[U-Boot] [GIT PULL] Pull request: u-boot-imx
Hi Tom,
The following changes since commit f3651764e57e353251695691677bd95ba5a420bc: Frans Meulenbroeks (1): cmd_itest.c: fix pointer dereferencing
git://git.denx.de/u-boot-imx master
John Rigby (5): mxc_serial replace platform specific clock Add support for Freescale MX25 SOC fec_mxc: cleanup and factor out MX27 dependencies fec_mxc: add MX25 support Add support for KARO TX25 board
Stefano Babic (9): MX51: Add initial support for the Freescale MX51 MX51: Add register definitions MX51: Add pin and multiplexer definitions. serial_mxc: add support for MX51 processor mmc: check correctness of the voltage mask in ocr MMC: add weak function to detect MMC/SD card ARM: add accessors functions fsl_esdhc: add support for mx51 processor Add initial support for Freescale mx51evk board
MAINTAINERS | 8 + MAKEALL | 1 + Makefile | 8 + board/freescale/mx51evk/Makefile | 48 ++++ board/freescale/mx51evk/config.mk | 25 ++ board/freescale/mx51evk/imximage.cfg | 119 +++++++++ board/freescale/mx51evk/mx51evk.c | 406 ++++++++++++++++++++++++++++ board/freescale/mx51evk/mx51evk.h | 51 ++++ board/karo/tx25/Makefile | 51 ++++ board/karo/tx25/config.mk | 5 + board/karo/tx25/lowlevel_init.S | 131 +++++++++ board/karo/tx25/tx25.c | 176 +++++++++++++ cpu/arm926ejs/mx25/Makefile | 46 ++++ cpu/arm926ejs/mx25/generic.c | 263 +++++++++++++++++++ cpu/arm926ejs/mx25/reset.c | 56 ++++ cpu/arm926ejs/mx25/timer.c | 187 +++++++++++++ cpu/arm926ejs/mx27/generic.c | 5 + cpu/arm_cortexa8/mx51/Makefile | 48 ++++ cpu/arm_cortexa8/mx51/clock.c | 293 +++++++++++++++++++++ cpu/arm_cortexa8/mx51/iomux.c | 165 ++++++++++++ cpu/arm_cortexa8/mx51/lowlevel_init.S | 289 ++++++++++++++++++++ cpu/arm_cortexa8/mx51/soc.c | 109 ++++++++ cpu/arm_cortexa8/mx51/speed.c | 38 +++ cpu/arm_cortexa8/mx51/timer.c | 119 +++++++++ cpu/arm_cortexa8/mx51/u-boot.lds | 61 +++++ drivers/mmc/fsl_esdhc.c | 149 +++++++---- drivers/mmc/mmc.c | 17 ++- drivers/net/fec_mxc.c | 44 +++- drivers/net/fec_mxc.h | 32 +++- drivers/serial/serial_mxc.c | 28 ++- include/asm-arm/arch-mx25/clock.h | 36 +++ include/asm-arm/arch-mx25/imx-regs.h | 316 ++++++++++++++++++++++ include/asm-arm/arch-mx25/imx25-pinmux.h | 421 ++++++++++++++++++++++++++++++ include/asm-arm/arch-mx27/clock.h | 3 + include/asm-arm/arch-mx31/mx31.h | 1 + include/asm-arm/arch-mx51/asm-offsets.h | 50 ++++ include/asm-arm/arch-mx51/clock.h | 31 +++ include/asm-arm/arch-mx51/crm_regs.h | 192 ++++++++++++++ include/asm-arm/arch-mx51/imx-regs.h | 282 ++++++++++++++++++++ include/asm-arm/arch-mx51/iomux.h | 193 ++++++++++++++ include/asm-arm/arch-mx51/mx51_pins.h | 374 ++++++++++++++++++++++++++ include/asm-arm/global_data.h | 3 + include/asm-arm/io.h | 55 ++++ include/configs/mx51evk.h | 172 ++++++++++++ include/configs/tx25.h | 179 +++++++++++++ include/fsl_esdhc.h | 27 ++ include/mmc.h | 1 + lib_arm/board.c | 3 + nand_spl/board/karo/tx25/Makefile | 78 ++++++ nand_spl/board/karo/tx25/config.mk | 1 + nand_spl/board/karo/tx25/u-boot.lds | 58 ++++ 51 files changed, 5386 insertions(+), 68 deletions(-) create mode 100644 board/freescale/mx51evk/Makefile create mode 100644 board/freescale/mx51evk/config.mk create mode 100644 board/freescale/mx51evk/imximage.cfg create mode 100644 board/freescale/mx51evk/mx51evk.c create mode 100644 board/freescale/mx51evk/mx51evk.h create mode 100644 board/karo/tx25/Makefile create mode 100644 board/karo/tx25/config.mk create mode 100644 board/karo/tx25/lowlevel_init.S create mode 100644 board/karo/tx25/tx25.c create mode 100644 cpu/arm926ejs/mx25/Makefile create mode 100644 cpu/arm926ejs/mx25/generic.c create mode 100644 cpu/arm926ejs/mx25/reset.c create mode 100644 cpu/arm926ejs/mx25/timer.c create mode 100644 cpu/arm_cortexa8/mx51/Makefile create mode 100644 cpu/arm_cortexa8/mx51/clock.c create mode 100644 cpu/arm_cortexa8/mx51/iomux.c create mode 100644 cpu/arm_cortexa8/mx51/lowlevel_init.S create mode 100644 cpu/arm_cortexa8/mx51/soc.c create mode 100644 cpu/arm_cortexa8/mx51/speed.c create mode 100644 cpu/arm_cortexa8/mx51/timer.c create mode 100644 cpu/arm_cortexa8/mx51/u-boot.lds create mode 100644 include/asm-arm/arch-mx25/clock.h create mode 100644 include/asm-arm/arch-mx25/imx-regs.h create mode 100644 include/asm-arm/arch-mx25/imx25-pinmux.h create mode 100644 include/asm-arm/arch-mx51/asm-offsets.h create mode 100644 include/asm-arm/arch-mx51/clock.h create mode 100644 include/asm-arm/arch-mx51/crm_regs.h create mode 100644 include/asm-arm/arch-mx51/imx-regs.h create mode 100644 include/asm-arm/arch-mx51/iomux.h create mode 100644 include/asm-arm/arch-mx51/mx51_pins.h create mode 100644 include/configs/mx51evk.h create mode 100644 include/configs/tx25.h create mode 100644 nand_spl/board/karo/tx25/Makefile create mode 100644 nand_spl/board/karo/tx25/config.mk create mode 100644 nand_spl/board/karo/tx25/u-boot.lds
There are some compiler warnings. These should be resolved.
mx51evk.ERR
soc.c: In function 'print_cpuinfo': soc.c:68: warning: implicit declaration of function 'get_mcu_main_clk' soc.c: In function 'cpu_mmc_init': soc.c:99: warning: implicit declaration of function 'fsl_esdhc_mmc_init' clock.c:45: warning: initialization makes pointer from integer without a cast speed.c: In function 'get_clocks': speed.c:35: warning: implicit declaration of function 'mxc_get_clock' mx51evk.c: In function 'board_init': mx51evk.c:354: warning: implicit declaration of function 'get_cpu_rev'
Tom
Stefano Babic wrote:
Hi Tom,
Tom,
this is the updated pull-request for u-boot-imx. Warnings from mx51evk were removed and the magnesium board was added (acked by Wolfgang to get it in the release).
Heiko Schocher (2): arm, mx27: add support for SDHC1 pin init arm, i.mx27: add support for magnesium board from projectiondesign
MAINTAINERS | 12 + MAKEALL | 2 + Makefile | 9 + board/freescale/mx51evk/Makefile | 48 ++++ board/freescale/mx51evk/config.mk | 25 ++ board/freescale/mx51evk/imximage.cfg | 119 +++++++++ board/freescale/mx51evk/mx51evk.c | 397 ++++++++++++++++++++++++++++ board/freescale/mx51evk/mx51evk.h | 51 ++++ board/karo/tx25/Makefile | 51 ++++ board/karo/tx25/config.mk | 5 + board/karo/tx25/lowlevel_init.S | 131 +++++++++ board/karo/tx25/tx25.c | 176 +++++++++++++ board/logicpd/imx27lite/imx27lite.c | 18 ++- cpu/arm926ejs/mx25/Makefile | 46 ++++ cpu/arm926ejs/mx25/generic.c | 263 +++++++++++++++++++ cpu/arm926ejs/mx25/reset.c | 56 ++++ cpu/arm926ejs/mx25/timer.c | 187 +++++++++++++ cpu/arm926ejs/mx27/generic.c | 22 ++ cpu/arm_cortexa8/mx51/Makefile | 48 ++++ cpu/arm_cortexa8/mx51/clock.c | 294 +++++++++++++++++++++ cpu/arm_cortexa8/mx51/iomux.c | 166 ++++++++++++ cpu/arm_cortexa8/mx51/lowlevel_init.S | 288 ++++++++++++++++++++ cpu/arm_cortexa8/mx51/soc.c | 114 ++++++++ cpu/arm_cortexa8/mx51/speed.c | 39 +++ cpu/arm_cortexa8/mx51/timer.c | 119 +++++++++ cpu/arm_cortexa8/mx51/u-boot.lds | 61 +++++ drivers/mmc/fsl_esdhc.c | 149 +++++++---- drivers/mmc/mmc.c | 17 ++- drivers/net/fec_mxc.c | 44 +++- drivers/net/fec_mxc.h | 32 +++- drivers/serial/serial_mxc.c | 28 ++- include/asm-arm/arch-mx25/clock.h | 36 +++ include/asm-arm/arch-mx25/imx-regs.h | 316 ++++++++++++++++++++++ include/asm-arm/arch-mx27/imx-regs.h | 1 + include/asm-arm/arch-mx31/mx31.h | 1 + include/asm-arm/arch-mx51/asm-offsets.h | 50 ++++ include/asm-arm/arch-mx51/clock.h | 43 +++ include/asm-arm/arch-mx51/crm_regs.h | 192 ++++++++++++++ include/asm-arm/arch-mx51/imx-regs.h | 261 ++++++++++++++++++ include/asm-arm/arch-mx51/iomux.h | 193 ++++++++++++++ include/asm-arm/arch-mx51/mx51_pins.h | 374 ++++++++++++++++++++++++++ include/asm-arm/arch-mx51/sys_proto.h | 30 +++ include/asm-arm/global_data.h | 3 + include/asm-arm/io.h | 55 ++++ include/configs/imx27lite-common.h | 237 +++++++++++++++++ include/configs/imx27lite.h | 200 +-------------- include/configs/magnesium.h | 71 +++++ include/configs/mx51evk.h | 172 ++++++++++++ include/configs/tx25.h | 179 +++++++++++++ include/fsl_esdhc.h | 27 ++ include/mmc.h | 1 + lib_arm/board.c | 3 + nand_spl/board/karo/tx25/Makefile | 78 ++++++ nand_spl/board/karo/tx25/config.mk | 1 + nand_spl/board/karo/tx25/u-boot.lds | 58 ++++ 57 files changed, 5758 insertions(+), 265 deletions(-) create mode 100644 board/freescale/mx51evk/Makefile create mode 100644 board/freescale/mx51evk/config.mk create mode 100644 board/freescale/mx51evk/imximage.cfg create mode 100644 board/freescale/mx51evk/mx51evk.c create mode 100644 board/freescale/mx51evk/mx51evk.h create mode 100644 board/karo/tx25/Makefile create mode 100644 board/karo/tx25/config.mk create mode 100644 board/karo/tx25/lowlevel_init.S create mode 100644 board/karo/tx25/tx25.c create mode 100644 cpu/arm926ejs/mx25/Makefile create mode 100644 cpu/arm926ejs/mx25/generic.c create mode 100644 cpu/arm926ejs/mx25/reset.c create mode 100644 cpu/arm926ejs/mx25/timer.c create mode 100644 cpu/arm_cortexa8/mx51/Makefile create mode 100644 cpu/arm_cortexa8/mx51/clock.c create mode 100644 cpu/arm_cortexa8/mx51/iomux.c create mode 100644 cpu/arm_cortexa8/mx51/lowlevel_init.S create mode 100644 cpu/arm_cortexa8/mx51/soc.c create mode 100644 cpu/arm_cortexa8/mx51/speed.c create mode 100644 cpu/arm_cortexa8/mx51/timer.c create mode 100644 cpu/arm_cortexa8/mx51/u-boot.lds create mode 100644 include/asm-arm/arch-mx25/clock.h create mode 100644 include/asm-arm/arch-mx25/imx-regs.h create mode 100644 include/asm-arm/arch-mx25/imx25-pinmux.h create mode 100644 include/asm-arm/arch-mx51/asm-offsets.h create mode 100644 include/asm-arm/arch-mx51/clock.h create mode 100644 include/asm-arm/arch-mx51/crm_regs.h create mode 100644 include/asm-arm/arch-mx51/imx-regs.h create mode 100644 include/asm-arm/arch-mx51/iomux.h create mode 100644 include/asm-arm/arch-mx51/mx51_pins.h create mode 100644 include/asm-arm/arch-mx51/sys_proto.h create mode 100644 include/configs/imx27lite-common.h create mode 100644 include/configs/magnesium.h create mode 100644 include/configs/mx51evk.h create mode 100644 include/configs/tx25.h create mode 100644 nand_spl/board/karo/tx25/Makefile create mode 100644 nand_spl/board/karo/tx25/config.mk create mode 100644 nand_spl/board/karo/tx25/u-boot.lds
Tom,
this is the pull request after you have already merged part of u-boot-imx.
The following changes since commit 75b464b721408cd8b26ba92a249f0726f37c7249: John Rigby (1): Add support for KARO TX25 board
Stefano Babic (1): MX51: removed warnings for the mx51evk
MAINTAINERS | 4 + MAKEALL | 1 + Makefile | 1 + board/freescale/mx51evk/mx51evk.c | 11 +-- board/logicpd/imx27lite/imx27lite.c | 18 +++- cpu/arm926ejs/mx27/generic.c | 17 +++ cpu/arm_cortexa8/mx51/clock.c | 3 +- cpu/arm_cortexa8/mx51/iomux.c | 1 + cpu/arm_cortexa8/mx51/lowlevel_init.S | 1 - cpu/arm_cortexa8/mx51/soc.c | 7 +- cpu/arm_cortexa8/mx51/speed.c | 1 + include/asm-arm/arch-mx27/imx-regs.h | 1 + include/asm-arm/arch-mx51/clock.h | 16 ++- include/asm-arm/arch-mx51/imx-regs.h | 21 --- include/asm-arm/arch-mx51/sys_proto.h | 30 ++++ include/configs/imx27lite-common.h | 237 +++++++++++++++++++++++++++++++++ include/configs/imx27lite.h | 200 +--------------------------- include/configs/magnesium.h | 71 ++++++++++ 18 files changed, 408 insertions(+), 233 deletions(-) create mode 100644 include/asm-arm/arch-mx51/sys_proto.h create mode 100644 include/configs/imx27lite-common.h create mode 100644 include/configs/magnesium.h
Thanks, Stefano
Hi Tom,
This has been applied to ARM/master The fixes for the warning expected but not required. Thanks, Tom
Thanks, Tom. You are faster as I can send a git-pull-request ;)
In fact, I have an hour ago updated the u-boot-imx branch, pulling the modified patches to remove warnings (patches was sent for small review yesterday, I have waited a while to be sure). Is there a chance to take the updated u-boot-imx branch or I have to send patches on top of arm master ?
Stefano
Stefano
I think the best thing to do is to send me a pull request soon when you think the imx branch is in good shape. I noticed, but did not apply, some of the imx changes that came after your first pull request. These should be included in the next pull request.
I will send Wolfgang a pull request soon (this weekend) so if there is something that needs to get into the main release, please send me a request today or at the latest tomorrow.
Tom
Ok, thanks. I send you the pull request.
Stefano
Stefano Babic
Tom
