[U-Boot] [PATCH][v2] powerpc: Fix CamelCase checkpatch warnings
85xx, 86xx PowerPC folders have code variables with CamelCase naming conventions. because of this code checkpatch script generates "WARNING: Avoid CamelCase".
Convert variables name to normal naming convention and modify board, driver files with updated the new structure.
Signed-off-by: Prabhakar Kushwaha prabhakar@freescale.com --- Chages for v2: Incorporated Thomas's comments - Take care of git bisectable
arch/powerpc/cpu/mpc85xx/cpu.c | 43 +++++----- arch/powerpc/cpu/mpc85xx/fdt.c | 10 +-- arch/powerpc/cpu/mpc85xx/speed.c | 142 +++++++++++++++---------------- arch/powerpc/cpu/mpc86xx/cpu.c | 16 ++-- arch/powerpc/cpu/mpc86xx/speed.c | 40 ++++----- board/freescale/mpc8540ads/mpc8540ads.c | 2 +- board/freescale/mpc8541cds/mpc8541cds.c | 2 +- board/freescale/mpc8555cds/mpc8555cds.c | 2 +- board/freescale/mpc8560ads/mpc8560ads.c | 2 +- board/freescale/p1_p2_rdb_pc/ddr.c | 2 +- board/freescale/p1_twr/ddr.c | 2 +- board/sbc8548/sbc8548.c | 4 +- board/socrates/socrates.c | 2 +- board/xes/xpedite537x/ddr.c | 2 +- drivers/spi/fsl_espi.c | 2 +- include/e500.h | 16 ++-- include/mpc86xx.h | 6 +- 17 files changed, 149 insertions(+), 146 deletions(-)
diff --git a/arch/powerpc/cpu/mpc85xx/cpu.c b/arch/powerpc/cpu/mpc85xx/cpu.c index 66bc6a2..b77964a 100644 --- a/arch/powerpc/cpu/mpc85xx/cpu.c +++ b/arch/powerpc/cpu/mpc85xx/cpu.c @@ -135,78 +135,79 @@ int checkcpu (void) if (!(i & 3)) printf ("\n "); printf("CPU%d:%-4s MHz, ", core, - strmhz(buf1, sysinfo.freqProcessor[core])); + strmhz(buf1, sysinfo.freq_processor[core])); } - printf("\n CCB:%-4s MHz,\n", strmhz(buf1, sysinfo.freqSystemBus)); + printf("\n CCB:%-4s MHz,", strmhz(buf1, sysinfo.freq_systembus)); + printf("\n");
#ifdef CONFIG_FSL_CORENET if (ddr_sync == 1) { printf(" DDR:%-4s MHz (%s MT/s data rate) " "(Synchronous), ", - strmhz(buf1, sysinfo.freqDDRBus/2), - strmhz(buf2, sysinfo.freqDDRBus)); + strmhz(buf1, sysinfo.freq_ddrbus/2), + strmhz(buf2, sysinfo.freq_ddrbus)); } else { printf(" DDR:%-4s MHz (%s MT/s data rate) " "(Asynchronous), ", - strmhz(buf1, sysinfo.freqDDRBus/2), - strmhz(buf2, sysinfo.freqDDRBus)); + strmhz(buf1, sysinfo.freq_ddrbus/2), + strmhz(buf2, sysinfo.freq_ddrbus)); } #else switch (ddr_ratio) { case 0x0: printf(" DDR:%-4s MHz (%s MT/s data rate), ", - strmhz(buf1, sysinfo.freqDDRBus/2), - strmhz(buf2, sysinfo.freqDDRBus)); + strmhz(buf1, sysinfo.freq_ddrbus/2), + strmhz(buf2, sysinfo.freq_ddrbus)); break; case 0x7: printf(" DDR:%-4s MHz (%s MT/s data rate) " "(Synchronous), ", - strmhz(buf1, sysinfo.freqDDRBus/2), - strmhz(buf2, sysinfo.freqDDRBus)); + strmhz(buf1, sysinfo.freq_ddrbus/2), + strmhz(buf2, sysinfo.freq_ddrbus)); break; default: printf(" DDR:%-4s MHz (%s MT/s data rate) " "(Asynchronous), ", - strmhz(buf1, sysinfo.freqDDRBus/2), - strmhz(buf2, sysinfo.freqDDRBus)); + strmhz(buf1, sysinfo.freq_ddrbus/2), + strmhz(buf2, sysinfo.freq_ddrbus)); break; } #endif
#if defined(CONFIG_FSL_LBC) - if (sysinfo.freqLocalBus > LCRR_CLKDIV) { - printf("LBC:%-4s MHz\n", strmhz(buf1, sysinfo.freqLocalBus)); + if (sysinfo.freq_localbus > LCRR_CLKDIV) { + printf("LBC:%-4s MHz\n", strmhz(buf1, sysinfo.freq_localbus)); } else { printf("LBC: unknown (LCRR[CLKDIV] = 0x%02lx)\n", - sysinfo.freqLocalBus); + sysinfo.freq_localbus); } #endif
#if defined(CONFIG_FSL_IFC) - printf("IFC:%-4s MHz\n", strmhz(buf1, sysinfo.freqLocalBus)); + printf("IFC:%-4s MHz\n", strmhz(buf1, sysinfo.freq_localbus)); #endif
#ifdef CONFIG_CPM2 - printf("CPM: %s MHz\n", strmhz(buf1, sysinfo.freqSystemBus)); + printf("CPM: %s MHz\n", strmhz(buf1, sysinfo.freq_systembus)); #endif
#ifdef CONFIG_QE - printf(" QE:%-4s MHz\n", strmhz(buf1, sysinfo.freqQE)); + printf(" QE:%-4s MHz\n", strmhz(buf1, sysinfo.freq_qe)); #endif
#ifdef CONFIG_SYS_DPAA_FMAN for (i = 0; i < CONFIG_SYS_NUM_FMAN; i++) { printf(" FMAN%d: %s MHz\n", i + 1, - strmhz(buf1, sysinfo.freqFMan[i])); + strmhz(buf1, sysinfo.freq_fman[i])); } #endif
#ifdef CONFIG_SYS_DPAA_QBMAN - printf(" QMAN: %s MHz\n", strmhz(buf1, sysinfo.freqQMAN)); + printf(" QMAN: %s MHz\n", strmhz(buf1, sysinfo.freq_qman)); #endif
#ifdef CONFIG_SYS_DPAA_PME - printf(" PME: %s MHz\n", strmhz(buf1, sysinfo.freqPME)); + printf(" PME: %s MHz\n", strmhz(buf1, sysinfo.freq_pme)); #endif
puts("L1: D-cache 32 kB enabled\n I-cache 32 kB enabled\n"); diff --git a/arch/powerpc/cpu/mpc85xx/fdt.c b/arch/powerpc/cpu/mpc85xx/fdt.c index 84bb8fa..63a04f1 100644 --- a/arch/powerpc/cpu/mpc85xx/fdt.c +++ b/arch/powerpc/cpu/mpc85xx/fdt.c @@ -403,22 +403,22 @@ static void ft_fixup_dpaa_clks(void *blob) get_sys_info(&sysinfo); #ifdef CONFIG_SYS_DPAA_FMAN ft_fixup_clks(blob, "fsl,fman", CONFIG_SYS_FSL_FM1_OFFSET, - sysinfo.freqFMan[0]); + sysinfo.freq_fman[0]);
#if (CONFIG_SYS_NUM_FMAN == 2) ft_fixup_clks(blob, "fsl,fman", CONFIG_SYS_FSL_FM2_OFFSET, - sysinfo.freqFMan[1]); + sysinfo.freq_fman[1]); #endif #endif
#ifdef CONFIG_SYS_DPAA_QBMAN do_fixup_by_compat_u32(blob, "fsl,qman", - "clock-frequency", sysinfo.freqQMAN, 1); + "clock-frequency", sysinfo.freq_qman, 1); #endif
#ifdef CONFIG_SYS_DPAA_PME do_fixup_by_compat_u32(blob, "fsl,pme", - "clock-frequency", sysinfo.freqPME, 1); + "clock-frequency", sysinfo.freq_pme, 1); #endif } #else @@ -616,7 +616,7 @@ void ft_cpu_setup(void *blob, bd_t *bd) off = fdt_node_offset_by_prop_value(blob, -1, "device_type", "cpu", 4); while (off != -FDT_ERR_NOTFOUND) { u32 *reg = (u32 *)fdt_getprop(blob, off, "reg", 0); - val = cpu_to_fdt32(sysinfo.freqProcessor[*reg]); + val = cpu_to_fdt32(sysinfo.freq_processor[*reg]); fdt_setprop(blob, off, "clock-frequency", &val, 4); off = fdt_node_offset_by_prop_value(blob, off, "device_type", "cpu", 4); diff --git a/arch/powerpc/cpu/mpc85xx/speed.c b/arch/powerpc/cpu/mpc85xx/speed.c index f093960..07690f9 100644 --- a/arch/powerpc/cpu/mpc85xx/speed.c +++ b/arch/powerpc/cpu/mpc85xx/speed.c @@ -20,7 +20,7 @@ DECLARE_GLOBAL_DATA_PTR;
-void get_sys_info (sys_info_t * sysInfo) +void get_sys_info(sys_info_t *sys_info) { volatile ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); #ifdef CONFIG_FSL_IFC @@ -46,7 +46,7 @@ void get_sys_info (sys_info_t * sysInfo) [14] = 3, /* CC4 PPL / 4 */ };
- const u8 core_cplx_PLL_div[16] = { + const u8 core_cplx_pll_div[16] = { [ 0] = 1, /* CC1 PPL / 1 */ [ 1] = 2, /* CC1 PPL / 2 */ [ 2] = 4, /* CC1 PPL / 4 */ @@ -60,26 +60,26 @@ void get_sys_info (sys_info_t * sysInfo) [13] = 2, /* CC4 PPL / 2 */ [14] = 4, /* CC4 PPL / 4 */ }; - uint i, freqCC_PLL[6], rcw_tmp; + uint i, freq_cc_pll[6], rcw_tmp; uint ratio[6]; unsigned long sysclk = CONFIG_SYS_CLK_FREQ; uint mem_pll_rat;
- sysInfo->freqSystemBus = sysclk; + sys_info->freq_systembus = sysclk; #ifdef CONFIG_DDR_CLK_FREQ - sysInfo->freqDDRBus = CONFIG_DDR_CLK_FREQ; + sys_info->freq_ddrbus = CONFIG_DDR_CLK_FREQ; #else - sysInfo->freqDDRBus = sysclk; + sys_info->freq_ddrbus = sysclk; #endif
- sysInfo->freqSystemBus *= (in_be32(&gur->rcwsr[0]) >> 25) & 0x1f; + sys_info->freq_systembus *= (in_be32(&gur->rcwsr[0]) >> 25) & 0x1f; mem_pll_rat = (in_be32(&gur->rcwsr[0]) >> FSL_CORENET_RCWSR0_MEM_PLL_RAT_SHIFT) & FSL_CORENET_RCWSR0_MEM_PLL_RAT_MASK; if (mem_pll_rat > 2) - sysInfo->freqDDRBus *= mem_pll_rat; + sys_info->freq_ddrbus *= mem_pll_rat; else - sysInfo->freqDDRBus = sysInfo->freqSystemBus * mem_pll_rat; + sys_info->freq_ddrbus = sys_info->freq_systembus * mem_pll_rat;
ratio[0] = (in_be32(&clk->pllc1gsr) >> 1) & 0x3f; ratio[1] = (in_be32(&clk->pllc2gsr) >> 1) & 0x3f; @@ -89,9 +89,9 @@ void get_sys_info (sys_info_t * sysInfo) ratio[5] = (in_be32(&clk->pllc6gsr) >> 1) & 0x3f; for (i = 0; i < 6; i++) { if (ratio[i] > 4) - freqCC_PLL[i] = sysclk * ratio[i]; + freq_cc_pll[i] = sysclk * ratio[i]; else - freqCC_PLL[i] = sysInfo->freqSystemBus * ratio[i]; + freq_cc_pll[i] = sys_info->freq_systembus * ratio[i]; } #ifdef CONFIG_SYS_FSL_QORIQ_CHASSIS2 /* @@ -110,8 +110,8 @@ void get_sys_info (sys_info_t * sysInfo) printf("Unsupported architecture configuration" " in function %s\n", __func__); cplx_pll += (cluster / 2) * 3; - sysInfo->freqProcessor[cpu] = - freqCC_PLL[cplx_pll] / core_cplx_PLL_div[c_pll_sel]; + sys_info->freq_processor[cpu] = + freq_cc_pll[cplx_pll] / core_cplx_pll_div[c_pll_sel]; } #ifdef CONFIG_PPC_B4860 #define FM1_CLK_SEL 0xe0000000 @@ -127,63 +127,63 @@ void get_sys_info (sys_info_t * sysInfo) #ifdef CONFIG_SYS_DPAA_PME switch ((rcw_tmp & PME_CLK_SEL) >> PME_CLK_SHIFT) { case 1: - sysInfo->freqPME = freqCC_PLL[0]; + sys_info->freq_pme = freq_cc_pll[0]; break; case 2: - sysInfo->freqPME = freqCC_PLL[0] / 2; + sys_info->freq_pme = freq_cc_pll[0] / 2; break; case 3: - sysInfo->freqPME = freqCC_PLL[0] / 3; + sys_info->freq_pme = freq_cc_pll[0] / 3; break; case 4: - sysInfo->freqPME = freqCC_PLL[0] / 4; + sys_info->freq_pme = freq_cc_pll[0] / 4; break; case 6: - sysInfo->freqPME = freqCC_PLL[1] / 2; + sys_info->freq_pme = freq_cc_pll[1] / 2; break; case 7: - sysInfo->freqPME = freqCC_PLL[1] / 3; + sys_info->freq_pme = freq_cc_pll[1] / 3; break; default: printf("Error: Unknown PME clock select!\n"); case 0: - sysInfo->freqPME = sysInfo->freqSystemBus / 2; + sys_info->freq_pme = sys_info->freq_systembus / 2; break;
} #endif
#ifdef CONFIG_SYS_DPAA_QBMAN - sysInfo->freqQMAN = sysInfo->freqSystemBus / 2; + sys_info->freq_qman = sys_info->freq_systembus / 2; #endif
#ifdef CONFIG_SYS_DPAA_FMAN switch ((rcw_tmp & FM1_CLK_SEL) >> FM1_CLK_SHIFT) { case 1: - sysInfo->freqFMan[0] = freqCC_PLL[3]; + sys_info->freq_fman[0] = freq_cc_pll[3]; break; case 2: - sysInfo->freqFMan[0] = freqCC_PLL[3] / 2; + sys_info->freq_fman[0] = freq_cc_pll[3] / 2; break; case 3: - sysInfo->freqFMan[0] = freqCC_PLL[3] / 3; + sys_info->freq_fman[0] = freq_cc_pll[3] / 3; break; case 4: - sysInfo->freqFMan[0] = freqCC_PLL[3] / 4; + sys_info->freq_fman[0] = freq_cc_pll[3] / 4; break; case 5: - sysInfo->freqFMan[0] = sysInfo->freqSystemBus; + sys_info->freq_fman[0] = sys_info->freq_systembus; break; case 6: - sysInfo->freqFMan[0] = freqCC_PLL[4] / 2; + sys_info->freq_fman[0] = freq_cc_pll[4] / 2; break; case 7: - sysInfo->freqFMan[0] = freqCC_PLL[4] / 3; + sys_info->freq_fman[0] = freq_cc_pll[4] / 3; break; default: printf("Error: Unknown FMan1 clock select!\n"); case 0: - sysInfo->freqFMan[0] = sysInfo->freqSystemBus / 2; + sys_info->freq_fman[0] = sys_info->freq_systembus / 2; break; } #if (CONFIG_SYS_NUM_FMAN) == 2 @@ -192,27 +192,27 @@ void get_sys_info (sys_info_t * sysInfo) rcw_tmp = in_be32(&gur->rcwsr[15]); switch ((rcw_tmp & FM2_CLK_SEL) >> FM2_CLK_SHIFT) { case 1: - sysInfo->freqFMan[1] = freqCC_PLL[4]; + sys_info->freq_fman[1] = freq_cc_pll[4]; break; case 2: - sysInfo->freqFMan[1] = freqCC_PLL[4] / 2; + sys_info->freq_fman[1] = freq_cc_pll[4] / 2; break; case 3: - sysInfo->freqFMan[1] = freqCC_PLL[4] / 3; + sys_info->freq_fman[1] = freq_cc_pll[4] / 3; break; case 4: - sysInfo->freqFMan[1] = freqCC_PLL[4] / 4; + sys_info->freq_fman[1] = freq_cc_pll[4] / 4; break; case 6: - sysInfo->freqFMan[1] = freqCC_PLL[3] / 2; + sys_info->freq_fman[1] = freq_cc_pll[3] / 2; break; case 7: - sysInfo->freqFMan[1] = freqCC_PLL[3] / 3; + sys_info->freq_fman[1] = freq_cc_pll[3] / 3; break; default: printf("Error: Unknown FMan2 clock select!\n"); case 0: - sysInfo->freqFMan[1] = sysInfo->freqSystemBus / 2; + sys_info->freq_fman[1] = sys_info->freq_systembus / 2; break; } #endif /* CONFIG_SYS_NUM_FMAN == 2 */ @@ -225,8 +225,8 @@ void get_sys_info (sys_info_t * sysInfo) & 0xf; u32 cplx_pll = core_cplx_PLL[c_pll_sel];
- sysInfo->freqProcessor[cpu] = - freqCC_PLL[cplx_pll] / core_cplx_PLL_div[c_pll_sel]; + sys_info->freq_processor[cpu] = + freq_cc_pll[cplx_pll] / core_cplx_pll_div[c_pll_sel]; } #define PME_CLK_SEL 0x80000000 #define FM1_CLK_SEL 0x40000000 @@ -246,43 +246,43 @@ void get_sys_info (sys_info_t * sysInfo) #ifdef CONFIG_SYS_DPAA_PME if (rcw_tmp & PME_CLK_SEL) { if (rcw_tmp & HWA_ASYNC_DIV) - sysInfo->freqPME = freqCC_PLL[HWA_CC_PLL] / 4; + sys_info->freq_pme = freq_cc_pll[HWA_CC_PLL] / 4; else - sysInfo->freqPME = freqCC_PLL[HWA_CC_PLL] / 2; + sys_info->freq_pme = freq_cc_pll[HWA_CC_PLL] / 2; } else { - sysInfo->freqPME = sysInfo->freqSystemBus / 2; + sys_info->freq_pme = sys_info->freq_systembus / 2; } #endif
#ifdef CONFIG_SYS_DPAA_FMAN if (rcw_tmp & FM1_CLK_SEL) { if (rcw_tmp & HWA_ASYNC_DIV) - sysInfo->freqFMan[0] = freqCC_PLL[HWA_CC_PLL] / 4; + sys_info->freq_fman[0] = freq_cc_pll[HWA_CC_PLL] / 4; else - sysInfo->freqFMan[0] = freqCC_PLL[HWA_CC_PLL] / 2; + sys_info->freq_fman[0] = freq_cc_pll[HWA_CC_PLL] / 2; } else { - sysInfo->freqFMan[0] = sysInfo->freqSystemBus / 2; + sys_info->freq_fman[0] = sys_info->freq_systembus / 2; } #if (CONFIG_SYS_NUM_FMAN) == 2 if (rcw_tmp & FM2_CLK_SEL) { if (rcw_tmp & HWA_ASYNC_DIV) - sysInfo->freqFMan[1] = freqCC_PLL[HWA_CC_PLL] / 4; + sys_info->freq_fman[1] = freq_cc_pll[HWA_CC_PLL] / 4; else - sysInfo->freqFMan[1] = freqCC_PLL[HWA_CC_PLL] / 2; + sys_info->freq_fman[1] = freq_cc_pll[HWA_CC_PLL] / 2; } else { - sysInfo->freqFMan[1] = sysInfo->freqSystemBus / 2; + sys_info->freq_fman[1] = sys_info->freq_systembus / 2; } #endif #endif
#endif /* CONFIG_SYS_FSL_QORIQ_CHASSIS2 */
#else /* CONFIG_FSL_CORENET */ - uint plat_ratio, e500_ratio, half_freqSystemBus; + uint plat_ratio, e500_ratio, half_freq_systembus; int i; #ifdef CONFIG_QE __maybe_unused u32 qe_ratio; @@ -290,40 +290,40 @@ void get_sys_info (sys_info_t * sysInfo)
plat_ratio = (gur->porpllsr) & 0x0000003e; plat_ratio >>= 1; - sysInfo->freqSystemBus = plat_ratio * CONFIG_SYS_CLK_FREQ; + sys_info->freq_systembus = plat_ratio * CONFIG_SYS_CLK_FREQ;
/* Divide before multiply to avoid integer * overflow for processor speeds above 2GHz */ - half_freqSystemBus = sysInfo->freqSystemBus/2; + half_freq_systembus = sys_info->freq_systembus/2; for (i = 0; i < cpu_numcores(); i++) { e500_ratio = ((gur->porpllsr) >> (i * 8 + 16)) & 0x3f; - sysInfo->freqProcessor[i] = e500_ratio * half_freqSystemBus; + sys_info->freq_processor[i] = e500_ratio * half_freq_systembus; }
- /* Note: freqDDRBus is the MCLK frequency, not the data rate. */ - sysInfo->freqDDRBus = sysInfo->freqSystemBus; + /* Note: freq_ddrbus is the MCLK frequency, not the data rate. */ + sys_info->freq_ddrbus = sys_info->freq_systembus;
#ifdef CONFIG_DDR_CLK_FREQ { u32 ddr_ratio = ((gur->porpllsr) & MPC85xx_PORPLLSR_DDR_RATIO) >> MPC85xx_PORPLLSR_DDR_RATIO_SHIFT; if (ddr_ratio != 0x7) - sysInfo->freqDDRBus = ddr_ratio * CONFIG_DDR_CLK_FREQ; + sys_info->freq_ddrbus = ddr_ratio * CONFIG_DDR_CLK_FREQ; } #endif
#ifdef CONFIG_QE #if defined(CONFIG_P1012) || defined(CONFIG_P1021) || defined(CONFIG_P1025) - sysInfo->freqQE = sysInfo->freqSystemBus; + sys_info->freq_qe = sys_info->freq_systembus; #else qe_ratio = ((gur->porpllsr) & MPC85xx_PORPLLSR_QE_RATIO) >> MPC85xx_PORPLLSR_QE_RATIO_SHIFT; - sysInfo->freqQE = qe_ratio * CONFIG_SYS_CLK_FREQ; + sys_info->freq_qe = qe_ratio * CONFIG_SYS_CLK_FREQ; #endif #endif
#ifdef CONFIG_SYS_DPAA_FMAN - sysInfo->freqFMan[0] = sysInfo->freqSystemBus; + sys_info->freq_fman[0] = sys_info->freq_systembus; #endif
#endif /* CONFIG_FSL_CORENET */ @@ -350,10 +350,10 @@ void get_sys_info (sys_info_t * sysInfo) */ lcrr_div *= 2; #endif - sysInfo->freqLocalBus = sysInfo->freqSystemBus / lcrr_div; + sys_info->freq_localbus = sys_info->freq_systembus / lcrr_div; } else { /* In case anyone cares what the unknown value is */ - sysInfo->freqLocalBus = lcrr_div; + sys_info->freq_localbus = lcrr_div; } #endif
@@ -361,7 +361,7 @@ void get_sys_info (sys_info_t * sysInfo) ccr = in_be32(&ifc_regs->ifc_ccr); ccr = ((ccr & IFC_CCR_CLK_DIV_MASK) >> IFC_CCR_CLK_DIV_SHIFT) + 1;
- sysInfo->freqLocalBus = sysInfo->freqSystemBus / ccr; + sys_info->freq_localbus = sys_info->freq_systembus / ccr; #endif }
@@ -382,13 +382,13 @@ int get_clocks (void) dfbrg = (sccr & SCCR_DFBRG_MSK) >> SCCR_DFBRG_SHIFT; #endif get_sys_info (&sys_info); - gd->cpu_clk = sys_info.freqProcessor[0]; - gd->bus_clk = sys_info.freqSystemBus; - gd->mem_clk = sys_info.freqDDRBus; - gd->arch.lbc_clk = sys_info.freqLocalBus; + gd->cpu_clk = sys_info.freq_processor[0]; + gd->bus_clk = sys_info.freq_systembus; + gd->mem_clk = sys_info.freq_ddrbus; + gd->arch.lbc_clk = sys_info.freq_localbus;
#ifdef CONFIG_QE - gd->arch.qe_clk = sys_info.freqQE; + gd->arch.qe_clk = sys_info.freq_qe; gd->arch.brg_clk = gd->arch.qe_clk / 2; #endif /* @@ -400,7 +400,7 @@ int get_clocks (void) */ #if defined(CONFIG_MPC8540) || defined(CONFIG_MPC8541) || \ defined(CONFIG_MPC8560) || defined(CONFIG_MPC8555) - gd->arch.i2c1_clk = sys_info.freqSystemBus; + gd->arch.i2c1_clk = sys_info.freq_systembus; #elif defined(CONFIG_MPC8544) /* * On the 8544, the I2C clock is the same as the SEC clock. This can be @@ -410,12 +410,12 @@ int get_clocks (void) * PORDEVSR2_SEC_CFG bit is 0 on all 85xx boards that are not an 8544. */ if (gur->pordevsr2 & MPC85xx_PORDEVSR2_SEC_CFG) - gd->arch.i2c1_clk = sys_info.freqSystemBus / 3; + gd->arch.i2c1_clk = sys_info.freq_systembus / 3; else - gd->arch.i2c1_clk = sys_info.freqSystemBus / 2; + gd->arch.i2c1_clk = sys_info.freq_systembus / 2; #else /* Most 85xx SOCs use CCB/2, so this is the default behavior. */ - gd->arch.i2c1_clk = sys_info.freqSystemBus / 2; + gd->arch.i2c1_clk = sys_info.freq_systembus / 2; #endif gd->arch.i2c2_clk = gd->arch.i2c1_clk;
@@ -429,7 +429,7 @@ int get_clocks (void) #endif /* defined(CONFIG_FSL_ESDHC) */
#if defined(CONFIG_CPM2) - gd->arch.vco_out = 2*sys_info.freqSystemBus; + gd->arch.vco_out = 2*sys_info.freq_systembus; gd->arch.cpm_clk = gd->arch.vco_out / 2; gd->arch.scc_clk = gd->arch.vco_out / 4; gd->arch.brg_clk = gd->arch.vco_out / (1 << (2 * (dfbrg + 1))); diff --git a/arch/powerpc/cpu/mpc86xx/cpu.c b/arch/powerpc/cpu/mpc86xx/cpu.c index d6b28dd..ab3250b 100644 --- a/arch/powerpc/cpu/mpc86xx/cpu.c +++ b/arch/powerpc/cpu/mpc86xx/cpu.c @@ -72,17 +72,17 @@ checkcpu(void) get_sys_info(&sysinfo);
puts("Clock Configuration:\n"); - printf(" CPU:%-4s MHz, ", strmhz(buf1, sysinfo.freqProcessor)); - printf("MPX:%-4s MHz\n", strmhz(buf1, sysinfo.freqSystemBus)); + printf(" CPU:%-4s MHz, ", strmhz(buf1, sysinfo.freq_processor)); + printf("MPX:%-4s MHz\n", strmhz(buf1, sysinfo.freq_systembus)); printf(" DDR:%-4s MHz (%s MT/s data rate), ", - strmhz(buf1, sysinfo.freqSystemBus / 2), - strmhz(buf2, sysinfo.freqSystemBus)); + strmhz(buf1, sysinfo.freq_systembus / 2), + strmhz(buf2, sysinfo.freq_systembus));
puts("L1: D-cache 32 KB enabled\n"); @@ -131,7 +131,7 @@ get_tbclk(void) sys_info_t sys_info;
get_sys_info(&sys_info); - return (sys_info.freqSystemBus + 3L) / 4L; + return (sys_info.freq_systembus + 3L) / 4L; }
diff --git a/arch/powerpc/cpu/mpc86xx/speed.c b/arch/powerpc/cpu/mpc86xx/speed.c index ea366ab..854d02b 100644 --- a/arch/powerpc/cpu/mpc86xx/speed.c +++ b/arch/powerpc/cpu/mpc86xx/speed.c @@ -19,7 +19,7 @@ DECLARE_GLOBAL_DATA_PTR; /* used in some defintiions of CONFIG_SYS_CLK_FREQ */ extern unsigned long get_board_sys_clk(unsigned long dummy);
-void get_sys_info(sys_info_t *sysInfo) +void get_sys_info(sys_info_t *sys_info) { volatile immap_t *immap = (immap_t *) CONFIG_SYS_IMMR; volatile ccsr_gur_t *gur = &immap->im_gur; @@ -31,7 +31,7 @@ void get_sys_info(sys_info_t *sysInfo)
switch (plat_ratio) { case 0x0: - sysInfo->freqSystemBus = 16 * CONFIG_SYS_CLK_FREQ; + sys_info->freq_systembus = 16 * CONFIG_SYS_CLK_FREQ; break; case 0x02: case 0x03: @@ -43,10 +43,10 @@ void get_sys_info(sys_info_t *sysInfo) case 0x0a: case 0x0c: case 0x10: - sysInfo->freqSystemBus = plat_ratio * CONFIG_SYS_CLK_FREQ; + sys_info->freq_systembus = plat_ratio * CONFIG_SYS_CLK_FREQ; break; default: - sysInfo->freqSystemBus = 0; + sys_info->freq_systembus = 0; break; }
@@ -55,25 +55,26 @@ void get_sys_info(sys_info_t *sysInfo)
switch (e600_ratio) { case 0x10: - sysInfo->freqProcessor = 2 * sysInfo->freqSystemBus; + sys_info->freq_processor = 2 * sys_info->freq_systembus; break; case 0x19: - sysInfo->freqProcessor = 5 * sysInfo->freqSystemBus / 2; + sys_info->freq_processor = 5 * sys_info->freq_systembus / 2; break; case 0x20: - sysInfo->freqProcessor = 3 * sysInfo->freqSystemBus; + sys_info->freq_processor = 3 * sys_info->freq_systembus; break; case 0x39: - sysInfo->freqProcessor = 7 * sysInfo->freqSystemBus / 2; + sys_info->freq_processor = 7 * sys_info->freq_systembus / 2; break; case 0x28: - sysInfo->freqProcessor = 4 * sysInfo->freqSystemBus; + sys_info->freq_processor = 4 * sys_info->freq_systembus; break; case 0x1d: - sysInfo->freqProcessor = 9 * sysInfo->freqSystemBus / 2; + sys_info->freq_processor = 9 * sys_info->freq_systembus / 2; break; default: - sysInfo->freqProcessor = e600_ratio + sysInfo->freqSystemBus; + sys_info->freq_processor = e600_ratio + + sys_info->freq_systembus; break; }
@@ -84,10 +85,11 @@ void get_sys_info(sys_info_t *sysInfo) lcrr_div = in_be32(&immap->im_lbc.lcrr) & LCRR_CLKDIV; #endif if (lcrr_div == 2 || lcrr_div == 4 || lcrr_div == 8) { - sysInfo->freqLocalBus = sysInfo->freqSystemBus / (lcrr_div * 2); + sys_info->freq_localbus = sys_info->freq_systembus + / (lcrr_div * 2); } else { /* In case anyone cares what the unknown value is */ - sysInfo->freqLocalBus = lcrr_div; + sys_info->freq_localbus = lcrr_div; } }
@@ -102,9 +104,9 @@ int get_clocks(void) sys_info_t sys_info;
get_sys_info(&sys_info); - gd->cpu_clk = sys_info.freqProcessor; - gd->bus_clk = sys_info.freqSystemBus; - gd->arch.lbc_clk = sys_info.freqLocalBus; + gd->cpu_clk = sys_info.freq_processor; + gd->bus_clk = sys_info.freq_systembus; + gd->arch.lbc_clk = sys_info.freq_localbus;
/* * The base clock for I2C depends on the actual SOC. Unfortunately, @@ -114,9 +116,9 @@ int get_clocks(void) * AN2919. */ #ifdef CONFIG_MPC8610 - gd->arch.i2c1_clk = sys_info.freqSystemBus; + gd->arch.i2c1_clk = sys_info.freq_systembus; #else - gd->arch.i2c1_clk = sys_info.freqSystemBus / 2; + gd->arch.i2c1_clk = sys_info.freq_systembus / 2; #endif gd->arch.i2c2_clk = gd->arch.i2c1_clk;
@@ -138,7 +140,7 @@ ulong get_bus_freq(ulong dummy) sys_info_t sys_info;
get_sys_info(&sys_info); - val = sys_info.freqSystemBus; + val = sys_info.freq_systembus;
return val; } diff --git a/board/freescale/mpc8540ads/mpc8540ads.c b/board/freescale/mpc8540ads/mpc8540ads.c index 7a84cd2..2fb4037 100644 --- a/board/freescale/mpc8540ads/mpc8540ads.c +++ b/board/freescale/mpc8540ads/mpc8540ads.c @@ -68,7 +68,7 @@ local_bus_init(void)
get_sys_info(&sysinfo); clkdiv = lbc->lcrr & LCRR_CLKDIV; - lbc_hz = sysinfo.freqSystemBus / 1000000 / clkdiv; + lbc_hz = sysinfo.freq_systembus / 1000000 / clkdiv;
if (lbc_hz < 66) { lbc->lcrr = CONFIG_SYS_LBC_LCRR | LCRR_DBYP; /* DLL Bypass */ diff --git a/board/freescale/mpc8541cds/mpc8541cds.c b/board/freescale/mpc8541cds/mpc8541cds.c index 3d2dabd..1e21a66 100644 --- a/board/freescale/mpc8541cds/mpc8541cds.c +++ b/board/freescale/mpc8541cds/mpc8541cds.c @@ -250,7 +250,7 @@ local_bus_init(void)
if (lbc_hz < 66) { lbc->lcrr |= LCRR_DBYP; /* DLL Bypass */ diff --git a/board/freescale/mpc8555cds/mpc8555cds.c b/board/freescale/mpc8555cds/mpc8555cds.c index d4e7abe..ee92695 100644 --- a/board/freescale/mpc8555cds/mpc8555cds.c +++ b/board/freescale/mpc8555cds/mpc8555cds.c @@ -248,7 +248,7 @@ local_bus_init(void)
if (lbc_hz < 66) { lbc->lcrr |= LCRR_DBYP; /* DLL Bypass */ diff --git a/board/freescale/mpc8560ads/mpc8560ads.c b/board/freescale/mpc8560ads/mpc8560ads.c index a45a558..162636e 100644 --- a/board/freescale/mpc8560ads/mpc8560ads.c +++ b/board/freescale/mpc8560ads/mpc8560ads.c @@ -273,7 +273,7 @@ local_bus_init(void)
if (lbc_hz < 66) { lbc->lcrr = CONFIG_SYS_LBC_LCRR | LCRR_DBYP; /* DLL Bypass */ diff --git a/board/freescale/p1_p2_rdb_pc/ddr.c b/board/freescale/p1_p2_rdb_pc/ddr.c index 5c51845..c0b72e0 100644 --- a/board/freescale/p1_p2_rdb_pc/ddr.c +++ b/board/freescale/p1_p2_rdb_pc/ddr.c @@ -247,7 +247,7 @@ phys_size_t fixed_sdram(void)
get_sys_info(&sysinfo); printf("Configuring DDR for %s MT/s data rate\n", - strmhz(buf, sysinfo.freqDDRBus)); + strmhz(buf, sysinfo.freq_ddrbus));
ddr_size = CONFIG_SYS_SDRAM_SIZE * 1024 * 1024;
diff --git a/board/freescale/p1_twr/ddr.c b/board/freescale/p1_twr/ddr.c index 697c0dd..67f69d7 100644 --- a/board/freescale/p1_twr/ddr.c +++ b/board/freescale/p1_twr/ddr.c @@ -53,7 +53,7 @@ phys_size_t fixed_sdram(void)
diff --git a/board/sbc8548/sbc8548.c b/board/sbc8548/sbc8548.c index dee8710..8378518 100644 --- a/board/sbc8548/sbc8548.c +++ b/board/sbc8548/sbc8548.c @@ -65,8 +65,8 @@ local_bus_init(void)
- lbc_mhz = sysinfo.freqLocalBus / 1000000; - clkdiv = sysinfo.freqSystemBus / sysinfo.freqLocalBus; + lbc_mhz = sysinfo.freq_localbus / 1000000; + clkdiv = sysinfo.freq_systembus / sysinfo.freq_localbus;
debug("LCRR=0x%x, CD=%d, MHz=%d\n", lcrr, clkdiv, lbc_mhz);
diff --git a/board/socrates/socrates.c b/board/socrates/socrates.c index 97fd0e4..2caefbb 100644 --- a/board/socrates/socrates.c +++ b/board/socrates/socrates.c @@ -143,7 +143,7 @@ void local_bus_init (void)
get_sys_info (&sysinfo); clkdiv = lbc->lcrr & LCRR_CLKDIV; - lbc_mhz = sysinfo.freqSystemBus / 1000000 / clkdiv; + lbc_mhz = sysinfo.freq_systembus / 1000000 / clkdiv;
/* Disable PLL bypass for Local Bus Clock >= 66 MHz */ if (lbc_mhz >= 66) diff --git a/board/xes/xpedite537x/ddr.c b/board/xes/xpedite537x/ddr.c index 0daa189..c128fcb 100644 --- a/board/xes/xpedite537x/ddr.c +++ b/board/xes/xpedite537x/ddr.c @@ -210,7 +210,7 @@ void fsl_ddr_board_options(memctl_options_t *popts, unsigned int datarate;
get_sys_info(&sysinfo); - datarate = sysinfo.freqDDRBus / 1000 / 1000; + datarate = sysinfo.freq_ddrbus / 1000 / 1000;
for (i = 0; i < ARRAY_SIZE(bopts_ctrl[ctrl_num]); i++) { if ((bopts[i].datarate_mhz_low <= datarate) && diff --git a/drivers/spi/fsl_espi.c b/drivers/spi/fsl_espi.c index c883d3c..7c84582 100644 --- a/drivers/spi/fsl_espi.c +++ b/drivers/spi/fsl_espi.c @@ -75,7 +75,7 @@ struct spi_slave *spi_setup_slave(unsigned int bus, unsigned int cs,
/* Set eSPI BRG clock source */ get_sys_info(&sysinfo); - spibrg = sysinfo.freqSystemBus / 2; + spibrg = sysinfo.freq_systembus / 2; fsl->div16 = 0; if ((spibrg / max_hz) > 32) { fsl->div16 = ESPI_CSMODE_DIV16; diff --git a/include/e500.h b/include/e500.h index 0ff8e89..0c24326 100644 --- a/include/e500.h +++ b/include/e500.h @@ -10,19 +10,19 @@
typedef struct { - unsigned long freqProcessor[CONFIG_MAX_CPUS]; - unsigned long freqSystemBus; - unsigned long freqDDRBus; - unsigned long freqLocalBus; - unsigned long freqQE; + unsigned long freq_processor[CONFIG_MAX_CPUS]; + unsigned long freq_systembus; + unsigned long freq_ddrbus; + unsigned long freq_localbus; + unsigned long freq_qe; #ifdef CONFIG_SYS_DPAA_FMAN - unsigned long freqFMan[CONFIG_SYS_NUM_FMAN]; + unsigned long freq_fman[CONFIG_SYS_NUM_FMAN]; #endif #ifdef CONFIG_SYS_DPAA_QBMAN - unsigned long freqQMAN; + unsigned long freq_qman; #endif #ifdef CONFIG_SYS_DPAA_PME - unsigned long freqPME; + unsigned long freq_pme; #endif } MPC85xx_SYS_INFO;
diff --git a/include/mpc86xx.h b/include/mpc86xx.h index 31e83f2..9fe4748 100644 --- a/include/mpc86xx.h +++ b/include/mpc86xx.h @@ -41,9 +41,9 @@ #ifndef __ASSEMBLY__
typedef struct { - unsigned long freqProcessor; - unsigned long freqSystemBus; - unsigned long freqLocalBus; + unsigned long freq_processor; + unsigned long freq_systembus; + unsigned long freq_localbus; } MPC86xx_SYS_INFO;
#define l1icache_enable icache_enable
Applied to u-boot-mpc85xx.git.
York
Prabhakar Kushwaha
York Sun
