[PATCH v4] fdt: automatically add /chosen/kaslr-seed if DM_RNG is enabled
If RANDOMIZE_BASE is enabled in the Linux kernel instructing it to randomize the virtual address at which the kernel image is loaded, it expects entropy to be provided by the bootloader by populating /chosen/kaslr-seed with a 64-bit value from source of entropy at boot.
If we have DM_RNG enabled populate this value automatically when fdt_chosen is called. We skip this if ARMV8_SEC_FIRMWARE_SUPPORT is enabled as it's implementation uses a different source of entropy that is not yet implemented as DM_RNG. We also skip this if MEASURED_BOOT is enabled as in that case any modifications to the dt will cause measured boot to fail (although there are many other places the dt is altered).
As this fdt node is added elsewhere create a library function and use it to deduplicate code. We will provide a parameter to specify the index of the rng device as well as a boolean to overwrite if present.
For our automatic injection, we will use the first rng device and not overwrite if already present with a non-zero value (which may have been populated by an earlier boot stage). This way if a board specific ft_board_setup() function wants to customize this behavior it can call fdt_kaslrseed with a rng device index of its choosing and set overwrite true.
Note that the kalsrseed command (CMD_KASLRSEED) is likely pointless now but left in place in case boot scripts exist that rely on this command existing and returning success. An informational message is printed to alert users of this command that it is likely no longer needed.
Note that the Kernel's EFI STUB only relies on EFI_RNG_PROTOCOL for randomization and completely ignores the kaslr-seed for its own randomness needs (i.e the randomization of the physical placement of the kernel). It gets weeded out from the DTB that gets handed over via efi_install_fdt() as it would also mess up the measured boot DTB TPM measurements as well.
Signed-off-by: Tim Harvey tharvey@gateworks.com Cc: Michal Simek michal.simek@amd.com Cc: Andy Yan andy.yan@rock-chips.com Cc: Akash Gajjar gajjar04akash@gmail.com Cc: Ilias Apalodimas ilias.apalodimas@linaro.org Cc: Simon Glass sjg@chromium.org Cc: Patrick Delaunay patrick.delaunay@foss.st.com Cc: Patrice Chotard patrice.chotard@foss.st.com Cc: Devarsh Thakkar devarsht@ti.com Cc: Heinrich Schuchardt xypron.glpk@gmx.de Cc: Hugo Villeneuve hvilleneuve@dimonoff.com Cc: Marek Vasut marex@denx.de Cc: Tom Rini trini@konsulko.com Cc: Chris Morgan macromorgan@hotmail.com --- v4: - add missing /n to notice in kaslrseed cmd - combine ints in declaration - remove unused vars from board/xilinx/common/board.c ft_board_setup v3: - skip if CONFIG_MEASURED_BOOT - fix skip for CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT - pass in rng index and bool to specify overwrite - remove duplicate error strings printed outside of fdt_kaslrseed - added note to commit log about how EFI STUB weeds out kalsr-seed v2: - fix typo in commit msg - use stack for seed to avoid unecessary malloc/free - move to a library function and deduplicate code by using it elsewhere --- board/xilinx/common/board.c | 40 ------------------------------ boot/fdt_support.c | 6 +++++ boot/pxe_utils.c | 35 ++------------------------ cmd/kaslrseed.c | 45 +++++----------------------------- include/kaslrseed.h | 19 ++++++++++++++ lib/Makefile | 1 + lib/kaslrseed.c | 49 +++++++++++++++++++++++++++++++++++++ 7 files changed, 83 insertions(+), 112 deletions(-) create mode 100644 include/kaslrseed.h create mode 100644 lib/kaslrseed.c
diff --git a/board/xilinx/common/board.c b/board/xilinx/common/board.c index 30a81376ac41..0b43407b9e94 100644 --- a/board/xilinx/common/board.c +++ b/board/xilinx/common/board.c @@ -701,11 +701,6 @@ phys_addr_t board_get_usable_ram_top(phys_size_t total_size) #define MAX_RAND_SIZE 8 int ft_board_setup(void *blob, struct bd_info *bd) { - size_t n = MAX_RAND_SIZE; - struct udevice *dev; - u8 buf[MAX_RAND_SIZE]; - int nodeoffset, ret; - static const struct node_info nodes[] = { { "arm,pl353-nand-r2p1", MTD_DEV_TYPE_NAND, }, }; @@ -713,41 +708,6 @@ int ft_board_setup(void *blob, struct bd_info *bd) if (IS_ENABLED(CONFIG_FDT_FIXUP_PARTITIONS) && IS_ENABLED(CONFIG_NAND_ZYNQ)) fdt_fixup_mtdparts(blob, nodes, ARRAY_SIZE(nodes));
- if (uclass_get_device(UCLASS_RNG, 0, &dev) || !dev) { - debug("No RNG device\n"); - return 0; - } - - if (dm_rng_read(dev, buf, n)) { - debug("Reading RNG failed\n"); - return 0; - } - - if (!blob) { - debug("No FDT memory address configured. Please configure\n" - "the FDT address via "fdt addr <address>" command.\n" - "Aborting!\n"); - return 0; - } - - ret = fdt_check_header(blob); - if (ret < 0) { - debug("fdt_chosen: %s\n", fdt_strerror(ret)); - return ret; - } - - nodeoffset = fdt_find_or_add_subnode(blob, 0, "chosen"); - if (nodeoffset < 0) { - debug("Reading chosen node failed\n"); - return nodeoffset; - } - - ret = fdt_setprop(blob, nodeoffset, "kaslr-seed", buf, sizeof(buf)); - if (ret < 0) { - debug("Unable to set kaslr-seed on chosen node: %s\n", fdt_strerror(ret)); - return ret; - } - return 0; } #endif diff --git a/boot/fdt_support.c b/boot/fdt_support.c index 874ca4d6f5af..b64cdd34825a 100644 --- a/boot/fdt_support.c +++ b/boot/fdt_support.c @@ -8,6 +8,7 @@
#include <abuf.h> #include <env.h> +#include <kaslrseed.h> #include <log.h> #include <mapmem.h> #include <net.h> @@ -300,6 +301,11 @@ int fdt_chosen(void *fdt) if (nodeoffset < 0) return nodeoffset;
+ if (IS_ENABLED(CONFIG_DM_RNG) && + !IS_ENABLED(CONFIG_MEASURED_BOOT) && + !IS_ENABLED(CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT)) + fdt_kaslrseed(fdt, 0, false); + if (IS_ENABLED(CONFIG_BOARD_RNG_SEED) && !board_rng_seed(&buf)) { err = fdt_setprop(fdt, nodeoffset, "rng-seed", abuf_data(&buf), abuf_size(&buf)); diff --git a/boot/pxe_utils.c b/boot/pxe_utils.c index 4b22bb6f525a..35d5b9ed3ecc 100644 --- a/boot/pxe_utils.c +++ b/boot/pxe_utils.c @@ -8,6 +8,7 @@ #include <dm.h> #include <env.h> #include <image.h> +#include <kaslrseed.h> #include <log.h> #include <malloc.h> #include <mapmem.h> @@ -323,10 +324,6 @@ static void label_boot_kaslrseed(void) #if CONFIG_IS_ENABLED(DM_RNG) ulong fdt_addr; struct fdt_header *working_fdt; - size_t n = 0x8; - struct udevice *dev; - u64 *buf; - int nodeoffset; int err;
/* Get the main fdt and map it */ @@ -342,35 +339,7 @@ static void label_boot_kaslrseed(void) if (err <= 0) return;
- if (uclass_get_device(UCLASS_RNG, 0, &dev) || !dev) { - printf("No RNG device\n"); - return; - } - - nodeoffset = fdt_find_or_add_subnode(working_fdt, 0, "chosen"); - if (nodeoffset < 0) { - printf("Reading chosen node failed\n"); - return; - } - - buf = malloc(n); - if (!buf) { - printf("Out of memory\n"); - return; - } - - if (dm_rng_read(dev, buf, n)) { - printf("Reading RNG failed\n"); - goto err; - } - - err = fdt_setprop(working_fdt, nodeoffset, "kaslr-seed", buf, sizeof(buf)); - if (err < 0) { - printf("Unable to set kaslr-seed on chosen node: %s\n", fdt_strerror(err)); - goto err; - } -err: - free(buf); + fdt_kaslrseed(working_fdt, 0, true); #endif return; } diff --git a/cmd/kaslrseed.c b/cmd/kaslrseed.c index e0d3c7fe7489..ebe4058d7ac6 100644 --- a/cmd/kaslrseed.c +++ b/cmd/kaslrseed.c @@ -9,33 +9,16 @@ #include <command.h> #include <dm.h> #include <hexdump.h> +#include <kaslrseed.h> #include <malloc.h> #include <rng.h> #include <fdt_support.h>
static int do_kaslr_seed(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) { - size_t n = 0x8; - struct udevice *dev; - u64 *buf; - int nodeoffset; - int ret = CMD_RET_SUCCESS; + int err;
- if (uclass_get_device(UCLASS_RNG, 0, &dev) || !dev) { - printf("No RNG device\n"); - return CMD_RET_FAILURE; - } - - buf = malloc(n); - if (!buf) { - printf("Out of memory\n"); - return CMD_RET_FAILURE; - } - - if (dm_rng_read(dev, buf, n)) { - printf("Reading RNG failed\n"); - return CMD_RET_FAILURE; - } + printf("Notice: a /chosen/kaslr-seed is automatically added to the device-tree when booted via booti/bootm/bootz therefore using this command is likely no longer needed\n");
if (!working_fdt) { printf("No FDT memory address configured. Please configure\n" @@ -44,27 +27,11 @@ static int do_kaslr_seed(struct cmd_tbl *cmdtp, int flag, int argc, char *const return CMD_RET_FAILURE; }
- ret = fdt_check_header(working_fdt); - if (ret < 0) { - printf("fdt_chosen: %s\n", fdt_strerror(ret)); + err = fdt_kaslrseed(working_fdt, 0, true); + if (err < 0) return CMD_RET_FAILURE; - } - - nodeoffset = fdt_find_or_add_subnode(working_fdt, 0, "chosen"); - if (nodeoffset < 0) { - printf("Reading chosen node failed\n"); - return CMD_RET_FAILURE; - } - - ret = fdt_setprop(working_fdt, nodeoffset, "kaslr-seed", buf, sizeof(buf)); - if (ret < 0) { - printf("Unable to set kaslr-seed on chosen node: %s\n", fdt_strerror(ret)); - return CMD_RET_FAILURE; - } - - free(buf);
- return ret; + return CMD_RET_SUCCESS; }
U_BOOT_LONGHELP(kaslrseed, diff --git a/include/kaslrseed.h b/include/kaslrseed.h new file mode 100644 index 000000000000..7f9911c59fa4 --- /dev/null +++ b/include/kaslrseed.h @@ -0,0 +1,19 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright 2024 Tim Harvey tharvey@gateworks.com + */ + +#if !defined _KASLRSEED_H_ +#define _KASLRSEED_H_ + +/** + * fdt_kaslrseed() - create a 'kaslr-seed' node in chosen + * + * @blob: fdt blob + * @index: index of UCLASS_RNG device to use + * @overwrite: do not overwrite existing non-zero node unless true + * Return: 0 if OK, -ve on error + */ +int fdt_kaslrseed(void *blob, int index, bool overwrite); + +#endif /* _KASLRSEED_H_ */ diff --git a/lib/Makefile b/lib/Makefile index 2a76acf100d0..20a0242055fa 100644 --- a/lib/Makefile +++ b/lib/Makefile @@ -149,6 +149,7 @@ obj-y += date.o obj-y += rtc-lib.o obj-$(CONFIG_LIB_ELF) += elf.o
+obj-$(CONFIG_DM_RNG) += kaslrseed.o obj-$(CONFIG_$(SPL_TPL_)SEMIHOSTING) += semihosting.o
# diff --git a/lib/kaslrseed.c b/lib/kaslrseed.c new file mode 100644 index 000000000000..5ba3700e9e06 --- /dev/null +++ b/lib/kaslrseed.c @@ -0,0 +1,49 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2024 Tim Harvey tharvey@gateworks.com + */ +#include <dm.h> +#include <rng.h> +#include <fdt_support.h> +#include <dm/device_compat.h> + +int fdt_kaslrseed(void *fdt, int index, bool overwrite) +{ + int len, err, nodeoffset; + struct udevice *dev; + const u64 *orig; + u64 data = 0; + + err = fdt_check_header(fdt); + if (err < 0) + return err; + + /* find or create "/chosen" node. */ + nodeoffset = fdt_find_or_add_subnode(fdt, 0, "chosen"); + if (nodeoffset < 0) + return nodeoffset; + + /* return without error if we are not overwriting and existing non-zero node */ + orig = fdt_getprop(fdt, nodeoffset, "kaslr-seed", &len); + if (orig && len == sizeof(*orig)) + data = fdt64_to_cpu(*orig); + if (data && !overwrite) { + debug("not overwriting existing kaslr-seed\n"); + return 0; + } + err = uclass_get_device(UCLASS_RNG, index, &dev); + if (err) { + printf("No RNG device at index %d\n", index); + return err; + } + err = dm_rng_read(dev, &data, sizeof(data)); + if (err) { + dev_err(dev, "dm_rng_read failed: %d\n", err); + return err; + } + err = fdt_setprop(fdt, nodeoffset, "kaslr-seed", &data, sizeof(data)); + if (err < 0) + printf("WARNING: could not set kaslr-seed %s.\n", fdt_strerror(err)); + + return err; +}
v4:
v3:
v2:
- if (!blob) {
"the FDT address via \"fdt addr <address>\" command.\n"
"Aborting!\n");
- if (ret < 0) {
return ret;
return nodeoffset;
- if (ret < 0) {
return ret;
- if (IS_ENABLED(CONFIG_DM_RNG) &&
- if (IS_ENABLED(CONFIG_BOARD_RNG_SEED) && !board_rng_seed(&buf)) { err = fdt_setprop(fdt, nodeoffset, "rng-seed", abuf_data(&buf), abuf_size(&buf));
size_t n = 0x8;
u64 *buf;
return;
return;
- buf = malloc(n);
- if (!buf) {
return;
goto err;
- if (err < 0) {
goto err;
-err:
- free(buf);
- fdt_kaslrseed(working_fdt, 0, true); #endif return; }
- size_t n = 0x8;
- u64 *buf;
- int nodeoffset;
- int err;
- buf = malloc(n);
- if (!buf) {
- if (ret < 0) {
- err = fdt_kaslrseed(working_fdt, 0, true);
- if (err < 0) return CMD_RET_FAILURE;
if (ret < 0) {
free(buf);
return ret;
- return CMD_RET_SUCCESS;
You should consider to use standard function here. return cmd_process_error(cmdtp, err);
Anyway looks good to me. Acked-by: Michal Simek michal.simek@amd.com Tested-by: Michal Simek michal.simek@amd.com # ZynqMP Kria
Thanks, Michal
v4:
v3:
v2:
if (!blob) {
"Aborting!\n");
if (ret < 0) {
return ret;
return nodeoffset;
if (ret < 0) {
return ret;
} #endifreturn 0;
size_t n = 0x8;
u64 *buf;
int nodeoffset; int err; /* Get the main fdt and map it */
return;
return;
buf = malloc(n);
if (!buf) {
return;
goto err;
if (err < 0) {
goto err;
-err:
free(buf);
#endif return; }fdt_kaslrseed(working_fdt, 0, true);
size_t n = 0x8;
u64 *buf;
int nodeoffset;
int err;
buf = malloc(n);
if (!buf) {
printf("Notice: a /chosen/kaslr-seed is automatically added to the device-tree when booted via booti/bootm/bootz therefore using this command is likely no longer needed\n"); if (!working_fdt) { printf("No FDT memory address configured. Please configure\n"
if (ret < 0) {
if (ret < 0) {
free(buf);
return ret;
how about this on top?:
diff --git a/cmd/kaslrseed.c b/cmd/kaslrseed.c index ebe4058d7ac6..3e93369e9372 100644 --- a/cmd/kaslrseed.c +++ b/cmd/kaslrseed.c @@ -16,7 +16,7 @@
static int do_kaslr_seed(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) { - int err; + int err = CMD_RET_SUCCESS;
printf("Notice: a /chosen/kaslr-seed is automatically added to the device-tree when booted via booti/bootm/bootz therefore us ing this command is likely no longer needed\n");
@@ -24,14 +24,13 @@ static int do_kaslr_seed(struct cmd_tbl *cmdtp, int flag, int argc, char *const printf("No FDT memory address configured. Please configure\n" "the FDT address via "fdt addr <address>" command.\n" "Aborting!\n"); - return CMD_RET_FAILURE; + err = CMD_RET_FAILURE; + } else { + if (fdt_kaslrseed(working_fdt, 0, true) < 0) + err = CMD_RET_FAILURE; }
- err = fdt_kaslrseed(working_fdt, 0, true); - if (err < 0) - return CMD_RET_FAILURE; - - return CMD_RET_SUCCESS; + return cmd_process_error(cmdtp, err); }
Best Regards,
Tim
Thanks, Michal
Hi Tim,
its
I suggest creating a sysinfo driver which can provide the RNG device.
v4:
v3:
v2:
Are you able to split this patch into a few patches, one of which handles the refactoring first?
if (!blob) {
"Aborting!\n");
if (ret < 0) {
return ret;
return nodeoffset;
if (ret < 0) {
return ret;
This looks like it needs a new Kconfig to enable this behaviour, rather than inferring it from others.
size_t n = 0x8;
u64 *buf;
return;
return;
buf = malloc(n);
if (!buf) {
return;
goto err;
if (err < 0) {
goto err;
-err:
free(buf);
size_t n = 0x8;
u64 *buf;
int nodeoffset;
int err;
buf = malloc(n);
if (!buf) {
if (ret < 0) {
if (ret < 0) {
free(buf);
return ret;
- Copyright 2024 Tim Harvey tharvey@gateworks.com
- fdt_kaslrseed() - create a 'kaslr-seed' node in chosen
- @blob: fdt blob
- @index: index of UCLASS_RNG device to use
- @overwrite: do not overwrite existing non-zero node unless true
- Return: 0 if OK, -ve on error
Shouldn't this go in fdt_support.c ?
const u64 *orig;
u64 data = 0;
if (err < 0)
return err;
if (nodeoffset < 0)
return nodeoffset;
if (err) {
return err;
if (err) {
return err;
if (err < 0)
return err;
2.25.1
On Wed, May 29, 2024 at 9:30 AM Simon Glass sjg@chromium.org wrote:
Hi Tim,
its
Hi Simon,
Thanks for the review. I can fix that.
I'm not really clear what you mean but that seems out of scope for this patch. If/when someone needs to extend the functionality of specifying one of many RNG's perhaps they can follow that approach.
v4:
v3:
v2:
as in the following? 1/3 Add fdt_kaslrseed function to add kaslr-seed to chosen node 2/3 fdt: automatically add /chosen/kaslr-seed if DM_RNG is enabled 3/3 Use fdt_kaslrseed function to de-duplicate code
if (!blob) {
"Aborting!\n");
if (ret < 0) {
return ret;
return nodeoffset;
if (ret < 0) {
return ret;
I hate to add additional Kconfigs when I don't feel they are necessary. I'm doing this for the following reason (which I can add a comment for):
!CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT: We are skipping this case temporarily until that code is refactored to use DM_RNG (which is out of the scope of this patch). If someone could provide a patch that make CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT a DM_RNG driver I could add it to my series.
!CONFIG_MEASURED_BOOT: We do not want to modify the dt as it will break measured boot. Honestly I think I should drop this as if you are in this function you are modifying other dt props. I believe keeping the dt unmodified for measured boot should be out of the scope of this patch and will require additional work elsewhere. When this work is done (out of scope of this patch) then it likely could/should be implmeneted via a new Kconfig (ie CONFIG_NO_DTMODS).
Thoughts?
size_t n = 0x8;
u64 *buf;
return;
return;
buf = malloc(n);
if (!buf) {
return;
goto err;
if (err < 0) {
goto err;
-err:
free(buf);
size_t n = 0x8;
u64 *buf;
int nodeoffset;
int err;
buf = malloc(n);
if (!buf) {
if (ret < 0) {
if (ret < 0) {
free(buf);
return ret;
- @blob: fdt blob
Sure, I can change that. Are you happy with the function prototype?
Best Regards,
Tim
const u64 *orig;
u64 data = 0;
if (err < 0)
return err;
if (nodeoffset < 0)
return nodeoffset;
if (err) {
return err;
if (err) {
return err;
if (err < 0)
return err;
2.25.1
Hi Tim,
Hi Tim,
its
Hi Simon,
The thing is, you are creating a way to specify the RNG which will presumably lead to different vendors all doing it a different way.
Specifically, fdt_kaslrseed() takes a device number (would be better to take a struct udevice, BTW).
Instead, I think you should define the standard way that the chosen RNG should be specified by the board. The sysinfo driver can provide a way to do this. Then boards can handle this themselves, using sysinfo, rather than directly calling a function in the fixup. After all, we want the fixup flow to be as generic as possible.
v4:
v3:
v2:
Yes that is good
if (!blob) {
"Aborting!\n");
if (ret < 0) {
return ret;
return nodeoffset;
if (ret < 0) {
return ret;
OK, then perhaps add a comment?
Thoughts?
The inability to modify the DT is a flaw in measured boot, but I'll leave that issue for now.
If you really don't want to add a Kconfig, that is OK.
size_t n = 0x8;
u64 *buf;
return;
return;
buf = malloc(n);
if (!buf) {
return;
goto err;
if (err < 0) {
goto err;
-err:
free(buf);
size_t n = 0x8;
u64 *buf;
int nodeoffset;
int err;
buf = malloc(n);
if (!buf) {
if (ret < 0) {
if (ret < 0) {
free(buf);
return ret;
- @blob: fdt blob
Well see my sysinfo comment above (and use struct udevice * instead of int). Somewhere, it should use that to determine the RNG device.
I think this patch simply picks up the first RNG that is available, pulls a number out of it, and uses that as the KASLR seed in DT. That's what the implementation(s) seems to be doing so far, this patch is a deduplication only, so maybe we should retain the original behavior first, and do architectural changes in follow up patch(es) ?
Marek,
Thank you - I had a draft saying exactly the same thing that I hadn't sent out yet.
This is an incremental improvement... for sure there are follow-on improvements that can be made and should be made but the sysinfo and policy creation are something I don't have time for at the moment and may not be the right person to implement that. I'm happy to accept something to add to my series though!
So the question is, if we can agree that improvements can continue to be made later should I do one more revision that split this out into three patches and fixes the typo in the commit?
Best Regards,
Tim
Marek,
OK, well specifically, my objection is to the 'index' argument, since someone will pass 1 to it and then we have a new API.
So if you can drop that and go back to the hard-coded 0, then I agree this is just a refactoring and yes, this is fine.
Michal Simek
Tim Harvey
