[U-Boot] [PATCH 1/1] Fixed clobbered output of the "help usb" command
Hello all,
I've noticed that the "usb help" doesn't format the output correctly:
=> help usb usb - USB sub-system
Usage: usb reset - reset (rescan) USB controller usb stop [f] - stop USB [f]=force stop usb tree - show USB device tree usb info [dev] - show available USB devices usb storage - show details of USB storage devices usb dev [dev] - show or set current USB storage device usb part [dev] - print partition table of one or all USB storage devices usb read addr blk# cnt - read `cnt' blocks starting at block `blk#' to memory address `addr'usb write addr blk# cnt - write `cnt' blocks starting at block `blk#' from memory address `addr' =>
With fix below applied, the output is correct:
Usage: usb reset - reset (rescan) USB controller usb stop [f] - stop USB [f]=force stop usb tree - show USB device tree usb info [dev] - show available USB devices usb storage - show details of USB storage devices usb dev [dev] - show or set current USB storage device usb part [dev] - print partition table of one or all USB storage devices usb read addr blk# cnt - read `cnt' blocks starting at block `blk#' to memory address `addr' usb write addr blk# cnt - write `cnt' blocks starting at block `blk#' from memory address `addr' =>
Please apply.
Regards, Sergei
From 473e86d3f5fe82fa7b27e5e73929e0e1f11987f4 Mon Sep 17 00:00:00 2001 From: Sergei Poselenov psl@pollux.denx.de Date: Mon, 9 Aug 2010 13:45:00 +0200 Subject: [PATCH] common/cmd_usb.c: fixed clobbered output in "help usb". Signed-off-by: Sergei Poselenov sposelenov@emcraft.com
--- common/cmd_usb.c | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/common/cmd_usb.c b/common/cmd_usb.c index dc63f24..226ea0d 100644 --- a/common/cmd_usb.c +++ b/common/cmd_usb.c @@ -712,7 +712,7 @@ U_BOOT_CMD( "usb part [dev] - print partition table of one or all USB storage" " devices\n" "usb read addr blk# cnt - read `cnt' blocks starting at block `blk#'\n" - " to memory address `addr'" + " to memory address `addr'\n" "usb write addr blk# cnt - write `cnt' blocks starting at block `blk#'\n" " from memory address `addr'" );
2010/8/9 Sergei Poselenov sposelenov@emcraft.com:
Hello all,
Please apply.
Regards, Sergei
Patch is corrupt. Lines are wrapped.
- " to memory address `addr'\n"
Applied to u-boot-usb after some small fixes to this patch (header text cleaned up and word wrapping) Thanks.
Remy
Hi Remy,
Sorry for that. Now I adjusted wrapping settings on my Claws Mail client.
Thank you.
Regards, Sergei
Remy Bohmer
Sergei Poselenov
