[U-Boot] [PATCH] powerpc/8xxx: Fix compile warning when build for a DDR1 or DDR2 board
ctrl_regs.c: In function 'set_ddr_sdram_mode_2': ctrl_regs.c:690:6: warning: unused variable 'i'
'i' is only used by DDR3 code.
Signed-off-by: Kumar Gala galak@kernel.crashing.org --- arch/powerpc/cpu/mpc8xxx/ddr/ctrl_regs.c | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/arch/powerpc/cpu/mpc8xxx/ddr/ctrl_regs.c b/arch/powerpc/cpu/mpc8xxx/ddr/ctrl_regs.c index 2271071..c3e1d76 100644 --- a/arch/powerpc/cpu/mpc8xxx/ddr/ctrl_regs.c +++ b/arch/powerpc/cpu/mpc8xxx/ddr/ctrl_regs.c @@ -687,9 +687,9 @@ static void set_ddr_sdram_mode_2(fsl_ddr_cfg_regs_t *ddr, { unsigned short esdmode2 = 0; /* Extended SDRAM mode 2 */ unsigned short esdmode3 = 0; /* Extended SDRAM mode 3 */ - int i;
#if defined(CONFIG_FSL_DDR3) + int i; unsigned int rtt_wr = 0; /* Rtt_WR - dynamic ODT off */ unsigned int srt = 0; /* self-refresh temerature, normal range */ unsigned int asr = 0; /* auto self-refresh disable */
applied
- k
Kumar Gala
