[U-Boot] [PATCH] lib_arm/board.c: remove misleading "test-only" comment.
For a long time, the print_cpuinfo() declaration in lib_arm/board.c had been marked as "test-only", which is plain wrong considering current usage. Delete this misleading comment.
Signed-off-by: Wolfgang Denk wd@denx.de --- lib_arm/board.c | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/lib_arm/board.c b/lib_arm/board.c index 6847ea8..5d05d9b 100644 --- a/lib_arm/board.c +++ b/lib_arm/board.c @@ -258,7 +258,7 @@ static int arm_pci_init(void) */ typedef int (init_fnc_t) (void);
-int print_cpuinfo (void); /* test-only */ +int print_cpuinfo (void);
init_fnc_t *init_sequence[] = { cpu_init, /* basic cpu dependent setup */
Applied.
