[U-Boot] [PATCH] omap3: pandora: use common configuration
This allows to clean up the config a good deal and also converts pandora to Generic Board.
Signed-off-by: Grazvydas Ignotas notasas@gmail.com --- include/configs/omap3_pandora.h | 177 ++++++++-------------------------------- 1 file changed, 36 insertions(+), 141 deletions(-)
diff --git a/include/configs/omap3_pandora.h b/include/configs/omap3_pandora.h index 11d7b86..8d3531c 100644 --- a/include/configs/omap3_pandora.h +++ b/include/configs/omap3_pandora.h @@ -10,22 +10,13 @@ #ifndef __CONFIG_H #define __CONFIG_H
-/* - * High Level Configuration Options - */ -#define CONFIG_OMAP 1 /* in a TI OMAP core */ -#define CONFIG_OMAP3_PANDORA 1 /* working with pandora */ -#define CONFIG_OMAP_GPIO -#define CONFIG_OMAP_COMMON -/* Common ARM Erratas */ -#define CONFIG_ARM_ERRATA_454179 -#define CONFIG_ARM_ERRATA_430973 -#define CONFIG_ARM_ERRATA_621766 +#define CONFIG_NR_DRAM_BANKS 2 /* CS1 may or may not be populated */ +#define CONFIG_NAND
-#define CONFIG_SDRC /* The chip has SDRC controller */ +/* override base for compatibility with MLO the device ships with */ +#define CONFIG_SYS_TEXT_BASE 0x80008000
-#include <asm/arch/cpu.h> /* get chip and board defs */ -#include <asm/arch/omap.h> +#include <configs/ti_omap3_common.h>
/* * Display CPU and Board information @@ -33,79 +24,42 @@ #define CONFIG_DISPLAY_CPUINFO 1 #define CONFIG_DISPLAY_BOARDINFO 1
-/* Clock Defines */ -#define V_OSCK 26000000 /* Clock output from T2 */ -#define V_SCLK (V_OSCK >> 1) - #define CONFIG_MISC_INIT_R - -#define CONFIG_CMDLINE_TAG 1 /* enable passing of ATAGs */ -#define CONFIG_SETUP_MEMORY_TAGS 1 -#define CONFIG_INITRD_TAG 1 #define CONFIG_REVISION_TAG 1
-#define CONFIG_OF_LIBFDT 1 - -/* - * Size of malloc() pool - */ #define CONFIG_ENV_SIZE (128 << 10) /* 128 KiB */ -#define CONFIG_SYS_MALLOC_LEN (1024 * 1024 + CONFIG_ENV_SIZE) + +#define CONFIG_SYS_CONSOLE_IS_IN_ENV 1 +#define CONFIG_SYS_DEVICE_NULLDEV 1
/* * Hardware drivers */
-#define CONFIG_SYS_CONSOLE_IS_IN_ENV 1 -#define CONFIG_SYS_DEVICE_NULLDEV 1 +/* I2C Support */ +#define CONFIG_SYS_I2C_OMAP34XX
-/* USB */ -#define CONFIG_MUSB_UDC 1 -#define CONFIG_USB_OMAP3 1 -#define CONFIG_TWL4030_USB 1 +/* TWL4030 LED */ +#define CONFIG_TWL4030_LED
-/* USB device configuration */ -#define CONFIG_USB_DEVICE 1 -#define CONFIG_USB_TTY 1 +/* Initialize GPIOs by default */ +#define CONFIG_OMAP3_GPIO_4 /* GPIO96..127 is in GPIO Bank 4 */ +#define CONFIG_OMAP3_GPIO_6 /* GPIO160..191 is in GPIO Bank 6 */
/* * NS16550 Configuration */ -#define V_NS16550_CLK 48000000 /* 48MHz (APLL96/2) */ - -#define CONFIG_SYS_NS16550 +#undef CONFIG_OMAP_SERIAL #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE (-4) #define CONFIG_SYS_NS16550_CLK V_NS16550_CLK - -/* - * select serial console configuration - */ -#define CONFIG_CONS_INDEX 3 #define CONFIG_SYS_NS16550_COM3 OMAP34XX_UART3 #define CONFIG_SERIAL3 3
-/* allow to overwrite serial and ethaddr */ -#define CONFIG_ENV_OVERWRITE -#define CONFIG_BAUDRATE 115200 -#define CONFIG_SYS_BAUDRATE_TABLE {4800, 9600, 19200, 38400, 57600, \ - 115200} -#define CONFIG_GENERIC_MMC 1 -#define CONFIG_MMC 1 -#define CONFIG_OMAP_HSMMC 1 -#define CONFIG_DOS_PARTITION 1 - /* commands to include */ #include <config_cmd_default.h>
-#define CONFIG_CMD_EXT2 /* EXT2 Support */ -#define CONFIG_CMD_FAT /* FAT support */ - -#define CONFIG_CMD_I2C /* I2C serial bus support */ -#define CONFIG_CMD_MMC /* MMC support */ -#define CONFIG_CMD_NAND /* NAND support */ #define CONFIG_CMD_CACHE /* Cache control */ - #undef CONFIG_CMD_FLASH /* flinfo, erase, protect */ #undef CONFIG_CMD_FPGA /* FPGA configuration Support */ #undef CONFIG_CMD_IMI /* iminfo */ @@ -113,53 +67,36 @@ #undef CONFIG_CMD_NET /* bootp, tftpboot, rarpboot */ #undef CONFIG_CMD_NFS /* NFS support */
-#define CONFIG_SYS_NO_FLASH -#define CONFIG_SYS_I2C -#define CONFIG_SYS_OMAP24_I2C_SPEED 100000 -#define CONFIG_SYS_OMAP24_I2C_SLAVE 1 -#define CONFIG_SYS_I2C_OMAP34XX - -/* - * TWL4030 - */ -#define CONFIG_TWL4030_POWER 1 -#define CONFIG_TWL4030_LED 1 - /* * Board NAND Info. */ -#define CONFIG_NAND_OMAP_GPMC #define CONFIG_SYS_NAND_ADDR NAND_BASE /* physical address */ /* to access nand */ -#define CONFIG_SYS_NAND_BASE NAND_BASE /* physical address */ - /* to access nand */ - /* at CS0 */ -#define CONFIG_SYS_MAX_NAND_DEVICE 1 /* Max number of NAND */ - /* devices */ - -#ifdef CONFIG_CMD_NAND -#define CONFIG_CMD_MTDPARTS -#define CONFIG_MTD_PARTITIONS -#define CONFIG_MTD_DEVICE -#define CONFIG_CMD_UBI -#define CONFIG_CMD_UBIFS -#define CONFIG_RBTREE -#define CONFIG_LZO - -#define MTDIDS_DEFAULT "nand0=nand" -#define MTDPARTS_DEFAULT "mtdparts=nand:512k(xloader),"\ +#define CONFIG_SYS_NAND_BUSWIDTH_16BIT 16 +#define CONFIG_NAND_OMAP_ECCSCHEME OMAP_ECC_HAM1_CODE_SW +#define CONFIG_SYS_NAND_PAGE_SIZE 2048 +#define CONFIG_SYS_NAND_OOBSIZE 64 + +#ifdef CONFIG_NAND +#define CONFIG_CMD_UBI /* UBI-formated MTD partition support */ +#define CONFIG_CMD_UBIFS /* Read-only UBI volume operations */ + +#define CONFIG_RBTREE /* required by CONFIG_CMD_UBI */ +#define CONFIG_LZO /* required by CONFIG_CMD_UBIFS */ + +#define CONFIG_MTD_PARTITIONS /* required for UBI partition support */ + +#define MTDIDS_DEFAULT "nand0=omap2-nand.0" +#define MTDPARTS_DEFAULT "mtdparts=omap2-nand.0:512k(xloader),"\ "1920k(uboot),128k(uboot-env),"\ "10m(boot),-(rootfs)" #else #define MTDPARTS_DEFAULT #endif
-/* Environment information */ -#define CONFIG_BOOTDELAY 1 - #define CONFIG_EXTRA_ENV_SETTINGS \ + DEFAULT_LINUX_BOOT_ENV \ "usbtty=cdc_acm\0" \ - "loadaddr=0x82000000\0" \ "bootargs=ubi.mtd=4 ubi.mtd=3 root=ubi0:rootfs rootfstype=ubifs " \ "rw rootflags=bulk_read vram=6272K omapfb.vram=0:3000K\0" \ "mtdparts=" MTDPARTS_DEFAULT "\0" \ @@ -172,60 +109,18 @@ "ubi part boot && ubifsmount ubi:boot && " \ "ubifsload ${loadaddr} uImage && bootm ${loadaddr}"
-#define CONFIG_AUTO_COMPLETE 1 /* * Miscellaneous configurable options */ -#define CONFIG_SYS_LONGHELP /* undef to save memory */ -#define CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */ +#undef CONFIG_SYS_PROMPT #define CONFIG_SYS_PROMPT "Pandora # " -#define CONFIG_SYS_CBSIZE 512 /* Console I/O Buffer Size */ -/* Print Buffer Size */ -#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ - sizeof(CONFIG_SYS_PROMPT) + 16) -#define CONFIG_SYS_MAXARGS 16 /* max number of command */ - /* args */ -/* Boot Argument Buffer Size */ -#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE + /* memtest works on */ #define CONFIG_SYS_MEMTEST_START (OMAP34XX_SDRC_CS0) #define CONFIG_SYS_MEMTEST_END (OMAP34XX_SDRC_CS0 + \ 0x01F00000) /* 31MB */
-#define CONFIG_SYS_LOAD_ADDR (OMAP34XX_SDRC_CS0) /* default load */ - /* address */ - -/* - * OMAP3 has 12 GP timers, they can be driven by the system clock - * (12/13/16.8/19.2/38.4MHz) or by 32KHz clock. We use 13MHz (V_SCLK). - * This rate is divided by a local divisor. - */ -#define CONFIG_SYS_TIMERBASE OMAP34XX_GPT2 -#define CONFIG_SYS_PTV 2 /* Divisor: 2^(PTV+1) => 8 */ - -/*----------------------------------------------------------------------- - * Physical Memory Map - */ -#define CONFIG_NR_DRAM_BANKS 2 /* CS1 may or may not be populated */ -#define PHYS_SDRAM_1 OMAP34XX_SDRC_CS0 -#define PHYS_SDRAM_2 OMAP34XX_SDRC_CS1 - -#define CONFIG_SYS_TEXT_BASE 0x80008000 -#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1 -#define CONFIG_SYS_INIT_RAM_ADDR 0x4020f800 -#define CONFIG_SYS_INIT_RAM_SIZE 0x800 -#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_INIT_RAM_ADDR + \ - CONFIG_SYS_INIT_RAM_SIZE - \ - GENERATED_GBL_DATA_SIZE) - -/*----------------------------------------------------------------------- - * FLASH and environment organization - */ - -/* **** PISMO SUPPORT *** */ -#define CONFIG_SYS_MONITOR_LEN (256 << 10) /* Reserve 2 sectors */ - -#if defined(CONFIG_CMD_NAND) +#if defined(CONFIG_NAND) #define CONFIG_SYS_FLASH_BASE NAND_BASE #endif
Grazvydas Ignotas
