[U-Boot] [Patch v2, batch 1 01/10] doc/ramboot.mpc85xx: Documented the RAMBOOT for MPC85xx
There could be scenarios where the user would like to manually(via JTAG) configure the DDR/L2SRAM and load the bootloader binary onto DDR/L2SRAM. This document explains thse usecases and the detailed explanation of what needs to be done to use it.
Most of the code from CONFIG_SYS_RAMBOOT will be used except for small changes of CCSRBAR etc.
The changes are not very large, but it is good to document them so that user can get it working at once.
Signed-off-by: Poonam Aggrwal poonam.aggrwal@freescale.com --- doc/README.ramboot-ppc85xx | 102 ++++++++++++++++++++++++++++++++++++++++++++ 1 file changed, 102 insertions(+) create mode 100644 doc/README.ramboot-ppc85xx
diff --git a/doc/README.ramboot-ppc85xx b/doc/README.ramboot-ppc85xx new file mode 100644 index 0000000..8ed45fb --- /dev/null +++ b/doc/README.ramboot-ppc85xx @@ -0,0 +1,102 @@ + RAMBOOT for MPC85xx Platforms + ============================== + +RAMBOOT literally means boot from DDR. But since DDR is volatile memory some +pre-mechanism is required to load the DDR with the bootloader binary. +- In case of SD and SPI boot this is done by BootROM code inside the chip + itself. +- In case of NAND boot FCM supports loading initial 4K code from NAND flash + which can initialize the DDR and get the complete bootloader copied to DDR. + +In addition to the above there could be some more methods to initialize the DDR +and load it manually. +Two of them are described below.There is also an explanation as to where these +methods could be handy. +1. Load the RAM based bootloader onto DDR via JTAG/BDI interface. And then + execute the bootloader from DDR. + This may be handy in the following cases: + - In very early stage of platform bringup where other boot options are not + functional because of various reasons. + - In case the support to program the flashes on the board is not available. + +2. Load the RAM based bootloader onto DDR using already existing bootloader on + the board.And then execute the bootloader from DDR. + Some usecases where this may be used: + - While developing some new feature of u-boot, for example USB driver or + SPI driver. + Suppose the board already has a working bootloader on it. And you would + prefer to keep it intact, at the same time want to test your bootloader. + In this case you can get your test bootloader binary into DDR via tftp + for example. Then execute the test bootloader. + - Suppose a platform already has a propreitery bootloader which does not + support for example AMP boot. In this case also RAM boot loader can be + utilized. + + So basically when the original bootloader is required to be kept intact + RAM based bootloader can offer an updated bootloader on the system. + +Both the above Bootloaders are slight variants of SDcard or SPI Flash +bootloader or for that matter even NAND bootloader. +All of them define CONFIG_SYS_RAMBOOT. +The main difference among all of them is the way the pre-environment is getting +configured and who is doing that. +- In case of SD card and SPI flash bootloader this is done by On Chip BootROM inside the Si itself. +- In case of NAND boot SPL/TPL code does it with some support from Si itself. +- In case of the pure RAM based bootloaders we have to do it by JTAG manually or already existing bootloader. + +How to use them: +1. Using JTAG + Boot up in core hold off mode or stop the core after reset using JTAG + interface. + Preconfigure DDR/L2SRAM through JTAG interface. + - setup DDR controller registers. + - setup DDR LAWs + - setup DDR TLB + Load the RAM based boot loader to the proper location in DDR/L2SRAM. + set up IAR (Instruction counter properly) + Enable the core to execute. + +2. Using already existing bootloader. + get the rambased boot loader binary into DDR/L2SRAM via tftp. + execute the RAM based bootloader. + => tftp 11000000 u-boot-ram.bin + => go 1107f000 + +Please note that L2SRAM can also be used instead of DDR if the SOC has +sufficient size of L2SRAM. + +Necessary Code changes Required: +===================================== +Please note that below mentioned changes are for 85xx platforms. +They have been tested on P1020/P2020/P1010 RDB. + +The main difference between the above two methods from technical perspective is +that in 1st case SOC is just out of reset so it is in default configuration. +(CCSRBAR is at 0xff700000). +In the 2nd case bootloader has already re-located CCSRBAR to 0xffe00000 + +1. File name-> boards.cfg + There can be added specific Make options for RAMBoot. We can keep different + options for the two cases mentioned above. + for example + P1020RDB_JTAG_RAMBOOT and P1020RDB_GO_RAMBOOT. + +2. platform config file + for example include/configs/P1_P2_RDB.h + + #ifdef CONFIG_RAMBOOT + #define CONFIG_SDCARD + #endif + + This will finally use the CONFIG_SYS_RAMBOOT. + +3. File name-> arch/powerpc/include/asm/config_mpc85xx.h + In the section of the particular SOC, for example P1020, + + #if defined(CONFIG_GO) + #define CONFIG_SYS_CCSRBAR_DEFAULT 0xffe00000 + #else + #define CONFIG_SYS_CCSRBAR_DEFAULT 0xff700000 + #endif + +For JTAG RAMBOOT this is not required because CCSRBAR is at ff700000.
Resolve P1020 second USB controller multiplexing with eLBC - mandatory to mention USB2 in hwconfig string to select it over eLBC, otherwise USB2 node is removed - works only for SPI and SD boot
Signed-off-by: Ramneek Mehresh ramneek.mehresh@freescale.com Signed-off-by: Kumar Gala galak@kernel.crashing.org Signed-off-by: Zhicheng Fan B32736@freescale.com --- board/freescale/p1_p2_rdb_pc/p1_p2_rdb_pc.c | 47 +++++++++++++++++++++++++++ 1 file changed, 47 insertions(+)
diff --git a/board/freescale/p1_p2_rdb_pc/p1_p2_rdb_pc.c b/board/freescale/p1_p2_rdb_pc/p1_p2_rdb_pc.c index 5b5b86c..ef62638 100644 --- a/board/freescale/p1_p2_rdb_pc/p1_p2_rdb_pc.c +++ b/board/freescale/p1_p2_rdb_pc/p1_p2_rdb_pc.c @@ -421,6 +421,8 @@ void ft_board_setup(void *blob, bd_t *bd) { phys_addr_t base; phys_size_t size; + const char *soc_usb_compat = "fsl-usb2-dr"; + int err, usb1_off, usb2_off;
ft_cpu_setup(blob, bd);
@@ -442,5 +444,50 @@ void ft_board_setup(void *blob, bd_t *bd) #if defined(CONFIG_HAS_FSL_DR_USB) fdt_fixup_dr_usb(blob, bd); #endif + +#if defined(CONFIG_SDCARD) || defined(CONFIG_SPIFLASH) + /* Delete eLBC node as it is muxed with USB2 controller */ + if (hwconfig("usb2")) { + const char *soc_elbc_compat = "fsl,p1020-elbc"; + int off = fdt_node_offset_by_compatible(blob, -1, + soc_elbc_compat); + if (off < 0) { + printf("WARNING: could not find compatible node %s: %s.\n", + soc_elbc_compat, + fdt_strerror(off)); + return; + } + err = fdt_del_node(blob, off); + if (err < 0) { + printf("WARNING: could not remove %s: %s.\n", + soc_elbc_compat, fdt_strerror(err)); + } + return; + } +#endif + +/* Delete USB2 node as it is muxed with eLBC */ + usb1_off = fdt_node_offset_by_compatible(blob, -1, + soc_usb_compat); + if (usb1_off < 0) { + printf("WARNING: could not find compatible node %s: %s.\n", + soc_usb_compat, + fdt_strerror(usb1_off)); + return; + } + usb2_off = fdt_node_offset_by_compatible(blob, usb1_off, + soc_usb_compat); + if (usb2_off < 0) { + printf("WARNING: could not find compatible node %s: %s.\n", + soc_usb_compat, + fdt_strerror(usb2_off)); + return; + } + err = fdt_del_node(blob, usb2_off); + if (err < 0) { + printf("WARNING: could not remove %s: %s.\n", + soc_usb_compat, fdt_strerror(err)); + } + } #endif
Only some chips have four SerDes banks, so don't define lanes for a bank that doesn't exist.
This fixes warning message "excess elements in array initializer" for array lanes[], because that array is defined with a size of SRDS_MAX_LANES, and the value of SRDS_MAX_LANES depends on the number of SerDes banks.
Signed-off-by: Timur Tabi timur@tabi.org --- arch/powerpc/cpu/mpc85xx/fsl_corenet_serdes.c | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/arch/powerpc/cpu/mpc85xx/fsl_corenet_serdes.c b/arch/powerpc/cpu/mpc85xx/fsl_corenet_serdes.c index 5495dc5..00e1c11 100644 --- a/arch/powerpc/cpu/mpc85xx/fsl_corenet_serdes.c +++ b/arch/powerpc/cpu/mpc85xx/fsl_corenet_serdes.c @@ -103,6 +103,10 @@ static const struct { { 22, 168, FSL_SRDS_BANK_3 }, { 23, 169, FSL_SRDS_BANK_3 }, #endif +#if SRDS_MAX_BANK > 3 + { 24, 175, FSL_SRDS_BANK_4 }, + { 25, 176, FSL_SRDS_BANK_4 }, +#endif };
int serdes_get_lane_idx(int lane)
Change flexcan compatible string from "fsl,flexcan-v1.0" to "fsl,p1010-flexcan" to match the device tree.
Signed-off-by: Shengzhou Liu Shengzhou.Liu@freescale.com --- board/freescale/p1010rdb/p1010rdb.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/board/freescale/p1010rdb/p1010rdb.c b/board/freescale/p1010rdb/p1010rdb.c index 11e2e8a..0c30d76 100644 --- a/board/freescale/p1010rdb/p1010rdb.c +++ b/board/freescale/p1010rdb/p1010rdb.c @@ -217,7 +217,7 @@ void fdt_del_flexcan(void *blob) int nodeoff = 0;
while ((nodeoff = fdt_node_offset_by_compatible(blob, 0, - "fsl,flexcan-v1.0")) >= 0) { + "fsl,p1010-flexcan")) >= 0) { fdt_del_node(blob, nodeoff); } }
Signed-off-by: Shengzhou Liu Shengzhou.Liu@freescale.com --- doc/README.p1010rdb | 199 +++++++++++++++++++++++++++++++++++++++++++++++++++ 1 file changed, 199 insertions(+) create mode 100644 doc/README.p1010rdb
diff --git a/doc/README.p1010rdb b/doc/README.p1010rdb new file mode 100644 index 0000000..dee63d7 --- /dev/null +++ b/doc/README.p1010rdb @@ -0,0 +1,199 @@ +Overview +========= +The P1010RDB is a Freescale reference design board that hosts the P1010 SoC. + +The P1010 is a cost-effective, low-power, highly integrated host processor +based on a Power Architecture e500v2 core (maximum core frequency 800/1000 MHz), +that addresses the requirements of several routing, gateways, storage, consumer, +and industrial applications. Applications of interest include the main CPUs and +I/O processors in network attached storage (NAS), the voice over IP (VoIP) +router/gateway, and wireless LAN (WLAN) and industrial controllers. + +The P1010RDB board features are as follows: +Memory subsystem: + - 1Gbyte unbuffered DDR3 SDRAM discrete devices (32-bit bus) + - 32 Mbyte NOR flash single-chip memory + - 32 Mbyte NAND flash memory + - 256 Kbit M24256 I2C EEPROM + - 16 Mbyte SPI memory + - I2C Board EEPROM 128x8 bit memory + - SD/MMC connector to interface with the SD memory card +Interfaces: + - PCIe: + - Lane0: x1 mini-PCIe slot + - Lane1: x1 PCIe standard slot + - SATA: + - 1 internal SATA connector to 2.5" 160G SATA2 HDD + - 1 eSATA connector to rear panel + - 10/100/1000 BaseT Ethernet ports: + - eTSEC1, RGMII: one 10/100/1000 port using Vitesse VSC8641XKO + - eTSEC2, SGMII: one 10/100/1000 port using Vitesse VSC8221 + - eTSEC3, SGMII: one 10/100/1000 port using Vitesse VSC8221 + - USB 2.0 port: + - x1 USB2.0 port: via an ULPI PHY to micro-AB connector + - x1 USB2.0 poort via an internal PHY to micro-AB connector + - FlexCAN ports: + - x2 DB-9 female connectors for FlexCAN bus(revision 2.0B) + interface; + - DUART interface: + - DUART interface: supports two UARTs up to 115200 bps for + console display + - J45 connectors are used for these 2 UART ports. + - TDM + - 2 FXS ports connected via an external SLIC to the TDM + interface. SLIC is controllled via SPI. + - 1 FXO port connected via a relay to FXS for switchover to + POTS +Board connectors: + - Mini-ITX power supply connector + - JTAG/COP for debugging +IEEE Std. 1588 signals for test and measurement +Real-time clock on I2C bus +POR + - support critical POR setting changed via switch on board +PCB + - 6-layer routing (4-layer signals, 2-layer power and ground) + + +Serial Port Configuration on P1010RDB +===================================== +Configure the serial port of the attached computer with the following values: + -Data rate: 115200 bps + -Number of data bits: 8 + -Parity: None + -Number of Stop bits: 1 + -Flow Control: Hardware/None + + +Settings of DIP-switch +====================== + SW4[1:4]= 1111 and SW6[4]=0 for boot from 16bit NOR flash + SW4[1:4]= 1000 and SW6[4]=1 for boot from 8bit NAND flash + SW4[1:4]= 0110 and SW6[4]=0 for boot from SPI flash +Note: 1 stands for 'on', 0 stands for 'off' + + +Setting of hwconfig +=================== +If FlexCAN or TDM is needed, please set "fsl_p1010mux:tdm_can=can" or +"fsl_p1010mux:tdm_can=tdm" explicitly in u-booot prompt as below for example: +setenv hwconfig "fsl_p1010mux:tdm_can=tdm;usb1:dr_mode=host,phy_type=utmi" +By default, don't set fsl_p1010mux:tdm_can, in this case, spi chip selection +is set to spi-flash instead of to SLIC/TDM/DAC and tdm_can_sel is set to TDM +instead of to CAN/UART1. + + +Build and burn u-boot to NOR flash +================================== +1. Build u-boot.bin image + export ARCH=powerpc + export CROSS_COMPILE=/your_path/powerpc-linux-gnu- + make P1010RDB_NOR + +2. Burn u-boot.bin into NOR flash + => tftp $loadaddr $uboot + => protect off eff80000 +$filesize + => erase eff80000 +$filesize + => cp.b $loadaddr eff80000 $filesize + +3. Check SW4[1:4]= 1111 and SW6[4]=0, then power on. + + +Alternate NOR bank +============================ +1. Burn u-boot.bin into alternate NOR bank + => tftp $loadaddr $uboot + => protect off eef80000 +$filesize + => erase eef80000 +$filesize + => cp.b $loadaddr eef80000 $filesize + +2. Switch to alternate NOR bank + => mw.b ffb00009 1 + => reset + or set SW1[8]= ON + +SW1[8]= OFF: Upper bank used for booting start +SW1[8]= ON: Lower bank used for booting start +CPLD NOR bank selection register address 0xFFB00009 Bit[0]: +0 - boot from upper 4 sectors +1 - boot from lower 4 sectors + + +Build and burn u-boot to NAND flash +=================================== +1. Build u-boot.bin image + export ARCH=powerpc + export CROSS_COMPILE=/your_path/powerpc-linux-gnu- + make P1010RDB_NAND + +2. Burn u-boot-nand.bin into NAND flash + => tftp $loadaddr $uboot-nand + => nand erase 0 $filesize + => nand write $loadaddr 0 $filesize + +3. Check SW4[1:4]= 1000 and SW6[4]=1, then power on. + + + +Build and burn u-boot to SPI flash +================================== +1. Build u-boot-spi.bin image + make P1010RDB_SPIFLASH_config; make + Boot up kernel with rootfs.ext2.gz.uboot.p1010rdb + Download u-boot.bin to linux and you can find some config files + under /usr/share such as config_xx.dat. Do below command: + boot_format config_ddr3_1gb_p1010rdb_800M.dat u-boot.bin -spi \ + u-boot-spi.bin + to generate u-boot-spi.bin. + +2. Burn u-boot-spi.bin into SPI flash + => tftp $loadaddr $uboot-spi + => sf erase 0 100000 + => sf write $loadaddr 0 $filesize + +3. Check SW4[1:4]= 0110 and SW6[4]=0, then power on. + + + +CPLD POR setting registers +========================== +1. Set POR switch selection register (addr 0xFFB00011) to 0. +2. Write CPLD POR registers (BCSR0~BCSR3, addr 0xFFB00014~0xFFB00017) with + proper values. + If change boot ROM location to NOR or NAND flash, need write the IFC_CS0 + switch command by I2C. +3. Send reset command. + After reset, the new POR setting will be implemented. + +Two examples are given in below: +Switch from NOR to NAND boot with default frequency: + => i2c dev 0 + => i2c mw 18 1 f9 + => i2c mw 18 3 f0 + => mw.b ffb00011 0 + => mw.b ffb00017 1 + => reset +Switch from NAND to NOR boot with Core/CCB/DDR (800/400/667 MHz): + => i2c dev 0 + => i2c mw 18 1 f1 + => i2c mw 18 3 f0 + => mw.b ffb00011 0 + => mw.b ffb00014 2 + => mw.b ffb00015 5 + => mw.b ffb00016 3 + => mw.b ffb00017 f + => reset + + + +Boot Linux from network using TFTP on P1010RDB +============================================== +Place uImage, p1010rdb.dtb and rootfs files in the TFTP disk area. + => tftp 1000000 uImage + => tftp 2000000 p1010rdb.dtb + => tftp 3000000 rootfs.ext2.gz.uboot.p1010rdb + => bootm 1000000 3000000 2000000 + + +Please contact your local field applications engineer or sales representative +to obtain related documents, such as P1010-RDB User Guide for details.
Erratum DDR_A003 applies to P5020, P3041, P4080, P3060, P2041, P5040.
Signed-off-by: York Sun yorksun@freescale.com --- arch/powerpc/include/asm/config_mpc85xx.h | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/arch/powerpc/include/asm/config_mpc85xx.h b/arch/powerpc/include/asm/config_mpc85xx.h index d57c178..352e303 100644 --- a/arch/powerpc/include/asm/config_mpc85xx.h +++ b/arch/powerpc/include/asm/config_mpc85xx.h @@ -334,6 +334,7 @@ #define CONFIG_SYS_FSL_ERRATUM_ESDHC111 #define CONFIG_SYS_FSL_ERRATUM_NMG_CPU_A011 #define CONFIG_SYS_FSL_ERRATUM_CPU_A003999 +#define CONFIG_SYS_FSL_ERRATUM_DDR_A003 #define CONFIG_SYS_FSL_ERRATUM_DDR_A003474 #define CONFIG_SYS_FSL_SRIO_PCIE_BOOT_MASTER #define CONFIG_SYS_FSL_SRIO_MAX_PORTS 2 @@ -366,6 +367,7 @@ #define CONFIG_SYS_FSL_ERRATUM_ESDHC111 #define CONFIG_SYS_FSL_ERRATUM_NMG_CPU_A011 #define CONFIG_SYS_FSL_ERRATUM_CPU_A003999 +#define CONFIG_SYS_FSL_ERRATUM_DDR_A003 #define CONFIG_SYS_FSL_ERRATUM_DDR_A003474 #define CONFIG_SYS_FSL_SRIO_PCIE_BOOT_MASTER #define CONFIG_SYS_FSL_SRIO_MAX_PORTS 2 @@ -442,6 +444,7 @@ #define CONFIG_SYS_FSL_USB2_PHY_ENABLE #define CONFIG_SYS_FSL_USB_INTERNAL_UTMI_PHY #define CONFIG_SYS_FSL_ERRATUM_ESDHC111 +#define CONFIG_SYS_FSL_ERRATUM_DDR_A003 #define CONFIG_SYS_FSL_ERRATUM_DDR_A003474 #define CONFIG_SYS_FSL_SRIO_PCIE_BOOT_MASTER #define CONFIG_SYS_FSL_SRIO_MAX_PORTS 2
From: Cristian Sovaiala cristian.sovaiala@freescale.com
Extending LIODN offset range from 1-5 to 1-10 While using a qman portal with a higher index the LIODN offset is incorrectly set, thus extending the range of offsets covers all 10 qman portals
Signed-off-by: Cristian Sovaiala cristian.sovaiala@freescale.com Acked-by: Haiying Wang Haiying.Wang@freescale.com --- arch/powerpc/cpu/mpc85xx/p2041_ids.c | 20 ++++++++++---------- arch/powerpc/cpu/mpc85xx/p3041_ids.c | 20 ++++++++++---------- arch/powerpc/cpu/mpc85xx/p5020_ids.c | 20 ++++++++++---------- 3 files changed, 30 insertions(+), 30 deletions(-)
diff --git a/arch/powerpc/cpu/mpc85xx/p2041_ids.c b/arch/powerpc/cpu/mpc85xx/p2041_ids.c index 91d9cac..ef685fe 100644 --- a/arch/powerpc/cpu/mpc85xx/p2041_ids.c +++ b/arch/powerpc/cpu/mpc85xx/p2041_ids.c @@ -27,16 +27,16 @@ #ifdef CONFIG_SYS_DPAA_QBMAN struct qportal_info qp_info[CONFIG_SYS_QMAN_NUM_PORTALS] = { /* dqrr liodn, frame data liodn, liodn off, sdest */ - SET_QP_INFO(1, 2, 1, 0), - SET_QP_INFO(3, 4, 2, 1), - SET_QP_INFO(5, 6, 3, 2), - SET_QP_INFO(7, 8, 4, 3), - SET_QP_INFO(9, 10, 5, 0), - SET_QP_INFO(11, 12, 1, 1), - SET_QP_INFO(13, 14, 2, 2), - SET_QP_INFO(15, 16, 3, 3), - SET_QP_INFO(17, 18, 4, 0), /* for now sdest to 0 */ - SET_QP_INFO(19, 20, 5, 0), /* for now sdest to 0 */ + SET_QP_INFO(1, 2, 1, 0), + SET_QP_INFO(3, 4, 2, 1), + SET_QP_INFO(5, 6, 3, 2), + SET_QP_INFO(7, 8, 4, 3), + SET_QP_INFO(9, 10, 5, 0), + SET_QP_INFO(11, 12, 6, 1), + SET_QP_INFO(13, 14, 7, 2), + SET_QP_INFO(15, 16, 8, 3), + SET_QP_INFO(17, 18, 9, 0), /* for now sdest to 0 */ + SET_QP_INFO(19, 20, 10, 0), /* for now sdest to 0 */ }; #endif
diff --git a/arch/powerpc/cpu/mpc85xx/p3041_ids.c b/arch/powerpc/cpu/mpc85xx/p3041_ids.c index e46a714..cab03f8 100644 --- a/arch/powerpc/cpu/mpc85xx/p3041_ids.c +++ b/arch/powerpc/cpu/mpc85xx/p3041_ids.c @@ -27,16 +27,16 @@ #ifdef CONFIG_SYS_DPAA_QBMAN struct qportal_info qp_info[CONFIG_SYS_QMAN_NUM_PORTALS] = { /* dqrr liodn, frame data liodn, liodn off, sdest */ - SET_QP_INFO(1, 2, 1, 0), - SET_QP_INFO(3, 4, 2, 1), - SET_QP_INFO(5, 6, 3, 2), - SET_QP_INFO(7, 8, 4, 3), - SET_QP_INFO(9, 10, 5, 0), - SET_QP_INFO(11, 12, 1, 1), - SET_QP_INFO(13, 14, 2, 2), - SET_QP_INFO(15, 16, 3, 3), - SET_QP_INFO(17, 18, 4, 0), /* for now sdest to 0 */ - SET_QP_INFO(19, 20, 5, 0), /* for now sdest to 0 */ + SET_QP_INFO(1, 2, 1, 0), + SET_QP_INFO(3, 4, 2, 1), + SET_QP_INFO(5, 6, 3, 2), + SET_QP_INFO(7, 8, 4, 3), + SET_QP_INFO(9, 10, 5, 0), + SET_QP_INFO(1, 12, 6, 1), + SET_QP_INFO(13, 14, 7, 2), + SET_QP_INFO(15, 16, 8, 3), + SET_QP_INFO(17, 18, 9, 0), /* for now sdest to 0 */ + SET_QP_INFO(19, 20, 10, 0), /* for now sdest to 0 */ }; #endif
diff --git a/arch/powerpc/cpu/mpc85xx/p5020_ids.c b/arch/powerpc/cpu/mpc85xx/p5020_ids.c index e8c26bf..ca05b9c 100644 --- a/arch/powerpc/cpu/mpc85xx/p5020_ids.c +++ b/arch/powerpc/cpu/mpc85xx/p5020_ids.c @@ -27,16 +27,16 @@ #ifdef CONFIG_SYS_DPAA_QBMAN struct qportal_info qp_info[CONFIG_SYS_QMAN_NUM_PORTALS] = { /* dqrr liodn, frame data liodn, liodn off, sdest */ - SET_QP_INFO(1, 2, 1, 0), - SET_QP_INFO(3, 4, 2, 1), - SET_QP_INFO(5, 6, 3, 0), - SET_QP_INFO(7, 8, 4, 1), - SET_QP_INFO(9, 10, 5, 0), - SET_QP_INFO(11, 12, 1, 1), - SET_QP_INFO(13, 14, 2, 0), - SET_QP_INFO(15, 16, 3, 1), - SET_QP_INFO(17, 18, 4, 0), - SET_QP_INFO(19, 20, 5, 1), + SET_QP_INFO(1, 2, 1, 0), + SET_QP_INFO(3, 4, 2, 1), + SET_QP_INFO(5, 6, 3, 0), + SET_QP_INFO(7, 8, 4, 1), + SET_QP_INFO(9, 10, 5, 0), + SET_QP_INFO(11, 12, 6, 1), + SET_QP_INFO(13, 14, 7, 0), + SET_QP_INFO(15, 16, 8, 1), + SET_QP_INFO(17, 18, 9, 0), + SET_QP_INFO(19, 20, 10, 1), }; #endif
When P1021RDB-PC reboot system, the board will hung at uboot DDR configuration. For P1021RDB-PC DDR reset pin is multiplex with QE, so uboot will reserve this pin for QE and skip DDR reset. Other platforms without QE will do this reset. This patch adds a slight code to reset DDR chip by QE CE_PB8 pin for NAND and NOR FLASH boot. For booting from SPI FALSH and SD card, it seems possible to use the rom on chip to write to the GPIO pins before configuring the DDR.
Signed-off-by: Xu Jiucheng B37781@freescale.com Signed-off-by: Xie Xiaobo X.Xie@freescale.com --- board/freescale/p1_p2_rdb_pc/p1_p2_rdb_pc.c | 19 ++++++++++++++++++- board/freescale/p1_p2_rdb_pc/spl_minimal.c | 15 +++++++++++++++ 2 files changed, 33 insertions(+), 1 deletion(-)
diff --git a/board/freescale/p1_p2_rdb_pc/p1_p2_rdb_pc.c b/board/freescale/p1_p2_rdb_pc/p1_p2_rdb_pc.c index ef62638..2e0e0c7 100644 --- a/board/freescale/p1_p2_rdb_pc/p1_p2_rdb_pc.c +++ b/board/freescale/p1_p2_rdb_pc/p1_p2_rdb_pc.c @@ -55,6 +55,13 @@ #define GPIO_SLIC_PIN 30 #define GPIO_SLIC_DATA (1 << (31 - GPIO_SLIC_PIN))
+#if defined(CONFIG_P1021RDB) && !defined(CONFIG_SYS_RAMBOOT) +#define GPIO_DDR_RST_PORT 1 +#define GPIO_DDR_RST_PIN 8 +#define GPIO_DDR_RST_DATA (1 << (31 - GPIO_DDR_RST_PIN)) + +#define GPIO_2BIT_MASK (0x3 << (32 - (GPIO_DDR_RST_PIN + 1) * 2)) +#endif
#if defined(CONFIG_P1025RDB) || defined(CONFIG_P1021RDB) #define PCA_IOPORT_I2C_ADDR 0x23 @@ -67,7 +74,7 @@ const qe_iop_conf_t qe_iop_conf_tab[] = { /* GPIO */ {1, 1, 2, 0, 0}, /* GPIO7/PB1 - LOAD_DEFAULT_N */ -#if 0 +#if defined(CONFIG_P1021RDB) && !defined(CONFIG_SYS_RAMBOOT) {1, 8, 1, 1, 0}, /* GPIO10/PB8 - DDR_RST */ #endif {0, 15, 1, 0, 0}, /* GPIO11/A15 - WDI */ @@ -159,6 +166,16 @@ void board_gpio_init(void) ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); par_io_t *par_io = (par_io_t *) &(gur->qe_par_io);
+#if defined(CONFIG_P1021RDB) && !defined(CONFIG_SYS_RAMBOOT) + /* reset DDR3 */ + setbits_be32(&par_io[GPIO_DDR_RST_PORT].cpdat, GPIO_DDR_RST_DATA); + udelay(1000); + clrbits_be32(&par_io[GPIO_DDR_RST_PORT].cpdat, GPIO_DDR_RST_DATA); + udelay(1000); + setbits_be32(&par_io[GPIO_DDR_RST_PORT].cpdat, GPIO_DDR_RST_DATA); + /* disable CE_PB8 */ + clrbits_be32(&par_io[GPIO_DDR_RST_PORT].cpdir1, GPIO_2BIT_MASK); +#endif /* Enable VSC7385 switch */ setbits_be32(&par_io[GPIO_GETH_SW_PORT].cpdat, GPIO_GETH_SW_DATA);
diff --git a/board/freescale/p1_p2_rdb_pc/spl_minimal.c b/board/freescale/p1_p2_rdb_pc/spl_minimal.c index 09019e9..e2bfb0d 100644 --- a/board/freescale/p1_p2_rdb_pc/spl_minimal.c +++ b/board/freescale/p1_p2_rdb_pc/spl_minimal.c @@ -81,6 +81,8 @@ void board_init_f(ulong bootflag) ccsr_gur_t *gur = (void *)CONFIG_SYS_MPC85xx_GUTS_ADDR; #ifndef CONFIG_QE ccsr_gpio_t *pgpio = (void *)(CONFIG_SYS_MPC85xx_GPIO_ADDR); +#elif defined(CONFIG_P1021RDB) + par_io_t *par_io = (par_io_t *)&(gur->qe_par_io); #endif
/* initialize selected port with appropriate baud rate */ @@ -102,6 +104,19 @@ void board_init_f(ulong bootflag) __raw_writel(0x00200000, &pgpio->gpdat); udelay(1000); __raw_writel(0x00000000, &pgpio->gpdir); +#elif defined(CONFIG_P1021RDB) + /* init DDR3 reset signal CE_PB8 */ + out_be32(&par_io[1].cpdir1, 0x00004000); + out_be32(&par_io[1].cpodr, 0x00800000); + out_be32(&par_io[1].cppar1, 0x00000000); + /* reset DDR3 */ + out_be32(&par_io[1].cpdat, 0x00800000); + udelay(1000); + out_be32(&par_io[1].cpdat, 0x00000000); + udelay(1000); + out_be32(&par_io[1].cpdat, 0x00800000); + /* disable the CE_PB8 */ + out_be32(&par_io[1].cpdir1, 0x00000000); #endif
#ifndef CONFIG_SYS_INIT_L2_ADDR
SRIO doesn't exist on the P5040DS board and we'll reuse the common corenet_ds.h for it. So move the SRIO defines into the board specific headers.
Signed-off-by: Kumar Gala galak@kernel.crashing.org --- include/configs/P3041DS.h | 3 +++ include/configs/P4080DS.h | 3 +++ include/configs/P5020DS.h | 3 +++ 3 files changed, 9 insertions(+)
diff --git a/include/configs/P3041DS.h b/include/configs/P3041DS.h index ce8f9b0..a0a4a3c 100644 --- a/include/configs/P3041DS.h +++ b/include/configs/P3041DS.h @@ -35,6 +35,9 @@ #define CONFIG_FSL_SATA_V2 #define CONFIG_PCIE3 #define CONFIG_PCIE4 +#define CONFIG_SYS_SRIO +#define CONFIG_SRIO1 /* SRIO port 1 */ +#define CONFIG_SRIO2 /* SRIO port 2 */ #define CONFIG_SYS_DPAA_RMAN
#define CONFIG_SYS_SRIO diff --git a/include/configs/P4080DS.h b/include/configs/P4080DS.h index 53979dd..257258b 100644 --- a/include/configs/P4080DS.h +++ b/include/configs/P4080DS.h @@ -32,6 +32,9 @@
#define CONFIG_MMC #define CONFIG_PCIE3 +#define CONFIG_SYS_SRIO +#define CONFIG_SRIO1 /* SRIO port 1 */ +#define CONFIG_SRIO2 /* SRIO port 2 */
#define CONFIG_SYS_SRIO #define CONFIG_SRIO1 /* SRIO port 1 */ diff --git a/include/configs/P5020DS.h b/include/configs/P5020DS.h index 778230d..a32b610 100644 --- a/include/configs/P5020DS.h +++ b/include/configs/P5020DS.h @@ -35,6 +35,9 @@ #define CONFIG_FSL_SATA_V2 #define CONFIG_PCIE3 #define CONFIG_PCIE4 +#define CONFIG_SYS_SRIO +#define CONFIG_SRIO1 /* SRIO port 1 */ +#define CONFIG_SRIO2 /* SRIO port 2 */ #define CONFIG_SYS_FSL_RAID_ENGINE #define CONFIG_SYS_DPAA_RMAN
This patch is actually this patch:
commit 11860d888cdc2be5da7b8738a067b84cd76e71c0 Author: Timur Tabi timur@freescale.com Date: Fri Oct 5 09:48:53 2012 +0000
powerpc/85xx: move SRIO configuration out of corenet_ds.h
Which is already upstream. My guess is that Kumar submitted it internally to get internal u-boot in sync, or visa-versa, and it got merged internally.
This also means your subsequent patch from batch 3 (Remove duplicate macro...) is unnecessary.
NAK. I will update patchworks.
Andy
The Hydra and Superhydra (P3041DS, P5020DS, and P5040DS) boards have a second USB port that can be configured in either host, peripheral (aka device), or OTG (on-the-go) mode. When configured in host mode, if the port is connected to another USB host, damage to the board can occur.
To avoid this, we change the default setting to peripheral mode. Ideally, we'd set it to OTG mode, but currently there is no OTG support for these boards.
Setting the hwconfig variable will also update the device tree, and so Linux will configure the port for peripheral mode as well.
Signed-off-by: Shaohui Xie Shaohui.Xie@freescale.com Signed-off-by: Timur Tabi timur@tabi.org --- include/configs/corenet_ds.h | 1 + 1 file changed, 1 insertion(+)
diff --git a/include/configs/corenet_ds.h b/include/configs/corenet_ds.h index 3f42cd9..5cc9b5a 100644 --- a/include/configs/corenet_ds.h +++ b/include/configs/corenet_ds.h @@ -714,6 +714,7 @@ #define CONFIG_EXTRA_ENV_SETTINGS \ "hwconfig=fsl_ddr:ctlr_intlv=cacheline," \ "bank_intlv=cs0_cs1;" \ + "usb2:dr_mode=peripheral,phy_type=" __stringify(__USB_PHY_TYPE) ";"\ "usb1:dr_mode=host,phy_type=" __stringify(__USB_PHY_TYPE) "\0"\ "netdev=eth0\0" \ "uboot=" __stringify(CONFIG_UBOOTPATH) "\0" \
Andy Fleming
York Sun
