[PATCH] bootstd: USB devtype detection for script boot
Change the device type from "usb_mass_storage" to "usb" when booting a script.
Before this change: => printenv devtype devtype=usb_mass_storage
After this change: => printenv devtype devtype=usb
Signed-off-by: John Clark inindev@gmail.com ---
boot/bootmeth_script.c | 8 ++++++-- 1 file changed, 6 insertions(+), 2 deletions(-)
diff --git a/boot/bootmeth_script.c b/boot/bootmeth_script.c index 225eb18ee6..9fdadb3005 100644 --- a/boot/bootmeth_script.c +++ b/boot/bootmeth_script.c @@ -187,10 +187,14 @@ static int script_set_bootflow(struct udevice *dev, struct bootflow *bflow, static int script_boot(struct udevice *dev, struct bootflow *bflow) { struct blk_desc *desc = dev_get_uclass_plat(bflow->blk); + const char *devtype = blk_get_devtype(bflow->blk); ulong addr; int ret;
- ret = env_set("devtype", blk_get_devtype(bflow->blk)); + if (!strcmp("usb_mass_storage", devtype)) + ret = env_set("devtype", "usb"); + else + ret = env_set("devtype", devtype); if (!ret) ret = env_set_hex("devnum", desc->devnum); if (!ret) @@ -198,7 +202,7 @@ static int script_boot(struct udevice *dev, struct bootflow *bflow) if (!ret) ret = env_set("prefix", bflow->subdir); if (!ret && IS_ENABLED(CONFIG_ARCH_SUNXI) && - !strcmp("mmc", blk_get_devtype(bflow->blk))) + !strcmp("mmc", devtype)) ret = env_set_hex("mmc_bootdev", desc->devnum); if (ret) return log_msg_ret("env", ret);
Hi John,
I only just thought of this, but I think it is better to check blk->uclass_id == UCLASS_USB instead, since it avoids a string comparison.
else
-- 2.39.2
John Clark
