[U-Boot] [PATCH] pci: Fix expansion ROM programming for multi-function devices
PCI_HEADER_TYPE register (offset 0x0e) bit 7 is an indicator for multi-function devices. We should mask it off before using it as the header type.
Signed-off-by: Bin Meng bmeng.cn@gmail.com ---
drivers/pci/pci_auto.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/drivers/pci/pci_auto.c b/drivers/pci/pci_auto.c index 41d5447..79f27c7 100644 --- a/drivers/pci/pci_auto.c +++ b/drivers/pci/pci_auto.c @@ -185,6 +185,7 @@ void pciauto_setup_device(struct pci_controller *hose, #ifndef CONFIG_PCI_ENUM_ONLY /* Configure the expansion ROM address */ pci_hose_read_config_byte(hose, dev, PCI_HEADER_TYPE, &header_type); + header_type &= 0x7f; if (header_type != PCI_HEADER_TYPE_CARDBUS) { rom_addr = (header_type == PCI_HEADER_TYPE_NORMAL) ? PCI_ROM_ADDRESS : PCI_ROM_ADDRESS1;
Hi Tom,
I think we should get this patch in v2015.10 as it's a bug fix otherwise multi-function devices won't get ROM address assigned.
Regards, Bin
Hi Bin,
I'm not sure if this fix actually fixes anything for existing boards, but I'll pick it up.
Is there anything else I have missed?
Hi Simon,
On Fri, Oct 9, 2015 at 2:10 AM, Simon Glass sjg@chromium.org wrote:
Hi Bin,
Yes, it fixes the Crown Bay board where Topcliff PCI device D0:F0 is a multi-function device and has a ROM.
So far I believe everything for this release is in. Thanks!
Regards, Bin
On 8 October 2015 at 18:30, Bin Meng bmeng.cn@gmail.com wrote:
Hi Simon,
Hi Bin,
Regards, Bin
Applied to u-boot-x86, and now in mainline.
Bin Meng
