth_dev = eth_get_dev_by_name(ethname); + if (eth_dev == NULL) + continue; + + switch (type) { + case MC_FIXUP_DPL: + err = mc_fixup_dpl_mac_addr(blob, i, eth_dev); + break; + case MC_FIXUP_DPC: + err = mc_fixup_dpc_mac_addr(blob, i, eth_dev); + break; + default: + break; + } + + if (err) + printf("fsl-mc: ERROR fixing mac address for %s\n", + ethname); + ret |= err; }
- return err; + return ret; }
static int mc_fixup_dpc(u64 dpc_addr) { void *blob = (void *)dpc_addr; int nodeoffset, err = 0; - char ethname[10]; - struct eth_device *eth_dev; - int i;
/* delete any existing ICID pools */ nodeoffset = fdt_path_offset(blob, "/resources/icid_pools"); @@ -254,30 +388,9 @@ static int mc_fixup_dpc(u64 dpc_addr) /* fixup MAC addresses for dpmac ports */ nodeoffset = fdt_path_offset(blob, "/board_info/ports"); if (nodeoffset < 0) - goto out; - - for (i = WRIOP1_DPMAC1; i < NUM_WRIOP_PORTS; i++) { - /* port not enabled */ - if ((wriop_is_enabled_dpmac(i) != 1) || - (wriop_get_phy_address(i) == -1)) - continue; - - sprintf(ethname, "DPMAC%d@%s", i, - phy_interface_strings[wriop_get_enet_if(i)]); - - eth_dev = eth_get_dev_by_name(ethname); - if (eth_dev == NULL) - continue; - - err = mc_fixup_dpc_mac_addr(blob, nodeoffset, i, eth_dev); - if (err) { - printf("mc_fixup_dpc_mac_addr failed: err=%s\n", - fdt_strerror(err)); - goto out; - } - } + return 0;
-out: + err = mc_fixup_mac_addrs(blob, MC_FIXUP_DPC); flush_dcache_range(dpc_addr, dpc_addr + fdt_totalsize(blob));
return err; @@ -340,6 +453,25 @@ static int load_mc_dpc(u64 mc_ram_addr, size_t mc_ram_size, u64 mc_dpc_addr) return 0; }
+ +static int mc_fixup_dpl(u64 dpl_addr) +{ + void *blob = (void *)dpl_addr; + u32 ver = fdt_getprop_u32_default(blob, "/", "dpl-version", 0); + int err = 0; + + /* The DPL fixup for mac addresses is only relevant + * for old-style DPLs + */ + if (ver >= 10) + return 0; + + err = mc_fixup_mac_addrs(blob, MC_FIXUP_DPL); + flush_dcache_range(dpl_addr, dpl_addr + fdt_totalsize(blob)); + + return err; +} + static int load_mc_dpl(u64 mc_ram_addr, size_t mc_ram_size, u64 mc_dpl_addr) { u64 mc_dpl_offset; @@ -386,6 +518,8 @@ static int load_mc_dpl(u64 mc_ram_addr, size_t mc_ram_size, u64 mc_dpl_addr) (u64)dpl_fdt_hdr, dpl_size, mc_ram_addr + mc_dpl_offset); #endif /* not defined CONFIG_SYS_LS_MC_DPL_IN_DDR */
+ if (mc_fixup_dpl(mc_ram_addr + mc_dpl_offset)) + return -EINVAL; dump_ram_words("DPL", (void *)(mc_ram_addr + mc_dpl_offset)); return 0; }
I see compiling warning about uninitialized variables "val" and "len". Please fix.
York
-----Original Message----- From: york sun Sent: Friday, May 19, 2017 12:04 AM To: Bogdan Purcareata bogdan.purcareata@nxp.com; Prabhakar Kushwaha prabhakar.kushwaha@nxp.com; u-boot@lists.denx.de Cc: Heinz Wrobel heinz.wrobel@nxp.com Subject: Re: [PATCH 2/2] drivers: net: fsl-mc: Include MAC addr fixup in DPL
Thank you, will send v2.
Regards, Bogdan P.
Bogdan Purcareata
york sun
