[U-Boot] sunxi: SPI: reset bus when enabling clock
Hi all,
The sun6i SPI peripheral needs to be reset before it can be used. Add the necessary offset #defines and perform this reset.
Applies to the allwinner-spi head on the u-boot-spi tree. Tested on Orange Pi R1 (Allwinner H2+ / sun8i) and successfully booted from SPI
Thanks,
Signed-off-by: Fahad Sadah fahad@sadah.uk
Fahad Sadah (2): sunxi: SPI: add AHB gate and reset offsets sunxi: SPI: reset bus when enabling clock
arch/arm/include/asm/arch-sunxi/clock_sun6i.h | 4 ++++ drivers/spi/sun6i_spi.c | 1 + 2 files changed, 5 insertions(+)
--- arch/arm/include/asm/arch-sunxi/clock_sun6i.h | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/arch/arm/include/asm/arch-sunxi/clock_sun6i.h b/arch/arm/include/asm/arch-sunxi/clock_sun6i.h index d328df9597..71a1673fa8 100644 --- a/arch/arm/include/asm/arch-sunxi/clock_sun6i.h +++ b/arch/arm/include/asm/arch-sunxi/clock_sun6i.h @@ -290,6 +290,8 @@ struct sunxi_ccm_reg { #define AHB_GATE_OFFSET_USB0 25 #define AHB_GATE_OFFSET_SATA 24 #endif +#define AHB_GATE_OFFSET_SPI1 21 +#define AHB_GATE_OFFSET_SPI0 20 #define AHB_GATE_OFFSET_MCTL 14 #define AHB_GATE_OFFSET_GMAC 17 #define AHB_GATE_OFFSET_NAND0 13 @@ -436,6 +438,8 @@ struct sunxi_ccm_reg { #ifdef CONFIG_MACH_SUN8I_R40 #define AHB_RESET_OFFSET_SATA 24 #endif +#define AHB_RESET_OFFSET_SPI1 21 +#define AHB_RESET_OFFSET_SPI0 20 #define AHB_RESET_OFFSET_GMAC 17 #define AHB_RESET_OFFSET_MCTL 14 #define AHB_RESET_OFFSET_MMC3 11
--- drivers/spi/sun6i_spi.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/drivers/spi/sun6i_spi.c b/drivers/spi/sun6i_spi.c index 3192548e83..3c6a13e40e 100644 --- a/drivers/spi/sun6i_spi.c +++ b/drivers/spi/sun6i_spi.c @@ -215,6 +215,7 @@ static inline void sun6i_spi_enable_clock(void) struct sunxi_ccm_reg *const ccm = (struct sunxi_ccm_reg *const)SUNXI_CCM_BASE;
+ setbits_le32(&ccm->ahb_reset0_cfg, (1 << AHB_RESET_OFFSET_SPI0)); setbits_le32(&ccm->ahb_gate0, (1 << AHB_GATE_OFFSET_SPI0)); writel((1 << 31), &ccm->spi0_clk_cfg); }
Fahad Sadah
