[U-Boot] [PATCH v3] Improve Power Management in SMC911X driver.
From datasheet, when READY bit is set inside PM_CTRL register, it means that
device is already in *normal* (D0) mode => it doesn't need to be wake-up.
With this patch, we only wake-up (writing on TEST_BYTE register) if PM_MODE bits of PM_CTRL register is in sleep (D1/D2) mode.
Signed-off-by: Bertrand Cachet bertrand.cachet@heig-vd.ch --- v2: Improve code styling by grouping two narrow comments. v3: Place versions information under scissors line.
drivers/net/smc911x.h | 7 +++++-- 1 files changed, 5 insertions(+), 2 deletions(-)
diff --git a/drivers/net/smc911x.h b/drivers/net/smc911x.h index 8ce08a9..00e5b2e 100644 --- a/drivers/net/smc911x.h +++ b/drivers/net/smc911x.h @@ -471,8 +471,11 @@ static void smc911x_reset(struct eth_device *dev) { int timeout;
- /* Take out of PM setting first */ - if (smc911x_reg_read(dev, PMT_CTRL) & PMT_CTRL_READY) { + /* + * Take out of PM setting first + * Device is already wake up if PMT_CTRL_READY bit is set + */ + if ((smc911x_reg_read(dev, PMT_CTRL) & PMT_CTRL_READY) == 0) { /* Write to the bytetest will take out of powerdown */ smc911x_reg_write(dev, BYTE_TEST, 0x0);
Bertrand Cachet
