[PATCH v10 00/10] Enable EFI capsule generation through binman
This patch series adds support for generation of EFI capsules as part of U-Boot build flow. The capsules can be generated as part of U-Boot build, and this is being achieved through binman, by adding a capsule entry type. The parameters needed for capsule generation are specified as properties under the capsule entry node.
Changes have also been made to the efi capsule update feature testing setup on the sandbox variants. Currently, the capsule files and the keys for testing capsule authentication are generated after U-Boot has been built. As part of this patch series, the private and public keys along with the EFI Signature List(ESL) needed for testing the capsule update functionality on the sandbox plaform are placed in the board directory. The test logic has been changed so that the capsules which were generated as part of the test setup are now being generated as part of the build for sandbox platform. The document has been updated to reflect the above changes.
Changes since V9: * s/u-boot/U-Boot/ * Add a link to the binman capsule entry type documentation as suggested by Simon Glass.
Sughosh Ganu (10): binman: bintool: Build a tool from a list of commands nuvoton: npcm845-evb: Add a newline at the end of file sandbox: capsule: Add keys and certificates needed for capsule update testing sandbox: capsule: Enable EFI capsule module on sandbox variants btool: mkeficapsule: Add a bintool for EFI capsule generation binman: capsule: Add support for generating EFI capsules sandbox: binman: Add support for generating multiple images sandbox: capsule: Generate capsule related files through binman doc: Add documentation to highlight capsule generation related updates sandbox: trace: Increase trace buffer size
.azure-pipelines.yml | 2 +- .gitlab-ci.yml | 2 +- arch/arm/dts/nuvoton-npcm845-evb.dts | 2 +- arch/sandbox/dts/sandbox.dts | 3 + arch/sandbox/dts/sandbox_capsule.dtsi | 315 ++++++++++++++++++ arch/sandbox/dts/sandbox_vpl.dtsi | 5 + arch/sandbox/dts/test.dts | 3 + board/sandbox/capsule_priv_key_bad.key | 28 ++ board/sandbox/capsule_priv_key_good.key | 28 ++ board/sandbox/capsule_pub_esl_good.esl | Bin 0 -> 831 bytes board/sandbox/capsule_pub_key_bad.crt | 19 ++ board/sandbox/capsule_pub_key_good.crt | 19 ++ configs/sandbox_noinst_defconfig | 2 + configs/sandbox_spl_defconfig | 2 + configs/sandbox_vpl_defconfig | 2 + doc/develop/uefi/uefi.rst | 17 + include/sandbox_efi_capsule.h | 21 ++ test/py/tests/test_efi_capsule/conftest.py | 155 +-------- .../tests/test_efi_capsule/uboot_bin_env.its | 36 -- test/py/tests/test_trace.py | 2 +- tools/binman/bintool.py | 19 +- tools/binman/btool/mkeficapsule.py | 101 ++++++ tools/binman/entries.rst | 64 ++++ tools/binman/etype/efi_capsule.py | 143 ++++++++ tools/binman/ftest.py | 118 +++++++ tools/binman/test/311_capsule.dts | 21 ++ tools/binman/test/312_capsule_signed.dts | 23 ++ tools/binman/test/313_capsule_version.dts | 22 ++ tools/binman/test/314_capsule_signed_ver.dts | 24 ++ tools/binman/test/315_capsule_oemflags.dts | 22 ++ tools/binman/test/316_capsule_missing_key.dts | 22 ++ .../binman/test/317_capsule_missing_index.dts | 20 ++ .../binman/test/318_capsule_missing_guid.dts | 19 ++ 33 files changed, 1094 insertions(+), 187 deletions(-) create mode 100644 arch/sandbox/dts/sandbox_capsule.dtsi create mode 100644 board/sandbox/capsule_priv_key_bad.key create mode 100644 board/sandbox/capsule_priv_key_good.key create mode 100644 board/sandbox/capsule_pub_esl_good.esl create mode 100644 board/sandbox/capsule_pub_key_bad.crt create mode 100644 board/sandbox/capsule_pub_key_good.crt create mode 100644 include/sandbox_efi_capsule.h delete mode 100644 test/py/tests/test_efi_capsule/uboot_bin_env.its create mode 100644 tools/binman/btool/mkeficapsule.py create mode 100644 tools/binman/etype/efi_capsule.py create mode 100644 tools/binman/test/311_capsule.dts create mode 100644 tools/binman/test/312_capsule_signed.dts create mode 100644 tools/binman/test/313_capsule_version.dts create mode 100644 tools/binman/test/314_capsule_signed_ver.dts create mode 100644 tools/binman/test/315_capsule_oemflags.dts create mode 100644 tools/binman/test/316_capsule_missing_key.dts create mode 100644 tools/binman/test/317_capsule_missing_index.dts create mode 100644 tools/binman/test/318_capsule_missing_guid.dts
Add support to build a tool from source with a list of commands. This is useful when a tool can be built with multiple commands instead of a single command.
Signed-off-by: Sughosh Ganu sughosh.ganu@linaro.org Reviewed-by: Simon Glass sjg@chromium.org --- Changes since V9: None
tools/binman/bintool.py | 19 +++++++++++-------- 1 file changed, 11 insertions(+), 8 deletions(-)
diff --git a/tools/binman/bintool.py b/tools/binman/bintool.py index 0b0f56dbbb..3c4ad1adbb 100644 --- a/tools/binman/bintool.py +++ b/tools/binman/bintool.py @@ -328,7 +328,7 @@ class Bintool: return result.stdout
@classmethod - def build_from_git(cls, git_repo, make_target, bintool_path, flags=None): + def build_from_git(cls, git_repo, make_targets, bintool_path, flags=None): """Build a bintool from a git repo
This clones the repo in a temporary directory, builds it with 'make', @@ -336,7 +336,8 @@ class Bintool:
Args: git_repo (str): URL of git repo - make_target (str): Target to pass to 'make' to build the tool + make_targets (list of str): List of targets to pass to 'make' to build + the tool bintool_path (str): Relative path of the tool in the repo, after build is complete flags (list of str): Flags or variables to pass to make, or None @@ -350,12 +351,14 @@ class Bintool: tmpdir = tempfile.mkdtemp(prefix='binmanf.') print(f"- clone git repo '{git_repo}' to '{tmpdir}'") tools.run('git', 'clone', '--depth', '1', git_repo, tmpdir) - print(f"- build target '{make_target}'") - cmd = ['make', '-C', tmpdir, '-j', f'{multiprocessing.cpu_count()}', - make_target] - if flags: - cmd += flags - tools.run(*cmd) + for target in make_targets: + print(f"- build target '{target}'") + cmd = ['make', '-C', tmpdir, '-j', f'{multiprocessing.cpu_count()}', + target] + if flags: + cmd += flags + tools.run(*cmd) + fname = os.path.join(tmpdir, bintool_path) if not os.path.exists(fname): print(f"- File '{fname}' was not produced")
Add a newline at the end of the dts, without which the build fails when including a dtsi file.
Signed-off-by: Sughosh Ganu sughosh.ganu@linaro.org Reviewed-by: Simon Glass sjg@chromium.org Reviewed-by: Ilias Apalodimas ilias.apalodimas@linaro.org --- Changes since V9: None
arch/arm/dts/nuvoton-npcm845-evb.dts | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/dts/nuvoton-npcm845-evb.dts b/arch/arm/dts/nuvoton-npcm845-evb.dts index 3cab7807e3..a93666cb41 100644 --- a/arch/arm/dts/nuvoton-npcm845-evb.dts +++ b/arch/arm/dts/nuvoton-npcm845-evb.dts @@ -354,4 +354,4 @@ &r1en_pins &r1oen_pins >; -}; \ No newline at end of file +};
Add the private keys and public key certificates which are to be used for capsule authentication while testing the EFI capsule update functionality. There are two pairs of private and public keys, good and bad. The good key pair will be used for signing capsules, whilst the bad key pair is to be used as malicious keys for testing authentication failure cases. The capsule_pub_key_good.crt is also converted to an EFI Signature List(ESL) file, SIGNER.esl, which is embedded in the platform's device-tree for capsule authentication.
board/sandbox/capsule_priv_key_bad.key | 28 ++++++++++++++++++++++++ board/sandbox/capsule_priv_key_good.key | 28 ++++++++++++++++++++++++ board/sandbox/capsule_pub_esl_good.esl | Bin 0 -> 831 bytes board/sandbox/capsule_pub_key_bad.crt | 19 ++++++++++++++++ board/sandbox/capsule_pub_key_good.crt | 19 ++++++++++++++++ 5 files changed, 94 insertions(+) create mode 100644 board/sandbox/capsule_priv_key_bad.key create mode 100644 board/sandbox/capsule_priv_key_good.key create mode 100644 board/sandbox/capsule_pub_esl_good.esl create mode 100644 board/sandbox/capsule_pub_key_bad.crt create mode 100644 board/sandbox/capsule_pub_key_good.crt
diff --git a/board/sandbox/capsule_priv_key_bad.key b/board/sandbox/capsule_priv_key_bad.key new file mode 100644 index 0000000000..2324f69ebd --- /dev/null +++ b/board/sandbox/capsule_priv_key_bad.key @@ -0,0 +1,28 @@ +-----BEGIN PRIVATE KEY----- +MIIEvQIBADANBgkqhkiG9w0BAQEFAASCBKcwggSjAgEAAoIBAQCmPw1pGd2xNW0p +lesRXkkek3uwUB06Nt61tnZvpMkBKt4IokqGWz1tZls+Z2CqvwOfcsPZ27cPRYSu +xRnM3YdL4MG6SePV7i/YSNw3rq8CP8zLGtCbNIfsfsNfPQEtPBpw6+7pMJKhjqpV +2U2UQzZEiX4qlnhLpyv2JNJag27yf0feLdJi7HnJ9xdvcXpA1DSGm4y+DDhgYeI8 +DEteEu6s0TYQfnOZSQOeJi+1/Qz0S594uFJB37MyGh/mB15ILb8gva4nA3ayHOBK +0dd+HSiUCGYrLYO7aj+nfzQj9N1qTlzCnC1603bMczU5pkwcODg6xP0Sn11J6RYy +y0c0qzJLAgMBAAECggEABDY2MLoew3IkBltrParAWAUUcFLi95jw92q6BkOHEJg8 +2qia1yCitPUtPodMLmOKF5x4EdgXg5sv2O8MGbWP1VtUKXGh3QJcnRnNmsZ1hXJC +RBcrei2aVLsqf0V2Mg3+GuG8PW3vLWHyZ/Sd6afeuXEYm2Bzrw9J5rfd3dBVKm7f +HBvIyy1ATO/2cbUaEaCLOyhxLhssTI2TIK5SjlsjFLxiQXEi6RyGfBxUCriKZykS +krMdvYh7Tf0uYcv0STmQ5s5Rd+RhRIGCVAdsNBxxJjgBAgqqa/B+kWbcc6o2D41n +yWjErUaBBx3t0A7oT4K4DSTYwMNDVY3fhdd+szsocQKBgQDjnm8LG4UO6OQDm6iX +0vTQTItoAz5TU6GEjHTCfVEqiupD4LKfHhSXwp2hRyzxXO5oNTU9MQCzYd7Npes0 +oVk4Tjo3YDacNPgxqKjODu/Q+tkTH15ydzGr674+YXHfCA1uT5GKOiiF0H1FZgMa +Dk0s+3uWX34vbL4QCu97bUhBewKBgQC6+Z0J9sClgWvvjkglJN3XhRnAacp+WgX7 +bkpgSboXIIsqeqhd1WCLeV7L1pcZgifYBMPojf5LTBqBedL1q3RuqiqQWD/bSIYN +Oc9KCdTjksS8Zo+w+s5zDObDhW9y13H2mKwDqilYBrT4fiA62wPMf1SjEF+RSC6K +ZrQzHO1xcQKBgAILsXnLFIYOx8XUh05eAf9BQNt9c/jxvnjffkklMS6Nsw9LHK/b +aFn40MvbROcia64aFFFpeFUkYwk8HYIKlS+xXEqVHciHnVds6Z94eOVK69qFJKco +tRSTeNE8tPZJLz23j1pLrYOOXSHbidmZGU53MCQo1Yx9kLO6NW7Ji6WzAoGBALP4 +lEoE80Xbn3NEdvkZ1VcfzLvCmKCqMlvjuz+Xd8HPF2VaDznSq01VFAQMmAB7obJy +U8hC9OSxakn6Yy8JS9dBgBrUdxKxaibM4FQZxosOuMPHzMPDhniDkJPemnnmGtIL +/nbAkW8jdYpCjO9Z5PwwC92xYuvKmNGrLgSM8ZhhAoGAfgSZTpASXubM18E3ecfw +5z333wf9qEQgZj7i9MzByFZudyHUhv/FPW1ocUJf36Wu1dfofZg3noSL6oakrm2v +dFDo4PoyCStuF0w9SSzpIld01ZG0t7XqphY0DmshCXIXsqr7Vb4WrbBI7KX+b3Um +BzmROfaSud97NjQ/RA26OZk= +-----END PRIVATE KEY----- diff --git a/board/sandbox/capsule_priv_key_good.key b/board/sandbox/capsule_priv_key_good.key new file mode 100644 index 0000000000..9a37f59796 --- /dev/null +++ b/board/sandbox/capsule_priv_key_good.key @@ -0,0 +1,28 @@ +-----BEGIN PRIVATE KEY----- +MIIEvQIBADANBgkqhkiG9w0BAQEFAASCBKcwggSjAgEAAoIBAQCwBfaV0P1jRzS6 +13U1T+4VbuMVsxFXhwHJY5z5Fx6v+cWBf3K1ruK+7cEnW55ZHXvNE2JCkjMvISKm +hI/DLJWIPnAus8tFdU/R2u5oJbKI+b6GbuamO/CG9HsXZ58lOC6r2ckjixxovsA9 +SFshccdIv2YrwiVsWeyFpH+rB3/+cFbrgdWpaUc1367GkU/ZCnSRDBvVvzRRI1a4 +y2NogFqbZHXHENpzWNJ3TTXhf9dwM5HFGkmX7SA43Dtazae6CB4EaUKzLYWj3+ae +AQbdvBrupKZQz1PUKn7X6+BGaLujHthvibYppNegPvqbJ1xBbv59CQK+lRULwC05 +NYw5+sIxAgMBAAECggEAHn8h/knjpMAw/BAZP//VrYP1Nwy7u/Dpl9U43JUrXWzG +Uc3dd2nR4id6GBIRCLqJePnbQ9JlqMwyXyxHZhbC34SF1imTVbjh9+dY99VULdQr +NMphDrsCzLbt3pu24HFv8Jk+dniDFwi5cMSo+U3nq4xxrLIp3rBjwLHD5sNZYyEU +9xZnj7ziTn5X8da8iRxNpyzz2kQeVemJ0ahr/IkX718bkakSFMesGkln06vH7rAs +069SeqOPrFEbWYXI5iMktLugl3JZpzasRE48j0M42PuProgvT7jb8B35ZF7kn0jT +MqTIHglsJRWcSY0fAb2lHSAvd2vLLVunxr9PDWZvGQKBgQDVzVTuvo1CrVrQLy+B +tpy2k5mjR3qxAOcoWTnKcMErLe8imWWaxukODenP4XqQIX4Sl+X3BXxOqun0Klap +FEsI7TWSHf0eULFtFj0SCgqfRR+V/nblP05eO2nFXgr5YdNa1bWf/aMHplBo4q9e +bbAr4InUB7IGWL2cWjhOhWuJbQKBgQDSw81cBM+vGPUYH/wlxlTVgZCo2Dg2NHjt +LUBqvOZNr21j2F+w8t1vKmqwhkqpc5HIi3pHjEA5gZLTRtmf4GQyo973I6MGn4bS +eayOd6/+FkAi9DUD+WaF7yctJqeevav6KF2UCiz78OtCAU5Y9jFFJpuOANIztI7m +t7ZCUpMFVQKBgFnAsP7oj3SGQbFTnaXeeztKCx04TJExx9hwXIpXe0AdMF5d9wFa +r0tvG9Bg34rSBJLZoXhpnR2JMl2FyIuCMV219t84J6IqTdF1nH2OKZdi9TeKc28Z +fFSirGxmZkT6hDeFr5FScLYtY2QkhWomseY5hKK1+E4hwrd4SFruN46hAoGBAJgh +nzTBgEtqH1enlrCJhSiLmihV0dVGcNb559pjuXTvoG0GfKPT2gPowRPkCzZe5ia0 +jrHgSWd44MtCA8nEBW8MG9+VyJH6Si3Yh7ZaLB2iX+8bCL1yow8f/c44bZtGW0F5 +K3q1EZ1VW+rL2IqcQhog8P1CGHgb514f0x3yTo71AoGACGdb+Nb6lg8OSJPUcuuH +xsWk6RhkJl9bldTleS+QT3R9zO3FvbTwnCCYJboh5Cq/jVmiA7T+fcVAyEJNHSdm +hxbHdScuiJdNWL9+FczOkylnKH3VEdG3RS5lGdyi6r+miTMs3h8WfzGp4JINysjg +PUFskK36qGjASfkRUn0hizQ= +-----END PRIVATE KEY----- diff --git a/board/sandbox/capsule_pub_esl_good.esl b/board/sandbox/capsule_pub_esl_good.esl new file mode 100644 index 0000000000000000000000000000000000000000..f8cc272309b2f80113c29e22bc9fdd5c767b4667 GIT binary patch literal 831 zcmZ1&d0^?2Da*aux2_hA(f&|m&&&V@%1|1@gOCPI%=`vTjNcb9GchtTi3D3+YdNud z!N;6d=3f<&F-6ONS4$i4vT<s)d9;1!Wn|=LWiSvk6fqEDV-96u=HU);4GxJ9_H_4i z4Kh#==QT1murM$&v@kF?F^ZDlH#RUZHZ(9Wg9_l(*~F-XYzZSP19KB2KLgNRTue=j zj0_uCzfHaHH`(1}*Y#3U|97H!k3}~NhPN}GOrG;oTyFi(qmA`NTh~3>_x7NA^t?#f z>a)U0PLquF6_u8?^dHul+F@6qxB0YdssF`W?=n<3b^P4dmiKI#^@p}E)#B;%RW0;Z z-#n?@Et9eDfUQTgV&QR*{b|~VRC6NVv@WS%&0hbnAnbMH)s>m<ruWw!o9KU&t7IaN z^ws?)fy!Y!PA6wHM9oeqJuYyoIO0;duj#}3>jlOWk4kw?f2&||$2#il@?9KqESXN5 zbz2wTe>RVi?d~3_cT1K9oDaUDRd@aM1GkLbi{)<QcW%>Ma(#i_ui5G`j(PuTIhpoN z73DslYiZhJ`RkA&6Eh<N<Kke0Km%D|xXbdfh_Q&secT;;BI`VRLX*$F#X3)yTwnIl z%Rn9^t;`}}Al86g0Y6BAFeBrC7FGjhAcY+4z_<klJ0n9-ZF-^Byx1)aGPkZ;M8@iK z@4h6QYApWke51U4vh|)B+RHfwcQh8f`Fd8-Ad#bU?mv#SCl^~!ojUbKMpn)-Kd>zH z-bULy5-~dZsg>zZPS-w(zNM;c<#N4ar|5@t2FY2AoF7{4IWYI(=HR-Vl;VtSQGM$z zG&LhNEwesN5|ez&@#Le<mt%k4Ngp{`oU3!I!!G(r+O78=mGAf;yBNLt_LaVmLHB2w zF3Vp(*($;GmPMkjzjWQf=x-~Qozl?NwEilS|Lo7%xGP$f^Riek&1Q@!w>qJ9NJDsL xX})Fc$L0Fj-&QP|CD!3Bu=aCF<a-t|<@nrhQ$HQy*tL7JV9T^r#)tp!0|2#rO&9<G
literal 0 HcmV?d00001
diff --git a/board/sandbox/capsule_pub_key_bad.crt b/board/sandbox/capsule_pub_key_bad.crt new file mode 100644 index 0000000000..2e8e5d5828 --- /dev/null +++ b/board/sandbox/capsule_pub_key_bad.crt @@ -0,0 +1,19 @@ +-----BEGIN CERTIFICATE----- +MIIDDzCCAfegAwIBAgIUWw3vHYnrjoHUXytxSm2eYWzbYVAwDQYJKoZIhvcNAQEL +BQAwFjEUMBIGA1UEAwwLVEVTVF9TSUdORVIwIBcNMjMwODA0MTgwODEyWhgPMzAw +MzEwMDYxODA4MTJaMBYxFDASBgNVBAMMC1RFU1RfU0lHTkVSMIIBIjANBgkqhkiG +9w0BAQEFAAOCAQ8AMIIBCgKCAQEApj8NaRndsTVtKZXrEV5JHpN7sFAdOjbetbZ2 +b6TJASreCKJKhls9bWZbPmdgqr8Dn3LD2du3D0WErsUZzN2HS+DBuknj1e4v2Ejc +N66vAj/MyxrQmzSH7H7DXz0BLTwacOvu6TCSoY6qVdlNlEM2RIl+KpZ4S6cr9iTS +WoNu8n9H3i3SYux5yfcXb3F6QNQ0hpuMvgw4YGHiPAxLXhLurNE2EH5zmUkDniYv +tf0M9EufeLhSQd+zMhof5gdeSC2/IL2uJwN2shzgStHXfh0olAhmKy2Du2o/p380 +I/Tdak5cwpwtetN2zHM1OaZMHDg4OsT9Ep9dSekWMstHNKsySwIDAQABo1MwUTAd +BgNVHQ4EFgQUm9b8SnF811nweXSfGisfpzUHGwgwHwYDVR0jBBgwFoAUm9b8SnF8 +11nweXSfGisfpzUHGwgwDwYDVR0TAQH/BAUwAwEB/zANBgkqhkiG9w0BAQsFAAOC +AQEAaOZFOcQzF1MRekcBmIZMaHSWYxOUrVLzBNSNhFD8muYiUAAufrkyTUq0Mmat +w5hAnJ34VGpU1wxQlr/uwH7wpZZnGuj10rAp3tqES0g24AeH1bC9wmRs+rD6dcZR +YmZq6FxtV7Cv3pQX7lhDYbcBj2za3YT6I1+yczskAHR6KYYuJzKJ7XRVCL7ZlYRX +pUMZBQq2eAVWlW/c5iDT3KoGZUD9Of71F7qyUAqMMYafeDxguDz7gKstoXVCklQ+ +I4C7JKmRbrRvMgXx6O1clGhAsRZ0nNAtzi7XT5tD27qFwIPgwv48RWgsmPtzE03S +YGQ5WhYMdHOOjWmcV6MDkCpiSA== +-----END CERTIFICATE----- diff --git a/board/sandbox/capsule_pub_key_good.crt b/board/sandbox/capsule_pub_key_good.crt new file mode 100644 index 0000000000..82d8576a64 --- /dev/null +++ b/board/sandbox/capsule_pub_key_good.crt @@ -0,0 +1,19 @@ +-----BEGIN CERTIFICATE----- +MIIDDzCCAfegAwIBAgIUUzrWhMi7oPFshQP6eFlccqf7exswDQYJKoZIhvcNAQEL +BQAwFjEUMBIGA1UEAwwLVEVTVF9TSUdORVIwIBcNMjMwODA0MTgwNzQyWhgPMzAw +MzEwMDYxODA3NDJaMBYxFDASBgNVBAMMC1RFU1RfU0lHTkVSMIIBIjANBgkqhkiG +9w0BAQEFAAOCAQ8AMIIBCgKCAQEAsAX2ldD9Y0c0utd1NU/uFW7jFbMRV4cByWOc ++Rcer/nFgX9yta7ivu3BJ1ueWR17zRNiQpIzLyEipoSPwyyViD5wLrPLRXVP0dru +aCWyiPm+hm7mpjvwhvR7F2efJTguq9nJI4scaL7APUhbIXHHSL9mK8IlbFnshaR/ +qwd//nBW64HVqWlHNd+uxpFP2Qp0kQwb1b80USNWuMtjaIBam2R1xxDac1jSd001 +4X/XcDORxRpJl+0gONw7Ws2nuggeBGlCsy2Fo9/mngEG3bwa7qSmUM9T1Cp+1+vg +Rmi7ox7Yb4m2KaTXoD76mydcQW7+fQkCvpUVC8AtOTWMOfrCMQIDAQABo1MwUTAd +BgNVHQ4EFgQUHvG7Xchqzwdggky+oyzlpNem8UowHwYDVR0jBBgwFoAUHvG7Xchq +zwdggky+oyzlpNem8UowDwYDVR0TAQH/BAUwAwEB/zANBgkqhkiG9w0BAQsFAAOC +AQEAUn1ncSqeXbQAHNrVOFldLwu70hNlMxf2z4EfH2M7vJgrpwkRuIFw7PXNITBh +CImd/ghm5NGFysrK7BwdHkFvUXZV3rE93BhcLC9leWfky33kW9olIzpE14i5FfBn +ABmaokPhOrzAneGzU35sZHNotlqOrzgpKVkpOWrykhYZ5Qjk8Sz0xvzuG8TJc20s +2og+W8Rm2u/xI9xPxtFbq9vUjvFS35o1pm+vkzpgNdo4YS1PG37BW/aopsooLSk7 +9Rxv5vzNXtQqeZ5qBdKbAVh3OsgqwigTmXVvOX3xpy9r9qiimhaISxCt83RZ7wQW +I19t9pXyxAi6u7MRhJZlAeH/3w== +-----END CERTIFICATE-----
Enable the EFI capsule update code on all sandbox variants. This was already enabled on the sandbox, sandbox64 and sandbox_flattree variants. The rest of the variants also have the EFI capsule update module enabled now. With this commit, the mkeficapsule tool also gets enabled on all variants.
configs/sandbox_noinst_defconfig | 2 ++ configs/sandbox_spl_defconfig | 2 ++ configs/sandbox_vpl_defconfig | 2 ++ 3 files changed, 6 insertions(+)
diff --git a/configs/sandbox_noinst_defconfig b/configs/sandbox_noinst_defconfig index 2c6aab6c85..e202ffccd2 100644 --- a/configs/sandbox_noinst_defconfig +++ b/configs/sandbox_noinst_defconfig @@ -237,6 +237,8 @@ CONFIG_TPM=y CONFIG_LZ4=y CONFIG_ZSTD=y CONFIG_ERRNO_STR=y +CONFIG_EFI_CAPSULE_ON_DISK=y +CONFIG_EFI_CAPSULE_FIRMWARE_RAW=y CONFIG_UNIT_TEST=y CONFIG_SPL_UNIT_TEST=y CONFIG_UT_TIME=y diff --git a/configs/sandbox_spl_defconfig b/configs/sandbox_spl_defconfig index 8d50162b27..25a21b8493 100644 --- a/configs/sandbox_spl_defconfig +++ b/configs/sandbox_spl_defconfig @@ -245,6 +245,8 @@ CONFIG_LZ4=y CONFIG_ZSTD=y CONFIG_ERRNO_STR=y CONFIG_SPL_HEXDUMP=y +CONFIG_EFI_CAPSULE_ON_DISK=y +CONFIG_EFI_CAPSULE_FIRMWARE_RAW=y CONFIG_UNIT_TEST=y CONFIG_SPL_UNIT_TEST=y CONFIG_UT_TIME=y diff --git a/configs/sandbox_vpl_defconfig b/configs/sandbox_vpl_defconfig index f3a0fd19a9..a9a7136ce7 100644 --- a/configs/sandbox_vpl_defconfig +++ b/configs/sandbox_vpl_defconfig @@ -256,6 +256,8 @@ CONFIG_LZ4=y CONFIG_ZSTD=y # CONFIG_VPL_LZMA is not set CONFIG_ERRNO_STR=y +CONFIG_EFI_CAPSULE_ON_DISK=y +CONFIG_EFI_CAPSULE_FIRMWARE_RAW=y CONFIG_UNIT_TEST=y CONFIG_SPL_UNIT_TEST=y CONFIG_UT_TIME=y
Add a bintool for generating EFI capsules. This calls the mkeficapsule tool which generates the capsules.
tools/binman/btool/mkeficapsule.py | 101 +++++++++++++++++++++++++++++ 1 file changed, 101 insertions(+) create mode 100644 tools/binman/btool/mkeficapsule.py
diff --git a/tools/binman/btool/mkeficapsule.py b/tools/binman/btool/mkeficapsule.py new file mode 100644 index 0000000000..61179747ff --- /dev/null +++ b/tools/binman/btool/mkeficapsule.py @@ -0,0 +1,101 @@ +# SPDX-License-Identifier: GPL-2.0+ +# Copyright 2023 Linaro Limited +# +"""Bintool implementation for mkeficapsule tool + +mkeficapsule is a tool used for generating EFI capsules. + +The following are the commandline options to be provided +to the tool +Usage: mkeficapsule [options] <image blob> <output file> +Options: + -g, --guid <guid string> guid for image blob type + -i, --index <index> update image index + -I, --instance <instance> update hardware instance + -v, --fw-version <version> firmware version + -p, --private-key <privkey file> private key file + -c, --certificate <cert file> signer's certificate file + -m, --monotonic-count <count> monotonic count + -d, --dump_sig dump signature (*.p7) + -A, --fw-accept firmware accept capsule, requires GUID, no image blob + -R, --fw-revert firmware revert capsule, takes no GUID, no image blob + -o, --capoemflag Capsule OEM Flag, an integer between 0x0000 and 0xffff + -h, --help print a help message +""" + +from binman import bintool + +class Bintoolmkeficapsule(bintool.Bintool): + """Handles the 'mkeficapsule' tool + + This bintool is used for generating the EFI capsules. The + capsule generation parameters can either be specified through + commandline, or through a config file. + """ + def __init__(self, name): + super().__init__(name, 'mkeficapsule tool for generating capsules') + + def generate_capsule(self, image_index, image_guid, hardware_instance, + payload, output_fname, priv_key, pub_key, + monotonic_count=0, version=0, oemflags=0): + """Generate a capsule through commandline-provided parameters + + Args: + image_index (int): Unique number for identifying payload image + image_guid (str): GUID used for identifying the image + hardware_instance (int): Optional unique hardware instance of + a device in the system. 0 if not being used + payload (str): Path to the input payload image + output_fname (str): Path to the output capsule file + priv_key (str): Path to the private key + pub_key(str): Path to the public key + monotonic_count (int): Count used when signing an image + version (int): Image version (Optional) + oemflags (int): Optional 16 bit OEM flags + + Returns: + str: Tool output + """ + args = [ + f'--index={image_index}', + f'--guid={image_guid}', + f'--instance={hardware_instance}' + ] + + if version: + args += [f'--fw-version={version}'] + if oemflags: + args += [f'--capoemflag={oemflags}'] + if priv_key and pub_key: + args += [ + f'--monotonic-count={monotonic_count}', + f'--private-key={priv_key}', + f'--certificate={pub_key}' + ] + + args += [ + payload, + output_fname + ] + + return self.run_cmd(*args) + + def fetch(self, method): + """Fetch handler for mkeficapsule + + This builds the tool from source + + Returns: + tuple: + str: Filename of fetched file to copy to a suitable directory + str: Name of temp directory to remove, or None + """ + if method != bintool.FETCH_BUILD: + return None + + cmd = ['tools-only_defconfig', 'tools'] + result = self.build_from_git( + 'https://source.denx.de/u-boot/u-boot.git', + cmd, + 'tools/mkeficapsule') + return result
Add support in binman for generating EFI capsules. The capsule parameters can be specified through the capsule binman entry. Also add test cases in binman for testing capsule generation.
tools/binman/entries.rst | 64 ++++++++ tools/binman/etype/efi_capsule.py | 143 ++++++++++++++++++ tools/binman/ftest.py | 118 +++++++++++++++ tools/binman/test/311_capsule.dts | 21 +++ tools/binman/test/312_capsule_signed.dts | 23 +++ tools/binman/test/313_capsule_version.dts | 22 +++ tools/binman/test/314_capsule_signed_ver.dts | 24 +++ tools/binman/test/315_capsule_oemflags.dts | 22 +++ tools/binman/test/316_capsule_missing_key.dts | 22 +++ .../binman/test/317_capsule_missing_index.dts | 20 +++ .../binman/test/318_capsule_missing_guid.dts | 19 +++ 11 files changed, 498 insertions(+) create mode 100644 tools/binman/etype/efi_capsule.py create mode 100644 tools/binman/test/311_capsule.dts create mode 100644 tools/binman/test/312_capsule_signed.dts create mode 100644 tools/binman/test/313_capsule_version.dts create mode 100644 tools/binman/test/314_capsule_signed_ver.dts create mode 100644 tools/binman/test/315_capsule_oemflags.dts create mode 100644 tools/binman/test/316_capsule_missing_key.dts create mode 100644 tools/binman/test/317_capsule_missing_index.dts create mode 100644 tools/binman/test/318_capsule_missing_guid.dts
diff --git a/tools/binman/entries.rst b/tools/binman/entries.rst index e7dfe6b2a3..801bd94674 100644 --- a/tools/binman/entries.rst +++ b/tools/binman/entries.rst @@ -468,6 +468,70 @@ updating the EC on startup via software sync.
+.. _etype_efi_capsule: + +Entry: capsule: Entry for generating EFI Capsule files +------------------------------------------------------ + +The parameters needed for generation of the capsules can be provided +as properties in the entry. + +Properties / Entry arguments: + - image-index: Unique number for identifying corresponding + payload image. Number between 1 and descriptor count, i.e. + the total number of firmware images that can be updated. Mandatory + property. + - image-guid: Image GUID which will be used for identifying the + updatable image on the board. Mandatory property. + - hardware-instance: Optional number for identifying unique + hardware instance of a device in the system. Default value of 0 + for images where value is not to be used. + - fw-version: Value of image version that can be put on the capsule + through the Firmware Management Protocol(FMP) header. + - monotonic-count: Count used when signing an image. + - private-key: Path to PEM formatted .key private key file. Mandatory + property for generating signed capsules. + - public-key-cert: Path to PEM formatted .crt public key certificate + file. Mandatory property for generating signed capsules. + - oem-flags - OEM flags to be passed through capsule header. + + Since this is a subclass of Entry_section, all properties of the parent + class also apply here. Except for the properties stated as mandatory, the + rest of the properties are optional. + +For more details on the description of the capsule format, and the capsule +update functionality, refer Section 8.5 and Chapter 23 in the `UEFI +specification`_. + +The capsule parameters like image index and image GUID are passed as +properties in the entry. The payload to be used in the capsule is to be +provided as a subnode of the capsule entry. + +A typical capsule entry node would then look something like this:: + + capsule { + type = "efi-capsule"; + image-index = <0x1>; + /* Image GUID for testing capsule update */ + image-guid = SANDBOX_UBOOT_IMAGE_GUID; + hardware-instance = <0x0>; + private-key = "path/to/the/private/key"; + public-key-cert = "path/to/the/public-key-cert"; + oem-flags = <0x8000>; + + u-boot { + }; + }; + +In the above example, the capsule payload is the U-Boot image. The +capsule entry would read the contents of the payload and put them +into the capsule. Any external file can also be specified as the +payload using the blob-ext subnode. + +.. _`UEFI specification`: https://uefi.org/sites/default/files/resources/UEFI_Spec_2_10_Aug29.pdf + + + .. _etype_encrypted:
Entry: encrypted: Externally built encrypted binary blob diff --git a/tools/binman/etype/efi_capsule.py b/tools/binman/etype/efi_capsule.py new file mode 100644 index 0000000000..006eb630ad --- /dev/null +++ b/tools/binman/etype/efi_capsule.py @@ -0,0 +1,143 @@ +# SPDX-License-Identifier: GPL-2.0+ +# Copyright (c) 2023 Linaro Limited +# +# Entry-type module for producing a EFI capsule +# + +import os + +from binman.entry import Entry +from binman.etype.section import Entry_section +from dtoc import fdt_util +from u_boot_pylib import tools + +class Entry_efi_capsule(Entry_section): + """Generate EFI capsules + + The parameters needed for generation of the capsules can + be provided as properties in the entry. + + Properties / Entry arguments: + - image-index: Unique number for identifying corresponding + payload image. Number between 1 and descriptor count, i.e. + the total number of firmware images that can be updated. Mandatory + property. + - image-guid: Image GUID which will be used for identifying the + updatable image on the board. Mandatory property. + - hardware-instance: Optional number for identifying unique + hardware instance of a device in the system. Default value of 0 + for images where value is not to be used. + - fw-version: Value of image version that can be put on the capsule + through the Firmware Management Protocol(FMP) header. + - monotonic-count: Count used when signing an image. + - private-key: Path to PEM formatted .key private key file. Mandatory + property for generating signed capsules. + - public-key-cert: Path to PEM formatted .crt public key certificate + file. Mandatory property for generating signed capsules. + - oem-flags - OEM flags to be passed through capsule header. + + Since this is a subclass of Entry_section, all properties of the parent + class also apply here. Except for the properties stated as mandatory, the + rest of the properties are optional. + + For more details on the description of the capsule format, and the capsule + update functionality, refer Section 8.5 and Chapter 23 in the `UEFI + specification`_. + + The capsule parameters like image index and image GUID are passed as + properties in the entry. The payload to be used in the capsule is to be + provided as a subnode of the capsule entry. + + A typical capsule entry node would then look something like this + + capsule { + type = "efi-capsule"; + image-index = <0x1>; + /* Image GUID for testing capsule update */ + image-guid = SANDBOX_UBOOT_IMAGE_GUID; + hardware-instance = <0x0>; + private-key = "path/to/the/private/key"; + public-key-cert = "path/to/the/public-key-cert"; + oem-flags = <0x8000>; + + u-boot { + }; + }; + + In the above example, the capsule payload is the U-Boot image. The + capsule entry would read the contents of the payload and put them + into the capsule. Any external file can also be specified as the + payload using the blob-ext subnode. + + .. _`UEFI specification`: https://uefi.org/sites/default/files/resources/UEFI_Spec_2_10_Aug29.pdf + """ + def __init__(self, section, etype, node): + super().__init__(section, etype, node) + self.required_props = ['image-index', 'image-guid'] + self.image_index = 0 + self.image_guid = '' + self.hardware_instance = 0 + self.monotonic_count = 0 + self.fw_version = 0 + self.oem_flags = 0 + self.private_key = '' + self.public_key_cert = '' + self.auth = 0 + + def ReadNode(self): + super().ReadNode() + + self.image_index = fdt_util.GetInt(self._node, 'image-index') + self.image_guid = fdt_util.GetString(self._node, 'image-guid') + self.fw_version = fdt_util.GetInt(self._node, 'fw-version') + self.hardware_instance = fdt_util.GetInt(self._node, 'hardware-instance') + self.monotonic_count = fdt_util.GetInt(self._node, 'monotonic-count') + self.oem_flags = fdt_util.GetInt(self._node, 'oem-flags') + + self.private_key = fdt_util.GetString(self._node, 'private-key') + self.public_key_cert = fdt_util.GetString(self._node, 'public-key-cert') + if ((self.private_key and not self.public_key_cert) or (self.public_key_cert and not self.private_key)): + self.Raise('Both private key and public key certificate need to be provided') + elif not (self.private_key and self.public_key_cert): + self.auth = 0 + else: + self.auth = 1 + + def BuildSectionData(self, required): + def get_binman_test_guid(type_str): + TYPE_TO_GUID = { + 'binman-test' : '09d7cf52-0720-4710-91d1-08469b7fe9c8' + } + return TYPE_TO_GUID[type_str] + + private_key = '' + public_key_cert = '' + if self.auth: + if not os.path.isabs(self.private_key): + private_key = tools.get_input_filename(self.private_key) + if not os.path.isabs(self.public_key_cert): + public_key_cert = tools.get_input_filename(self.public_key_cert) + data, payload, uniq = self.collect_contents_to_file( + self._entries.values(), 'capsule_in') + outfile = self._filename if self._filename else 'capsule.%s' % uniq + capsule_fname = tools.get_output_filename(outfile) + guid = self.image_guid + if self.image_guid == "binman-test": + guid = get_binman_test_guid('binman-test') + + ret = self.mkeficapsule.generate_capsule(self.image_index, + guid, + self.hardware_instance, + payload, + capsule_fname, + private_key, + public_key_cert, + self.monotonic_count, + self.fw_version, + self.oem_flags) + if ret is not None: + os.remove(payload) + return tools.read_file(capsule_fname) + + def AddBintools(self, btools): + self.mkeficapsule = self.AddBintool(btools, 'mkeficapsule') diff --git a/tools/binman/ftest.py b/tools/binman/ftest.py index 1293e9dbf4..8e419645a6 100644 --- a/tools/binman/ftest.py +++ b/tools/binman/ftest.py @@ -48,6 +48,7 @@ U_BOOT_VPL_DATA = b'vpl76543210fedcbazywxyz_' BLOB_DATA = b'89' ME_DATA = b'0abcd' VGA_DATA = b'vga' +EFI_CAPSULE_DATA = b'efi' U_BOOT_DTB_DATA = b'udtb' U_BOOT_SPL_DTB_DATA = b'spldtb' U_BOOT_TPL_DTB_DATA = b'tpldtb' @@ -119,6 +120,11 @@ COMP_BINTOOLS = ['bzip2', 'gzip', 'lz4', 'lzma_alone', 'lzop', 'xz', 'zstd']
TEE_ADDR = 0x5678
+# Firmware Management Protocol(FMP) GUID +FW_MGMT_GUID = 'edd5cb6d2de8444cbda17194199ad92a' +# Image GUID specified in the DTS +CAPSULE_IMAGE_GUID = '52cfd7092007104791d108469b7fe9c8' + class TestFunctional(unittest.TestCase): """Functional tests for binman
@@ -215,6 +221,7 @@ class TestFunctional(unittest.TestCase): TestFunctional._MakeInputFile('scp.bin', SCP_DATA) TestFunctional._MakeInputFile('rockchip-tpl.bin', ROCKCHIP_TPL_DATA) TestFunctional._MakeInputFile('ti_unsecure.bin', TI_UNSECURE_DATA) + TestFunctional._MakeInputFile('capsule_input.bin', EFI_CAPSULE_DATA)
# Add a few .dtb files for testing TestFunctional._MakeInputFile('%s/test-fdt1.dtb' % TEST_FDT_SUBDIR, @@ -7216,5 +7223,116 @@ fdt fdtmap Extract the devicetree blob from the fdtmap self.assertRegex(err, "Image 'image'.*missing bintools.*: bootgen")
+ def _CheckCapsule(self, data, signed_capsule=False, version_check=False, + capoemflags=False): + fmp_signature = "4d535331" # 'M', 'S', 'S', '1' + fmp_size = "10" + fmp_fw_version = "02" + oemflag = "0080" + + payload_data = EFI_CAPSULE_DATA + + # TODO - Currently, these offsets for capsule fields are hardcoded. + # There are plans to add support to the mkeficapsule tool to dump + # the capsule contents which can then be used for capsule + # verification. + + # Firmware Management Protocol(FMP) GUID - offset(0 - 32) + self.assertEqual(FW_MGMT_GUID, data.hex()[:32]) + # Image GUID - offset(96 - 128) + self.assertEqual(CAPSULE_IMAGE_GUID, data.hex()[96:128]) + + if capoemflags: + # OEM Flags - offset(40 - 44) + self.assertEqual(oemflag, data.hex()[40:44]) + if signed_capsule and version_check: + # FMP header signature - offset(4770 - 4778) + self.assertEqual(fmp_signature, data.hex()[4770:4778]) + # FMP header size - offset(4778 - 4780) + self.assertEqual(fmp_size, data.hex()[4778:4780]) + # firmware version - offset(4786 - 4788) + self.assertEqual(fmp_fw_version, data.hex()[4786:4788]) + # payload offset signed capsule(4802 - 4808) + self.assertEqual(payload_data.hex(), data.hex()[4802:4808]) + elif signed_capsule: + # payload offset signed capsule(4770 - 4776) + self.assertEqual(payload_data.hex(), data.hex()[4770:4776]) + elif version_check: + # FMP header signature - offset(184 - 192) + self.assertEqual(fmp_signature, data.hex()[184:192]) + # FMP header size - offset(192 - 194) + self.assertEqual(fmp_size, data.hex()[192:194]) + # firmware version - offset(200 - 202) + self.assertEqual(fmp_fw_version, data.hex()[200:202]) + # payload offset for non-signed capsule with version header(216 - 222) + self.assertEqual(payload_data.hex(), data.hex()[216:222]) + else: + # payload offset for non-signed capsule with no version header(184 - 190) + self.assertEqual(payload_data.hex(), data.hex()[184:190]) + + def testCapsuleGen(self): + """Test generation of EFI capsule""" + data = self._DoReadFile('311_capsule.dts') + + self._CheckCapsule(data) + + def testSignedCapsuleGen(self): + """Test generation of EFI capsule""" + data = tools.read_file(self.TestFile("key.key")) + self._MakeInputFile("key.key", data) + data = tools.read_file(self.TestFile("key.pem")) + self._MakeInputFile("key.crt", data) + + data = self._DoReadFile('312_capsule_signed.dts') + + self._CheckCapsule(data, signed_capsule=True) + + def testCapsuleGenVersionSupport(self): + """Test generation of EFI capsule with version support""" + data = self._DoReadFile('313_capsule_version.dts') + + self._CheckCapsule(data, version_check=True) + + def testCapsuleGenSignedVer(self): + """Test generation of signed EFI capsule with version information""" + data = tools.read_file(self.TestFile("key.key")) + self._MakeInputFile("key.key", data) + data = tools.read_file(self.TestFile("key.pem")) + self._MakeInputFile("key.crt", data) + + data = self._DoReadFile('314_capsule_signed_ver.dts') + + self._CheckCapsule(data, signed_capsule=True, version_check=True) + + def testCapsuleGenCapOemFlags(self): + """Test generation of EFI capsule with OEM Flags set""" + data = self._DoReadFile('315_capsule_oemflags.dts') + + self._CheckCapsule(data, capoemflags=True) + + def testCapsuleGenKeyMissing(self): + """Test that binman errors out on missing key""" + with self.assertRaises(ValueError) as e: + self._DoReadFile('316_capsule_missing_key.dts') + + self.assertIn("Both private key and public key certificate need to be provided", + str(e.exception)) + + def testCapsuleGenIndexMissing(self): + """Test that binman errors out on missing image index""" + with self.assertRaises(ValueError) as e: + self._DoReadFile('317_capsule_missing_index.dts') + + self.assertIn("entry is missing properties: image-index", + str(e.exception)) + + def testCapsuleGenGuidMissing(self): + """Test that binman errors out on missing image GUID""" + with self.assertRaises(ValueError) as e: + self._DoReadFile('318_capsule_missing_guid.dts') + + self.assertIn("entry is missing properties: image-guid", + str(e.exception)) + if __name__ == "__main__": unittest.main() diff --git a/tools/binman/test/311_capsule.dts b/tools/binman/test/311_capsule.dts new file mode 100644 index 0000000000..8eb4250b14 --- /dev/null +++ b/tools/binman/test/311_capsule.dts @@ -0,0 +1,21 @@ +// SPDX-License-Identifier: GPL-2.0+ + +/dts-v1/; + +/ { + #address-cells = <1>; + #size-cells = <1>; + + binman { + efi-capsule { + image-index = <0x1>; + /* Image GUID for testing capsule update */ + image-guid = "binman-test"; + hardware-instance = <0x0>; + + blob { + filename = "capsule_input.bin"; + }; + }; + }; +}; diff --git a/tools/binman/test/312_capsule_signed.dts b/tools/binman/test/312_capsule_signed.dts new file mode 100644 index 0000000000..d1c76e269c --- /dev/null +++ b/tools/binman/test/312_capsule_signed.dts @@ -0,0 +1,23 @@ +// SPDX-License-Identifier: GPL-2.0+ + +/dts-v1/; + +/ { + #address-cells = <1>; + #size-cells = <1>; + + binman { + efi-capsule { + image-index = <0x1>; + /* Image GUID for testing capsule update */ + image-guid = "binman-test"; + hardware-instance = <0x0>; + private-key = "key.key"; + public-key-cert = "key.crt"; + + blob { + filename = "capsule_input.bin"; + }; + }; + }; +}; diff --git a/tools/binman/test/313_capsule_version.dts b/tools/binman/test/313_capsule_version.dts new file mode 100644 index 0000000000..bafef3609e --- /dev/null +++ b/tools/binman/test/313_capsule_version.dts @@ -0,0 +1,22 @@ +// SPDX-License-Identifier: GPL-2.0+ + +/dts-v1/; + +/ { + #address-cells = <1>; + #size-cells = <1>; + + binman { + efi-capsule { + image-index = <0x1>; + fw-version = <0x2>; + /* Image GUID for testing capsule update */ + image-guid = "binman-test"; + hardware-instance = <0x0>; + + blob { + filename = "capsule_input.bin"; + }; + }; + }; +}; diff --git a/tools/binman/test/314_capsule_signed_ver.dts b/tools/binman/test/314_capsule_signed_ver.dts new file mode 100644 index 0000000000..85c784bba4 --- /dev/null +++ b/tools/binman/test/314_capsule_signed_ver.dts @@ -0,0 +1,24 @@ +// SPDX-License-Identifier: GPL-2.0+ + +/dts-v1/; + +/ { + #address-cells = <1>; + #size-cells = <1>; + + binman { + efi-capsule { + image-index = <0x1>; + fw-version = <0x2>; + /* Image GUID for testing capsule update */ + image-guid = "binman-test"; + hardware-instance = <0x0>; + private-key = "key.key"; + public-key-cert = "key.crt"; + + blob { + filename = "capsule_input.bin"; + }; + }; + }; +}; diff --git a/tools/binman/test/315_capsule_oemflags.dts b/tools/binman/test/315_capsule_oemflags.dts new file mode 100644 index 0000000000..f736e8758f --- /dev/null +++ b/tools/binman/test/315_capsule_oemflags.dts @@ -0,0 +1,22 @@ +// SPDX-License-Identifier: GPL-2.0+ + +/dts-v1/; + +/ { + #address-cells = <1>; + #size-cells = <1>; + + binman { + efi-capsule { + image-index = <0x1>; + /* Image GUID for testing capsule update */ + image-guid = "binman-test"; + hardware-instance = <0x0>; + oem-flags = <0x8000>; + + blob { + filename = "capsule_input.bin"; + }; + }; + }; +}; diff --git a/tools/binman/test/316_capsule_missing_key.dts b/tools/binman/test/316_capsule_missing_key.dts new file mode 100644 index 0000000000..2080b50e3d --- /dev/null +++ b/tools/binman/test/316_capsule_missing_key.dts @@ -0,0 +1,22 @@ +// SPDX-License-Identifier: GPL-2.0+ + +/dts-v1/; + +/ { + #address-cells = <1>; + #size-cells = <1>; + + binman { + efi-capsule { + image-index = <0x1>; + /* Image GUID for testing capsule update */ + image-guid = "binman-test"; + hardware-instance = <0x0>; + private-key = "tools/binman/test/key.key"; + + blob { + filename = "capsule_input.bin"; + }; + }; + }; +}; diff --git a/tools/binman/test/317_capsule_missing_index.dts b/tools/binman/test/317_capsule_missing_index.dts new file mode 100644 index 0000000000..aadb61f647 --- /dev/null +++ b/tools/binman/test/317_capsule_missing_index.dts @@ -0,0 +1,20 @@ +// SPDX-License-Identifier: GPL-2.0+ + +/dts-v1/; + +/ { + #address-cells = <1>; + #size-cells = <1>; + + binman { + efi-capsule { + /* Image GUID for testing capsule update */ + image-guid = "binman-test"; + hardware-instance = <0x0>; + + blob { + filename = "capsule_input.bin"; + }; + }; + }; +}; diff --git a/tools/binman/test/318_capsule_missing_guid.dts b/tools/binman/test/318_capsule_missing_guid.dts new file mode 100644 index 0000000000..d76afba853 --- /dev/null +++ b/tools/binman/test/318_capsule_missing_guid.dts @@ -0,0 +1,19 @@ +// SPDX-License-Identifier: GPL-2.0+ + +/dts-v1/; + +/ { + #address-cells = <1>; + #size-cells = <1>; + + binman { + efi-capsule { + image-index = <0x1>; + hardware-instance = <0x0>; + + blob { + filename = "capsule_input.bin"; + }; + }; + }; +};
Add support for all sandbox variants to support generating multiple images. This also requires tweaking the binman node of the sandbox_vpl variant to work with the multiple-images property.
Signed-off-by: Sughosh Ganu sughosh.ganu@linaro.org Signed-off-by: Simon Glass sjg@chromium.org Reviewed-by: Simon Glass sjg@chromium.org --- Changes since V9: None
arch/sandbox/dts/sandbox.dts | 1 + arch/sandbox/dts/sandbox_vpl.dtsi | 5 +++++ arch/sandbox/dts/test.dts | 1 + 3 files changed, 7 insertions(+)
diff --git a/arch/sandbox/dts/sandbox.dts b/arch/sandbox/dts/sandbox.dts index 12d3eff5fa..1039b029f4 100644 --- a/arch/sandbox/dts/sandbox.dts +++ b/arch/sandbox/dts/sandbox.dts @@ -22,6 +22,7 @@ };
binman: binman { + multiple-images; };
memory { diff --git a/arch/sandbox/dts/sandbox_vpl.dtsi b/arch/sandbox/dts/sandbox_vpl.dtsi index c7dc00a8d2..83e7657d5d 100644 --- a/arch/sandbox/dts/sandbox_vpl.dtsi +++ b/arch/sandbox/dts/sandbox_vpl.dtsi @@ -4,6 +4,11 @@ */
&binman { + image: image { + }; +}; + +&image { u-boot-tpl-elf { no-expanded; }; diff --git a/arch/sandbox/dts/test.dts b/arch/sandbox/dts/test.dts index f351d5cb84..9b731a29cf 100644 --- a/arch/sandbox/dts/test.dts +++ b/arch/sandbox/dts/test.dts @@ -67,6 +67,7 @@ };
config {
The EFI capsule files can now be generated as part of u-boot build through binman. Add capsule entry nodes for the sandbox architecture for generating the capsules. These capsules are then used for testing the EFI capsule update functionality on the sandbox platforms.
Remove the corresponding logic in the test setup which was used for generation of these capsule which is now superfluous.
arch/sandbox/dts/sandbox.dts | 2 + arch/sandbox/dts/sandbox_capsule.dtsi | 315 ++++++++++++++++++ arch/sandbox/dts/test.dts | 2 + include/sandbox_efi_capsule.h | 21 ++ test/py/tests/test_efi_capsule/conftest.py | 155 +-------- .../tests/test_efi_capsule/uboot_bin_env.its | 36 -- 6 files changed, 356 insertions(+), 175 deletions(-) create mode 100644 arch/sandbox/dts/sandbox_capsule.dtsi create mode 100644 include/sandbox_efi_capsule.h delete mode 100644 test/py/tests/test_efi_capsule/uboot_bin_env.its
diff --git a/arch/sandbox/dts/sandbox.dts b/arch/sandbox/dts/sandbox.dts index 1039b029f4..3da96ae99d 100644 --- a/arch/sandbox/dts/sandbox.dts +++ b/arch/sandbox/dts/sandbox.dts @@ -107,3 +107,5 @@ #if IS_ENABLED(CONFIG_SUPPORT_VPL) #include "sandbox_vpl.dtsi" #endif + +#include "sandbox_capsule.dtsi" diff --git a/arch/sandbox/dts/sandbox_capsule.dtsi b/arch/sandbox/dts/sandbox_capsule.dtsi new file mode 100644 index 0000000000..bd48f18760 --- /dev/null +++ b/arch/sandbox/dts/sandbox_capsule.dtsi @@ -0,0 +1,315 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Devicetree file with binman nodes for generating capsules. + */ + +#include <sandbox_efi_capsule.h> + +&binman { + itb { + filename = UBOOT_FIT_IMAGE; + + fit { + description = "Automatic U-Boot environment update"; + #address-cells = <2>; + + images { + u-boot-bin { + description = "U-Boot binary on SPI Flash"; + compression = "none"; + type = "firmware"; + arch = "sandbox"; + load = <0>; + text { + text = "u-boot:New"; + }; + + hash-1 { + algo = "sha1"; + }; + }; + u-boot-env { + description = "U-Boot environment on SPI Flash"; + compression = "none"; + type = "firmware"; + arch = "sandbox"; + load = <0>; + text { + text = "u-boot-env:New"; + }; + + hash-1 { + algo = "sha1"; + }; + }; + }; + }; + }; + + capsule1 { + filename = "Test01"; + efi-capsule { + image-index = <0x1>; + image-guid = SANDBOX_UBOOT_IMAGE_GUID; + + text { + text = "u-boot:New"; + }; + }; + }; + + capsule2 { + filename = "Test02"; + efi-capsule { + image-index = <0x2>; + image-guid = SANDBOX_UBOOT_ENV_IMAGE_GUID; + + text { + text = "u-boot-env:New"; + }; + }; + }; + + capsule3 { + filename = "Test03"; + efi-capsule { + image-index = <0x1>; + image-guid = SANDBOX_INCORRECT_GUID; + + text { + text = "u-boot:New"; + }; + }; + }; + + capsule4 { + filename = "Test04"; + efi-capsule { + image-index = <0x1>; + image-guid = SANDBOX_FIT_IMAGE_GUID; + + blob { + filename = UBOOT_FIT_IMAGE; + }; + }; + }; + + capsule5 { + filename = "Test05"; + efi-capsule { + image-index = <0x1>; + image-guid = SANDBOX_INCORRECT_GUID; + + blob { + filename = UBOOT_FIT_IMAGE; + }; + }; + }; + + capsule6 { + filename = "Test101"; + efi-capsule { + image-index = <0x1>; + fw-version = <0x5>; + image-guid = SANDBOX_UBOOT_IMAGE_GUID; + + text { + text = "u-boot:New"; + }; + }; + }; + + capsule7 { + filename = "Test102"; + efi-capsule { + image-index = <0x2>; + fw-version = <0xa>; + image-guid = SANDBOX_UBOOT_ENV_IMAGE_GUID; + + text { + text = "u-boot-env:New"; + }; + }; + }; + + capsule8 { + filename = "Test103"; + efi-capsule { + image-index = <0x1>; + fw-version = <0x2>; + image-guid = SANDBOX_UBOOT_IMAGE_GUID; + + text { + text = "u-boot:New"; + }; + }; + }; + + capsule9 { + filename = "Test104"; + efi-capsule { + image-index = <0x1>; + fw-version = <0x5>; + image-guid = SANDBOX_FIT_IMAGE_GUID; + + blob { + filename = UBOOT_FIT_IMAGE; + }; + }; + }; + + capsule10 { + filename = "Test105"; + efi-capsule { + image-index = <0x1>; + fw-version = <0x2>; + image-guid = SANDBOX_FIT_IMAGE_GUID; + + blob { + filename = UBOOT_FIT_IMAGE; + }; + }; + }; + +#ifdef CONFIG_EFI_CAPSULE_AUTHENTICATE + capsule11 { + filename = "Test11"; + efi-capsule { + image-index = <0x1>; + image-guid = SANDBOX_UBOOT_IMAGE_GUID; + private-key = CAPSULE_PRIV_KEY; + public-key-cert = CAPSULE_PUB_KEY; + monotonic-count = <0x1>; + + text { + text = "u-boot:New"; + }; + }; + }; + + capsule12 { + filename = "Test12"; + efi-capsule { + image-index = <0x1>; + image-guid = SANDBOX_UBOOT_IMAGE_GUID; + private-key = CAPSULE_INVAL_KEY; + public-key-cert = CAPSULE_INVAL_PUB_KEY; + monotonic-count = <0x1>; + + text { + text = "u-boot:New"; + }; + }; + }; + + capsule13 { + filename = "Test13"; + efi-capsule { + image-index = <0x1>; + image-guid = SANDBOX_FIT_IMAGE_GUID; + private-key = CAPSULE_PRIV_KEY; + public-key-cert = CAPSULE_PUB_KEY; + monotonic-count = <0x1>; + + blob { + filename = UBOOT_FIT_IMAGE; + }; + }; + }; + + capsule14 { + filename = "Test14"; + efi-capsule { + image-index = <0x1>; + image-guid = SANDBOX_FIT_IMAGE_GUID; + private-key = CAPSULE_INVAL_KEY; + public-key-cert = CAPSULE_INVAL_PUB_KEY; + monotonic-count = <0x1>; + + blob { + filename = UBOOT_FIT_IMAGE; + }; + }; + }; + + capsule15 { + filename = "Test111"; + efi-capsule { + image-index = <0x1>; + fw-version = <0x5>; + image-guid = SANDBOX_UBOOT_IMAGE_GUID; + private-key = CAPSULE_PRIV_KEY; + public-key-cert = CAPSULE_PUB_KEY; + monotonic-count = <0x1>; + + text { + text = "u-boot:New"; + }; + }; + }; + + capsule16 { + filename = "Test112"; + efi-capsule { + image-index = <0x2>; + fw-version = <0xa>; + image-guid = SANDBOX_UBOOT_ENV_IMAGE_GUID; + private-key = CAPSULE_PRIV_KEY; + public-key-cert = CAPSULE_PUB_KEY; + monotonic-count = <0x1>; + + text { + text = "u-boot-env:New"; + }; + }; + }; + + capsule17 { + filename = "Test113"; + efi-capsule { + image-index = <0x1>; + fw-version = <0x2>; + image-guid = SANDBOX_UBOOT_IMAGE_GUID; + private-key = CAPSULE_PRIV_KEY; + public-key-cert = CAPSULE_PUB_KEY; + monotonic-count = <0x1>; + + text { + text = "u-boot:New"; + }; + }; + }; + + capsule18 { + filename = "Test114"; + efi-capsule { + image-index = <0x1>; + fw-version = <0x5>; + image-guid = SANDBOX_FIT_IMAGE_GUID; + private-key = CAPSULE_PRIV_KEY; + public-key-cert = CAPSULE_PUB_KEY; + monotonic-count = <0x1>; + + blob { + filename = UBOOT_FIT_IMAGE; + }; + }; + }; + + capsule19 { + filename = "Test115"; + efi-capsule { + image-index = <0x1>; + fw-version = <0x2>; + image-guid = SANDBOX_FIT_IMAGE_GUID; + private-key = CAPSULE_PRIV_KEY; + public-key-cert = CAPSULE_PUB_KEY; + monotonic-count = <0x1>; + + blob { + filename = UBOOT_FIT_IMAGE; + }; + }; + }; +#endif /* CONFIG_EFI_CAPSULE_AUTHENTICATE */ +}; diff --git a/arch/sandbox/dts/test.dts b/arch/sandbox/dts/test.dts index 9b731a29cf..54368047f0 100644 --- a/arch/sandbox/dts/test.dts +++ b/arch/sandbox/dts/test.dts @@ -1850,3 +1850,5 @@ #endif
#include "cedit.dtsi" + +#include "sandbox_capsule.dtsi" diff --git a/include/sandbox_efi_capsule.h b/include/sandbox_efi_capsule.h new file mode 100644 index 0000000000..3e288e8a84 --- /dev/null +++ b/include/sandbox_efi_capsule.h @@ -0,0 +1,21 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (c) 2023, Linaro Limited + */ + +#if !defined(_SANDBOX_EFI_CAPSULE_H_) +#define _SANDBOX_EFI_CAPSULE_H_ + +#define SANDBOX_UBOOT_IMAGE_GUID "09d7cf52-0720-4710-91d1-08469b7fe9c8" +#define SANDBOX_UBOOT_ENV_IMAGE_GUID "5a7021f5-fef2-48b4-aaba-832e777418c0" +#define SANDBOX_FIT_IMAGE_GUID "3673b45d-6a7c-46f3-9e60-adabb03f7937" +#define SANDBOX_INCORRECT_GUID "058b7d83-50d5-4c47-a195-60d86ad341c4" + +#define UBOOT_FIT_IMAGE "u-boot_bin_env.itb" + +#define CAPSULE_PRIV_KEY "capsule_priv_key_good.key" +#define CAPSULE_PUB_KEY "capsule_pub_key_good.crt" +#define CAPSULE_INVAL_KEY "capsule_priv_key_bad.key" +#define CAPSULE_INVAL_PUB_KEY "capsule_pub_key_bad.crt" + +#endif /* _SANDBOX_EFI_CAPSULE_H_ */ diff --git a/test/py/tests/test_efi_capsule/conftest.py b/test/py/tests/test_efi_capsule/conftest.py index 054be1ee97..7eead9bc64 100644 --- a/test/py/tests/test_efi_capsule/conftest.py +++ b/test/py/tests/test_efi_capsule/conftest.py @@ -34,15 +34,20 @@ def efi_capsule_data(request, u_boot_config):
capsule_auth_enabled = u_boot_config.buildconfig.get( 'config_efi_capsule_authenticate') + key_dir = u_boot_config.source_dir + '/board/sandbox' if capsule_auth_enabled: - # Create private key (SIGNER.key) and certificate (SIGNER.crt) - check_call('cd %s; ' - 'openssl req -x509 -sha256 -newkey rsa:2048 ' - '-subj /CN=TEST_SIGNER/ -keyout SIGNER.key ' - '-out SIGNER.crt -nodes -days 365' - % data_dir, shell=True) - check_call('cd %s; %scert-to-efi-sig-list SIGNER.crt SIGNER.esl' - % (data_dir, EFITOOLS_PATH), shell=True) + # Get the keys from the board directory + check_call('cp %s/capsule_priv_key_good.key %s/SIGNER.key' + % (key_dir, data_dir), shell=True) + check_call('cp %s/capsule_pub_key_good.crt %s/SIGNER.crt' + % (key_dir, data_dir), shell=True) + check_call('cp %s/capsule_pub_esl_good.esl %s/SIGNER.esl' + % (key_dir, data_dir), shell=True) + + check_call('cp %s/capsule_priv_key_bad.key %s/SIGNER2.key' + % (key_dir, data_dir), shell=True) + check_call('cp %s/capsule_pub_key_bad.crt %s/SIGNER2.crt' + % (key_dir, data_dir), shell=True)
# Update dtb adding capsule certificate check_call('cd %s; ' @@ -54,14 +59,6 @@ def efi_capsule_data(request, u_boot_config): '-o test_sig.dtb signature.dtbo' % (data_dir, u_boot_config.build_dir), shell=True)
- # Create *malicious* private key (SIGNER2.key) and certificate - # (SIGNER2.crt) - check_call('cd %s; ' - 'openssl req -x509 -sha256 -newkey rsa:2048 ' - '-subj /CN=TEST_SIGNER/ -keyout SIGNER2.key ' - '-out SIGNER2.crt -nodes -days 365' - % data_dir, shell=True) - # Update dtb to add the version information check_call('cd %s; ' 'cp %s/test/py/tests/test_efi_capsule/version.dts .' @@ -79,132 +76,12 @@ def efi_capsule_data(request, u_boot_config): '-o test_ver.dtb version.dtbo' % (data_dir, u_boot_config.build_dir), shell=True)
- # Create capsule files + + check_call('cp %s/u-boot_bin_env.itb %s ' % (u_boot_config.build_dir, data_dir), shell=True) + check_call('cp %s/Test* %s ' % (u_boot_config.build_dir, data_dir), shell=True) # two regions: one for u-boot.bin and the other for u-boot.env check_call('cd %s; echo -n u-boot:Old > u-boot.bin.old; echo -n u-boot:New > u-boot.bin.new; echo -n u-boot-env:Old > u-boot.env.old; echo -n u-boot-env:New > u-boot.env.new' % data_dir, shell=True) - check_call('sed -e "s?BINFILE1?u-boot.bin.new?" -e "s?BINFILE2?u-boot.env.new?" %s/test/py/tests/test_efi_capsule/uboot_bin_env.its > %s/uboot_bin_env.its' % - (u_boot_config.source_dir, data_dir), - shell=True) - check_call('cd %s; %s/tools/mkimage -f uboot_bin_env.its uboot_bin_env.itb' % - (data_dir, u_boot_config.build_dir), - shell=True) - check_call('cd %s; %s/tools/mkeficapsule --index 1 --guid 09D7CF52-0720-4710-91D1-08469B7FE9C8 u-boot.bin.new Test01' % - (data_dir, u_boot_config.build_dir), - shell=True) - check_call('cd %s; %s/tools/mkeficapsule --index 2 --guid 5A7021F5-FEF2-48B4-AABA-832E777418C0 u-boot.env.new Test02' % - (data_dir, u_boot_config.build_dir), - shell=True) - check_call('cd %s; %s/tools/mkeficapsule --index 1 --guid 058B7D83-50D5-4C47-A195-60D86AD341C4 u-boot.bin.new Test03' % - (data_dir, u_boot_config.build_dir), - shell=True) - check_call('cd %s; %s/tools/mkeficapsule --index 1 --guid 3673B45D-6A7C-46F3-9E60-ADABB03F7937 uboot_bin_env.itb Test04' % - (data_dir, u_boot_config.build_dir), - shell=True) - check_call('cd %s; %s/tools/mkeficapsule --index 1 --guid 058B7D83-50D5-4C47-A195-60D86AD341C4 uboot_bin_env.itb Test05' % - (data_dir, u_boot_config.build_dir), - shell=True) - check_call('cd %s; %s/tools/mkeficapsule --index 1 --fw-version 5 ' - '--guid 09D7CF52-0720-4710-91D1-08469B7FE9C8 u-boot.bin.new Test101' % - (data_dir, u_boot_config.build_dir), - shell=True) - check_call('cd %s; %s/tools/mkeficapsule --index 2 --fw-version 10 ' - '--guid 5A7021F5-FEF2-48B4-AABA-832E777418C0 u-boot.env.new Test102' % - (data_dir, u_boot_config.build_dir), - shell=True) - check_call('cd %s; %s/tools/mkeficapsule --index 1 --fw-version 2 ' - '--guid 09D7CF52-0720-4710-91D1-08469B7FE9C8 u-boot.bin.new Test103' % - (data_dir, u_boot_config.build_dir), - shell=True) - check_call('cd %s; %s/tools/mkeficapsule --index 1 --fw-version 5 ' - '--guid 3673B45D-6A7C-46F3-9E60-ADABB03F7937 uboot_bin_env.itb Test104' % - (data_dir, u_boot_config.build_dir), - shell=True) - check_call('cd %s; %s/tools/mkeficapsule --index 1 --fw-version 2 ' - '--guid 3673B45D-6A7C-46F3-9E60-ADABB03F7937 uboot_bin_env.itb Test105' % - (data_dir, u_boot_config.build_dir), - shell=True) - - if capsule_auth_enabled: - # raw firmware signed with proper key - check_call('cd %s; ' - '%s/tools/mkeficapsule --index 1 --monotonic-count 1 ' - '--private-key SIGNER.key --certificate SIGNER.crt ' - '--guid 09D7CF52-0720-4710-91D1-08469B7FE9C8 ' - 'u-boot.bin.new Test11' - % (data_dir, u_boot_config.build_dir), - shell=True) - # raw firmware signed with *mal* key - check_call('cd %s; ' - '%s/tools/mkeficapsule --index 1 --monotonic-count 1 ' - '--private-key SIGNER2.key ' - '--certificate SIGNER2.crt ' - '--guid 09D7CF52-0720-4710-91D1-08469B7FE9C8 ' - 'u-boot.bin.new Test12' - % (data_dir, u_boot_config.build_dir), - shell=True) - # FIT firmware signed with proper key - check_call('cd %s; ' - '%s/tools/mkeficapsule --index 1 --monotonic-count 1 ' - '--private-key SIGNER.key --certificate SIGNER.crt ' - '--guid 3673B45D-6A7C-46F3-9E60-ADABB03F7937 ' - 'uboot_bin_env.itb Test13' - % (data_dir, u_boot_config.build_dir), - shell=True) - # FIT firmware signed with *mal* key - check_call('cd %s; ' - '%s/tools/mkeficapsule --index 1 --monotonic-count 1 ' - '--private-key SIGNER2.key ' - '--certificate SIGNER2.crt ' - '--guid 3673B45D-6A7C-46F3-9E60-ADABB03F7937 ' - 'uboot_bin_env.itb Test14' - % (data_dir, u_boot_config.build_dir), - shell=True) - # raw firmware signed with proper key with version information - check_call('cd %s; ' - '%s/tools/mkeficapsule --index 1 --monotonic-count 1 ' - '--fw-version 5 ' - '--private-key SIGNER.key --certificate SIGNER.crt ' - '--guid 09D7CF52-0720-4710-91D1-08469B7FE9C8 ' - 'u-boot.bin.new Test111' - % (data_dir, u_boot_config.build_dir), - shell=True) - # raw firmware signed with proper key with version information - check_call('cd %s; ' - '%s/tools/mkeficapsule --index 2 --monotonic-count 1 ' - '--fw-version 10 ' - '--private-key SIGNER.key --certificate SIGNER.crt ' - '--guid 5A7021F5-FEF2-48B4-AABA-832E777418C0 ' - 'u-boot.env.new Test112' - % (data_dir, u_boot_config.build_dir), - shell=True) - # raw firmware signed with proper key with lower version information - check_call('cd %s; ' - '%s/tools/mkeficapsule --index 1 --monotonic-count 1 ' - '--fw-version 2 ' - '--private-key SIGNER.key --certificate SIGNER.crt ' - '--guid 09D7CF52-0720-4710-91D1-08469B7FE9C8 ' - 'u-boot.bin.new Test113' - % (data_dir, u_boot_config.build_dir), - shell=True) - # FIT firmware signed with proper key with version information - check_call('cd %s; ' - '%s/tools/mkeficapsule --index 1 --monotonic-count 1 ' - '--fw-version 5 ' - '--private-key SIGNER.key --certificate SIGNER.crt ' - '--guid 3673B45D-6A7C-46F3-9E60-ADABB03F7937 ' - 'uboot_bin_env.itb Test114' - % (data_dir, u_boot_config.build_dir), - shell=True) - # FIT firmware signed with proper key with lower version information - check_call('cd %s; ' - '%s/tools/mkeficapsule --index 1 --monotonic-count 1 ' - '--fw-version 2 ' - '--private-key SIGNER.key --certificate SIGNER.crt ' - '--guid 3673B45D-6A7C-46F3-9E60-ADABB03F7937 ' - 'uboot_bin_env.itb Test115' - % (data_dir, u_boot_config.build_dir), - shell=True)
# Create a disk image with EFI system partition check_call('virt-make-fs --partition=gpt --size=+1M --type=vfat %s %s' % diff --git a/test/py/tests/test_efi_capsule/uboot_bin_env.its b/test/py/tests/test_efi_capsule/uboot_bin_env.its deleted file mode 100644 index fc65907481..0000000000 --- a/test/py/tests/test_efi_capsule/uboot_bin_env.its +++ /dev/null @@ -1,36 +0,0 @@ -/* - * Automatic software update for U-Boot - * Make sure the flashing addresses ('load' prop) is correct for your board! - */ - -/dts-v1/; - -/ { - description = "Automatic U-Boot environment update"; - #address-cells = <2>; - - images { - u-boot-bin { - description = "U-Boot binary on SPI Flash"; - data = /incbin/("BINFILE1"); - compression = "none"; - type = "firmware"; - arch = "sandbox"; - load = <0>; - hash-1 { - algo = "sha1"; - }; - }; - u-boot-env { - description = "U-Boot environment on SPI Flash"; - data = /incbin/("BINFILE2"); - compression = "none"; - type = "firmware"; - arch = "sandbox"; - load = <0>; - hash-1 { - algo = "sha1"; - }; - }; - }; -};
The EFI capsules can now be generated as part of U-Boot build, through binman. Highlight these changes in the documentation.
Signed-off-by: Sughosh Ganu sughosh.ganu@linaro.org Acked-by: Heinrich Schuchardt xypron.glpk@gmx.de --- Changes since V9: * s/u-boot/U-Boot/ * Add a link to the binman capsule entry type documentation as suggested by Simon Glass.
doc/develop/uefi/uefi.rst | 17 +++++++++++++++++ 1 file changed, 17 insertions(+)
diff --git a/doc/develop/uefi/uefi.rst b/doc/develop/uefi/uefi.rst index a7a41f2fac..3ce579d46e 100644 --- a/doc/develop/uefi/uefi.rst +++ b/doc/develop/uefi/uefi.rst @@ -318,6 +318,9 @@ Run the following command --guid <image GUID> \ <capsule_file_name>
+Capsule with firmware version +***************************** + The UEFI specification does not define the firmware versioning mechanism. EDK II reference implementation inserts the FMP Payload Header right before the payload. It coutains the fw_version and lowest supported version, @@ -345,6 +348,20 @@ add --fw-version option in mkeficapsule tool. If the --fw-version option is not set, FMP Payload Header is not inserted and fw_version is set as 0.
+Capsule Generation through binman +********************************* + +Support has also been added to generate capsules during U-Boot build +through binman. This requires the platform's DTB to be populated with +the capsule entry nodes for binman. The capsules then can be generated +by specifying the capsule parameters as properties in the capsule +entry node. + +Check the arch/sandbox/dts/sandbox_capsule.dtsi file for the sandbox +platform as reference for how to generate capsules through binman as +part of U-Boot build. Refer :ref:`etype_efi_capsule` for +documentation about the efi-capsule binman entry type. + Performing the update *********************
Changes since V9:
- s/u-boot/U-Boot/
- Add a link to the binman capsule entry type documentation as suggested by Simon Glass.
When running the trace test on the sandbox platform, the current size of 16MiB is no longer large enough for capturing the entire trace history, and results in truncation. Use a size of 32MiB for the trace buffer on the sandbox platform while running the trace test.
.azure-pipelines.yml | 2 +- .gitlab-ci.yml | 2 +- test/py/tests/test_trace.py | 2 +- 3 files changed, 3 insertions(+), 3 deletions(-)
diff --git a/.azure-pipelines.yml b/.azure-pipelines.yml index 61d4bf8c8e..90c82d30b3 100644 --- a/.azure-pipelines.yml +++ b/.azure-pipelines.yml @@ -275,7 +275,7 @@ stages: TEST_PY_BD: "sandbox" BUILD_ENV: "FTRACE=1 NO_LTO=1" TEST_PY_TEST_SPEC: "trace" - OVERRIDE: "-a CONFIG_TRACE=y -a CONFIG_TRACE_EARLY=y -a CONFIG_TRACE_EARLY_SIZE=0x01000000" + OVERRIDE: "-a CONFIG_TRACE=y -a CONFIG_TRACE_EARLY=y -a CONFIG_TRACE_EARLY_SIZE=0x01000000 -a CONFIG_TRACE_BUFFER_SIZE=0x02000000" coreboot: TEST_PY_BD: "coreboot" TEST_PY_ID: "--id qemu" diff --git a/.gitlab-ci.yml b/.gitlab-ci.yml index d9f6b31792..874deb4ac3 100644 --- a/.gitlab-ci.yml +++ b/.gitlab-ci.yml @@ -315,7 +315,7 @@ sandbox trace_test.py: TEST_PY_BD: "sandbox" BUILD_ENV: "FTRACE=1 NO_LTO=1" TEST_PY_TEST_SPEC: "trace" - OVERRIDE: "-a CONFIG_TRACE=y -a CONFIG_TRACE_EARLY=y -a CONFIG_TRACE_EARLY_SIZE=0x01000000" + OVERRIDE: "-a CONFIG_TRACE=y -a CONFIG_TRACE_EARLY=y -a CONFIG_TRACE_EARLY_SIZE=0x01000000 -a CONFIG_TRACE_BUFFER_SIZE=0x02000000" <<: *buildman_and_testpy_dfn
evb-ast2500 test.py: diff --git a/test/py/tests/test_trace.py b/test/py/tests/test_trace.py index ac3e95925e..ad2250920d 100644 --- a/test/py/tests/test_trace.py +++ b/test/py/tests/test_trace.py @@ -61,7 +61,7 @@ def collect_trace(cons):
# Read out the trace data addr = 0x02000000 - size = 0x01000000 + size = 0x02000000 out = cons.run_command(f'trace calls {addr:x} {size:x}') print(out) fname = os.path.join(TMPDIR, 'trace')
Sughosh Ganu
