[U-Boot] [PATCH v12 0/2] S5P: Exynos: Add GPIO numbering feature
Used a script to recheck/verify pin mapping and existing mapping appears to be fine, returning correct bank and pin values. Did ./MAKEALL -a arm and found all Exynos/S5P related boards compiled successfully. Couldn't test booting over all of them. Tested U-Boot bootup over SMDK5420, SMDK5250, Snow. Requesting maintaners to please test over affected SoCs/boards.
Changes in V2: - Enabled CMD_GPIO as suggested by Simon Glass and supported same for EXYNOS5. Changes in V3: - New patch added to rename S5P GPIO definitions to S5P_GPIO. - GPIO Table added to calculate the base address of input gpio bank. Changes in V4: - To have consistent 0..n-1 GPIO numbering the banks are divided into different parts where ever they have holes in them. - Function and table to support gpio command moved to s5p-gpio driver. - Rebased on latest u-boot-samsung tree. Changes in V5: - Rebased on latest u-boot-samsung tree. - Removed Exynos5 specific code in gpio driver api to get bank. - Added #define HAVE_GENERIC_GPIO in config file to remove conditinal CPU check in gpio driver. Changes in V6: - Isolated config changes in a new patch. - Updated patches with corresponding changes for Exynos 5420. Changes in V7: - Added changes for other SoCs like Exynos 4412, 4210 etc. Changes in V8: - Changed Subject of patch 2/2 to reflect affected SoCs/boards. - Fixed arndale board compile time errors introduced due to patch-set v7. Changes in V9: - Fixed checkpatch errors. - Fixed naming error in exynosxxxx_gpio_data arrays which could be the possible reason behind data abort witnessed over Exynos4 boards. Changes in v10: - Made arch-exynos/gpio.h -> arch/gpio.h. - Removed dead code. - Replaced exynos_gpio_get calls with corresponding pin number. - Edited pin numbmers in dts files. Changes in v11: - Created and fixed pinmux_config for Exynos 4412. - Removed dead code. Changes in v12: - Added change logs in individual patches. - Fixed few bugs and typos. - Added "Acked-by: Przemyslaw Marczak".
Akshay Saraswat (2): S5P: Exynos: Add GPIO pin numbering and rename definitions S5P: Exynos: Config: Enable GPIO CMD config
arch/arm/cpu/armv7/exynos/pinmux.c | 561 +++++---- arch/arm/dts/exynos4210-origen.dts | 4 +- arch/arm/dts/exynos4210-trats.dts | 6 +- arch/arm/dts/exynos4210-universal_c210.dts | 4 +- arch/arm/dts/exynos4412-trats2.dts | 4 +- arch/arm/include/asm/arch-exynos/cpu.h | 17 +- arch/arm/include/asm/arch-exynos/gpio.h | 1761 +++++++++++++++++++++++----- arch/arm/include/asm/arch-s5pc1xx/gpio.h | 948 ++++++++++++--- board/samsung/arndale/arndale.c | 11 +- board/samsung/goni/goni.c | 32 +- board/samsung/smdk5250/exynos5-dt.c | 20 +- board/samsung/smdk5250/smdk5250.c | 19 +- board/samsung/smdk5420/smdk5420.c | 15 +- board/samsung/smdkc100/smdkc100.c | 5 +- board/samsung/smdkv310/smdkv310.c | 19 +- board/samsung/trats/trats.c | 39 +- board/samsung/trats2/trats2.c | 74 +- board/samsung/universal_c210/universal.c | 51 +- drivers/gpio/s5p_gpio.c | 204 +++- include/configs/exynos5-dt.h | 2 + include/configs/s5p_goni.h | 4 +- include/configs/s5pc210_universal.h | 16 +- include/configs/smdkv310.h | 1 + include/configs/trats.h | 8 +- include/configs/trats2.h | 4 +- 25 files changed, 2918 insertions(+), 911 deletions(-)
This patch includes following changes : * Adds gpio pin numbering support for EXYNOS SOCs. To have consistent 0..n-1 GPIO numbering the banks are divided into different parts where ever they have holes in them.
* Rename GPIO definitions from GPIO_... to S5P_GPIO_... These changes were done to enable cmd_gpio for EXYNOS and cmd_gpio has GPIO_INPUT same as s5p_gpio driver and hence getting a error during compilation.
* Adds support for name to gpio conversion in s5p_gpio to enable gpio command EXYNOS SoCs. Function has been added to asm/gpio.h to decode the input gpio name to gpio number. Example: SMDK5420 # gpio set gpa00
Signed-off-by: Leela Krishna Amudala l.krishna@samsung.com Signed-off-by: Rajeshwari Shinde rajeshwari.s@samsung.com Signed-off-by: Akshay Saraswat akshay.s@samsung.com Acked-by: Przemyslaw Marczak p.marczak@samsung.com --- Changes in V12: - Added change log in this patch. - Fixed few bugs and typos. - Added "Acked-by: Przemyslaw Marczak". Changes in v11: - Created and fixed pinmux_config for Exynos 4412. - Removed dead code. Changes in v10: - Made arch-exynos/gpio.h -> arch/gpio.h. - Removed dead code. - Edited pin numbmers in dts files. Changes in V9: - Fixed checkpatch errors. - Fixed naming error in exynosxxxx_gpio_data arrays which could be the possible reason behind data abort witnessed over Exynos4 boards. Changes in V8: - Fixed arndale board compile time errors introduced due to patch-set v7. Changes in V7: - Added changes for other SoCs like Exynos 4412, 4210 etc. Changes in V6: - Updated patch with corresponding changes for Exynos 5420. Changes in V5: - Rebased on latest u-boot-samsung tree. - Removed Exynos5 specific code in gpio driver api to get bank. Changes in V4: - To have consistent 0..n-1 GPIO numbering the banks are divided into different parts where ever they have holes in them. - Function and table to support gpio command moved to s5p-gpio driver. - Rebased on latest u-boot-samsung tree. Changes in V3: - GPIO Table added to calculate the base address of input gpio bank.
arch/arm/cpu/armv7/exynos/pinmux.c | 561 +++++---- arch/arm/dts/exynos4210-origen.dts | 4 +- arch/arm/dts/exynos4210-trats.dts | 6 +- arch/arm/dts/exynos4210-universal_c210.dts | 4 +- arch/arm/dts/exynos4412-trats2.dts | 4 +- arch/arm/include/asm/arch-exynos/cpu.h | 17 +- arch/arm/include/asm/arch-exynos/gpio.h | 1761 +++++++++++++++++++++++----- arch/arm/include/asm/arch-s5pc1xx/gpio.h | 948 ++++++++++++--- board/samsung/arndale/arndale.c | 11 +- board/samsung/goni/goni.c | 32 +- board/samsung/smdk5250/exynos5-dt.c | 20 +- board/samsung/smdk5250/smdk5250.c | 19 +- board/samsung/smdk5420/smdk5420.c | 15 +- board/samsung/smdkc100/smdkc100.c | 5 +- board/samsung/smdkv310/smdkv310.c | 19 +- board/samsung/trats/trats.c | 39 +- board/samsung/trats2/trats2.c | 74 +- board/samsung/universal_c210/universal.c | 51 +- drivers/gpio/s5p_gpio.c | 204 +++- 19 files changed, 2899 insertions(+), 895 deletions(-)
diff --git a/arch/arm/cpu/armv7/exynos/pinmux.c b/arch/arm/cpu/armv7/exynos/pinmux.c index 9edb475..ee7c2e5 100644 --- a/arch/arm/cpu/armv7/exynos/pinmux.c +++ b/arch/arm/cpu/armv7/exynos/pinmux.c @@ -13,30 +13,23 @@
static void exynos5_uart_config(int peripheral) { - struct exynos5_gpio_part1 *gpio1 = - (struct exynos5_gpio_part1 *) samsung_get_base_gpio_part1(); - struct s5p_gpio_bank *bank; int i, start, count;
switch (peripheral) { case PERIPH_ID_UART0: - bank = &gpio1->a0; - start = 0; + start = EXYNOS5_GPIO_A00; count = 4; break; case PERIPH_ID_UART1: - bank = &gpio1->d0; - start = 0; + start = EXYNOS5_GPIO_D00; count = 4; break; case PERIPH_ID_UART2: - bank = &gpio1->a1; - start = 0; + start = EXYNOS5_GPIO_A10; count = 4; break; case PERIPH_ID_UART3: - bank = &gpio1->a1; - start = 4; + start = EXYNOS5_GPIO_A14; count = 2; break; default: @@ -44,37 +37,30 @@ static void exynos5_uart_config(int peripheral) return; } for (i = start; i < start + count; i++) { - s5p_gpio_set_pull(bank, i, GPIO_PULL_NONE); - s5p_gpio_cfg_pin(bank, i, GPIO_FUNC(0x2)); + gpio_set_pull(i, S5P_GPIO_PULL_NONE); + gpio_cfg_pin(i, S5P_GPIO_FUNC(0x2)); } }
static void exynos5420_uart_config(int peripheral) { - struct exynos5420_gpio_part1 *gpio1 = - (struct exynos5420_gpio_part1 *)samsung_get_base_gpio_part1(); - struct s5p_gpio_bank *bank; int i, start, count;
switch (peripheral) { case PERIPH_ID_UART0: - bank = &gpio1->a0; - start = 0; + start = EXYNOS5420_GPIO_A00; count = 4; break; case PERIPH_ID_UART1: - bank = &gpio1->a0; - start = 4; + start = EXYNOS5420_GPIO_A04; count = 4; break; case PERIPH_ID_UART2: - bank = &gpio1->a1; - start = 0; + start = EXYNOS5420_GPIO_A10; count = 4; break; case PERIPH_ID_UART3: - bank = &gpio1->a1; - start = 4; + start = EXYNOS5420_GPIO_A14; count = 2; break; default: @@ -83,64 +69,59 @@ static void exynos5420_uart_config(int peripheral) }
static int exynos5_mmc_config(int peripheral, int flags) { - struct exynos5_gpio_part1 *gpio1 = - (struct exynos5_gpio_part1 *) samsung_get_base_gpio_part1(); - struct s5p_gpio_bank *bank, *bank_ext; - int i, start = 0, gpio_func = 0; + int i, start, start_ext, gpio_func = 0;
switch (peripheral) { case PERIPH_ID_SDMMC0: - bank = &gpio1->c0; - bank_ext = &gpio1->c1; - start = 0; - gpio_func = GPIO_FUNC(0x2); + start = EXYNOS5_GPIO_C00; + start_ext = EXYNOS5_GPIO_C10; + gpio_func = S5P_GPIO_FUNC(0x2); break; case PERIPH_ID_SDMMC1: - bank = &gpio1->c2; - bank_ext = NULL; + start = EXYNOS5_GPIO_C20; + start_ext = 0; break; case PERIPH_ID_SDMMC2: - bank = &gpio1->c3; - bank_ext = &gpio1->c4; - start = 3; - gpio_func = GPIO_FUNC(0x3); + start = EXYNOS5_GPIO_C30; + start_ext = EXYNOS5_GPIO_C43; + gpio_func = S5P_GPIO_FUNC(0x3); break; case PERIPH_ID_SDMMC3: - bank = &gpio1->c4; - bank_ext = NULL; + start = EXYNOS5_GPIO_C40; + start_ext = 0; break; default: debug("%s: invalid peripheral %d", __func__, peripheral); return -1; } - if ((flags & PINMUX_FLAG_8BIT_MODE) && !bank_ext) { + if ((flags & PINMUX_FLAG_8BIT_MODE) && !start_ext) { debug("SDMMC device %d does not support 8bit mode", peripheral); return -1; } if (flags & PINMUX_FLAG_8BIT_MODE) { - for (i = start; i <= (start + 3); i++) { - s5p_gpio_cfg_pin(bank_ext, i, gpio_func); - s5p_gpio_set_pull(bank_ext, i, GPIO_PULL_UP); - s5p_gpio_set_drv(bank_ext, i, GPIO_DRV_4X); + for (i = start_ext; i <= (start_ext + 3); i++) { + gpio_cfg_pin(i, gpio_func); + gpio_set_pull(i, S5P_GPIO_PULL_UP); + gpio_set_drv(i, S5P_GPIO_DRV_4X); } } - for (i = 0; i < 2; i++) { - s5p_gpio_cfg_pin(bank, i, GPIO_FUNC(0x2)); - s5p_gpio_set_pull(bank, i, GPIO_PULL_NONE); - s5p_gpio_set_drv(bank, i, GPIO_DRV_4X); + for (i = start; i < (start + 2); i++) { + gpio_cfg_pin(i, S5P_GPIO_FUNC(0x2)); + gpio_set_pull(i, S5P_GPIO_PULL_NONE); + gpio_set_drv(i, S5P_GPIO_DRV_4X); } - for (i = 3; i <= 6; i++) { - s5p_gpio_cfg_pin(bank, i, GPIO_FUNC(0x2)); - s5p_gpio_set_pull(bank, i, GPIO_PULL_UP); - s5p_gpio_set_drv(bank, i, GPIO_DRV_4X); + for (i = (start + 3); i <= (start + 6); i++) { + gpio_cfg_pin(i, S5P_GPIO_FUNC(0x2)); + gpio_set_pull(i, S5P_GPIO_PULL_UP); + gpio_set_drv(i, S5P_GPIO_DRV_4X); }
return 0; @@ -148,26 +129,20 @@ static int exynos5_mmc_config(int peripheral, int flags)
static int exynos5420_mmc_config(int peripheral, int flags) { - struct exynos5420_gpio_part3 *gpio3 = - (struct exynos5420_gpio_part3 *)samsung_get_base_gpio_part3(); - struct s5p_gpio_bank *bank = NULL, *bank_ext = NULL; - int i, start; + int i, start = 0, start_ext = 0;
switch (peripheral) { case PERIPH_ID_SDMMC0: - bank = &gpio3->c0; - bank_ext = &gpio3->c3; - start = 0; + start = EXYNOS5420_GPIO_C00; + start_ext = EXYNOS5420_GPIO_C30; break; case PERIPH_ID_SDMMC1: - bank = &gpio3->c1; - bank_ext = &gpio3->d1; - start = 4; + start = EXYNOS5420_GPIO_C10; + start_ext = EXYNOS5420_GPIO_D14; break; case PERIPH_ID_SDMMC2: - bank = &gpio3->c2; - bank_ext = NULL; - start = 0; + start = EXYNOS5420_GPIO_C20; + start_ext = 0; break; default: start = 0; @@ -175,41 +150,41 @@ static int exynos5420_mmc_config(int peripheral, int flags) return -1; }
if (flags & PINMUX_FLAG_8BIT_MODE) { - for (i = start; i <= (start + 3); i++) { - s5p_gpio_cfg_pin(bank_ext, i, GPIO_FUNC(0x2)); - s5p_gpio_set_pull(bank_ext, i, GPIO_PULL_UP); - s5p_gpio_set_drv(bank_ext, i, GPIO_DRV_4X); + for (i = start_ext; i <= (start_ext + 3); i++) { + gpio_cfg_pin(i, S5P_GPIO_FUNC(0x2)); + gpio_set_pull(i, S5P_GPIO_PULL_UP); + gpio_set_drv(i, S5P_GPIO_DRV_4X); } }
- for (i = 0; i < 3; i++) { + for (i = start; i < (start + 3); i++) { /* * MMC0 is intended to be used for eMMC. The * card detect pin is used as a VDDEN signal to * power on the eMMC. The 5420 iROM makes * this same assumption. */ - if ((peripheral == PERIPH_ID_SDMMC0) && (i == 2)) { - s5p_gpio_set_value(bank, i, 1); - s5p_gpio_cfg_pin(bank, i, GPIO_OUTPUT); + if ((peripheral == PERIPH_ID_SDMMC0) && (i == (start + 2))) { + gpio_set_value(i, 1); + gpio_cfg_pin(i, S5P_GPIO_OUTPUT); } else { - s5p_gpio_cfg_pin(bank, i, GPIO_FUNC(0x2)); + gpio_cfg_pin(i, S5P_GPIO_FUNC(0x2)); } - s5p_gpio_set_pull(bank, i, GPIO_PULL_NONE); - s5p_gpio_set_drv(bank, i, GPIO_DRV_4X); + gpio_set_pull(i, S5P_GPIO_PULL_NONE); + gpio_set_drv(i, S5P_GPIO_DRV_4X); }
return 0; @@ -217,8 +192,6 @@ static int exynos5420_mmc_config(int peripheral, int flags)
static void exynos5_sromc_config(int flags) { - struct exynos5_gpio_part1 *gpio1 = - (struct exynos5_gpio_part1 *) samsung_get_base_gpio_part1(); int i;
/* @@ -236,13 +209,13 @@ static void exynos5_sromc_config(int flags) * GPY1[2] SROM_WAIT(2) * GPY1[3] EBI_DATA_RDn(2) */ - s5p_gpio_cfg_pin(&gpio1->y0, (flags & PINMUX_FLAG_BANK), - GPIO_FUNC(2)); - s5p_gpio_cfg_pin(&gpio1->y0, 4, GPIO_FUNC(2)); - s5p_gpio_cfg_pin(&gpio1->y0, 5, GPIO_FUNC(2)); + gpio_cfg_pin(EXYNOS5_GPIO_Y00 + (flags & PINMUX_FLAG_BANK), + S5P_GPIO_FUNC(2)); + gpio_cfg_pin(EXYNOS5_GPIO_Y04, S5P_GPIO_FUNC(2)); + gpio_cfg_pin(EXYNOS5_GPIO_Y05, S5P_GPIO_FUNC(2));
for (i = 0; i < 4; i++) - s5p_gpio_cfg_pin(&gpio1->y1, i, GPIO_FUNC(2)); + gpio_cfg_pin(EXYNOS5_GPIO_Y10 + i, S5P_GPIO_FUNC(2));
/* * EBI: 8 Addrss Lines @@ -277,108 +250,101 @@ static void exynos5_sromc_config(int flags) * GPY6[7] EBI_DATA[15](2) */ for (i = 0; i < 8; i++) { - s5p_gpio_cfg_pin(&gpio1->y3, i, GPIO_FUNC(2)); - s5p_gpio_set_pull(&gpio1->y3, i, GPIO_PULL_UP); + gpio_cfg_pin(EXYNOS5_GPIO_Y30 + i, S5P_GPIO_FUNC(2)); + gpio_set_pull(EXYNOS5_GPIO_Y30 + i, S5P_GPIO_PULL_UP);
- s5p_gpio_cfg_pin(&gpio1->y5, i, GPIO_FUNC(2)); - s5p_gpio_set_pull(&gpio1->y5, i, GPIO_PULL_UP); + gpio_cfg_pin(EXYNOS5_GPIO_Y50 + i, S5P_GPIO_FUNC(2)); + gpio_set_pull(EXYNOS5_GPIO_Y50 + i, S5P_GPIO_PULL_UP);
- s5p_gpio_cfg_pin(&gpio1->y6, i, GPIO_FUNC(2)); - s5p_gpio_set_pull(&gpio1->y6, i, GPIO_PULL_UP); + gpio_cfg_pin(EXYNOS5_GPIO_Y60 + i, S5P_GPIO_FUNC(2)); + gpio_set_pull(EXYNOS5_GPIO_Y60 + i, S5P_GPIO_PULL_UP); } }
static void exynos5_i2c_config(int peripheral, int flags) { - - struct exynos5_gpio_part1 *gpio1 = - (struct exynos5_gpio_part1 *) samsung_get_base_gpio_part1(); - switch (peripheral) { case PERIPH_ID_I2C0: - s5p_gpio_cfg_pin(&gpio1->b3, 0, GPIO_FUNC(0x2)); - s5p_gpio_cfg_pin(&gpio1->b3, 1, GPIO_FUNC(0x2)); + gpio_cfg_pin(EXYNOS5_GPIO_B30, S5P_GPIO_FUNC(0x2)); + gpio_cfg_pin(EXYNOS5_GPIO_B31, S5P_GPIO_FUNC(0x2)); break; case PERIPH_ID_I2C1: - s5p_gpio_cfg_pin(&gpio1->b3, 2, GPIO_FUNC(0x2)); - s5p_gpio_cfg_pin(&gpio1->b3, 3, GPIO_FUNC(0x2)); + gpio_cfg_pin(EXYNOS5_GPIO_B32, S5P_GPIO_FUNC(0x2)); + gpio_cfg_pin(EXYNOS5_GPIO_B33, S5P_GPIO_FUNC(0x2)); break; case PERIPH_ID_I2C2: - s5p_gpio_cfg_pin(&gpio1->a0, 6, GPIO_FUNC(0x3)); - s5p_gpio_cfg_pin(&gpio1->a0, 7, GPIO_FUNC(0x3)); + gpio_cfg_pin(EXYNOS5_GPIO_A06, S5P_GPIO_FUNC(0x3)); + gpio_cfg_pin(EXYNOS5_GPIO_A07, S5P_GPIO_FUNC(0x3)); break; case PERIPH_ID_I2C3: - s5p_gpio_cfg_pin(&gpio1->a1, 2, GPIO_FUNC(0x3)); - s5p_gpio_cfg_pin(&gpio1->a1, 3, GPIO_FUNC(0x3)); + gpio_cfg_pin(EXYNOS5_GPIO_A12, S5P_GPIO_FUNC(0x3)); + gpio_cfg_pin(EXYNOS5_GPIO_A13, S5P_GPIO_FUNC(0x3)); break; case PERIPH_ID_I2C4: - s5p_gpio_cfg_pin(&gpio1->a2, 0, GPIO_FUNC(0x3)); - s5p_gpio_cfg_pin(&gpio1->a2, 1, GPIO_FUNC(0x3)); + gpio_cfg_pin(EXYNOS5_GPIO_A20, S5P_GPIO_FUNC(0x3)); + gpio_cfg_pin(EXYNOS5_GPIO_A21, S5P_GPIO_FUNC(0x3)); break; case PERIPH_ID_I2C5: - s5p_gpio_cfg_pin(&gpio1->a2, 2, GPIO_FUNC(0x3)); - s5p_gpio_cfg_pin(&gpio1->a2, 3, GPIO_FUNC(0x3)); + gpio_cfg_pin(EXYNOS5_GPIO_A22, S5P_GPIO_FUNC(0x3)); + gpio_cfg_pin(EXYNOS5_GPIO_A23, S5P_GPIO_FUNC(0x3)); break; case PERIPH_ID_I2C6: - s5p_gpio_cfg_pin(&gpio1->b1, 3, GPIO_FUNC(0x4)); - s5p_gpio_cfg_pin(&gpio1->b1, 4, GPIO_FUNC(0x4)); + gpio_cfg_pin(EXYNOS5_GPIO_B13, S5P_GPIO_FUNC(0x4)); + gpio_cfg_pin(EXYNOS5_GPIO_B14, S5P_GPIO_FUNC(0x4)); break; case PERIPH_ID_I2C7: - s5p_gpio_cfg_pin(&gpio1->b2, 2, GPIO_FUNC(0x3)); - s5p_gpio_cfg_pin(&gpio1->b2, 3, GPIO_FUNC(0x3)); + gpio_cfg_pin(EXYNOS5_GPIO_B22, S5P_GPIO_FUNC(0x3)); + gpio_cfg_pin(EXYNOS5_GPIO_B23, S5P_GPIO_FUNC(0x3)); break; } }
static void exynos5420_i2c_config(int peripheral) { - struct exynos5420_gpio_part1 *gpio1 = - (struct exynos5420_gpio_part1 *)samsung_get_base_gpio_part1(); - switch (peripheral) { case PERIPH_ID_I2C0: - s5p_gpio_cfg_pin(&gpio1->b3, 0, GPIO_FUNC(0x2)); - s5p_gpio_cfg_pin(&gpio1->b3, 1, GPIO_FUNC(0x2)); + gpio_cfg_pin(EXYNOS5420_GPIO_B30, S5P_GPIO_FUNC(0x2)); + gpio_cfg_pin(EXYNOS5420_GPIO_B31, S5P_GPIO_FUNC(0x2)); break; case PERIPH_ID_I2C1: - s5p_gpio_cfg_pin(&gpio1->b3, 2, GPIO_FUNC(0x2)); - s5p_gpio_cfg_pin(&gpio1->b3, 3, GPIO_FUNC(0x2)); + gpio_cfg_pin(EXYNOS5420_GPIO_B32, S5P_GPIO_FUNC(0x2)); + gpio_cfg_pin(EXYNOS5420_GPIO_B33, S5P_GPIO_FUNC(0x2)); break; case PERIPH_ID_I2C2: - s5p_gpio_cfg_pin(&gpio1->a0, 6, GPIO_FUNC(0x3)); - s5p_gpio_cfg_pin(&gpio1->a0, 7, GPIO_FUNC(0x3)); + gpio_cfg_pin(EXYNOS5420_GPIO_A06, S5P_GPIO_FUNC(0x3)); + gpio_cfg_pin(EXYNOS5420_GPIO_A07, S5P_GPIO_FUNC(0x3)); break; case PERIPH_ID_I2C3: - s5p_gpio_cfg_pin(&gpio1->a1, 2, GPIO_FUNC(0x3)); - s5p_gpio_cfg_pin(&gpio1->a1, 3, GPIO_FUNC(0x3)); + gpio_cfg_pin(EXYNOS5420_GPIO_A12, S5P_GPIO_FUNC(0x3)); + gpio_cfg_pin(EXYNOS5420_GPIO_A13, S5P_GPIO_FUNC(0x3)); break; case PERIPH_ID_I2C4: - s5p_gpio_cfg_pin(&gpio1->a2, 0, GPIO_FUNC(0x3)); - s5p_gpio_cfg_pin(&gpio1->a2, 1, GPIO_FUNC(0x3)); + gpio_cfg_pin(EXYNOS5420_GPIO_A20, S5P_GPIO_FUNC(0x3)); + gpio_cfg_pin(EXYNOS5420_GPIO_A21, S5P_GPIO_FUNC(0x3)); break; case PERIPH_ID_I2C5: - s5p_gpio_cfg_pin(&gpio1->a2, 2, GPIO_FUNC(0x3)); - s5p_gpio_cfg_pin(&gpio1->a2, 3, GPIO_FUNC(0x3)); + gpio_cfg_pin(EXYNOS5420_GPIO_A22, S5P_GPIO_FUNC(0x3)); + gpio_cfg_pin(EXYNOS5420_GPIO_A23, S5P_GPIO_FUNC(0x3)); break; case PERIPH_ID_I2C6: - s5p_gpio_cfg_pin(&gpio1->b1, 3, GPIO_FUNC(0x4)); - s5p_gpio_cfg_pin(&gpio1->b1, 4, GPIO_FUNC(0x4)); + gpio_cfg_pin(EXYNOS5420_GPIO_B13, S5P_GPIO_FUNC(0x4)); + gpio_cfg_pin(EXYNOS5420_GPIO_B14, S5P_GPIO_FUNC(0x4)); break; case PERIPH_ID_I2C7: - s5p_gpio_cfg_pin(&gpio1->b2, 2, GPIO_FUNC(0x3)); - s5p_gpio_cfg_pin(&gpio1->b2, 3, GPIO_FUNC(0x3)); + gpio_cfg_pin(EXYNOS5420_GPIO_B22, S5P_GPIO_FUNC(0x3)); + gpio_cfg_pin(EXYNOS5420_GPIO_B23, S5P_GPIO_FUNC(0x3)); break; case PERIPH_ID_I2C8: - s5p_gpio_cfg_pin(&gpio1->b3, 4, GPIO_FUNC(0x2)); - s5p_gpio_cfg_pin(&gpio1->b3, 5, GPIO_FUNC(0x2)); + gpio_cfg_pin(EXYNOS5420_GPIO_B34, S5P_GPIO_FUNC(0x2)); + gpio_cfg_pin(EXYNOS5420_GPIO_B35, S5P_GPIO_FUNC(0x2)); break; case PERIPH_ID_I2C9: - s5p_gpio_cfg_pin(&gpio1->b3, 6, GPIO_FUNC(0x2)); - s5p_gpio_cfg_pin(&gpio1->b3, 7, GPIO_FUNC(0x2)); + gpio_cfg_pin(EXYNOS5420_GPIO_B36, S5P_GPIO_FUNC(0x2)); + gpio_cfg_pin(EXYNOS5420_GPIO_B37, S5P_GPIO_FUNC(0x2)); break; case PERIPH_ID_I2C10: - s5p_gpio_cfg_pin(&gpio1->b4, 0, GPIO_FUNC(0x2)); - s5p_gpio_cfg_pin(&gpio1->b4, 1, GPIO_FUNC(0x2)); + gpio_cfg_pin(EXYNOS5420_GPIO_B40, S5P_GPIO_FUNC(0x2)); + gpio_cfg_pin(EXYNOS5420_GPIO_B41, S5P_GPIO_FUNC(0x2)); break; } } @@ -386,19 +352,15 @@ static void exynos5420_i2c_config(int peripheral) static void exynos5_i2s_config(int peripheral) { int i; - struct exynos5_gpio_part1 *gpio1 = - (struct exynos5_gpio_part1 *)samsung_get_base_gpio_part1(); - struct exynos5_gpio_part4 *gpio4 = - (struct exynos5_gpio_part4 *)samsung_get_base_gpio_part4();
switch (peripheral) { case PERIPH_ID_I2S0: for (i = 0; i < 5; i++) - s5p_gpio_cfg_pin(&gpio4->z, i, GPIO_FUNC(0x02)); + gpio_cfg_pin(EXYNOS5_GPIO_Z0 + i, S5P_GPIO_FUNC(0x02)); break; case PERIPH_ID_I2S1: for (i = 0; i < 5; i++) - s5p_gpio_cfg_pin(&gpio1->b0, i, GPIO_FUNC(0x02)); + gpio_cfg_pin(EXYNOS5_GPIO_B00 + i, S5P_GPIO_FUNC(0x02)); break; } } @@ -406,75 +368,57 @@ static void exynos5_i2s_config(int peripheral) void exynos5_spi_config(int peripheral) { int cfg = 0, pin = 0, i; - struct s5p_gpio_bank *bank = NULL; - struct exynos5_gpio_part1 *gpio1 = - (struct exynos5_gpio_part1 *) samsung_get_base_gpio_part1(); - struct exynos5_gpio_part2 *gpio2 = - (struct exynos5_gpio_part2 *) samsung_get_base_gpio_part2();
switch (peripheral) { case PERIPH_ID_SPI0: - bank = &gpio1->a2; - cfg = GPIO_FUNC(0x2); - pin = 0; + cfg = S5P_GPIO_FUNC(0x2); + pin = EXYNOS5_GPIO_A20; break; case PERIPH_ID_SPI1: - bank = &gpio1->a2; - cfg = GPIO_FUNC(0x2); - pin = 4; + cfg = S5P_GPIO_FUNC(0x2); + pin = EXYNOS5_GPIO_A24; break; case PERIPH_ID_SPI2: - bank = &gpio1->b1; - cfg = GPIO_FUNC(0x5); - pin = 1; + cfg = S5P_GPIO_FUNC(0x5); + pin = EXYNOS5_GPIO_B11; break; case PERIPH_ID_SPI3: - bank = &gpio2->f1; - cfg = GPIO_FUNC(0x2); - pin = 0; + cfg = S5P_GPIO_FUNC(0x2); + pin = EXYNOS5_GPIO_F10; break; case PERIPH_ID_SPI4: for (i = 0; i < 2; i++) { - s5p_gpio_cfg_pin(&gpio2->f0, i + 2, GPIO_FUNC(0x4)); - s5p_gpio_cfg_pin(&gpio2->e0, i + 4, GPIO_FUNC(0x4)); + gpio_cfg_pin(EXYNOS5_GPIO_F02 + i, S5P_GPIO_FUNC(0x4)); + gpio_cfg_pin(EXYNOS5_GPIO_E04 + i, S5P_GPIO_FUNC(0x4)); } break; } if (peripheral != PERIPH_ID_SPI4) { for (i = pin; i < pin + 4; i++) - s5p_gpio_cfg_pin(bank, i, cfg); + gpio_cfg_pin(i, cfg); } }
void exynos5420_spi_config(int peripheral) { int cfg, pin, i; - struct s5p_gpio_bank *bank = NULL; - struct exynos5420_gpio_part1 *gpio1 = - (struct exynos5420_gpio_part1 *)samsung_get_base_gpio_part1(); - struct exynos5420_gpio_part4 *gpio4 = - (struct exynos5420_gpio_part4 *)samsung_get_base_gpio_part4();
switch (peripheral) { case PERIPH_ID_SPI0: - bank = &gpio1->a2; - cfg = GPIO_FUNC(0x2); - pin = 0; + pin = EXYNOS5420_GPIO_A20; + cfg = S5P_GPIO_FUNC(0x2); break; case PERIPH_ID_SPI1: - bank = &gpio1->a2; - cfg = GPIO_FUNC(0x2); - pin = 4; + pin = EXYNOS5420_GPIO_A24; + cfg = S5P_GPIO_FUNC(0x2); break; case PERIPH_ID_SPI2: - bank = &gpio1->b1; - cfg = GPIO_FUNC(0x5); - pin = 1; + pin = EXYNOS5420_GPIO_B11; + cfg = S5P_GPIO_FUNC(0x5); break; case PERIPH_ID_SPI3: - bank = &gpio4->f1; - cfg = GPIO_FUNC(0x2); - pin = 0; + pin = EXYNOS5420_GPIO_F10; + cfg = S5P_GPIO_FUNC(0x2); break; case PERIPH_ID_SPI4: cfg = 0; @@ -489,11 +433,13 @@ void exynos5420_spi_config(int peripheral)
if (peripheral != PERIPH_ID_SPI4) { for (i = pin; i < pin + 4; i++) - s5p_gpio_cfg_pin(bank, i, cfg); + gpio_cfg_pin(i, cfg); } else { for (i = 0; i < 2; i++) { - s5p_gpio_cfg_pin(&gpio4->f0, i + 2, GPIO_FUNC(0x4)); - s5p_gpio_cfg_pin(&gpio4->e0, i + 4, GPIO_FUNC(0x4)); + gpio_cfg_pin(EXYNOS5420_GPIO_F02 + i, + S5P_GPIO_FUNC(0x4)); + gpio_cfg_pin(EXYNOS5420_GPIO_E04 + i, + S5P_GPIO_FUNC(0x4)); } } } @@ -588,76 +534,70 @@ static int exynos5420_pinmux_config(int peripheral, int flags)
static void exynos4_i2c_config(int peripheral, int flags) { - struct exynos4_gpio_part1 *gpio1 = - (struct exynos4_gpio_part1 *) samsung_get_base_gpio_part1(); - switch (peripheral) { case PERIPH_ID_I2C0: - s5p_gpio_cfg_pin(&gpio1->d1, 0, GPIO_FUNC(0x2)); - s5p_gpio_cfg_pin(&gpio1->d1, 1, GPIO_FUNC(0x2)); + gpio_cfg_pin(EXYNOS4_GPIO_D10, S5P_GPIO_FUNC(0x2)); + gpio_cfg_pin(EXYNOS4_GPIO_D11, S5P_GPIO_FUNC(0x2)); break; case PERIPH_ID_I2C1: - s5p_gpio_cfg_pin(&gpio1->d1, 2, GPIO_FUNC(0x2)); - s5p_gpio_cfg_pin(&gpio1->d1, 3, GPIO_FUNC(0x2)); + gpio_cfg_pin(EXYNOS4_GPIO_D12, S5P_GPIO_FUNC(0x2)); + gpio_cfg_pin(EXYNOS4_GPIO_D13, S5P_GPIO_FUNC(0x2)); break; case PERIPH_ID_I2C2: - s5p_gpio_cfg_pin(&gpio1->a0, 6, GPIO_FUNC(0x3)); - s5p_gpio_cfg_pin(&gpio1->a0, 7, GPIO_FUNC(0x3)); + gpio_cfg_pin(EXYNOS4_GPIO_A06, S5P_GPIO_FUNC(0x3)); + gpio_cfg_pin(EXYNOS4_GPIO_A07, S5P_GPIO_FUNC(0x3)); break; case PERIPH_ID_I2C3: - s5p_gpio_cfg_pin(&gpio1->a1, 2, GPIO_FUNC(0x3)); - s5p_gpio_cfg_pin(&gpio1->a1, 3, GPIO_FUNC(0x3)); + gpio_cfg_pin(EXYNOS4_GPIO_A12, S5P_GPIO_FUNC(0x3)); + gpio_cfg_pin(EXYNOS4_GPIO_A13, S5P_GPIO_FUNC(0x3)); break; case PERIPH_ID_I2C4: - s5p_gpio_cfg_pin(&gpio1->b, 2, GPIO_FUNC(0x3)); - s5p_gpio_cfg_pin(&gpio1->b, 3, GPIO_FUNC(0x3)); + gpio_cfg_pin(EXYNOS4_GPIO_B2, S5P_GPIO_FUNC(0x3)); + gpio_cfg_pin(EXYNOS4_GPIO_B3, S5P_GPIO_FUNC(0x3)); break; case PERIPH_ID_I2C5: - s5p_gpio_cfg_pin(&gpio1->b, 6, GPIO_FUNC(0x3)); - s5p_gpio_cfg_pin(&gpio1->b, 7, GPIO_FUNC(0x3)); + gpio_cfg_pin(EXYNOS4_GPIO_B6, S5P_GPIO_FUNC(0x3)); + gpio_cfg_pin(EXYNOS4_GPIO_B7, S5P_GPIO_FUNC(0x3)); break; case PERIPH_ID_I2C6: - s5p_gpio_cfg_pin(&gpio1->c1, 3, GPIO_FUNC(0x4)); - s5p_gpio_cfg_pin(&gpio1->c1, 4, GPIO_FUNC(0x4)); + gpio_cfg_pin(EXYNOS4_GPIO_C13, S5P_GPIO_FUNC(0x4)); + gpio_cfg_pin(EXYNOS4_GPIO_C14, S5P_GPIO_FUNC(0x4)); break; case PERIPH_ID_I2C7: - s5p_gpio_cfg_pin(&gpio1->d0, 2, GPIO_FUNC(0x3)); - s5p_gpio_cfg_pin(&gpio1->d0, 3, GPIO_FUNC(0x3)); + gpio_cfg_pin(EXYNOS4_GPIO_D02, S5P_GPIO_FUNC(0x3)); + gpio_cfg_pin(EXYNOS4_GPIO_D03, S5P_GPIO_FUNC(0x3)); break; } }
static int exynos4_mmc_config(int peripheral, int flags) { - struct exynos4_gpio_part2 *gpio2 = - (struct exynos4_gpio_part2 *)samsung_get_base_gpio_part2(); - struct s5p_gpio_bank *bank, *bank_ext; - int i; + int i, start = 0, start_ext = 0;
switch (peripheral) { case PERIPH_ID_SDMMC0: - bank = &gpio2->k0; - bank_ext = &gpio2->k1; + start = EXYNOS4_GPIO_K00; + start_ext = EXYNOS4_GPIO_K13; break; case PERIPH_ID_SDMMC2: - bank = &gpio2->k2; - bank_ext = &gpio2->k3; + start = EXYNOS4_GPIO_K20; + start_ext = EXYNOS4_GPIO_K33; break; default: return -1; } - for (i = 0; i < 7; i++) { - if (i == 2) + for (i = start; i < (start + 7); i++) { + if (i == (start + 2)) continue; - s5p_gpio_cfg_pin(bank, i, GPIO_FUNC(0x2)); - s5p_gpio_set_pull(bank, i, GPIO_PULL_NONE); - s5p_gpio_set_drv(bank, i, GPIO_DRV_4X); + gpio_cfg_pin(i, S5P_GPIO_FUNC(0x2)); + gpio_set_pull(i, S5P_GPIO_PULL_NONE); + gpio_set_drv(i, S5P_GPIO_DRV_4X); } if (flags & PINMUX_FLAG_8BIT_MODE) { - for (i = 3; i < 7; i++) { - s5p_gpio_cfg_pin(bank_ext, i, GPIO_FUNC(0x3)); - s5p_gpio_set_pull(bank_ext, i, GPIO_PULL_NONE); - s5p_gpio_set_drv(bank_ext, i, GPIO_DRV_4X); + for (i = start_ext; i < (start_ext + 4); i++) { + gpio_cfg_pin(i, S5P_GPIO_FUNC(0x3)); + gpio_set_pull(i, S5P_GPIO_PULL_NONE); + gpio_set_drv(i, S5P_GPIO_DRV_4X); } }
@@ -666,41 +606,138 @@ static int exynos4_mmc_config(int peripheral, int flags)
static void exynos4_uart_config(int peripheral) { - struct exynos4_gpio_part1 *gpio1 = - (struct exynos4_gpio_part1 *)samsung_get_base_gpio_part1(); - struct s5p_gpio_bank *bank; int i, start, count;
switch (peripheral) { case PERIPH_ID_UART0: - bank = &gpio1->a0; - start = 0; + start = EXYNOS4_GPIO_A00; count = 4; break; case PERIPH_ID_UART1: - bank = &gpio1->a0; - start = 4; + start = EXYNOS4_GPIO_A04; count = 4; break; case PERIPH_ID_UART2: - bank = &gpio1->a1; - start = 0; + start = EXYNOS4_GPIO_A10; count = 4; break; case PERIPH_ID_UART3: - bank = &gpio1->a1; - start = 4; + start = EXYNOS4_GPIO_A14; count = 2; break; default: debug("%s: invalid peripheral %d", __func__, peripheral); return; } - for (i = start; i < start + count; i++) { - s5p_gpio_set_pull(bank, i, GPIO_PULL_NONE); - s5p_gpio_cfg_pin(bank, i, GPIO_FUNC(0x2)); + for (i = start; i < (start + count); i++) { + gpio_set_pull(i, S5P_GPIO_PULL_NONE); + gpio_cfg_pin(i, S5P_GPIO_FUNC(0x2)); + } +} + +static void exynos4x12_i2c_config(int peripheral, int flags) +{ + switch (peripheral) { + case PERIPH_ID_I2C0: + gpio_cfg_pin(EXYNOS4X12_GPIO_D10, S5P_GPIO_FUNC(0x2)); + gpio_cfg_pin(EXYNOS4X12_GPIO_D11, S5P_GPIO_FUNC(0x2)); + break; + case PERIPH_ID_I2C1: + gpio_cfg_pin(EXYNOS4X12_GPIO_D12, S5P_GPIO_FUNC(0x2)); + gpio_cfg_pin(EXYNOS4X12_GPIO_D13, S5P_GPIO_FUNC(0x2)); + break; + case PERIPH_ID_I2C2: + gpio_cfg_pin(EXYNOS4X12_GPIO_A06, S5P_GPIO_FUNC(0x3)); + gpio_cfg_pin(EXYNOS4X12_GPIO_A07, S5P_GPIO_FUNC(0x3)); + break; + case PERIPH_ID_I2C3: + gpio_cfg_pin(EXYNOS4X12_GPIO_A12, S5P_GPIO_FUNC(0x3)); + gpio_cfg_pin(EXYNOS4X12_GPIO_A13, S5P_GPIO_FUNC(0x3)); + break; + case PERIPH_ID_I2C4: + gpio_cfg_pin(EXYNOS4X12_GPIO_B2, S5P_GPIO_FUNC(0x3)); + gpio_cfg_pin(EXYNOS4X12_GPIO_B3, S5P_GPIO_FUNC(0x3)); + break; + case PERIPH_ID_I2C5: + gpio_cfg_pin(EXYNOS4X12_GPIO_B6, S5P_GPIO_FUNC(0x3)); + gpio_cfg_pin(EXYNOS4X12_GPIO_B7, S5P_GPIO_FUNC(0x3)); + break; + case PERIPH_ID_I2C6: + gpio_cfg_pin(EXYNOS4X12_GPIO_C13, S5P_GPIO_FUNC(0x4)); + gpio_cfg_pin(EXYNOS4X12_GPIO_C14, S5P_GPIO_FUNC(0x4)); + break; + case PERIPH_ID_I2C7: + gpio_cfg_pin(EXYNOS4X12_GPIO_D02, S5P_GPIO_FUNC(0x3)); + gpio_cfg_pin(EXYNOS4X12_GPIO_D03, S5P_GPIO_FUNC(0x3)); + break; + } +} + +static int exynos4x12_mmc_config(int peripheral, int flags) +{ + int i, start = 0, start_ext = 0; + + switch (peripheral) { + case PERIPH_ID_SDMMC0: + start = EXYNOS4X12_GPIO_K00; + start_ext = EXYNOS4X12_GPIO_K13; + break; + case PERIPH_ID_SDMMC2: + start = EXYNOS4X12_GPIO_K20; + start_ext = EXYNOS4X12_GPIO_K33; + break; + default: + return -1; } + for (i = start; i < (start + 7); i++) { + if (i == (start + 2)) + continue; + gpio_cfg_pin(i, S5P_GPIO_FUNC(0x2)); + gpio_set_pull(i, S5P_GPIO_PULL_NONE); + gpio_set_drv(i, S5P_GPIO_DRV_4X); + } + if (flags & PINMUX_FLAG_8BIT_MODE) { + for (i = start_ext; i < (start_ext + 4); i++) { + gpio_cfg_pin(i, S5P_GPIO_FUNC(0x3)); + gpio_set_pull(i, S5P_GPIO_PULL_NONE); + gpio_set_drv(i, S5P_GPIO_DRV_4X); + } + } + + return 0; } + +static void exynos4x12_uart_config(int peripheral) +{ + int i, start, count; + + switch (peripheral) { + case PERIPH_ID_UART0: + start = EXYNOS4X12_GPIO_A00; + count = 4; + break; + case PERIPH_ID_UART1: + start = EXYNOS4X12_GPIO_A04; + count = 4; + break; + case PERIPH_ID_UART2: + start = EXYNOS4X12_GPIO_A10; + count = 4; + break; + case PERIPH_ID_UART3: + start = EXYNOS4X12_GPIO_A14; + count = 2; + break; + default: + debug("%s: invalid peripheral %d", __func__, peripheral); + return; + } + for (i = start; i < (start + count); i++) { + gpio_set_pull(i, S5P_GPIO_PULL_NONE); + gpio_cfg_pin(i, S5P_GPIO_FUNC(0x2)); + } +} + static int exynos4_pinmux_config(int peripheral, int flags) { switch (peripheral) { @@ -736,6 +773,41 @@ static int exynos4_pinmux_config(int peripheral, int flags) return 0; }
+static int exynos4x12_pinmux_config(int peripheral, int flags) +{ + switch (peripheral) { + case PERIPH_ID_UART0: + case PERIPH_ID_UART1: + case PERIPH_ID_UART2: + case PERIPH_ID_UART3: + exynos4x12_uart_config(peripheral); + break; + case PERIPH_ID_I2C0: + case PERIPH_ID_I2C1: + case PERIPH_ID_I2C2: + case PERIPH_ID_I2C3: + case PERIPH_ID_I2C4: + case PERIPH_ID_I2C5: + case PERIPH_ID_I2C6: + case PERIPH_ID_I2C7: + exynos4x12_i2c_config(peripheral, flags); + break; + case PERIPH_ID_SDMMC0: + case PERIPH_ID_SDMMC2: + return exynos4x12_mmc_config(peripheral, flags); + case PERIPH_ID_SDMMC1: + case PERIPH_ID_SDMMC3: + case PERIPH_ID_SDMMC4: + debug("SDMMC device %d not implemented\n", peripheral); + return -1; + default: + debug("%s: invalid peripheral %d", __func__, peripheral); + return -1; + } + + return 0; +} + int exynos_pinmux_config(int peripheral, int flags) { if (cpu_is_exynos5()) { @@ -744,11 +816,14 @@ int exynos_pinmux_config(int peripheral, int flags) else if (proid_is_exynos5250()) return exynos5_pinmux_config(peripheral, flags); } else if (cpu_is_exynos4()) { - return exynos4_pinmux_config(peripheral, flags); - } else { - debug("pinmux functionality not supported\n"); + if (proid_is_exynos4412()) + return exynos4x12_pinmux_config(peripheral, flags); + else + return exynos4_pinmux_config(peripheral, flags); }
+ debug("pinmux functionality not supported\n"); + return -1; }
@@ -787,7 +862,7 @@ int pinmux_decode_periph_id(const void *blob, int node) return exynos5_pinmux_decode_periph_id(blob, node); else if (cpu_is_exynos4()) return exynos4_pinmux_decode_periph_id(blob, node); - else - return PERIPH_ID_NONE; + + return PERIPH_ID_NONE; } #endif diff --git a/arch/arm/dts/exynos4210-origen.dts b/arch/arm/dts/exynos4210-origen.dts index 5c9d2ae..15059d2 100644 --- a/arch/arm/dts/exynos4210-origen.dts +++ b/arch/arm/dts/exynos4210-origen.dts @@ -36,10 +36,10 @@ sdhci@12530000 { samsung,bus-width = <4>; samsung,timing = <1 2 3>; - cd-gpios = <&gpio 0x2008002 0>; + cd-gpios = <&gpio 0xA2 0>; };
sdhci@12540000 { status = "disabled"; }; -}; \ No newline at end of file +}; diff --git a/arch/arm/dts/exynos4210-trats.dts b/arch/arm/dts/exynos4210-trats.dts index 992e023..0ff6939 100644 --- a/arch/arm/dts/exynos4210-trats.dts +++ b/arch/arm/dts/exynos4210-trats.dts @@ -101,7 +101,7 @@ sdhci@12510000 { samsung,bus-width = <8>; samsung,timing = <1 3 3>; - pwr-gpios = <&gpio 0x2008002 0>; + pwr-gpios = <&gpio 0xA2 0>; };
sdhci@12520000 { @@ -111,10 +111,10 @@ sdhci@12530000 { samsung,bus-width = <4>; samsung,timing = <1 2 3>; - cd-gpios = <&gpio 0x20c6004 0>; + cd-gpios = <&gpio 0x39C 0>; };
sdhci@12540000 { status = "disabled"; }; -}; \ No newline at end of file +}; diff --git a/arch/arm/dts/exynos4210-universal_c210.dts b/arch/arm/dts/exynos4210-universal_c210.dts index 1cdd981..6941906 100644 --- a/arch/arm/dts/exynos4210-universal_c210.dts +++ b/arch/arm/dts/exynos4210-universal_c210.dts @@ -24,7 +24,7 @@ sdhci@12510000 { samsung,bus-width = <8>; samsung,timing = <1 3 3>; - pwr-gpios = <&gpio 0x2008002 0>; + pwr-gpios = <&gpio 0xA2 0>; };
sdhci@12520000 { @@ -34,7 +34,7 @@ sdhci@12530000 { samsung,bus-width = <4>; samsung,timing = <1 2 3>; - cd-gpios = <&gpio 0x20c6004 0>; + cd-gpios = <&gpio 0x39C 0>; };
sdhci@12540000 { diff --git a/arch/arm/dts/exynos4412-trats2.dts b/arch/arm/dts/exynos4412-trats2.dts index 7d32067..1596f83 100644 --- a/arch/arm/dts/exynos4412-trats2.dts +++ b/arch/arm/dts/exynos4412-trats2.dts @@ -415,7 +415,7 @@ sdhci@12510000 { samsung,bus-width = <8>; samsung,timing = <1 3 3>; - pwr-gpios = <&gpio 0x2004002 0>; + pwr-gpios = <&gpio 0xB2 0>; };
sdhci@12520000 { @@ -425,7 +425,7 @@ sdhci@12530000 { samsung,bus-width = <4>; samsung,timing = <1 2 3>; - cd-gpios = <&gpio 0x20C6004 0>; + cd-gpios = <&gpio 0x3BC 0>; };
sdhci@12540000 { diff --git a/arch/arm/include/asm/arch-exynos/cpu.h b/arch/arm/include/asm/arch-exynos/cpu.h index fdf73b5..ba71714 100644 --- a/arch/arm/include/asm/arch-exynos/cpu.h +++ b/arch/arm/include/asm/arch-exynos/cpu.h @@ -98,7 +98,7 @@ #define EXYNOS5_I2C_SPACING 0x10000
#define EXYNOS5_AUDIOSS_BASE 0x03810000 -#define EXYNOS5_GPIO_PART4_BASE 0x03860000 +#define EXYNOS5_GPIO_PART8_BASE 0x03860000 #define EXYNOS5_PRO_ID 0x10000000 #define EXYNOS5_CLOCK_BASE 0x10010000 #define EXYNOS5_POWER_BASE 0x10040000 @@ -108,9 +108,13 @@ #define EXYNOS5_WATCHDOG_BASE 0x101D0000 #define EXYNOS5_ACE_SFR_BASE 0x10830000 #define EXYNOS5_DMC_PHY_BASE 0x10C00000 -#define EXYNOS5_GPIO_PART3_BASE 0x10D10000 +#define EXYNOS5_GPIO_PART5_BASE 0x10D10000 +#define EXYNOS5_GPIO_PART6_BASE 0x10D10060 +#define EXYNOS5_GPIO_PART7_BASE 0x10D100C0 #define EXYNOS5_DMC_CTRL_BASE 0x10DD0000 #define EXYNOS5_GPIO_PART1_BASE 0x11400000 +#define EXYNOS5_GPIO_PART2_BASE 0x114002E0 +#define EXYNOS5_GPIO_PART3_BASE 0x11400C00 #define EXYNOS5_MIPI_DSIM_BASE 0x11D00000 #define EXYNOS5_USB_HOST_XHCI_BASE 0x12000000 #define EXYNOS5_USB3PHY_BASE 0x12100000 @@ -125,7 +129,7 @@ #define EXYNOS5_I2S_BASE 0x12D60000 #define EXYNOS5_PWMTIMER_BASE 0x12DD0000 #define EXYNOS5_SPI_ISP_BASE 0x131A0000 -#define EXYNOS5_GPIO_PART2_BASE 0x13400000 +#define EXYNOS5_GPIO_PART4_BASE 0x13400000 #define EXYNOS5_FIMD_BASE 0x14400000 #define EXYNOS5_DP_BASE 0x145B0000
@@ -135,7 +139,7 @@
/* EXYNOS5420 */ #define EXYNOS5420_AUDIOSS_BASE 0x03810000 -#define EXYNOS5420_GPIO_PART5_BASE 0x03860000 +#define EXYNOS5420_GPIO_PART6_BASE 0x03860000 #define EXYNOS5420_PRO_ID 0x10000000 #define EXYNOS5420_CLOCK_BASE 0x10010000 #define EXYNOS5420_POWER_BASE 0x10040000 @@ -158,8 +162,9 @@ #define EXYNOS5420_PWMTIMER_BASE 0x12DD0000 #define EXYNOS5420_SPI_ISP_BASE 0x131A0000 #define EXYNOS5420_GPIO_PART2_BASE 0x13400000 -#define EXYNOS5420_GPIO_PART3_BASE 0x13410000 -#define EXYNOS5420_GPIO_PART4_BASE 0x14000000 +#define EXYNOS5420_GPIO_PART3_BASE 0x13400C00 +#define EXYNOS5420_GPIO_PART4_BASE 0x13410000 +#define EXYNOS5420_GPIO_PART5_BASE 0x14000000 #define EXYNOS5420_GPIO_PART1_BASE 0x14010000 #define EXYNOS5420_MIPI_DSIM_BASE 0x14500000 #define EXYNOS5420_DP_BASE 0x145B0000 diff --git a/arch/arm/include/asm/arch-exynos/gpio.h b/arch/arm/include/asm/arch-exynos/gpio.h index d6868fa..be5113f 100644 --- a/arch/arm/include/asm/arch-exynos/gpio.h +++ b/arch/arm/include/asm/arch-exynos/gpio.h @@ -19,328 +19,1515 @@ struct s5p_gpio_bank { unsigned char res1[8]; };
-struct exynos4_gpio_part1 { - struct s5p_gpio_bank a0; - struct s5p_gpio_bank a1; - struct s5p_gpio_bank b; - struct s5p_gpio_bank c0; - struct s5p_gpio_bank c1; - struct s5p_gpio_bank d0; - struct s5p_gpio_bank d1; - struct s5p_gpio_bank e0; - struct s5p_gpio_bank e1; - struct s5p_gpio_bank e2; - struct s5p_gpio_bank e3; - struct s5p_gpio_bank e4; - struct s5p_gpio_bank f0; - struct s5p_gpio_bank f1; - struct s5p_gpio_bank f2; - struct s5p_gpio_bank f3; -}; +/* GPIO pins per bank */ +#define GPIO_PER_BANK 8
-struct exynos4_gpio_part2 { - struct s5p_gpio_bank j0; - struct s5p_gpio_bank j1; - struct s5p_gpio_bank k0; - struct s5p_gpio_bank k1; - struct s5p_gpio_bank k2; - struct s5p_gpio_bank k3; - struct s5p_gpio_bank l0; - struct s5p_gpio_bank l1; - struct s5p_gpio_bank l2; - struct s5p_gpio_bank y0; - struct s5p_gpio_bank y1; - struct s5p_gpio_bank y2; - struct s5p_gpio_bank y3; - struct s5p_gpio_bank y4; - struct s5p_gpio_bank y5; - struct s5p_gpio_bank y6; - struct s5p_gpio_bank res1[80]; - struct s5p_gpio_bank x0; - struct s5p_gpio_bank x1; - struct s5p_gpio_bank x2; - struct s5p_gpio_bank x3; -}; +/* A list of valid GPIO numbers for the asm-generic/gpio.h interface */ +enum exynos4_gpio_pin { + /* GPIO_PART1_STARTS */ + EXYNOS4_GPIO_A00, /* 0 */ + EXYNOS4_GPIO_A01, + EXYNOS4_GPIO_A02, + EXYNOS4_GPIO_A03, + EXYNOS4_GPIO_A04, + EXYNOS4_GPIO_A05, + EXYNOS4_GPIO_A06, + EXYNOS4_GPIO_A07, + EXYNOS4_GPIO_A10, /* 8 */ + EXYNOS4_GPIO_A11, + EXYNOS4_GPIO_A12, + EXYNOS4_GPIO_A13, + EXYNOS4_GPIO_A14, + EXYNOS4_GPIO_A15, + EXYNOS4_GPIO_A16, + EXYNOS4_GPIO_A17, + EXYNOS4_GPIO_B0, /* 16 0x10 */ + EXYNOS4_GPIO_B1, + EXYNOS4_GPIO_B2, + EXYNOS4_GPIO_B3, + EXYNOS4_GPIO_B4, + EXYNOS4_GPIO_B5, + EXYNOS4_GPIO_B6, + EXYNOS4_GPIO_B7, + EXYNOS4_GPIO_C00, /* 24 0x18 */ + EXYNOS4_GPIO_C01, + EXYNOS4_GPIO_C02, + EXYNOS4_GPIO_C03, + EXYNOS4_GPIO_C04, + EXYNOS4_GPIO_C05, + EXYNOS4_GPIO_C06, + EXYNOS4_GPIO_C07, + EXYNOS4_GPIO_C10, /* 32 0x20*/ + EXYNOS4_GPIO_C11, + EXYNOS4_GPIO_C12, + EXYNOS4_GPIO_C13, + EXYNOS4_GPIO_C14, + EXYNOS4_GPIO_C15, + EXYNOS4_GPIO_C16, + EXYNOS4_GPIO_C17, + EXYNOS4_GPIO_D00, /* 40 0x28 */ + EXYNOS4_GPIO_D01, + EXYNOS4_GPIO_D02, + EXYNOS4_GPIO_D03, + EXYNOS4_GPIO_D04, + EXYNOS4_GPIO_D05, + EXYNOS4_GPIO_D06, + EXYNOS4_GPIO_D07, + EXYNOS4_GPIO_D10, /* 48 0x30 */ + EXYNOS4_GPIO_D11, + EXYNOS4_GPIO_D12, + EXYNOS4_GPIO_D13, + EXYNOS4_GPIO_D14, + EXYNOS4_GPIO_D15, + EXYNOS4_GPIO_D16, + EXYNOS4_GPIO_D17, + EXYNOS4_GPIO_E00, /* 56 0x38 */ + EXYNOS4_GPIO_E01, + EXYNOS4_GPIO_E02, + EXYNOS4_GPIO_E03, + EXYNOS4_GPIO_E04, + EXYNOS4_GPIO_E05, + EXYNOS4_GPIO_E06, + EXYNOS4_GPIO_E07, + EXYNOS4_GPIO_E10, /* 64 0x40 */ + EXYNOS4_GPIO_E11, + EXYNOS4_GPIO_E12, + EXYNOS4_GPIO_E13, + EXYNOS4_GPIO_E14, + EXYNOS4_GPIO_E15, + EXYNOS4_GPIO_E16, + EXYNOS4_GPIO_E17, + EXYNOS4_GPIO_E20, /* 72 0x48 */ + EXYNOS4_GPIO_E21, + EXYNOS4_GPIO_E22, + EXYNOS4_GPIO_E23, + EXYNOS4_GPIO_E24, + EXYNOS4_GPIO_E25, + EXYNOS4_GPIO_E26, + EXYNOS4_GPIO_E27, + EXYNOS4_GPIO_E30, /* 80 0x50 */ + EXYNOS4_GPIO_E31, + EXYNOS4_GPIO_E32, + EXYNOS4_GPIO_E33, + EXYNOS4_GPIO_E34, + EXYNOS4_GPIO_E35, + EXYNOS4_GPIO_E36, + EXYNOS4_GPIO_E37, + EXYNOS4_GPIO_E40, /* 88 0x58 */ + EXYNOS4_GPIO_E41, + EXYNOS4_GPIO_E42, + EXYNOS4_GPIO_E43, + EXYNOS4_GPIO_E44, + EXYNOS4_GPIO_E45, + EXYNOS4_GPIO_E46, + EXYNOS4_GPIO_E47, + EXYNOS4_GPIO_F00, /* 96 0x60 */ + EXYNOS4_GPIO_F01, + EXYNOS4_GPIO_F02, + EXYNOS4_GPIO_F03, + EXYNOS4_GPIO_F04, + EXYNOS4_GPIO_F05, + EXYNOS4_GPIO_F06, + EXYNOS4_GPIO_F07, + EXYNOS4_GPIO_F10, /* 104 0x68 */ + EXYNOS4_GPIO_F11, + EXYNOS4_GPIO_F12, + EXYNOS4_GPIO_F13, + EXYNOS4_GPIO_F14, + EXYNOS4_GPIO_F15, + EXYNOS4_GPIO_F16, + EXYNOS4_GPIO_F17, + EXYNOS4_GPIO_F20, /* 112 0x70 */ + EXYNOS4_GPIO_F21, + EXYNOS4_GPIO_F22, + EXYNOS4_GPIO_F23, + EXYNOS4_GPIO_F24, + EXYNOS4_GPIO_F25, + EXYNOS4_GPIO_F26, + EXYNOS4_GPIO_F27, + EXYNOS4_GPIO_F30, /* 120 0x78 */ + EXYNOS4_GPIO_F31, + EXYNOS4_GPIO_F32, + EXYNOS4_GPIO_F33, + EXYNOS4_GPIO_F34, + EXYNOS4_GPIO_F35, + EXYNOS4_GPIO_F36, + EXYNOS4_GPIO_F37,
-struct exynos4_gpio_part3 { - struct s5p_gpio_bank z; -}; + /* GPIO_PART2_STARTS */ + EXYNOS4_GPIO_MAX_PORT_PART_1, /* 128 0x80 */ + EXYNOS4_GPIO_J00 = EXYNOS4_GPIO_MAX_PORT_PART_1, + EXYNOS4_GPIO_J01, + EXYNOS4_GPIO_J02, + EXYNOS4_GPIO_J03, + EXYNOS4_GPIO_J04, + EXYNOS4_GPIO_J05, + EXYNOS4_GPIO_J06, + EXYNOS4_GPIO_J07, + EXYNOS4_GPIO_J10, /* 136 0x88 */ + EXYNOS4_GPIO_J11, + EXYNOS4_GPIO_J12, + EXYNOS4_GPIO_J13, + EXYNOS4_GPIO_J14, + EXYNOS4_GPIO_J15, + EXYNOS4_GPIO_J16, + EXYNOS4_GPIO_J17, + EXYNOS4_GPIO_K00, /* 144 0x90 */ + EXYNOS4_GPIO_K01, + EXYNOS4_GPIO_K02, + EXYNOS4_GPIO_K03, + EXYNOS4_GPIO_K04, + EXYNOS4_GPIO_K05, + EXYNOS4_GPIO_K06, + EXYNOS4_GPIO_K07, + EXYNOS4_GPIO_K10, /* 152 0x98 */ + EXYNOS4_GPIO_K11, + EXYNOS4_GPIO_K12, + EXYNOS4_GPIO_K13, + EXYNOS4_GPIO_K14, + EXYNOS4_GPIO_K15, + EXYNOS4_GPIO_K16, + EXYNOS4_GPIO_K17, + EXYNOS4_GPIO_K20, /* 160 0xA0 */ + EXYNOS4_GPIO_K21, + EXYNOS4_GPIO_K22, + EXYNOS4_GPIO_K23, + EXYNOS4_GPIO_K24, + EXYNOS4_GPIO_K25, + EXYNOS4_GPIO_K26, + EXYNOS4_GPIO_K27, + EXYNOS4_GPIO_K30, /* 168 0xA8 */ + EXYNOS4_GPIO_K31, + EXYNOS4_GPIO_K32, + EXYNOS4_GPIO_K33, + EXYNOS4_GPIO_K34, + EXYNOS4_GPIO_K35, + EXYNOS4_GPIO_K36, + EXYNOS4_GPIO_K37, + EXYNOS4_GPIO_L00, /* 176 0xB0 */ + EXYNOS4_GPIO_L01, + EXYNOS4_GPIO_L02, + EXYNOS4_GPIO_L03, + EXYNOS4_GPIO_L04, + EXYNOS4_GPIO_L05, + EXYNOS4_GPIO_L06, + EXYNOS4_GPIO_L07, + EXYNOS4_GPIO_L10, /* 184 0xB8 */ + EXYNOS4_GPIO_L11, + EXYNOS4_GPIO_L12, + EXYNOS4_GPIO_L13, + EXYNOS4_GPIO_L14, + EXYNOS4_GPIO_L15, + EXYNOS4_GPIO_L16, + EXYNOS4_GPIO_L17, + EXYNOS4_GPIO_L20, /* 192 0xC0 */ + EXYNOS4_GPIO_L21, + EXYNOS4_GPIO_L22, + EXYNOS4_GPIO_L23, + EXYNOS4_GPIO_L24, + EXYNOS4_GPIO_L25, + EXYNOS4_GPIO_L26, + EXYNOS4_GPIO_L27, + EXYNOS4_GPIO_Y00, /* 200 0xC8 */ + EXYNOS4_GPIO_Y01, + EXYNOS4_GPIO_Y02, + EXYNOS4_GPIO_Y03, + EXYNOS4_GPIO_Y04, + EXYNOS4_GPIO_Y05, + EXYNOS4_GPIO_Y06, + EXYNOS4_GPIO_Y07, + EXYNOS4_GPIO_Y10, /* 208 0xD0 */ + EXYNOS4_GPIO_Y11, + EXYNOS4_GPIO_Y12, + EXYNOS4_GPIO_Y13, + EXYNOS4_GPIO_Y14, + EXYNOS4_GPIO_Y15, + EXYNOS4_GPIO_Y16, + EXYNOS4_GPIO_Y17, + EXYNOS4_GPIO_Y20, /* 216 0xD8 */ + EXYNOS4_GPIO_Y21, + EXYNOS4_GPIO_Y22, + EXYNOS4_GPIO_Y23, + EXYNOS4_GPIO_Y24, + EXYNOS4_GPIO_Y25, + EXYNOS4_GPIO_Y26, + EXYNOS4_GPIO_Y27, + EXYNOS4_GPIO_Y30, /* 224 0xE0 */ + EXYNOS4_GPIO_Y31, + EXYNOS4_GPIO_Y32, + EXYNOS4_GPIO_Y33, + EXYNOS4_GPIO_Y34, + EXYNOS4_GPIO_Y35, + EXYNOS4_GPIO_Y36, + EXYNOS4_GPIO_Y37, + EXYNOS4_GPIO_Y40, /* 232 0xE8 */ + EXYNOS4_GPIO_Y41, + EXYNOS4_GPIO_Y42, + EXYNOS4_GPIO_Y43, + EXYNOS4_GPIO_Y44, + EXYNOS4_GPIO_Y45, + EXYNOS4_GPIO_Y46, + EXYNOS4_GPIO_Y47, + EXYNOS4_GPIO_Y50, /* 240 0xF0 */ + EXYNOS4_GPIO_Y51, + EXYNOS4_GPIO_Y52, + EXYNOS4_GPIO_Y53, + EXYNOS4_GPIO_Y54, + EXYNOS4_GPIO_Y55, + EXYNOS4_GPIO_Y56, + EXYNOS4_GPIO_Y57, + EXYNOS4_GPIO_Y60, /* 248 0xF8 */ + EXYNOS4_GPIO_Y61, + EXYNOS4_GPIO_Y62, + EXYNOS4_GPIO_Y63, + EXYNOS4_GPIO_Y64, + EXYNOS4_GPIO_Y65, + EXYNOS4_GPIO_Y66, + EXYNOS4_GPIO_Y67, + EXYNOS4_GPIO_X00 = 896, /* 896 0x380 */ + EXYNOS4_GPIO_X01, + EXYNOS4_GPIO_X02, + EXYNOS4_GPIO_X03, + EXYNOS4_GPIO_X04, + EXYNOS4_GPIO_X05, + EXYNOS4_GPIO_X06, + EXYNOS4_GPIO_X07, + EXYNOS4_GPIO_X10, /* 904 0x388 */ + EXYNOS4_GPIO_X11, + EXYNOS4_GPIO_X12, + EXYNOS4_GPIO_X13, + EXYNOS4_GPIO_X14, + EXYNOS4_GPIO_X15, + EXYNOS4_GPIO_X16, + EXYNOS4_GPIO_X17, + EXYNOS4_GPIO_X20, /* 912 0x390 */ + EXYNOS4_GPIO_X21, + EXYNOS4_GPIO_X22, + EXYNOS4_GPIO_X23, + EXYNOS4_GPIO_X24, + EXYNOS4_GPIO_X25, + EXYNOS4_GPIO_X26, + EXYNOS4_GPIO_X27, + EXYNOS4_GPIO_X30, /* 920 0x398 */ + EXYNOS4_GPIO_X31, + EXYNOS4_GPIO_X32, + EXYNOS4_GPIO_X33, + EXYNOS4_GPIO_X34, + EXYNOS4_GPIO_X35, + EXYNOS4_GPIO_X36, + EXYNOS4_GPIO_X37, + + /* GPIO_PART3_STARTS */ + EXYNOS4_GPIO_MAX_PORT_PART_2, /* 928 0x3A0 */ + EXYNOS4_GPIO_Z0 = EXYNOS4_GPIO_MAX_PORT_PART_2, + EXYNOS4_GPIO_Z1, + EXYNOS4_GPIO_Z2, + EXYNOS4_GPIO_Z3, + EXYNOS4_GPIO_Z4, + EXYNOS4_GPIO_Z5, + EXYNOS4_GPIO_Z6, + EXYNOS4_GPIO_Z7,
-struct exynos4x12_gpio_part1 { - struct s5p_gpio_bank a0; - struct s5p_gpio_bank a1; - struct s5p_gpio_bank b; - struct s5p_gpio_bank c0; - struct s5p_gpio_bank c1; - struct s5p_gpio_bank d0; - struct s5p_gpio_bank d1; - struct s5p_gpio_bank res1[0x5]; - struct s5p_gpio_bank f0; - struct s5p_gpio_bank f1; - struct s5p_gpio_bank f2; - struct s5p_gpio_bank f3; - struct s5p_gpio_bank res2[0x2]; - struct s5p_gpio_bank j0; - struct s5p_gpio_bank j1; + EXYNOS4_GPIO_MAX_PORT };
-struct exynos4x12_gpio_part2 { - struct s5p_gpio_bank res1[0x2]; - struct s5p_gpio_bank k0; - struct s5p_gpio_bank k1; - struct s5p_gpio_bank k2; - struct s5p_gpio_bank k3; - struct s5p_gpio_bank l0; - struct s5p_gpio_bank l1; - struct s5p_gpio_bank l2; - struct s5p_gpio_bank y0; - struct s5p_gpio_bank y1; - struct s5p_gpio_bank y2; - struct s5p_gpio_bank y3; - struct s5p_gpio_bank y4; - struct s5p_gpio_bank y5; - struct s5p_gpio_bank y6; - struct s5p_gpio_bank res2[0x3]; - struct s5p_gpio_bank m0; - struct s5p_gpio_bank m1; - struct s5p_gpio_bank m2; - struct s5p_gpio_bank m3; - struct s5p_gpio_bank m4; - struct s5p_gpio_bank res3[0x48]; - struct s5p_gpio_bank x0; - struct s5p_gpio_bank x1; - struct s5p_gpio_bank x2; - struct s5p_gpio_bank x3; +enum exynos4X12_gpio_pin { + /* GPIO_PART1_STARTS */ + EXYNOS4X12_GPIO_A00, /* 0 */ + EXYNOS4X12_GPIO_A01, + EXYNOS4X12_GPIO_A02, + EXYNOS4X12_GPIO_A03, + EXYNOS4X12_GPIO_A04, + EXYNOS4X12_GPIO_A05, + EXYNOS4X12_GPIO_A06, + EXYNOS4X12_GPIO_A07, + EXYNOS4X12_GPIO_A10, /* 8 */ + EXYNOS4X12_GPIO_A11, + EXYNOS4X12_GPIO_A12, + EXYNOS4X12_GPIO_A13, + EXYNOS4X12_GPIO_A14, + EXYNOS4X12_GPIO_A15, + EXYNOS4X12_GPIO_A16, + EXYNOS4X12_GPIO_A17, + EXYNOS4X12_GPIO_B0, /* 16 0x10 */ + EXYNOS4X12_GPIO_B1, + EXYNOS4X12_GPIO_B2, + EXYNOS4X12_GPIO_B3, + EXYNOS4X12_GPIO_B4, + EXYNOS4X12_GPIO_B5, + EXYNOS4X12_GPIO_B6, + EXYNOS4X12_GPIO_B7, + EXYNOS4X12_GPIO_C00, /* 24 0x18 */ + EXYNOS4X12_GPIO_C01, + EXYNOS4X12_GPIO_C02, + EXYNOS4X12_GPIO_C03, + EXYNOS4X12_GPIO_C04, + EXYNOS4X12_GPIO_C05, + EXYNOS4X12_GPIO_C06, + EXYNOS4X12_GPIO_C07, + EXYNOS4X12_GPIO_C10, /* 32 0x20 */ + EXYNOS4X12_GPIO_C11, + EXYNOS4X12_GPIO_C12, + EXYNOS4X12_GPIO_C13, + EXYNOS4X12_GPIO_C14, + EXYNOS4X12_GPIO_C15, + EXYNOS4X12_GPIO_C16, + EXYNOS4X12_GPIO_C17, + EXYNOS4X12_GPIO_D00, /* 40 0x28 */ + EXYNOS4X12_GPIO_D01, + EXYNOS4X12_GPIO_D02, + EXYNOS4X12_GPIO_D03, + EXYNOS4X12_GPIO_D04, + EXYNOS4X12_GPIO_D05, + EXYNOS4X12_GPIO_D06, + EXYNOS4X12_GPIO_D07, + EXYNOS4X12_GPIO_D10, /* 48 0x30 */ + EXYNOS4X12_GPIO_D11, + EXYNOS4X12_GPIO_D12, + EXYNOS4X12_GPIO_D13, + EXYNOS4X12_GPIO_D14, + EXYNOS4X12_GPIO_D15, + EXYNOS4X12_GPIO_D16, + EXYNOS4X12_GPIO_D17, + EXYNOS4X12_GPIO_F00 = 96, /* 96 0x60 */ + EXYNOS4X12_GPIO_F01, + EXYNOS4X12_GPIO_F02, + EXYNOS4X12_GPIO_F03, + EXYNOS4X12_GPIO_F04, + EXYNOS4X12_GPIO_F05, + EXYNOS4X12_GPIO_F06, + EXYNOS4X12_GPIO_F07, + EXYNOS4X12_GPIO_F10, /* 104 0x68 */ + EXYNOS4X12_GPIO_F11, + EXYNOS4X12_GPIO_F12, + EXYNOS4X12_GPIO_F13, + EXYNOS4X12_GPIO_F14, + EXYNOS4X12_GPIO_F15, + EXYNOS4X12_GPIO_F16, + EXYNOS4X12_GPIO_F17, + EXYNOS4X12_GPIO_F20, /* 112 0x70 */ + EXYNOS4X12_GPIO_F21, + EXYNOS4X12_GPIO_F22, + EXYNOS4X12_GPIO_F23, + EXYNOS4X12_GPIO_F24, + EXYNOS4X12_GPIO_F25, + EXYNOS4X12_GPIO_F26, + EXYNOS4X12_GPIO_F27, + EXYNOS4X12_GPIO_F30, /* 120 0x78 */ + EXYNOS4X12_GPIO_F31, + EXYNOS4X12_GPIO_F32, + EXYNOS4X12_GPIO_F33, + EXYNOS4X12_GPIO_F34, + EXYNOS4X12_GPIO_F35, + EXYNOS4X12_GPIO_F36, + EXYNOS4X12_GPIO_F37, + EXYNOS4X12_GPIO_J00 = 144, /* 144 0x90 */ + EXYNOS4X12_GPIO_J01, + EXYNOS4X12_GPIO_J02, + EXYNOS4X12_GPIO_J03, + EXYNOS4X12_GPIO_J04, + EXYNOS4X12_GPIO_J05, + EXYNOS4X12_GPIO_J06, + EXYNOS4X12_GPIO_J07, + EXYNOS4X12_GPIO_J10, /* 152 0x98 */ + EXYNOS4X12_GPIO_J11, + EXYNOS4X12_GPIO_J12, + EXYNOS4X12_GPIO_J13, + EXYNOS4X12_GPIO_J14, + EXYNOS4X12_GPIO_J15, + EXYNOS4X12_GPIO_J16, + EXYNOS4X12_GPIO_J17, + + /* GPIO_PART2_STARTS */ + EXYNOS4X12_GPIO_MAX_PORT_PART_1,/* 160 0xA0 */ + EXYNOS4X12_GPIO_K00 = 176, /* 176 0xB0 */ + EXYNOS4X12_GPIO_K01, + EXYNOS4X12_GPIO_K02, + EXYNOS4X12_GPIO_K03, + EXYNOS4X12_GPIO_K04, + EXYNOS4X12_GPIO_K05, + EXYNOS4X12_GPIO_K06, + EXYNOS4X12_GPIO_K07, + EXYNOS4X12_GPIO_K10, /* 184 0xB8 */ + EXYNOS4X12_GPIO_K11, + EXYNOS4X12_GPIO_K12, + EXYNOS4X12_GPIO_K13, + EXYNOS4X12_GPIO_K14, + EXYNOS4X12_GPIO_K15, + EXYNOS4X12_GPIO_K16, + EXYNOS4X12_GPIO_K17, + EXYNOS4X12_GPIO_K20, /* 192 0xC0 */ + EXYNOS4X12_GPIO_K21, + EXYNOS4X12_GPIO_K22, + EXYNOS4X12_GPIO_K23, + EXYNOS4X12_GPIO_K24, + EXYNOS4X12_GPIO_K25, + EXYNOS4X12_GPIO_K26, + EXYNOS4X12_GPIO_K27, + EXYNOS4X12_GPIO_K30, /* 200 0xC8 */ + EXYNOS4X12_GPIO_K31, + EXYNOS4X12_GPIO_K32, + EXYNOS4X12_GPIO_K33, + EXYNOS4X12_GPIO_K34, + EXYNOS4X12_GPIO_K35, + EXYNOS4X12_GPIO_K36, + EXYNOS4X12_GPIO_K37, + EXYNOS4X12_GPIO_L00, /* 208 0xD0 */ + EXYNOS4X12_GPIO_L01, + EXYNOS4X12_GPIO_L02, + EXYNOS4X12_GPIO_L03, + EXYNOS4X12_GPIO_L04, + EXYNOS4X12_GPIO_L05, + EXYNOS4X12_GPIO_L06, + EXYNOS4X12_GPIO_L07, + EXYNOS4X12_GPIO_L10, /* 216 0xD8 */ + EXYNOS4X12_GPIO_L11, + EXYNOS4X12_GPIO_L12, + EXYNOS4X12_GPIO_L13, + EXYNOS4X12_GPIO_L14, + EXYNOS4X12_GPIO_L15, + EXYNOS4X12_GPIO_L16, + EXYNOS4X12_GPIO_L17, + EXYNOS4X12_GPIO_L20, /* 224 0xE0 */ + EXYNOS4X12_GPIO_L21, + EXYNOS4X12_GPIO_L22, + EXYNOS4X12_GPIO_L23, + EXYNOS4X12_GPIO_L24, + EXYNOS4X12_GPIO_L25, + EXYNOS4X12_GPIO_L26, + EXYNOS4X12_GPIO_L27, + EXYNOS4X12_GPIO_Y00, /* 232 0xE8 */ + EXYNOS4X12_GPIO_Y01, + EXYNOS4X12_GPIO_Y02, + EXYNOS4X12_GPIO_Y03, + EXYNOS4X12_GPIO_Y04, + EXYNOS4X12_GPIO_Y05, + EXYNOS4X12_GPIO_Y06, + EXYNOS4X12_GPIO_Y07, + EXYNOS4X12_GPIO_Y10, /* 240 0xF0 */ + EXYNOS4X12_GPIO_Y11, + EXYNOS4X12_GPIO_Y12, + EXYNOS4X12_GPIO_Y13, + EXYNOS4X12_GPIO_Y14, + EXYNOS4X12_GPIO_Y15, + EXYNOS4X12_GPIO_Y16, + EXYNOS4X12_GPIO_Y17, + EXYNOS4X12_GPIO_Y20, /* 248 0xF8 */ + EXYNOS4X12_GPIO_Y21, + EXYNOS4X12_GPIO_Y22, + EXYNOS4X12_GPIO_Y23, + EXYNOS4X12_GPIO_Y24, + EXYNOS4X12_GPIO_Y25, + EXYNOS4X12_GPIO_Y26, + EXYNOS4X12_GPIO_Y27, + EXYNOS4X12_GPIO_Y30, /* 256 0x100 */ + EXYNOS4X12_GPIO_Y31, + EXYNOS4X12_GPIO_Y32, + EXYNOS4X12_GPIO_Y33, + EXYNOS4X12_GPIO_Y34, + EXYNOS4X12_GPIO_Y35, + EXYNOS4X12_GPIO_Y36, + EXYNOS4X12_GPIO_Y37, + EXYNOS4X12_GPIO_Y40, /* 264 0x108 */ + EXYNOS4X12_GPIO_Y41, + EXYNOS4X12_GPIO_Y42, + EXYNOS4X12_GPIO_Y43, + EXYNOS4X12_GPIO_Y44, + EXYNOS4X12_GPIO_Y45, + EXYNOS4X12_GPIO_Y46, + EXYNOS4X12_GPIO_Y47, + EXYNOS4X12_GPIO_Y50, /* 272 0x110 */ + EXYNOS4X12_GPIO_Y51, + EXYNOS4X12_GPIO_Y52, + EXYNOS4X12_GPIO_Y53, + EXYNOS4X12_GPIO_Y54, + EXYNOS4X12_GPIO_Y55, + EXYNOS4X12_GPIO_Y56, + EXYNOS4X12_GPIO_Y57, + EXYNOS4X12_GPIO_Y60, /* 280 0x118 */ + EXYNOS4X12_GPIO_Y61, + EXYNOS4X12_GPIO_Y62, + EXYNOS4X12_GPIO_Y63, + EXYNOS4X12_GPIO_Y64, + EXYNOS4X12_GPIO_Y65, + EXYNOS4X12_GPIO_Y66, + EXYNOS4X12_GPIO_Y67, + EXYNOS4X12_GPIO_M00 = 312, /* 312 0xF0 */ + EXYNOS4X12_GPIO_M01, + EXYNOS4X12_GPIO_M02, + EXYNOS4X12_GPIO_M03, + EXYNOS4X12_GPIO_M04, + EXYNOS4X12_GPIO_M05, + EXYNOS4X12_GPIO_M06, + EXYNOS4X12_GPIO_M07, + EXYNOS4X12_GPIO_M10, /* 320 0xF8 */ + EXYNOS4X12_GPIO_M11, + EXYNOS4X12_GPIO_M12, + EXYNOS4X12_GPIO_M13, + EXYNOS4X12_GPIO_M14, + EXYNOS4X12_GPIO_M15, + EXYNOS4X12_GPIO_M16, + EXYNOS4X12_GPIO_M17, + EXYNOS4X12_GPIO_M20, /* 328 0x100 */ + EXYNOS4X12_GPIO_M21, + EXYNOS4X12_GPIO_M22, + EXYNOS4X12_GPIO_M23, + EXYNOS4X12_GPIO_M24, + EXYNOS4X12_GPIO_M25, + EXYNOS4X12_GPIO_M26, + EXYNOS4X12_GPIO_M27, + EXYNOS4X12_GPIO_M30, /* 336 0x108 */ + EXYNOS4X12_GPIO_M31, + EXYNOS4X12_GPIO_M32, + EXYNOS4X12_GPIO_M33, + EXYNOS4X12_GPIO_M34, + EXYNOS4X12_GPIO_M35, + EXYNOS4X12_GPIO_M36, + EXYNOS4X12_GPIO_M37, + EXYNOS4X12_GPIO_M40, /* 344 0x110 */ + EXYNOS4X12_GPIO_M41, + EXYNOS4X12_GPIO_M42, + EXYNOS4X12_GPIO_M43, + EXYNOS4X12_GPIO_M44, + EXYNOS4X12_GPIO_M45, + EXYNOS4X12_GPIO_M46, + EXYNOS4X12_GPIO_M47, + EXYNOS4X12_GPIO_X00 = 928, /* 928 0x3A0 */ + EXYNOS4X12_GPIO_X01, + EXYNOS4X12_GPIO_X02, + EXYNOS4X12_GPIO_X03, + EXYNOS4X12_GPIO_X04, + EXYNOS4X12_GPIO_X05, + EXYNOS4X12_GPIO_X06, + EXYNOS4X12_GPIO_X07, + EXYNOS4X12_GPIO_X10, /* 936 0x3A8 */ + EXYNOS4X12_GPIO_X11, + EXYNOS4X12_GPIO_X12, + EXYNOS4X12_GPIO_X13, + EXYNOS4X12_GPIO_X14, + EXYNOS4X12_GPIO_X15, + EXYNOS4X12_GPIO_X16, + EXYNOS4X12_GPIO_X17, + EXYNOS4X12_GPIO_X20, /* 944 0x3B0 */ + EXYNOS4X12_GPIO_X21, + EXYNOS4X12_GPIO_X22, + EXYNOS4X12_GPIO_X23, + EXYNOS4X12_GPIO_X24, + EXYNOS4X12_GPIO_X25, + EXYNOS4X12_GPIO_X26, + EXYNOS4X12_GPIO_X27, + EXYNOS4X12_GPIO_X30, /* 952 0x3B8 */ + EXYNOS4X12_GPIO_X31, + EXYNOS4X12_GPIO_X32, + EXYNOS4X12_GPIO_X33, + EXYNOS4X12_GPIO_X34, + EXYNOS4X12_GPIO_X35, + EXYNOS4X12_GPIO_X36, + EXYNOS4X12_GPIO_X37, + + /* GPIO_PART3_STARTS */ + EXYNOS4X12_GPIO_MAX_PORT_PART_2,/* 960 0x3C0 */ + EXYNOS4X12_GPIO_Z0 = EXYNOS4X12_GPIO_MAX_PORT_PART_2, + EXYNOS4X12_GPIO_Z1, + EXYNOS4X12_GPIO_Z2, + EXYNOS4X12_GPIO_Z3, + EXYNOS4X12_GPIO_Z4, + EXYNOS4X12_GPIO_Z5, + EXYNOS4X12_GPIO_Z6, + EXYNOS4X12_GPIO_Z7, + + /* GPIO_PART4_STARTS */ + EXYNOS4X12_GPIO_MAX_PORT_PART_3,/* 968 0x3C8 */ + EXYNOS4X12_GPIO_V00 = EXYNOS4X12_GPIO_MAX_PORT_PART_3, + EXYNOS4X12_GPIO_V01, + EXYNOS4X12_GPIO_V02, + EXYNOS4X12_GPIO_V03, + EXYNOS4X12_GPIO_V04, + EXYNOS4X12_GPIO_V05, + EXYNOS4X12_GPIO_V06, + EXYNOS4X12_GPIO_V07, + EXYNOS4X12_GPIO_V10, /* 976 0x3D0 */ + EXYNOS4X12_GPIO_V11, + EXYNOS4X12_GPIO_V12, + EXYNOS4X12_GPIO_V13, + EXYNOS4X12_GPIO_V14, + EXYNOS4X12_GPIO_V15, + EXYNOS4X12_GPIO_V16, + EXYNOS4X12_GPIO_V17, + EXYNOS4X12_GPIO_V20 = 992, /* 992 0x3E0 */ + EXYNOS4X12_GPIO_V21, + EXYNOS4X12_GPIO_V22, + EXYNOS4X12_GPIO_V23, + EXYNOS4X12_GPIO_V24, + EXYNOS4X12_GPIO_V25, + EXYNOS4X12_GPIO_V26, + EXYNOS4X12_GPIO_V27, + EXYNOS4X12_GPIO_V30 = 1000, /* 1000 0x3E8 */ + EXYNOS4X12_GPIO_V31, + EXYNOS4X12_GPIO_V32, + EXYNOS4X12_GPIO_V33, + EXYNOS4X12_GPIO_V34, + EXYNOS4X12_GPIO_V35, + EXYNOS4X12_GPIO_V36, + EXYNOS4X12_GPIO_V37, + EXYNOS4X12_GPIO_V40 = 1016, /* 1016 0x3F8 */ + EXYNOS4X12_GPIO_V41, + EXYNOS4X12_GPIO_V42, + EXYNOS4X12_GPIO_V43, + EXYNOS4X12_GPIO_V44, + EXYNOS4X12_GPIO_V45, + EXYNOS4X12_GPIO_V46, + EXYNOS4X12_GPIO_V47, + + EXYNOS4X12_GPIO_MAX_PORT };
-struct exynos4x12_gpio_part3 { - struct s5p_gpio_bank z; +enum exynos5_gpio_pin { + /* GPIO_PART1_STARTS */ + EXYNOS5_GPIO_A00, /* 0 */ + EXYNOS5_GPIO_A01, + EXYNOS5_GPIO_A02, + EXYNOS5_GPIO_A03, + EXYNOS5_GPIO_A04, + EXYNOS5_GPIO_A05, + EXYNOS5_GPIO_A06, + EXYNOS5_GPIO_A07, + EXYNOS5_GPIO_A10, /* 8 */ + EXYNOS5_GPIO_A11, + EXYNOS5_GPIO_A12, + EXYNOS5_GPIO_A13, + EXYNOS5_GPIO_A14, + EXYNOS5_GPIO_A15, + EXYNOS5_GPIO_A16, + EXYNOS5_GPIO_A17, + EXYNOS5_GPIO_A20, /* 16 0x10 */ + EXYNOS5_GPIO_A21, + EXYNOS5_GPIO_A22, + EXYNOS5_GPIO_A23, + EXYNOS5_GPIO_A24, + EXYNOS5_GPIO_A25, + EXYNOS5_GPIO_A26, + EXYNOS5_GPIO_A27, + EXYNOS5_GPIO_B00, /* 24 0x18 */ + EXYNOS5_GPIO_B01, + EXYNOS5_GPIO_B02, + EXYNOS5_GPIO_B03, + EXYNOS5_GPIO_B04, + EXYNOS5_GPIO_B05, + EXYNOS5_GPIO_B06, + EXYNOS5_GPIO_B07, + EXYNOS5_GPIO_B10, /* 32 0x20 */ + EXYNOS5_GPIO_B11, + EXYNOS5_GPIO_B12, + EXYNOS5_GPIO_B13, + EXYNOS5_GPIO_B14, + EXYNOS5_GPIO_B15, + EXYNOS5_GPIO_B16, + EXYNOS5_GPIO_B17, + EXYNOS5_GPIO_B20, /* 40 0x28 */ + EXYNOS5_GPIO_B21, + EXYNOS5_GPIO_B22, + EXYNOS5_GPIO_B23, + EXYNOS5_GPIO_B24, + EXYNOS5_GPIO_B25, + EXYNOS5_GPIO_B26, + EXYNOS5_GPIO_B27, + EXYNOS5_GPIO_B30, /* 48 0x39 */ + EXYNOS5_GPIO_B31, + EXYNOS5_GPIO_B32, + EXYNOS5_GPIO_B33, + EXYNOS5_GPIO_B34, + EXYNOS5_GPIO_B35, + EXYNOS5_GPIO_B36, + EXYNOS5_GPIO_B37, + EXYNOS5_GPIO_C00, /* 56 0x38 */ + EXYNOS5_GPIO_C01, + EXYNOS5_GPIO_C02, + EXYNOS5_GPIO_C03, + EXYNOS5_GPIO_C04, + EXYNOS5_GPIO_C05, + EXYNOS5_GPIO_C06, + EXYNOS5_GPIO_C07, + EXYNOS5_GPIO_C10, /* 64 0x40 */ + EXYNOS5_GPIO_C11, + EXYNOS5_GPIO_C12, + EXYNOS5_GPIO_C13, + EXYNOS5_GPIO_C14, + EXYNOS5_GPIO_C15, + EXYNOS5_GPIO_C16, + EXYNOS5_GPIO_C17, + EXYNOS5_GPIO_C20, /* 72 0x48 */ + EXYNOS5_GPIO_C21, + EXYNOS5_GPIO_C22, + EXYNOS5_GPIO_C23, + EXYNOS5_GPIO_C24, + EXYNOS5_GPIO_C25, + EXYNOS5_GPIO_C26, + EXYNOS5_GPIO_C27, + EXYNOS5_GPIO_C30, /* 80 0x50 */ + EXYNOS5_GPIO_C31, + EXYNOS5_GPIO_C32, + EXYNOS5_GPIO_C33, + EXYNOS5_GPIO_C34, + EXYNOS5_GPIO_C35, + EXYNOS5_GPIO_C36, + EXYNOS5_GPIO_C37, + EXYNOS5_GPIO_D00, /* 88 0x58 */ + EXYNOS5_GPIO_D01, + EXYNOS5_GPIO_D02, + EXYNOS5_GPIO_D03, + EXYNOS5_GPIO_D04, + EXYNOS5_GPIO_D05, + EXYNOS5_GPIO_D06, + EXYNOS5_GPIO_D07, + EXYNOS5_GPIO_D10, /* 96 0x60 */ + EXYNOS5_GPIO_D11, + EXYNOS5_GPIO_D12, + EXYNOS5_GPIO_D13, + EXYNOS5_GPIO_D14, + EXYNOS5_GPIO_D15, + EXYNOS5_GPIO_D16, + EXYNOS5_GPIO_D17, + EXYNOS5_GPIO_Y00, /* 104 0x68 */ + EXYNOS5_GPIO_Y01, + EXYNOS5_GPIO_Y02, + EXYNOS5_GPIO_Y03, + EXYNOS5_GPIO_Y04, + EXYNOS5_GPIO_Y05, + EXYNOS5_GPIO_Y06, + EXYNOS5_GPIO_Y07, + EXYNOS5_GPIO_Y10, /* 112 0x70 */ + EXYNOS5_GPIO_Y11, + EXYNOS5_GPIO_Y12, + EXYNOS5_GPIO_Y13, + EXYNOS5_GPIO_Y14, + EXYNOS5_GPIO_Y15, + EXYNOS5_GPIO_Y16, + EXYNOS5_GPIO_Y17, + EXYNOS5_GPIO_Y20, /* 120 0x78 */ + EXYNOS5_GPIO_Y21, + EXYNOS5_GPIO_Y22, + EXYNOS5_GPIO_Y23, + EXYNOS5_GPIO_Y24, + EXYNOS5_GPIO_Y25, + EXYNOS5_GPIO_Y26, + EXYNOS5_GPIO_Y27, + EXYNOS5_GPIO_Y30, /* 128 0x80 */ + EXYNOS5_GPIO_Y31, + EXYNOS5_GPIO_Y32, + EXYNOS5_GPIO_Y33, + EXYNOS5_GPIO_Y34, + EXYNOS5_GPIO_Y35, + EXYNOS5_GPIO_Y36, + EXYNOS5_GPIO_Y37, + EXYNOS5_GPIO_Y40, /* 136 0x88 */ + EXYNOS5_GPIO_Y41, + EXYNOS5_GPIO_Y42, + EXYNOS5_GPIO_Y43, + EXYNOS5_GPIO_Y44, + EXYNOS5_GPIO_Y45, + EXYNOS5_GPIO_Y46, + EXYNOS5_GPIO_Y47, + EXYNOS5_GPIO_Y50, /* 144 0x90 */ + EXYNOS5_GPIO_Y51, + EXYNOS5_GPIO_Y52, + EXYNOS5_GPIO_Y53, + EXYNOS5_GPIO_Y54, + EXYNOS5_GPIO_Y55, + EXYNOS5_GPIO_Y56, + EXYNOS5_GPIO_Y57, + EXYNOS5_GPIO_Y60, /* 152 0x98 */ + EXYNOS5_GPIO_Y61, + EXYNOS5_GPIO_Y62, + EXYNOS5_GPIO_Y63, + EXYNOS5_GPIO_Y64, + EXYNOS5_GPIO_Y65, + EXYNOS5_GPIO_Y66, + EXYNOS5_GPIO_Y67, + + /* GPIO_PART2_STARTS */ + EXYNOS5_GPIO_MAX_PORT_PART_1, /* 160 0xa0 */ + EXYNOS5_GPIO_C40 = EXYNOS5_GPIO_MAX_PORT_PART_1, + EXYNOS5_GPIO_C41, + EXYNOS5_GPIO_C42, + EXYNOS5_GPIO_C43, + EXYNOS5_GPIO_C44, + EXYNOS5_GPIO_C45, + EXYNOS5_GPIO_C46, + EXYNOS5_GPIO_C47, + + /* GPIO_PART3_STARTS */ + EXYNOS5_GPIO_MAX_PORT_PART_2, /* 168 0xa8 */ + EXYNOS5_GPIO_X00 = EXYNOS5_GPIO_MAX_PORT_PART_2, + EXYNOS5_GPIO_X01, + EXYNOS5_GPIO_X02, + EXYNOS5_GPIO_X03, + EXYNOS5_GPIO_X04, + EXYNOS5_GPIO_X05, + EXYNOS5_GPIO_X06, + EXYNOS5_GPIO_X07, + EXYNOS5_GPIO_X10, /* 176 0xb0 */ + EXYNOS5_GPIO_X11, + EXYNOS5_GPIO_X12, + EXYNOS5_GPIO_X13, + EXYNOS5_GPIO_X14, + EXYNOS5_GPIO_X15, + EXYNOS5_GPIO_X16, + EXYNOS5_GPIO_X17, + EXYNOS5_GPIO_X20, /* 184 0xb8 */ + EXYNOS5_GPIO_X21, + EXYNOS5_GPIO_X22, + EXYNOS5_GPIO_X23, + EXYNOS5_GPIO_X24, + EXYNOS5_GPIO_X25, + EXYNOS5_GPIO_X26, + EXYNOS5_GPIO_X27, + EXYNOS5_GPIO_X30, /* 192 0xc0 */ + EXYNOS5_GPIO_X31, + EXYNOS5_GPIO_X32, + EXYNOS5_GPIO_X33, + EXYNOS5_GPIO_X34, + EXYNOS5_GPIO_X35, + EXYNOS5_GPIO_X36, + EXYNOS5_GPIO_X37, + + /* GPIO_PART4_STARTS */ + EXYNOS5_GPIO_MAX_PORT_PART_3, /* 200 0xc8 */ + EXYNOS5_GPIO_E00 = EXYNOS5_GPIO_MAX_PORT_PART_3, + EXYNOS5_GPIO_E01, + EXYNOS5_GPIO_E02, + EXYNOS5_GPIO_E03, + EXYNOS5_GPIO_E04, + EXYNOS5_GPIO_E05, + EXYNOS5_GPIO_E06, + EXYNOS5_GPIO_E07, + EXYNOS5_GPIO_E10, /* 208 0xd0 */ + EXYNOS5_GPIO_E11, + EXYNOS5_GPIO_E12, + EXYNOS5_GPIO_E13, + EXYNOS5_GPIO_E14, + EXYNOS5_GPIO_E15, + EXYNOS5_GPIO_E16, + EXYNOS5_GPIO_E17, + EXYNOS5_GPIO_F00, /* 216 0xd8 */ + EXYNOS5_GPIO_F01, + EXYNOS5_GPIO_F02, + EXYNOS5_GPIO_F03, + EXYNOS5_GPIO_F04, + EXYNOS5_GPIO_F05, + EXYNOS5_GPIO_F06, + EXYNOS5_GPIO_F07, + EXYNOS5_GPIO_F10, /* 224 0xe0 */ + EXYNOS5_GPIO_F11, + EXYNOS5_GPIO_F12, + EXYNOS5_GPIO_F13, + EXYNOS5_GPIO_F14, + EXYNOS5_GPIO_F15, + EXYNOS5_GPIO_F16, + EXYNOS5_GPIO_F17, + EXYNOS5_GPIO_G00, /* 232 0xe8 */ + EXYNOS5_GPIO_G01, + EXYNOS5_GPIO_G02, + EXYNOS5_GPIO_G03, + EXYNOS5_GPIO_G04, + EXYNOS5_GPIO_G05, + EXYNOS5_GPIO_G06, + EXYNOS5_GPIO_G07, + EXYNOS5_GPIO_G10, /* 240 0xf0 */ + EXYNOS5_GPIO_G11, + EXYNOS5_GPIO_G12, + EXYNOS5_GPIO_G13, + EXYNOS5_GPIO_G14, + EXYNOS5_GPIO_G15, + EXYNOS5_GPIO_G16, + EXYNOS5_GPIO_G17, + EXYNOS5_GPIO_G20, /* 248 0xf8 */ + EXYNOS5_GPIO_G21, + EXYNOS5_GPIO_G22, + EXYNOS5_GPIO_G23, + EXYNOS5_GPIO_G24, + EXYNOS5_GPIO_G25, + EXYNOS5_GPIO_G26, + EXYNOS5_GPIO_G27, + EXYNOS5_GPIO_H00, /* 256 0x100 */ + EXYNOS5_GPIO_H01, + EXYNOS5_GPIO_H02, + EXYNOS5_GPIO_H03, + EXYNOS5_GPIO_H04, + EXYNOS5_GPIO_H05, + EXYNOS5_GPIO_H06, + EXYNOS5_GPIO_H07, + EXYNOS5_GPIO_H10, /* 264 0x108 */ + EXYNOS5_GPIO_H11, + EXYNOS5_GPIO_H12, + EXYNOS5_GPIO_H13, + EXYNOS5_GPIO_H14, + EXYNOS5_GPIO_H15, + EXYNOS5_GPIO_H16, + EXYNOS5_GPIO_H17, + + /* GPIO_PART4_STARTS */ + EXYNOS5_GPIO_MAX_PORT_PART_4, /* 272 0x110 */ + EXYNOS5_GPIO_V00 = EXYNOS5_GPIO_MAX_PORT_PART_4, + EXYNOS5_GPIO_V01, + EXYNOS5_GPIO_V02, + EXYNOS5_GPIO_V03, + EXYNOS5_GPIO_V04, + EXYNOS5_GPIO_V05, + EXYNOS5_GPIO_V06, + EXYNOS5_GPIO_V07, + EXYNOS5_GPIO_V10, /* 280 0x118 */ + EXYNOS5_GPIO_V11, + EXYNOS5_GPIO_V12, + EXYNOS5_GPIO_V13, + EXYNOS5_GPIO_V14, + EXYNOS5_GPIO_V15, + EXYNOS5_GPIO_V16, + EXYNOS5_GPIO_V17, + + /* GPIO_PART5_STARTS */ + EXYNOS5_GPIO_MAX_PORT_PART_5, /* 288 0x120 */ + EXYNOS5_GPIO_V20 = EXYNOS5_GPIO_MAX_PORT_PART_5, + EXYNOS5_GPIO_V21, + EXYNOS5_GPIO_V22, + EXYNOS5_GPIO_V23, + EXYNOS5_GPIO_V24, + EXYNOS5_GPIO_V25, + EXYNOS5_GPIO_V26, + EXYNOS5_GPIO_V27, + EXYNOS5_GPIO_V30, /* 296 0x128 */ + EXYNOS5_GPIO_V31, + EXYNOS5_GPIO_V32, + EXYNOS5_GPIO_V33, + EXYNOS5_GPIO_V34, + EXYNOS5_GPIO_V35, + EXYNOS5_GPIO_V36, + EXYNOS5_GPIO_V37, + + /* GPIO_PART6_STARTS */ + EXYNOS5_GPIO_MAX_PORT_PART_6, /* 304 0x130 */ + EXYNOS5_GPIO_V40 = EXYNOS5_GPIO_MAX_PORT_PART_6, + EXYNOS5_GPIO_V41, + EXYNOS5_GPIO_V42, + EXYNOS5_GPIO_V43, + EXYNOS5_GPIO_V44, + EXYNOS5_GPIO_V45, + EXYNOS5_GPIO_V46, + EXYNOS5_GPIO_V47, + + /* GPIO_PART7_STARTS */ /* 312 0x138 */ + EXYNOS5_GPIO_MAX_PORT_PART_7, + EXYNOS5_GPIO_Z0 = EXYNOS5_GPIO_MAX_PORT_PART_7, + EXYNOS5_GPIO_Z1, + EXYNOS5_GPIO_Z2, + EXYNOS5_GPIO_Z3, + EXYNOS5_GPIO_Z4, + EXYNOS5_GPIO_Z5, + EXYNOS5_GPIO_Z6, + EXYNOS5_GPIO_MAX_PORT };
-struct exynos4x12_gpio_part4 { - struct s5p_gpio_bank v0; - struct s5p_gpio_bank v1; - struct s5p_gpio_bank res1[0x1]; - struct s5p_gpio_bank v2; - struct s5p_gpio_bank v3; - struct s5p_gpio_bank res2[0x1]; - struct s5p_gpio_bank v4; +enum exynos5420_gpio_pin { + /* GPIO_PART1_STARTS */ + EXYNOS5420_GPIO_A00, /* 0 */ + EXYNOS5420_GPIO_A01, + EXYNOS5420_GPIO_A02, + EXYNOS5420_GPIO_A03, + EXYNOS5420_GPIO_A04, + EXYNOS5420_GPIO_A05, + EXYNOS5420_GPIO_A06, + EXYNOS5420_GPIO_A07, + EXYNOS5420_GPIO_A10, /* 8 */ + EXYNOS5420_GPIO_A11, + EXYNOS5420_GPIO_A12, + EXYNOS5420_GPIO_A13, + EXYNOS5420_GPIO_A14, + EXYNOS5420_GPIO_A15, + EXYNOS5420_GPIO_A16, + EXYNOS5420_GPIO_A17, + EXYNOS5420_GPIO_A20, /* 16 0x10 */ + EXYNOS5420_GPIO_A21, + EXYNOS5420_GPIO_A22, + EXYNOS5420_GPIO_A23, + EXYNOS5420_GPIO_A24, + EXYNOS5420_GPIO_A25, + EXYNOS5420_GPIO_A26, + EXYNOS5420_GPIO_A27, + EXYNOS5420_GPIO_B00, /* 24 0x18 */ + EXYNOS5420_GPIO_B01, + EXYNOS5420_GPIO_B02, + EXYNOS5420_GPIO_B03, + EXYNOS5420_GPIO_B04, + EXYNOS5420_GPIO_B05, + EXYNOS5420_GPIO_B06, + EXYNOS5420_GPIO_B07, + EXYNOS5420_GPIO_B10, /* 32 0x20 */ + EXYNOS5420_GPIO_B11, + EXYNOS5420_GPIO_B12, + EXYNOS5420_GPIO_B13, + EXYNOS5420_GPIO_B14, + EXYNOS5420_GPIO_B15, + EXYNOS5420_GPIO_B16, + EXYNOS5420_GPIO_B17, + EXYNOS5420_GPIO_B20, /* 40 0x28 */ + EXYNOS5420_GPIO_B21, + EXYNOS5420_GPIO_B22, + EXYNOS5420_GPIO_B23, + EXYNOS5420_GPIO_B24, + EXYNOS5420_GPIO_B25, + EXYNOS5420_GPIO_B26, + EXYNOS5420_GPIO_B27, + EXYNOS5420_GPIO_B30, /* 48 0x30 */ + EXYNOS5420_GPIO_B31, + EXYNOS5420_GPIO_B32, + EXYNOS5420_GPIO_B33, + EXYNOS5420_GPIO_B34, + EXYNOS5420_GPIO_B35, + EXYNOS5420_GPIO_B36, + EXYNOS5420_GPIO_B37, + EXYNOS5420_GPIO_B40, /* 56 0x38 */ + EXYNOS5420_GPIO_B41, + EXYNOS5420_GPIO_B42, + EXYNOS5420_GPIO_B43, + EXYNOS5420_GPIO_B44, + EXYNOS5420_GPIO_B45, + EXYNOS5420_GPIO_B46, + EXYNOS5420_GPIO_B47, + EXYNOS5420_GPIO_H00, /* 64 0x40 */ + EXYNOS5420_GPIO_H01, + EXYNOS5420_GPIO_H02, + EXYNOS5420_GPIO_H03, + EXYNOS5420_GPIO_H04, + EXYNOS5420_GPIO_H05, + EXYNOS5420_GPIO_H06, + EXYNOS5420_GPIO_H07, + + /* GPIO PART 2 STARTS*/ + EXYNOS5420_GPIO_MAX_PORT_PART_1,/* 72 0x48 */ + EXYNOS5420_GPIO_Y70 = EXYNOS5420_GPIO_MAX_PORT_PART_1, + EXYNOS5420_GPIO_Y71, + EXYNOS5420_GPIO_Y72, + EXYNOS5420_GPIO_Y73, + EXYNOS5420_GPIO_Y74, + EXYNOS5420_GPIO_Y75, + EXYNOS5420_GPIO_Y76, + EXYNOS5420_GPIO_Y77, + + /* GPIO PART 3 STARTS*/ + EXYNOS5420_GPIO_MAX_PORT_PART_2,/* 80 0x50 */ + EXYNOS5420_GPIO_X00 = EXYNOS5420_GPIO_MAX_PORT_PART_2, + EXYNOS5420_GPIO_X01, + EXYNOS5420_GPIO_X02, + EXYNOS5420_GPIO_X03, + EXYNOS5420_GPIO_X04, + EXYNOS5420_GPIO_X05, + EXYNOS5420_GPIO_X06, + EXYNOS5420_GPIO_X07, + EXYNOS5420_GPIO_X10, /* 88 0x58 */ + EXYNOS5420_GPIO_X11, + EXYNOS5420_GPIO_X12, + EXYNOS5420_GPIO_X13, + EXYNOS5420_GPIO_X14, + EXYNOS5420_GPIO_X15, + EXYNOS5420_GPIO_X16, + EXYNOS5420_GPIO_X17, + EXYNOS5420_GPIO_X20, /* 96 0x60 */ + EXYNOS5420_GPIO_X21, + EXYNOS5420_GPIO_X22, + EXYNOS5420_GPIO_X23, + EXYNOS5420_GPIO_X24, + EXYNOS5420_GPIO_X25, + EXYNOS5420_GPIO_X26, + EXYNOS5420_GPIO_X27, + EXYNOS5420_GPIO_X30, /* 104 0x68 */ + EXYNOS5420_GPIO_X31, + EXYNOS5420_GPIO_X32, + EXYNOS5420_GPIO_X33, + EXYNOS5420_GPIO_X34, + EXYNOS5420_GPIO_X35, + EXYNOS5420_GPIO_X36, + EXYNOS5420_GPIO_X37, + + /* GPIO PART 4 STARTS*/ + EXYNOS5420_GPIO_MAX_PORT_PART_3,/* 112 0x70 */ + EXYNOS5420_GPIO_C00 = EXYNOS5420_GPIO_MAX_PORT_PART_3, + EXYNOS5420_GPIO_C01, + EXYNOS5420_GPIO_C02, + EXYNOS5420_GPIO_C03, + EXYNOS5420_GPIO_C04, + EXYNOS5420_GPIO_C05, + EXYNOS5420_GPIO_C06, + EXYNOS5420_GPIO_C07, + EXYNOS5420_GPIO_C10, /* 120 0x78 */ + EXYNOS5420_GPIO_C11, + EXYNOS5420_GPIO_C12, + EXYNOS5420_GPIO_C13, + EXYNOS5420_GPIO_C14, + EXYNOS5420_GPIO_C15, + EXYNOS5420_GPIO_C16, + EXYNOS5420_GPIO_C17, + EXYNOS5420_GPIO_C20, /* 128 0x80 */ + EXYNOS5420_GPIO_C21, + EXYNOS5420_GPIO_C22, + EXYNOS5420_GPIO_C23, + EXYNOS5420_GPIO_C24, + EXYNOS5420_GPIO_C25, + EXYNOS5420_GPIO_C26, + EXYNOS5420_GPIO_C27, + EXYNOS5420_GPIO_C30, /* 136 0x88 */ + EXYNOS5420_GPIO_C31, + EXYNOS5420_GPIO_C32, + EXYNOS5420_GPIO_C33, + EXYNOS5420_GPIO_C34, + EXYNOS5420_GPIO_C35, + EXYNOS5420_GPIO_C36, + EXYNOS5420_GPIO_C37, + EXYNOS5420_GPIO_C40, /* 144 0x90 */ + EXYNOS5420_GPIO_C41, + EXYNOS5420_GPIO_C42, + EXYNOS5420_GPIO_C43, + EXYNOS5420_GPIO_C44, + EXYNOS5420_GPIO_C45, + EXYNOS5420_GPIO_C46, + EXYNOS5420_GPIO_C47, + EXYNOS5420_GPIO_D10, /* 152 0x98 */ + EXYNOS5420_GPIO_D11, + EXYNOS5420_GPIO_D12, + EXYNOS5420_GPIO_D13, + EXYNOS5420_GPIO_D14, + EXYNOS5420_GPIO_D15, + EXYNOS5420_GPIO_D16, + EXYNOS5420_GPIO_D17, + EXYNOS5420_GPIO_Y00, /* 160 0xa0 */ + EXYNOS5420_GPIO_Y01, + EXYNOS5420_GPIO_Y02, + EXYNOS5420_GPIO_Y03, + EXYNOS5420_GPIO_Y04, + EXYNOS5420_GPIO_Y05, + EXYNOS5420_GPIO_Y06, + EXYNOS5420_GPIO_Y07, + EXYNOS5420_GPIO_Y10, /* 168 0xa8 */ + EXYNOS5420_GPIO_Y11, + EXYNOS5420_GPIO_Y12, + EXYNOS5420_GPIO_Y13, + EXYNOS5420_GPIO_Y14, + EXYNOS5420_GPIO_Y15, + EXYNOS5420_GPIO_Y16, + EXYNOS5420_GPIO_Y17, + EXYNOS5420_GPIO_Y20, /* 176 0xb0 */ + EXYNOS5420_GPIO_Y21, + EXYNOS5420_GPIO_Y22, + EXYNOS5420_GPIO_Y23, + EXYNOS5420_GPIO_Y24, + EXYNOS5420_GPIO_Y25, + EXYNOS5420_GPIO_Y26, + EXYNOS5420_GPIO_Y27, + EXYNOS5420_GPIO_Y30, /* 184 0xb8 */ + EXYNOS5420_GPIO_Y31, + EXYNOS5420_GPIO_Y32, + EXYNOS5420_GPIO_Y33, + EXYNOS5420_GPIO_Y34, + EXYNOS5420_GPIO_Y35, + EXYNOS5420_GPIO_Y36, + EXYNOS5420_GPIO_Y37, + EXYNOS5420_GPIO_Y40, /* 192 0xc0 */ + EXYNOS5420_GPIO_Y41, + EXYNOS5420_GPIO_Y42, + EXYNOS5420_GPIO_Y43, + EXYNOS5420_GPIO_Y44, + EXYNOS5420_GPIO_Y45, + EXYNOS5420_GPIO_Y46, + EXYNOS5420_GPIO_Y47, + EXYNOS5420_GPIO_Y50, /* 200 0xc8 */ + EXYNOS5420_GPIO_Y51, + EXYNOS5420_GPIO_Y52, + EXYNOS5420_GPIO_Y53, + EXYNOS5420_GPIO_Y54, + EXYNOS5420_GPIO_Y55, + EXYNOS5420_GPIO_Y56, + EXYNOS5420_GPIO_Y57, + EXYNOS5420_GPIO_Y60, /* 208 0xd0 */ + EXYNOS5420_GPIO_Y61, + EXYNOS5420_GPIO_Y62, + EXYNOS5420_GPIO_Y63, + EXYNOS5420_GPIO_Y64, + EXYNOS5420_GPIO_Y65, + EXYNOS5420_GPIO_Y66, + EXYNOS5420_GPIO_Y67, + + /* GPIO_PART5_STARTS */ + EXYNOS5420_GPIO_MAX_PORT_PART_4,/* 216 0xd8 */ + EXYNOS5420_GPIO_E00 = EXYNOS5420_GPIO_MAX_PORT_PART_4, + EXYNOS5420_GPIO_E01, + EXYNOS5420_GPIO_E02, + EXYNOS5420_GPIO_E03, + EXYNOS5420_GPIO_E04, + EXYNOS5420_GPIO_E05, + EXYNOS5420_GPIO_E06, + EXYNOS5420_GPIO_E07, + EXYNOS5420_GPIO_E10, /* 224 0xe0 */ + EXYNOS5420_GPIO_E11, + EXYNOS5420_GPIO_E12, + EXYNOS5420_GPIO_E13, + EXYNOS5420_GPIO_E14, + EXYNOS5420_GPIO_E15, + EXYNOS5420_GPIO_E16, + EXYNOS5420_GPIO_E17, + EXYNOS5420_GPIO_F00, /* 232 0xe8 */ + EXYNOS5420_GPIO_F01, + EXYNOS5420_GPIO_F02, + EXYNOS5420_GPIO_F03, + EXYNOS5420_GPIO_F04, + EXYNOS5420_GPIO_F05, + EXYNOS5420_GPIO_F06, + EXYNOS5420_GPIO_F07, + EXYNOS5420_GPIO_F10, /* 240 0xf0 */ + EXYNOS5420_GPIO_F11, + EXYNOS5420_GPIO_F12, + EXYNOS5420_GPIO_F13, + EXYNOS5420_GPIO_F14, + EXYNOS5420_GPIO_F15, + EXYNOS5420_GPIO_F16, + EXYNOS5420_GPIO_F17, + EXYNOS5420_GPIO_G00, /* 248 0xf8 */ + EXYNOS5420_GPIO_G01, + EXYNOS5420_GPIO_G02, + EXYNOS5420_GPIO_G03, + EXYNOS5420_GPIO_G04, + EXYNOS5420_GPIO_G05, + EXYNOS5420_GPIO_G06, + EXYNOS5420_GPIO_G07, + EXYNOS5420_GPIO_G10, /* 256 0x100 */ + EXYNOS5420_GPIO_G11, + EXYNOS5420_GPIO_G12, + EXYNOS5420_GPIO_G13, + EXYNOS5420_GPIO_G14, + EXYNOS5420_GPIO_G15, + EXYNOS5420_GPIO_G16, + EXYNOS5420_GPIO_G17, + EXYNOS5420_GPIO_G20, /* 264 0x108 */ + EXYNOS5420_GPIO_G21, + EXYNOS5420_GPIO_G22, + EXYNOS5420_GPIO_G23, + EXYNOS5420_GPIO_G24, + EXYNOS5420_GPIO_G25, + EXYNOS5420_GPIO_G26, + EXYNOS5420_GPIO_G27, + EXYNOS5420_GPIO_J40, /* 272 0x110 */ + EXYNOS5420_GPIO_J41, + EXYNOS5420_GPIO_J42, + EXYNOS5420_GPIO_J43, + EXYNOS5420_GPIO_J44, + EXYNOS5420_GPIO_J45, + EXYNOS5420_GPIO_J46, + EXYNOS5420_GPIO_J47, + + /* GPIO_PART6_STARTS */ + EXYNOS5420_GPIO_MAX_PORT_PART_5,/* 280 0x118 */ + EXYNOS5420_GPIO_Z0 = EXYNOS5420_GPIO_MAX_PORT_PART_5, + EXYNOS5420_GPIO_Z1, + EXYNOS5420_GPIO_Z2, + EXYNOS5420_GPIO_Z3, + EXYNOS5420_GPIO_Z4, + EXYNOS5420_GPIO_Z5, + EXYNOS5420_GPIO_Z6, + EXYNOS5420_GPIO_MAX_PORT };
-struct exynos5420_gpio_part1 { - struct s5p_gpio_bank a0; - struct s5p_gpio_bank a1; - struct s5p_gpio_bank a2; - struct s5p_gpio_bank b0; - struct s5p_gpio_bank b1; - struct s5p_gpio_bank b2; - struct s5p_gpio_bank b3; - struct s5p_gpio_bank b4; - struct s5p_gpio_bank h0; +struct gpio_info { + unsigned int reg_addr; /* Address of register for this part */ + unsigned int max_gpio; /* Maximum GPIO in this part */ };
-struct exynos5420_gpio_part2 { - struct s5p_gpio_bank y7; /* 0x1340_0000 */ - struct s5p_gpio_bank res[0x5f]; /* */ - struct s5p_gpio_bank x0; /* 0x1340_0C00 */ - struct s5p_gpio_bank x1; /* 0x1340_0C20 */ - struct s5p_gpio_bank x2; /* 0x1340_0C40 */ - struct s5p_gpio_bank x3; /* 0x1340_0C60 */ +#define EXYNOS4_GPIO_NUM_PARTS 3 +static struct gpio_info exynos4_gpio_data[EXYNOS4_GPIO_NUM_PARTS] = { + { EXYNOS4_GPIO_PART1_BASE, EXYNOS4_GPIO_MAX_PORT_PART_1 }, + { EXYNOS4_GPIO_PART2_BASE, EXYNOS4_GPIO_MAX_PORT_PART_2 }, + { EXYNOS4_GPIO_PART3_BASE, EXYNOS4_GPIO_MAX_PORT }, };
-struct exynos5420_gpio_part3 { - struct s5p_gpio_bank c0; - struct s5p_gpio_bank c1; - struct s5p_gpio_bank c2; - struct s5p_gpio_bank c3; - struct s5p_gpio_bank c4; - struct s5p_gpio_bank d1; - struct s5p_gpio_bank y0; - struct s5p_gpio_bank y1; - struct s5p_gpio_bank y2; - struct s5p_gpio_bank y3; - struct s5p_gpio_bank y4; - struct s5p_gpio_bank y5; - struct s5p_gpio_bank y6; +#define EXYNOS4X12_GPIO_NUM_PARTS 4 +static struct gpio_info exynos4x12_gpio_data[EXYNOS4X12_GPIO_NUM_PARTS] = { + { EXYNOS4X12_GPIO_PART1_BASE, EXYNOS4X12_GPIO_MAX_PORT_PART_1 }, + { EXYNOS4X12_GPIO_PART2_BASE, EXYNOS4X12_GPIO_MAX_PORT_PART_2 }, + { EXYNOS4X12_GPIO_PART3_BASE, EXYNOS4X12_GPIO_MAX_PORT_PART_3 }, + { EXYNOS4X12_GPIO_PART4_BASE, EXYNOS4X12_GPIO_MAX_PORT }, };
-struct exynos5420_gpio_part4 { - struct s5p_gpio_bank e0; /* 0x1400_0000 */ - struct s5p_gpio_bank e1; /* 0x1400_0020 */ - struct s5p_gpio_bank f0; /* 0x1400_0040 */ - struct s5p_gpio_bank f1; /* 0x1400_0060 */ - struct s5p_gpio_bank g0; /* 0x1400_0080 */ - struct s5p_gpio_bank g1; /* 0x1400_00A0 */ - struct s5p_gpio_bank g2; /* 0x1400_00C0 */ - struct s5p_gpio_bank j4; /* 0x1400_00E0 */ +#define EXYNOS5_GPIO_NUM_PARTS 8 +static struct gpio_info exynos5_gpio_data[EXYNOS5_GPIO_NUM_PARTS] = { + { EXYNOS5_GPIO_PART1_BASE, EXYNOS5_GPIO_MAX_PORT_PART_1 }, + { EXYNOS5_GPIO_PART2_BASE, EXYNOS5_GPIO_MAX_PORT_PART_2 }, + { EXYNOS5_GPIO_PART3_BASE, EXYNOS5_GPIO_MAX_PORT_PART_3 }, + { EXYNOS5_GPIO_PART4_BASE, EXYNOS5_GPIO_MAX_PORT_PART_4 }, + { EXYNOS5_GPIO_PART5_BASE, EXYNOS5_GPIO_MAX_PORT_PART_5 }, + { EXYNOS5_GPIO_PART6_BASE, EXYNOS5_GPIO_MAX_PORT_PART_6 }, + { EXYNOS5_GPIO_PART7_BASE, EXYNOS5_GPIO_MAX_PORT_PART_7 }, + { EXYNOS5_GPIO_PART8_BASE, EXYNOS5_GPIO_MAX_PORT }, };
-struct exynos5420_gpio_part5 { - struct s5p_gpio_bank z0; /* 0x0386_0000 */ +#define EXYNOS5420_GPIO_NUM_PARTS 6 +static struct gpio_info exynos5420_gpio_data[EXYNOS5420_GPIO_NUM_PARTS] = { + { EXYNOS5420_GPIO_PART1_BASE, EXYNOS5420_GPIO_MAX_PORT_PART_1 }, + { EXYNOS5420_GPIO_PART2_BASE, EXYNOS5420_GPIO_MAX_PORT_PART_2 }, + { EXYNOS5420_GPIO_PART3_BASE, EXYNOS5420_GPIO_MAX_PORT_PART_3 }, + { EXYNOS5420_GPIO_PART4_BASE, EXYNOS5420_GPIO_MAX_PORT_PART_4 }, + { EXYNOS5420_GPIO_PART5_BASE, EXYNOS5420_GPIO_MAX_PORT_PART_5 }, + { EXYNOS5420_GPIO_PART6_BASE, EXYNOS5420_GPIO_MAX_PORT }, };
-struct exynos5_gpio_part1 { - struct s5p_gpio_bank a0; - struct s5p_gpio_bank a1; - struct s5p_gpio_bank a2; - struct s5p_gpio_bank b0; - struct s5p_gpio_bank b1; - struct s5p_gpio_bank b2; - struct s5p_gpio_bank b3; - struct s5p_gpio_bank c0; - struct s5p_gpio_bank c1; - struct s5p_gpio_bank c2; - struct s5p_gpio_bank c3; - struct s5p_gpio_bank d0; - struct s5p_gpio_bank d1; - struct s5p_gpio_bank y0; - struct s5p_gpio_bank y1; - struct s5p_gpio_bank y2; - struct s5p_gpio_bank y3; - struct s5p_gpio_bank y4; - struct s5p_gpio_bank y5; - struct s5p_gpio_bank y6; - struct s5p_gpio_bank res1[0x3]; - struct s5p_gpio_bank c4; - struct s5p_gpio_bank res2[0x48]; - struct s5p_gpio_bank x0; - struct s5p_gpio_bank x1; - struct s5p_gpio_bank x2; - struct s5p_gpio_bank x3; +static inline struct gpio_info *get_gpio_data(void) +{ + if (cpu_is_exynos5()) { + if (proid_is_exynos5420()) + return exynos5420_gpio_data; + else + return exynos5_gpio_data; + } else if (cpu_is_exynos4()) { + if (proid_is_exynos4412()) + return exynos4x12_gpio_data; + else + return exynos4_gpio_data; + } + + return NULL; +} + +static inline unsigned int get_bank_num(void) +{ + if (cpu_is_exynos5()) { + if (proid_is_exynos5420()) + return EXYNOS5420_GPIO_NUM_PARTS; + else + return EXYNOS5_GPIO_NUM_PARTS; + } else if (cpu_is_exynos4()) { + if (proid_is_exynos4412()) + return EXYNOS4X12_GPIO_NUM_PARTS; + else + return EXYNOS4_GPIO_NUM_PARTS; + } + + return 0; +} + +/* + * This structure helps mapping symbolic GPIO names into indices from + * exynos5_gpio_pin/exynos5420_gpio_pin enums. + * + * By convention, symbolic GPIO name is defined as follows: + * + * g[p]<bank><set><bit>, where + * p is optional + * <bank> - a single character bank name, as defined by the SOC + * <set> - a single digit set number + * <bit> - bit number within the set (in 0..7 range). + * + * <set><bit> essentially form an octal number of the GPIO pin within the bank + * space. On the 5420 architecture some banks' sets do not start not from zero + * ('d' starts from 1 and 'j' starts from 4). To compensate for that and + * maintain flat number space withoout holes, those banks use offsets to be + * deducted from the pin number. + */ +struct gpio_name_num_table { + char bank; /* bank name symbol */ + unsigned int bank_size; /* total number of pins in the bank */ + char bank_offset; /* offset of the first bank's pin */ + unsigned int base; /* index of the first bank's pin in the enum */ };
-struct exynos5_gpio_part2 { - struct s5p_gpio_bank e0; - struct s5p_gpio_bank e1; - struct s5p_gpio_bank f0; - struct s5p_gpio_bank f1; - struct s5p_gpio_bank g0; - struct s5p_gpio_bank g1; - struct s5p_gpio_bank g2; - struct s5p_gpio_bank h0; - struct s5p_gpio_bank h1; +#define GPIO_ENTRY(name, base, top, offset) { name, top - base, offset, base } +static const struct gpio_name_num_table exynos4_gpio_table[] = { + GPIO_ENTRY('a', EXYNOS4_GPIO_A00, EXYNOS4_GPIO_B0, 0), + GPIO_ENTRY('b', EXYNOS4_GPIO_B0, EXYNOS4_GPIO_C00, 0), + GPIO_ENTRY('c', EXYNOS4_GPIO_C00, EXYNOS4_GPIO_D00, 0), + GPIO_ENTRY('d', EXYNOS4_GPIO_D00, EXYNOS4_GPIO_E00, 0), + GPIO_ENTRY('e', EXYNOS4_GPIO_E00, EXYNOS4_GPIO_F00, 0), + GPIO_ENTRY('f', EXYNOS4_GPIO_F00, EXYNOS4_GPIO_J00, 0), + GPIO_ENTRY('j', EXYNOS4_GPIO_J00, EXYNOS4_GPIO_K00, 0), + GPIO_ENTRY('k', EXYNOS4_GPIO_K00, EXYNOS4_GPIO_L00, 0), + GPIO_ENTRY('l', EXYNOS4_GPIO_L00, EXYNOS4_GPIO_Y00, 0), + GPIO_ENTRY('y', EXYNOS4_GPIO_Y00, EXYNOS4_GPIO_X00, 0), + GPIO_ENTRY('x', EXYNOS4_GPIO_X00, EXYNOS4_GPIO_Z0, 0), + GPIO_ENTRY('z', EXYNOS4_GPIO_Z0, EXYNOS4_GPIO_MAX_PORT, 0), + { 0 } };
-struct exynos5_gpio_part3 { - struct s5p_gpio_bank v0; - struct s5p_gpio_bank v1; - struct s5p_gpio_bank res1[0x1]; - struct s5p_gpio_bank v2; - struct s5p_gpio_bank v3; - struct s5p_gpio_bank res2[0x1]; - struct s5p_gpio_bank v4; +static const struct gpio_name_num_table exynos4x12_gpio_table[] = { + GPIO_ENTRY('a', EXYNOS4X12_GPIO_A00, EXYNOS4X12_GPIO_B0, 0), + GPIO_ENTRY('b', EXYNOS4X12_GPIO_B0, EXYNOS4X12_GPIO_C00, 0), + GPIO_ENTRY('c', EXYNOS4X12_GPIO_C00, EXYNOS4X12_GPIO_D00, 0), + GPIO_ENTRY('d', EXYNOS4X12_GPIO_D00, EXYNOS4X12_GPIO_F00, 0), + GPIO_ENTRY('f', EXYNOS4X12_GPIO_F00, EXYNOS4X12_GPIO_J00, 0), + GPIO_ENTRY('j', EXYNOS4X12_GPIO_J00, EXYNOS4X12_GPIO_K00, 0), + GPIO_ENTRY('k', EXYNOS4X12_GPIO_K00, EXYNOS4X12_GPIO_L00, 0), + GPIO_ENTRY('l', EXYNOS4X12_GPIO_L00, EXYNOS4X12_GPIO_Y00, 0), + GPIO_ENTRY('y', EXYNOS4X12_GPIO_Y00, EXYNOS4X12_GPIO_M00, 0), + GPIO_ENTRY('m', EXYNOS4X12_GPIO_M00, EXYNOS4X12_GPIO_X00, 0), + GPIO_ENTRY('x', EXYNOS4X12_GPIO_X00, EXYNOS4X12_GPIO_Z0, 0), + GPIO_ENTRY('z', EXYNOS4X12_GPIO_Z0, EXYNOS4X12_GPIO_V00, 0), + GPIO_ENTRY('v', EXYNOS4X12_GPIO_V00, EXYNOS4X12_GPIO_MAX_PORT, 0), + { 0 } };
-struct exynos5_gpio_part4 { - struct s5p_gpio_bank z; +static const struct gpio_name_num_table exynos5_gpio_table[] = { + GPIO_ENTRY('a', EXYNOS5_GPIO_A00, EXYNOS5_GPIO_B00, 0), + GPIO_ENTRY('b', EXYNOS5_GPIO_B00, EXYNOS5_GPIO_C00, 0), + GPIO_ENTRY('c', EXYNOS5_GPIO_C00, EXYNOS5_GPIO_D00, 0), + GPIO_ENTRY('d', EXYNOS5_GPIO_D00, EXYNOS5_GPIO_Y00, 0), + GPIO_ENTRY('y', EXYNOS5_GPIO_Y00, EXYNOS5_GPIO_C40, 0), + GPIO_ENTRY('x', EXYNOS5_GPIO_X00, EXYNOS5_GPIO_E00, 0), + GPIO_ENTRY('e', EXYNOS5_GPIO_E00, EXYNOS5_GPIO_F00, 0), + GPIO_ENTRY('f', EXYNOS5_GPIO_F00, EXYNOS5_GPIO_G00, 0), + GPIO_ENTRY('g', EXYNOS5_GPIO_G00, EXYNOS5_GPIO_H00, 0), + GPIO_ENTRY('h', EXYNOS5_GPIO_H00, EXYNOS5_GPIO_V00, 0), + GPIO_ENTRY('v', EXYNOS5_GPIO_V00, EXYNOS5_GPIO_Z0, 0), + GPIO_ENTRY('z', EXYNOS5_GPIO_Z0, EXYNOS5_GPIO_MAX_PORT, 0), + { 0 } };
-/* functions */ -void s5p_gpio_cfg_pin(struct s5p_gpio_bank *bank, int gpio, int cfg); -void s5p_gpio_direction_output(struct s5p_gpio_bank *bank, int gpio, int en); -void s5p_gpio_direction_input(struct s5p_gpio_bank *bank, int gpio); -void s5p_gpio_set_value(struct s5p_gpio_bank *bank, int gpio, int en); -unsigned int s5p_gpio_get_value(struct s5p_gpio_bank *bank, int gpio); -void s5p_gpio_set_pull(struct s5p_gpio_bank *bank, int gpio, int mode); -void s5p_gpio_set_drv(struct s5p_gpio_bank *bank, int gpio, int mode); -void s5p_gpio_set_rate(struct s5p_gpio_bank *bank, int gpio, int mode); +static const struct gpio_name_num_table exynos5420_gpio_table[] = { + GPIO_ENTRY('a', EXYNOS5420_GPIO_A00, EXYNOS5420_GPIO_B00, 0), + GPIO_ENTRY('b', EXYNOS5420_GPIO_B00, EXYNOS5420_GPIO_H00, 0), + GPIO_ENTRY('h', EXYNOS5420_GPIO_H00, EXYNOS5420_GPIO_Y70, 0), + GPIO_ENTRY('x', EXYNOS5420_GPIO_X00, EXYNOS5420_GPIO_C00, 0), + GPIO_ENTRY('c', EXYNOS5420_GPIO_C00, EXYNOS5420_GPIO_D10, 0), + GPIO_ENTRY('d', EXYNOS5420_GPIO_D10, EXYNOS5420_GPIO_Y00, 010), + GPIO_ENTRY('y', EXYNOS5420_GPIO_Y00, EXYNOS5420_GPIO_E00, 0), + GPIO_ENTRY('e', EXYNOS5420_GPIO_E00, EXYNOS5420_GPIO_F00, 0), + GPIO_ENTRY('f', EXYNOS5420_GPIO_F00, EXYNOS5420_GPIO_G00, 0), + GPIO_ENTRY('g', EXYNOS5420_GPIO_G00, EXYNOS5420_GPIO_J40, 0), + GPIO_ENTRY('j', EXYNOS5420_GPIO_J40, EXYNOS5420_GPIO_Z0, 040), + GPIO_ENTRY('z', EXYNOS5420_GPIO_Z0, EXYNOS5420_GPIO_MAX_PORT, 0), + { 0 } +};
-/* GPIO pins per bank */ -#define GPIO_PER_BANK 8 -#define S5P_GPIO_PART_SHIFT (24) -#define S5P_GPIO_PART_MASK (0xff) -#define S5P_GPIO_BANK_SHIFT (8) -#define S5P_GPIO_BANK_MASK (0xffff) -#define S5P_GPIO_PIN_MASK (0xff) - -#define S5P_GPIO_SET_PART(x) \ - (((x) & S5P_GPIO_PART_MASK) << S5P_GPIO_PART_SHIFT) - -#define S5P_GPIO_GET_PART(x) \ - (((x) >> S5P_GPIO_PART_SHIFT) & S5P_GPIO_PART_MASK) - -#define S5P_GPIO_SET_PIN(x) \ - ((x) & S5P_GPIO_PIN_MASK) - -#define EXYNOS4_GPIO_SET_BANK(part, bank) \ - ((((unsigned)&(((struct exynos4_gpio_part##part *) \ - EXYNOS4_GPIO_PART##part##_BASE)->bank) \ - - EXYNOS4_GPIO_PART##part##_BASE) \ - & S5P_GPIO_BANK_MASK) << S5P_GPIO_BANK_SHIFT) - -#define EXYNOS4X12_GPIO_SET_BANK(part, bank) \ - ((((unsigned)&(((struct exynos4x12_gpio_part##part *) \ - EXYNOS4X12_GPIO_PART##part##_BASE)->bank) \ - - EXYNOS4X12_GPIO_PART##part##_BASE) \ - & S5P_GPIO_BANK_MASK) << S5P_GPIO_BANK_SHIFT) - -#define EXYNOS5_GPIO_SET_BANK(part, bank) \ - ((((unsigned)&(((struct exynos5420_gpio_part##part *) \ - EXYNOS5420_GPIO_PART##part##_BASE)->bank) \ - - EXYNOS5_GPIO_PART##part##_BASE) \ - & S5P_GPIO_BANK_MASK) << S5P_GPIO_BANK_SHIFT) - -#define EXYNOS5420_GPIO_SET_BANK(part, bank) \ - ((((unsigned)&(((struct exynos5420_gpio_part##part *) \ - EXYNOS5420_GPIO_PART##part##_BASE)->bank) \ - - EXYNOS5420_GPIO_PART##part##_BASE) \ - & S5P_GPIO_BANK_MASK) << S5P_GPIO_BANK_SHIFT) - -#define exynos4_gpio_get(part, bank, pin) \ - (S5P_GPIO_SET_PART(part) | \ - EXYNOS4_GPIO_SET_BANK(part, bank) | \ - S5P_GPIO_SET_PIN(pin)) - -#define exynos4x12_gpio_get(part, bank, pin) \ - (S5P_GPIO_SET_PART(part) | \ - EXYNOS4X12_GPIO_SET_BANK(part, bank) | \ - S5P_GPIO_SET_PIN(pin)) - -#define exynos5420_gpio_get(part, bank, pin) \ - (S5P_GPIO_SET_PART(part) | \ - EXYNOS5420_GPIO_SET_BANK(part, bank) | \ - S5P_GPIO_SET_PIN(pin)) - -#define exynos5_gpio_get(part, bank, pin) \ - (S5P_GPIO_SET_PART(part) | \ - EXYNOS5_GPIO_SET_BANK(part, bank) | \ - S5P_GPIO_SET_PIN(pin)) - -static inline unsigned int s5p_gpio_base(int gpio) -{ - unsigned gpio_part = S5P_GPIO_GET_PART(gpio); - - switch (gpio_part) { - case 1: - return samsung_get_base_gpio_part1(); - case 2: - return samsung_get_base_gpio_part2(); - case 3: - return samsung_get_base_gpio_part3(); - case 4: - return samsung_get_base_gpio_part4(); - default: - return 0; - } -} +void gpio_cfg_pin(int gpio, int cfg); +void gpio_set_pull(int gpio, int mode); +void gpio_set_drv(int gpio, int mode); +int gpio_direction_output(unsigned gpio, int value); +int gpio_set_value(unsigned gpio, int value); +int gpio_get_value(unsigned gpio); +void gpio_set_rate(int gpio, int mode); +struct s5p_gpio_bank *s5p_gpio_get_bank(unsigned gpio); +int s5p_gpio_get_pin(unsigned gpio); #endif
/* Pin configurations */ -#define GPIO_INPUT 0x0 -#define GPIO_OUTPUT 0x1 -#define GPIO_IRQ 0xf -#define GPIO_FUNC(x) (x) +#define S5P_GPIO_INPUT 0x0 +#define S5P_GPIO_OUTPUT 0x1 +#define S5P_GPIO_IRQ 0xf +#define S5P_GPIO_FUNC(x) (x)
/* Pull mode */ -#define GPIO_PULL_NONE 0x0 -#define GPIO_PULL_DOWN 0x1 -#define GPIO_PULL_UP 0x3 +#define S5P_GPIO_PULL_NONE 0x0 +#define S5P_GPIO_PULL_DOWN 0x1 +#define S5P_GPIO_PULL_UP 0x3
/* Drive Strength level */ -#define GPIO_DRV_1X 0x0 -#define GPIO_DRV_3X 0x1 -#define GPIO_DRV_2X 0x2 -#define GPIO_DRV_4X 0x3 -#define GPIO_DRV_FAST 0x0 -#define GPIO_DRV_SLOW 0x1 +#define S5P_GPIO_DRV_1X 0x0 +#define S5P_GPIO_DRV_3X 0x1 +#define S5P_GPIO_DRV_2X 0x2 +#define S5P_GPIO_DRV_4X 0x3 +#define S5P_GPIO_DRV_FAST 0x0 +#define S5P_GPIO_DRV_SLOW 0x1 #endif diff --git a/arch/arm/include/asm/arch-s5pc1xx/gpio.h b/arch/arm/include/asm/arch-s5pc1xx/gpio.h index da8df74..d5dbc22 100644 --- a/arch/arm/include/asm/arch-s5pc1xx/gpio.h +++ b/arch/arm/include/asm/arch-s5pc1xx/gpio.h @@ -19,170 +19,830 @@ struct s5p_gpio_bank { unsigned char res1[8]; };
-struct s5pc100_gpio { - struct s5p_gpio_bank a0; - struct s5p_gpio_bank a1; - struct s5p_gpio_bank b; - struct s5p_gpio_bank c; - struct s5p_gpio_bank d; - struct s5p_gpio_bank e0; - struct s5p_gpio_bank e1; - struct s5p_gpio_bank f0; - struct s5p_gpio_bank f1; - struct s5p_gpio_bank f2; - struct s5p_gpio_bank f3; - struct s5p_gpio_bank g0; - struct s5p_gpio_bank g1; - struct s5p_gpio_bank g2; - struct s5p_gpio_bank g3; - struct s5p_gpio_bank i; - struct s5p_gpio_bank j0; - struct s5p_gpio_bank j1; - struct s5p_gpio_bank j2; - struct s5p_gpio_bank j3; - struct s5p_gpio_bank j4; - struct s5p_gpio_bank k0; - struct s5p_gpio_bank k1; - struct s5p_gpio_bank k2; - struct s5p_gpio_bank k3; - struct s5p_gpio_bank l0; - struct s5p_gpio_bank l1; - struct s5p_gpio_bank l2; - struct s5p_gpio_bank l3; - struct s5p_gpio_bank l4; - struct s5p_gpio_bank h0; - struct s5p_gpio_bank h1; - struct s5p_gpio_bank h2; - struct s5p_gpio_bank h3; +/* A list of valid GPIO numbers for the asm-generic/gpio.h interface */ +enum s5pc100_gpio_pin { + S5PC100_GPIO_A00, + S5PC100_GPIO_A01, + S5PC100_GPIO_A02, + S5PC100_GPIO_A03, + S5PC100_GPIO_A04, + S5PC100_GPIO_A05, + S5PC100_GPIO_A06, + S5PC100_GPIO_A07, + S5PC100_GPIO_A10, + S5PC100_GPIO_A11, + S5PC100_GPIO_A12, + S5PC100_GPIO_A13, + S5PC100_GPIO_A14, + S5PC100_GPIO_A15, + S5PC100_GPIO_A16, + S5PC100_GPIO_A17, + S5PC100_GPIO_B0, + S5PC100_GPIO_B1, + S5PC100_GPIO_B2, + S5PC100_GPIO_B3, + S5PC100_GPIO_B4, + S5PC100_GPIO_B5, + S5PC100_GPIO_B6, + S5PC100_GPIO_B7, + S5PC100_GPIO_C0, + S5PC100_GPIO_C1, + S5PC100_GPIO_C2, + S5PC100_GPIO_C3, + S5PC100_GPIO_C4, + S5PC100_GPIO_C5, + S5PC100_GPIO_C6, + S5PC100_GPIO_C7, + S5PC100_GPIO_D0, + S5PC100_GPIO_D1, + S5PC100_GPIO_D2, + S5PC100_GPIO_D3, + S5PC100_GPIO_D4, + S5PC100_GPIO_D5, + S5PC100_GPIO_D6, + S5PC100_GPIO_D7, + S5PC100_GPIO_E00, + S5PC100_GPIO_E01, + S5PC100_GPIO_E02, + S5PC100_GPIO_E03, + S5PC100_GPIO_E04, + S5PC100_GPIO_E05, + S5PC100_GPIO_E06, + S5PC100_GPIO_E07, + S5PC100_GPIO_E10, + S5PC100_GPIO_E11, + S5PC100_GPIO_E12, + S5PC100_GPIO_E13, + S5PC100_GPIO_E14, + S5PC100_GPIO_E15, + S5PC100_GPIO_E16, + S5PC100_GPIO_E17, + S5PC100_GPIO_F00, + S5PC100_GPIO_F01, + S5PC100_GPIO_F02, + S5PC100_GPIO_F03, + S5PC100_GPIO_F04, + S5PC100_GPIO_F05, + S5PC100_GPIO_F06, + S5PC100_GPIO_F07, + S5PC100_GPIO_F10, + S5PC100_GPIO_F11, + S5PC100_GPIO_F12, + S5PC100_GPIO_F13, + S5PC100_GPIO_F14, + S5PC100_GPIO_F15, + S5PC100_GPIO_F16, + S5PC100_GPIO_F17, + S5PC100_GPIO_F20, + S5PC100_GPIO_F21, + S5PC100_GPIO_F22, + S5PC100_GPIO_F23, + S5PC100_GPIO_F24, + S5PC100_GPIO_F25, + S5PC100_GPIO_F26, + S5PC100_GPIO_F27, + S5PC100_GPIO_F30, + S5PC100_GPIO_F31, + S5PC100_GPIO_F32, + S5PC100_GPIO_F33, + S5PC100_GPIO_F34, + S5PC100_GPIO_F35, + S5PC100_GPIO_F36, + S5PC100_GPIO_F37, + S5PC100_GPIO_G00, + S5PC100_GPIO_G01, + S5PC100_GPIO_G02, + S5PC100_GPIO_G03, + S5PC100_GPIO_G04, + S5PC100_GPIO_G05, + S5PC100_GPIO_G06, + S5PC100_GPIO_G07, + S5PC100_GPIO_G10, + S5PC100_GPIO_G11, + S5PC100_GPIO_G12, + S5PC100_GPIO_G13, + S5PC100_GPIO_G14, + S5PC100_GPIO_G15, + S5PC100_GPIO_G16, + S5PC100_GPIO_G17, + S5PC100_GPIO_G20, + S5PC100_GPIO_G21, + S5PC100_GPIO_G22, + S5PC100_GPIO_G23, + S5PC100_GPIO_G24, + S5PC100_GPIO_G25, + S5PC100_GPIO_G26, + S5PC100_GPIO_G27, + S5PC100_GPIO_G30, + S5PC100_GPIO_G31, + S5PC100_GPIO_G32, + S5PC100_GPIO_G33, + S5PC100_GPIO_G34, + S5PC100_GPIO_G35, + S5PC100_GPIO_G36, + S5PC100_GPIO_G37, + S5PC100_GPIO_I0, + S5PC100_GPIO_I1, + S5PC100_GPIO_I2, + S5PC100_GPIO_I3, + S5PC100_GPIO_I4, + S5PC100_GPIO_I5, + S5PC100_GPIO_I6, + S5PC100_GPIO_I7, + S5PC100_GPIO_J00, + S5PC100_GPIO_J01, + S5PC100_GPIO_J02, + S5PC100_GPIO_J03, + S5PC100_GPIO_J04, + S5PC100_GPIO_J05, + S5PC100_GPIO_J06, + S5PC100_GPIO_J07, + S5PC100_GPIO_J10, + S5PC100_GPIO_J11, + S5PC100_GPIO_J12, + S5PC100_GPIO_J13, + S5PC100_GPIO_J14, + S5PC100_GPIO_J15, + S5PC100_GPIO_J16, + S5PC100_GPIO_J17, + S5PC100_GPIO_J20, + S5PC100_GPIO_J21, + S5PC100_GPIO_J22, + S5PC100_GPIO_J23, + S5PC100_GPIO_J24, + S5PC100_GPIO_J25, + S5PC100_GPIO_J26, + S5PC100_GPIO_J27, + S5PC100_GPIO_J30, + S5PC100_GPIO_J31, + S5PC100_GPIO_J32, + S5PC100_GPIO_J33, + S5PC100_GPIO_J34, + S5PC100_GPIO_J35, + S5PC100_GPIO_J36, + S5PC100_GPIO_J37, + S5PC100_GPIO_J40, + S5PC100_GPIO_J41, + S5PC100_GPIO_J42, + S5PC100_GPIO_J43, + S5PC100_GPIO_J44, + S5PC100_GPIO_J45, + S5PC100_GPIO_J46, + S5PC100_GPIO_J47, + S5PC100_GPIO_K00, + S5PC100_GPIO_K01, + S5PC100_GPIO_K02, + S5PC100_GPIO_K03, + S5PC100_GPIO_K04, + S5PC100_GPIO_K05, + S5PC100_GPIO_K06, + S5PC100_GPIO_K07, + S5PC100_GPIO_K10, + S5PC100_GPIO_K11, + S5PC100_GPIO_K12, + S5PC100_GPIO_K13, + S5PC100_GPIO_K14, + S5PC100_GPIO_K15, + S5PC100_GPIO_K16, + S5PC100_GPIO_K17, + S5PC100_GPIO_K20, + S5PC100_GPIO_K21, + S5PC100_GPIO_K22, + S5PC100_GPIO_K23, + S5PC100_GPIO_K24, + S5PC100_GPIO_K25, + S5PC100_GPIO_K26, + S5PC100_GPIO_K27, + S5PC100_GPIO_K30, + S5PC100_GPIO_K31, + S5PC100_GPIO_K32, + S5PC100_GPIO_K33, + S5PC100_GPIO_K34, + S5PC100_GPIO_K35, + S5PC100_GPIO_K36, + S5PC100_GPIO_K37, + S5PC100_GPIO_L00, + S5PC100_GPIO_L01, + S5PC100_GPIO_L02, + S5PC100_GPIO_L03, + S5PC100_GPIO_L04, + S5PC100_GPIO_L05, + S5PC100_GPIO_L06, + S5PC100_GPIO_L07, + S5PC100_GPIO_L10, + S5PC100_GPIO_L11, + S5PC100_GPIO_L12, + S5PC100_GPIO_L13, + S5PC100_GPIO_L14, + S5PC100_GPIO_L15, + S5PC100_GPIO_L16, + S5PC100_GPIO_L17, + S5PC100_GPIO_L20, + S5PC100_GPIO_L21, + S5PC100_GPIO_L22, + S5PC100_GPIO_L23, + S5PC100_GPIO_L24, + S5PC100_GPIO_L25, + S5PC100_GPIO_L26, + S5PC100_GPIO_L27, + S5PC100_GPIO_L30, + S5PC100_GPIO_L31, + S5PC100_GPIO_L32, + S5PC100_GPIO_L33, + S5PC100_GPIO_L34, + S5PC100_GPIO_L35, + S5PC100_GPIO_L36, + S5PC100_GPIO_L37, + S5PC100_GPIO_L40, + S5PC100_GPIO_L41, + S5PC100_GPIO_L42, + S5PC100_GPIO_L43, + S5PC100_GPIO_L44, + S5PC100_GPIO_L45, + S5PC100_GPIO_L46, + S5PC100_GPIO_L47, + S5PC100_GPIO_H00, + S5PC100_GPIO_H01, + S5PC100_GPIO_H02, + S5PC100_GPIO_H03, + S5PC100_GPIO_H04, + S5PC100_GPIO_H05, + S5PC100_GPIO_H06, + S5PC100_GPIO_H07, + S5PC100_GPIO_H10, + S5PC100_GPIO_H11, + S5PC100_GPIO_H12, + S5PC100_GPIO_H13, + S5PC100_GPIO_H14, + S5PC100_GPIO_H15, + S5PC100_GPIO_H16, + S5PC100_GPIO_H17, + S5PC100_GPIO_H20, + S5PC100_GPIO_H21, + S5PC100_GPIO_H22, + S5PC100_GPIO_H23, + S5PC100_GPIO_H24, + S5PC100_GPIO_H25, + S5PC100_GPIO_H26, + S5PC100_GPIO_H27, + S5PC100_GPIO_H30, + S5PC100_GPIO_H31, + S5PC100_GPIO_H32, + S5PC100_GPIO_H33, + S5PC100_GPIO_H34, + S5PC100_GPIO_H35, + S5PC100_GPIO_H36, + S5PC100_GPIO_H37, + + S5PC100_GPIO_MAX_PORT };
-struct s5pc110_gpio { - struct s5p_gpio_bank a0; - struct s5p_gpio_bank a1; - struct s5p_gpio_bank b; - struct s5p_gpio_bank c0; - struct s5p_gpio_bank c1; - struct s5p_gpio_bank d0; - struct s5p_gpio_bank d1; - struct s5p_gpio_bank e0; - struct s5p_gpio_bank e1; - struct s5p_gpio_bank f0; - struct s5p_gpio_bank f1; - struct s5p_gpio_bank f2; - struct s5p_gpio_bank f3; - struct s5p_gpio_bank g0; - struct s5p_gpio_bank g1; - struct s5p_gpio_bank g2; - struct s5p_gpio_bank g3; - struct s5p_gpio_bank i; - struct s5p_gpio_bank j0; - struct s5p_gpio_bank j1; - struct s5p_gpio_bank j2; - struct s5p_gpio_bank j3; - struct s5p_gpio_bank j4; - struct s5p_gpio_bank mp0_1; - struct s5p_gpio_bank mp0_2; - struct s5p_gpio_bank mp0_3; - struct s5p_gpio_bank mp0_4; - struct s5p_gpio_bank mp0_5; - struct s5p_gpio_bank mp0_6; - struct s5p_gpio_bank mp0_7; - struct s5p_gpio_bank mp1_0; - struct s5p_gpio_bank mp1_1; - struct s5p_gpio_bank mp1_2; - struct s5p_gpio_bank mp1_3; - struct s5p_gpio_bank mp1_4; - struct s5p_gpio_bank mp1_5; - struct s5p_gpio_bank mp1_6; - struct s5p_gpio_bank mp1_7; - struct s5p_gpio_bank mp1_8; - struct s5p_gpio_bank mp2_0; - struct s5p_gpio_bank mp2_1; - struct s5p_gpio_bank mp2_2; - struct s5p_gpio_bank mp2_3; - struct s5p_gpio_bank mp2_4; - struct s5p_gpio_bank mp2_5; - struct s5p_gpio_bank mp2_6; - struct s5p_gpio_bank mp2_7; - struct s5p_gpio_bank mp2_8; - struct s5p_gpio_bank res1[48]; - struct s5p_gpio_bank h0; - struct s5p_gpio_bank h1; - struct s5p_gpio_bank h2; - struct s5p_gpio_bank h3; +enum s5pc110_gpio_pin { + S5PC110_GPIO_A00, + S5PC110_GPIO_A01, + S5PC110_GPIO_A02, + S5PC110_GPIO_A03, + S5PC110_GPIO_A04, + S5PC110_GPIO_A05, + S5PC110_GPIO_A06, + S5PC110_GPIO_A07, + S5PC110_GPIO_A10, + S5PC110_GPIO_A11, + S5PC110_GPIO_A12, + S5PC110_GPIO_A13, + S5PC110_GPIO_A14, + S5PC110_GPIO_A15, + S5PC110_GPIO_A16, + S5PC110_GPIO_A17, + S5PC110_GPIO_B0, + S5PC110_GPIO_B1, + S5PC110_GPIO_B2, + S5PC110_GPIO_B3, + S5PC110_GPIO_B4, + S5PC110_GPIO_B5, + S5PC110_GPIO_B6, + S5PC110_GPIO_B7, + S5PC110_GPIO_C00, + S5PC110_GPIO_C01, + S5PC110_GPIO_C02, + S5PC110_GPIO_C03, + S5PC110_GPIO_C04, + S5PC110_GPIO_C05, + S5PC110_GPIO_C06, + S5PC110_GPIO_C07, + S5PC110_GPIO_C10, + S5PC110_GPIO_C11, + S5PC110_GPIO_C12, + S5PC110_GPIO_C13, + S5PC110_GPIO_C14, + S5PC110_GPIO_C15, + S5PC110_GPIO_C16, + S5PC110_GPIO_C17, + S5PC110_GPIO_D00, + S5PC110_GPIO_D01, + S5PC110_GPIO_D02, + S5PC110_GPIO_D03, + S5PC110_GPIO_D04, + S5PC110_GPIO_D05, + S5PC110_GPIO_D06, + S5PC110_GPIO_D07, + S5PC110_GPIO_D10, + S5PC110_GPIO_D11, + S5PC110_GPIO_D12, + S5PC110_GPIO_D13, + S5PC110_GPIO_D14, + S5PC110_GPIO_D15, + S5PC110_GPIO_D16, + S5PC110_GPIO_D17, + S5PC110_GPIO_E00, + S5PC110_GPIO_E01, + S5PC110_GPIO_E02, + S5PC110_GPIO_E03, + S5PC110_GPIO_E04, + S5PC110_GPIO_E05, + S5PC110_GPIO_E06, + S5PC110_GPIO_E07, + S5PC110_GPIO_E10, + S5PC110_GPIO_E11, + S5PC110_GPIO_E12, + S5PC110_GPIO_E13, + S5PC110_GPIO_E14, + S5PC110_GPIO_E15, + S5PC110_GPIO_E16, + S5PC110_GPIO_E17, + S5PC110_GPIO_F00, + S5PC110_GPIO_F01, + S5PC110_GPIO_F02, + S5PC110_GPIO_F03, + S5PC110_GPIO_F04, + S5PC110_GPIO_F05, + S5PC110_GPIO_F06, + S5PC110_GPIO_F07, + S5PC110_GPIO_F10, + S5PC110_GPIO_F11, + S5PC110_GPIO_F12, + S5PC110_GPIO_F13, + S5PC110_GPIO_F14, + S5PC110_GPIO_F15, + S5PC110_GPIO_F16, + S5PC110_GPIO_F17, + S5PC110_GPIO_F20, + S5PC110_GPIO_F21, + S5PC110_GPIO_F22, + S5PC110_GPIO_F23, + S5PC110_GPIO_F24, + S5PC110_GPIO_F25, + S5PC110_GPIO_F26, + S5PC110_GPIO_F27, + S5PC110_GPIO_F30, + S5PC110_GPIO_F31, + S5PC110_GPIO_F32, + S5PC110_GPIO_F33, + S5PC110_GPIO_F34, + S5PC110_GPIO_F35, + S5PC110_GPIO_F36, + S5PC110_GPIO_F37, + S5PC110_GPIO_G00, + S5PC110_GPIO_G01, + S5PC110_GPIO_G02, + S5PC110_GPIO_G03, + S5PC110_GPIO_G04, + S5PC110_GPIO_G05, + S5PC110_GPIO_G06, + S5PC110_GPIO_G07, + S5PC110_GPIO_G10, + S5PC110_GPIO_G11, + S5PC110_GPIO_G12, + S5PC110_GPIO_G13, + S5PC110_GPIO_G14, + S5PC110_GPIO_G15, + S5PC110_GPIO_G16, + S5PC110_GPIO_G17, + S5PC110_GPIO_G20, + S5PC110_GPIO_G21, + S5PC110_GPIO_G22, + S5PC110_GPIO_G23, + S5PC110_GPIO_G24, + S5PC110_GPIO_G25, + S5PC110_GPIO_G26, + S5PC110_GPIO_G27, + S5PC110_GPIO_G30, + S5PC110_GPIO_G31, + S5PC110_GPIO_G32, + S5PC110_GPIO_G33, + S5PC110_GPIO_G34, + S5PC110_GPIO_G35, + S5PC110_GPIO_G36, + S5PC110_GPIO_G37, + S5PC110_GPIO_I0, + S5PC110_GPIO_I1, + S5PC110_GPIO_I2, + S5PC110_GPIO_I3, + S5PC110_GPIO_I4, + S5PC110_GPIO_I5, + S5PC110_GPIO_I6, + S5PC110_GPIO_I7, + S5PC110_GPIO_J00, + S5PC110_GPIO_J01, + S5PC110_GPIO_J02, + S5PC110_GPIO_J03, + S5PC110_GPIO_J04, + S5PC110_GPIO_J05, + S5PC110_GPIO_J06, + S5PC110_GPIO_J07, + S5PC110_GPIO_J10, + S5PC110_GPIO_J11, + S5PC110_GPIO_J12, + S5PC110_GPIO_J13, + S5PC110_GPIO_J14, + S5PC110_GPIO_J15, + S5PC110_GPIO_J16, + S5PC110_GPIO_J17, + S5PC110_GPIO_J20, + S5PC110_GPIO_J21, + S5PC110_GPIO_J22, + S5PC110_GPIO_J23, + S5PC110_GPIO_J24, + S5PC110_GPIO_J25, + S5PC110_GPIO_J26, + S5PC110_GPIO_J27, + S5PC110_GPIO_J30, + S5PC110_GPIO_J31, + S5PC110_GPIO_J32, + S5PC110_GPIO_J33, + S5PC110_GPIO_J34, + S5PC110_GPIO_J35, + S5PC110_GPIO_J36, + S5PC110_GPIO_J37, + S5PC110_GPIO_J40, + S5PC110_GPIO_J41, + S5PC110_GPIO_J42, + S5PC110_GPIO_J43, + S5PC110_GPIO_J44, + S5PC110_GPIO_J45, + S5PC110_GPIO_J46, + S5PC110_GPIO_J47, + S5PC110_GPIO_MP010, + S5PC110_GPIO_MP011, + S5PC110_GPIO_MP012, + S5PC110_GPIO_MP013, + S5PC110_GPIO_MP014, + S5PC110_GPIO_MP015, + S5PC110_GPIO_MP016, + S5PC110_GPIO_MP017, + S5PC110_GPIO_MP020, + S5PC110_GPIO_MP021, + S5PC110_GPIO_MP022, + S5PC110_GPIO_MP023, + S5PC110_GPIO_MP024, + S5PC110_GPIO_MP025, + S5PC110_GPIO_MP026, + S5PC110_GPIO_MP027, + S5PC110_GPIO_MP030, + S5PC110_GPIO_MP031, + S5PC110_GPIO_MP032, + S5PC110_GPIO_MP033, + S5PC110_GPIO_MP034, + S5PC110_GPIO_MP035, + S5PC110_GPIO_MP036, + S5PC110_GPIO_MP037, + S5PC110_GPIO_MP040, + S5PC110_GPIO_MP041, + S5PC110_GPIO_MP042, + S5PC110_GPIO_MP043, + S5PC110_GPIO_MP044, + S5PC110_GPIO_MP045, + S5PC110_GPIO_MP046, + S5PC110_GPIO_MP047, + S5PC110_GPIO_MP050, + S5PC110_GPIO_MP051, + S5PC110_GPIO_MP052, + S5PC110_GPIO_MP053, + S5PC110_GPIO_MP054, + S5PC110_GPIO_MP055, + S5PC110_GPIO_MP056, + S5PC110_GPIO_MP057, + S5PC110_GPIO_MP060, + S5PC110_GPIO_MP061, + S5PC110_GPIO_MP062, + S5PC110_GPIO_MP063, + S5PC110_GPIO_MP064, + S5PC110_GPIO_MP065, + S5PC110_GPIO_MP066, + S5PC110_GPIO_MP067, + S5PC110_GPIO_MP070, + S5PC110_GPIO_MP071, + S5PC110_GPIO_MP072, + S5PC110_GPIO_MP073, + S5PC110_GPIO_MP074, + S5PC110_GPIO_MP075, + S5PC110_GPIO_MP076, + S5PC110_GPIO_MP077, + S5PC110_GPIO_MP100, + S5PC110_GPIO_MP101, + S5PC110_GPIO_MP102, + S5PC110_GPIO_MP103, + S5PC110_GPIO_MP104, + S5PC110_GPIO_MP105, + S5PC110_GPIO_MP106, + S5PC110_GPIO_MP107, + S5PC110_GPIO_MP110, + S5PC110_GPIO_MP111, + S5PC110_GPIO_MP112, + S5PC110_GPIO_MP113, + S5PC110_GPIO_MP114, + S5PC110_GPIO_MP115, + S5PC110_GPIO_MP116, + S5PC110_GPIO_MP117, + S5PC110_GPIO_MP120, + S5PC110_GPIO_MP121, + S5PC110_GPIO_MP122, + S5PC110_GPIO_MP123, + S5PC110_GPIO_MP124, + S5PC110_GPIO_MP125, + S5PC110_GPIO_MP126, + S5PC110_GPIO_MP127, + S5PC110_GPIO_MP130, + S5PC110_GPIO_MP131, + S5PC110_GPIO_MP132, + S5PC110_GPIO_MP133, + S5PC110_GPIO_MP134, + S5PC110_GPIO_MP135, + S5PC110_GPIO_MP136, + S5PC110_GPIO_MP137, + S5PC110_GPIO_MP140, + S5PC110_GPIO_MP141, + S5PC110_GPIO_MP142, + S5PC110_GPIO_MP143, + S5PC110_GPIO_MP144, + S5PC110_GPIO_MP145, + S5PC110_GPIO_MP146, + S5PC110_GPIO_MP147, + S5PC110_GPIO_MP150, + S5PC110_GPIO_MP151, + S5PC110_GPIO_MP152, + S5PC110_GPIO_MP153, + S5PC110_GPIO_MP154, + S5PC110_GPIO_MP155, + S5PC110_GPIO_MP156, + S5PC110_GPIO_MP157, + S5PC110_GPIO_MP160, + S5PC110_GPIO_MP161, + S5PC110_GPIO_MP162, + S5PC110_GPIO_MP163, + S5PC110_GPIO_MP164, + S5PC110_GPIO_MP165, + S5PC110_GPIO_MP166, + S5PC110_GPIO_MP167, + S5PC110_GPIO_MP170, + S5PC110_GPIO_MP171, + S5PC110_GPIO_MP172, + S5PC110_GPIO_MP173, + S5PC110_GPIO_MP174, + S5PC110_GPIO_MP175, + S5PC110_GPIO_MP176, + S5PC110_GPIO_MP177, + S5PC110_GPIO_MP180, + S5PC110_GPIO_MP181, + S5PC110_GPIO_MP182, + S5PC110_GPIO_MP183, + S5PC110_GPIO_MP184, + S5PC110_GPIO_MP185, + S5PC110_GPIO_MP186, + S5PC110_GPIO_MP187, + S5PC110_GPIO_MP200, + S5PC110_GPIO_MP201, + S5PC110_GPIO_MP202, + S5PC110_GPIO_MP203, + S5PC110_GPIO_MP204, + S5PC110_GPIO_MP205, + S5PC110_GPIO_MP206, + S5PC110_GPIO_MP207, + S5PC110_GPIO_MP210, + S5PC110_GPIO_MP211, + S5PC110_GPIO_MP212, + S5PC110_GPIO_MP213, + S5PC110_GPIO_MP214, + S5PC110_GPIO_MP215, + S5PC110_GPIO_MP216, + S5PC110_GPIO_MP217, + S5PC110_GPIO_MP220, + S5PC110_GPIO_MP221, + S5PC110_GPIO_MP222, + S5PC110_GPIO_MP223, + S5PC110_GPIO_MP224, + S5PC110_GPIO_MP225, + S5PC110_GPIO_MP226, + S5PC110_GPIO_MP227, + S5PC110_GPIO_MP230, + S5PC110_GPIO_MP231, + S5PC110_GPIO_MP232, + S5PC110_GPIO_MP233, + S5PC110_GPIO_MP234, + S5PC110_GPIO_MP235, + S5PC110_GPIO_MP236, + S5PC110_GPIO_MP237, + S5PC110_GPIO_MP240, + S5PC110_GPIO_MP241, + S5PC110_GPIO_MP242, + S5PC110_GPIO_MP243, + S5PC110_GPIO_MP244, + S5PC110_GPIO_MP245, + S5PC110_GPIO_MP246, + S5PC110_GPIO_MP247, + S5PC110_GPIO_MP250, + S5PC110_GPIO_MP251, + S5PC110_GPIO_MP252, + S5PC110_GPIO_MP253, + S5PC110_GPIO_MP254, + S5PC110_GPIO_MP255, + S5PC110_GPIO_MP256, + S5PC110_GPIO_MP257, + S5PC110_GPIO_MP260, + S5PC110_GPIO_MP261, + S5PC110_GPIO_MP262, + S5PC110_GPIO_MP263, + S5PC110_GPIO_MP264, + S5PC110_GPIO_MP265, + S5PC110_GPIO_MP266, + S5PC110_GPIO_MP267, + S5PC110_GPIO_MP270, + S5PC110_GPIO_MP271, + S5PC110_GPIO_MP272, + S5PC110_GPIO_MP273, + S5PC110_GPIO_MP274, + S5PC110_GPIO_MP275, + S5PC110_GPIO_MP276, + S5PC110_GPIO_MP277, + S5PC110_GPIO_MP280, + S5PC110_GPIO_MP281, + S5PC110_GPIO_MP282, + S5PC110_GPIO_MP283, + S5PC110_GPIO_MP284, + S5PC110_GPIO_MP285, + S5PC110_GPIO_MP286, + S5PC110_GPIO_MP287, + S5PC110_GPIO_RES, + S5PC110_GPIO_H00 = (S5PC110_GPIO_RES + (48 * 8)), + S5PC110_GPIO_H01, + S5PC110_GPIO_H02, + S5PC110_GPIO_H03, + S5PC110_GPIO_H04, + S5PC110_GPIO_H05, + S5PC110_GPIO_H06, + S5PC110_GPIO_H07, + S5PC110_GPIO_H10, + S5PC110_GPIO_H11, + S5PC110_GPIO_H12, + S5PC110_GPIO_H13, + S5PC110_GPIO_H14, + S5PC110_GPIO_H15, + S5PC110_GPIO_H16, + S5PC110_GPIO_H17, + S5PC110_GPIO_H20, + S5PC110_GPIO_H21, + S5PC110_GPIO_H22, + S5PC110_GPIO_H23, + S5PC110_GPIO_H24, + S5PC110_GPIO_H25, + S5PC110_GPIO_H26, + S5PC110_GPIO_H27, + S5PC110_GPIO_H30, + S5PC110_GPIO_H31, + S5PC110_GPIO_H32, + S5PC110_GPIO_H33, + S5PC110_GPIO_H34, + S5PC110_GPIO_H35, + S5PC110_GPIO_H36, + S5PC110_GPIO_H37, + + S5PC110_GPIO_MAX_PORT };
-/* functions */ -void s5p_gpio_cfg_pin(struct s5p_gpio_bank *bank, int gpio, int cfg); -void s5p_gpio_direction_output(struct s5p_gpio_bank *bank, int gpio, int en); -void s5p_gpio_direction_input(struct s5p_gpio_bank *bank, int gpio); -void s5p_gpio_set_value(struct s5p_gpio_bank *bank, int gpio, int en); -unsigned int s5p_gpio_get_value(struct s5p_gpio_bank *bank, int gpio); -void s5p_gpio_set_pull(struct s5p_gpio_bank *bank, int gpio, int mode); -void s5p_gpio_set_drv(struct s5p_gpio_bank *bank, int gpio, int mode); -void s5p_gpio_set_rate(struct s5p_gpio_bank *bank, int gpio, int mode); +struct gpio_info { + unsigned int reg_addr; /* Address of register for this part */ + unsigned int max_gpio; /* Maximum GPIO in this part */ +};
-/* GPIO pins per bank */ -#define GPIO_PER_BANK 8 +#define S5PC100_GPIO_NUM_PARTS 1 +static struct gpio_info s5pc100_gpio_data[S5PC100_GPIO_NUM_PARTS] = { + { S5PC100_GPIO_BASE, S5PC100_GPIO_MAX_PORT }, +};
-#define S5P_GPIO_PART_SHIFT (24) -#define S5P_GPIO_PART_MASK (0xff) -#define S5P_GPIO_BANK_SHIFT (8) -#define S5P_GPIO_BANK_MASK (0xffff) -#define S5P_GPIO_PIN_MASK (0xff) +#define S5PC110_GPIO_NUM_PARTS 1 +static struct gpio_info s5pc110_gpio_data[S5PC110_GPIO_NUM_PARTS] = { + { S5PC110_GPIO_BASE, S5PC110_GPIO_MAX_PORT }, +};
-#define S5P_GPIO_SET_PART(x) \ - (((x) & S5P_GPIO_PART_MASK) << S5P_GPIO_PART_SHIFT) +static inline struct gpio_info *get_gpio_data(void) +{ + if (cpu_is_s5pc100()) + return s5pc100_gpio_data; + else if (cpu_is_s5pc110()) + return s5pc110_gpio_data;
-#define S5P_GPIO_GET_PART(x) \ - (((x) >> S5P_GPIO_PART_SHIFT) & S5P_GPIO_PART_MASK) + return NULL; +}
-#define S5P_GPIO_SET_PIN(x) \ - ((x) & S5P_GPIO_PIN_MASK) +static inline unsigned int get_bank_num(void) +{ + if (cpu_is_s5pc100()) + return S5PC100_GPIO_NUM_PARTS; + else if (cpu_is_s5pc110()) + return S5PC110_GPIO_NUM_PARTS;
-#define S5PC100_SET_BANK(bank) \ - (((unsigned)&(((struct s5pc100_gpio *) \ - S5PC100_GPIO_BASE)->bank) - S5PC100_GPIO_BASE) \ - & S5P_GPIO_BANK_MASK) << S5P_GPIO_BANK_SHIFT) + return 0; +}
-#define S5PC110_SET_BANK(bank) \ - ((((unsigned)&(((struct s5pc110_gpio *) \ - S5PC110_GPIO_BASE)->bank) - S5PC110_GPIO_BASE) \ - & S5P_GPIO_BANK_MASK) << S5P_GPIO_BANK_SHIFT) +/* + * This structure helps mapping symbolic GPIO names into indices from + * exynos5_gpio_pin/exynos5420_gpio_pin enums. + * + * By convention, symbolic GPIO name is defined as follows: + * + * g[p]<bank><set><bit>, where + * p is optional + * <bank> - a single character bank name, as defined by the SOC + * <set> - a single digit set number + * <bit> - bit number within the set (in 0..7 range). + * + * <set><bit> essentially form an octal number of the GPIO pin within the bank + * space. On the 5420 architecture some banks' sets do not start not from zero + * ('d' starts from 1 and 'j' starts from 4). To compensate for that and + * maintain flat number space withoout holes, those banks use offsets to be + * deducted from the pin number. + */ +struct gpio_name_num_table { + char bank; /* bank name symbol */ + u8 bank_size; /* total number of pins in the bank */ + char bank_offset; /* offset of the first bank's pin */ + unsigned int base; /* index of the first bank's pin in the enum */ +};
-#define s5pc100_gpio_get(bank, pin) \ - (S5P_GPIO_SET_PART(0) | \ - S5PC100_SET_BANK(bank) | \ - S5P_GPIO_SET_PIN(pin)) +#define GPIO_PER_BANK 8 +#define GPIO_ENTRY(name, base, top, offset) { name, top - base, offset, base } +static const struct gpio_name_num_table s5pc100_gpio_table[] = { + GPIO_ENTRY('a', S5PC100_GPIO_A00, S5PC100_GPIO_B0, 0), + GPIO_ENTRY('b', S5PC100_GPIO_B0, S5PC100_GPIO_C0, 0), + GPIO_ENTRY('c', S5PC100_GPIO_C0, S5PC100_GPIO_D0, 0), + GPIO_ENTRY('d', S5PC100_GPIO_D0, S5PC100_GPIO_E00, 0), + GPIO_ENTRY('e', S5PC100_GPIO_E00, S5PC100_GPIO_F00, 0), + GPIO_ENTRY('f', S5PC100_GPIO_F00, S5PC100_GPIO_G00, 0), + GPIO_ENTRY('g', S5PC100_GPIO_G00, S5PC100_GPIO_I0, 0), + GPIO_ENTRY('i', S5PC100_GPIO_I0, S5PC100_GPIO_J00, 0), + GPIO_ENTRY('j', S5PC100_GPIO_J00, S5PC100_GPIO_K00, 0), + GPIO_ENTRY('k', S5PC100_GPIO_K00, S5PC100_GPIO_L00, 0), + GPIO_ENTRY('l', S5PC100_GPIO_L00, S5PC100_GPIO_H00, 0), + GPIO_ENTRY('h', S5PC100_GPIO_H00, S5PC100_GPIO_MAX_PORT, 0), + { 0 } +};
-#define s5pc110_gpio_get(bank, pin) \ - (S5P_GPIO_SET_PART(0) | \ - S5PC110_SET_BANK(bank) | \ - S5P_GPIO_SET_PIN(pin)) +static const struct gpio_name_num_table s5pc110_gpio_table[] = { + GPIO_ENTRY('a', S5PC110_GPIO_A00, S5PC110_GPIO_B0, 0), + GPIO_ENTRY('b', S5PC110_GPIO_B0, S5PC110_GPIO_C00, 0), + GPIO_ENTRY('c', S5PC110_GPIO_C00, S5PC110_GPIO_D00, 0), + GPIO_ENTRY('d', S5PC110_GPIO_D00, S5PC110_GPIO_E00, 0), + GPIO_ENTRY('e', S5PC110_GPIO_E00, S5PC110_GPIO_F00, 0), + GPIO_ENTRY('f', S5PC110_GPIO_F00, S5PC110_GPIO_G00, 0), + GPIO_ENTRY('g', S5PC110_GPIO_G00, S5PC110_GPIO_I0, 0), + GPIO_ENTRY('i', S5PC110_GPIO_I0, S5PC110_GPIO_J00, 0), + GPIO_ENTRY('j', S5PC110_GPIO_J00, S5PC110_GPIO_MP010, 0), + GPIO_ENTRY('h', S5PC110_GPIO_H00, S5PC110_GPIO_MAX_PORT, 0), + { 0 } +};
-static inline unsigned int s5p_gpio_base(int nr) -{ - return samsung_get_base_gpio(); -} +/* functions */ +void gpio_cfg_pin(int gpio, int cfg); +void gpio_set_pull(int gpio, int mode); +void gpio_set_drv(int gpio, int mode); +int gpio_direction_output(unsigned gpio, int value); +int gpio_set_value(unsigned gpio, int value); +int gpio_get_value(unsigned gpio); +void gpio_set_rate(int gpio, int mode); +struct s5p_gpio_bank *s5p_gpio_get_bank(unsigned gpio); +int s5p_gpio_get_pin(unsigned gpio); + +/* GPIO pins per bank */ +#define GPIO_PER_BANK 8 #endif
/* Pull mode */ -#define GPIO_PULL_NONE 0x0 -#define GPIO_PULL_DOWN 0x1 -#define GPIO_PULL_UP 0x2 +#define S5P_GPIO_PULL_NONE 0x0 +#define S5P_GPIO_PULL_DOWN 0x1 +#define S5P_GPIO_PULL_UP 0x2
#endif diff --git a/board/samsung/arndale/arndale.c b/board/samsung/arndale/arndale.c index 9efc355..ef88314 100644 --- a/board/samsung/arndale/arndale.c +++ b/board/samsung/arndale/arndale.c @@ -16,17 +16,14 @@ DECLARE_GLOBAL_DATA_PTR; #ifdef CONFIG_USB_EHCI_EXYNOS int board_usb_init(int index, enum usb_init_type init) { - struct exynos5_gpio_part1 *gpio = (struct exynos5_gpio_part1 *) - samsung_get_base_gpio_part1(); - /* Configure gpios for usb 3503 hub: * disconnect, toggle reset and connect */ - s5p_gpio_direction_output(&gpio->d1, 7, 0); - s5p_gpio_direction_output(&gpio->x3, 5, 0); + gpio_direction_output(EXYNOS5_GPIO_D17, 0); + gpio_direction_output(EXYNOS5_GPIO_X35, 0);
- s5p_gpio_direction_output(&gpio->x3, 5, 1); - s5p_gpio_direction_output(&gpio->d1, 7, 1); + gpio_direction_output(EXYNOS5_GPIO_X35, 1); + gpio_direction_output(EXYNOS5_GPIO_D17, 1);
return 0; } diff --git a/board/samsung/goni/goni.c b/board/samsung/goni/goni.c index 61b9ece..4cea63b 100644 --- a/board/samsung/goni/goni.c +++ b/board/samsung/goni/goni.c @@ -17,8 +17,6 @@
-static struct s5pc110_gpio *s5pc110_gpio; - u32 get_board_rev(void) { return 0; @@ -27,8 +25,6 @@ u32 get_board_rev(void) int board_init(void) { /* Set Initial global variables */ - s5pc110_gpio = (struct s5pc110_gpio *)S5PC110_GPIO_BASE; - gd->bd->bi_arch_number = MACH_TYPE_GONI; gd->bd->bi_boot_params = PHYS_SDRAM_1 + 0x100;
@@ -82,7 +78,7 @@ int board_mmc_init(bd_t *bis) int i, ret, ret_sd = 0;
/* MASSMEMORY_EN: XMSMDATA7: GPJ2[7] output high */ - s5p_gpio_direction_output(&s5pc110_gpio->j2, 7, 1); + gpio_direction_output(S5PC110_GPIO_J27, 1);
/* * MMC0 GPIO @@ -91,15 +87,15 @@ int board_mmc_init(bd_t *bis) * GPG0[2] SD_0_CDn -> Not used * GPG0[3:6] SD_0_DATA[0:3] */ - for (i = 0; i < 7; i++) { - if (i == 2) + for (i = S5PC110_GPIO_G00; i < S5PC110_GPIO_G07; i++) { + if (i == S5PC110_GPIO_G02) continue; /* GPG0[0:6] special function 2 */ - s5p_gpio_cfg_pin(&s5pc110_gpio->g0, i, 0x2); + gpio_cfg_pin(i, 0x2); /* GPG0[0:6] pull disable */ - s5p_gpio_set_pull(&s5pc110_gpio->g0, i, GPIO_PULL_NONE); + gpio_set_pull(i, S5P_GPIO_PULL_NONE); /* GPG0[0:6] drv 4x */ - s5p_gpio_set_drv(&s5pc110_gpio->g0, i, GPIO_DRV_4X); + gpio_set_drv(i, S5P_GPIO_DRV_4X); }
ret = s5p_mmc_init(0, 4); @@ -110,20 +106,20 @@ int board_mmc_init(bd_t *bis) * SD card (T_FLASH) detect and init * T_FLASH_DETECT: EINT28: GPH3[4] input mode */ - s5p_gpio_cfg_pin(&s5pc110_gpio->h3, 4, GPIO_INPUT); - s5p_gpio_set_pull(&s5pc110_gpio->h3, 4, GPIO_PULL_UP); + gpio_cfg_pin(S5PC110_GPIO_H34, S5P_GPIO_INPUT); + gpio_set_pull(S5PC110_GPIO_H34, S5P_GPIO_PULL_UP);
- if (!s5p_gpio_get_value(&s5pc110_gpio->h3, 4)) { - for (i = 0; i < 7; i++) { - if (i == 2) + if (!gpio_get_value(S5PC110_GPIO_H34)) { + for (i = S5PC110_GPIO_G20; i < S5PC110_GPIO_G27; i++) { + if (i == S5PC110_GPIO_G22) continue;
/* GPG2[0:6] special function 2 */ - s5p_gpio_cfg_pin(&s5pc110_gpio->g2, i, 0x2); + gpio_cfg_pin(i, 0x2); /* GPG2[0:6] pull disable */ - s5p_gpio_set_pull(&s5pc110_gpio->g2, i, GPIO_PULL_NONE); + gpio_set_pull(i, S5P_GPIO_PULL_NONE); /* GPG2[0:6] drv 4x */ - s5p_gpio_set_drv(&s5pc110_gpio->g2, i, GPIO_DRV_4X); + gpio_set_drv(i, S5P_GPIO_DRV_4X); }
ret_sd = s5p_mmc_init(2, 4); diff --git a/board/samsung/smdk5250/exynos5-dt.c b/board/samsung/smdk5250/exynos5-dt.c index 379a45c..58821c4 100644 --- a/board/samsung/smdk5250/exynos5-dt.c +++ b/board/samsung/smdk5250/exynos5-dt.c @@ -27,12 +27,9 @@ DECLARE_GLOBAL_DATA_PTR; #ifdef CONFIG_SOUND_MAX98095 static void board_enable_audio_codec(void) { - struct exynos5_gpio_part1 *gpio1 = (struct exynos5_gpio_part1 *) - samsung_get_base_gpio_part1(); - /* Enable MAX98095 Codec */ - s5p_gpio_direction_output(&gpio1->x1, 7, 1); - s5p_gpio_set_pull(&gpio1->x1, 7, GPIO_PULL_NONE); + gpio_direction_output(EXYNOS5_GPIO_X17, 1); + gpio_set_pull(EXYNOS5_GPIO_X17, S5P_GPIO_PULL_NONE); } #endif
@@ -47,19 +44,16 @@ int exynos_init(void) #ifdef CONFIG_LCD void exynos_cfg_lcd_gpio(void) { - struct exynos5_gpio_part1 *gpio1 = - (struct exynos5_gpio_part1 *)samsung_get_base_gpio_part1(); - /* For Backlight */ - s5p_gpio_cfg_pin(&gpio1->b2, 0, GPIO_OUTPUT); - s5p_gpio_set_value(&gpio1->b2, 0, 1); + gpio_cfg_pin(EXYNOS5_GPIO_B20, S5P_GPIO_OUTPUT); + gpio_set_value(EXYNOS5_GPIO_B20, 1);
/* LCD power on */ - s5p_gpio_cfg_pin(&gpio1->x1, 5, GPIO_OUTPUT); - s5p_gpio_set_value(&gpio1->x1, 5, 1); + gpio_cfg_pin(EXYNOS5_GPIO_X15, S5P_GPIO_OUTPUT); + gpio_set_value(EXYNOS5_GPIO_X15, 1);
/* Set Hotplug detect for DP */ - s5p_gpio_cfg_pin(&gpio1->x0, 7, GPIO_FUNC(0x3)); + gpio_cfg_pin(EXYNOS5_GPIO_X07, S5P_GPIO_FUNC(0x3)); }
void exynos_set_dp_phy(unsigned int onoff) diff --git a/board/samsung/smdk5250/smdk5250.c b/board/samsung/smdk5250/smdk5250.c index 28a6d9e..014b7bd 100644 --- a/board/samsung/smdk5250/smdk5250.c +++ b/board/samsung/smdk5250/smdk5250.c @@ -29,12 +29,9 @@ DECLARE_GLOBAL_DATA_PTR; #ifdef CONFIG_SOUND_MAX98095 static void board_enable_audio_codec(void) { - struct exynos5_gpio_part1 *gpio1 = (struct exynos5_gpio_part1 *) - samsung_get_base_gpio_part1(); - /* Enable MAX98095 Codec */ - s5p_gpio_direction_output(&gpio1->x1, 7, 1); - s5p_gpio_set_pull(&gpio1->x1, 7, GPIO_PULL_NONE); + gpio_direction_output(EXYNOS5_GPIO_X17, 1); + gpio_set_pull(EXYNOS5_GPIO_X17, S5P_GPIO_PULL_NONE); } #endif
@@ -275,19 +272,17 @@ int exynos_power_init(void) #ifdef CONFIG_LCD void exynos_cfg_lcd_gpio(void) { - struct exynos5_gpio_part1 *gpio1 = - (struct exynos5_gpio_part1 *) samsung_get_base_gpio_part1();
void exynos_set_dp_phy(unsigned int onoff) diff --git a/board/samsung/smdk5420/smdk5420.c b/board/samsung/smdk5420/smdk5420.c index e4606ec..fa3aa2c 100644 --- a/board/samsung/smdk5420/smdk5420.c +++ b/board/samsung/smdk5420/smdk5420.c @@ -21,11 +21,8 @@ DECLARE_GLOBAL_DATA_PTR; #ifdef CONFIG_USB_EHCI_EXYNOS static int board_usb_vbus_init(void) { - struct exynos5_gpio_part1 *gpio1 = (struct exynos5_gpio_part1 *) - samsung_get_base_gpio_part1(); - /* Enable VBUS power switch */ - s5p_gpio_direction_output(&gpio1->x2, 6, 1); + gpio_direction_output(EXYNOS5420_GPIO_X26, 1);
/* VBUS turn ON time */ mdelay(3); @@ -49,15 +46,15 @@ void cfg_lcd_gpio(void) (struct exynos5_gpio_part1 *)samsung_get_base_gpio_part1();
/* For Backlight */ - s5p_gpio_cfg_pin(&gpio1->b2, 0, GPIO_OUTPUT); - s5p_gpio_set_value(&gpio1->b2, 0, 1); + gpio_cfg_pin(EXYNOS5420_GPIO_B10, S5P_GPIO_OUTPUT); + gpio_set_value(EXYNOS5420_GPIO_B20, 1);
/* LCD power on */ - s5p_gpio_cfg_pin(&gpio1->x1, 5, GPIO_OUTPUT); - s5p_gpio_set_value(&gpio1->x1, 5, 1); + gpio_cfg_pin(EXYNOS5420_GPIO_X15, S5P_GPIO_OUTPUT); + gpio_set_value(EXYNOS5420_GPIO_X15, 1);
/* Set Hotplug detect for DP */ - s5p_gpio_cfg_pin(&gpio1->x0, 7, GPIO_FUNC(0x3)); + gpio_cfg_pin(EXYNOS5420_GPIO_X07, S5P_GPIO_FUNC(0x3)); }
vidinfo_t panel_info = { diff --git a/board/samsung/smdkc100/smdkc100.c b/board/samsung/smdkc100/smdkc100.c index 860c851..e009564 100644 --- a/board/samsung/smdkc100/smdkc100.c +++ b/board/samsung/smdkc100/smdkc100.c @@ -21,11 +21,8 @@ static void smc9115_pre_init(void) { u32 smc_bw_conf, smc_bc_conf;
- struct s5pc100_gpio *const gpio = - (struct s5pc100_gpio *)samsung_get_base_gpio(); - /* gpio configuration GPK0CON */ - s5p_gpio_cfg_pin(&gpio->k0, CONFIG_ENV_SROM_BANK, GPIO_FUNC(2)); + gpio_cfg_pin(S5PC100_GPIO_K00 + CONFIG_ENV_SROM_BANK, S5P_GPIO_FUNC(2));
/* Ethernet needs bus width of 16 bits */ smc_bw_conf = SMC_DATA16_WIDTH(CONFIG_ENV_SROM_BANK); diff --git a/board/samsung/smdkv310/smdkv310.c b/board/samsung/smdkv310/smdkv310.c index 81a3060..8eca358 100644 --- a/board/samsung/smdkv310/smdkv310.c +++ b/board/samsung/smdkv310/smdkv310.c @@ -15,15 +15,13 @@ #include <asm/arch/sromc.h>
DECLARE_GLOBAL_DATA_PTR; -struct exynos4_gpio_part1 *gpio1; -struct exynos4_gpio_part2 *gpio2;
/* gpio configuration GPK0CON */ - s5p_gpio_cfg_pin(&gpio2->y0, CONFIG_ENV_SROM_BANK, GPIO_FUNC(2)); + gpio_cfg_pin(EXYNOS4_GPIO_Y00 + CONFIG_ENV_SROM_BANK, S5P_GPIO_FUNC(2));
/* Ethernet needs bus width of 16 bits */ smc_bw_conf = SROMC_DATA16_WIDTH(CONFIG_ENV_SROM_BANK); @@ -38,9 +36,6 @@ static void smc9115_pre_init(void)
int board_init(void) { - gpio1 = (struct exynos4_gpio_part1 *) EXYNOS4_GPIO_PART1_BASE; - gpio2 = (struct exynos4_gpio_part2 *) EXYNOS4_GPIO_PART2_BASE; - smc9115_pre_init();
gd->bd->bi_boot_params = (PHYS_SDRAM_1 + 0x100UL); @@ -103,21 +98,21 @@ int board_mmc_init(bd_t *bis) * GPK2[2] SD_2_CDn * GPK2[3:6] SD_2_DATA[0:3](2) */ - for (i = 0; i < 7; i++) { + for (i = EXYNOS4_GPIO_K20; i < EXYNOS4_GPIO_K27; i++) { /* GPK2[0:6] special function 2 */ - s5p_gpio_cfg_pin(&gpio2->k2, i, GPIO_FUNC(0x2)); + gpio_cfg_pin(i, S5P_GPIO_FUNC(0x2));
/* GPK2[0:6] drv 4x */ - s5p_gpio_set_drv(&gpio2->k2, i, GPIO_DRV_4X); + gpio_set_drv(i, S5P_GPIO_DRV_4X);
/* GPK2[0:1] pull disable */ - if (i == 0 || i == 1) { - s5p_gpio_set_pull(&gpio2->k2, i, GPIO_PULL_NONE); + if (i == EXYNOS4_GPIO_K20 || i == EXYNOS4_GPIO_K21) { + gpio_set_pull(i, S5P_GPIO_PULL_NONE); continue; }
/* GPK2[2:6] pull up */ - s5p_gpio_set_pull(&gpio2->k2, i, GPIO_PULL_UP); + gpio_set_pull(i, S5P_GPIO_PULL_UP); } err = s5p_mmc_init(2, 4); return err; diff --git a/board/samsung/trats/trats.c b/board/samsung/trats/trats.c index 7c79e7b..f8b2908 100644 --- a/board/samsung/trats/trats.c +++ b/board/samsung/trats/trats.c @@ -54,8 +54,6 @@ int exynos_init(void) void i2c_init_board(void) { int err; - struct exynos4_gpio_part2 *gpio2 = - (struct exynos4_gpio_part2 *)samsung_get_base_gpio_part2();
/* I2C_5 -> PMIC */ err = exynos_pinmux_config(PERIPH_ID_I2C5, PINMUX_FLAG_NONE); @@ -65,8 +63,8 @@ void i2c_init_board(void) }
/* I2C_8 -> FG */ - s5p_gpio_direction_output(&gpio2->y4, 0, 1); - s5p_gpio_direction_output(&gpio2->y4, 1, 1); + gpio_direction_output(EXYNOS4_GPIO_Y40, 1); + gpio_direction_output(EXYNOS4_GPIO_Y41, 1); }
static void trats_low_power_mode(void) @@ -347,21 +345,19 @@ int exynos_power_init(void)
static unsigned int get_hw_revision(void) { - struct exynos4_gpio_part1 *gpio = - (struct exynos4_gpio_part1 *)samsung_get_base_gpio_part1(); int hwrev = 0; int i;
/* hw_rev[3:0] == GPE1[3:0] */ - for (i = 0; i < 4; i++) { - s5p_gpio_cfg_pin(&gpio->e1, i, GPIO_INPUT); - s5p_gpio_set_pull(&gpio->e1, i, GPIO_PULL_NONE); + for (i = EXYNOS4_GPIO_E10; i < EXYNOS4_GPIO_E14; i++) { + gpio_cfg_pin(i, S5P_GPIO_INPUT); + gpio_set_pull(i, S5P_GPIO_PULL_NONE); }
udelay(1);
for (i = 0; i < 4; i++) - hwrev |= (s5p_gpio_get_value(&gpio->e1, i) << i); + hwrev |= (gpio_get_value(EXYNOS4_GPIO_E10 + i) << i);
debug("hwrev 0x%x\n", hwrev);
@@ -444,11 +440,8 @@ int usb_cable_connected(void)
static void pmic_reset(void) { - struct exynos4_gpio_part2 *gpio = - (struct exynos4_gpio_part2 *)samsung_get_base_gpio_part2(); - - s5p_gpio_direction_output(&gpio->x0, 7, 1); - s5p_gpio_set_pull(&gpio->x2, 7, GPIO_PULL_NONE); + gpio_direction_output(EXYNOS4_GPIO_X07, 1); + gpio_set_pull(EXYNOS4_GPIO_X27, S5P_GPIO_PULL_NONE); }
static void board_clock_init(void) @@ -525,12 +518,9 @@ static void board_power_init(void)
static void exynos_uart_init(void) { - struct exynos4_gpio_part2 *gpio2 = - (struct exynos4_gpio_part2 *)samsung_get_base_gpio_part2(); - /* UART_SEL GPY4[7] (part2) at EXYNOS4 */ - s5p_gpio_set_pull(&gpio2->y4, 7, GPIO_PULL_UP); - s5p_gpio_direction_output(&gpio2->y4, 7, 1); + gpio_set_pull(EXYNOS4_GPIO_Y47, S5P_GPIO_PULL_UP); + gpio_direction_output(EXYNOS4_GPIO_Y47, 1); }
int exynos_early_init_f(void) @@ -546,14 +536,11 @@ int exynos_early_init_f(void)
void exynos_reset_lcd(void) { - struct exynos4_gpio_part2 *gpio2 = - (struct exynos4_gpio_part2 *)samsung_get_base_gpio_part2(); - - s5p_gpio_direction_output(&gpio2->y4, 5, 1); + gpio_direction_output(EXYNOS4_GPIO_Y45, 1); udelay(10000); - s5p_gpio_direction_output(&gpio2->y4, 5, 0); + gpio_direction_output(EXYNOS4_GPIO_Y45, 0); udelay(10000); - s5p_gpio_direction_output(&gpio2->y4, 5, 1); + gpio_direction_output(EXYNOS4_GPIO_Y45, 1); }
int lcd_power(void) diff --git a/board/samsung/trats2/trats2.c b/board/samsung/trats2/trats2.c index f558ef9..d4d5926 100644 --- a/board/samsung/trats2/trats2.c +++ b/board/samsung/trats2/trats2.c @@ -25,9 +25,6 @@
-static struct exynos4x12_gpio_part1 *gpio1; -static struct exynos4x12_gpio_part2 *gpio2; - static unsigned int board_rev = -1;
static inline u32 get_model_rev(void); @@ -37,26 +34,24 @@ static void check_hw_revision(void) int modelrev = 0; int i;
- gpio2 = (struct exynos4x12_gpio_part2 *)samsung_get_base_gpio_part2(); - /* * GPM1[1:0]: MODEL_REV[1:0] * Don't set as pull-none for these N/C pin. * TRM say that it may cause unexcepted state and leakage current. * and pull-none is only for output function. */ - for (i = 0; i < 2; i++) - s5p_gpio_cfg_pin(&gpio2->m1, i, GPIO_INPUT); + for (i = EXYNOS4X12_GPIO_M10; i < EXYNOS4X12_GPIO_M12; i++) + gpio_cfg_pin(i, S5P_GPIO_INPUT);
/* GPM1[5:2]: HW_REV[3:0] */ - for (i = 2; i < 6; i++) { - s5p_gpio_cfg_pin(&gpio2->m1, i, GPIO_INPUT); - s5p_gpio_set_pull(&gpio2->m1, i, GPIO_PULL_NONE); + for (i = EXYNOS4X12_GPIO_M12; i < EXYNOS4X12_GPIO_M16; i++) { + gpio_cfg_pin(i, S5P_GPIO_INPUT); + gpio_set_pull(i, S5P_GPIO_PULL_NONE); }
/* GPM1[1:0]: MODEL_REV[1:0] */ for (i = 0; i < 2; i++) - modelrev |= (s5p_gpio_get_value(&gpio2->m1, i) << i); + modelrev |= (gpio_get_value(EXYNOS4X12_GPIO_M10 + i) << i);
/* board_rev[15:8] = model */ board_rev = modelrev << 8; @@ -74,26 +69,24 @@ static inline u32 get_model_rev(void)
static void board_external_gpio_init(void) { - gpio2 = (struct exynos4x12_gpio_part2 *)samsung_get_base_gpio_part2(); - /* * some pins which in alive block are connected with external pull-up * but it's default setting is pull-down. * if that pin set as input then that floated */
- s5p_gpio_set_pull(&gpio2->x0, 2, GPIO_PULL_NONE); /* PS_ALS_INT */ - s5p_gpio_set_pull(&gpio2->x0, 4, GPIO_PULL_NONE); /* TSP_nINT */ - s5p_gpio_set_pull(&gpio2->x0, 7, GPIO_PULL_NONE); /* AP_PMIC_IRQ*/ - s5p_gpio_set_pull(&gpio2->x1, 5, GPIO_PULL_NONE); /* IF_PMIC_IRQ*/ - s5p_gpio_set_pull(&gpio2->x2, 0, GPIO_PULL_NONE); /* VOL_UP */ - s5p_gpio_set_pull(&gpio2->x2, 1, GPIO_PULL_NONE); /* VOL_DOWN */ - s5p_gpio_set_pull(&gpio2->x2, 3, GPIO_PULL_NONE); /* FUEL_ALERT */ - s5p_gpio_set_pull(&gpio2->x2, 4, GPIO_PULL_NONE); /* ADC_INT */ - s5p_gpio_set_pull(&gpio2->x2, 7, GPIO_PULL_NONE); /* nPOWER */ - s5p_gpio_set_pull(&gpio2->x3, 0, GPIO_PULL_NONE); /* WPC_INT */ - s5p_gpio_set_pull(&gpio2->x3, 5, GPIO_PULL_NONE); /* OK_KEY */ - s5p_gpio_set_pull(&gpio2->x3, 7, GPIO_PULL_NONE); /* HDMI_HPD */ + gpio_set_pull(EXYNOS4X12_GPIO_X02, S5P_GPIO_PULL_NONE); /* PS_ALS_INT */ + gpio_set_pull(EXYNOS4X12_GPIO_X04, S5P_GPIO_PULL_NONE); /* TSP_nINT */ + gpio_set_pull(EXYNOS4X12_GPIO_X07, S5P_GPIO_PULL_NONE); /* AP_PMIC_IRQ*/ + gpio_set_pull(EXYNOS4X12_GPIO_X15, S5P_GPIO_PULL_NONE); /* IF_PMIC_IRQ*/ + gpio_set_pull(EXYNOS4X12_GPIO_X20, S5P_GPIO_PULL_NONE); /* VOL_UP */ + gpio_set_pull(EXYNOS4X12_GPIO_X21, S5P_GPIO_PULL_NONE); /* VOL_DOWN */ + gpio_set_pull(EXYNOS4X12_GPIO_X23, S5P_GPIO_PULL_NONE); /* FUEL_ALERT */ + gpio_set_pull(EXYNOS4X12_GPIO_X24, S5P_GPIO_PULL_NONE); /* ADC_INT */ + gpio_set_pull(EXYNOS4X12_GPIO_X27, S5P_GPIO_PULL_NONE); /* nPOWER */ + gpio_set_pull(EXYNOS4X12_GPIO_X30, S5P_GPIO_PULL_NONE); /* WPC_INT */ + gpio_set_pull(EXYNOS4X12_GPIO_X35, S5P_GPIO_PULL_NONE); /* OK_KEY */ + gpio_set_pull(EXYNOS4X12_GPIO_X37, S5P_GPIO_PULL_NONE); /* HDMI_HPD */ }
#ifdef CONFIG_SYS_I2C_INIT_BOARD @@ -101,9 +94,6 @@ static void board_init_i2c(void) { int err;
- gpio1 = (struct exynos4x12_gpio_part1 *)samsung_get_base_gpio_part1(); - gpio2 = (struct exynos4x12_gpio_part2 *)samsung_get_base_gpio_part2(); - /* I2C_7 */ err = exynos_pinmux_config(PERIPH_ID_I2C7, PINMUX_FLAG_NONE); if (err) { @@ -112,12 +102,12 @@ static void board_init_i2c(void) }
/* I2C_8 */ - s5p_gpio_direction_output(&gpio1->f1, 4, 1); - s5p_gpio_direction_output(&gpio1->f1, 5, 1); + gpio_direction_output(EXYNOS4X12_GPIO_F14, 1); + gpio_direction_output(EXYNOS4X12_GPIO_F15, 1);
/* I2C_9 */ - s5p_gpio_direction_output(&gpio2->m2, 1, 1); - s5p_gpio_direction_output(&gpio2->m2, 0, 1); + gpio_direction_output(EXYNOS4X12_GPIO_M21, 1); + gpio_direction_output(EXYNOS4X12_GPIO_M20, 1); } #endif
@@ -125,17 +115,17 @@ static void board_init_i2c(void) int get_soft_i2c_scl_pin(void) { if (I2C_ADAP_HWNR) - return exynos4x12_gpio_get(2, m2, 1); /* I2C9 */ + return EXYNOS4X12_GPIO_M21; /* I2C9 */ else - return exynos4x12_gpio_get(1, f1, 4); /* I2C8 */ + return EXYNOS4X12_GPIO_F14; /* I2C8 */ }
int get_soft_i2c_sda_pin(void) { if (I2C_ADAP_HWNR) - return exynos4x12_gpio_get(2, m2, 0); /* I2C9 */ + return EXYNOS4X12_GPIO_M20; /* I2C9 */ else - return exynos4x12_gpio_get(1, f1, 5); /* I2C8 */ + return EXYNOS4X12_GPIO_F15; /* I2C8 */ } #endif
@@ -398,11 +388,9 @@ void exynos_lcd_power_on(void) { struct pmic *p = pmic_get("MAX77686_PMIC");
- gpio1 = (struct exynos4x12_gpio_part1 *)samsung_get_base_gpio_part1(); - /* LCD_2.2V_EN: GPC0[1] */ - s5p_gpio_set_pull(&gpio1->c0, 1, GPIO_PULL_UP); - s5p_gpio_direction_output(&gpio1->c0, 1, 1); + gpio_set_pull(EXYNOS4X12_GPIO_C01, S5P_GPIO_PULL_UP); + gpio_direction_output(EXYNOS4X12_GPIO_C01, 1);
/* LDO25 VCC_3.1V_LCD */ pmic_probe(p); @@ -412,12 +400,10 @@ void exynos_lcd_power_on(void)
void exynos_reset_lcd(void) { - gpio1 = (struct exynos4x12_gpio_part1 *)samsung_get_base_gpio_part1(); - /* reset lcd */ - s5p_gpio_direction_output(&gpio1->f2, 1, 0); + gpio_direction_output(EXYNOS4X12_GPIO_F21, 0); udelay(10); - s5p_gpio_set_value(&gpio1->f2, 1, 1); + gpio_set_value(EXYNOS4X12_GPIO_F21, 1); }
void exynos_lcd_misc_init(vidinfo_t *vid) diff --git a/board/samsung/universal_c210/universal.c b/board/samsung/universal_c210/universal.c index f9d71b6..25f2a93 100644 --- a/board/samsung/universal_c210/universal.c +++ b/board/samsung/universal_c210/universal.c @@ -27,8 +27,6 @@
-struct exynos4_gpio_part1 *gpio1; -struct exynos4_gpio_part2 *gpio2; unsigned int board_rev;
u32 get_board_rev(void) @@ -312,35 +310,35 @@ void exynos_cfg_lcd_gpio(void)
for (i = 0; i < 8; i++) { /* set GPF0,1,2[0:7] for RGB Interface and Data lines (32bit) */ - s5p_gpio_cfg_pin(&gpio1->f0, i, GPIO_FUNC(2)); - s5p_gpio_cfg_pin(&gpio1->f1, i, GPIO_FUNC(2)); - s5p_gpio_cfg_pin(&gpio1->f2, i, GPIO_FUNC(2)); + gpio_cfg_pin(EXYNOS4_GPIO_F00 + i, S5P_GPIO_FUNC(2)); + gpio_cfg_pin(EXYNOS4_GPIO_F10 + i, S5P_GPIO_FUNC(2)); + gpio_cfg_pin(EXYNOS4_GPIO_F20 + i, S5P_GPIO_FUNC(2)); /* pull-up/down disable */ - s5p_gpio_set_pull(&gpio1->f0, i, GPIO_PULL_NONE); - s5p_gpio_set_pull(&gpio1->f1, i, GPIO_PULL_NONE); - s5p_gpio_set_pull(&gpio1->f2, i, GPIO_PULL_NONE); + gpio_set_pull(EXYNOS4_GPIO_F00 + i, S5P_GPIO_PULL_NONE); + gpio_set_pull(EXYNOS4_GPIO_F10 + i, S5P_GPIO_PULL_NONE); + gpio_set_pull(EXYNOS4_GPIO_F20 + i, S5P_GPIO_PULL_NONE);
/* drive strength to max (24bit) */ - s5p_gpio_set_drv(&gpio1->f0, i, GPIO_DRV_4X); - s5p_gpio_set_rate(&gpio1->f0, i, GPIO_DRV_SLOW); - s5p_gpio_set_drv(&gpio1->f1, i, GPIO_DRV_4X); - s5p_gpio_set_rate(&gpio1->f1, i, GPIO_DRV_SLOW); - s5p_gpio_set_drv(&gpio1->f2, i, GPIO_DRV_4X); - s5p_gpio_set_rate(&gpio1->f0, i, GPIO_DRV_SLOW); + gpio_set_drv(EXYNOS4_GPIO_F00 + i, S5P_GPIO_DRV_4X); + gpio_set_rate(EXYNOS4_GPIO_F00 + i, S5P_GPIO_DRV_SLOW); + gpio_set_drv(EXYNOS4_GPIO_F10 + i, S5P_GPIO_DRV_4X); + gpio_set_rate(EXYNOS4_GPIO_F10 + i, S5P_GPIO_DRV_SLOW); + gpio_set_drv(EXYNOS4_GPIO_F20 + i, S5P_GPIO_DRV_4X); + gpio_set_rate(EXYNOS4_GPIO_F00 + i, S5P_GPIO_DRV_SLOW); }
- for (i = 0; i < f3_end; i++) { + for (i = EXYNOS4_GPIO_F30; i < (EXYNOS4_GPIO_F30 + f3_end); i++) { /* set GPF3[0:3] for RGB Interface and Data lines (32bit) */ - s5p_gpio_cfg_pin(&gpio1->f3, i, GPIO_FUNC(2)); + gpio_cfg_pin(i, S5P_GPIO_FUNC(2)); /* pull-up/down disable */ - s5p_gpio_set_pull(&gpio1->f3, i, GPIO_PULL_NONE); + gpio_set_pull(i, S5P_GPIO_PULL_NONE); /* drive strength to max (24bit) */ - s5p_gpio_set_drv(&gpio1->f3, i, GPIO_DRV_4X); - s5p_gpio_set_rate(&gpio1->f3, i, GPIO_DRV_SLOW); + gpio_set_drv(i, S5P_GPIO_DRV_4X); + gpio_set_rate(i, S5P_GPIO_DRV_SLOW); }
/* gpio pad configuration for LCD reset. */ - s5p_gpio_cfg_pin(&gpio2->y4, 5, GPIO_OUTPUT); + gpio_cfg_pin(EXYNOS4_GPIO_Y45, S5P_GPIO_OUTPUT);
spi_init(); } @@ -352,11 +350,11 @@ int mipi_power(void)
void exynos_reset_lcd(void) { - s5p_gpio_set_value(&gpio2->y4, 5, 1); + gpio_set_value(EXYNOS4_GPIO_Y45, 1); udelay(10000); - s5p_gpio_set_value(&gpio2->y4, 5, 0); + gpio_set_value(EXYNOS4_GPIO_Y45, 0); udelay(10000); - s5p_gpio_set_value(&gpio2->y4, 5, 1); + gpio_set_value(EXYNOS4_GPIO_Y45, 1); udelay(100); }
@@ -386,9 +384,6 @@ void exynos_enable_ldo(unsigned int onoff)
int exynos_init(void) { - gpio1 = (struct exynos4_gpio_part1 *) EXYNOS4_GPIO_PART1_BASE; - gpio2 = (struct exynos4_gpio_part2 *) EXYNOS4_GPIO_PART2_BASE; - gd->bd->bi_arch_number = MACH_TYPE_UNIVERSAL_C210;
switch (get_hwrev()) { @@ -399,7 +394,7 @@ int exynos_init(void) * you should set it HIGH since it removes the inverter */ /* MASSMEMORY_EN: XMDMDATA_6: GPE3[6] */ - s5p_gpio_direction_output(&gpio1->e3, 6, 0); + gpio_direction_output(EXYNOS4_GPIO_E36, 0); break; default: /* @@ -407,7 +402,7 @@ int exynos_init(void) * But set it as HIGH to ensure */ /* MASSMEMORY_EN: XMDMADDR_3: GPE1[3] */ - s5p_gpio_direction_output(&gpio1->e1, 3, 1); + gpio_direction_output(EXYNOS4_GPIO_E13, 1); break; }
diff --git a/drivers/gpio/s5p_gpio.c b/drivers/gpio/s5p_gpio.c index 11a0472..db7b673 100644 --- a/drivers/gpio/s5p_gpio.c +++ b/drivers/gpio/s5p_gpio.c @@ -8,11 +8,9 @@ #include <common.h> #include <asm/io.h> #include <asm/gpio.h> +#include <asm/arch/gpio.h>
-#define S5P_GPIO_GET_BANK(x) ((x >> S5P_GPIO_BANK_SHIFT) \ - & S5P_GPIO_BANK_MASK) - -#define S5P_GPIO_GET_PIN(x) (x & S5P_GPIO_PIN_MASK) +#define S5P_GPIO_GET_PIN(x) (x % GPIO_PER_BANK)
#define CON_MASK(x) (0xf << ((x) << 2)) #define CON_SFR(x, v) ((v) << ((x) << 2)) @@ -28,7 +26,103 @@ #define RATE_MASK(x) (0x1 << (x + 16)) #define RATE_SET(x) (0x1 << (x + 16))
-void s5p_gpio_cfg_pin(struct s5p_gpio_bank *bank, int gpio, int cfg) +#define name_to_gpio(n) s5p_name_to_gpio(n) +static inline int s5p_name_to_gpio(const char *name) +{ + unsigned num, irregular_set_number, irregular_bank_base; + const struct gpio_name_num_table *tabp; + char this_bank, bank_name, irregular_bank_name; + char *endp; + + /* + * The gpio name starts with either 'g' or 'gp' followed by the bank + * name character. Skip one or two characters depending on the prefix. + */ + if (name[0] == 'g' && name[1] == 'p') + name += 2; + else if (name[0] == 'g') + name++; + else + return -1; /* Name must start with 'g' */ + + bank_name = *name++; + if (!*name) + return -1; /* At least one digit is required/expected. */ + + /* + * On both exynos5 and exynos5420 architectures there is a bank of + * GPIOs which does not fall into the regular address pattern. Those + * banks are c4 on Exynos5 and y7 on Exynos5420. The rest of the below + * assignments help to handle these irregularities. + */ +#if defined(CONFIG_EXYNOS4) || defined(CONFIG_EXYNOS5) + if (cpu_is_exynos5()) { + if (proid_is_exynos5420()) { + tabp = exynos5420_gpio_table; + irregular_bank_name = 'y'; + irregular_set_number = '7'; + irregular_bank_base = EXYNOS5420_GPIO_Y70; + } else { + tabp = exynos5_gpio_table; + irregular_bank_name = 'c'; + irregular_set_number = '4'; + irregular_bank_base = EXYNOS5_GPIO_C40; + } + } else { + if (proid_is_exynos4412()) + tabp = exynos4x12_gpio_table; + else + tabp = exynos4_gpio_table; + irregular_bank_name = 0; + irregular_set_number = 0; + irregular_bank_base = 0; + } +#else + if (cpu_is_s5pc110()) + tabp = s5pc110_gpio_table; + else + tabp = s5pc100_gpio_table; + irregular_bank_name = 0; + irregular_set_number = 0; + irregular_bank_base = 0; +#endif + + this_bank = tabp->bank; + do { + if (bank_name == this_bank) { + unsigned pin_index; /* pin number within the bank */ + if ((bank_name == irregular_bank_name) && + (name[0] == irregular_set_number)) { + pin_index = name[1] - '0'; + /* Irregular sets have 8 pins. */ + if (pin_index >= GPIO_PER_BANK) + return -1; + num = irregular_bank_base + pin_index; + } else { + pin_index = simple_strtoul(name, &endp, 8); + pin_index -= tabp->bank_offset; + /* + * Sanity check: bunk 'z' has no set number, + * for all other banks there must be exactly + * two octal digits, and the resulting number + * should not exceed the number of pins in the + * bank. + */ + if (((bank_name != 'z') && !name[1]) || + *endp || + (pin_index >= tabp->bank_size)) + return -1; + num = tabp->base + pin_index; + } + return num; + } + this_bank = (++tabp)->bank; + } while (this_bank); + + return -1; +} + +static void s5p_gpio_cfg_pin(struct s5p_gpio_bank *bank, int gpio, int cfg) { unsigned int value;
@@ -38,18 +132,7 @@ void s5p_gpio_cfg_pin(struct s5p_gpio_bank *bank, int gpio, int cfg) writel(value, &bank->con); }
-void s5p_gpio_direction_output(struct s5p_gpio_bank *bank, int gpio, int en) -{ - s5p_gpio_cfg_pin(bank, gpio, GPIO_OUTPUT); - s5p_gpio_set_value(bank, gpio, en); -} - -void s5p_gpio_direction_input(struct s5p_gpio_bank *bank, int gpio) -{ - s5p_gpio_cfg_pin(bank, gpio, GPIO_INPUT); -} - -void s5p_gpio_set_value(struct s5p_gpio_bank *bank, int gpio, int en) +static void s5p_gpio_set_value(struct s5p_gpio_bank *bank, int gpio, int en) { unsigned int value;
@@ -60,7 +143,19 @@ void s5p_gpio_set_value(struct s5p_gpio_bank *bank, int gpio, int en) writel(value, &bank->dat); }
-unsigned int s5p_gpio_get_value(struct s5p_gpio_bank *bank, int gpio) +static void s5p_gpio_direction_output(struct s5p_gpio_bank *bank, + int gpio, int en) +{ + s5p_gpio_cfg_pin(bank, gpio, S5P_GPIO_OUTPUT); + s5p_gpio_set_value(bank, gpio, en); +} + +static void s5p_gpio_direction_input(struct s5p_gpio_bank *bank, int gpio) +{ + s5p_gpio_cfg_pin(bank, gpio, S5P_GPIO_INPUT); +} + +static unsigned int s5p_gpio_get_value(struct s5p_gpio_bank *bank, int gpio) { unsigned int value;
@@ -68,7 +163,7 @@ unsigned int s5p_gpio_get_value(struct s5p_gpio_bank *bank, int gpio) return !!(value & DAT_MASK(gpio)); }
-void s5p_gpio_set_pull(struct s5p_gpio_bank *bank, int gpio, int mode) +static void s5p_gpio_set_pull(struct s5p_gpio_bank *bank, int gpio, int mode) { unsigned int value;
@@ -76,8 +171,8 @@ void s5p_gpio_set_pull(struct s5p_gpio_bank *bank, int gpio, int mode) value &= ~PULL_MASK(gpio);
switch (mode) { - case GPIO_PULL_DOWN: - case GPIO_PULL_UP: + case S5P_GPIO_PULL_DOWN: + case S5P_GPIO_PULL_UP: value |= PULL_MODE(gpio, mode); break; default: @@ -87,7 +182,7 @@ void s5p_gpio_set_pull(struct s5p_gpio_bank *bank, int gpio, int mode) writel(value, &bank->pull); }
-void s5p_gpio_set_drv(struct s5p_gpio_bank *bank, int gpio, int mode) +static void s5p_gpio_set_drv(struct s5p_gpio_bank *bank, int gpio, int mode) { unsigned int value;
@@ -95,10 +190,10 @@ void s5p_gpio_set_drv(struct s5p_gpio_bank *bank, int gpio, int mode) value &= ~DRV_MASK(gpio);
switch (mode) { - case GPIO_DRV_1X: - case GPIO_DRV_2X: - case GPIO_DRV_3X: - case GPIO_DRV_4X: + case S5P_GPIO_DRV_1X: + case S5P_GPIO_DRV_2X: + case S5P_GPIO_DRV_3X: + case S5P_GPIO_DRV_4X: value |= DRV_SET(gpio, mode); break; default: @@ -108,7 +203,7 @@ void s5p_gpio_set_drv(struct s5p_gpio_bank *bank, int gpio, int mode) writel(value, &bank->drv); }
-void s5p_gpio_set_rate(struct s5p_gpio_bank *bank, int gpio, int mode) +static void s5p_gpio_set_rate(struct s5p_gpio_bank *bank, int gpio, int mode) { unsigned int value;
@@ -116,8 +211,8 @@ void s5p_gpio_set_rate(struct s5p_gpio_bank *bank, int gpio, int mode) value &= ~RATE_MASK(gpio);
switch (mode) { - case GPIO_DRV_FAST: - case GPIO_DRV_SLOW: + case S5P_GPIO_DRV_FAST: + case S5P_GPIO_DRV_SLOW: value |= RATE_SET(gpio); break; default: @@ -127,12 +222,31 @@ void s5p_gpio_set_rate(struct s5p_gpio_bank *bank, int gpio, int mode) writel(value, &bank->drv); }
-struct s5p_gpio_bank *s5p_gpio_get_bank(unsigned gpio) +struct s5p_gpio_bank *s5p_gpio_get_bank(unsigned int gpio) { - unsigned bank = S5P_GPIO_GET_BANK(gpio); - unsigned base = s5p_gpio_base(gpio); + const struct gpio_info *data; + unsigned int upto; + int i, count; + + data = get_gpio_data(); + count = get_bank_num(); + upto = 0; + + for (i = 0; i < count; i++) { + debug("i=%d, upto=%d\n", i, upto); + if (gpio < data->max_gpio) { + struct s5p_gpio_bank *bank; + bank = (struct s5p_gpio_bank *)data->reg_addr; + bank += (gpio - upto) / GPIO_PER_BANK; + debug("gpio=%d, bank=%p\n", gpio, bank); + return bank; + } + + upto = data->max_gpio; + data++; + }
- return (struct s5p_gpio_bank *)(base + bank); + return NULL; }
int s5p_gpio_get_pin(unsigned gpio) @@ -179,3 +293,27 @@ int gpio_set_value(unsigned gpio, int value)
return 0; } + +void gpio_set_pull(int gpio, int mode) +{ + s5p_gpio_set_pull(s5p_gpio_get_bank(gpio), + s5p_gpio_get_pin(gpio), mode); +} + +void gpio_set_drv(int gpio, int mode) +{ + s5p_gpio_set_drv(s5p_gpio_get_bank(gpio), + s5p_gpio_get_pin(gpio), mode); +} + +void gpio_cfg_pin(int gpio, int cfg) +{ + s5p_gpio_cfg_pin(s5p_gpio_get_bank(gpio), + s5p_gpio_get_pin(gpio), cfg); +} + +void gpio_set_rate(int gpio, int mode) +{ + s5p_gpio_set_rate(s5p_gpio_get_bank(gpio), + s5p_gpio_get_pin(gpio), mode); +}
Dear Akshay Saraswat,
On 06/05/14 23:36, Akshay Saraswat wrote:
This patch includes following changes :
Adds gpio pin numbering support for EXYNOS SOCs. To have consistent 0..n-1 GPIO numbering the banks are divided into different parts where ever they have holes in them.
Rename GPIO definitions from GPIO_... to S5P_GPIO_... These changes were done to enable cmd_gpio for EXYNOS and cmd_gpio has GPIO_INPUT same as s5p_gpio driver and hence getting a error during compilation.
Adds support for name to gpio conversion in s5p_gpio to enable gpio command EXYNOS SoCs. Function has been added to asm/gpio.h to decode the input gpio name to gpio number. Example: SMDK5420 # gpio set gpa00
Signed-off-by: Leela Krishna Amudala l.krishna@samsung.com Signed-off-by: Rajeshwari Shinde rajeshwari.s@samsung.com Signed-off-by: Akshay Saraswat akshay.s@samsung.com Acked-by: Przemyslaw Marczak p.marczak@samsung.com
Changes in V12:
- Added change log in this patch.
- Fixed few bugs and typos.
- Added "Acked-by: Przemyslaw Marczak".
Changes in v11:
- Created and fixed pinmux_config for Exynos 4412.
- Removed dead code.
Changes in v10:
- Made arch-exynos/gpio.h -> arch/gpio.h.
- Edited pin numbmers in dts files.
Changes in V9:
- Fixed checkpatch errors.
- Fixed naming error in exynosxxxx_gpio_data arrays which could be the possible reason behind data abort witnessed over Exynos4 boards.
Changes in V8:
- Fixed arndale board compile time errors introduced due to patch-set v7.
Changes in V7:
- Added changes for other SoCs like Exynos 4412, 4210 etc.
Changes in V6:
- Updated patch with corresponding changes for Exynos 5420.
Changes in V5:
- Rebased on latest u-boot-samsung tree.
- Removed Exynos5 specific code in gpio driver api to get bank.
Changes in V4:
- To have consistent 0..n-1 GPIO numbering the banks are divided into different parts where ever they have holes in them.
- Function and table to support gpio command moved to s5p-gpio driver.
Changes in V3:
- GPIO Table added to calculate the base address of input gpio bank.
arch/arm/cpu/armv7/exynos/pinmux.c | 561 +++++---- arch/arm/dts/exynos4210-origen.dts | 4 +- arch/arm/dts/exynos4210-trats.dts | 6 +- arch/arm/dts/exynos4210-universal_c210.dts | 4 +- arch/arm/dts/exynos4412-trats2.dts | 4 +- arch/arm/include/asm/arch-exynos/cpu.h | 17 +- arch/arm/include/asm/arch-exynos/gpio.h | 1761 +++++++++++++++++++++++----- arch/arm/include/asm/arch-s5pc1xx/gpio.h | 948 ++++++++++++--- board/samsung/arndale/arndale.c | 11 +- board/samsung/goni/goni.c | 32 +- board/samsung/smdk5250/exynos5-dt.c | 20 +- board/samsung/smdk5250/smdk5250.c | 19 +- board/samsung/smdk5420/smdk5420.c | 15 +- board/samsung/smdkc100/smdkc100.c | 5 +- board/samsung/smdkv310/smdkv310.c | 19 +- board/samsung/trats/trats.c | 39 +- board/samsung/trats2/trats2.c | 74 +- board/samsung/universal_c210/universal.c | 51 +- drivers/gpio/s5p_gpio.c | 204 +++- 19 files changed, 2899 insertions(+), 895 deletions(-)
- disconnect, toggle reset and connect
- gpio_direction_output(EXYNOS5_GPIO_D17, 0);
- gpio_direction_output(EXYNOS5_GPIO_X35, 0);
- MMC0 GPIO
if (i == 2)
- for (i = S5PC110_GPIO_G00; i < S5PC110_GPIO_G07; i++) {
/* GPG0[0:6] special function 2 */if (i == S5PC110_GPIO_G02) continue;
/* GPG0[0:6] pull disable */gpio_cfg_pin(i, 0x2);
/* GPG0[0:6] drv 4x */gpio_set_pull(i, S5P_GPIO_PULL_NONE);
- gpio_cfg_pin(S5PC110_GPIO_H34, S5P_GPIO_INPUT);
- gpio_set_pull(S5PC110_GPIO_H34, S5P_GPIO_PULL_UP);
if (i == 2)
if (i == S5PC110_GPIO_G22) continue; /* GPG2[0:6] special function 2 */
- gpio_direction_output(EXYNOS5_GPIO_X17, 1);
- gpio_set_pull(EXYNOS5_GPIO_X17, S5P_GPIO_PULL_NONE);
} #endif
/* LCD power on */
- gpio_cfg_pin(EXYNOS5_GPIO_X07, S5P_GPIO_FUNC(0x3));
} #endif
/* For Backlight */
/* LCD power on */
/* For Backlight */
- gpio_cfg_pin(EXYNOS5420_GPIO_B10, S5P_GPIO_OUTPUT);
GPIO_B20
/* LCD power on */
- gpio_cfg_pin(EXYNOS5420_GPIO_X07, S5P_GPIO_FUNC(0x3));
Thanks, Minkyu Kang.
Enabling configs for GPIO CMD, EXYNOS4 family and replacing exynos_gpio_get with new linear GPIO pin number required because of the new function asking only 2 arguments (pin and value) instead of 3 (bank, pin and value).
Signed-off-by: Akshay Saraswat akshay.s@samsung.com Acked-by: Przemyslaw Marczak p.marczak@samsung.com --- Changes in v12: - Added change log in this patch. - Added "Acked-by: Przemyslaw Marczak". Changes in v10: - Replaced exynos_gpio_get calls with corresponding pin number. Changes in V8: - Changed Subject to reflect affected SoCs/boards. Changes in V6: - Isolated config changes in a new patch.
include/configs/exynos5-dt.h | 2 ++ include/configs/s5p_goni.h | 4 ++-- include/configs/s5pc210_universal.h | 16 ++++++++-------- include/configs/smdkv310.h | 1 + include/configs/trats.h | 8 ++++---- include/configs/trats2.h | 4 ++-- 6 files changed, 19 insertions(+), 16 deletions(-)
diff --git a/include/configs/exynos5-dt.h b/include/configs/exynos5-dt.h index 414db42..5a9b1b4 100644 --- a/include/configs/exynos5-dt.h +++ b/include/configs/exynos5-dt.h @@ -288,4 +288,6 @@
#define CONFIG_CMD_BOOTZ
+#define CONFIG_CMD_GPIO + #endif /* __CONFIG_H */ diff --git a/include/configs/s5p_goni.h b/include/configs/s5p_goni.h index 991c43e..799d4fe 100644 --- a/include/configs/s5p_goni.h +++ b/include/configs/s5p_goni.h @@ -214,8 +214,8 @@ /* * I2C Settings */ -#define CONFIG_SOFT_I2C_GPIO_SCL s5pc110_gpio_get(j4, 3) -#define CONFIG_SOFT_I2C_GPIO_SDA s5pc110_gpio_get(j4, 0) +#define CONFIG_SOFT_I2C_GPIO_SCL S5PC110_GPIO_J43 +#define CONFIG_SOFT_I2C_GPIO_SDA S5PC110_GPIO_J40
#define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_SOFT /* I2C bit-banged */ diff --git a/include/configs/s5pc210_universal.h b/include/configs/s5pc210_universal.h index 2da8871..b368266 100644 --- a/include/configs/s5pc210_universal.h +++ b/include/configs/s5pc210_universal.h @@ -170,8 +170,8 @@ /* * I2C Settings */ -#define CONFIG_SOFT_I2C_GPIO_SCL exynos4_gpio_get(1, b, 7) -#define CONFIG_SOFT_I2C_GPIO_SDA exynos4_gpio_get(1, b, 6) +#define CONFIG_SOFT_I2C_GPIO_SCL EXYNOS4_GPIO_B7 +#define CONFIG_SOFT_I2C_GPIO_SDA EXYNOS4_GPIO_B6
#define CONFIG_CMD_I2C
@@ -196,10 +196,10 @@ */ #define CONFIG_SOFT_SPI #define CONFIG_SOFT_SPI_MODE SPI_MODE_3 -#define CONFIG_SOFT_SPI_GPIO_SCLK exynos4_gpio_get(2, y3, 1) -#define CONFIG_SOFT_SPI_GPIO_MOSI exynos4_gpio_get(2, y3, 3) -#define CONFIG_SOFT_SPI_GPIO_MISO exynos4_gpio_get(2, y3, 0) -#define CONFIG_SOFT_SPI_GPIO_CS exynos4_gpio_get(2, y4, 3) +#define CONFIG_SOFT_SPI_GPIO_SCLK EXYNOS4_GPIO_Y31 +#define CONFIG_SOFT_SPI_GPIO_MOSI EXYNOS4_GPIO_Y33 +#define CONFIG_SOFT_SPI_GPIO_MISO EXYNOS4_GPIO_Y30 +#define CONFIG_SOFT_SPI_GPIO_CS EXYNOS4_GPIO_Y43
#define SPI_DELAY udelay(1) #undef SPI_INIT @@ -231,8 +231,8 @@ int universal_spi_read(void); #define KEY_PWR_INTERRUPT_REG MAX8998_REG_IRQ1 #define KEY_PWR_INTERRUPT_MASK (1 << 7)
-#define KEY_VOL_UP_GPIO exynos4_gpio_get(2, x2, 0) -#define KEY_VOL_DOWN_GPIO exynos4_gpio_get(2, x2, 1) +#define KEY_VOL_UP_GPIO EXYNOS4_GPIO_X20 +#define KEY_VOL_DOWN_GPIO EXYNOS4_GPIO_X21 #endif /* __ASSEMBLY__ */
/* LCD console */ diff --git a/include/configs/smdkv310.h b/include/configs/smdkv310.h index 1388f49..34adfaf 100644 --- a/include/configs/smdkv310.h +++ b/include/configs/smdkv310.h @@ -12,6 +12,7 @@ /* High Level Configuration Options */ #define CONFIG_SAMSUNG 1 /* in a SAMSUNG core */ #define CONFIG_S5P 1 /* S5P Family */ +#define CONFIG_EXYNOS4 /* EXYNOS4 Family */ #define CONFIG_EXYNOS4210 1 /* which is a EXYNOS4210 SoC */ #define CONFIG_SMDKV310 1 /* working with SMDKV310*/
diff --git a/include/configs/trats.h b/include/configs/trats.h index 5d8bd60..6cade07 100644 --- a/include/configs/trats.h +++ b/include/configs/trats.h @@ -207,8 +207,8 @@ #define CONFIG_SYS_I2C_INIT_BOARD
/* I2C FG */ -#define CONFIG_SOFT_I2C_GPIO_SCL exynos4_gpio_get(2, y4, 1) -#define CONFIG_SOFT_I2C_GPIO_SDA exynos4_gpio_get(2, y4, 0) +#define CONFIG_SOFT_I2C_GPIO_SCL EXYNOS4_GPIO_Y41 +#define CONFIG_SOFT_I2C_GPIO_SDA EXYNOS4_GPIO_Y40
/* POWER */ #define CONFIG_POWER @@ -245,8 +245,8 @@ #define KEY_PWR_INTERRUPT_REG MAX8997_REG_INT1 #define KEY_PWR_INTERRUPT_MASK (1 << 0)
/* LCD console */ diff --git a/include/configs/trats2.h b/include/configs/trats2.h index 53d449c..856c03b 100644 --- a/include/configs/trats2.h +++ b/include/configs/trats2.h @@ -227,8 +227,8 @@ int get_soft_i2c_sda_pin(void); #define KEY_PWR_INTERRUPT_REG MAX77686_REG_PMIC_INT1 #define KEY_PWR_INTERRUPT_MASK (1 << 1)
-#define KEY_VOL_UP_GPIO exynos4x12_gpio_get(2, x2, 2) -#define KEY_VOL_DOWN_GPIO exynos4x12_gpio_get(2, x3, 3) +#define KEY_VOL_UP_GPIO EXYNOS4X12_GPIO_X22 +#define KEY_VOL_DOWN_GPIO EXYNOS4X12_GPIO_X33 #endif /* __ASSEMBLY__ */
/* LCD console */
On 05/06/2014 04:36 PM, Akshay Saraswat wrote:
Used a script to recheck/verify pin mapping and existing mapping appears to be fine, returning correct bank and pin values. Did ./MAKEALL -a arm and found all Exynos/S5P related boards compiled successfully. Couldn't test booting over all of them. Tested U-Boot bootup over SMDK5420, SMDK5250, Snow. Requesting maintaners to please test over affected SoCs/boards.
Changes in V2:
- Enabled CMD_GPIO as suggested by Simon Glass and supported same for EXYNOS5.
Changes in V3:
- New patch added to rename S5P GPIO definitions to S5P_GPIO.
Changes in V4:
Changes in V5:
- Added #define HAVE_GENERIC_GPIO in config file to remove conditinal CPU check in gpio driver.
Changes in V6:
- Updated patches with corresponding changes for Exynos 5420.
Changes in V7:
Changes in V8:
- Changed Subject of patch 2/2 to reflect affected SoCs/boards.
Changes in V9:
Changes in v10:
Changes in v11:
Changes in v12:
- Added change logs in individual patches.
Akshay Saraswat (2): S5P: Exynos: Add GPIO pin numbering and rename definitions S5P: Exynos: Config: Enable GPIO CMD config
arch/arm/cpu/armv7/exynos/pinmux.c | 561 +++++---- arch/arm/dts/exynos4210-origen.dts | 4 +- arch/arm/dts/exynos4210-trats.dts | 6 +- arch/arm/dts/exynos4210-universal_c210.dts | 4 +- arch/arm/dts/exynos4412-trats2.dts | 4 +- arch/arm/include/asm/arch-exynos/cpu.h | 17 +- arch/arm/include/asm/arch-exynos/gpio.h | 1761 +++++++++++++++++++++++----- arch/arm/include/asm/arch-s5pc1xx/gpio.h | 948 ++++++++++++--- board/samsung/arndale/arndale.c | 11 +- board/samsung/goni/goni.c | 32 +- board/samsung/smdk5250/exynos5-dt.c | 20 +- board/samsung/smdk5250/smdk5250.c | 19 +- board/samsung/smdk5420/smdk5420.c | 15 +- board/samsung/smdkc100/smdkc100.c | 5 +- board/samsung/smdkv310/smdkv310.c | 19 +- board/samsung/trats/trats.c | 39 +- board/samsung/trats2/trats2.c | 74 +- board/samsung/universal_c210/universal.c | 51 +- drivers/gpio/s5p_gpio.c | 204 +++- include/configs/exynos5-dt.h | 2 + include/configs/s5p_goni.h | 4 +- include/configs/s5pc210_universal.h | 16 +- include/configs/smdkv310.h | 1 + include/configs/trats.h | 8 +- include/configs/trats2.h | 4 +- 25 files changed, 2918 insertions(+), 911 deletions(-)
Tested on Trats2. Tested-by: Piotr Wilczek p.wilczek@samsung.com
Best regards, Piotr Wilczek
Akshay Saraswat
Minkyu Kang
Piotr Wilczek
