[U-Boot] [PATCH 0/4] arm: rmobile: Stout board support and minor fixes
This patch series adds the following: 1) sh-pfc: fix gpio input read 2) serial-sh: SCIFA interface for R-Car Gen2 SoCs 3) rmobile: add SCIFA port base offsets 4) rmobile: Add Stout board support
Signed-off-by: Vladimir Barinov vladimir.barinov@cogentembedded.com --- arch/arm/cpu/armv7/rmobile/Kconfig | 8 arch/arm/include/asm/arch-rmobile/rcar-base.h | 3 board/renesas/stout/Kconfig | 12 board/renesas/stout/MAINTAINERS | 6 board/renesas/stout/Makefile | 11 board/renesas/stout/cpld.c | 167 + board/renesas/stout/cpld.h | 183 + board/renesas/stout/qos.c | 2435 ++++++++++++++++++++++++++ board/renesas/stout/qos.h | 14 board/renesas/stout/stout.c | 232 ++ configs/stout_defconfig | 21 drivers/gpio/sh_pfc.c | 3 drivers/serial/serial_sh.h | 43 include/configs/stout.h | 112 + 14 files changed, 3239 insertions(+), 11 deletions(-)
Fix gpio_read: gpio input (INDT) and gpio output (OUTDT) registers have different offset. gpio_read must be performed from INDT.
Signed-off-by: Vladimir Barinov vladimir.barinov@cogentembedded.com --- drivers/gpio/sh_pfc.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/gpio/sh_pfc.c b/drivers/gpio/sh_pfc.c index 7a5af20..95f5b2a 100644 --- a/drivers/gpio/sh_pfc.c +++ b/drivers/gpio/sh_pfc.c @@ -75,7 +75,8 @@ static int gpio_read_bit(struct pinmux_data_reg *dr, debug("read_bit: addr = %lx, pos = %ld, " "r_width = %ld\n", dr->reg, pos, dr->reg_width);
- return (gpio_read_raw_reg(dr->mapped_reg, dr->reg_width) >> pos) & 1; + return + (gpio_read_raw_reg(dr->mapped_reg + 0x4, dr->reg_width) >> pos) & 1; }
static void gpio_write_bit(struct pinmux_data_reg *dr,
Add SCIFA console interface for R-Car Gen2 SoCs. SCIFA has different registers offsets and sizes then SCI. Hence it needs to put it's macro definitions separately.
Signed-off-by: Vladimir Barinov vladimir.barinov@cogentembedded.com --- drivers/serial/serial_sh.h | 43 ++++++++++++++++++++++++++++++++++--------- 1 file changed, 34 insertions(+), 9 deletions(-)
diff --git a/drivers/serial/serial_sh.h b/drivers/serial/serial_sh.h index 941e6ed..cbc2929 100644 --- a/drivers/serial/serial_sh.h +++ b/drivers/serial/serial_sh.h @@ -226,7 +226,11 @@ struct uart_port { # define SCSCR_INIT(port) 0x38 /* TIE=0,RIE=0,TE=1,RE=1,REIE=1 */ #elif defined(CONFIG_R8A7790) || defined(CONFIG_R8A7791) || \ defined(CONFIG_R8A7793) || defined(CONFIG_R8A7794) -# define SCIF_ORER 0x0001 +# if defined(CONFIG_SCIF_A) +# define SCIF_ORER 0x0200 +# else +# define SCIF_ORER 0x0001 +# endif # define SCSCR_INIT(port) (port->clk_mode == EXT_CLK ? 0x32 : 0x30) /* TIE=0,RIE=0,TE=1,RE=1,REIE=0, */ #else @@ -306,7 +310,11 @@ struct uart_port { #elif defined(CONFIG_R8A7790) || defined(CONFIG_R8A7791) || \ defined(CONFIG_R8A7793) || defined(CONFIG_R8A7794) # define SCIF_ERRORS (SCIF_PER | SCIF_FER | SCIF_ER | SCIF_BRK) -# define SCIF_RFDC_MASK 0x003f +# if defined(CONFIG_SCIF_A) +# define SCIF_RFDC_MASK 0x007f +# else +# define SCIF_RFDC_MASK 0x001f +# endif #else # define SCIF_ERRORS (SCIF_PER | SCIF_FER | SCIF_ER | SCIF_BRK) # define SCIF_RFDC_MASK 0x001f @@ -557,6 +565,25 @@ SCIF_FNS(SCFCR, 0x18, 16) SCIF_FNS(SCFDR, 0x1c, 16) SCIF_FNS(SCLSR, 0x24, 16) SCIF_FNS(DL, 0x00, 0) /* dummy */ +#elif defined(CONFIG_R8A7790) || defined(CONFIG_R8A7791) || \ + defined(CONFIG_R8A7793) || defined(CONFIG_R8A7794) +/* SCIFA and SCIF register offsets and size */ +SCIx_FNS(SCSMR, 0, 0, 0x00, 16, 0, 0, 0x00, 16, 0, 0) +SCIx_FNS(SCBRR, 0, 0, 0x04, 8, 0, 0, 0x04, 8, 0, 0) +SCIx_FNS(SCSCR, 0, 0, 0x08, 16, 0, 0, 0x08, 16, 0, 0) +SCIx_FNS(SCxTDR, 0, 0, 0x20, 8, 0, 0, 0x0C, 8, 0, 0) +SCIx_FNS(SCxSR, 0, 0, 0x14, 16, 0, 0, 0x10, 16, 0, 0) +SCIx_FNS(SCxRDR, 0, 0, 0x24, 8, 0, 0, 0x14, 8, 0, 0) +SCIF_FNS(SCFCR, 0, 0, 0x18, 16) +SCIF_FNS(SCFDR, 0, 0, 0x1C, 16) +SCIF_FNS(SCSPTR, 0, 0, 0x20, 16) +SCIF_FNS(DL, 0, 0, 0x30, 16) +SCIF_FNS(CKS, 0, 0, 0x34, 16) +#if defined(CONFIG_SCIF_A) +SCIF_FNS(SCLSR, 0, 0, 0x14, 16) +#else +SCIF_FNS(SCLSR, 0, 0, 0x24, 16) +#endif #else /* reg SCI/SH3 SCI/SH4 SCIF/SH3 SCIF/SH4 SCI/H8*/ /* name off sz off sz off sz off sz off sz*/ @@ -594,14 +621,8 @@ SCIF_FNS(SCSPTR, 0, 0, 0x20, 16) #endif SCIF_FNS(SCLSR, 0, 0, 0x24, 16) #endif -#if defined(CONFIG_R8A7790) || defined(CONFIG_R8A7791) || \ - defined(CONFIG_R8A7793) || defined(CONFIG_R8A7794) -SCIF_FNS(DL, 0, 0, 0x30, 16) -SCIF_FNS(CKS, 0, 0, 0x34, 16) -#else SCIF_FNS(DL, 0, 0, 0x0, 0) /* dummy */ #endif -#endif #define sci_in(port, reg) sci_##reg##_in(port) #define sci_out(port, reg, value) sci_##reg##_out(port, value)
@@ -743,7 +764,11 @@ static inline int scbrr_calc(struct uart_port *port, int bps, int clk) #elif defined(CONFIG_R8A7790) || defined(CONFIG_R8A7791) || \ defined(CONFIG_R8A7793) || defined(CONFIG_R8A7794) #define DL_VALUE(bps, clk) (clk / bps / 16) /* External Clock */ -#define SCBRR_VALUE(bps, clk) (clk / bps / 32 - 1) /* Internal Clock */ + #if defined(CONFIG_SCIF_A) + #define SCBRR_VALUE(bps, clk) (clk / bps / 16 - 1) /* Internal Clock */ + #else + #define SCBRR_VALUE(bps, clk) (clk / bps / 32 - 1) /* Internal Clock */ + #endif #else /* Generic SH */ #define SCBRR_VALUE(bps, clk) ((clk+16*bps)/(32*bps)-1) #endif
Signed-off-by: Vladimir Barinov vladimir.barinov@cogentembedded.com --- arch/arm/include/asm/arch-rmobile/rcar-base.h | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/arch/arm/include/asm/arch-rmobile/rcar-base.h b/arch/arm/include/asm/arch-rmobile/rcar-base.h index d594cd7..53ead26 100644 --- a/arch/arm/include/asm/arch-rmobile/rcar-base.h +++ b/arch/arm/include/asm/arch-rmobile/rcar-base.h @@ -28,6 +28,9 @@ #define SCIF3_BASE 0xE6EA8000 #define SCIF4_BASE 0xE6EE0000 #define SCIF5_BASE 0xE6EE8000 +#define SCIFA0_BASE 0xE6C40000 +#define SCIFA1_BASE 0xE6C50000 +#define SCIFA2_BASE 0xE6C60000
/* Module stop status register */ #define MSTPSR0 0xE6150030
Stout is an entry level development board based on R-Car H2 SoC (R8A7790)
This commit supports the following peripherals: - SCIFA, I2C, Ethernet, QSPI, SDHI0/2, CPLD
Signed-off-by: Vladimir Barinov vladimir.barinov@cogentembedded.com --- arch/arm/cpu/armv7/rmobile/Kconfig | 8 +- board/renesas/stout/Kconfig | 12 + board/renesas/stout/MAINTAINERS | 6 + board/renesas/stout/Makefile | 11 + board/renesas/stout/cpld.c | 167 +++ board/renesas/stout/cpld.h | 183 +++ board/renesas/stout/qos.c | 2435 ++++++++++++++++++++++++++++++++++++ board/renesas/stout/qos.h | 14 + board/renesas/stout/stout.c | 232 ++++ configs/stout_defconfig | 21 + include/configs/stout.h | 112 ++ 11 files changed, 3200 insertions(+), 1 deletion(-) create mode 100644 board/renesas/stout/Kconfig create mode 100644 board/renesas/stout/MAINTAINERS create mode 100644 board/renesas/stout/Makefile create mode 100644 board/renesas/stout/cpld.c create mode 100644 board/renesas/stout/cpld.h create mode 100644 board/renesas/stout/qos.c create mode 100644 board/renesas/stout/qos.h create mode 100644 board/renesas/stout/stout.c create mode 100644 configs/stout_defconfig create mode 100644 include/configs/stout.h
diff --git a/arch/arm/cpu/armv7/rmobile/Kconfig b/arch/arm/cpu/armv7/rmobile/Kconfig index ef56286..85c06eb 100644 --- a/arch/arm/cpu/armv7/rmobile/Kconfig +++ b/arch/arm/cpu/armv7/rmobile/Kconfig @@ -40,6 +40,11 @@ config TARGET_PORTER select DM select DM_SERIAL
+config TARGET_STOUT + bool "Stout board" + select DM + select DM_SERIAL + endchoice
config SYS_SOC @@ -47,7 +52,7 @@ config SYS_SOC
config RMOBILE_EXTRAM_BOOT bool "Enable boot from RAM" - depends on TARGET_ALT || TARGET_KOELSCH || TARGET_LAGER || TARGET_PORTER || TARGET_SILK + depends on TARGET_ALT || TARGET_KOELSCH || TARGET_LAGER || TARGET_PORTER || TARGET_SILK || TARGET_STOUT default n
choice @@ -80,5 +85,6 @@ source "board/kmc/kzm9g/Kconfig" source "board/renesas/alt/Kconfig" source "board/renesas/silk/Kconfig" source "board/renesas/porter/Kconfig" +source "board/renesas/stout/Kconfig"
endif diff --git a/board/renesas/stout/Kconfig b/board/renesas/stout/Kconfig new file mode 100644 index 0000000..cbbc6dd --- /dev/null +++ b/board/renesas/stout/Kconfig @@ -0,0 +1,12 @@ +if TARGET_STOUT + +config SYS_BOARD + default "stout" + +config SYS_VENDOR + default "renesas" + +config SYS_CONFIG_NAME + default "stout" + +endif diff --git a/board/renesas/stout/MAINTAINERS b/board/renesas/stout/MAINTAINERS new file mode 100644 index 0000000..b7098e7 --- /dev/null +++ b/board/renesas/stout/MAINTAINERS @@ -0,0 +1,6 @@ +STOUT BOARD +M: Cogent Embedded, Inc. source@cogentembedded.com +S: Maintained +F: board/renesas/stout/ +F: include/configs/stout.h +F: configs/stout_defconfig diff --git a/board/renesas/stout/Makefile b/board/renesas/stout/Makefile new file mode 100644 index 0000000..e78f80c --- /dev/null +++ b/board/renesas/stout/Makefile @@ -0,0 +1,11 @@ +# +# board/renesas/stout/Makefile +# +# Copyright (C) 2015 Renesas Electronics Europe GmbH +# Copyright (C) 2015 Renesas Electronics Corporation +# Copyright (C) 2015 Cogent Embedded, Inc. +# +# SPDX-License-Identifier: GPL-2.0 +# + +obj-y := stout.o cpld.o qos.o ../rcar-gen2-common/common.o diff --git a/board/renesas/stout/cpld.c b/board/renesas/stout/cpld.c new file mode 100644 index 0000000..6fbe083 --- /dev/null +++ b/board/renesas/stout/cpld.c @@ -0,0 +1,167 @@ +/* + * Stout board CPLD access support + * + * Copyright (C) 2015 Renesas Electronics Europe GmbH + * Copyright (C) 2015 Renesas Electronics Corporation + * Copyright (C) 2015 Cogent Embedded, Inc. + * + * SPDX-License-Identifier: GPL-2.0 + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/gpio.h> +#include "cpld.h" + +#define SCLK GPIO_GP_3_24 +#define SSTBZ GPIO_GP_3_25 +#define MOSI GPIO_GP_3_26 +#define MISO GPIO_GP_3_27 + +#define CPLD_ADDR_MODE 0x00 /* RW */ +#define CPLD_ADDR_MUX 0x01 /* RW */ +#define CPLD_ADDR_HDMI 0x02 /* RW */ +#define CPLD_ADDR_DIPSW 0x08 /* R */ +#define CPLD_ADDR_RESET 0x80 /* RW */ +#define CPLD_ADDR_VERSION 0xFF /* R */ + +static u32 cpld_read(u8 addr) +{ + int i; + u32 data = 0; + + for (i = 0; i < 8; i++) { + gpio_set_value(MOSI, addr & 0x80); /* MSB first */ + gpio_set_value(SCLK, 1); + addr <<= 1; + gpio_set_value(SCLK, 0); + } + + gpio_set_value(MOSI, 0); /* READ */ + gpio_set_value(SSTBZ, 0); + gpio_set_value(SCLK, 1); + gpio_set_value(SCLK, 0); + gpio_set_value(SSTBZ, 1); + + for (i = 0; i < 32; i++) { + gpio_set_value(SCLK, 1); + data <<= 1; + data |= gpio_get_value(MISO); /* MSB first */ + gpio_set_value(SCLK, 0); + } + + return data; +} + +static void cpld_write(u8 addr, u32 data) +{ + int i; + + for (i = 0; i < 32; i++) { + gpio_set_value(MOSI, data & (1 << 31)); /* MSB first */ + gpio_set_value(SCLK, 1); + data <<= 1; + gpio_set_value(SCLK, 0); + } + + for (i = 0; i < 8; i++) { + gpio_set_value(MOSI, addr & 0x80); /* MSB first */ + gpio_set_value(SCLK, 1); + addr <<= 1; + gpio_set_value(SCLK, 0); + } + + gpio_set_value(MOSI, 1); /* WRITE */ + gpio_set_value(SSTBZ, 0); + gpio_set_value(SCLK, 1); + gpio_set_value(SCLK, 0); + gpio_set_value(SSTBZ, 1); +} + +/* LSI pin pull-up control */ +#define PUPR3 0xe606010C +#define PUPR3_SD3_DAT1 (1 << 27) + +void cpld_init(void) +{ + u32 val; + + /* PULL-UP on MISO line */ + val = readl(PUPR3); + val |= PUPR3_SD3_DAT1; + writel(val, PUPR3); + + gpio_request(SCLK, NULL); + gpio_request(SSTBZ, NULL); + gpio_request(MOSI, NULL); + gpio_request(MISO, NULL); + + gpio_direction_output(SCLK, 0); + gpio_direction_output(SSTBZ, 1); + gpio_direction_output(MOSI, 0); + gpio_direction_input(MISO); + + /* dummy read */ + cpld_read(CPLD_ADDR_VERSION); + + printf("CPLD version: 0x%08x\n", + cpld_read(CPLD_ADDR_VERSION)); + printf("H2 Mode setting (MD0..28): 0x%08x\n", + cpld_read(CPLD_ADDR_MODE)); + printf("Multiplexer settings: 0x%08x\n", + cpld_read(CPLD_ADDR_MUX)); + printf("HDMI setting: 0x%08x\n", + cpld_read(CPLD_ADDR_HDMI)); + printf("DIPSW (SW3): 0x%08x\n", + cpld_read(CPLD_ADDR_DIPSW)); + +#ifdef CONFIG_SH_SDHI + /* switch MUX to SD0 */ + val = cpld_read(CPLD_ADDR_MUX); + val &= ~MUX_MSK_SD0; + val |= MUX_VAL_SD0; + cpld_write(CPLD_ADDR_MUX, val); +#endif +} + +static int do_cpld(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) +{ + u32 addr, val; + + if (argc < 3) + return CMD_RET_USAGE; + + addr = simple_strtoul(argv[2], NULL, 16); + if (!(addr == CPLD_ADDR_VERSION || addr == CPLD_ADDR_MODE || + addr == CPLD_ADDR_MUX || addr == CPLD_ADDR_HDMI || + addr == CPLD_ADDR_DIPSW || addr == CPLD_ADDR_RESET)) { + printf("cpld invalid addr\n"); + return CMD_RET_USAGE; + } + + if (argc == 3 && strcmp(argv[1], "read") == 0) { + printf("0x%x\n", cpld_read(addr)); + } else if (argc == 4 && strcmp(argv[1], "write") == 0) { + val = simple_strtoul(argv[3], NULL, 16); + if (addr == CPLD_ADDR_MUX) { + /* never mask SCIFA0 console */ + val &= ~MUX_MSK_SCIFA0_USB; + val |= MUX_VAL_SCIFA0_USB; + } + cpld_write(addr, val); + } + + return 0; +} + +U_BOOT_CMD( + cpld, 4, 1, do_cpld, + "CPLD access", + "read addr\n" + "cpld write addr val\n" +); + +void reset_cpu(ulong addr) +{ + cpld_write(CPLD_ADDR_RESET, 1); +} diff --git a/board/renesas/stout/cpld.h b/board/renesas/stout/cpld.h new file mode 100644 index 0000000..a265670 --- /dev/null +++ b/board/renesas/stout/cpld.h @@ -0,0 +1,183 @@ +/* + * Stout board CPLD definition + * + * Copyright (C) 2015 Renesas Electronics Europe GmbH + * Copyright (C) 2015 Renesas Electronics Corporation + * Copyright (C) 2015 Cogent Embedded, Inc. + * + * SPDX-License-Identifier: GPL-2.0 + */ + +#ifndef _CPLD_H_ +#define _CPLD_H_ + +/* power-up behaviour */ +#define MODE_MSK_FREE_RUN 0x00000001 +#define MODE_VAL_FREE_RUN 0x00000000 +#define MODE_MSK_STEP_UP 0x00000001 +#define MODE_VAL_STEP_UP 0x00000000 + +/* boot source */ +#define MODE_MSK_BOOT_SQPI_16KB_FAST 0x0000000E +#define MODE_VAL_BOOT_SQPI_16KB_FAST 0x00000004 +#define MODE_MSK_BOOT_SQPI_16KB_SLOW 0x0000000E +#define MODE_VAL_BOOT_SQPI_16KB_SLOW 0x00000008 +#define MODE_MSK_BOOT_SQPI_4KB_SLOW 0x0000000E +#define MODE_VAL_BOOT_SQPI_4KB_SLOW 0x0000000C + +/* booting CPU */ +#define MODE_MSK_BOOT_CA15 0x000000C0 +#define MODE_VAL_BOOT_CA15 0x00000000 +#define MODE_MSK_BOOT_CA7 0x000000C0 +#define MODE_VAL_BOOT_CA7 0x00000040 +#define MODE_MSK_BOOT_SH4 0x000000C0 +#define MODE_VAL_BOOT_SH4 0x000000C0 + +/* JTAG connection */ +#define MODE_MSK_JTAG_CORESIGHT 0xC0301C00 +#define MODE_VAL_JTAG_CORESIGHT 0x00200000 +#define MODE_MSK_JTAG_SH4 0xC0301C00 +#define MODE_VAL_JTAG_SH4 0x00300000 + +/* DDR3 (PLL) speed */ +#define MODE_MSK_DDR3_1600 0x00080000 +#define MODE_VAL_DDR3_1600 0x00000000 +#define MODE_MSK_DDR3_1333 0x00080000 +#define MODE_VAL_DDR3_1333 0x00080000 + +/* ComboPhy0 mode */ +#define MODE_MSK_PHY0_SATA0 0x01000000 +#define MODE_VAL_PHY0_SATA0 0x00000000 +#define MODE_MSK_PHY0_PCIE 0x01000000 +#define MODE_VAL_PHY0_PCIE 0x01000000 + +/* ComboPhy1 mode */ +#define MODE_MSK_PHY1_SATA1 0x00800000 +#define MODE_VAL_PHY1_SATA1 0x00000000 +#define MODE_MSK_PHY1_USB3 0x00800000 +#define MODE_VAL_PHY1_USB3 0x00800000 + +/* + * Illegal multiplexer combinations. + * MUX Conflicts + * name with any one of + * VIN0_BT656 VIN0_full, SD2 + * VIN0_full VIN0_BT656, SD2, AVB, VIN2_(all) + * VIN1_BT656 VIN1_(others), SD0 + * VIN1_10bit VIN1_(others), SD0, VIN3_with*, I2C1 + * VIN1_12bit VIN1_(others), SD0, VIN3_with*, I2C1, SCIFA0_(all) + * VIN2_BT656 VIN0_full, VIN2_(others), AVB, + * VIN2_withSYNC VIN0_full, VIN2_(others), AVB, I2C1, SCIFA0_(all), + * VIN3_with* + * VIN2_withFIELD VIN0_full, VIN2_(others), AVB, SQPI_(all) + * VIN2_withSYNCandFIELD VIN0_full, VIN2_(others), AVB, SQPI_(all), I2C1, + * SCIFA0_(all), VIN3_with* + * VIN3_BT656 VIN3_(others), IRQ3 + * VIN3_withFIELD VIN3_(others), IRQ3, VIN1_12bit, VIN2_withSYNC, + * VIN2_withSYNCandFIELD, VIN1_10bit + * VIN3_withSYNCandFIELD VIN3_(others), IRQ3, VIN1_12bit, VIN2_withSYNC, + * VIN2_withSYNCandFIELD, VIN1_10bit, I2C1 + * AVB VIN0_full, VIN2_(all) + * QSPI_ONBOARD VIN2_withFIELD, VIN2_withSYNCandFIELD, QSPI_COMEXPRESS + * QSPI_COMEXPRESS VIN2_withFIELD, VIN2_withSYNCandFIELD, QSPI_ONBOARD + * I2C1 VIN1_12bit, VIN2_withSYNC, VIN2_withSYNCandFIELD, + * VIN3_withSYNCandFIELD + * IRQ3 VIN3_(all) + * SCIFA0_USB VIN1_12bit, VIN2_withSYNC, VIN2_withSYNCandFIELD, + * SCIFA0_COMEXPRESS + * SCIFA0_COMEXPRESS VIN1_12bit, VIN2_withSYNC, VIN2_withSYNCandFIELD, + * SCIFA0_USB + * SCIFA2 PWM210 + * ETH_ONBOARD ETH_COMEXPRESS + * ETH_COMEXPRESS ETH_ONBOARD + * SD0 VIN1_(all) + * SD2 VIN0_(all) + * PWM210 SCIFA2 + */ + +/* connected to COM Express connector and CN6 for camera, BT656 only */ +#define MUX_MSK_VIN0_BT656 0x00001001 +#define MUX_VAL_VIN0_BT656 0x00000000 +/* connected to COM Express connector and CN6 for camera, all modes */ +#define MUX_MSK_VIN0_full 0x00001007 +#define MUX_VAL_VIN0_full 0x00000002 +/* connected to COM Express connector, BT656 only */ +#define MUX_MSK_VIN1_BT656 0x00000801 +#define MUX_VAL_VIN1_BT656 0x00000800 +/* connected to COM Express connector, all 10-bit modes */ +#define MUX_MSK_VIN1_10bit 0x00000821 +#define MUX_VAL_VIN1_10bit 0x00000800 +/* connected to COM Express connector, all 12-bit modes */ +#define MUX_MSK_VIN1_12bit 0x000008A1 +#define MUX_VAL_VIN1_12bit 0x00000880 +/* connected to COM Express connector, BT656 only */ +#define MUX_MSK_VIN2_BT656 0x00000007 +#define MUX_VAL_VIN2_BT656 0x00000006 +/* connected to COM Express connector, modes with sync signals */ +#define MUX_MSK_VIN2_withSYNC 0x000000A7 +#define MUX_VAL_VIN2_withSYNC 0x00000086 +/* connected to COM Express connector, modes with field, clken signals */ +#define MUX_MSK_VIN2_withFIELD 0x0000000F +#define MUX_VAL_VIN2_withFIELD 0x0000000E +/* connected to COM Express connector, modes with sync, field, clken signals */ +#define MUX_MSK_VIN2_withSYNCandFIELD 0x000000AF +#define MUX_VAL_VIN2_withSYNCandFIELD 0x0000008E +/* connected to COM Express connector, BT656 only */ +#define MUX_MSK_VIN3_BT656 0x00000101 +#define MUX_VAL_VIN3_BT656 0x00000100 +/* connected to COM Express connector, modes with field, clken signals */ +#define MUX_MSK_VIN3_withFIELD 0x00000121 +#define MUX_VAL_VIN3_withFIELD 0x00000120 +/* connected to COM Express connector, modes with sync, field, clken signals */ +#define MUX_MSK_VIN3_withSYNCandFIELD 0x00000161 +#define MUX_VAL_VIN3_withSYNCandFIELD 0x00000120 +/* connected to COM Express connector (RGMII) */ +#define MUX_MSK_AVB 0x00000003 +#define MUX_VAL_AVB 0x00000000 +/* connected to on-board QSPI flash */ +#define MUX_MSK_QSPI_ONBOARD 0x00000019 +#define MUX_VAL_QSPI_ONBOARD 0x00000000 +/* connected to COM Express connector */ +#define MUX_MSK_QSPI_COMEXPRESS 0x00000019 +#define MUX_VAL_QSPI_COMEXPRESS 0x00000010 +/* connected to COM Express connector and PMIC */ +#define MUX_MSK_I2C1 0x00000061 +#define MUX_VAL_I2C1 0x00000060 +/* connected to HDMI driver */ +#define MUX_MSK_IRQ3 0x00000101 +#define MUX_VAL_IRQ3 0x00000000 +/* connected to USB/FTDI */ +#define MUX_MSK_SCIFA0_USB 0x00004081 +#define MUX_VAL_SCIFA0_USB 0x00004000 +/* connected to COM Express connector */ +#define MUX_MSK_SCIFA0_COMEXPRESS 0x00004081 +#define MUX_VAL_SCIFA0_COMEXPRESS 0x00000000 +/* connected to COM Express connector */ +#define MUX_MSK_SCIFA2 0x00002001 +#define MUX_VAL_SCIFA2 0x00000000 +/* connected to on-board 10/100 Phy */ +#define MUX_MSK_ETH_ONBOARD 0x00000600 +#define MUX_VAL_ETH_ONBOARD 0x00000000 +/* connected to COM Express connector (RMII) */ +#define MUX_MSK_ETH_COMEXPRESS 0x00000600 +#define MUX_VAL_ETH_COMEXPRESS 0x00000400 +/* connected to on-board MicroSD slot */ +#define MUX_MSK_SD0 0x00000801 +#define MUX_VAL_SD0 0x00000000 +/* connected to COM Express connector */ +#define MUX_MSK_SD2 0x00001001 +#define MUX_VAL_SD2 0x00001000 +/* connected to COM Express connector */ +#define MUX_MSK_PWM210 0x00002001 +#define MUX_VAL_PWM210 0x00002000 + +#define HDMI_MSK 0x07 +#define HDMI_OFF 0x00 +#define HDMI_ONBOARD 0x07 +#define HDMI_COMEXPRESS 0x05 +#define HDMI_ONBOARD_NODDC 0x03 +#define HDMI_COMEXPRESS_NODDC 0x01 + +void cpld_init(void); + +#endif /* _CPLD_H_ */ diff --git a/board/renesas/stout/qos.c b/board/renesas/stout/qos.c new file mode 100644 index 0000000..d49a0ab --- /dev/null +++ b/board/renesas/stout/qos.c @@ -0,0 +1,2435 @@ +/* + * board/renesas/stout/qos.c + * + * Copyright (C) 2015 Renesas Electronics Europe GmbH + * Copyright (C) 2015 Renesas Electronics Corporation + * Copyright (C) 2015 Cogent Embedded, Inc. + * + * SPDX-License-Identifier: GPL-2.0 + */ + +#include <common.h> +#include <asm/processor.h> +#include <asm/mach-types.h> +#include <asm/io.h> +#include <asm/arch/rmobile.h> + +/* QoS version 0.955 for ES1 and version 0.973 for ES2 */ +#if defined(CONFIG_RMOBILE_EXTRAM_BOOT) +enum { + DBSC3_00, DBSC3_01, DBSC3_02, DBSC3_03, DBSC3_04, + DBSC3_05, DBSC3_06, DBSC3_07, DBSC3_08, DBSC3_09, + DBSC3_10, DBSC3_11, DBSC3_12, DBSC3_13, DBSC3_14, + DBSC3_15, + DBSC3_NR, +}; + +static u32 dbsc3_0_r_qos_addr[DBSC3_NR] = { + [DBSC3_00] = DBSC3_0_QOS_R0_BASE, + [DBSC3_01] = DBSC3_0_QOS_R1_BASE, + [DBSC3_02] = DBSC3_0_QOS_R2_BASE, + [DBSC3_03] = DBSC3_0_QOS_R3_BASE, + [DBSC3_04] = DBSC3_0_QOS_R4_BASE, + [DBSC3_05] = DBSC3_0_QOS_R5_BASE, + [DBSC3_06] = DBSC3_0_QOS_R6_BASE, + [DBSC3_07] = DBSC3_0_QOS_R7_BASE, + [DBSC3_08] = DBSC3_0_QOS_R8_BASE, + [DBSC3_09] = DBSC3_0_QOS_R9_BASE, + [DBSC3_10] = DBSC3_0_QOS_R10_BASE, + [DBSC3_11] = DBSC3_0_QOS_R11_BASE, + [DBSC3_12] = DBSC3_0_QOS_R12_BASE, + [DBSC3_13] = DBSC3_0_QOS_R13_BASE, + [DBSC3_14] = DBSC3_0_QOS_R14_BASE, + [DBSC3_15] = DBSC3_0_QOS_R15_BASE, +}; + +static u32 dbsc3_0_w_qos_addr[DBSC3_NR] = { + [DBSC3_00] = DBSC3_0_QOS_W0_BASE, + [DBSC3_01] = DBSC3_0_QOS_W1_BASE, + [DBSC3_02] = DBSC3_0_QOS_W2_BASE, + [DBSC3_03] = DBSC3_0_QOS_W3_BASE, + [DBSC3_04] = DBSC3_0_QOS_W4_BASE, + [DBSC3_05] = DBSC3_0_QOS_W5_BASE, + [DBSC3_06] = DBSC3_0_QOS_W6_BASE, + [DBSC3_07] = DBSC3_0_QOS_W7_BASE, + [DBSC3_08] = DBSC3_0_QOS_W8_BASE, + [DBSC3_09] = DBSC3_0_QOS_W9_BASE, + [DBSC3_10] = DBSC3_0_QOS_W10_BASE, + [DBSC3_11] = DBSC3_0_QOS_W11_BASE, + [DBSC3_12] = DBSC3_0_QOS_W12_BASE, + [DBSC3_13] = DBSC3_0_QOS_W13_BASE, + [DBSC3_14] = DBSC3_0_QOS_W14_BASE, + [DBSC3_15] = DBSC3_0_QOS_W15_BASE, +}; + +/* QoS version 0.955 for ES1 */ +static void qos_init_es1(void) +{ + int i; + struct rcar_s3c *s3c; + struct rcar_s3c_qos *s3c_qos; + struct rcar_dbsc3_qos *qos_addr; + struct rcar_mxi *mxi; + struct rcar_mxi_qos *mxi_qos; + struct rcar_axi_qos *axi_qos; + + /* DBSC DBADJ2 */ + writel(0x20042004, DBSC3_0_DBADJ2); + + /* S3C -QoS */ + s3c = (struct rcar_s3c *)S3C_BASE; + writel(0x80FF1C1E, &s3c->s3cadsplcr); + writel(0x1F060505, &s3c->s3crorr); + writel(0x1F020100, &s3c->s3cworr); + + /* QoS Control Registers */ + s3c_qos = (struct rcar_s3c_qos *)S3C_QOS_CCI0_BASE; + writel(0x00800080, &s3c_qos->s3cqos0); + writel(0x22000010, &s3c_qos->s3cqos1); + writel(0x22002200, &s3c_qos->s3cqos2); + writel(0x2F002200, &s3c_qos->s3cqos3); + writel(0x2F002F00, &s3c_qos->s3cqos4); + writel(0x22000010, &s3c_qos->s3cqos5); + writel(0x22002200, &s3c_qos->s3cqos6); + writel(0x2F002200, &s3c_qos->s3cqos7); + writel(0x2F002F00, &s3c_qos->s3cqos8); + + s3c_qos = (struct rcar_s3c_qos *)S3C_QOS_CCI1_BASE; + writel(0x00800080, &s3c_qos->s3cqos0); + writel(0x22000010, &s3c_qos->s3cqos1); + writel(0x22002200, &s3c_qos->s3cqos2); + writel(0x2F002200, &s3c_qos->s3cqos3); + writel(0x2F002F00, &s3c_qos->s3cqos4); + writel(0x22000010, &s3c_qos->s3cqos5); + writel(0x22002200, &s3c_qos->s3cqos6); + writel(0x2F002200, &s3c_qos->s3cqos7); + writel(0x2F002F00, &s3c_qos->s3cqos8); + + s3c_qos = (struct rcar_s3c_qos *)S3C_QOS_MXI_BASE; + writel(0x80918099, &s3c_qos->s3cqos0); + writel(0x20410010, &s3c_qos->s3cqos1); + writel(0x200A2023, &s3c_qos->s3cqos2); + writel(0x20502001, &s3c_qos->s3cqos3); + writel(0x00002032, &s3c_qos->s3cqos4); + writel(0x20410FFF, &s3c_qos->s3cqos5); + writel(0x200A2023, &s3c_qos->s3cqos6); + writel(0x20502001, &s3c_qos->s3cqos7); + writel(0x20142032, &s3c_qos->s3cqos8); + + s3c_qos = (struct rcar_s3c_qos *)S3C_QOS_AXI_BASE; + writel(0x00810089, &s3c_qos->s3cqos0); + writel(0x20410001, &s3c_qos->s3cqos1); + writel(0x200A2023, &s3c_qos->s3cqos2); + writel(0x20502001, &s3c_qos->s3cqos3); + writel(0x00002032, &s3c_qos->s3cqos4); + writel(0x20410FFF, &s3c_qos->s3cqos5); + writel(0x200A2023, &s3c_qos->s3cqos6); + writel(0x20502001, &s3c_qos->s3cqos7); + writel(0x20142032, &s3c_qos->s3cqos8); + + writel(0x00200808, &s3c->s3carcr11); + + /* DBSC -QoS */ + /* DBSC0 - Read */ + for (i = DBSC3_00; i < DBSC3_NR; i++) { + qos_addr = (struct rcar_dbsc3_qos *)dbsc3_0_r_qos_addr[i]; + writel(0x00000203, &qos_addr->dblgcnt); + writel(0x00002064, &qos_addr->dbtmval0); + writel(0x00002048, &qos_addr->dbtmval1); + writel(0x00002032, &qos_addr->dbtmval2); + writel(0x00002019, &qos_addr->dbtmval3); + writel(0x00000001, &qos_addr->dbrqctr); + writel(0x00002019, &qos_addr->dbthres0); + writel(0x00002019, &qos_addr->dbthres1); + writel(0x00002019, &qos_addr->dbthres2); + writel(0x00000000, &qos_addr->dblgqon); + } + + /* DBSC0 - Write */ + for (i = DBSC3_00; i < DBSC3_NR; i++) { + qos_addr = (struct rcar_dbsc3_qos *)dbsc3_0_w_qos_addr[i]; + writel(0x00000203, &qos_addr->dblgcnt); + writel(0x00002064, &qos_addr->dbtmval0); + writel(0x00002048, &qos_addr->dbtmval1); + writel(0x00002032, &qos_addr->dbtmval2); + writel(0x00002019, &qos_addr->dbtmval3); + writel(0x00000001, &qos_addr->dbrqctr); + writel(0x00002019, &qos_addr->dbthres0); + writel(0x00002019, &qos_addr->dbthres1); + writel(0x00002019, &qos_addr->dbthres2); + writel(0x00000000, &qos_addr->dblgqon); + } + + /* CCI-400 -QoS */ + writel(0x20001000, CCI_400_MAXOT_1); + writel(0x20001000, CCI_400_MAXOT_2); + writel(0x0000000C, CCI_400_QOSCNTL_1); + writel(0x0000000C, CCI_400_QOSCNTL_2); + + /* MXI -QoS */ + /* Transaction Control (MXI) */ + mxi = (struct rcar_mxi *)MXI_BASE; + writel(0x00000013, &mxi->mxrtcr); + writel(0x00000013, &mxi->mxwtcr); + writel(0x00B800C0, &mxi->mxsaar0); + writel(0x02000800, &mxi->mxsaar1); + writel(0x00200000, &mxi->mxs3cracr); + writel(0x00200000, &mxi->mxs3cwacr); + writel(0x00200000, &mxi->mxaxiracr); + writel(0x00200000, &mxi->mxaxiwacr); + + /* QoS Control (MXI) */ + mxi_qos = (struct rcar_mxi_qos *)MXI_QOS_BASE; + writel(0x0000000C, &mxi_qos->vspdu0); + writel(0x0000000C, &mxi_qos->vspdu1); + writel(0x0000000D, &mxi_qos->du0); + writel(0x0000000D, &mxi_qos->du1); + + /* AXI -QoS */ + /* Transaction Control (MXI) */ + axi_qos = (struct rcar_axi_qos *)SYS_AXI_SYX64TO128_BASE; + writel(0x00000002, &axi_qos->qosconf); + writel(0x0000200F, &axi_qos->qosctset0); + writel(0x00002009, &axi_qos->qosctset1); + writel(0x00002003, &axi_qos->qosctset2); + writel(0x00002003, &axi_qos->qosctset3); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002001, &axi_qos->qosthres1); + writel(0x00000000, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)SYS_AXI_AVB_BASE; + writel(0x00000000, &axi_qos->qosconf); + writel(0x0000200A, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002001, &axi_qos->qosthres1); + writel(0x00000000, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)SYS_AXI_G2D_BASE; + writel(0x00000000, &axi_qos->qosconf); + writel(0x0000200A, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002001, &axi_qos->qosthres1); + writel(0x00000000, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)SYS_AXI_IMP0_BASE; + writel(0x00000000, &axi_qos->qosconf); + writel(0x00002002, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002001, &axi_qos->qosthres1); + writel(0x00000000, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)SYS_AXI_IMP1_BASE; + writel(0x00000000, &axi_qos->qosconf); + writel(0x00002004, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002001, &axi_qos->qosthres1); + writel(0x00000000, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)SYS_AXI_IMUX0_BASE; + writel(0x00000002, &axi_qos->qosconf); + writel(0x0000200F, &axi_qos->qosctset0); + writel(0x00002009, &axi_qos->qosctset1); + writel(0x00002003, &axi_qos->qosctset2); + writel(0x00002003, &axi_qos->qosctset3); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002001, &axi_qos->qosthres1); + writel(0x00000000, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)SYS_AXI_IMUX1_BASE; + writel(0x00000002, &axi_qos->qosconf); + writel(0x0000200F, &axi_qos->qosctset0); + writel(0x00002009, &axi_qos->qosctset1); + writel(0x00002003, &axi_qos->qosctset2); + writel(0x00002003, &axi_qos->qosctset3); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002001, &axi_qos->qosthres1); + writel(0x00000000, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)SYS_AXI_IMUX2_BASE; + writel(0x00000002, &axi_qos->qosconf); + writel(0x0000200F, &axi_qos->qosctset0); + writel(0x00002009, &axi_qos->qosctset1); + writel(0x00002003, &axi_qos->qosctset2); + writel(0x00002003, &axi_qos->qosctset3); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002001, &axi_qos->qosthres1); + writel(0x00000000, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)SYS_AXI_LBS_BASE; + writel(0x00000000, &axi_qos->qosconf); + writel(0x00002014, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002001, &axi_qos->qosthres1); + writel(0x00000000, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)SYS_AXI_MMUDS_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x00002001, &axi_qos->qosctset0); + writel(0x00002009, &axi_qos->qosctset1); + writel(0x00002003, &axi_qos->qosctset2); + writel(0x00002003, &axi_qos->qosctset3); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002001, &axi_qos->qosthres1); + writel(0x00000000, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)SYS_AXI_MMUM_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x00002001, &axi_qos->qosctset0); + writel(0x00002009, &axi_qos->qosctset1); + writel(0x00002003, &axi_qos->qosctset2); + writel(0x00002003, &axi_qos->qosctset3); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002001, &axi_qos->qosthres1); + writel(0x00000000, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)SYS_AXI_MMUR_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x00002001, &axi_qos->qosctset0); + writel(0x00002009, &axi_qos->qosctset1); + writel(0x00002003, &axi_qos->qosctset2); + writel(0x00002003, &axi_qos->qosctset3); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002001, &axi_qos->qosthres1); + writel(0x00000000, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)SYS_AXI_MMUS0_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x00002001, &axi_qos->qosctset0); + writel(0x00002009, &axi_qos->qosctset1); + writel(0x00002003, &axi_qos->qosctset2); + writel(0x00002003, &axi_qos->qosctset3); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002001, &axi_qos->qosthres1); + writel(0x00000000, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)SYS_AXI_MMUS1_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x00002001, &axi_qos->qosctset0); + writel(0x00002009, &axi_qos->qosctset1); + writel(0x00002003, &axi_qos->qosctset2); + writel(0x00002003, &axi_qos->qosctset3); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002001, &axi_qos->qosthres1); + writel(0x00000000, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)SYS_AXI_MTSB0_BASE; + writel(0x00000000, &axi_qos->qosconf); + writel(0x00002002, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002001, &axi_qos->qosthres1); + writel(0x00000000, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)SYS_AXI_MTSB1_BASE; + writel(0x00000000, &axi_qos->qosconf); + writel(0x00002002, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002001, &axi_qos->qosthres1); + writel(0x00000000, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)SYS_AXI_PCI_BASE; + writel(0x00000000, &axi_qos->qosconf); + writel(0x00002014, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002001, &axi_qos->qosthres1); + writel(0x00000000, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)SYS_AXI_RTX_BASE; + writel(0x00000002, &axi_qos->qosconf); + writel(0x0000200F, &axi_qos->qosctset0); + writel(0x00002009, &axi_qos->qosctset1); + writel(0x00002003, &axi_qos->qosctset2); + writel(0x00002003, &axi_qos->qosctset3); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002001, &axi_qos->qosthres1); + writel(0x00000000, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)SYS_AXI_SDS0_BASE; + writel(0x00000000, &axi_qos->qosconf); + writel(0x0000200A, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002001, &axi_qos->qosthres1); + writel(0x00000000, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)SYS_AXI_SDS1_BASE; + writel(0x00000000, &axi_qos->qosconf); + writel(0x0000200A, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002001, &axi_qos->qosthres1); + writel(0x00000000, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)SYS_AXI_USB20_BASE; + writel(0x00000000, &axi_qos->qosconf); + writel(0x00002005, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002001, &axi_qos->qosthres1); + writel(0x00000000, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)SYS_AXI_USB21_BASE; + writel(0x00000000, &axi_qos->qosconf); + writel(0x00002005, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002001, &axi_qos->qosthres1); + writel(0x00000000, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)SYS_AXI_USB22_BASE; + writel(0x00000000, &axi_qos->qosconf); + writel(0x00002005, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002001, &axi_qos->qosthres1); + writel(0x00000000, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)SYS_AXI_USB30_BASE; + writel(0x00000000, &axi_qos->qosconf); + writel(0x00002014, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002001, &axi_qos->qosthres1); + writel(0x00000000, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + /* QoS Register (RT-AXI) */ + axi_qos = (struct rcar_axi_qos *)RT_AXI_SHX_BASE; + writel(0x00000000, &axi_qos->qosconf); + writel(0x00002005, &axi_qos->qosctset0); + writel(0x00002009, &axi_qos->qosctset1); + writel(0x00002003, &axi_qos->qosctset2); + writel(0x00002003, &axi_qos->qosctset3); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002001, &axi_qos->qosthres1); + writel(0x00000000, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)RT_AXI_RDS_BASE; + writel(0x00000000, &axi_qos->qosconf); + writel(0x00002007, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002001, &axi_qos->qosthres1); + writel(0x00000000, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)RT_AXI_RTX64TO128_BASE; + writel(0x00000002, &axi_qos->qosconf); + writel(0x0000200F, &axi_qos->qosctset0); + writel(0x00002009, &axi_qos->qosctset1); + writel(0x00002003, &axi_qos->qosctset2); + writel(0x00002003, &axi_qos->qosctset3); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002001, &axi_qos->qosthres1); + writel(0x00000000, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)RT_AXI_STPRO_BASE; + writel(0x00000000, &axi_qos->qosconf); + writel(0x00002003, &axi_qos->qosctset0); + writel(0x00002009, &axi_qos->qosctset1); + writel(0x00002003, &axi_qos->qosctset2); + writel(0x00002003, &axi_qos->qosctset3); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002001, &axi_qos->qosthres1); + writel(0x00000000, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + /* QoS Register (MP-AXI) */ + axi_qos = (struct rcar_axi_qos *)MP_AXI_ADSP_BASE; + writel(0x00000000, &axi_qos->qosconf); + writel(0x00002007, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002001, &axi_qos->qosthres1); + writel(0x00000000, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)MP_AXI_ASDS0_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x00002014, &axi_qos->qosctset0); + writel(0x00000040, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002001, &axi_qos->qosthres1); + writel(0x00000000, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)MP_AXI_ASDS1_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x00002014, &axi_qos->qosctset0); + writel(0x00000040, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002001, &axi_qos->qosthres1); + writel(0x00000000, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)MP_AXI_MLP_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x00001FF0, &axi_qos->qosctset0); + writel(0x00000020, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002001, &axi_qos->qosthres1); + writel(0x00002001, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)MP_AXI_MMUMP_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x00002001, &axi_qos->qosctset0); + writel(0x00002009, &axi_qos->qosctset1); + writel(0x00002003, &axi_qos->qosctset2); + writel(0x00002003, &axi_qos->qosctset3); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002001, &axi_qos->qosthres1); + writel(0x00000000, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)MP_AXI_SPU_BASE; + writel(0x00000000, &axi_qos->qosconf); + writel(0x00002018, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002001, &axi_qos->qosthres1); + writel(0x00000000, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)MP_AXI_SPUC_BASE; + writel(0x00000000, &axi_qos->qosconf); + writel(0x0000200D, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002001, &axi_qos->qosthres1); + writel(0x00000000, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + /* QoS Register (SYS-AXI256) */ + axi_qos = (struct rcar_axi_qos *)SYS_AXI256_AXI128TO256_BASE; + writel(0x00000002, &axi_qos->qosconf); + writel(0x0000200F, &axi_qos->qosctset0); + writel(0x00002009, &axi_qos->qosctset1); + writel(0x00002003, &axi_qos->qosctset2); + writel(0x00002003, &axi_qos->qosctset3); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002001, &axi_qos->qosthres1); + writel(0x00000000, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)SYS_AXI256_SYX_BASE; + writel(0x00000002, &axi_qos->qosconf); + writel(0x0000200F, &axi_qos->qosctset0); + writel(0x00002009, &axi_qos->qosctset1); + writel(0x00002003, &axi_qos->qosctset2); + writel(0x00002003, &axi_qos->qosctset3); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002001, &axi_qos->qosthres1); + writel(0x00000000, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)SYS_AXI256_MPX_BASE; + writel(0x00000002, &axi_qos->qosconf); + writel(0x0000200F, &axi_qos->qosctset0); + writel(0x00002009, &axi_qos->qosctset1); + writel(0x00002003, &axi_qos->qosctset2); + writel(0x00002003, &axi_qos->qosctset3); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002001, &axi_qos->qosthres1); + writel(0x00000000, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)SYS_AXI256_MXI_BASE; + writel(0x00000002, &axi_qos->qosconf); + writel(0x0000200F, &axi_qos->qosctset0); + writel(0x00002009, &axi_qos->qosctset1); + writel(0x00002003, &axi_qos->qosctset2); + writel(0x00002003, &axi_qos->qosctset3); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002001, &axi_qos->qosthres1); + writel(0x00000000, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + /* QoS Register (CCI-AXI) */ + axi_qos = (struct rcar_axi_qos *)CCI_AXI_MMUS0_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x00002001, &axi_qos->qosctset0); + writel(0x00002009, &axi_qos->qosctset1); + writel(0x00002003, &axi_qos->qosctset2); + writel(0x00002003, &axi_qos->qosctset3); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002001, &axi_qos->qosthres1); + writel(0x00000000, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)CCI_AXI_SYX2_BASE; + writel(0x00000002, &axi_qos->qosconf); + writel(0x0000200F, &axi_qos->qosctset0); + writel(0x00002009, &axi_qos->qosctset1); + writel(0x00002003, &axi_qos->qosctset2); + writel(0x00002003, &axi_qos->qosctset3); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002001, &axi_qos->qosthres1); + writel(0x00000000, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)CCI_AXI_MMUR_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x00002001, &axi_qos->qosctset0); + writel(0x00002009, &axi_qos->qosctset1); + writel(0x00002003, &axi_qos->qosctset2); + writel(0x00002003, &axi_qos->qosctset3); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002001, &axi_qos->qosthres1); + writel(0x00000000, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)CCI_AXI_MMUDS_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x00002001, &axi_qos->qosctset0); + writel(0x00002009, &axi_qos->qosctset1); + writel(0x00002003, &axi_qos->qosctset2); + writel(0x00002003, &axi_qos->qosctset3); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002001, &axi_qos->qosthres1); + writel(0x00000000, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)CCI_AXI_MMUM_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x00002001, &axi_qos->qosctset0); + writel(0x00002009, &axi_qos->qosctset1); + writel(0x00002003, &axi_qos->qosctset2); + writel(0x00002003, &axi_qos->qosctset3); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002001, &axi_qos->qosthres1); + writel(0x00000000, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)CCI_AXI_MXI_BASE; + writel(0x00000002, &axi_qos->qosconf); + writel(0x0000200F, &axi_qos->qosctset0); + writel(0x00002009, &axi_qos->qosctset1); + writel(0x00002003, &axi_qos->qosctset2); + writel(0x00002003, &axi_qos->qosctset3); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002001, &axi_qos->qosthres1); + writel(0x00000000, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)CCI_AXI_MMUS1_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x00002001, &axi_qos->qosctset0); + writel(0x00002009, &axi_qos->qosctset1); + writel(0x00002003, &axi_qos->qosctset2); + writel(0x00002003, &axi_qos->qosctset3); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002001, &axi_qos->qosthres1); + writel(0x00000000, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)CCI_AXI_MMUMP_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x00002001, &axi_qos->qosctset0); + writel(0x00002009, &axi_qos->qosctset1); + writel(0x00002003, &axi_qos->qosctset2); + writel(0x00002003, &axi_qos->qosctset3); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002001, &axi_qos->qosthres1); + writel(0x00000000, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + /* QoS Register (Media-AXI) */ + axi_qos = (struct rcar_axi_qos *)MEDIA_AXI_JPR_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x00002018, &axi_qos->qosctset0); + writel(0x00000020, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002001, &axi_qos->qosthres1); + writel(0x00000001, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)MEDIA_AXI_JPW_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x00002018, &axi_qos->qosctset0); + writel(0x00000020, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002001, &axi_qos->qosthres1); + writel(0x00000001, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)MEDIA_AXI_GCU0R_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x00002018, &axi_qos->qosctset0); + writel(0x00000020, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002001, &axi_qos->qosthres1); + writel(0x00000001, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)MEDIA_AXI_GCU0W_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x00002018, &axi_qos->qosctset0); + writel(0x00000020, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002001, &axi_qos->qosthres1); + writel(0x00000001, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)MEDIA_AXI_GCU1R_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x00002018, &axi_qos->qosctset0); + writel(0x00000020, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002001, &axi_qos->qosthres1); + writel(0x00000001, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)MEDIA_AXI_GCU1W_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x00002018, &axi_qos->qosctset0); + writel(0x00000020, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002001, &axi_qos->qosthres1); + writel(0x00000001, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)MEDIA_AXI_TDMR_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x00002018, &axi_qos->qosctset0); + writel(0x00000020, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002001, &axi_qos->qosthres1); + writel(0x00000001, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)MEDIA_AXI_TDMW_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x00002018, &axi_qos->qosctset0); + writel(0x00000020, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002001, &axi_qos->qosthres1); + writel(0x00000001, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)MEDIA_AXI_VSP0CR_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x00002018, &axi_qos->qosctset0); + writel(0x00000020, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002001, &axi_qos->qosthres1); + writel(0x00000001, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)MEDIA_AXI_VSP0CW_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x00002018, &axi_qos->qosctset0); + writel(0x00000020, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002001, &axi_qos->qosthres1); + writel(0x00000001, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)MEDIA_AXI_VSP1CR_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x00002018, &axi_qos->qosctset0); + writel(0x00000020, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002001, &axi_qos->qosthres1); + writel(0x00000001, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)MEDIA_AXI_VSP1CW_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x00002018, &axi_qos->qosctset0); + writel(0x00000020, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002001, &axi_qos->qosthres1); + writel(0x00000001, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)MEDIA_AXI_VSPDU0CR_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x00002018, &axi_qos->qosctset0); + writel(0x00000020, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002001, &axi_qos->qosthres1); + writel(0x00000001, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)MEDIA_AXI_VSPDU0CW_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x00002018, &axi_qos->qosctset0); + writel(0x00000020, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002001, &axi_qos->qosthres1); + writel(0x00000001, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)MEDIA_AXI_VSPDU1CR_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x00002018, &axi_qos->qosctset0); + writel(0x00000020, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002001, &axi_qos->qosthres1); + writel(0x00000001, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)MEDIA_AXI_VSPDU1CW_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x00002018, &axi_qos->qosctset0); + writel(0x00000020, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002001, &axi_qos->qosthres1); + writel(0x00000001, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)MEDIA_AXI_VIN0W_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x0000200C, &axi_qos->qosctset0); + writel(0x00000020, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002001, &axi_qos->qosthres1); + writel(0x00000001, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)MEDIA_AXI_VSP0R_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x0000200C, &axi_qos->qosctset0); + writel(0x00000020, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002001, &axi_qos->qosthres1); + writel(0x00000001, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)MEDIA_AXI_VSP0W_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x0000200C, &axi_qos->qosctset0); + writel(0x00000020, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002001, &axi_qos->qosthres1); + writel(0x00000001, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)MEDIA_AXI_FDP0R_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x0000200C, &axi_qos->qosctset0); + writel(0x00000020, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002001, &axi_qos->qosthres1); + writel(0x00000001, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)MEDIA_AXI_FDP0W_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x0000200C, &axi_qos->qosctset0); + writel(0x00000020, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002001, &axi_qos->qosthres1); + writel(0x00000001, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)MEDIA_AXI_IMSR_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x0000200C, &axi_qos->qosctset0); + writel(0x00000020, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002001, &axi_qos->qosthres1); + writel(0x00000001, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)MEDIA_AXI_IMSW_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x0000200C, &axi_qos->qosctset0); + writel(0x00000020, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002001, &axi_qos->qosthres1); + writel(0x00000001, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)MEDIA_AXI_VSP1R_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x0000200C, &axi_qos->qosctset0); + writel(0x00000020, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002001, &axi_qos->qosthres1); + writel(0x00000001, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)MEDIA_AXI_VSP1W_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x0000200C, &axi_qos->qosctset0); + writel(0x00000020, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002001, &axi_qos->qosthres1); + writel(0x00000001, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)MEDIA_AXI_FDP1R_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x0000200C, &axi_qos->qosctset0); + writel(0x00000020, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002001, &axi_qos->qosthres1); + writel(0x00000001, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)MEDIA_AXI_FDP1W_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x0000200C, &axi_qos->qosctset0); + writel(0x00000020, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002001, &axi_qos->qosthres1); + writel(0x00000001, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)MEDIA_AXI_IMRR_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x0000200C, &axi_qos->qosctset0); + writel(0x00000020, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002001, &axi_qos->qosthres1); + writel(0x00000001, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)MEDIA_AXI_IMRW_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x0000200C, &axi_qos->qosctset0); + writel(0x00000020, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002001, &axi_qos->qosthres1); + writel(0x00000001, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)MEDIA_AXI_FDP2R_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x0000200C, &axi_qos->qosctset0); + writel(0x00000020, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002001, &axi_qos->qosthres1); + writel(0x00000001, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)MEDIA_AXI_FDP2W_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x0000200C, &axi_qos->qosctset0); + writel(0x00000020, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002001, &axi_qos->qosthres1); + writel(0x00000001, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)MEDIA_AXI_VSPD0R_BASE; + writel(0x00000000, &axi_qos->qosconf); + writel(0x0000200C, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002001, &axi_qos->qosthres1); + writel(0x00000001, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)MEDIA_AXI_VSPD0W_BASE; + writel(0x00000000, &axi_qos->qosconf); + writel(0x0000200C, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002001, &axi_qos->qosthres1); + writel(0x00000001, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)MEDIA_AXI_VSPD1R_BASE; + writel(0x00000000, &axi_qos->qosconf); + writel(0x0000200C, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002001, &axi_qos->qosthres1); + writel(0x00000001, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)MEDIA_AXI_VSPD1W_BASE; + writel(0x00000000, &axi_qos->qosconf); + writel(0x0000200C, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002001, &axi_qos->qosthres1); + writel(0x00000001, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)MEDIA_AXI_DU0R_BASE; + writel(0x00000000, &axi_qos->qosconf); + writel(0x0000200C, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002001, &axi_qos->qosthres1); + writel(0x00000001, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)MEDIA_AXI_DU0W_BASE; + writel(0x00000000, &axi_qos->qosconf); + writel(0x0000200C, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002001, &axi_qos->qosthres1); + writel(0x00000001, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)MEDIA_AXI_DU1R_BASE; + writel(0x00000000, &axi_qos->qosconf); + writel(0x0000200C, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002001, &axi_qos->qosthres1); + writel(0x00000001, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)MEDIA_AXI_DU1W_BASE; + writel(0x00000000, &axi_qos->qosconf); + writel(0x0000200C, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002001, &axi_qos->qosthres1); + writel(0x00000001, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)MEDIA_AXI_VCP0CR_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x00002007, &axi_qos->qosctset0); + writel(0x00000020, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002001, &axi_qos->qosthres1); + writel(0x00000001, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)MEDIA_AXI_VCP0CW_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x00002007, &axi_qos->qosctset0); + writel(0x00000020, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002001, &axi_qos->qosthres1); + writel(0x00000001, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)MEDIA_AXI_VCP0VR_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x00002007, &axi_qos->qosctset0); + writel(0x00000020, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002001, &axi_qos->qosthres1); + writel(0x00000001, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)MEDIA_AXI_VCP0VW_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x00002007, &axi_qos->qosctset0); + writel(0x00000020, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002001, &axi_qos->qosthres1); + writel(0x00000001, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)MEDIA_AXI_VPC0R_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x00002007, &axi_qos->qosctset0); + writel(0x00000020, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002001, &axi_qos->qosthres1); + writel(0x00000001, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)MEDIA_AXI_VCP1CR_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x00002007, &axi_qos->qosctset0); + writel(0x00000020, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002001, &axi_qos->qosthres1); + writel(0x00000001, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)MEDIA_AXI_VCP1CW_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x00002007, &axi_qos->qosctset0); + writel(0x00000020, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002001, &axi_qos->qosthres1); + writel(0x00000001, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)MEDIA_AXI_VCP1VR_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x00002007, &axi_qos->qosctset0); + writel(0x00000020, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002001, &axi_qos->qosthres1); + writel(0x00000001, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)MEDIA_AXI_VCP1VW_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x00002007, &axi_qos->qosctset0); + writel(0x00000020, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002001, &axi_qos->qosthres1); + writel(0x00000001, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)MEDIA_AXI_VPC1R_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x00002007, &axi_qos->qosctset0); + writel(0x00000020, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002001, &axi_qos->qosthres1); + writel(0x00000001, &axi_qos->qosthres2); + writel(0x00000000, &axi_qos->qosqon); +} + +#if defined(CONFIG_QOS_PRI_MEDIA) +#define is_qos_pri_media() 1 +#else +#define is_qos_pri_media() 0 +#endif + +#if defined(CONFIG_QOS_PRI_NORMAL) +#define is_qos_pri_normal() 1 +#else +#define is_qos_pri_normal() 0 +#endif + +#if defined(CONFIG_QOS_PRI_GFX) +#define is_qos_pri_gfx() 1 +#else +#define is_qos_pri_gfx() 0 +#endif + +/* QoS version 0.963 for ES2 */ +static void qos_init_es2(void) +{ + int i; + struct rcar_s3c *s3c; + struct rcar_s3c_qos *s3c_qos; + struct rcar_dbsc3_qos *qos_addr; + struct rcar_mxi *mxi; + struct rcar_mxi_qos *mxi_qos; + struct rcar_axi_qos *axi_qos; + + /* DBSC DBADJ2 */ + writel(0x20042004, DBSC3_0_DBADJ2); + + /* S3C -QoS */ + s3c = (struct rcar_s3c *)S3C_BASE; + writel(0x80000000, &s3c->s3cadsplcr); + if (is_qos_pri_media()) { + writel(0x1F060302, &s3c->s3crorr); + writel(0x07070302, &s3c->s3cworr); + } else if (is_qos_pri_normal()) { + writel(0x1F060504, &s3c->s3crorr); + writel(0x07070503, &s3c->s3cworr); + } else if (is_qos_pri_gfx()) { + writel(0x1F060606, &s3c->s3crorr); + writel(0x07070606, &s3c->s3cworr); + } + /* QoS Control Registers */ + s3c_qos = (struct rcar_s3c_qos *)S3C_QOS_CCI0_BASE; + writel(0x00890089, &s3c_qos->s3cqos0); + writel(0x20960010, &s3c_qos->s3cqos1); + writel(0x20302030, &s3c_qos->s3cqos2); + if (is_qos_pri_media()) + writel(0x20AA2300, &s3c_qos->s3cqos3); + else if (is_qos_pri_normal()) + writel(0x20AA2200, &s3c_qos->s3cqos3); + else if (is_qos_pri_gfx()) + writel(0x20AA2100, &s3c_qos->s3cqos3); + writel(0x00002032, &s3c_qos->s3cqos4); + writel(0x20960010, &s3c_qos->s3cqos5); + writel(0x20302030, &s3c_qos->s3cqos6); + if (is_qos_pri_media()) + writel(0x20AA2300, &s3c_qos->s3cqos7); + else if (is_qos_pri_normal()) + writel(0x20AA2200, &s3c_qos->s3cqos7); + else if (is_qos_pri_gfx()) + writel(0x20AA2100, &s3c_qos->s3cqos7); + writel(0x00002032, &s3c_qos->s3cqos8); + + s3c_qos = (struct rcar_s3c_qos *)S3C_QOS_CCI1_BASE; + writel(0x00890089, &s3c_qos->s3cqos0); + writel(0x20960010, &s3c_qos->s3cqos1); + writel(0x20302030, &s3c_qos->s3cqos2); + if (is_qos_pri_media()) + writel(0x20AA2300, &s3c_qos->s3cqos3); + else if (is_qos_pri_normal()) + writel(0x20AA2200, &s3c_qos->s3cqos3); + else if (is_qos_pri_gfx()) + writel(0x20AA2100, &s3c_qos->s3cqos3); + writel(0x00002032, &s3c_qos->s3cqos4); + writel(0x20960010, &s3c_qos->s3cqos5); + writel(0x20302030, &s3c_qos->s3cqos6); + if (is_qos_pri_media()) + writel(0x20AA2300, &s3c_qos->s3cqos7); + else if (is_qos_pri_normal()) + writel(0x20AA2200, &s3c_qos->s3cqos7); + else if (is_qos_pri_gfx()) + writel(0x20AA2100, &s3c_qos->s3cqos7); + writel(0x00002032, &s3c_qos->s3cqos8); + + s3c_qos = (struct rcar_s3c_qos *)S3C_QOS_MXI_BASE; + writel(0x80928092, &s3c_qos->s3cqos0); + writel(0x20960020, &s3c_qos->s3cqos1); + writel(0x20302030, &s3c_qos->s3cqos2); + writel(0x20AA20DC, &s3c_qos->s3cqos3); + writel(0x00002032, &s3c_qos->s3cqos4); + writel(0x20960020, &s3c_qos->s3cqos5); + writel(0x20302030, &s3c_qos->s3cqos6); + writel(0x20AA20DC, &s3c_qos->s3cqos7); + writel(0x00002032, &s3c_qos->s3cqos8); + + s3c_qos = (struct rcar_s3c_qos *)S3C_QOS_AXI_BASE; + writel(0x00828092, &s3c_qos->s3cqos0); + writel(0x20960020, &s3c_qos->s3cqos1); + writel(0x20302030, &s3c_qos->s3cqos2); + writel(0x20AA20FA, &s3c_qos->s3cqos3); + writel(0x00002032, &s3c_qos->s3cqos4); + writel(0x20960020, &s3c_qos->s3cqos5); + writel(0x20302030, &s3c_qos->s3cqos6); + writel(0x20AA20FA, &s3c_qos->s3cqos7); + writel(0x00002032, &s3c_qos->s3cqos8); + + writel(0x00310808, &s3c->s3carcr11); + + /* DBSC -QoS */ + /* DBSC0 - Read */ + for (i = DBSC3_00; i < DBSC3_NR; i++) { + qos_addr = (struct rcar_dbsc3_qos *)dbsc3_0_r_qos_addr[i]; + writel(0x00000002, &qos_addr->dblgcnt); + writel(0x00002096, &qos_addr->dbtmval0); + writel(0x00002064, &qos_addr->dbtmval1); + writel(0x00002032, &qos_addr->dbtmval2); + writel(0x00001FB0, &qos_addr->dbtmval3); + writel(0x00000001, &qos_addr->dbrqctr); + writel(0x00002078, &qos_addr->dbthres0); + writel(0x0000204B, &qos_addr->dbthres1); + writel(0x0000201E, &qos_addr->dbthres2); + writel(0x00000001, &qos_addr->dblgqon); + } + + /* DBSC0 - Write */ + for (i = DBSC3_00; i < DBSC3_NR; i++) { + qos_addr = (struct rcar_dbsc3_qos *)dbsc3_0_w_qos_addr[i]; + writel(0x00000002, &qos_addr->dblgcnt); + writel(0x00002096, &qos_addr->dbtmval0); + writel(0x00002064, &qos_addr->dbtmval1); + writel(0x00002050, &qos_addr->dbtmval2); + writel(0x0000203A, &qos_addr->dbtmval3); + writel(0x00000001, &qos_addr->dbrqctr); + writel(0x00002078, &qos_addr->dbthres0); + writel(0x0000204B, &qos_addr->dbthres1); + writel(0x0000203C, &qos_addr->dbthres2); + writel(0x00000001, &qos_addr->dblgqon); + } + + /* MXI -QoS */ + /* Transaction Control (MXI) */ + mxi = (struct rcar_mxi *)MXI_BASE; + writel(0x00000013, &mxi->mxrtcr); + writel(0x00000016, &mxi->mxwtcr); + writel(0x00B800C0, &mxi->mxsaar0); + writel(0x02000800, &mxi->mxsaar1); + + /* QoS Control (MXI) */ + mxi_qos = (struct rcar_mxi_qos *)MXI_QOS_BASE; + writel(0x0000000C, &mxi_qos->vspdu0); + writel(0x0000000C, &mxi_qos->vspdu1); + writel(0x0000000E, &mxi_qos->du0); + writel(0x0000000E, &mxi_qos->du1); + + /* AXI -QoS */ + /* Transaction Control (MXI) */ + axi_qos = (struct rcar_axi_qos *)SYS_AXI_SYX64TO128_BASE; + writel(0x00000002, &axi_qos->qosconf); + writel(0x00002245, &axi_qos->qosctset0); + writel(0x00002096, &axi_qos->qosctset1); + writel(0x00002030, &axi_qos->qosctset2); + writel(0x00002030, &axi_qos->qosctset3); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002064, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00000000, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)SYS_AXI_AVB_BASE; + writel(0x00000000, &axi_qos->qosconf); + writel(0x000020A6, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002064, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00000000, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)SYS_AXI_G2D_BASE; + writel(0x00000000, &axi_qos->qosconf); + writel(0x000020A6, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002064, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00000000, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)SYS_AXI_IMP0_BASE; + writel(0x00000000, &axi_qos->qosconf); + writel(0x00002021, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002064, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00000000, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)SYS_AXI_IMP1_BASE; + writel(0x00000000, &axi_qos->qosconf); + writel(0x00002037, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002064, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00000000, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)SYS_AXI_IMUX0_BASE; + writel(0x00000002, &axi_qos->qosconf); + writel(0x00002245, &axi_qos->qosctset0); + writel(0x00002096, &axi_qos->qosctset1); + writel(0x00002030, &axi_qos->qosctset2); + writel(0x00002030, &axi_qos->qosctset3); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002064, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00000000, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)SYS_AXI_IMUX1_BASE; + writel(0x00000002, &axi_qos->qosconf); + writel(0x00002245, &axi_qos->qosctset0); + writel(0x00002096, &axi_qos->qosctset1); + writel(0x00002030, &axi_qos->qosctset2); + writel(0x00002030, &axi_qos->qosctset3); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002064, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00000000, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)SYS_AXI_IMUX2_BASE; + writel(0x00000002, &axi_qos->qosconf); + writel(0x00002245, &axi_qos->qosctset0); + writel(0x00002096, &axi_qos->qosctset1); + writel(0x00002030, &axi_qos->qosctset2); + writel(0x00002030, &axi_qos->qosctset3); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002064, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00000000, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)SYS_AXI_LBS_BASE; + writel(0x00000000, &axi_qos->qosconf); + writel(0x0000214C, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002064, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00000000, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)SYS_AXI_MMUDS_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x00002004, &axi_qos->qosctset0); + writel(0x00002096, &axi_qos->qosctset1); + writel(0x00002030, &axi_qos->qosctset2); + writel(0x00002030, &axi_qos->qosctset3); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002064, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00000000, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)SYS_AXI_MMUM_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x00002004, &axi_qos->qosctset0); + writel(0x00002096, &axi_qos->qosctset1); + writel(0x00002030, &axi_qos->qosctset2); + writel(0x00002030, &axi_qos->qosctset3); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002064, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00000000, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)SYS_AXI_MMUR_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x00002004, &axi_qos->qosctset0); + writel(0x00002096, &axi_qos->qosctset1); + writel(0x00002030, &axi_qos->qosctset2); + writel(0x00002030, &axi_qos->qosctset3); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002064, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00000000, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)SYS_AXI_MMUS0_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x00002004, &axi_qos->qosctset0); + writel(0x00002096, &axi_qos->qosctset1); + writel(0x00002030, &axi_qos->qosctset2); + writel(0x00002030, &axi_qos->qosctset3); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002064, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00000000, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)SYS_AXI_MMUS1_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x00002004, &axi_qos->qosctset0); + writel(0x00002096, &axi_qos->qosctset1); + writel(0x00002030, &axi_qos->qosctset2); + writel(0x00002030, &axi_qos->qosctset3); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002064, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00000000, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)SYS_AXI_MTSB0_BASE; + writel(0x00000000, &axi_qos->qosconf); + writel(0x00002021, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002064, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00000000, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)SYS_AXI_MTSB1_BASE; + writel(0x00000000, &axi_qos->qosconf); + writel(0x00002021, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002064, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00000000, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)SYS_AXI_PCI_BASE; + writel(0x00000000, &axi_qos->qosconf); + writel(0x0000214C, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002064, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00000000, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)SYS_AXI_RTX_BASE; + writel(0x00000002, &axi_qos->qosconf); + writel(0x00002245, &axi_qos->qosctset0); + writel(0x00002096, &axi_qos->qosctset1); + writel(0x00002030, &axi_qos->qosctset2); + writel(0x00002030, &axi_qos->qosctset3); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002064, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00000000, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)SYS_AXI_SDS0_BASE; + writel(0x00000000, &axi_qos->qosconf); + writel(0x000020A6, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002064, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00000000, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)SYS_AXI_SDS1_BASE; + writel(0x00000000, &axi_qos->qosconf); + writel(0x000020A6, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002064, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00000000, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)SYS_AXI_USB20_BASE; + writel(0x00000000, &axi_qos->qosconf); + writel(0x00002053, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002064, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00000000, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)SYS_AXI_USB21_BASE; + writel(0x00000000, &axi_qos->qosconf); + writel(0x00002053, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002064, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00000000, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)SYS_AXI_USB22_BASE; + writel(0x00000000, &axi_qos->qosconf); + writel(0x00002053, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002064, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00000000, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)SYS_AXI_USB30_BASE; + writel(0x00000000, &axi_qos->qosconf); + writel(0x0000214C, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002064, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00000000, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)SYS_AXI_AX2M_BASE; + writel(0x00000002, &axi_qos->qosconf); + writel(0x00002245, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002064, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00000000, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)SYS_AXI_CC50_BASE; + writel(0x00000000, &axi_qos->qosconf); + writel(0x00002029, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002064, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00000000, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)SYS_AXI_CCI_BASE; + writel(0x00000002, &axi_qos->qosconf); + writel(0x00002245, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002064, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00000000, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)SYS_AXI_CS_BASE; + writel(0x00000000, &axi_qos->qosconf); + writel(0x00002053, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002064, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00000000, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)SYS_AXI_DDM_BASE; + writel(0x00000000, &axi_qos->qosconf); + writel(0x000020A6, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002064, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00000000, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)SYS_AXI_ETH_BASE; + writel(0x00000000, &axi_qos->qosconf); + writel(0x00002053, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002064, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00000000, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)SYS_AXI_MPXM_BASE; + writel(0x00000002, &axi_qos->qosconf); + writel(0x00002245, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002064, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00000000, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)SYS_AXI_SAT0_BASE; + writel(0x00000000, &axi_qos->qosconf); + writel(0x00002053, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002064, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00000000, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)SYS_AXI_SAT1_BASE; + writel(0x00000000, &axi_qos->qosconf); + writel(0x00002053, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002064, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00000000, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)SYS_AXI_SDM0_BASE; + writel(0x00000000, &axi_qos->qosconf); + writel(0x0000214C, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002064, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00000000, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)SYS_AXI_SDM1_BASE; + writel(0x00000000, &axi_qos->qosconf); + writel(0x0000214C, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002064, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00000000, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)SYS_AXI_TRAB_BASE; + writel(0x00000000, &axi_qos->qosconf); + writel(0x000020A6, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002064, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00000000, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)SYS_AXI_UDM0_BASE; + writel(0x00000000, &axi_qos->qosconf); + writel(0x00002053, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002064, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00000000, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)SYS_AXI_UDM1_BASE; + writel(0x00000000, &axi_qos->qosconf); + writel(0x00002053, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002064, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00000000, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + /* QoS Register (RT-AXI) */ + axi_qos = (struct rcar_axi_qos *)RT_AXI_SHX_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x00002053, &axi_qos->qosctset0); + writel(0x00002096, &axi_qos->qosctset1); + writel(0x00002030, &axi_qos->qosctset2); + writel(0x00002030, &axi_qos->qosctset3); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002064, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00000000, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)RT_AXI_DBG_BASE; + writel(0x00000000, &axi_qos->qosconf); + writel(0x00002053, &axi_qos->qosctset0); + writel(0x00002096, &axi_qos->qosctset1); + writel(0x00002030, &axi_qos->qosctset2); + writel(0x00002030, &axi_qos->qosctset3); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002064, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00000000, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)RT_AXI_RDM_BASE; + writel(0x00000000, &axi_qos->qosconf); + writel(0x00002299, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002064, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00000000, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)RT_AXI_RDS_BASE; + writel(0x00000000, &axi_qos->qosconf); + writel(0x00002029, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002064, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00000000, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)RT_AXI_RTX64TO128_BASE; + writel(0x00000002, &axi_qos->qosconf); + writel(0x00002245, &axi_qos->qosctset0); + writel(0x00002096, &axi_qos->qosctset1); + writel(0x00002030, &axi_qos->qosctset2); + writel(0x00002030, &axi_qos->qosctset3); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002064, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00000000, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)RT_AXI_STPRO_BASE; + writel(0x00000000, &axi_qos->qosconf); + writel(0x00002029, &axi_qos->qosctset0); + writel(0x00002096, &axi_qos->qosctset1); + writel(0x00002030, &axi_qos->qosctset2); + writel(0x00002030, &axi_qos->qosctset3); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002064, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00000000, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)RT_AXI_SY2RT_BASE; + writel(0x00000002, &axi_qos->qosconf); + writel(0x00002245, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002064, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00000000, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + /* QoS Register (MP-AXI) */ + axi_qos = (struct rcar_axi_qos *)MP_AXI_ADSP_BASE; + writel(0x00000000, &axi_qos->qosconf); + writel(0x00002037, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002064, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00000000, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)MP_AXI_ASDS0_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x00002014, &axi_qos->qosctset0); + writel(0x00000040, &axi_qos->qosreqctr); + writel(0x00002064, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00000000, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)MP_AXI_ASDS1_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x00002014, &axi_qos->qosctset0); + writel(0x00000040, &axi_qos->qosreqctr); + writel(0x00002064, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00000000, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)MP_AXI_MLP_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x00001FF0, &axi_qos->qosctset0); + writel(0x00000020, &axi_qos->qosreqctr); + writel(0x00002064, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00002001, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)MP_AXI_MMUMP_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x00002004, &axi_qos->qosctset0); + writel(0x00002096, &axi_qos->qosctset1); + writel(0x00002030, &axi_qos->qosctset2); + writel(0x00002030, &axi_qos->qosctset3); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002064, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00000000, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)MP_AXI_SPU_BASE; + writel(0x00000000, &axi_qos->qosconf); + writel(0x00002053, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002064, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00000000, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)MP_AXI_SPUC_BASE; + writel(0x00000000, &axi_qos->qosconf); + writel(0x0000206E, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002064, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00000000, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + /* QoS Register (SYS-AXI256) */ + axi_qos = (struct rcar_axi_qos *)SYS_AXI256_AXI128TO256_BASE; + writel(0x00000002, &axi_qos->qosconf); + writel(0x000020EB, &axi_qos->qosctset0); + writel(0x00002096, &axi_qos->qosctset1); + writel(0x00002030, &axi_qos->qosctset2); + writel(0x00002030, &axi_qos->qosctset3); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002064, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00000000, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)SYS_AXI256_SYX_BASE; + writel(0x00000002, &axi_qos->qosconf); + writel(0x000020EB, &axi_qos->qosctset0); + writel(0x00002096, &axi_qos->qosctset1); + writel(0x00002030, &axi_qos->qosctset2); + writel(0x00002030, &axi_qos->qosctset3); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002064, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00000000, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)SYS_AXI256_MPX_BASE; + writel(0x00000002, &axi_qos->qosconf); + writel(0x000020EB, &axi_qos->qosctset0); + writel(0x00002096, &axi_qos->qosctset1); + writel(0x00002030, &axi_qos->qosctset2); + writel(0x00002030, &axi_qos->qosctset3); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002064, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00000000, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)SYS_AXI256_MXI_BASE; + writel(0x00000002, &axi_qos->qosconf); + writel(0x000020EB, &axi_qos->qosctset0); + writel(0x00002096, &axi_qos->qosctset1); + writel(0x00002030, &axi_qos->qosctset2); + writel(0x00002030, &axi_qos->qosctset3); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002064, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00000000, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + /* QoS Register (CCI-AXI) */ + axi_qos = (struct rcar_axi_qos *)CCI_AXI_MMUS0_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x00002004, &axi_qos->qosctset0); + writel(0x00002096, &axi_qos->qosctset1); + writel(0x00002030, &axi_qos->qosctset2); + writel(0x00002030, &axi_qos->qosctset3); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002064, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00000000, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)CCI_AXI_SYX2_BASE; + writel(0x00000002, &axi_qos->qosconf); + writel(0x00002245, &axi_qos->qosctset0); + writel(0x00002096, &axi_qos->qosctset1); + writel(0x00002030, &axi_qos->qosctset2); + writel(0x00002030, &axi_qos->qosctset3); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002064, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00000000, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)CCI_AXI_MMUR_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x00002004, &axi_qos->qosctset0); + writel(0x00002096, &axi_qos->qosctset1); + writel(0x00002030, &axi_qos->qosctset2); + writel(0x00002030, &axi_qos->qosctset3); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002064, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00000000, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)CCI_AXI_MMUDS_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x00002004, &axi_qos->qosctset0); + writel(0x00002096, &axi_qos->qosctset1); + writel(0x00002030, &axi_qos->qosctset2); + writel(0x00002030, &axi_qos->qosctset3); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002064, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00000000, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)CCI_AXI_MMUM_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x00002004, &axi_qos->qosctset0); + writel(0x00002096, &axi_qos->qosctset1); + writel(0x00002030, &axi_qos->qosctset2); + writel(0x00002030, &axi_qos->qosctset3); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002064, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00000000, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)CCI_AXI_MXI_BASE; + writel(0x00000002, &axi_qos->qosconf); + writel(0x00002245, &axi_qos->qosctset0); + writel(0x00002096, &axi_qos->qosctset1); + writel(0x00002030, &axi_qos->qosctset2); + writel(0x00002030, &axi_qos->qosctset3); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002064, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00000000, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)CCI_AXI_MMUS1_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x00002004, &axi_qos->qosctset0); + writel(0x00002096, &axi_qos->qosctset1); + writel(0x00002030, &axi_qos->qosctset2); + writel(0x00002030, &axi_qos->qosctset3); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002064, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00000000, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)CCI_AXI_MMUMP_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x00002004, &axi_qos->qosctset0); + writel(0x00002096, &axi_qos->qosctset1); + writel(0x00002030, &axi_qos->qosctset2); + writel(0x00002030, &axi_qos->qosctset3); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002064, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00000000, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + /* QoS Register (Media-AXI) */ + axi_qos = (struct rcar_axi_qos *)MEDIA_AXI_MXR_BASE; + writel(0x00000002, &axi_qos->qosconf); + writel(0x000020dc, &axi_qos->qosctset0); + writel(0x00002096, &axi_qos->qosctset1); + writel(0x00002030, &axi_qos->qosctset2); + writel(0x00002030, &axi_qos->qosctset3); + writel(0x00000020, &axi_qos->qosreqctr); + writel(0x000020AA, &axi_qos->qosthres0); + writel(0x00002032, &axi_qos->qosthres1); + writel(0x00000001, &axi_qos->qosthres2); + + axi_qos = (struct rcar_axi_qos *)MEDIA_AXI_MXW_BASE; + writel(0x00000002, &axi_qos->qosconf); + writel(0x000020dc, &axi_qos->qosctset0); + writel(0x00002096, &axi_qos->qosctset1); + writel(0x00002030, &axi_qos->qosctset2); + writel(0x00002030, &axi_qos->qosctset3); + writel(0x00000020, &axi_qos->qosreqctr); + writel(0x000020AA, &axi_qos->qosthres0); + writel(0x00002032, &axi_qos->qosthres1); + writel(0x00000001, &axi_qos->qosthres2); + + axi_qos = (struct rcar_axi_qos *)MEDIA_AXI_JPR_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x00002190, &axi_qos->qosctset0); + writel(0x00000020, &axi_qos->qosreqctr); + writel(0x00002064, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00000001, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)MEDIA_AXI_JPW_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x00002190, &axi_qos->qosctset0); + writel(0x00000020, &axi_qos->qosreqctr); + writel(0x00002004, &axi_qos->qosthres0); + writel(0x00000001, &axi_qos->qosthres1); + writel(0x00000001, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)MEDIA_AXI_GCU0R_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x00002190, &axi_qos->qosctset0); + writel(0x00000020, &axi_qos->qosreqctr); + writel(0x00002064, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00000001, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)MEDIA_AXI_GCU0W_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x00002190, &axi_qos->qosctset0); + writel(0x00000020, &axi_qos->qosreqctr); + writel(0x00002004, &axi_qos->qosthres0); + writel(0x00000001, &axi_qos->qosthres1); + writel(0x00000001, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)MEDIA_AXI_GCU1R_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x00002190, &axi_qos->qosctset0); + writel(0x00000020, &axi_qos->qosreqctr); + writel(0x00002064, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00000001, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)MEDIA_AXI_GCU1W_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x00002190, &axi_qos->qosctset0); + writel(0x00000020, &axi_qos->qosreqctr); + writel(0x00002004, &axi_qos->qosthres0); + writel(0x00000001, &axi_qos->qosthres1); + writel(0x00000001, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)MEDIA_AXI_TDMR_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x00002190, &axi_qos->qosctset0); + writel(0x00000020, &axi_qos->qosreqctr); + writel(0x00002064, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00000001, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)MEDIA_AXI_TDMW_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x00002190, &axi_qos->qosctset0); + writel(0x00000020, &axi_qos->qosreqctr); + writel(0x00002004, &axi_qos->qosthres0); + writel(0x00000001, &axi_qos->qosthres1); + writel(0x00000001, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)MEDIA_AXI_VSP0CR_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x00002190, &axi_qos->qosctset0); + writel(0x00000020, &axi_qos->qosreqctr); + writel(0x00002064, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00000001, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)MEDIA_AXI_VSP0CW_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x00002190, &axi_qos->qosctset0); + writel(0x00000020, &axi_qos->qosreqctr); + writel(0x00002004, &axi_qos->qosthres0); + writel(0x00000001, &axi_qos->qosthres1); + writel(0x00000001, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)MEDIA_AXI_VSP1CR_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x00002190, &axi_qos->qosctset0); + writel(0x00000020, &axi_qos->qosreqctr); + writel(0x00002064, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00000001, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)MEDIA_AXI_VSP1CW_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x00002190, &axi_qos->qosctset0); + writel(0x00000020, &axi_qos->qosreqctr); + writel(0x00002004, &axi_qos->qosthres0); + writel(0x00000001, &axi_qos->qosthres1); + writel(0x00000001, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)MEDIA_AXI_VSPDU0CR_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x00002190, &axi_qos->qosctset0); + writel(0x00000020, &axi_qos->qosreqctr); + writel(0x00002064, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00000001, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)MEDIA_AXI_VSPDU0CW_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x00002190, &axi_qos->qosctset0); + writel(0x00000020, &axi_qos->qosreqctr); + writel(0x00002004, &axi_qos->qosthres0); + writel(0x00000001, &axi_qos->qosthres1); + writel(0x00000001, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)MEDIA_AXI_VSPDU1CR_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x00002190, &axi_qos->qosctset0); + writel(0x00000020, &axi_qos->qosreqctr); + writel(0x00002064, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00000001, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)MEDIA_AXI_VSPDU1CW_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x00002190, &axi_qos->qosctset0); + writel(0x00000020, &axi_qos->qosreqctr); + writel(0x00002004, &axi_qos->qosthres0); + writel(0x00000001, &axi_qos->qosthres1); + writel(0x00000001, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)MEDIA_AXI_VIN0W_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x00001FF0, &axi_qos->qosctset0); + writel(0x00000020, &axi_qos->qosreqctr); + writel(0x00002064, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00002001, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)MEDIA_AXI_VSP0R_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x000020C8, &axi_qos->qosctset0); + writel(0x00000020, &axi_qos->qosreqctr); + writel(0x00002064, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00000001, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)MEDIA_AXI_VSP0W_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x000020C8, &axi_qos->qosctset0); + writel(0x00000020, &axi_qos->qosreqctr); + writel(0x00002004, &axi_qos->qosthres0); + writel(0x00000001, &axi_qos->qosthres1); + writel(0x00000001, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)MEDIA_AXI_FDP0R_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x000020C8, &axi_qos->qosctset0); + writel(0x00000020, &axi_qos->qosreqctr); + writel(0x00002064, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00000001, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)MEDIA_AXI_FDP0W_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x000020C8, &axi_qos->qosctset0); + writel(0x00000020, &axi_qos->qosreqctr); + writel(0x00002004, &axi_qos->qosthres0); + writel(0x00000001, &axi_qos->qosthres1); + writel(0x00000001, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)MEDIA_AXI_IMSR_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x000020C8, &axi_qos->qosctset0); + writel(0x00000020, &axi_qos->qosreqctr); + writel(0x00002064, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00000001, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)MEDIA_AXI_IMSW_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x000020C8, &axi_qos->qosctset0); + writel(0x00000020, &axi_qos->qosreqctr); + writel(0x00002064, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00000001, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)MEDIA_AXI_VSP1R_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x000020C8, &axi_qos->qosctset0); + writel(0x00000020, &axi_qos->qosreqctr); + writel(0x00002064, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00000001, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)MEDIA_AXI_VSP1W_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x000020C8, &axi_qos->qosctset0); + writel(0x00000020, &axi_qos->qosreqctr); + writel(0x00002004, &axi_qos->qosthres0); + writel(0x00000001, &axi_qos->qosthres1); + writel(0x00000001, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)MEDIA_AXI_FDP1R_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x000020C8, &axi_qos->qosctset0); + writel(0x00000020, &axi_qos->qosreqctr); + writel(0x00002064, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00000001, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)MEDIA_AXI_FDP1W_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x000020C8, &axi_qos->qosctset0); + writel(0x00000020, &axi_qos->qosreqctr); + writel(0x00002004, &axi_qos->qosthres0); + writel(0x00000001, &axi_qos->qosthres1); + writel(0x00000001, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)MEDIA_AXI_IMRR_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x000020C8, &axi_qos->qosctset0); + writel(0x00000020, &axi_qos->qosreqctr); + writel(0x00002064, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00000001, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)MEDIA_AXI_IMRW_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x000020C8, &axi_qos->qosctset0); + writel(0x00000020, &axi_qos->qosreqctr); + writel(0x00002004, &axi_qos->qosthres0); + writel(0x00000001, &axi_qos->qosthres1); + writel(0x00000001, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)MEDIA_AXI_FDP2R_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x000020C8, &axi_qos->qosctset0); + writel(0x00000020, &axi_qos->qosreqctr); + writel(0x00002064, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00000001, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)MEDIA_AXI_FDP2W_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x000020C8, &axi_qos->qosctset0); + writel(0x00000020, &axi_qos->qosreqctr); + writel(0x00002004, &axi_qos->qosthres0); + writel(0x00000001, &axi_qos->qosthres1); + writel(0x00000001, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)MEDIA_AXI_VSPD0R_BASE; + writel(0x00000003, &axi_qos->qosconf); + writel(0x000020C8, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002064, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00000001, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)MEDIA_AXI_VSPD0W_BASE; + writel(0x00000003, &axi_qos->qosconf); + writel(0x000020C8, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00000001, &axi_qos->qosthres0); + writel(0x00000001, &axi_qos->qosthres1); + writel(0x00000001, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)MEDIA_AXI_VSPD1R_BASE; + writel(0x00000003, &axi_qos->qosconf); + writel(0x000020C8, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002064, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00000001, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)MEDIA_AXI_VSPD1W_BASE; + writel(0x00000003, &axi_qos->qosconf); + writel(0x000020C8, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00000001, &axi_qos->qosthres0); + writel(0x00000001, &axi_qos->qosthres1); + writel(0x00000001, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)MEDIA_AXI_DU0R_BASE; + writel(0x00000003, &axi_qos->qosconf); + writel(0x00002063, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002064, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00000001, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)MEDIA_AXI_DU0W_BASE; + writel(0x00000003, &axi_qos->qosconf); + writel(0x00002063, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00000001, &axi_qos->qosthres0); + writel(0x00000001, &axi_qos->qosthres1); + writel(0x00000001, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)MEDIA_AXI_DU1R_BASE; + writel(0x00000003, &axi_qos->qosconf); + writel(0x00002063, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002064, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00000001, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)MEDIA_AXI_DU1W_BASE; + writel(0x00000003, &axi_qos->qosconf); + writel(0x00002063, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00000001, &axi_qos->qosthres0); + writel(0x00000001, &axi_qos->qosthres1); + writel(0x00000001, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)MEDIA_AXI_VCP0CR_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x00002073, &axi_qos->qosctset0); + writel(0x00000020, &axi_qos->qosreqctr); + writel(0x00002064, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00000001, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)MEDIA_AXI_VCP0CW_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x00002073, &axi_qos->qosctset0); + writel(0x00000020, &axi_qos->qosreqctr); + writel(0x00002004, &axi_qos->qosthres0); + writel(0x00000001, &axi_qos->qosthres1); + writel(0x00000001, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)MEDIA_AXI_VCP0VR_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x00002073, &axi_qos->qosctset0); + writel(0x00000020, &axi_qos->qosreqctr); + writel(0x00002064, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00000001, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)MEDIA_AXI_VCP0VW_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x00002073, &axi_qos->qosctset0); + writel(0x00000020, &axi_qos->qosreqctr); + writel(0x00002004, &axi_qos->qosthres0); + writel(0x00000001, &axi_qos->qosthres1); + writel(0x00000001, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)MEDIA_AXI_VPC0R_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x00002073, &axi_qos->qosctset0); + writel(0x00000020, &axi_qos->qosreqctr); + writel(0x00002064, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00000001, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)MEDIA_AXI_VCP1CR_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x00002073, &axi_qos->qosctset0); + writel(0x00000020, &axi_qos->qosreqctr); + writel(0x00002064, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00000001, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)MEDIA_AXI_VCP1CW_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x00002073, &axi_qos->qosctset0); + writel(0x00000020, &axi_qos->qosreqctr); + writel(0x00002004, &axi_qos->qosthres0); + writel(0x00000001, &axi_qos->qosthres1); + writel(0x00000001, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)MEDIA_AXI_VCP1VR_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x00002073, &axi_qos->qosctset0); + writel(0x00000020, &axi_qos->qosreqctr); + writel(0x00002064, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00000001, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)MEDIA_AXI_VCP1VW_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x00002073, &axi_qos->qosctset0); + writel(0x00000020, &axi_qos->qosreqctr); + writel(0x00002004, &axi_qos->qosthres0); + writel(0x00000001, &axi_qos->qosthres1); + writel(0x00000001, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct rcar_axi_qos *)MEDIA_AXI_VPC1R_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x00002073, &axi_qos->qosctset0); + writel(0x00000020, &axi_qos->qosreqctr); + writel(0x00002064, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00000001, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); +} + +void qos_init(void) +{ + if (rmobile_get_cpu_rev_integer() >= R8A7790_CUT_ES2X) + qos_init_es2(); + else + qos_init_es1(); +} +#else /* CONFIG_RMOBILE_EXTRAM_BOOT */ +void qos_init(void) +{ +} +#endif /* CONFIG_RMOBILE_EXTRAM_BOOT */ diff --git a/board/renesas/stout/qos.h b/board/renesas/stout/qos.h new file mode 100644 index 0000000..645a5b0 --- /dev/null +++ b/board/renesas/stout/qos.h @@ -0,0 +1,14 @@ +/* + * Copyright (C) 2015 Renesas Electronics Europe GmbH + * Copyright (C) 2015 Renesas Electronics Corporation + * Copyright (C) 2015 Cogent Embedded, Inc. + * + * SPDX-License-Identifier: GPL-2.0 + */ + +#ifndef __QOS_H__ +#define __QOS_H__ + +void qos_init(void); + +#endif diff --git a/board/renesas/stout/stout.c b/board/renesas/stout/stout.c new file mode 100644 index 0000000..7df7394 --- /dev/null +++ b/board/renesas/stout/stout.c @@ -0,0 +1,232 @@ +/* + * board/renesas/stout/stout.c + * This file is Stout board support. + * + * Copyright (C) 2015 Renesas Electronics Europe GmbH + * Copyright (C) 2015 Renesas Electronics Corporation + * Copyright (C) 2015 Cogent Embedded, Inc. + * + * SPDX-License-Identifier: GPL-2.0 + */ + +#include <common.h> +#include <malloc.h> +#include <netdev.h> +#include <dm.h> +#include <dm/platform_data/serial_sh.h> +#include <asm/processor.h> +#include <asm/mach-types.h> +#include <asm/io.h> +#include <asm/errno.h> +#include <asm/arch/sys_proto.h> +#include <asm/gpio.h> +#include <asm/arch/rmobile.h> +#include <asm/arch/rcar-mstp.h> +#include <asm/arch/mmc.h> +#include <asm/arch/sh_sdhi.h> +#include <miiphy.h> +#include <i2c.h> +#include <mmc.h> +#include "qos.h" +#include "cpld.h" + +DECLARE_GLOBAL_DATA_PTR; + +#define CLK2MHZ(clk) (clk / 1000 / 1000) +void s_init(void) +{ + struct rcar_rwdt *rwdt = (struct rcar_rwdt *)RWDT_BASE; + struct rcar_swdt *swdt = (struct rcar_swdt *)SWDT_BASE; + + /* Watchdog init */ + writel(0xA5A5A500, &rwdt->rwtcsra); + writel(0xA5A5A500, &swdt->swtcsra); + + /* CPU frequency setting. Set to 1.4GHz */ + if (rmobile_get_cpu_rev_integer() >= R8A7790_CUT_ES2X) { + u32 stat = 0; + u32 stc = ((1400 / CLK2MHZ(CONFIG_SYS_CLK_FREQ)) - 1) + << PLL0_STC_BIT; + clrsetbits_le32(PLL0CR, PLL0_STC_MASK, stc); + + do { + stat = readl(PLLECR) & PLL0ST; + } while (stat == 0x0); + } + + /* QoS(Quality-of-Service) Init */ + qos_init(); +} + +#define TMU0_MSTP125 (1 << 25) +#define SCIFA0_MSTP204 (1 << 4) +#define SDHI0_MSTP314 (1 << 14) +#define SDHI2_MSTP312 (1 << 12) +#define ETHER_MSTP813 (1 << 13) + +#define MSTPSR3 0xE6150048 +#define SMSTPCR3 0xE615013C + +#define SD2CKCR 0xE6150078 +#define SD2_97500KHZ 0x7 + +int board_early_init_f(void) +{ + /* TMU0 */ + mstp_clrbits_le32(MSTPSR1, SMSTPCR1, TMU0_MSTP125); + /* SCIFA0 */ + mstp_clrbits_le32(MSTPSR2, SMSTPCR2, SCIFA0_MSTP204); + /* ETHER */ + mstp_clrbits_le32(MSTPSR8, SMSTPCR8, ETHER_MSTP813); + /* SDHI0,2 */ + mstp_clrbits_le32(MSTPSR3, SMSTPCR3, SDHI0_MSTP314 | SDHI2_MSTP312); + + /* + * SD0 clock is set to 97.5MHz by default. + * Set SD2 to the 97.5MHz as well. + */ + writel(SD2_97500KHZ, SD2CKCR); + + return 0; +} + +int board_init(void) +{ + /* adress of boot parameters */ + gd->bd->bi_boot_params = CONFIG_SYS_SDRAM_BASE + 0x100; + + /* Init PFC controller */ + r8a7790_pinmux_init(); + + cpld_init(); + +#ifdef CONFIG_SH_ETHER + /* ETHER Enable */ + gpio_request(GPIO_FN_ETH_CRS_DV, NULL); + gpio_request(GPIO_FN_ETH_RX_ER, NULL); + gpio_request(GPIO_FN_ETH_RXD0, NULL); + gpio_request(GPIO_FN_ETH_RXD1, NULL); + gpio_request(GPIO_FN_ETH_LINK, NULL); + gpio_request(GPIO_FN_ETH_REF_CLK, NULL); + gpio_request(GPIO_FN_ETH_MDIO, NULL); + gpio_request(GPIO_FN_ETH_TXD1, NULL); + gpio_request(GPIO_FN_ETH_TX_EN, NULL); + gpio_request(GPIO_FN_ETH_MAGIC, NULL); + gpio_request(GPIO_FN_ETH_TXD0, NULL); + gpio_request(GPIO_FN_ETH_MDC, NULL); + gpio_request(GPIO_FN_IRQ1, NULL); + + gpio_request(GPIO_GP_3_31, NULL); /* PHY_RST */ + gpio_direction_output(GPIO_GP_3_31, 0); + mdelay(20); + gpio_set_value(GPIO_GP_3_31, 1); + udelay(1); +#endif + + return 0; +} + +#define CXR24 0xEE7003C0 /* MAC address high register */ +#define CXR25 0xEE7003C8 /* MAC address low register */ +int board_eth_init(bd_t *bis) +{ + int ret = -ENODEV; + +#ifdef CONFIG_SH_ETHER + u32 val; + unsigned char enetaddr[6]; + + ret = sh_eth_initialize(bis); + if (!eth_getenv_enetaddr("ethaddr", enetaddr)) + return ret; + + /* Set Mac address */ + val = enetaddr[0] << 24 | enetaddr[1] << 16 | + enetaddr[2] << 8 | enetaddr[3]; + writel(val, CXR24); + + val = enetaddr[4] << 8 | enetaddr[5]; + writel(val, CXR25); +#endif + + return ret; +} + +/* Stout has KSZ8041NL/RNL */ +#define PHY_CONTROL1 0x1E +#define PHY_LED_MODE 0xC0000 +#define PHY_LED_MODE_ACK 0x4000 +int board_phy_config(struct phy_device *phydev) +{ + int ret = phy_read(phydev, MDIO_DEVAD_NONE, PHY_CONTROL1); + ret &= ~PHY_LED_MODE; + ret |= PHY_LED_MODE_ACK; + ret = phy_write(phydev, MDIO_DEVAD_NONE, PHY_CONTROL1, (u16)ret); + + return 0; +} + +int board_mmc_init(bd_t *bis) +{ + int ret = -ENODEV; + +#ifdef CONFIG_SH_SDHI + gpio_request(GPIO_FN_SD0_DAT0, NULL); + gpio_request(GPIO_FN_SD0_DAT1, NULL); + gpio_request(GPIO_FN_SD0_DAT2, NULL); + gpio_request(GPIO_FN_SD0_DAT3, NULL); + gpio_request(GPIO_FN_SD0_CLK, NULL); + gpio_request(GPIO_FN_SD0_CMD, NULL); + gpio_request(GPIO_FN_SD0_CD, NULL); + gpio_request(GPIO_FN_SD2_DAT0, NULL); + gpio_request(GPIO_FN_SD2_DAT1, NULL); + gpio_request(GPIO_FN_SD2_DAT2, NULL); + gpio_request(GPIO_FN_SD2_DAT3, NULL); + gpio_request(GPIO_FN_SD2_CLK, NULL); + gpio_request(GPIO_FN_SD2_CMD, NULL); + gpio_request(GPIO_FN_SD2_CD, NULL); + + /* SDHI0 - needs CPLD mux setup */ + gpio_request(GPIO_GP_3_30, NULL); + gpio_direction_output(GPIO_GP_3_30, 1); /* VLDO3=3.3V */ + gpio_request(GPIO_GP_5_24, NULL); + gpio_direction_output(GPIO_GP_5_24, 1); /* power on */ + + ret = sh_sdhi_init(CONFIG_SYS_SH_SDHI0_BASE, 0, + SH_SDHI_QUIRK_16BIT_BUF); + if (ret) + return ret; + + /* SDHI2 - needs CPLD mux setup */ + gpio_request(GPIO_GP_3_29, NULL); + gpio_direction_output(GPIO_GP_3_29, 1); /* VLDO4=3.3V */ + gpio_request(GPIO_GP_5_25, NULL); + gpio_direction_output(GPIO_GP_5_25, 1); /* power on */ + + ret = sh_sdhi_init(CONFIG_SYS_SH_SDHI2_BASE, 2, 0); +#endif + return ret; +} + + +int dram_init(void) +{ + gd->ram_size = CONFIG_SYS_SDRAM_SIZE; + + return 0; +} + +const struct rmobile_sysinfo sysinfo = { + CONFIG_RMOBILE_BOARD_STRING +}; + +static const struct sh_serial_platdata serial_platdata = { + .base = SCIFA0_BASE, + .type = PORT_SCIFA, + .clk = CONFIG_MP_CLK_FREQ, +}; + +U_BOOT_DEVICE(stout_serials) = { + .name = "serial_sh", + .platdata = &serial_platdata, +}; diff --git a/configs/stout_defconfig b/configs/stout_defconfig new file mode 100644 index 0000000..fbfe919 --- /dev/null +++ b/configs/stout_defconfig @@ -0,0 +1,21 @@ +CONFIG_ARM=y +CONFIG_RMOBILE=y +CONFIG_TARGET_STOUT=y +# CONFIG_CMD_BDI is not set +# CONFIG_CMD_CONSOLE is not set +# CONFIG_CMD_BOOTD is not set +# CONFIG_CMD_IMI is not set +# CONFIG_CMD_IMLS is not set +# CONFIG_CMD_XIMG is not set +# CONFIG_CMD_ENV_EXISTS is not set +# CONFIG_CMD_LOADB is not set +# CONFIG_CMD_FLASH is not set +# CONFIG_CMD_FPGA is not set +# CONFIG_CMD_ECHO is not set +# CONFIG_CMD_ITEST is not set +# CONFIG_CMD_SOURCE is not set +# CONFIG_CMD_SETEXPR is not set +# CONFIG_CMD_MISC is not set +CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_BAR=y +CONFIG_SH_SDHI=y diff --git a/include/configs/stout.h b/include/configs/stout.h new file mode 100644 index 0000000..87ea530 --- /dev/null +++ b/include/configs/stout.h @@ -0,0 +1,112 @@ +/* + * include/configs/stout.h + * This file is Stout board configuration. + * + * Copyright (C) 2015 Renesas Electronics Europe GmbH + * Copyright (C) 2015 Renesas Electronics Corporation + * Copyright (C) 2015 Cogent Embedded, Inc. + * + * SPDX-License-Identifier: GPL-2.0 + */ + +#ifndef __STOUT_H +#define __STOUT_H + +#undef DEBUG +#define CONFIG_R8A7790 +#define CONFIG_RMOBILE_BOARD_STRING "Stout" + +#include "rcar-gen2-common.h" + +/* #define CONFIG_BOARD_LATE_INIT */ + +#if defined(CONFIG_RMOBILE_EXTRAM_BOOT) +#define CONFIG_SYS_TEXT_BASE 0xB0000000 +#else +#define CONFIG_SYS_TEXT_BASE 0xE8080000 +#endif + +/* STACK */ +#if defined(CONFIGF_RMOBILE_EXTRAM_BOOT) +#define CONFIG_SYS_INIT_SP_ADDR 0xB003FFFC +#else +#define CONFIG_SYS_INIT_SP_ADDR 0xE827FFFC +#endif +#define STACK_AREA_SIZE 0xC000 +#define LOW_LEVEL_MERAM_STACK \ + (CONFIG_SYS_INIT_SP_ADDR + STACK_AREA_SIZE - 4) + +/* MEMORY */ +#define RCAR_GEN2_SDRAM_BASE 0x40000000 +#define RCAR_GEN2_SDRAM_SIZE (1024u * 1024 * 1024) +#define RCAR_GEN2_UBOOT_SDRAM_SIZE (512 * 1024 * 1024) + +/* SCIF */ +#define CONFIG_SCIF_CONSOLE +#define CONFIG_SCIF_A + +/* SPI */ +#define CONFIG_SPI +#define CONFIG_SH_QSPI +#define CONFIG_SPI_FLASH_SPANSION +#define CONFIG_SPI_FLASH_QUAD +#define CONFIG_SYS_NO_FLASH + +/* SH Ether */ +#define CONFIG_SH_ETHER +#define CONFIG_SH_ETHER_USE_PORT 0 +#define CONFIG_SH_ETHER_PHY_ADDR 0x1 +#define CONFIG_SH_ETHER_PHY_MODE PHY_INTERFACE_MODE_RMII +#define CONFIG_SH_ETHER_ALIGNE_SIZE 64 +#define CONFIG_SH_ETHER_CACHE_WRITEBACK +#define CONFIG_SH_ETHER_CACHE_INVALIDATE +#define CONFIG_PHYLIB +#define CONFIG_PHY_MICREL +#define CONFIG_BITBANGMII +#define CONFIG_BITBANGMII_MULTI + +/* I2C */ +#define CONFIG_SYS_I2C +#define CONFIG_SYS_I2C_RCAR +#define CONFIG_SYS_RCAR_I2C0_SPEED 400000 +#define CONFIG_SYS_RCAR_I2C1_SPEED 400000 +#define CONFIG_SYS_RCAR_I2C2_SPEED 400000 +#define CONFIG_SYS_RCAR_I2C3_SPEED 400000 +#define CONFIF_SYS_RCAR_I2C_NUM_CONTROLLERS 4 + +#define CONFIG_SYS_I2C_POWERIC_ADDR 0x58 /* da9063 */ + +/* Board Clock */ +#define RMOBILE_XTAL_CLK 20000000u +#define CONFIG_SYS_CLK_FREQ RMOBILE_XTAL_CLK +#define CONFIG_SH_TMU_CLK_FREQ (CONFIG_SYS_CLK_FREQ / 2) /* EXT / 2 */ +#define CONFIG_PLL1_CLK_FREQ (CONFIG_SYS_CLK_FREQ * 156 / 2) +#define CONFIG_PLL1_DIV2_CLK_FREQ (CONFIG_PLL1_CLK_FREQ / 2) +#define CONFIG_MP_CLK_FREQ (CONFIG_PLL1_DIV2_CLK_FREQ / 15) +#define CONFIG_HP_CLK_FREQ (CONFIG_PLL1_CLK_FREQ / 12) + +#define CONFIG_SYS_TMU_CLK_DIV 4 + +/* USB */ +#define CONFIG_USB_EHCI +#define CONFIG_USB_EHCI_RMOBILE +#define CONFIG_USB_MAX_CONTROLLER_COUNT 3 +#define CONFIG_USB_STORAGE + +/* MMC */ +#define CONFIG_MMC +#define CONFIG_CMD_MMC +#define CONFIG_GENERIC_MMC + +/* Module stop status bits */ +/* INTC-RT */ +#define CONFIG_SMSTP0_ENA 0x00400000 +/* MSIF, SCIFA0 */ +#define CONFIG_SMSTP2_ENA 0x00002010 +/* INTC-SYS, IRQC */ +#define CONFIG_SMSTP4_ENA 0x00000180 + +/* SDHI */ +#define CONFIG_SH_SDHI_FREQ 97500000 + +#endif /* __STOUT_H */
+ Nobuhiro Iwamatsu iwamatsu@nigauri.org
Sorry, seem that I've added old maintainer email.
On 20.07.2015 20:48, Vladimir Barinov wrote:
This patch series adds the following:
- sh-pfc: fix gpio input read
- serial-sh: SCIFA interface for R-Car Gen2 SoCs
- rmobile: add SCIFA port base offsets
- rmobile: Add Stout board support
Signed-off-by: Vladimir Barinov vladimir.barinov@cogentembedded.com
arch/arm/cpu/armv7/rmobile/Kconfig | 8 arch/arm/include/asm/arch-rmobile/rcar-base.h | 3 board/renesas/stout/Kconfig | 12 board/renesas/stout/MAINTAINERS | 6 board/renesas/stout/Makefile | 11 board/renesas/stout/cpld.c | 167 + board/renesas/stout/cpld.h | 183 + board/renesas/stout/qos.c | 2435 ++++++++++++++++++++++++++ board/renesas/stout/qos.h | 14 board/renesas/stout/stout.c | 232 ++ configs/stout_defconfig | 21 drivers/gpio/sh_pfc.c | 3 drivers/serial/serial_sh.h | 43 include/configs/stout.h | 112 + 14 files changed, 3239 insertions(+), 11 deletions(-)
Hello Nobuhiro-san,
Could you provide any response for this patchset.
TIA, Vladimir
Hi, Vladimir.
Sorry about this. I just applied my repository.
Best regards, Nobuhiro
2015-08-21 4:57 GMT+09:00 Vladimir Barinov vladimir.barinov@cogentembedded.com:
Hello Nobuhiro-san,
TIA, Vladimir
Nobuhiro Iwamatsu
Vladimir Barinov
