[U-Boot] [PATCH] axi: ethernet: Added support for 64 bit addressing for axi-ethernet
This patch uses writeq() function to enable greater than 32 bit addressing of axi-ethernet for the ZynqMP devices.
Signed-off-by: Vipul Kumar vipulk@xilinx.com Signed-off-by: Michal Simek michal.simek@xilinx.com ---
drivers/net/xilinx_axi_emac.c | 33 +++++++++++++++++++++++++-------- 1 file changed, 25 insertions(+), 8 deletions(-)
diff --git a/drivers/net/xilinx_axi_emac.c b/drivers/net/xilinx_axi_emac.c index 70a2e95a8ec1..80ed06ac66c9 100644 --- a/drivers/net/xilinx_axi_emac.c +++ b/drivers/net/xilinx_axi_emac.c @@ -78,9 +78,10 @@ static u8 rxframe[PKTSIZE_ALIGN] __attribute((aligned(DMAALIGN))); struct axidma_reg { u32 control; /* DMACR */ u32 status; /* DMASR */ - u32 current; /* CURDESC */ - u32 reserved; - u32 tail; /* TAILDESC */ + u32 current; /* CURDESC low 32 bit */ + u32 current_hi; /* CURDESC high 32 bit */ + u32 tail; /* TAILDESC low 32 bit */ + u32 tail_hi; /* TAILDESC high 32 bit */ };
/* Private driver structures */ @@ -168,6 +169,22 @@ static inline int mdio_wait(struct axi_regs *regs) return 0; }
+/** + * axienet_dma_write - Memory mapped Axi DMA register Buffer Descriptor write. + * @bd: pointer to BD descriptor structure + * @desc: Address offset of DMA descriptors + * + * This function writes the value into the corresponding Axi DMA register. + */ +static inline void axienet_dma_write(struct axidma_bd *bd, u32 *desc) +{ +#if defined(CONFIG_PHYS_64BIT) + writeq(bd, desc); +#else + writel((u32)bd, desc); +#endif +} + static u32 phyread(struct axidma_priv *priv, u32 phyaddress, u32 registernum, u16 *val) { @@ -465,7 +482,7 @@ static int axiemac_start(struct udevice *dev) writel(temp, &priv->dmarx->control);
/* Start DMA RX channel. Now it's ready to receive data.*/ - writel((u32)&rx_bd, &priv->dmarx->current); + axienet_dma_write(&rx_bd, &priv->dmarx->current);
/* Setup the BD. */ memset(&rx_bd, 0, sizeof(rx_bd)); @@ -485,7 +502,7 @@ static int axiemac_start(struct udevice *dev) writel(temp, &priv->dmarx->control);
/* Rx BD is ready - start */ - writel((u32)&rx_bd, &priv->dmarx->tail); + axienet_dma_write(&rx_bd, &priv->dmarx->tail);
/* Enable TX */ writel(XAE_TC_TX_MASK, ®s->tc); @@ -527,7 +544,7 @@ static int axiemac_send(struct udevice *dev, void *ptr, int len)
if (readl(&priv->dmatx->status) & XAXIDMA_HALTED_MASK) { u32 temp; - writel((u32)&tx_bd, &priv->dmatx->current); + axienet_dma_write(&tx_bd, &priv->dmatx->current); /* Start the hardware */ temp = readl(&priv->dmatx->control); temp |= XAXIDMA_CR_RUNSTOP_MASK; @@ -535,7 +552,7 @@ static int axiemac_send(struct udevice *dev, void *ptr, int len) }
/* Start transfer */ - writel((u32)&tx_bd, &priv->dmatx->tail); + axienet_dma_write(&tx_bd, &priv->dmatx->tail);
/* Wait for transmission to complete */ debug("axiemac: Waiting for tx to be done\n"); @@ -626,7 +643,7 @@ static int axiemac_free_pkt(struct udevice *dev, uchar *packet, int length) flush_cache((u32)&rxframe, sizeof(rxframe));
/* Rx BD is ready - start again */ - writel((u32)&rx_bd, &priv->dmarx->tail); + axienet_dma_write(&rx_bd, &priv->dmarx->tail);
debug("axiemac: RX completed, framelength = %d\n", length);
Joe Hershberger
Michal Simek
