[U-Boot] [PATCH] sunxi: Fix Orangepi_mini dtb filename
The Orangepi_mini is different enough from the regular Orangepi that it needs its own dtb, but when it got added a copy and paste error was made and it got the same dtb filename, fix this.
While at it also add a short description of both Orangepi boards to the defconfig files for them.
Signed-off-by: Hans de Goede hdegoede@redhat.com --- configs/Orangepi_defconfig | 7 +++++++ configs/Orangepi_mini_defconfig | 10 +++++++++- 2 files changed, 16 insertions(+), 1 deletion(-)
diff --git a/configs/Orangepi_defconfig b/configs/Orangepi_defconfig index 28fadcd..01d1b2c 100644 --- a/configs/Orangepi_defconfig +++ b/configs/Orangepi_defconfig @@ -1,3 +1,10 @@ +# The Orangepi is a development board using the Allwinner A20 SoC, with 1G +# RAM, microsd slot, HDMI, 1Gbit ethernet, USB wifi, Micro USB (otg), sata, +# 4 USB A ports, ir receiver and a headphones jack. +# +# Also see: +# http://linux-sunxi.org/Xunlong_Orange_Pi +# http://www.orangepi.org/ CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="AXP209_POWER,SUNXI_GMAC,RGMII,MACPWR=SUNXI_GPH(23),AHCI,USB_EHCI" CONFIG_FDTFILE="sun7i-a20-orangepi.dtb" diff --git a/configs/Orangepi_mini_defconfig b/configs/Orangepi_mini_defconfig index 330679b..5364589 100644 --- a/configs/Orangepi_mini_defconfig +++ b/configs/Orangepi_mini_defconfig @@ -1,6 +1,14 @@ +# The Orangepi mini is a development board using the Allwinner A20 SoC, +# with 1G RAM, 2 microsd slots (use the top side one for booting), HDMI, +# 1Gbit ethernet, USB wifi, Micro USB (otg), sata, 4 USB A ports, +# ir receiver and a headphones jack. +# +# Also see: +# http://linux-sunxi.org/Xunlong_Orange_Pi_Mini +# http://www.orangepi.org/ CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="AXP209_POWER,SUNXI_GMAC,RGMII,MACPWR=SUNXI_GPH(23),AHCI,USB_EHCI" -CONFIG_FDTFILE="sun7i-a20-orangepi.dtb" +CONFIG_FDTFILE="sun7i-a20-orangepi-mini.dtb" CONFIG_MMC_SUNXI_SLOT_EXTRA=3 CONFIG_MMC0_CD_PIN="PH10" CONFIG_MMC3_CD_PIN="PH11"
Acked-by: Ian Campbell ijc@hellion.org.uk
Hans de Goede
Ian Campbell
