[PATCH] riscv: Fix ax25-ae350 and qemu-riscv Kconfig dependency
SPL_RAM_SUPPORT and SPL_RAM_DEVICE are only visible in an SPL config.
Reported-by: Heinrich Schuchardt xypron.glpk@gmx.de Signed-off-by: Bin Meng bin.meng@windriver.com --- This patch should be applied after the following one: http://patchwork.ozlabs.org/project/uboot/patch/20201104114901.9420-2-xypron...
board/AndesTech/ax25-ae350/Kconfig | 4 ++-- board/emulation/qemu-riscv/Kconfig | 4 ++-- 2 files changed, 4 insertions(+), 4 deletions(-)
diff --git a/board/AndesTech/ax25-ae350/Kconfig b/board/AndesTech/ax25-ae350/Kconfig index 321dd0c..2491e26 100644 --- a/board/AndesTech/ax25-ae350/Kconfig +++ b/board/AndesTech/ax25-ae350/Kconfig @@ -32,7 +32,7 @@ config BOARD_SPECIFIC_OPTIONS # dummy select RISCV_NDS select SUPPORT_SPL imply SMP - imply SPL_RAM_SUPPORT - imply SPL_RAM_DEVICE + imply SPL_RAM_SUPPORT if SPL + imply SPL_RAM_DEVICE if SPL
endif diff --git a/board/emulation/qemu-riscv/Kconfig b/board/emulation/qemu-riscv/Kconfig index 0818048..71ce2e5 100644 --- a/board/emulation/qemu-riscv/Kconfig +++ b/board/emulation/qemu-riscv/Kconfig @@ -33,8 +33,8 @@ config BOARD_SPECIFIC_OPTIONS # dummy imply SMP imply BOARD_LATE_INIT imply PCI_INIT_R - imply SPL_RAM_SUPPORT - imply SPL_RAM_DEVICE + imply SPL_RAM_SUPPORT if SPL + imply SPL_RAM_DEVICE if SPL imply CMD_PCI imply CMD_POWEROFF imply CMD_SCSI
On Thu, Nov 5, 2020 at 4:16 PM Bin Meng bmeng.cn@gmail.com wrote:>
+Heinrich Schuchardt in CC
Regards, Bin
'if SPL' would only be required if you would use 'select'. With 'imply' the Kconfig build system takes care of this dependency.
My question was about CONFIG_RAM which is not selected on QEMU. But of cause you do not need a RAM driver on QEMU.
So I think you can drop this patch.
Best regards
Heinrich
- imply SPL_RAM_SUPPORT if SPL
- imply SPL_RAM_DEVICE if SPL
- imply SPL_RAM_DEVICE if SPL imply CMD_PCI imply CMD_POWEROFF imply CMD_SCSI
Hi Heinrich,
On Thu, Nov 5, 2020 at 4:55 PM Heinrich Schuchardt xypron.debian@gmx.de wrote:
Yes, but I feel that adding a "if" seems to be express the dependency explicitly to avoid confusions.
Correct.
I am fine to drop this if there is no concern.
Regards, Bin
Bin Meng
