[U-Boot] [PATCH 1/2] mtd: cqspi: Simplify indirect write code
The indirect write code is buggy pile of nastiness which fails horribly when the system runs fast enough to saturate the controller. The failure results in some pages (256B) not being written to the flash. This can be observed on systems which run with Dcache enabled and L2 cache enabled, like the Altera SoCFPGA.
This patch replaces the whole unmaintainable indirect write implementation with the one from upcoming Linux CQSPI driver, which went through multiple rounds of thorough review and testing. While this makes the patch look terrifying and violates all best-practices of software development, all the patch does is it plucks out duplicate ad-hoc code distributed across the driver and replaces it with more compact code doing exactly the same thing.
Signed-off-by: Marek Vasut marex@denx.de Cc: Anatolij Gustschin agust@denx.de Cc: Chin Liang See clsee@altera.com Cc: Dinh Nguyen dinguyen@opensource.altera.com Cc: Jagan Teki jteki@openedev.com Cc: Pavel Machek pavel@denx.de Cc: Stefan Roese sr@denx.de Cc: Vignesh R vigneshr@ti.com --- drivers/spi/cadence_qspi_apb.c | 122 +++++++++-------------------------------- 1 file changed, 26 insertions(+), 96 deletions(-)
diff --git a/drivers/spi/cadence_qspi_apb.c b/drivers/spi/cadence_qspi_apb.c index 7786dd6..00a50cb 100644 --- a/drivers/spi/cadence_qspi_apb.c +++ b/drivers/spi/cadence_qspi_apb.c @@ -28,6 +28,7 @@ #include <common.h> #include <asm/io.h> #include <asm/errno.h> +#include <wait_bit.h> #include "cadence_qspi.h"
#define CQSPI_REG_POLL_US (1) /* 1us */ @@ -214,32 +215,6 @@ static void cadence_qspi_apb_read_fifo_data(void *dest, return; }
-static void cadence_qspi_apb_write_fifo_data(const void *dest_ahb_addr, - const void *src, unsigned int bytes) -{ - unsigned int temp = 0; - int i; - int remaining = bytes; - unsigned int *dest_ptr = (unsigned int *)dest_ahb_addr; - unsigned int *src_ptr = (unsigned int *)src; - - while (remaining >= CQSPI_FIFO_WIDTH) { - for (i = CQSPI_FIFO_WIDTH/sizeof(src_ptr) - 1; i >= 0; i--) - writel(*(src_ptr+i), dest_ptr+i); - src_ptr += CQSPI_FIFO_WIDTH/sizeof(src_ptr); - remaining -= CQSPI_FIFO_WIDTH; - } - if (remaining) { - /* dangling bytes */ - i = remaining/sizeof(dest_ptr); - memcpy(&temp, src_ptr+i, remaining % sizeof(dest_ptr)); - writel(temp, dest_ptr+i); - for (--i; i >= 0; i--) - writel(*(src_ptr+i), dest_ptr+i); - } - return; -} - /* Read from SRAM FIFO with polling SRAM fill level. */ static int qspi_read_sram_fifo_poll(const void *reg_base, void *dest_addr, const void *src_addr, unsigned int num_bytes) @@ -276,44 +251,6 @@ static int qspi_read_sram_fifo_poll(const void *reg_base, void *dest_addr, return 0; }
-/* Write to SRAM FIFO with polling SRAM fill level. */ -static int qpsi_write_sram_fifo_push(struct cadence_spi_platdata *plat, - const void *src_addr, unsigned int num_bytes) -{ - const void *reg_base = plat->regbase; - void *dest_addr = plat->ahbbase; - unsigned int retry = CQSPI_REG_RETRY; - unsigned int sram_level; - unsigned int wr_bytes; - unsigned char *src = (unsigned char *)src_addr; - int remaining = num_bytes; - unsigned int page_size = plat->page_size; - unsigned int sram_threshold_words = CQSPI_REG_SRAM_THRESHOLD_WORDS; - - while (remaining > 0) { - retry = CQSPI_REG_RETRY; - while (retry--) { - sram_level = CQSPI_GET_WR_SRAM_LEVEL(reg_base); - if (sram_level <= sram_threshold_words) - break; - } - if (!retry) { - printf("QSPI: SRAM fill level (0x%08x) not hit lower expected level (0x%08x)", - sram_level, sram_threshold_words); - return -1; - } - /* Write a page or remaining bytes. */ - wr_bytes = (remaining > page_size) ? - page_size : remaining; - - cadence_qspi_apb_write_fifo_data(dest_addr, src, wr_bytes); - src += wr_bytes; - remaining -= wr_bytes; - } - - return 0; -} - void cadence_qspi_apb_controller_enable(void *reg_base) { unsigned int reg; @@ -810,48 +747,41 @@ int cadence_qspi_apb_indirect_write_setup(struct cadence_spi_platdata *plat, }
int cadence_qspi_apb_indirect_write_execute(struct cadence_spi_platdata *plat, - unsigned int txlen, const u8 *txbuf) + unsigned int n_tx, const u8 *txbuf) { - unsigned int reg = 0; - unsigned int retry; + unsigned int page_size = plat->page_size; + unsigned int remaining = n_tx; + unsigned int write_bytes; + int ret;
/* Configure the indirect read transfer bytes */ - writel(txlen, plat->regbase + CQSPI_REG_INDIRECTWRBYTES); + writel(n_tx, plat->regbase + CQSPI_REG_INDIRECTWRBYTES);
/* Start the indirect write transfer */ writel(CQSPI_REG_INDIRECTWR_START_MASK, plat->regbase + CQSPI_REG_INDIRECTWR);
- if (qpsi_write_sram_fifo_push(plat, (const void *)txbuf, txlen)) - goto failwr; - - /* Wait until last write is completed (FIFO empty) */ - retry = CQSPI_REG_RETRY; - while (retry--) { - reg = CQSPI_GET_WR_SRAM_LEVEL(plat->regbase); - if (reg == 0) - break; - - udelay(1); - } - - if (reg != 0) { - printf("QSPI: timeout for indirect write\n"); - goto failwr; - } + while (remaining > 0) { + write_bytes = remaining > page_size ? page_size : remaining; + writesl(plat->ahbbase, txbuf, DIV_ROUND_UP(write_bytes, 4)); + + ret = wait_for_bit("QSPI", plat->regbase + CQSPI_REG_SDRAMLEVEL, + CQSPI_REG_SDRAMLEVEL_WR_MASK << + CQSPI_REG_SDRAMLEVEL_WR_LSB, 0, 10, 0); + if (ret) { + printf("Indirect write timed out (%i)\n", ret); + goto failwr; + }
- /* Check flash indirect controller status */ - retry = CQSPI_REG_RETRY; - while (retry--) { - reg = readl(plat->regbase + CQSPI_REG_INDIRECTWR); - if (reg & CQSPI_REG_INDIRECTWR_DONE_MASK) - break; - udelay(1); + txbuf += write_bytes; + remaining -= write_bytes; }
- if (!(reg & CQSPI_REG_INDIRECTWR_DONE_MASK)) { - printf("QSPI: indirect completion status error with reg 0x%08x\n", - reg); + /* Check indirect done status */ + ret = wait_for_bit("QSPI", plat->regbase + CQSPI_REG_INDIRECTWR, + CQSPI_REG_INDIRECTWR_DONE_MASK, 1, 10, 0); + if (ret) { + printf("Indirect write completion error (%i)\n", ret); goto failwr; }
@@ -864,7 +794,7 @@ failwr: /* Cancel the indirect write */ writel(CQSPI_REG_INDIRECTWR_CANCEL_MASK, plat->regbase + CQSPI_REG_INDIRECTWR); - return -1; + return ret; }
void cadence_qspi_apb_enter_xip(void *reg_base, char xip_dummy)
The indirect read code is a pile of nastiness. This patch replaces the whole unmaintainable indirect read implementation with the one from upcoming Linux CQSPI driver, which went through multiple rounds of thorough review and testing. All the patch does is it plucks out duplicate ad-hoc code distributed across the driver and replaces it with more compact code doing exactly the same thing. There is no speed change of the read operation.
Signed-off-by: Marek Vasut marex@denx.de Cc: Anatolij Gustschin agust@denx.de Cc: Chin Liang See clsee@altera.com Cc: Dinh Nguyen dinguyen@opensource.altera.com Cc: Jagan Teki jteki@openedev.com Cc: Pavel Machek pavel@denx.de Cc: Stefan Roese sr@denx.de Cc: Vignesh R vigneshr@ti.com --- drivers/spi/cadence_qspi_apb.c | 124 ++++++++++++++++++----------------------- 1 file changed, 53 insertions(+), 71 deletions(-)
diff --git a/drivers/spi/cadence_qspi_apb.c b/drivers/spi/cadence_qspi_apb.c index 00a50cb..ac47c6f 100644 --- a/drivers/spi/cadence_qspi_apb.c +++ b/drivers/spi/cadence_qspi_apb.c @@ -193,64 +193,6 @@ static unsigned int cadence_qspi_apb_cmd2addr(const unsigned char *addr_buf, return addr; }
-static void cadence_qspi_apb_read_fifo_data(void *dest, - const void *src_ahb_addr, unsigned int bytes) -{ - unsigned int temp; - int remaining = bytes; - unsigned int *dest_ptr = (unsigned int *)dest; - unsigned int *src_ptr = (unsigned int *)src_ahb_addr; - - while (remaining >= sizeof(dest_ptr)) { - *dest_ptr = readl(src_ptr); - remaining -= sizeof(src_ptr); - dest_ptr++; - } - if (remaining) { - /* dangling bytes */ - temp = readl(src_ptr); - memcpy(dest_ptr, &temp, remaining); - } - - return; -} - -/* Read from SRAM FIFO with polling SRAM fill level. */ -static int qspi_read_sram_fifo_poll(const void *reg_base, void *dest_addr, - const void *src_addr, unsigned int num_bytes) -{ - unsigned int remaining = num_bytes; - unsigned int retry; - unsigned int sram_level = 0; - unsigned char *dest = (unsigned char *)dest_addr; - - while (remaining > 0) { - retry = CQSPI_REG_RETRY; - while (retry--) { - sram_level = CQSPI_GET_RD_SRAM_LEVEL(reg_base); - if (sram_level) - break; - udelay(1); - } - - if (!retry) { - printf("QSPI: No receive data after polling for %d times\n", - CQSPI_REG_RETRY); - return -1; - } - - sram_level *= CQSPI_FIFO_WIDTH; - sram_level = sram_level > remaining ? remaining : sram_level; - - /* Read data from FIFO. */ - cadence_qspi_apb_read_fifo_data(dest, src_addr, sram_level); - dest += sram_level; - remaining -= sram_level; - udelay(1); - } - return 0; -} - void cadence_qspi_apb_controller_enable(void *reg_base) { unsigned int reg; @@ -679,40 +621,80 @@ int cadence_qspi_apb_indirect_read_setup(struct cadence_spi_platdata *plat, return 0; }
+static u32 cadence_qspi_get_rd_sram_level(struct cadence_spi_platdata *plat) +{ + u32 reg = readl(plat->regbase + CQSPI_REG_SDRAMLEVEL); + reg >>= CQSPI_REG_SDRAMLEVEL_RD_LSB; + return reg & CQSPI_REG_SDRAMLEVEL_RD_MASK; +} + +static int cadence_qspi_wait_for_data(struct cadence_spi_platdata *plat) +{ + unsigned int timeout = 10000; + u32 reg; + + while (timeout--) { + reg = cadence_qspi_get_rd_sram_level(plat); + if (reg) + return reg; + udelay(1); + } + + return -ETIMEDOUT; +} + int cadence_qspi_apb_indirect_read_execute(struct cadence_spi_platdata *plat, - unsigned int rxlen, u8 *rxbuf) + unsigned int n_rx, u8 *rxbuf) { - unsigned int reg; + unsigned int remaining = n_rx; + unsigned int bytes_to_read = 0; + int ret;
- writel(rxlen, plat->regbase + CQSPI_REG_INDIRECTRDBYTES); + writel(n_rx, plat->regbase + CQSPI_REG_INDIRECTRDBYTES);
/* Start the indirect read transfer */ writel(CQSPI_REG_INDIRECTRD_START_MASK, plat->regbase + CQSPI_REG_INDIRECTRD);
- if (qspi_read_sram_fifo_poll(plat->regbase, (void *)rxbuf, - (const void *)plat->ahbbase, rxlen)) - goto failrd; + while (remaining > 0) { + ret = cadence_qspi_wait_for_data(plat); + if (ret < 0) { + printf("Indirect write timed out (%i)\n", ret); + goto failrd; + }
- /* Check flash indirect controller */ - reg = readl(plat->regbase + CQSPI_REG_INDIRECTRD); - if (!(reg & CQSPI_REG_INDIRECTRD_DONE_MASK)) { - reg = readl(plat->regbase + CQSPI_REG_INDIRECTRD); - printf("QSPI: indirect completion status error with reg 0x%08x\n", - reg); + bytes_to_read = ret; + + while (bytes_to_read != 0) { + bytes_to_read *= CQSPI_FIFO_WIDTH; + bytes_to_read = bytes_to_read > remaining ? + remaining : bytes_to_read; + readsl(plat->ahbbase, rxbuf, DIV_ROUND_UP(bytes_to_read, 4)); + rxbuf += bytes_to_read; + remaining -= bytes_to_read; + bytes_to_read = cadence_qspi_get_rd_sram_level(plat); + } + } + + /* Check indirect done status */ + ret = wait_for_bit("QSPI", plat->regbase + CQSPI_REG_INDIRECTRD, + CQSPI_REG_INDIRECTRD_DONE_MASK, 1, 10, 0); + if (ret) { + printf("Indirect read completion error (%i)\n", ret); goto failrd; }
/* Clear indirect completion status */ writel(CQSPI_REG_INDIRECTRD_DONE_MASK, plat->regbase + CQSPI_REG_INDIRECTRD); + return 0;
failrd: /* Cancel the indirect read */ writel(CQSPI_REG_INDIRECTRD_CANCEL_MASK, plat->regbase + CQSPI_REG_INDIRECTRD); - return -1; + return ret; }
/* Opcode + Address (3/4 bytes) */
Tested on K2G EVM that has Cadence QSPI controller and s25fl512s Spansion flash For both the patches:
Tested-by: Vignesh R vigneshr@ti.com
Hi Marek,
I've applied both patches and tested them on SR1500 (SPI-NOR used for booting and redundant environment). This is what I get upon "saveeenv":
=> saveenv Saving Environment to SPI Flash... SF: Detected N25Q128 with page size 256 Bytes, erase size 64 KiB, total 16 MiB Erasing SPI flash...Writing to SPI flash...data abort pc : [<3ff8368a>] lr : [<3ff8301b>] reloc pc : [<010216ca>] lr : [<0102105b>] sp : 3bf54eb8 ip : 3ff82f69 fp : 00000002 r10: 00000000 r9 : 3bf5dee8 r8 : ffff0000 r7 : 00000001 r6 : 3bf54f9b r5 : 00000001 r4 : 3bf5e520 r3 : 00000000 r2 : 3bf54f9b r1 : 00000001 r0 : ffa00000 Flags: nZCv IRQs off FIQs off Mode SVC_32 Resetting CPU ...
resetting ...
U-Boot SPL 2016.05-rc3-00009-ge1bf9b8 (Apr 29 2016 - 11:25:46)
Any idea, what might be going wrong here?
Thanks, Stefan
On 04/29/2016 11:35 AM, Stefan Roese wrote:
Hi Marek,
resetting ...
Does it work without the patch ? Where does your PC point to at the time of the crash ,which function is it ?
Thanks, Stefan
resetting ...
Yes, of course. I wouldn't have posted as a reply to this patch if this is not the root cause. The board is using SPI NOR for env storage from the beginning.
Its in cadence_qspi_apb_indirect_write_execute().
I debugged this issue a bit and found the following problem in cadence_qspi_apb_indirect_write_execute():
saveenv issues a 1-byte SPI write transfer with a non 4-byte aligned txbuf. This causes the data-abort here. Here my small patch that fixes the problem:
diff --git a/drivers/spi/cadence_qspi_apb.c b/drivers/spi/cadence_qspi_apb.c index ac47c6f..021a3e8 100644 --- a/drivers/spi/cadence_qspi_apb.c +++ b/drivers/spi/cadence_qspi_apb.c @@ -745,7 +745,15 @@ int cadence_qspi_apb_indirect_write_execute(struct cadence_spi_platdata *plat,
while (remaining > 0) { write_bytes = remaining > page_size ? page_size : remaining; - writesl(plat->ahbbase, txbuf, DIV_ROUND_UP(write_bytes, 4)); + + /* + * Handle non 4-byte aligned access differently to avoid + * data-aborts + */ + if (((u32)txbuf % 4) || (write_bytes % 4)) + writesb(plat->ahbbase, txbuf, write_bytes); + else + writesl(plat->ahbbase, txbuf, write_bytes >> 2);
ret = wait_for_bit("QSPI", plat->regbase + CQSPI_REG_SDRAMLEVEL, CQSPI_REG_SDRAMLEVEL_WR_MASK <<
Please fell free to use this patch as-is and squash it into your patches or enhance it while doing this. The read function is also missing this unaligned handling. And of course the Linux driver version as well.
Thanks, Stefan
resetting ...
*grumble*
It only happens if you use redundant env in SPI NOR.
Thanks, see below.
* data-aborts
else
writesl(plat->ahbbase, txbuf, write_bytes >> 2); ret = wait_for_bit("QSPI", plat->regbase + CQSPI_REG_SDRAMLEVEL, CQSPI_REG_SDRAMLEVEL_WR_MASK <<
Im afraid of the performance hit that we can suffer if we use byte-level access for every unaligned buffer. What do you think about using a bounce-buffer instead ?
Does linux use unaligned buffers internally ?
Thanks, Stefan
resetting ...
*grumble*
Thanks, see below.
* data-aborts
else
This is why is wrote: "or enhance it while doing this". You might want to change the code to first write the (optionally) unaligned bytes, then the aligned bytes via writesl() and last the (optionally) unaligned bytes.
I would prefer the simple solution I've drafted above.
Frankly, I don't know for sure. But I suspect, that you can also see unaligned buffers (and sizes!!!) in Linux as well. And you can't just write a different amount of data to the SPI NOR, which happens when you use DIV_ROUND_UP on an unaligned size.
Thanks, Stefan
resetting ...
*grumble*
I just sensed slight USB subtext here ;-)
Thanks, see below.
remaining;
* data-aborts
else
OK, I checked how many aligned and unaligned transfers happens and I guess it's really not worth going through the bounce buffer for 1 byte which only happens once during saveenv.
I'll squash it and pick via socfpga tree, so we can get this in 2016.05 and have working QSPI NOR support there.
You can write different amount of data into the FIFO, the amount which is transferred is controlled by INDIRECTRDBYTES / INDIRECTWRBYTES register.
Thanks, Stefan
On 28.04.2016 00:36, Marek Vasut wrote: > The indirect write code is buggy pile of nastiness which fails > horribly > when the system runs fast enough to saturate the controller. The > failure > results in some pages (256B) not being written to the flash. This > can be > observed on systems which run with Dcache enabled and L2 cache > enabled, > like the Altera SoCFPGA. > > This patch replaces the whole unmaintainable indirect write > implementation > with the one from upcoming Linux CQSPI driver, which went through > multiple > rounds of thorough review and testing. While this makes the patch > look > terrifying and violates all best-practices of software > development, all > the patch does is it plucks out duplicate ad-hoc code distributed > across > the driver and replaces it with more compact code doing exactly > the same > thing. > > Signed-off-by: Marek Vasut marex@denx.de > Cc: Anatolij Gustschin agust@denx.de > Cc: Chin Liang See clsee@altera.com > Cc: Dinh Nguyen dinguyen@opensource.altera.com > Cc: Jagan Teki jteki@openedev.com > Cc: Pavel Machek pavel@denx.de > Cc: Stefan Roese sr@denx.de > Cc: Vignesh R vigneshr@ti.com
resetting ...
*grumble*
Thanks, see below.
remaining;
* data-aborts
else
Good, thanks!
Okay. But won't those additional (non-written) bytes not be stuck in the FIFO until the next transfer? And sent first before the new data that is written to the FIFO?
But that's a mood discussion as its not a problem any more with the v2 of the patches AFAICT.
Thanks, Stefan
Hi!
Could we get something less terifying and less violating? :-).
So this one is just a cleanup, and no behaviour change yet?
Pavel
- int i;
- if (remaining) {
- return;
while (retry--) {
break;
if (!retry) {
return -1;
src += wr_bytes;
- unsigned int n_tx, const u8 *txbuf)
int ret;
goto failwr;
- while (retry--) {
if (reg == 0)
break;
udelay(1);
- if (reg != 0) {
goto failwr;
if (ret) {
goto failwr;
- while (retry--) {
break;
udelay(1);
}remaining -= write_bytes;
reg);
- /* Check indirect done status */
- ret = wait_for_bit("QSPI", plat->regbase + CQSPI_REG_INDIRECTWR,
- if (ret) {
goto failwr; }printf("Indirect write completion error (%i)\n", ret);
- return -1;
- return ret;
On 05/03/2016 12:42 PM, Pavel Machek wrote:
Hi!
Apparently Stefan discovered one behavior change, which I need to look into. Apparently, u-boot can pass unaligned buffer to the driver, which can cause problems.
Pavel
- int i;
- if (remaining) {
- return;
while (retry--) {
break;
if (!retry) {
return -1;
src += wr_bytes;
int ret;
goto failwr;
- while (retry--) {
if (reg == 0)
break;
udelay(1);
- if (reg != 0) {
goto failwr;
if (ret) {
goto failwr;
- while (retry--) {
break;
udelay(1);
reg);
- if (ret) {
- return -1;
- return ret;
Pavel Machek
Stefan Roese
Vignesh R
