[PATCH 00/11] Port manufacturer specific initialization
In preparation of re-sync of mtd stack, I opt to move the current stack slowly in order to have a more easy sync and test. I would like to prepare uboot to support no-jedec and no-onfi compliant nand so I need to clean up a bit the code we have now and upstream some of the support. In this series we expect no functional change
Tested on: - imx6ull Micron MT29F2G08ABAGAH4
Michael Trimarchi (11): mtd: nand: Get rid of busw parameter mtd: nand: Store nand ID in struct nand_chip mtd: nand: Add manufacturer specific initialization/detection steps mtd: nand: Get rid of mtd variable in function calls mtd: nand: Export symbol nand_decode_ext_id mtd: nand: Move Samsung specific init/detection logic in nand_samsung.c mtd: nand: Move Hynix specific init/detection logic in nand_hynix.c mtd: nand: Move Toshiba specific init/detection logic in nand_toshiba.c mtd: nand: Move Micron specific init logic in nand_micron.c mtd: nand: Move AMD/Spansion specific init/detection logic in nand_amd.c mtd: nand: Move Macronix specific initialization in nand_macronix.c
drivers/mtd/nand/raw/Makefile | 10 +- drivers/mtd/nand/raw/nand_amd.c | 53 ++++ drivers/mtd/nand/raw/nand_base.c | 359 ++++++++++----------------- drivers/mtd/nand/raw/nand_hynix.c | 86 +++++++ drivers/mtd/nand/raw/nand_ids.c | 14 +- drivers/mtd/nand/raw/nand_macronix.c | 32 +++ drivers/mtd/nand/raw/nand_micron.c | 88 +++++++ drivers/mtd/nand/raw/nand_samsung.c | 90 +++++++ drivers/mtd/nand/raw/nand_toshiba.c | 53 ++++ include/linux/mtd/rawnand.h | 78 ++++-- 10 files changed, 599 insertions(+), 264 deletions(-) create mode 100644 drivers/mtd/nand/raw/nand_amd.c create mode 100644 drivers/mtd/nand/raw/nand_hynix.c create mode 100644 drivers/mtd/nand/raw/nand_macronix.c create mode 100644 drivers/mtd/nand/raw/nand_micron.c create mode 100644 drivers/mtd/nand/raw/nand_samsung.c create mode 100644 drivers/mtd/nand/raw/nand_toshiba.c
Michael Trimarchi
