[U-Boot] [PATCH] socfpga: Adding Freeze Controller driver
Adding Freeze Controller driver. All HPS IOs need to be in freeze state during pin mux or IO buffer configuration. It is to avoid any glitch which might happen during the configuration from propagating to external devices.
Signed-off-by: Chin Liang See clsee@altera.com Cc: Wolfgang Denk wd@denx.de CC: Pavel Machek pavel@denx.de Cc: Dinh Nguyen dinguyen@altera.com --- arch/arm/cpu/armv7/socfpga/Makefile | 2 +- arch/arm/cpu/armv7/socfpga/freeze_controller.c | 321 ++++++++++++++++++++ arch/arm/cpu/armv7/socfpga/spl.c | 16 + arch/arm/cpu/armv7/socfpga/timer.c | 35 +++ .../include/asm/arch-socfpga/freeze_controller.h | 71 +++++ arch/arm/include/asm/arch-socfpga/timer.h | 3 + 6 files changed, 447 insertions(+), 1 deletion(-) create mode 100644 arch/arm/cpu/armv7/socfpga/freeze_controller.c create mode 100644 arch/arm/include/asm/arch-socfpga/freeze_controller.h
diff --git a/arch/arm/cpu/armv7/socfpga/Makefile b/arch/arm/cpu/armv7/socfpga/Makefile index 0859e44..10d20f2 100644 --- a/arch/arm/cpu/armv7/socfpga/Makefile +++ b/arch/arm/cpu/armv7/socfpga/Makefile @@ -14,7 +14,7 @@ LIB = $(obj)lib$(SOC).o
SOBJS := lowlevel_init.o COBJS-y := misc.o timer.o reset_manager.o system_manager.o -COBJS-$(CONFIG_SPL_BUILD) += spl.o +COBJS-$(CONFIG_SPL_BUILD) += spl.o freeze_controller.o
COBJS := $(COBJS-y) SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) diff --git a/arch/arm/cpu/armv7/socfpga/freeze_controller.c b/arch/arm/cpu/armv7/socfpga/freeze_controller.c new file mode 100644 index 0000000..af612c9 --- /dev/null +++ b/arch/arm/cpu/armv7/socfpga/freeze_controller.c @@ -0,0 +1,321 @@ +/* + * Copyright (C) 2013 Altera Corporation <www.altera.com> + * + * SPDX-License-Identifier: GPL-2.0+ + */ + + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/freeze_controller.h> +#include <asm/arch/timer.h> + +DECLARE_GLOBAL_DATA_PTR; + +static const struct socfpga_freeze_controller *freeze_controller_base = + (void *)(SOCFPGA_SYSMGR_ADDRESS + SYSMGR_FRZCTRL_ADDRESS); + +/* + * Default state from cold reset is FREEZE_ALL; the global + * flag is set to TRUE to indicate the IO banks are frozen + */ +static uint32_t frzctrl_channel_freeze[FREEZE_CHANNEL_NUM] + = { FREEZE_CTRL_FROZEN, FREEZE_CTRL_FROZEN, + FREEZE_CTRL_FROZEN, FREEZE_CTRL_FROZEN}; + +/* Get current state of freeze channel 1 (VIO) */ +static inline u32 sys_mgr_frzctrl_frzchn1_state_get(void) +{ + u32 frzchn1_state; + frzchn1_state = readl(&freeze_controller_base->hwctrl); + frzchn1_state = SYSMGR_FRZCTRL_HWCTRL_VIO1STATE_GET(frzchn1_state); + return frzchn1_state; +} + +/* Freeze HPS IOs */ +u32 sys_mgr_frzctrl_freeze_req(FreezeChannelSelect channel_id, + FreezeControllerFSMSelect fsm_select) +{ + u32 frzctrl_ioctrl_reg_offset; + u32 frzctrl_reg_value; + u32 frzctrl_reg_cfg_mask; + u32 i; + + if (FREEZE_CONTROLLER_FSM_SW == fsm_select) { + + /* select software FSM */ + writel(SYSMGR_FRZCTRL_SRC_VIO1_ENUM_SW, + &freeze_controller_base->src); + + /* Freeze channel ID checking and base address */ + switch (channel_id) { + case FREEZE_CHANNEL_0: + case FREEZE_CHANNEL_1: + case FREEZE_CHANNEL_2: + frzctrl_ioctrl_reg_offset = (u32)( + &freeze_controller_base->vioctrl + + (channel_id << SYSMGR_FRZCTRL_VIOCTRL_SHIFT)); + + /* + * Assert active low enrnsl, plniotri + * and niotri signals + */ + frzctrl_reg_cfg_mask = + SYSMGR_FRZCTRL_VIOCTRL_SLEW_MASK + | SYSMGR_FRZCTRL_VIOCTRL_WKPULLUP_MASK + | SYSMGR_FRZCTRL_VIOCTRL_TRISTATE_MASK; + clrbits_le32(frzctrl_ioctrl_reg_offset, + frzctrl_reg_cfg_mask); + + /* + * Note: Delay for 20ns at min + * Assert active low bhniotri signal and de-assert + * active high csrdone + */ + frzctrl_reg_cfg_mask + = SYSMGR_FRZCTRL_VIOCTRL_BUSHOLD_MASK + | SYSMGR_FRZCTRL_VIOCTRL_CFG_MASK; + clrbits_le32(frzctrl_ioctrl_reg_offset, + frzctrl_reg_cfg_mask); + + /* Set global flag to indicate channel is frozen */ + frzctrl_channel_freeze[channel_id] = + FREEZE_CTRL_FROZEN; + break; + + case FREEZE_CHANNEL_3: + /* + * Assert active low enrnsl, plniotri and + * niotri signals + */ + frzctrl_reg_cfg_mask + = SYSMGR_FRZCTRL_HIOCTRL_SLEW_MASK + | SYSMGR_FRZCTRL_HIOCTRL_WKPULLUP_MASK + | SYSMGR_FRZCTRL_HIOCTRL_TRISTATE_MASK; + clrbits_le32(&freeze_controller_base->hioctrl, + frzctrl_reg_cfg_mask); + + /* + * Note: Delay for 40ns at min + * assert active low bhniotri & nfrzdrv signals, + * de-assert active high csrdone and assert + * active high frzreg and nfrzdrv signals + */ + frzctrl_reg_value = + readl(&freeze_controller_base->hioctrl); + frzctrl_reg_cfg_mask + = SYSMGR_FRZCTRL_HIOCTRL_BUSHOLD_MASK + | SYSMGR_FRZCTRL_HIOCTRL_CFG_MASK; + frzctrl_reg_value + = (frzctrl_reg_value & ~frzctrl_reg_cfg_mask) + | SYSMGR_FRZCTRL_HIOCTRL_REGRST_MASK + | SYSMGR_FRZCTRL_HIOCTRL_OCTRST_MASK; + writel(frzctrl_reg_value, + &freeze_controller_base->hioctrl); + + /* + * Note: Delay for 40ns at min + * assert active high reinit signal and de-assert + * active high pllbiasen signals + */ + frzctrl_reg_value = + readl(&freeze_controller_base->hioctrl); + frzctrl_reg_value + = (frzctrl_reg_value & + ~SYSMGR_FRZCTRL_HIOCTRL_OCT_CFGEN_CALSTART_MASK) + | SYSMGR_FRZCTRL_HIOCTRL_DLLRST_MASK; + writel(frzctrl_reg_value, + &freeze_controller_base->hioctrl); + + /* Set global flag to indicate channel is frozen */ + frzctrl_channel_freeze[channel_id] = + FREEZE_CTRL_FROZEN; + break; + + default: + return 1; + } + } else if (FREEZE_CONTROLLER_FSM_HW == fsm_select) { + + /* select hardware FSM */ + writel(SYSMGR_FRZCTRL_SRC_VIO1_ENUM_HW, + &freeze_controller_base->src); + + /* write to hwctrl reg to enable freeze req */ + setbits_le32(&freeze_controller_base->hwctrl, + SYSMGR_FRZCTRL_HWCTRL_VIO1REQ_MASK); + + i = 0; + while (SYSMGR_FRZCTRL_HWCTRL_VIO1STATE_ENUM_FROZEN + != sys_mgr_frzctrl_frzchn1_state_get()) { + i++; + if (SYSMGR_FRZCTRL_LOOP_PARAM < i) + return 1; + } /* while ( not frozen) */ + + /* Set global flag to indicate channel is frozen */ + frzctrl_channel_freeze[channel_id] = FREEZE_CTRL_FROZEN; + } else { + return 1; + } /* if-else (fsm_select) */ + + return 0; +} + +/* Unfreeze/Thaw HPS IOs */ +u32 sys_mgr_frzctrl_thaw_req(FreezeChannelSelect channel_id, + FreezeControllerFSMSelect fsm_select) +{ + u32 frzctrl_ioctrl_reg_offset; + u32 frzctrl_reg_cfg_mask; + u32 frzctrl_reg_value; + u32 i; + u32 start_count, clk_cycles_count; + + if (FREEZE_CONTROLLER_FSM_SW == fsm_select) { + /* select software FSM */ + writel(SYSMGR_FRZCTRL_SRC_VIO1_ENUM_SW, + &freeze_controller_base->src); + + /* Freeze channel ID checking and base address */ + switch (channel_id) { + case FREEZE_CHANNEL_0: + case FREEZE_CHANNEL_1: + case FREEZE_CHANNEL_2: + frzctrl_ioctrl_reg_offset + = (u32)(&freeze_controller_base->vioctrl + + (channel_id << SYSMGR_FRZCTRL_VIOCTRL_SHIFT)); + + /* + * Assert active low bhniotri signal and + * de-assert active high csrdone + */ + frzctrl_reg_cfg_mask + = SYSMGR_FRZCTRL_VIOCTRL_BUSHOLD_MASK + | SYSMGR_FRZCTRL_VIOCTRL_CFG_MASK; + setbits_le32(frzctrl_ioctrl_reg_offset, + frzctrl_reg_cfg_mask); + + /* + * Note: Delay for 20ns at min + * de-assert active low plniotri and niotri signals + */ + frzctrl_reg_cfg_mask + = SYSMGR_FRZCTRL_VIOCTRL_WKPULLUP_MASK + | SYSMGR_FRZCTRL_VIOCTRL_TRISTATE_MASK; + setbits_le32(frzctrl_ioctrl_reg_offset, + frzctrl_reg_cfg_mask); + + /* + * Note: Delay for 20ns at min + * de-assert active low enrnsl signal + */ + setbits_le32(frzctrl_ioctrl_reg_offset, + SYSMGR_FRZCTRL_VIOCTRL_SLEW_MASK); + + /* Set global flag to indicate channel is thawed */ + frzctrl_channel_freeze[channel_id] = FREEZE_CTRL_THAWED; + + break; + + case FREEZE_CHANNEL_3: + /* de-assert active high reinit signal */ + clrbits_le32(&freeze_controller_base->hioctrl, + SYSMGR_FRZCTRL_HIOCTRL_DLLRST_MASK); + + /* + * Note: Delay for 40ns at min + * assert active high pllbiasen signals + */ + setbits_le32(&freeze_controller_base->hioctrl, + SYSMGR_FRZCTRL_HIOCTRL_OCT_CFGEN_CALSTART_MASK); + + /* Delay 1000 intosc. intosc is based on eosc1 */ + reset_timer_count(); + start_count = get_timer_count(0); + + do { + clk_cycles_count = + get_timer_count(start_count); + } while (clk_cycles_count < + SYSMGR_FRZCTRL_INTOSC_1000); + + /* + * de-assert active low bhniotri signals, + * assert active high csrdone and nfrzdrv signal + */ + frzctrl_reg_value = readl(&freeze_controller_base->hioctrl); + frzctrl_reg_value = (frzctrl_reg_value + | SYSMGR_FRZCTRL_HIOCTRL_BUSHOLD_MASK + | SYSMGR_FRZCTRL_HIOCTRL_CFG_MASK) + & ~SYSMGR_FRZCTRL_HIOCTRL_OCTRST_MASK; + writel(frzctrl_reg_value, &freeze_controller_base->hioctrl); + + /* Delay 33 intosc */ + reset_timer_count(); + start_count = get_timer_count(0); + + do { + clk_cycles_count = + get_timer_count(start_count); + } while (clk_cycles_count < + SYSMGR_FRZCTRL_INTOSC_33); + + /* de-assert active low plniotri and niotri signals */ + frzctrl_reg_cfg_mask + = SYSMGR_FRZCTRL_HIOCTRL_WKPULLUP_MASK + | SYSMGR_FRZCTRL_HIOCTRL_TRISTATE_MASK; + + setbits_le32(&freeze_controller_base->hioctrl, + frzctrl_reg_cfg_mask); + + /* + * Note: Delay for 40ns at min + * de-assert active high frzreg signal + */ + clrbits_le32(&freeze_controller_base->hioctrl, + SYSMGR_FRZCTRL_HIOCTRL_REGRST_MASK); + + /* + * Note: Delay for 40ns at min + * de-assert active low enrnsl signal + */ + setbits_le32(&freeze_controller_base->hioctrl, + SYSMGR_FRZCTRL_HIOCTRL_SLEW_MASK); + + /* Set global flag to indicate channel is thawed */ + frzctrl_channel_freeze[channel_id] = FREEZE_CTRL_THAWED; + + break; + + default: + return 1; + } + + } else if (FREEZE_CONTROLLER_FSM_HW == fsm_select) { + + /* select hardware FSM */ + writel(SYSMGR_FRZCTRL_SRC_VIO1_ENUM_HW, + &freeze_controller_base->src); + + /* write to hwctrl reg to enable thaw req; 0: thaw */ + clrbits_le32(&freeze_controller_base->hwctrl, + SYSMGR_FRZCTRL_HWCTRL_VIO1REQ_MASK); + + i = 0; + while (SYSMGR_FRZCTRL_HWCTRL_VIO1STATE_ENUM_THAWED + != sys_mgr_frzctrl_frzchn1_state_get()) { + i++; + if (SYSMGR_FRZCTRL_LOOP_PARAM < i) + return 1; + } /* while (not thaw) */ + + /* Set global flag to indicate channel is thawed */ + frzctrl_channel_freeze[channel_id] = FREEZE_CTRL_THAWED; + } else { + return 1; + } /* if-else (fsm_select) */ + + return 0; +} + diff --git a/arch/arm/cpu/armv7/socfpga/spl.c b/arch/arm/cpu/armv7/socfpga/spl.c index 74bceab..5173c0d 100644 --- a/arch/arm/cpu/armv7/socfpga/spl.c +++ b/arch/arm/cpu/armv7/socfpga/spl.c @@ -13,6 +13,8 @@ #include <asm/arch/reset_manager.h> #include <spl.h> #include <asm/arch/system_manager.h> +#include <asm/arch/freeze_controller.h> +
@@ -27,6 +29,13 @@ u32 spl_boot_device(void) void spl_board_init(void) { #ifndef CONFIG_SOCFPGA_VIRTUAL_TARGET + debug("Freezing all I/O banks\n"); + /* freeze all IO banks */ + sys_mgr_frzctrl_freeze_req(FREEZE_CHANNEL_0, FREEZE_CONTROLLER_FSM_SW); + sys_mgr_frzctrl_freeze_req(FREEZE_CHANNEL_1, FREEZE_CONTROLLER_FSM_SW); + sys_mgr_frzctrl_freeze_req(FREEZE_CHANNEL_2, FREEZE_CONTROLLER_FSM_SW); + sys_mgr_frzctrl_freeze_req(FREEZE_CHANNEL_3, FREEZE_CONTROLLER_FSM_SW); + /* configure the pin muxing through system manager */ sysmgr_pinmux_init(); #endif /* CONFIG_SOCFPGA_VIRTUAL_TARGET */ @@ -34,6 +43,13 @@ void spl_board_init(void) /* de-assert reset for peripherals and bridges based on handoff */ reset_deassert_peripherals_handoff();
+ debug("Unfreezing/Thaw all I/O banks\n"); + /* unfreeze / thaw all IO banks */ + sys_mgr_frzctrl_thaw_req(FREEZE_CHANNEL_0, FREEZE_CONTROLLER_FSM_SW); + sys_mgr_frzctrl_thaw_req(FREEZE_CHANNEL_1, FREEZE_CONTROLLER_FSM_SW); + sys_mgr_frzctrl_thaw_req(FREEZE_CHANNEL_2, FREEZE_CONTROLLER_FSM_SW); + sys_mgr_frzctrl_thaw_req(FREEZE_CHANNEL_3, FREEZE_CONTROLLER_FSM_SW); + /* enable console uart printing */ preloader_console_init(); } diff --git a/arch/arm/cpu/armv7/socfpga/timer.c b/arch/arm/cpu/armv7/socfpga/timer.c index 09f6f14..fb1282a 100644 --- a/arch/arm/cpu/armv7/socfpga/timer.c +++ b/arch/arm/cpu/armv7/socfpga/timer.c @@ -92,3 +92,38 @@ void reset_timer(void) /* start "advancing" time stamp from 0 */ gd->arch.tbl = 0; } + +/* Get the timer count value */ +ulong get_timer_count_masked(void) +{ + /* current tick value */ + ulong now = read_timer(); + if (gd->arch.lastinc >= now) { + /* + * normal mode (non roll) + * move stamp forward with absolute diff ticks + */ + gd->arch.tbl += gd->arch.lastinc - now; + } else { + /* we have overflow of the count down timer */ + gd->arch.tbl += TIMER_LOAD_VAL - gd->arch.lastinc + now; + } + gd->arch.lastinc = now; + return gd->arch.tbl; +} + +ulong get_timer_count(ulong base) +{ + return get_timer_count_masked() - base; +} + +/* + * Reset the timer + */ +void reset_timer_count(void) +{ + /* capure current decrementer value time */ + gd->arch.lastinc = read_timer(); + /* start "advancing" time stamp from 0 */ + gd->arch.tbl = 0; +} diff --git a/arch/arm/include/asm/arch-socfpga/freeze_controller.h b/arch/arm/include/asm/arch-socfpga/freeze_controller.h new file mode 100644 index 0000000..b25ff99 --- /dev/null +++ b/arch/arm/include/asm/arch-socfpga/freeze_controller.h @@ -0,0 +1,71 @@ +/* + * Copyright (C) 2013 Altera Corporation <www.altera.com> + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef _FREEZE_CONTROLLER_H_ +#define _FREEZE_CONTROLLER_H_ + +struct socfpga_freeze_controller { + u32 vioctrl; + u32 padding[3]; + u32 hioctrl; + u32 src; + u32 hwctrl; +}; + +#define SYSMGR_FRZCTRL_LOOP_PARAM (1000) +#define SYSMGR_FRZCTRL_DELAY_LOOP_PARAM (10) +#define SYSMGR_FRZCTRL_INTOSC_33 (33) +#define SYSMGR_FRZCTRL_INTOSC_1000 (1000) +#define FREEZE_CHANNEL_NUM (4) + +typedef enum { + FREEZE_CTRL_FROZEN = 0, + FREEZE_CTRL_THAWED = 1 +} FREEZE_CTRL_CHAN_STATE; + +typedef enum { + FREEZE_CHANNEL_0 = 0, /* EMAC_IO & MIXED2_IO */ + FREEZE_CHANNEL_1, /* MIXED1_IO and FLASH_IO */ + FREEZE_CHANNEL_2, /* General IO */ + FREEZE_CHANNEL_3, /* DDR IO */ + FREEZE_CHANNEL_UNDEFINED +} FreezeChannelSelect; + +typedef enum { + FREEZE_CONTROLLER_FSM_SW = 0, + FREEZE_CONTROLLER_FSM_HW, + FREEZE_CONTROLLER_FSM_UNDEFINED +} FreezeControllerFSMSelect; + +#define SYSMGR_FRZCTRL_ADDRESS 0x40 +#define SYSMGR_FRZCTRL_SRC_VIO1_ENUM_SW 0x0 +#define SYSMGR_FRZCTRL_SRC_VIO1_ENUM_HW 0x1 +#define SYSMGR_FRZCTRL_VIOCTRL_SLEW_MASK 0x00000010 +#define SYSMGR_FRZCTRL_VIOCTRL_WKPULLUP_MASK 0x00000008 +#define SYSMGR_FRZCTRL_VIOCTRL_TRISTATE_MASK 0x00000004 +#define SYSMGR_FRZCTRL_VIOCTRL_BUSHOLD_MASK 0x00000002 +#define SYSMGR_FRZCTRL_VIOCTRL_CFG_MASK 0x00000001 +#define SYSMGR_FRZCTRL_HIOCTRL_SLEW_MASK 0x00000010 +#define SYSMGR_FRZCTRL_HIOCTRL_WKPULLUP_MASK 0x00000008 +#define SYSMGR_FRZCTRL_HIOCTRL_TRISTATE_MASK 0x00000004 +#define SYSMGR_FRZCTRL_HIOCTRL_BUSHOLD_MASK 0x00000002 +#define SYSMGR_FRZCTRL_HIOCTRL_CFG_MASK 0x00000001 +#define SYSMGR_FRZCTRL_HIOCTRL_REGRST_MASK 0x00000080 +#define SYSMGR_FRZCTRL_HIOCTRL_OCTRST_MASK 0x00000040 +#define SYSMGR_FRZCTRL_HIOCTRL_OCT_CFGEN_CALSTART_MASK 0x00000100 +#define SYSMGR_FRZCTRL_HIOCTRL_DLLRST_MASK 0x00000020 +#define SYSMGR_FRZCTRL_HWCTRL_VIO1REQ_MASK 0x00000001 +#define SYSMGR_FRZCTRL_HWCTRL_VIO1STATE_ENUM_FROZEN 0x2 +#define SYSMGR_FRZCTRL_HWCTRL_VIO1STATE_ENUM_THAWED 0x1 +#define SYSMGR_FRZCTRL_HWCTRL_VIO1STATE_GET(x) (((x) & 0x00000006) >> 1) +#define SYSMGR_FRZCTRL_VIOCTRL_SHIFT 0x2 + +u32 sys_mgr_frzctrl_freeze_req(FreezeChannelSelect channel_id, + FreezeControllerFSMSelect fsm_select); +u32 sys_mgr_frzctrl_thaw_req(FreezeChannelSelect channel_id, + FreezeControllerFSMSelect fsm_select); + +#endif /* _FREEZE_CONTROLLER_H_ */ diff --git a/arch/arm/include/asm/arch-socfpga/timer.h b/arch/arm/include/asm/arch-socfpga/timer.h index ee6969b..de2f718 100644 --- a/arch/arm/include/asm/arch-socfpga/timer.h +++ b/arch/arm/include/asm/arch-socfpga/timer.h @@ -15,4 +15,7 @@ struct socfpga_timer { u32 int_stat; };
+ulong get_timer_count(ulong base); +void reset_timer_count(void); + #endif
Hi!
Thanks for the patch.
(What version is it against? Aha, it depends on previous patches, right?)
AFAICT:
FREEZE_CONTROLLER_FSM_HW is unused and can be removed.
frzctrl_channel_freeze[] is write-only and can be removed.
Local variables do not need frzctrl_ prefix.
[I have fixed those, suggested incremental diff is attached. Please review & apply to your tree.]
Is it really neccessary to introduce get_timer_count_masked? Replace the delays with udelay(1) and it should still work?
Thanks, Pavel
diff --git a/arch/arm/cpu/armv7/socfpga/freeze_controller.c b/arch/arm/cpu/armv7/socfpga/freeze_controller.c index af612c9..058d9b5 100644 --- a/arch/arm/cpu/armv7/socfpga/freeze_controller.c +++ b/arch/arm/cpu/armv7/socfpga/freeze_controller.c @@ -9,226 +9,183 @@ #include <asm/io.h> #include <asm/arch/freeze_controller.h> #include <asm/arch/timer.h> +#include <asm/errno.h>
+ + static const struct socfpga_freeze_controller *freeze_controller_base = (void *)(SOCFPGA_SYSMGR_ADDRESS + SYSMGR_FRZCTRL_ADDRESS);
-/* - * Default state from cold reset is FREEZE_ALL; the global - * flag is set to TRUE to indicate the IO banks are frozen - */ -static uint32_t frzctrl_channel_freeze[FREEZE_CHANNEL_NUM] - = { FREEZE_CTRL_FROZEN, FREEZE_CTRL_FROZEN, - FREEZE_CTRL_FROZEN, FREEZE_CTRL_FROZEN}; - -/* Get current state of freeze channel 1 (VIO) */ -static inline u32 sys_mgr_frzctrl_frzchn1_state_get(void) -{ - u32 frzchn1_state; - frzchn1_state = readl(&freeze_controller_base->hwctrl); - frzchn1_state = SYSMGR_FRZCTRL_HWCTRL_VIO1STATE_GET(frzchn1_state); - return frzchn1_state; -}
/* Freeze HPS IOs */ u32 sys_mgr_frzctrl_freeze_req(FreezeChannelSelect channel_id, - FreezeControllerFSMSelect fsm_select) + FreezeControllerFSMSelect fsm_select) { - u32 frzctrl_ioctrl_reg_offset; - u32 frzctrl_reg_value; - u32 frzctrl_reg_cfg_mask; + u32 ioctrl_reg_offset; + u32 reg_value; + u32 reg_cfg_mask; u32 i;
- if (FREEZE_CONTROLLER_FSM_SW == fsm_select) { - - /* select software FSM */ - writel(SYSMGR_FRZCTRL_SRC_VIO1_ENUM_SW, - &freeze_controller_base->src); - - /* Freeze channel ID checking and base address */ - switch (channel_id) { - case FREEZE_CHANNEL_0: - case FREEZE_CHANNEL_1: - case FREEZE_CHANNEL_2: - frzctrl_ioctrl_reg_offset = (u32)( - &freeze_controller_base->vioctrl + - (channel_id << SYSMGR_FRZCTRL_VIOCTRL_SHIFT)); - - /* - * Assert active low enrnsl, plniotri - * and niotri signals - */ - frzctrl_reg_cfg_mask = - SYSMGR_FRZCTRL_VIOCTRL_SLEW_MASK - | SYSMGR_FRZCTRL_VIOCTRL_WKPULLUP_MASK - | SYSMGR_FRZCTRL_VIOCTRL_TRISTATE_MASK; - clrbits_le32(frzctrl_ioctrl_reg_offset, - frzctrl_reg_cfg_mask); - - /* - * Note: Delay for 20ns at min - * Assert active low bhniotri signal and de-assert - * active high csrdone - */ - frzctrl_reg_cfg_mask - = SYSMGR_FRZCTRL_VIOCTRL_BUSHOLD_MASK - | SYSMGR_FRZCTRL_VIOCTRL_CFG_MASK; - clrbits_le32(frzctrl_ioctrl_reg_offset, - frzctrl_reg_cfg_mask); - - /* Set global flag to indicate channel is frozen */ - frzctrl_channel_freeze[channel_id] = - FREEZE_CTRL_FROZEN; - break; - - case FREEZE_CHANNEL_3: - /* - * Assert active low enrnsl, plniotri and - * niotri signals - */ - frzctrl_reg_cfg_mask - = SYSMGR_FRZCTRL_HIOCTRL_SLEW_MASK - | SYSMGR_FRZCTRL_HIOCTRL_WKPULLUP_MASK - | SYSMGR_FRZCTRL_HIOCTRL_TRISTATE_MASK; - clrbits_le32(&freeze_controller_base->hioctrl, - frzctrl_reg_cfg_mask); - - /* - * Note: Delay for 40ns at min - * assert active low bhniotri & nfrzdrv signals, - * de-assert active high csrdone and assert - * active high frzreg and nfrzdrv signals - */ - frzctrl_reg_value = - readl(&freeze_controller_base->hioctrl); - frzctrl_reg_cfg_mask - = SYSMGR_FRZCTRL_HIOCTRL_BUSHOLD_MASK - | SYSMGR_FRZCTRL_HIOCTRL_CFG_MASK; - frzctrl_reg_value - = (frzctrl_reg_value & ~frzctrl_reg_cfg_mask) - | SYSMGR_FRZCTRL_HIOCTRL_REGRST_MASK - | SYSMGR_FRZCTRL_HIOCTRL_OCTRST_MASK; - writel(frzctrl_reg_value, - &freeze_controller_base->hioctrl); - - /* - * Note: Delay for 40ns at min - * assert active high reinit signal and de-assert - * active high pllbiasen signals - */ - frzctrl_reg_value = - readl(&freeze_controller_base->hioctrl); - frzctrl_reg_value - = (frzctrl_reg_value & - ~SYSMGR_FRZCTRL_HIOCTRL_OCT_CFGEN_CALSTART_MASK) - | SYSMGR_FRZCTRL_HIOCTRL_DLLRST_MASK; - writel(frzctrl_reg_value, - &freeze_controller_base->hioctrl); - - /* Set global flag to indicate channel is frozen */ - frzctrl_channel_freeze[channel_id] = - FREEZE_CTRL_FROZEN; - break; - - default: - return 1; - } - } else if (FREEZE_CONTROLLER_FSM_HW == fsm_select) { - - /* select hardware FSM */ - writel(SYSMGR_FRZCTRL_SRC_VIO1_ENUM_HW, - &freeze_controller_base->src); - - /* write to hwctrl reg to enable freeze req */ - setbits_le32(&freeze_controller_base->hwctrl, - SYSMGR_FRZCTRL_HWCTRL_VIO1REQ_MASK); - - i = 0; - while (SYSMGR_FRZCTRL_HWCTRL_VIO1STATE_ENUM_FROZEN - != sys_mgr_frzctrl_frzchn1_state_get()) { - i++; - if (SYSMGR_FRZCTRL_LOOP_PARAM < i) - return 1; - } /* while ( not frozen) */ - - /* Set global flag to indicate channel is frozen */ - frzctrl_channel_freeze[channel_id] = FREEZE_CTRL_FROZEN; - } else { - return 1; - } /* if-else (fsm_select) */ + if (FREEZE_CONTROLLER_FSM_SW != fsm_select) + return -EINVAL; + + /* select software FSM */ + writel(SYSMGR_FRZCTRL_SRC_VIO1_ENUM_SW, + &freeze_controller_base->src); + + /* Freeze channel ID checking and base address */ + switch (channel_id) { + case FREEZE_CHANNEL_0: + case FREEZE_CHANNEL_1: + case FREEZE_CHANNEL_2: + ioctrl_reg_offset = (u32)( + &freeze_controller_base->vioctrl + + (channel_id << SYSMGR_FRZCTRL_VIOCTRL_SHIFT)); + + /* + * Assert active low enrnsl, plniotri + * and niotri signals + */ + reg_cfg_mask = + SYSMGR_FRZCTRL_VIOCTRL_SLEW_MASK + | SYSMGR_FRZCTRL_VIOCTRL_WKPULLUP_MASK + | SYSMGR_FRZCTRL_VIOCTRL_TRISTATE_MASK; + clrbits_le32(ioctrl_reg_offset, + reg_cfg_mask); + + /* + * Note: Delay for 20ns at min + * Assert active low bhniotri signal and de-assert + * active high csrdone + */ + reg_cfg_mask + = SYSMGR_FRZCTRL_VIOCTRL_BUSHOLD_MASK + | SYSMGR_FRZCTRL_VIOCTRL_CFG_MASK; + clrbits_le32(ioctrl_reg_offset, + reg_cfg_mask); + break; + + case FREEZE_CHANNEL_3: + /* + * Assert active low enrnsl, plniotri and + * niotri signals + */ + reg_cfg_mask + = SYSMGR_FRZCTRL_HIOCTRL_SLEW_MASK + | SYSMGR_FRZCTRL_HIOCTRL_WKPULLUP_MASK + | SYSMGR_FRZCTRL_HIOCTRL_TRISTATE_MASK; + clrbits_le32(&freeze_controller_base->hioctrl, + reg_cfg_mask); + + /* + * Note: Delay for 40ns at min + * assert active low bhniotri & nfrzdrv signals, + * de-assert active high csrdone and assert + * active high frzreg and nfrzdrv signals + */ + reg_value = + readl(&freeze_controller_base->hioctrl); + reg_cfg_mask + = SYSMGR_FRZCTRL_HIOCTRL_BUSHOLD_MASK + | SYSMGR_FRZCTRL_HIOCTRL_CFG_MASK; + reg_value + = (reg_value & ~reg_cfg_mask) + | SYSMGR_FRZCTRL_HIOCTRL_REGRST_MASK + | SYSMGR_FRZCTRL_HIOCTRL_OCTRST_MASK; + writel(reg_value, + &freeze_controller_base->hioctrl); + + /* + * Note: Delay for 40ns at min + * assert active high reinit signal and de-assert + * active high pllbiasen signals + */ + reg_value = + readl(&freeze_controller_base->hioctrl); + reg_value + = (reg_value & + ~SYSMGR_FRZCTRL_HIOCTRL_OCT_CFGEN_CALSTART_MASK) + | SYSMGR_FRZCTRL_HIOCTRL_DLLRST_MASK; + writel(reg_value, + &freeze_controller_base->hioctrl); + break; + + default: + return -EINVAL; + }
return 0; }
/* Unfreeze/Thaw HPS IOs */ u32 sys_mgr_frzctrl_thaw_req(FreezeChannelSelect channel_id, - FreezeControllerFSMSelect fsm_select) + FreezeControllerFSMSelect fsm_select) { - u32 frzctrl_ioctrl_reg_offset; - u32 frzctrl_reg_cfg_mask; - u32 frzctrl_reg_value; + u32 ioctrl_reg_offset; + u32 reg_cfg_mask; + u32 reg_value; u32 i; u32 start_count, clk_cycles_count;
- if (FREEZE_CONTROLLER_FSM_SW == fsm_select) { - /* select software FSM */ - writel(SYSMGR_FRZCTRL_SRC_VIO1_ENUM_SW, - &freeze_controller_base->src); + if (FREEZE_CONTROLLER_FSM_SW != fsm_select) { + return -EINVAL; + } + + + /* select software FSM */ + writel(SYSMGR_FRZCTRL_SRC_VIO1_ENUM_SW, + &freeze_controller_base->src);
/* Freeze channel ID checking and base address */ switch (channel_id) { case FREEZE_CHANNEL_0: case FREEZE_CHANNEL_1: case FREEZE_CHANNEL_2: - frzctrl_ioctrl_reg_offset + ioctrl_reg_offset = (u32)(&freeze_controller_base->vioctrl - + (channel_id << SYSMGR_FRZCTRL_VIOCTRL_SHIFT)); + + (channel_id << SYSMGR_FRZCTRL_VIOCTRL_SHIFT));
/* * Assert active low bhniotri signal and * de-assert active high csrdone */ - frzctrl_reg_cfg_mask + reg_cfg_mask = SYSMGR_FRZCTRL_VIOCTRL_BUSHOLD_MASK | SYSMGR_FRZCTRL_VIOCTRL_CFG_MASK; - setbits_le32(frzctrl_ioctrl_reg_offset, - frzctrl_reg_cfg_mask); + setbits_le32(ioctrl_reg_offset, + reg_cfg_mask);
/* * Note: Delay for 20ns at min * de-assert active low plniotri and niotri signals */ - frzctrl_reg_cfg_mask + reg_cfg_mask = SYSMGR_FRZCTRL_VIOCTRL_WKPULLUP_MASK | SYSMGR_FRZCTRL_VIOCTRL_TRISTATE_MASK; - setbits_le32(frzctrl_ioctrl_reg_offset, - frzctrl_reg_cfg_mask); + setbits_le32(ioctrl_reg_offset, + reg_cfg_mask);
/* * Note: Delay for 20ns at min * de-assert active low enrnsl signal */ - setbits_le32(frzctrl_ioctrl_reg_offset, - SYSMGR_FRZCTRL_VIOCTRL_SLEW_MASK); - - /* Set global flag to indicate channel is thawed */ - frzctrl_channel_freeze[channel_id] = FREEZE_CTRL_THAWED; - + setbits_le32(ioctrl_reg_offset, + SYSMGR_FRZCTRL_VIOCTRL_SLEW_MASK); break;
case FREEZE_CHANNEL_3: /* de-assert active high reinit signal */ clrbits_le32(&freeze_controller_base->hioctrl, - SYSMGR_FRZCTRL_HIOCTRL_DLLRST_MASK); + SYSMGR_FRZCTRL_HIOCTRL_DLLRST_MASK);
/* * Note: Delay for 40ns at min * assert active high pllbiasen signals */ setbits_le32(&freeze_controller_base->hioctrl, - SYSMGR_FRZCTRL_HIOCTRL_OCT_CFGEN_CALSTART_MASK); + SYSMGR_FRZCTRL_HIOCTRL_OCT_CFGEN_CALSTART_MASK);
/* Delay 1000 intosc. intosc is based on eosc1 */ reset_timer_count(); @@ -238,18 +195,18 @@ u32 sys_mgr_frzctrl_thaw_req(FreezeChannelSelect channel_id, clk_cycles_count = get_timer_count(start_count); } while (clk_cycles_count < - SYSMGR_FRZCTRL_INTOSC_1000); + SYSMGR_FRZCTRL_INTOSC_1000);
/* * de-assert active low bhniotri signals, * assert active high csrdone and nfrzdrv signal */ - frzctrl_reg_value = readl(&freeze_controller_base->hioctrl); - frzctrl_reg_value = (frzctrl_reg_value - | SYSMGR_FRZCTRL_HIOCTRL_BUSHOLD_MASK - | SYSMGR_FRZCTRL_HIOCTRL_CFG_MASK) + reg_value = readl(&freeze_controller_base->hioctrl); + reg_value = (reg_value + | SYSMGR_FRZCTRL_HIOCTRL_BUSHOLD_MASK + | SYSMGR_FRZCTRL_HIOCTRL_CFG_MASK) & ~SYSMGR_FRZCTRL_HIOCTRL_OCTRST_MASK; - writel(frzctrl_reg_value, &freeze_controller_base->hioctrl); + writel(reg_value, &freeze_controller_base->hioctrl);
/* Delay 33 intosc */ reset_timer_count(); @@ -259,63 +216,35 @@ u32 sys_mgr_frzctrl_thaw_req(FreezeChannelSelect channel_id, clk_cycles_count = get_timer_count(start_count); } while (clk_cycles_count < - SYSMGR_FRZCTRL_INTOSC_33); + SYSMGR_FRZCTRL_INTOSC_33);
/* de-assert active low plniotri and niotri signals */ - frzctrl_reg_cfg_mask + reg_cfg_mask = SYSMGR_FRZCTRL_HIOCTRL_WKPULLUP_MASK | SYSMGR_FRZCTRL_HIOCTRL_TRISTATE_MASK;
setbits_le32(&freeze_controller_base->hioctrl, - frzctrl_reg_cfg_mask); + reg_cfg_mask);
/* * Note: Delay for 40ns at min * de-assert active high frzreg signal */ clrbits_le32(&freeze_controller_base->hioctrl, - SYSMGR_FRZCTRL_HIOCTRL_REGRST_MASK); + SYSMGR_FRZCTRL_HIOCTRL_REGRST_MASK);
/* * Note: Delay for 40ns at min * de-assert active low enrnsl signal */ setbits_le32(&freeze_controller_base->hioctrl, - SYSMGR_FRZCTRL_HIOCTRL_SLEW_MASK); - - /* Set global flag to indicate channel is thawed */ - frzctrl_channel_freeze[channel_id] = FREEZE_CTRL_THAWED; - + SYSMGR_FRZCTRL_HIOCTRL_SLEW_MASK); break;
default: - return 1; + return -EINVAL; }
- } else if (FREEZE_CONTROLLER_FSM_HW == fsm_select) { - - /* select hardware FSM */ - writel(SYSMGR_FRZCTRL_SRC_VIO1_ENUM_HW, - &freeze_controller_base->src); - - /* write to hwctrl reg to enable thaw req; 0: thaw */ - clrbits_le32(&freeze_controller_base->hwctrl, - SYSMGR_FRZCTRL_HWCTRL_VIO1REQ_MASK); - - i = 0; - while (SYSMGR_FRZCTRL_HWCTRL_VIO1STATE_ENUM_THAWED - != sys_mgr_frzctrl_frzchn1_state_get()) { - i++; - if (SYSMGR_FRZCTRL_LOOP_PARAM < i) - return 1; - } /* while (not thaw) */ - - /* Set global flag to indicate channel is thawed */ - frzctrl_channel_freeze[channel_id] = FREEZE_CTRL_THAWED; - } else { - return 1; - } /* if-else (fsm_select) */ - return 0; }
Hi Pavel,
On Thu, 2013-09-19 at 14:11 +0200, ZY - pavel wrote:
Hi!
Thanks to you too for the speedy feedback.
I patched against latest release plus the last 2 patches for System Manager & pin mux (other earlier patches already in latest release). These patches already went through few round of reviews. I believe we just need to wait Albert to apply them into master git :)
AFAICT:
Yup, they can removed. It was put initially as customer can use either SW or HW state machine. But rethinking of this, most likely customer will not change this area. So its good to remove the dead code.
Actually they will be used in other function within this driver. This function is yet to be upstreamed. I plan to do it together with new driver "Scan Manager" in later days. The Scan Manager will need this function to work together. With that, is it ok that we maintain this first?
Oops, seems overdone here... haha. I already fix it
Thanks and applied
Good suggestion here. I converted them to use the delay now to avoid creating the new timer functions. End of day, not much impact to performance when converting clock cycles to microseconds.
I will send up the v2 in short time. Thanks again and have a fun day.
Chin Liang
Thanks, Pavel
- Default state from cold reset is FREEZE_ALL; the global
- flag is set to TRUE to indicate the IO banks are frozen
- u32 ioctrl_reg_offset;
- u32 reg_value;
- u32 reg_cfg_mask; u32 i;
FREEZE_CTRL_FROZEN;
break;
* niotri signals
frzctrl_reg_value =
frzctrl_reg_value
frzctrl_reg_value =
frzctrl_reg_value
FREEZE_CTRL_FROZEN;
break;
default:
return 1;
i = 0;
i++;
return 1;
- } else {
return 1;
return -EINVAL;
reg_cfg_mask =
reg_cfg_mask);
reg_cfg_mask
reg_cfg_mask);
break;
* niotri signals
reg_cfg_mask
reg_cfg_mask);
reg_value =
reg_cfg_mask
reg_value
writel(reg_value,
reg_value =
reg_value
= (reg_value &
writel(reg_value,
break;
default:
return -EINVAL;
- u32 reg_cfg_mask;
- u32 reg_value; u32 i; u32 start_count, clk_cycles_count;
return -EINVAL;
- Assert active low bhniotri signal and
- de-assert active high csrdone
reg_cfg_mask);
- Note: Delay for 20ns at min
- de-assert active low plniotri and niotri signals
reg_cfg_mask);
- de-assert active low enrnsl signal
break;
- Note: Delay for 40ns at min
- assert active high pllbiasen signals
- de-assert active low bhniotri signals,
- assert active high csrdone and nfrzdrv signal
reg_cfg_mask);
- de-assert active high frzreg signal
break;
default:
return 1;
}return -EINVAL;
i = 0;
i++;
return 1;
- } else {
return 1;
Chin Liang See
Pavel Machek
