[U-Boot] CONFIG_SILENT_CONSOLE not working with NAND env
common/console.c has this function:
/* Called before relocation - use serial functions */ int console_init_f(void) { gd->have_console = 1;
#ifdef CONFIG_SILENT_CONSOLE if (getenv("silent") != NULL) gd->flags |= GD_FLG_SILENT; #endif
return 0; }
I have defined CONFIG_SILENT_CONSOLE and set "silent" in my NAND env, but the SILENT flag doesn't get set.
I suspect this function is called way too early for NAND env to be available.
I can set the flag unconditionally and that works fine, but I don't think that that will make a patch worthy of submission...?
Any thoughts?
Thanks, Nick.
return 0; }
NAND isnt the only one with this problem (SPI does too last i looked). during early boot, you only have the default env available. so if you want silent console, i'd suggest you enable that in your default env. -mike
Yes, that's what I intend to do, I think, though I'd have liked it to be configurable at run time.
Thanks for the info, Nick.
Try enabling CONFIG_NAND_ENV_DST to have the environment be loaded by the SPL along with the main U-Boot image. You didn't say what board/chip you're using, so if you're using something other than the common nand_boot.c you may need to add support for this (it's just a couple lines), and silence any output from the SPL itself.
-Scott
-Scott
Thanks Scott,
That's interesting. I'm using a TI board (da830evm). Unfortunately it has its own UBL, so I don't have the SPL to configure that way.
That might be a good reason to consider dropping the UBL though. I believe TI are moving to U-Boot SPL themselves.
I'll add it to my TODO list.
Thanks, Nick.
Dear Nick Thompson,
There is little reason to stick with UBL. You can get rid of it and use the SPL approach instead - this is no real technical challenge, but just a "little effort".
Are they? Do you have any pointers?
Thanks!
On 06/04/11 10:22, Wolfgang Denk wrote:
Dear Nick Thompson,
There have been some SPL submissions from TI people, for example:
http://www.mail-archive.com/u-boot@lists.denx.de/msg48557.html
I believe the work is focused on OMAP4, with OMAP3 as a later addition.
I notice there is already something in repo for da8xx, though not from TI. I think I need to take a look at that.
Nick.
Mike Frysinger
Nick Thompson
Scott Wood
