[PATCH] tools: kwboot: Allow to use -b without image path as the last getopt() option
Currently it is possible to call "kwboot -b -t /dev/ttyUSB0" but not to call "kwboot -b /dev/ttyUSB0".
Fix it by not trying to process the last argv[], which is non-getopt() option (tty path) as the image path for -b.
Fixes: c513fe47dca2 ("tools: kwboot: Allow to use option -b without image path") Reported-by: Marcel Ziswiler marcel@ziswiler.com Signed-off-by: Pali Rohár pali@kernel.org Reviewed-by: Marcel Ziswiler marcel@ziswiler.com Tested-by: Marcel Ziswiler marcel@ziswiler.com --- tools/kwboot.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/tools/kwboot.c b/tools/kwboot.c index 7737188f0d0a..68c0ef1f1b07 100644 --- a/tools/kwboot.c +++ b/tools/kwboot.c @@ -1770,7 +1770,7 @@ main(int argc, char **argv) bootmsg = kwboot_msg_boot; if (prev_optind == optind) goto usage; - if (argv[optind] && argv[optind][0] != '-') + if (optind < argc - 1 && argv[optind] && argv[optind][0] != '-') imgpath = argv[optind++]; break;
Please correct me if I am wrong but AFAIU, this change makes it possible to use kwboot to also boot images on some of the Armada 64 bit platforms, as commented and tested by Marcel.
If this is the case, could you please update the documentation or at least add a note with some comments to the commit text?
Thanks, Stefan
Viele Grüße, Stefan Roese
Applied to u-boot-marvell/master
Thanks, Stefan
Pali Rohár
Stefan Roese
