[U-Boot-Users] get_timer versus get_ticks
Hello,
I am currently straightening out lib-mips/time.c to make its granularity defined by CFG_HZ (=1000) instead of the processors frequency at which MIPS counters normally run.
Can somebody explain me what the difference between get_timer and get_ticks is? Get_timer returns the current value of the timer in 1/CFG_HZ units, as I would expect. I would expect get_ticks to return the raw counter value, but that value would useless because theres no way to tell what speed its running at: get_tbclk is returning CFG_HZ and not the actual counter incremental frequency. In common/main.c get_ticks is used in conjuction with get_tbclk as if it were get_timer. This indicates either get_tbclk should be returning the actual counter incremental frequency, or get_ticks to return the same value as get_timer(0).
I have looked at the PPC implementation, but that wasnt of much help because there a hardware time base is used so that solution always correct.
Thanks in advance!
With kind regards,
Robert.
Robert Deliën
