[U-Boot] [PATCH] 83xx: Fix some bugs in spd sdram code
1. rd_to_pre is missed to add the AL. 2. add the support of DDR2-533,667,800 DIMMs 3. cpo 4. make the AL to min to gain better performance.
The Micron MT9HTF6472CHY-667D1 DIMMs test passed on MPC837xEMDS platform at 266MHz/333MHz/400MHz data rate.
Reported-by: Joakim Tjernlund Joakim.Tjernlund@transmode.se Signed-off-by: Dave Liu daveliu@freescale.com --- cpu/mpc83xx/spd_sdram.c | 23 ++++++++++++++++++++--- 1 files changed, 20 insertions(+), 3 deletions(-)
diff --git a/cpu/mpc83xx/spd_sdram.c b/cpu/mpc83xx/spd_sdram.c index 42a4e67..ecbc70c 100644 --- a/cpu/mpc83xx/spd_sdram.c +++ b/cpu/mpc83xx/spd_sdram.c @@ -319,7 +319,21 @@ long int spd_sdram() ddrc_clk = gd->mem_clk / 1000000; effective_data_rate = 0;
- if (max_data_rate >= 390 && max_data_rate < 460) { /* it is DDR 400 */ + if (max_data_rate >= 460) { /* it is DDR2-800, 667, 533 */ + if (spd.cas_lat & 0x08) + caslat = 3; + else + caslat = 4; + + if (ddrc_clk <= 460 && ddrc_clk > 350) + effective_data_rate = 400; + else if (ddrc_clk <=350 && ddrc_clk > 280) + effective_data_rate = 333; + else if (ddrc_clk <= 280 && ddrc_clk > 230) + effective_data_rate = 266; + else + effective_data_rate = 200; + } else if (max_data_rate >= 390 && max_data_rate < 460) { /* it is DDR 400 */ if (ddrc_clk <= 460 && ddrc_clk > 350) { /* DDR controller clk at 350~460 */ effective_data_rate = 400; /* 5ns */ @@ -529,7 +543,7 @@ long int spd_sdram() if (spd.mem_type == SPD_MEMTYPE_DDR2 && (odt_wr_cfg || odt_rd_cfg) && (caslat < 4)) { - add_lat = trcd_clk - 1; + add_lat = 4 - caslat; if ((add_lat + caslat) < 4) { add_lat = 0; } @@ -566,6 +580,7 @@ long int spd_sdram()
/* Convert SPD value from quarter nanos to picos. */ trtp_clk = picos_to_clk(spd.trtp * 250); + trtp_clk += add_lat;
cke_min_clk = 3; /* By the book. */ four_act = picos_to_clk(37500); /* By the book. 1k pages? */ @@ -579,7 +594,9 @@ long int spd_sdram() if (spd.mem_type == SPD_MEMTYPE_DDR2) { if (effective_data_rate == 266) { cpo = 0x4; /* READ_LAT + 1/2 */ - } else if (effective_data_rate == 333 || effective_data_rate == 400) { + } else if (effective_data_rate == 333) { + cpo = 0x6; /* READ_LAT + 1 */ + } else if (effective_data_rate == 400) { cpo = 0x7; /* READ_LAT + 5/4 */ } else { /* Automatic calibration */
Dave Liu
