[U-Boot] [PATCH 1/2] arm: mvebu: fix boot from UART on ClearFog Base
The ClearFog Base boot from UART when setting the DIP switches to 01001. Unfortunately, the SPL code sometimes fails to detect the UART boot method at run-time. Add an alternative SAR UART boot value to fix this.
Signed-off-by: Baruch Siach baruch@tkos.co.il --- arch/arm/mach-mvebu/include/mach/soc.h | 1 + arch/arm/mach-mvebu/spl.c | 1 + 2 files changed, 2 insertions(+)
diff --git a/arch/arm/mach-mvebu/include/mach/soc.h b/arch/arm/mach-mvebu/include/mach/soc.h index 0900e4008c12..44bac63b4447 100644 --- a/arch/arm/mach-mvebu/include/mach/soc.h +++ b/arch/arm/mach-mvebu/include/mach/soc.h @@ -139,6 +139,7 @@ #define BOOT_DEV_SEL_MASK (0x3f << BOOT_DEV_SEL_OFFS)
#define BOOT_FROM_UART 0x28 +#define BOOT_FROM_UART_ALT 0x3f #define BOOT_FROM_SPI 0x32 #define BOOT_FROM_MMC 0x30 #define BOOT_FROM_MMC_ALT 0x31 diff --git a/arch/arm/mach-mvebu/spl.c b/arch/arm/mach-mvebu/spl.c index 3cf02a54cea2..4b9c41360589 100644 --- a/arch/arm/mach-mvebu/spl.c +++ b/arch/arm/mach-mvebu/spl.c @@ -42,6 +42,7 @@ static u32 get_boot_device(void) return BOOT_DEVICE_MMC1; #endif case BOOT_FROM_UART: + case BOOT_FROM_UART_ALT: return BOOT_DEVICE_UART; case BOOT_FROM_SPI: default:
Signed-off-by: Baruch Siach baruch@tkos.co.il --- board/solidrun/clearfog/README | 20 ++++++++++++++++++++ 1 file changed, 20 insertions(+)
diff --git a/board/solidrun/clearfog/README b/board/solidrun/clearfog/README index 2cfa5bfc8637..ef1e3bf42666 100644 --- a/board/solidrun/clearfog/README +++ b/board/solidrun/clearfog/README @@ -16,3 +16,23 @@ $ sudo dd if=u-boot-spl.kwb of=/dev/sdX bs=512 seek=1
Please use the correct device node for your setup instead of "/dev/sdX" here! + +Boot from UART: +--------------- + +Connect the on-board micro-USB (CF Pro: CON11, CF Base: CON5) +to your host. + +Set the SW1 DIP switches to UART boot (0: OFF, 1: ON): + + ClearFog Base: 01001 + ClearFog Pro: 11110 + +Run the following command to initiate U-Boot download: + + ./tools/kwboot -b u-boot-spl.kwb /dev/ttyUSBX + +Use the correct UART device node for /dev/ttyUSBX. + +When download finishes start your favorite terminal emulator +on /dev/ttyUSBX.
Hi Baruch,
- case BOOT_FROM_UART_ALT: return BOOT_DEVICE_UART; case BOOT_FROM_SPI: default:
This patch produces this error for some MVEBU boards:
[stefan@stefan-work u-boot-marvell (master)]$ make db-mv784mp-gp_defconfig HOSTCC scripts/basic/fixdep HOSTCC scripts/kconfig/conf.o SHIPPED scripts/kconfig/zconf.tab.c SHIPPED scripts/kconfig/zconf.lex.c SHIPPED scripts/kconfig/zconf.hash.c HOSTCC scripts/kconfig/zconf.tab.o HOSTLD scripts/kconfig/conf # # configuration written to .config # [stefan@stefan-work u-boot-marvell (master)]$ make -s -j10 arch/arm/mach-mvebu/spl.c: In function ‘get_boot_device’: arch/arm/mach-mvebu/spl.c:45:7: error: ‘BOOT_FROM_UART_ALT’ undeclared (first use in this function) case BOOT_FROM_UART_ALT: ^~~~~~~~~~~~~~~~~~ arch/arm/mach-mvebu/spl.c:45:7: note: each undeclared identifier is reported only once for each function it appears in scripts/Makefile.build:280: recipe for target 'spl/arch/arm/mach-mvebu/spl.o' failed
Could you please fix this by either adding this UART_ALT for other MVEBUs as well (AXP, I didn't check if its available), or restricting its usage on the A38x?
Please make sure that future patches are compile clean for at least all MVEBU targets.
Thanks, Stefan
Hi Stefan,
Sorry about that.
How about:
#ifdef BOOT_FROM_UART_ALT case BOOT_FROM_UART_ALT: #endif return BOOT_DEVICE_UART;
Will do.
Thanks for testing and reviewing.
baruch
Hi Baruch,
Sorry about that.
How about:
If there is no such "alternative UART" for the other MVEBU SoCs (did you check this btw?), then this is most likely the best solution.
Please resubmit v2 and I'll apply soon.
Thanks, Stefan
Hi Stefan,
diff --git a/arch/arm/mach-mvebu/include/mach/soc.h b/arch/arm/mach-mvebu/include/mach/soc.h index 0900e4008c12..44bac63b4447 100644 --- a/arch/arm/mach-mvebu/include/mach/soc.h +++ b/arch/arm/mach-mvebu/include/mach/soc.h @@ -139,6 +139,7 @@ #define BOOT_DEV_SEL_MASK (0x3f << BOOT_DEV_SEL_OFFS) #define BOOT_FROM_UART 0x28 +#define BOOT_FROM_UART_ALT 0x3f #define BOOT_FROM_SPI 0x32 #define BOOT_FROM_MMC 0x30 #define BOOT_FROM_MMC_ALT 0x31 diff --git a/arch/arm/mach-mvebu/spl.c b/arch/arm/mach-mvebu/spl.c index 3cf02a54cea2..4b9c41360589 100644 --- a/arch/arm/mach-mvebu/spl.c +++ b/arch/arm/mach-mvebu/spl.c @@ -42,6 +42,7 @@ static u32 get_boot_device(void) return BOOT_DEVICE_MMC1; #endif case BOOT_FROM_UART:
Sorry about that.
How about:
The relevant documentation appears to be table 48 in §7.5.1 of the 38x Hardware Specification. Unfortunately, the 0x3f value for the Boot Mode Select field is not documented there. I only found it in experimentation.
Will do after some more build and run-time testing.
baruch
Baruch Siach
Stefan Roese
