[U-Boot] [PATCH 1/6] Add Broadwell-DE architecture cpu files
This patch contain all the cpu files for Broadwell-DE architecture, including ACPI and FSP settings.
Signed-off-by: Vincenzo Bove vnktux@protonmail.com --- arch/x86/cpu/broadwell-de/Kconfig | 66 +++++++ arch/x86/cpu/broadwell-de/Makefile | 10 ++ arch/x86/cpu/broadwell-de/acpi.c | 234 +++++++++++++++++++++++++ arch/x86/cpu/broadwell-de/broadwell_de.c | 38 ++++ arch/x86/cpu/broadwell-de/cpu.c | 98 +++++++++++ arch/x86/cpu/broadwell-de/fsp_configs.c | 292 +++++++++++++++++++++++++++++++ 6 files changed, 738 insertions(+) create mode 100644 arch/x86/cpu/broadwell-de/Kconfig create mode 100644 arch/x86/cpu/broadwell-de/Makefile create mode 100644 arch/x86/cpu/broadwell-de/acpi.c create mode 100644 arch/x86/cpu/broadwell-de/broadwell_de.c create mode 100644 arch/x86/cpu/broadwell-de/cpu.c create mode 100644 arch/x86/cpu/broadwell-de/fsp_configs.c
diff --git a/arch/x86/cpu/broadwell-de/Kconfig b/arch/x86/cpu/broadwell-de/Kconfig new file mode 100644 index 0000000000..4e7b72c81c --- /dev/null +++ b/arch/x86/cpu/broadwell-de/Kconfig @@ -0,0 +1,66 @@ +# +# Copyright (C) 2017, Vincenzo Bove vincenzo.bove@prodrive-technologies.com +# +# SPDX-License-Identifier: GPL-2.0+ +# + +config INTEL_BROADWELL_DE + bool + select HAVE_FSP + select ARCH_MISC_INIT + select CPU_INTEL_TURBO_NOT_PACKAGE_SCOPED + imply HAVE_INTEL_ME + imply ENABLE_MRC_CACHE + imply AHCI_PCI + imply ICH_SPI + imply INTEL_ICH6_GPIO + imply SCSI + imply SPI_FLASH + imply SYS_NS16550 + imply USB + imply USB_EHCI_HCD + imply USB_XHCI_HCD + #imply VIDEO_VESA + +if INTEL_BROADWELL_DE + +config FSP_ADDR + hex + default 0xffeb0000 + +#config DCACHE_RAM_BASE +# default 0xfef00000 + +#config DCACHE_RAM_SIZE +# default 0x4000 + +config CPU_SPECIFIC_OPTIONS + def_bool y + select SMM_TSEG + #select X86_RAMTEST + +config SMM_TSEG_SIZE + hex + default 0x800000 + +config INTERNAL_UART + bool + default y + +config MAX_CPUS + int + default 16 + +config MAX_PIRQ_LINKS + int + default 4 + +config IRQ_SLOT_COUNT + int + default 18 + +config XIP_ROM_SIZE + hex + default 0x10000 + +endif diff --git a/arch/x86/cpu/broadwell-de/Makefile b/arch/x86/cpu/broadwell-de/Makefile new file mode 100644 index 0000000000..0fa427e1bf --- /dev/null +++ b/arch/x86/cpu/broadwell-de/Makefile @@ -0,0 +1,10 @@ +# +# Copyright (C) 2017, Vincenzo Bove vincenzo.bove@prodrive-technologies.com +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y += cpu.o +obj-y += fsp_configs.o +obj-y += broadwell_de.o +obj-$(CONFIG_GENERATE_ACPI_TABLE) += acpi.o diff --git a/arch/x86/cpu/broadwell-de/acpi.c b/arch/x86/cpu/broadwell-de/acpi.c new file mode 100644 index 0000000000..2e005623de --- /dev/null +++ b/arch/x86/cpu/broadwell-de/acpi.c @@ -0,0 +1,234 @@ +/* + * Copyright (C) 2017, Vincenzo Bove vincenzo.bove@prodrive-technologies.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <cpu.h> +#include <dm.h> +#include <dm/uclass-internal.h> +#include <asm/acpi_s3.h> +#include <asm/acpi_table.h> +#include <asm/io.h> +#include <asm/tables.h> +#include <asm/arch/global_nvs.h> +#include <asm/arch/iomap.h> + +#define PM1_STS 0x00 +#define PM1_CNT 0x04 +#define GEN_PMCON1 0xA0 +#define WAK_STS (1 << 15) +#define PWR_FLR (1 << 1) +#define SUS_PWR_FLR (1 << 14) + +#define PMC_BASE_ADDRESS 0xfed03000 +#define PMC_BASE_SIZE 0x400 + +void acpi_create_fadt(struct acpi_fadt *fadt, struct acpi_facs *facs, + void *dsdt) +{ + struct acpi_table_header *header = &(fadt->header); + u16 pmbase = ACPI_BASE_ADDRESS; + + memset((void *)fadt, 0, sizeof(struct acpi_fadt)); + + /* + * Reference section 5.2.9 Fixed ACPI Description Table (FADT) + * in the ACPI 3.0b specification. + */ + + /* FADT Header Structure */ + acpi_fill_header(header, "FACP"); + header->length = sizeof(struct acpi_fadt); + header->revision = 4; + + /* ACPI Pointers */ + fadt->firmware_ctrl = (u32)facs; + fadt->dsdt = (u32)dsdt; + + fadt->preferred_pm_profile = ACPI_PM_MOBILE; + fadt->sci_int = 9; + + /* System Management */ + fadt->smi_cmd = 0; + fadt->acpi_enable = 0; + fadt->acpi_disable = 0; + + /* Power Control */ + fadt->s4bios_req = 0; + fadt->pstate_cnt = 0; + + /* Control Registers - Base Address */ + fadt->pm1a_evt_blk = pmbase + 0x00; //PM1_STS + fadt->pm1b_evt_blk = 0x0; + fadt->pm1a_cnt_blk = pmbase + 0x04; //PM1_CNT + fadt->pm1b_cnt_blk = 0x0; + fadt->pm2_cnt_blk = pmbase + 0x50; //PM2A_CNT_BLK + fadt->pm_tmr_blk = pmbase + 0x8; //PM1_TMR + fadt->gpe0_blk = pmbase + 0x20; //GPE0_STS + fadt->gpe1_blk = 0; + + /* Control Registers - Length */ + fadt->pm1_evt_len = 4; + fadt->pm1_cnt_len = 2; + fadt->pm2_cnt_len = 1; + fadt->pm_tmr_len = 4; + fadt->gpe0_blk_len = 8; + fadt->gpe1_blk_len = 0; + fadt->gpe1_base = 0; + fadt->cst_cnt = 0; + fadt->p_lvl2_lat = ACPI_FADT_C2_NOT_SUPPORTED; + fadt->p_lvl3_lat = ACPI_FADT_C3_NOT_SUPPORTED; + fadt->flush_size = 0; + fadt->flush_stride = 0; + fadt->duty_offset = 1; + fadt->duty_width = 0; + + /* RTC Registers */ + fadt->day_alrm = 0x0d; + fadt->mon_alrm = 0x00; + fadt->century = 0x00; + fadt->iapc_boot_arch = ACPI_FADT_LEGACY_DEVICES | ACPI_FADT_8042; + + fadt->flags = ACPI_FADT_WBINVD | ACPI_FADT_C1_SUPPORTED | + ACPI_FADT_C2_MP_SUPPORTED | ACPI_FADT_SLEEP_BUTTON | + ACPI_FADT_S4_RTC_WAKE | ACPI_FADT_RESET_REGISTER | + ACPI_FADT_PLATFORM_CLOCK; + + /* Reset Register */ + fadt->reset_reg.space_id = ACPI_ADDRESS_SPACE_IO; + fadt->reset_reg.bit_width = 8; + fadt->reset_reg.bit_offset = 0; + fadt->reset_reg.access_size = ACPI_ACCESS_SIZE_BYTE_ACCESS; + fadt->reset_reg.addrl = IO_PORT_RESET; + fadt->reset_reg.addrh = 0; + fadt->reset_value = 6; //SYS_RST | RST_CPU | FULL_RST + + /* Extended ACPI Pointers */ + fadt->x_firmware_ctl_l = (u32)facs; + fadt->x_firmware_ctl_h = 0; + fadt->x_dsdt_l = (u32)dsdt; + fadt->x_dsdt_h = 0; + + /* PM1 Status & PM1 Enable */ + fadt->x_pm1a_evt_blk.space_id = ACPI_ADDRESS_SPACE_IO; + fadt->x_pm1a_evt_blk.bit_width = fadt->pm1_evt_len * 8; + fadt->x_pm1a_evt_blk.bit_offset = 0; + fadt->x_pm1a_evt_blk.access_size = ACPI_ACCESS_SIZE_DWORD_ACCESS; + fadt->x_pm1a_evt_blk.addrl = fadt->pm1a_evt_blk; + fadt->x_pm1a_evt_blk.addrh = 0x0; + + fadt->x_pm1b_evt_blk.space_id = ACPI_ADDRESS_SPACE_IO; + fadt->x_pm1b_evt_blk.bit_width = 0; + fadt->x_pm1b_evt_blk.bit_offset = 0; + fadt->x_pm1b_evt_blk.access_size = 0; + fadt->x_pm1b_evt_blk.addrl = fadt->pm1b_evt_blk; + fadt->x_pm1b_evt_blk.addrh = 0x0; + + /* PM1 Control Registers */ + fadt->x_pm1a_cnt_blk.space_id = ACPI_ADDRESS_SPACE_IO; + fadt->x_pm1a_cnt_blk.bit_width = 16; + fadt->x_pm1a_cnt_blk.bit_offset = 0; + fadt->x_pm1a_cnt_blk.access_size = ACPI_ACCESS_SIZE_WORD_ACCESS; + fadt->x_pm1a_cnt_blk.addrl = fadt->pm1a_cnt_blk; + fadt->x_pm1a_cnt_blk.addrh = 0x0; + + fadt->x_pm1b_cnt_blk.space_id = ACPI_ADDRESS_SPACE_IO; + fadt->x_pm1b_cnt_blk.bit_width = 0; + fadt->x_pm1b_cnt_blk.bit_offset = 0; + fadt->x_pm1b_cnt_blk.access_size = 0; + fadt->x_pm1b_cnt_blk.addrl = fadt->pm1b_cnt_blk; + fadt->x_pm1b_cnt_blk.addrh = 0x0; + + /* PM2 Control Registers */ + fadt->x_pm2_cnt_blk.space_id = ACPI_ADDRESS_SPACE_IO; + fadt->x_pm2_cnt_blk.bit_width = 8; + fadt->x_pm2_cnt_blk.bit_offset = 0; + fadt->x_pm2_cnt_blk.access_size = ACPI_ACCESS_SIZE_BYTE_ACCESS; + fadt->x_pm2_cnt_blk.addrl = fadt->pm2_cnt_blk; + fadt->x_pm2_cnt_blk.addrh = 0x0; + + /* PM1 Timer Register */ + fadt->x_pm_tmr_blk.space_id = ACPI_ADDRESS_SPACE_IO; + fadt->x_pm_tmr_blk.bit_width = 32; + fadt->x_pm_tmr_blk.bit_offset = 0; + fadt->x_pm_tmr_blk.access_size = ACPI_ACCESS_SIZE_DWORD_ACCESS; + fadt->x_pm_tmr_blk.addrl = fadt->pm_tmr_blk; + fadt->x_pm_tmr_blk.addrh = 0x0; + + /* General-Purpose Event Registers */ + fadt->x_gpe0_blk.space_id = ACPI_ADDRESS_SPACE_IO; + fadt->x_gpe0_blk.bit_width = 64; + fadt->x_gpe0_blk.bit_offset = 0; + fadt->x_gpe0_blk.access_size = ACPI_ACCESS_SIZE_DWORD_ACCESS; + fadt->x_gpe0_blk.addrl = fadt->gpe0_blk; + fadt->x_gpe0_blk.addrh = 0x0; + + fadt->x_gpe1_blk.space_id = ACPI_ADDRESS_SPACE_IO; + fadt->x_gpe1_blk.bit_width = 0; + fadt->x_gpe1_blk.bit_offset = 0; + fadt->x_gpe1_blk.access_size = 0; + fadt->x_gpe1_blk.addrl = fadt->gpe1_blk; + fadt->x_gpe1_blk.addrh = 0x0; + + header->checksum = table_compute_checksum(fadt, header->length); +} + +void acpi_create_gnvs(struct acpi_global_nvs *gnvs) +{ + struct udevice *dev; + int ret; + + /* at least we have one processor */ + gnvs->pcnt = 1; + /* override the processor count with actual number */ + ret = uclass_find_first_device(UCLASS_CPU, &dev); + if (ret == 0 && dev != NULL) { + ret = cpu_get_count(dev); + if (ret > 0) + gnvs->pcnt = ret; + } + + /* determine whether internal uart is on */ + if (IS_ENABLED(CONFIG_INTERNAL_UART)) + gnvs->iuart_en = 1; + else + gnvs->iuart_en = 0; +} + +#ifdef CONFIG_HAVE_ACPI_RESUME + +enum acpi_sleep_state chipset_prev_sleep_state(void) +{ + u32 pm1_sts; + u32 pm1_cnt; + u32 gen_pmcon1; + enum acpi_sleep_state prev_sleep_state = ACPI_S0; + + /* Read Power State */ + pm1_sts = inw(ACPI_BASE_ADDRESS + PM1_STS); + pm1_cnt = inl(ACPI_BASE_ADDRESS + PM1_CNT); + gen_pmcon1 = readl(PMC_BASE_ADDRESS + GEN_PMCON1); + + debug("PM1_STS = 0x%x PM1_CNT = 0x%x GEN_PMCON1 = 0x%x\n", + pm1_sts, pm1_cnt, gen_pmcon1); + + if (pm1_sts & WAK_STS) + prev_sleep_state = acpi_sleep_from_pm1(pm1_cnt); + + if (gen_pmcon1 & (PWR_FLR | SUS_PWR_FLR)) + prev_sleep_state = ACPI_S5; + + return prev_sleep_state; +} + +void chipset_clear_sleep_state(void) +{ + u32 pm1_cnt; + + pm1_cnt = inl(ACPI_BASE_ADDRESS + PM1_CNT); + outl(pm1_cnt & ~(SLP_TYP), ACPI_BASE_ADDRESS + PM1_CNT); +} + +#endif diff --git a/arch/x86/cpu/broadwell-de/broadwell_de.c b/arch/x86/cpu/broadwell-de/broadwell_de.c new file mode 100644 index 0000000000..54afde7db9 --- /dev/null +++ b/arch/x86/cpu/broadwell-de/broadwell_de.c @@ -0,0 +1,38 @@ +/* + * Copyright (C) 2017, Vincenzo Bove vincenzo.bove@prodrive-technologies.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/mrccache.h> +#include <asm/post.h> + +int arch_cpu_init(void) +{ + post_code(POST_CPU_INIT); + + return x86_cpu_init_f(); +} + +int arch_misc_init(void) +{ +#ifdef CONFIG_ENABLE_MRC_CACHE + /* + * We intend not to check any return value here, as even MRC cache + * is not saved successfully, it is not a severe error that will + * prevent system from continuing to boot. + */ + mrccache_save(); +#endif + + return 0; +} + + + +void reset_cpu(ulong addr) +{ + /* cold reset */ + x86_full_reset(); +} diff --git a/arch/x86/cpu/broadwell-de/cpu.c b/arch/x86/cpu/broadwell-de/cpu.c new file mode 100644 index 0000000000..71377fad1c --- /dev/null +++ b/arch/x86/cpu/broadwell-de/cpu.c @@ -0,0 +1,98 @@ +/* + * Copyright (C) 2017, Vincenzo Bove vincenzo.bove@prodrive-technologies.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <dm.h> +#include <cpu.h> +#include <pci.h> +#include <asm/cpu.h> +#include <asm/cpu_x86.h> +#include <asm/cpu_common.h> +#include <asm/intel_regs.h> +#include <asm/io.h> +#include <asm/msr.h> +#include <asm/post.h> +#include <asm/turbo.h> +#include <asm/mrccache.h> +#include <asm/lapic.h> + +#define MSR_CORE_THREAD_COUNT 0x35 + +static void configure_mca(void) +{ + msr_t msr; + const unsigned int mcg_cap_msr = 0x179; + int i; + int num_banks; + + msr = msr_read(mcg_cap_msr); + num_banks = msr.lo & 0xff; + msr.lo = 0; + msr.hi = 0; + /* + * TODO(adurbin): This should only be done on a cold boot. Also, some + * of these banks are core vs package scope. For now every CPU clears + * every bank + */ + for (i = 0; i < num_banks; i++) { + msr_write(MSR_IA32_MC0_STATUS + (i * 4) + 1, msr); + msr_write(MSR_IA32_MC0_STATUS + (i * 4) + 2, msr); + msr_write(MSR_IA32_MC0_STATUS + (i * 4) + 3, msr); + + } + + msr.lo = 0xffffffff; + msr.hi = 0xffffffff; + + for (i = 0; i < num_banks; i++) { + msr_write(MSR_IA32_MC0_STATUS + (i * 4), msr); + } +} + +static int cpu_x86_broadwell_de_probe(struct udevice *dev) +{ + debug("Init Broadwell-DE core\n"); + + /* Clear out pending MCEs */ + configure_mca(); + + return 0; +} + + +static int broadwell_de_get_info(struct udevice *dev, struct cpu_info *info) +{ + //TBD + + return 0; +} + +static int broadwell_de_get_count(struct udevice *dev) +{ + msr_t core_thread_count = msr_read(MSR_CORE_THREAD_COUNT); + return core_thread_count.lo & 0xffff; +} + +static const struct cpu_ops cpu_x86_broadwell_de_ops = { + .get_desc = cpu_x86_get_desc, + .get_info = broadwell_de_get_info, + .get_count = broadwell_de_get_count, + .get_vendor = cpu_x86_get_vendor, +}; + +static const struct udevice_id cpu_x86_broadwell_de_ids[] = { + { .compatible = "intel,broadwell-de-cpu" }, + { } +}; + +U_BOOT_DRIVER(cpu_x86_broadwell_de_drv) = { + .name = "cpu_x86_broadwell_de", + .id = UCLASS_CPU, + .of_match = cpu_x86_broadwell_de_ids, + .bind = cpu_x86_bind, + .probe = cpu_x86_broadwell_de_probe, + .ops = &cpu_x86_broadwell_de_ops, +}; diff --git a/arch/x86/cpu/broadwell-de/fsp_configs.c b/arch/x86/cpu/broadwell-de/fsp_configs.c new file mode 100644 index 0000000000..b2ccbdbd55 --- /dev/null +++ b/arch/x86/cpu/broadwell-de/fsp_configs.c @@ -0,0 +1,292 @@ +/* + * Copyright (C) 2017, Vincenzo Bove vincenzo.bove@prodrive-technologies.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <fdtdec.h> +#include <asm/fsp/fsp_support.h> + +DECLARE_GLOBAL_DATA_PTR; + +/** + * Override the FSP's configuration data. + * If the device tree does not specify an integer setting, use the default + * provided by Prodrive BroadwellDE.rom + */ +void update_fsp_configs(struct fsp_config_data *config, + struct fspinit_rtbuf *rt_buf) +{ + struct upd_region *fsp_upd = &config->fsp_upd; + const void *blob = gd->fdt_blob; + int node; + + /* Initialize runtime buffer for fsp_init() */ + rt_buf->common.stack_top = config->common.stack_top - 32; + rt_buf->common.boot_mode = config->common.boot_mode; + rt_buf->common.upd_data = &config->fsp_upd; + + node = fdtdec_next_compatible(blob, 0, COMPAT_INTEL_BROADWELL_DE_FSP); + if (node < 0) { + debug("%s: Cannot find FSP node\n", __func__); + return; + } + + fsp_upd->memEccSupport = fdtdec_get_int(blob, node, + "fsp,memEccSupport", + MEM_ECC_SUPPORT_AUTO); + + fsp_upd->memDdrMemoryType = fdtdec_get_int(blob, node, + "fsp,memDdrMemoryType", + MEM_DDR_MEMORY_TYPE_UDIMM_AND_RDIMM); + + fsp_upd->memRankMultiplication = fdtdec_get_int(blob, node, + "fsp,memRankMultiplication", + MEM_RANK_MULTIPLICATION_AUTO); + + fsp_upd->memRankMarginTool = fdtdec_get_int(blob, node, + "fsp,memRankMarginTool", + MEM_RANK_MARGIN_TOOL_AUTO); + + fsp_upd->memScrambling = fdtdec_get_int(blob, node, + "fsp,memScrambling", + MEM_SCRAMBLING_AUTO); + + fsp_upd->memRefreshMode = fdtdec_get_int(blob, node, + "fsp,memRefreshMode", + MEM_REFRESH_MODE_ACC_SELF_REFRESH); + + fsp_upd->memMcOdtOverride = fdtdec_get_int(blob, node, + "fsp,memMcOdtOverride", + MEM_MC0DT_OVERRIDE_AUTO); + + fsp_upd->memCAParity = fdtdec_get_int(blob, node, + "fsp,memCAParity", + MEM_CA_PARITY_AUTO); + + fsp_upd->memThermalThrottling = fdtdec_get_int(blob, node, + "fsp,memThermalThrottling", + MEM_THERMAL_THROTTLING_CLOSEDLOOP); + + fsp_upd->memPowerSavingsMode = fdtdec_get_int(blob, node, + "fsp,memPowerSavingsMode", + MEM_POWER_SAVINGS_MODE_AUTO); + + fsp_upd->memElectricalThrottling = fdtdec_get_int(blob, node, + "fsp,memElectricalThrottling", + MEM_ELECTRICAL_THROTTLING_DISABLED); + + fsp_upd->memPagePolicy = fdtdec_get_int(blob, node, + "fsp,memPagePolicy", + MEM_PAGE_POLICY_AUTO); + + fsp_upd->memSocketInterleaveBelow4G = fdtdec_get_int(blob, node, + "fsp,memSocketInterleaveBelow4G", + MEM_SOCKET_INTERLEAVE_BELOW_4G_DISABLED); + + fsp_upd->memChannelInterleave = fdtdec_get_int(blob, node, + "fsp,memChannelInterleave", + MEM_CHANNEL_INTERLEAVE_AUTO); + + fsp_upd->memRankInterleave = fdtdec_get_int(blob, node, + "fsp,memRankInterleave", + MEM_RANK_INTERLEAVE_AUTO); + + #ifdef CONFIG_FSP_MEMORY_DOWN + fsp_upd->memDownEnable = fdtdec_get_bool(blob, node, "fsp,memDownEnable"); + + fsp_upd->memDownCh0Dimm0SpdPtr = fdtdec_get_int(blob, node, + "fsp,memDownCh0Dimm0SpdPtr", + CONFIG_SPD_ADDR); + + fsp_upd->memDownCh0Dimm1SpdPtr = fdtdec_get_int(blob, node, + "fsp,memDownCh0Dimm1SpdPtr", + 0x0); + + fsp_upd->memDownCh1Dimm0SpdPtr = fdtdec_get_int(blob, node, + "fsp,memDownCh1Dimm0SpdPtr", + 0x0); + + fsp_upd->memDownCh1Dimm1SpdPtr = fdtdec_get_int(blob, node, + "fsp,memDownCh1Dimm1SpdPtr", + 0x0); + #endif + + //#ifdef CONFIG_ENABLE_MRC_CACHE + //fsp_upd->memFastBoot = fdtdec_get_int(blob, node, "fsp,mem-fast-boot", MEM_FAST_BOOT_ENABLE); + //#else + //fsp_upd->memFastBoot = fdtdec_get_int(blob, node, "fsp,mem-fast-boot", MEM_FAST_BOOT_DISABLE); + //#endif + fsp_upd->memFastBoot = fdtdec_get_int(blob, node, "fsp,mem-fast-boot", MEM_FAST_BOOT_DISABLE); + + fsp_upd->pam0_hienable = fdtdec_get_int(blob, node, + "fsp,pam0-hienable", + PAM_RW_DRAM_ONLY); + + fsp_upd->pam1_loenable = fdtdec_get_int(blob, node, + "fsp,pam1-loenable", + PAM_RW_DRAM_ONLY); + + fsp_upd->pam1_hienable = fdtdec_get_int(blob, node, + "fsp,pam1-hienable", + PAM_RW_DRAM_ONLY); + + fsp_upd->pam2_loenable = fdtdec_get_int(blob, node, + "fsp,pam2-loenable", + PAM_RW_DRAM_ONLY); + + fsp_upd->pam2_hienable = fdtdec_get_int(blob, node, + "fsp,pam2-hienable", + PAM_RW_DRAM_ONLY); + + fsp_upd->pam3_loenable = fdtdec_get_int(blob, node, + "fsp,pam3-loenable", + PAM_RW_DRAM_ONLY); + + fsp_upd->pam3_hienable = fdtdec_get_int(blob, node, + "fsp,pam3-hienable", + PAM_RW_DRAM_ONLY); + + fsp_upd->pam4_loenable = fdtdec_get_int(blob, node, + "fsp,pam4-loenable", + PAM_RW_DRAM_ONLY); + + fsp_upd->pam4_hienable = fdtdec_get_int(blob, node, + "fsp,pam4-hienable", + PAM_RW_DRAM_ONLY); + + fsp_upd->pam5_loenable = fdtdec_get_int(blob, node, + "fsp,pam5-loenable", + PAM_RW_DRAM_ONLY); + + fsp_upd->pam5_hienable = fdtdec_get_int(blob, node, + "fsp,pam5-hienable", + PAM_RW_DRAM_ONLY); + + fsp_upd->pam6_loenable = fdtdec_get_int(blob, node, + "fsp,pam6-loenable", + PAM_RW_DRAM_ONLY); + + fsp_upd->pam6_hienable = fdtdec_get_int(blob, node, + "fsp,pam6-hienable", + PAM_RW_DRAM_ONLY); + + fsp_upd->memAdr = fdtdec_get_int(blob, node, + "fsp,memAdr", + MEM_ADR_DISABLED); + + fsp_upd->serialPortType = fdtdec_get_int(blob, node, + "fsp,serial-port-type", + SERIAL_PORT_TYPE_IO); + + fsp_upd->serialPortAddress = fdtdec_get_int(blob, node, + "fsp,serial-port-address", + 0x3f8); + + fsp_upd->serialPortConfigure = fdtdec_get_bool(blob, node, "fsp,serial-port-configure"); + + fsp_upd->serialPortBaudRate = fdtdec_get_int(blob, node, + "fsp,serial-port-baudrate", + SERIAL_PORT_BAUDRATE_115200); + + fsp_upd->serialPortControllerInit0 = fdtdec_get_bool(blob, node, "fsp,serial-port-controller-init0"); + + fsp_upd->serialPortControllerInit1 = fdtdec_get_bool(blob, node, "fsp,serial-port-controller-init1"); + + fsp_upd->configIOU1_PciPort3 = fdtdec_get_int(blob, node, + "fsp,config-iou1-pci-port3", + CONFIG_IOU1_PCI_PORT3_X4X4X4X4); + + fsp_upd->configIOU2_PciPort1 = fdtdec_get_int(blob, node, + "fsp,config-iou2-pci-port1", + CONFIG_IOU2_PCI_PORT1_XXX8); + + fsp_upd->pchPciPort1 = fdtdec_get_bool(blob, node, "fsp,pch-pci-port1"); + + fsp_upd->pchPciPort2 = fdtdec_get_bool(blob, node, "fsp,pch-pci-port2"); + + fsp_upd->pchPciPort3 = fdtdec_get_bool(blob, node, "fsp,pch-pci-port3"); + + fsp_upd->pchPciPort4 = fdtdec_get_bool(blob, node, "fsp,pch-pci-port4"); + + fsp_upd->pchPciPort5 = fdtdec_get_bool(blob, node, "fsp,pch-pci-port5"); + + fsp_upd->pchPciPort6 = fdtdec_get_bool(blob, node, "fsp,pch-pci-port6"); + + fsp_upd->pchPciPort7 = fdtdec_get_bool(blob, node, "fsp,pch-pci-port7"); + + fsp_upd->pchPciPort8 = fdtdec_get_bool(blob, node, "fsp,pch-pci-port8"); + + fsp_upd->ehci1Enable = fdtdec_get_bool(blob, node, "fsp,ehci1-enable"); + + fsp_upd->hyperThreading = fdtdec_get_bool(blob, node, "fsp,hyper-threading"); + + fsp_upd->debugOutputLevel = fdtdec_get_int(blob, node, + "fsp,debug-output-level", + DEBUG_OUTPUT_LEVEL_NORMAL); + + fsp_upd->tcoTimerHaltLock = fdtdec_get_bool(blob, node, "fsp,tco-timer-halt-lock"); + + fsp_upd->turboMode = fdtdec_get_bool(blob, node, "fsp,turbo-mode"); + + fsp_upd->bootPerfMode = fdtdec_get_bool(blob, node, "fsp,boot-perf-mode"); + + fsp_upd->pciePort1aAspm = fdtdec_get_int(blob, node, + "fsp,pcie-port1a-aspm", + PCIE_ASPM_DISABLED); + + fsp_upd->pciePort1bAspm = fdtdec_get_int(blob, node, + "fsp,pcie-port1b-aspm", + PCIE_ASPM_DISABLED); + + fsp_upd->pciePort3aAspm = fdtdec_get_int(blob, node, + "fsp,pcie-port3a-aspm", + PCIE_ASPM_DISABLED); + + fsp_upd->pciePort3bAspm = fdtdec_get_int(blob, node, + "fsp,pcie-port3b-aspm", + PCIE_ASPM_DISABLED); + + fsp_upd->pciePort3cAspm = fdtdec_get_int(blob, node, + "fsp,pcie-port3c-aspm", + PCIE_ASPM_DISABLED); + + fsp_upd->pciePort3dAspm = fdtdec_get_int(blob, node, + "fsp,pcie-port3d-aspm", + PCIE_ASPM_DISABLED); + + fsp_upd->pchPciePort1Aspm = fdtdec_get_int(blob, node, + "fsp,pch-pcie-port1-aspm", + PCH_PCI_ASPM_DISABLED); + + fsp_upd->pchPciePort2Aspm = fdtdec_get_int(blob, node, + "fsp,pch-pcie-port2-aspm", + PCH_PCI_ASPM_DISABLED); + + fsp_upd->pchPciePort3Aspm = fdtdec_get_int(blob, node, + "fsp,pch-pcie-port3-aspm", + PCH_PCI_ASPM_DISABLED); + + fsp_upd->pchPciePort4Aspm = fdtdec_get_int(blob, node, + "fsp,pch-pcie-port4-aspm", + PCH_PCI_ASPM_DISABLED); + + fsp_upd->pchPciePort5Aspm = fdtdec_get_int(blob, node, + "fsp,pch-pcie-port5-aspm", + PCH_PCI_ASPM_DISABLED); + + fsp_upd->pchPciePort6Aspm = fdtdec_get_int(blob, node, + "fsp,pch-pcie-port6-aspm", + PCH_PCI_ASPM_DISABLED); + + fsp_upd->pchPciePort7Aspm = fdtdec_get_int(blob, node, + "fsp,pch-pcie-port7-aspm", + PCH_PCI_ASPM_DISABLED); + + fsp_upd->pchPciePort8Aspm = fdtdec_get_int(blob, node, + "fsp,pch-pcie-port8-aspm", + PCH_PCI_ASPM_DISABLED); + + fsp_upd->thermalDeviceEnable = fdtdec_get_bool(blob, node, "fsp,thermal-device-enable"); +} -- 2.11.0
vnktux
