[U-Boot] [PATCH v4 1/3] armv8:fsl-layerscape: Consolidate registers space defination for CCI-400 bus
CoreLink Cache Coherent Interconnect (CCI) is ARM BUS which provides full cache coherency between two clusters of multi-core CPUs and I/O coherency for devices and I/O masters.
This patch add new CONFIG defination "SYS_FSL_HAS_CCI400" and moves existing register space definaton of CCI-400 bus from immap_lsch2 to fsl_immap, so that it can be used for both chasis 2 and chasis 3.
"CONFIG_SYS_CCI400_ADDR" is depricated and new SYS_CCI400_OFFSET is introduced in Kconfig
Signed-off-by: Ashish Kumar Ashish.Kumar@nxp.com Signed-off-by: Prabhakar Kushwaha prabhakar.kushwaha@nxp.com --- v3: This is v3 for https://patchwork.ozlabs.org/patch/731464/ v4: Header file included in middle of the file in cpu.c
README | 9 ++++ arch/arm/cpu/armv8/fsl-layerscape/Kconfig | 13 ++++++ arch/arm/cpu/armv8/fsl-layerscape/cpu.c | 1 + arch/arm/cpu/armv8/fsl-layerscape/soc.c | 10 +++-- .../include/asm/arch-fsl-layerscape/immap_lsch2.h | 49 --------------------- board/freescale/ls1012afrdm/ls1012afrdm.c | 4 +- board/freescale/ls1012aqds/ls1012aqds.c | 4 +- board/freescale/ls1012ardb/ls1012ardb.c | 3 +- board/freescale/ls1021aqds/ls1021aqds.c | 9 ++-- include/fsl_immap.h | 51 ++++++++++++++++++++++ 10 files changed, 94 insertions(+), 59 deletions(-)
diff --git a/README b/README index c73f6dd..165f403 100644 --- a/README +++ b/README @@ -312,6 +312,15 @@ Many of the options are named exactly as the corresponding Linux kernel configuration options. The intention is to make it easier to build a config tool - later.
+- ARM Platform Bus Type(CCI): + CoreLink Cache Coherent Interconnect (CCI) is ARM BUS which + provides full cache coherency between two clusters of multi-core + CPUs and I/O coherency for devices and I/O masters + + CONFIG_SYS_FSL_HAS_CCI400 + + Defined For SoC that has cache coherent interconnect + CCN-400
The following options need to be configured:
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig index 5825f9b..1132969 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig +++ b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig @@ -84,6 +84,7 @@ config ARCH_LS2080A
config FSL_LSCH2 bool + select SYS_FSL_HAS_CCI400 select SYS_FSL_HAS_SEC select SYS_FSL_SEC_COMPAT_5 select SYS_FSL_SEC_BE @@ -247,6 +248,15 @@ config QSPI_AHB_INIT But some QSPI flash size up to 64MBytes, so initialize the QSPI AHB bus for those flashes to support the full QSPI flash size.
+config SYS_CCI400_OFFSET + hex "Offset for CCI400 base" + depends on SYS_FSL_HAS_CCI400 + default 0x3090000 if ARCH_LS1088A + default 0x180000 if FSL_LSCH2 + help + Offset for CCI400 base + CCI400 base addr = CCSRBAR + CCI400_OFFSET + config SYS_FSL_IFC_BANK_COUNT int "Maximum banks of Integrated flash controller" depends on ARCH_LS1043A || ARCH_LS1046A || ARCH_LS2080A @@ -254,6 +264,9 @@ config SYS_FSL_IFC_BANK_COUNT default 4 if ARCH_LS1046A default 8 if ARCH_LS2080A
+config SYS_FSL_HAS_CCI400 + bool + config SYS_FSL_HAS_DP_DDR bool
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/cpu.c b/arch/arm/cpu/armv8/fsl-layerscape/cpu.c index c6fede3..ec58065 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/cpu.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/cpu.c @@ -16,6 +16,7 @@ #include <asm/arch/soc.h> #include <asm/arch/cpu.h> #include <asm/arch/speed.h> +#include <fsl_immap.h> #include <asm/arch/mp.h> #include <efi_loader.h> #include <fm_eth.h> diff --git a/arch/arm/cpu/armv8/fsl-layerscape/soc.c b/arch/arm/cpu/armv8/fsl-layerscape/soc.c index aee1ffa..ddb7d82 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/soc.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/soc.c @@ -5,6 +5,7 @@ */
#include <common.h> +#include <fsl_immap.h> #include <fsl_ifc.h> #include <ahci.h> #include <scsi.h> @@ -285,7 +286,8 @@ static void erratum_a008850_early(void) { #ifdef CONFIG_SYS_FSL_ERRATUM_A008850 /* part 1 of 2 */ - struct ccsr_cci400 __iomem *cci = (void *)CONFIG_SYS_CCI400_ADDR; + struct ccsr_cci400 __iomem *cci = (void *)(CONFIG_SYS_IMMR + + CONFIG_SYS_CCI400_OFFSET); struct ccsr_ddr __iomem *ddr = (void *)CONFIG_SYS_FSL_DDR_ADDR;
/* Skip if running at lower exception level */ @@ -304,7 +306,8 @@ void erratum_a008850_post(void) { #ifdef CONFIG_SYS_FSL_ERRATUM_A008850 /* part 2 of 2 */ - struct ccsr_cci400 __iomem *cci = (void *)CONFIG_SYS_CCI400_ADDR; + struct ccsr_cci400 __iomem *cci = (void *)(CONFIG_SYS_IMMR + + CONFIG_SYS_CCI400_OFFSET); struct ccsr_ddr __iomem *ddr = (void *)CONFIG_SYS_FSL_DDR_ADDR; u32 tmp;
@@ -439,7 +442,8 @@ int setup_chip_volt(void)
void fsl_lsch2_early_init_f(void) { - struct ccsr_cci400 *cci = (struct ccsr_cci400 *)CONFIG_SYS_CCI400_ADDR; + struct ccsr_cci400 *cci = (struct ccsr_cci400 *)(CONFIG_SYS_IMMR + + CONFIG_SYS_CCI400_OFFSET); struct ccsr_scfg *scfg = (struct ccsr_scfg *)CONFIG_SYS_FSL_SCFG_ADDR;
#ifdef CONFIG_LAYERSCAPE_NS_ACCESS diff --git a/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h b/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h index 8ad199f..560ad4e 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h @@ -15,7 +15,6 @@ #define CONFIG_SYS_DCSR_COP_CCP_ADDR (CONFIG_SYS_DCSRBAR + 0x02008040)
#define CONFIG_SYS_FSL_DDR_ADDR (CONFIG_SYS_IMMR + 0x00080000) -#define CONFIG_SYS_CCI400_ADDR (CONFIG_SYS_IMMR + 0x00180000) #define CONFIG_SYS_GIC400_ADDR (CONFIG_SYS_IMMR + 0x00400000) #define CONFIG_SYS_IFC_ADDR (CONFIG_SYS_IMMR + 0x00530000) #define SYS_FSL_QSPI_ADDR (CONFIG_SYS_IMMR + 0x00550000) @@ -543,54 +542,6 @@ struct ccsr_serdes { u8 res_19a0[0x2000-0x19a0]; /* from 0x19a0 to 0x1fff */ };
-#define CCI400_CTRLORD_TERM_BARRIER 0x00000008 -#define CCI400_CTRLORD_EN_BARRIER 0 -#define CCI400_SHAORD_NON_SHAREABLE 0x00000002 -#define CCI400_DVM_MESSAGE_REQ_EN 0x00000002 -#define CCI400_SNOOP_REQ_EN 0x00000001 - -/* CCI-400 registers */ -struct ccsr_cci400 { - u32 ctrl_ord; /* Control Override */ - u32 spec_ctrl; /* Speculation Control */ - u32 secure_access; /* Secure Access */ - u32 status; /* Status */ - u32 impr_err; /* Imprecise Error */ - u8 res_14[0x100 - 0x14]; - u32 pmcr; /* Performance Monitor Control */ - u8 res_104[0xfd0 - 0x104]; - u32 pid[8]; /* Peripheral ID */ - u32 cid[4]; /* Component ID */ - struct { - u32 snoop_ctrl; /* Snoop Control */ - u32 sha_ord; /* Shareable Override */ - u8 res_1008[0x1100 - 0x1008]; - u32 rc_qos_ord; /* read channel QoS Value Override */ - u32 wc_qos_ord; /* read channel QoS Value Override */ - u8 res_1108[0x110c - 0x1108]; - u32 qos_ctrl; /* QoS Control */ - u32 max_ot; /* Max OT */ - u8 res_1114[0x1130 - 0x1114]; - u32 target_lat; /* Target Latency */ - u32 latency_regu; /* Latency Regulation */ - u32 qos_range; /* QoS Range */ - u8 res_113c[0x2000 - 0x113c]; - } slave[5]; /* Slave Interface */ - u8 res_6000[0x9004 - 0x6000]; - u32 cycle_counter; /* Cycle counter */ - u32 count_ctrl; /* Count Control */ - u32 overflow_status; /* Overflow Flag Status */ - u8 res_9010[0xa000 - 0x9010]; - struct { - u32 event_select; /* Event Select */ - u32 event_count; /* Event Count */ - u32 counter_ctrl; /* Counter Control */ - u32 overflow_status; /* Overflow Flag Status */ - u8 res_a010[0xb000 - 0xa010]; - } pcounter[4]; /* Performance Counter */ - u8 res_e004[0x10000 - 0xe004]; -}; - /* MMU 500 */ #define SMMU_SCR0 (SMMU_BASE + 0x0) #define SMMU_SCR1 (SMMU_BASE + 0x4) diff --git a/board/freescale/ls1012afrdm/ls1012afrdm.c b/board/freescale/ls1012afrdm/ls1012afrdm.c index 25d22d2..9afd1c4 100644 --- a/board/freescale/ls1012afrdm/ls1012afrdm.c +++ b/board/freescale/ls1012afrdm/ls1012afrdm.c @@ -71,7 +71,9 @@ int board_early_init_f(void)
int board_init(void) { - struct ccsr_cci400 *cci = (struct ccsr_cci400 *)CONFIG_SYS_CCI400_ADDR; + struct ccsr_cci400 *cci = (struct ccsr_cci400 *)(CONFIG_SYS_IMMR + + CONFIG_SYS_CCI400_OFFSET); + /* * Set CCI-400 control override register to enable barrier * transaction diff --git a/board/freescale/ls1012aqds/ls1012aqds.c b/board/freescale/ls1012aqds/ls1012aqds.c index 97ab340..406194d 100644 --- a/board/freescale/ls1012aqds/ls1012aqds.c +++ b/board/freescale/ls1012aqds/ls1012aqds.c @@ -106,8 +106,8 @@ int misc_init_r(void)
int board_init(void) { - struct ccsr_cci400 *cci = (struct ccsr_cci400 *) - CONFIG_SYS_CCI400_ADDR; + struct ccsr_cci400 *cci = (struct ccsr_cci400 *)(CONFIG_SYS_IMMR + + CONFIG_SYS_CCI400_OFFSET);
/* Set CCI-400 control override register to enable barrier * transaction */ diff --git a/board/freescale/ls1012ardb/ls1012ardb.c b/board/freescale/ls1012ardb/ls1012ardb.c index a21e4c4..c6c1c71 100644 --- a/board/freescale/ls1012ardb/ls1012ardb.c +++ b/board/freescale/ls1012ardb/ls1012ardb.c @@ -104,7 +104,8 @@ int board_early_init_f(void)
int board_init(void) { - struct ccsr_cci400 *cci = (struct ccsr_cci400 *)CONFIG_SYS_CCI400_ADDR; + struct ccsr_cci400 *cci = (struct ccsr_cci400 *)(CONFIG_SYS_IMMR + + CONFIG_SYS_CCI400_OFFSET); /* * Set CCI-400 control override register to enable barrier * transaction diff --git a/board/freescale/ls1021aqds/ls1021aqds.c b/board/freescale/ls1021aqds/ls1021aqds.c index d81d8ab..8b3f4ad 100644 --- a/board/freescale/ls1021aqds/ls1021aqds.c +++ b/board/freescale/ls1021aqds/ls1021aqds.c @@ -204,7 +204,8 @@ int board_early_init_f(void) #ifdef CONFIG_SPL_BUILD void board_init_f(ulong dummy) { - struct ccsr_cci400 *cci = (struct ccsr_cci400 *)CONFIG_SYS_CCI400_ADDR; + struct ccsr_cci400 *cci = (struct ccsr_cci400 *)(CONFIG_SYS_IMMR + + CONFIG_SYS_CCI400_OFFSET); unsigned int major;
#ifdef CONFIG_NAND_BOOT @@ -425,7 +426,8 @@ int misc_init_r(void)
int board_init(void) { - struct ccsr_cci400 *cci = (struct ccsr_cci400 *)CONFIG_SYS_CCI400_ADDR; + struct ccsr_cci400 *cci = (struct ccsr_cci400 *)(CONFIG_SYS_IMMR + + CONFIG_SYS_CCI400_OFFSET); unsigned int major;
#ifdef CONFIG_SYS_FSL_ERRATUM_A010315 @@ -460,7 +462,8 @@ int board_init(void) #if defined(CONFIG_DEEP_SLEEP) void board_sleep_prepare(void) { - struct ccsr_cci400 __iomem *cci = (void *)CONFIG_SYS_CCI400_ADDR; + struct ccsr_cci400 __iomem *cci = (void *)(CONFIG_SYS_IMMR + + CONFIG_SYS_CCI400_OFFSET); unsigned int major;
major = get_soc_major_rev(); diff --git a/include/fsl_immap.h b/include/fsl_immap.h index b1c4fe7..4f5a19c 100644 --- a/include/fsl_immap.h +++ b/include/fsl_immap.h @@ -133,4 +133,55 @@ struct ccsr_ddr { u8 res_e5c[164]; u32 debug[64]; /* debug_1 to debug_64 */ }; + +#ifdef CONFIG_SYS_FSL_HAS_CCI400 +#define CCI400_CTRLORD_TERM_BARRIER 0x00000008 +#define CCI400_CTRLORD_EN_BARRIER 0 +#define CCI400_SHAORD_NON_SHAREABLE 0x00000002 +#define CCI400_DVM_MESSAGE_REQ_EN 0x00000002 +#define CCI400_SNOOP_REQ_EN 0x00000001 + +/* CCI-400 registers */ +struct ccsr_cci400 { + u32 ctrl_ord; /* Control Override */ + u32 spec_ctrl; /* Speculation Control */ + u32 secure_access; /* Secure Access */ + u32 status; /* Status */ + u32 impr_err; /* Imprecise Error */ + u8 res_14[0x100 - 0x14]; + u32 pmcr; /* Performance Monitor Control */ + u8 res_104[0xfd0 - 0x104]; + u32 pid[8]; /* Peripheral ID */ + u32 cid[4]; /* Component ID */ + struct { + u32 snoop_ctrl; /* Snoop Control */ + u32 sha_ord; /* Shareable Override */ + u8 res_1008[0x1100 - 0x1008]; + u32 rc_qos_ord; /* read channel QoS Value Override */ + u32 wc_qos_ord; /* read channel QoS Value Override */ + u8 res_1108[0x110c - 0x1108]; + u32 qos_ctrl; /* QoS Control */ + u32 max_ot; /* Max OT */ + u8 res_1114[0x1130 - 0x1114]; + u32 target_lat; /* Target Latency */ + u32 latency_regu; /* Latency Regulation */ + u32 qos_range; /* QoS Range */ + u8 res_113c[0x2000 - 0x113c]; + } slave[5]; /* Slave Interface */ + u8 res_6000[0x9004 - 0x6000]; + u32 cycle_counter; /* Cycle counter */ + u32 count_ctrl; /* Count Control */ + u32 overflow_status; /* Overflow Flag Status */ + u8 res_9010[0xa000 - 0x9010]; + struct { + u32 event_select; /* Event Select */ + u32 event_count; /* Event Count */ + u32 counter_ctrl; /* Counter Control */ + u32 overflow_status; /* Overflow Flag Status */ + u8 res_a010[0xb000 - 0xa010]; + } pcounter[4]; /* Performance Counter */ + u8 res_e004[0x10000 - 0xe004]; +}; +#endif + #endif /* __FSL_IMMAP_H */
This patch add new CONFIG defination "FSL_SYS_HAS_CCI400" and removes register space definaton of CCI-400 bus from immap_ls102xa to fsl_immap, since same is defined there already
Signed-off-by: Ashish Kumar Ashish.Kumar@nxp.com --- v3: This is v3 for https://patchwork.ozlabs.org/patch/731464/ v4: No change
arch/arm/cpu/armv7/ls102xa/Kconfig | 12 ++++++ arch/arm/cpu/armv7/ls102xa/soc.c | 3 +- arch/arm/include/asm/arch-ls102xa/config.h | 1 - arch/arm/include/asm/arch-ls102xa/immap_ls102xa.h | 49 +---------------------- 4 files changed, 16 insertions(+), 49 deletions(-)
diff --git a/arch/arm/cpu/armv7/ls102xa/Kconfig b/arch/arm/cpu/armv7/ls102xa/Kconfig index 6a013b2..61dd522 100644 --- a/arch/arm/cpu/armv7/ls102xa/Kconfig +++ b/arch/arm/cpu/armv7/ls102xa/Kconfig @@ -5,6 +5,7 @@ config ARCH_LS1021A select SYS_FSL_ERRATUM_A009663 select SYS_FSL_ERRATUM_A009942 select SYS_FSL_ERRATUM_A010315 + select SYS_FSL_HAS_CCI400 select SYS_FSL_SRDS_1 select SYS_HAS_SERDES select SYS_FSL_DDR_BE if SYS_FSL_DDR @@ -48,9 +49,20 @@ config SECURE_BOOT Enable Freescale Secure Boot feature. Normally selected by defconfig. If unsure, do not change.
+config SYS_CCI400_OFFSET + hex "Offset for CCI400 base" + depends on SYS_FSL_HAS_CCI400 + default 0x180000 + help + Offset for CCI400 base. + CCI400 base addr = CCSRBAR + CCI400_OFFSET + config SYS_FSL_ERRATUM_A010315 bool "Workaround for PCIe erratum A010315"
+config SYS_FSL_HAS_CCI400 + bool + config SYS_FSL_SRDS_1 bool
diff --git a/arch/arm/cpu/armv7/ls102xa/soc.c b/arch/arm/cpu/armv7/ls102xa/soc.c index b84a1a6..c043b82 100644 --- a/arch/arm/cpu/armv7/ls102xa/soc.c +++ b/arch/arm/cpu/armv7/ls102xa/soc.c @@ -80,7 +80,8 @@ void erratum_a010315(void) int arch_soc_init(void) { struct ccsr_scfg *scfg = (struct ccsr_scfg *)CONFIG_SYS_FSL_SCFG_ADDR; - struct ccsr_cci400 *cci = (struct ccsr_cci400 *)CONFIG_SYS_CCI400_ADDR; + struct ccsr_cci400 *cci = (struct ccsr_cci400 *)(CONFIG_SYS_IMMR + + CONFIG_SYS_CCI400_OFFSET); unsigned int major;
#ifdef CONFIG_LAYERSCAPE_NS_ACCESS diff --git a/arch/arm/include/asm/arch-ls102xa/config.h b/arch/arm/include/asm/arch-ls102xa/config.h index fc954c5..ff0fc47 100644 --- a/arch/arm/include/asm/arch-ls102xa/config.h +++ b/arch/arm/include/asm/arch-ls102xa/config.h @@ -20,7 +20,6 @@
#define SYS_FSL_GIC_ADDR (CONFIG_SYS_IMMR + 0x00400000) #define CONFIG_SYS_FSL_DDR_ADDR (CONFIG_SYS_IMMR + 0x00080000) -#define CONFIG_SYS_CCI400_ADDR (CONFIG_SYS_IMMR + 0x00180000) #define CONFIG_SYS_FSL_CSU_ADDR (CONFIG_SYS_IMMR + 0x00510000) #define CONFIG_SYS_IFC_ADDR (CONFIG_SYS_IMMR + 0x00530000) #define CONFIG_SYS_FSL_ESDHC_ADDR (CONFIG_SYS_IMMR + 0x00560000) diff --git a/arch/arm/include/asm/arch-ls102xa/immap_ls102xa.h b/arch/arm/include/asm/arch-ls102xa/immap_ls102xa.h index c34fd63..1415b0b 100644 --- a/arch/arm/include/asm/arch-ls102xa/immap_ls102xa.h +++ b/arch/arm/include/asm/arch-ls102xa/immap_ls102xa.h @@ -6,6 +6,7 @@
#ifndef __ASM_ARCH_LS102XA_IMMAP_H_ #define __ASM_ARCH_LS102XA_IMMAP_H_ +#include <fsl_immap.h>
#define SVR_MAJ(svr) (((svr) >> 4) & 0xf) #define SVR_MIN(svr) (((svr) >> 0) & 0xf) @@ -374,53 +375,7 @@ struct ccsr_serdes { u8 res_a00[0x1000-0xa00]; /* from 0xa00 to 0xfff */ };
-#define CCI400_CTRLORD_TERM_BARRIER 0x00000008 -#define CCI400_CTRLORD_EN_BARRIER 0 -#define CCI400_SHAORD_NON_SHAREABLE 0x00000002 -#define CCI400_DVM_MESSAGE_REQ_EN 0x00000002 -#define CCI400_SNOOP_REQ_EN 0x00000001 - -/* CCI-400 registers */ -struct ccsr_cci400 { - u32 ctrl_ord; /* Control Override */ - u32 spec_ctrl; /* Speculation Control */ - u32 secure_access; /* Secure Access */ - u32 status; /* Status */ - u32 impr_err; /* Imprecise Error */ - u8 res_14[0x100 - 0x14]; - u32 pmcr; /* Performance Monitor Control */ - u8 res_104[0xfd0 - 0x104]; - u32 pid[8]; /* Peripheral ID */ - u32 cid[4]; /* Component ID */ - struct { - u32 snoop_ctrl; /* Snoop Control */ - u32 sha_ord; /* Shareable Override */ - u8 res_1008[0x1100 - 0x1008]; - u32 rc_qos_ord; /* read channel QoS Value Override */ - u32 wc_qos_ord; /* read channel QoS Value Override */ - u8 res_1108[0x110c - 0x1108]; - u32 qos_ctrl; /* QoS Control */ - u32 max_ot; /* Max OT */ - u8 res_1114[0x1130 - 0x1114]; - u32 target_lat; /* Target Latency */ - u32 latency_regu; /* Latency Regulation */ - u32 qos_range; /* QoS Range */ - u8 res_113c[0x2000 - 0x113c]; - } slave[5]; /* Slave Interface */ - u8 res_6000[0x9004 - 0x6000]; - u32 cycle_counter; /* Cycle counter */ - u32 count_ctrl; /* Count Control */ - u32 overflow_status; /* Overflow Flag Status */ - u8 res_9010[0xa000 - 0x9010]; - struct { - u32 event_select; /* Event Select */ - u32 event_count; /* Event Count */ - u32 counter_ctrl; /* Counter Control */ - u32 overflow_status; /* Overflow Flag Status */ - u8 res_a010[0xb000 - 0xa010]; - } pcounter[4]; /* Performance Counter */ - u8 res_e004[0x10000 - 0xe004]; -}; +
/* AHCI (sata) register map */ struct ccsr_ahci {
This config is depricated and new config SYS_CCI400_OFFSET is introduced in Kconfig
scripts/config_whitelist.txt | 1 - 1 file changed, 1 deletion(-)
diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index e261d02..c29f8f3 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -2516,7 +2516,6 @@ CONFIG_SYS_CACHE_STASHING CONFIG_SYS_CADMUS_BASE_REG CONFIG_SYS_CBSIZE CONFIG_SYS_CCCR -CONFIG_SYS_CCI400_ADDR CONFIG_SYS_CCSRBAR CONFIG_SYS_CCSRBAR_PHYS CONFIG_SYS_CCSRBAR_PHYS_HIGH
v3: This is v3 for https://emea01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fpatchwork... v4: Header file included in middle of the file in cpu.c
Ashish,
This patch shouldn't include LS1021AQDS. It has ARMv7 core. It should be moved to your 2nd patch. You are breaking all LS1021A board with this patch. Please fix.
York
Ashish Kumar
York Sun
