[U-Boot] [PATCH v2 1/1] sunxi: Add support for A20-OLinuXino-MICRO-eMMC
From rev.J A20-OLinuXino-MICRO has eMMC option. For now this is
only 4GB, but in the future size may increase.
The dts file is the same from mainline kernel.
Signed-off-by: Stefan Mavrodiev stefan@olimex.com --- Changes for v2: - Synced with latest u-boot - Removed MMC3 CD pin configuration
arch/arm/dts/sun7i-a20-olinuxino-micro-emmc.dts | 70 +++++++++++++++++++++++++ configs/A20-OLinuXino_MICRO-eMMC_defconfig | 27 ++++++++++ 2 files changed, 97 insertions(+) create mode 100644 arch/arm/dts/sun7i-a20-olinuxino-micro-emmc.dts create mode 100644 configs/A20-OLinuXino_MICRO-eMMC_defconfig
diff --git a/arch/arm/dts/sun7i-a20-olinuxino-micro-emmc.dts b/arch/arm/dts/sun7i-a20-olinuxino-micro-emmc.dts new file mode 100644 index 0000000..d99e7b1 --- /dev/null +++ b/arch/arm/dts/sun7i-a20-olinuxino-micro-emmc.dts @@ -0,0 +1,70 @@ + /* + * Copyright 2017 Olimex Ltd. + * Stefan Mavrodiev stefan@olimex.com + * + * This file is dual-licensed: you can use it either under the terms + * of the GPL or the X11 license, at your option. Note that this dual + * licensing only applies to this file, and not this project as a + * whole. + * + * a) This file is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of the + * License, or (at your option) any later version. + * + * This file is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * Or, alternatively, + * + * b) Permission is hereby granted, free of charge, to any person + * obtaining a copy of this software and associated documentation + * files (the "Software"), to deal in the Software without + * restriction, including without limitation the rights to use, + * copy, modify, merge, publish, distribute, sublicense, and/or + * sell copies of the Software, and to permit persons to whom the + * Software is furnished to do so, subject to the following + * conditions: + * + * The above copyright notice and this permission notice shall be + * included in all copies or substantial portions of the Software. + * + * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, + * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES + * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND + * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT + * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, + * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING + * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR + * OTHER DEALINGS IN THE SOFTWARE. + */ + +#include "sun7i-a20-olinuxino-micro.dts" + +/ { + model = "Olimex A20-OLinuXino-MICRO-eMMC"; + compatible = "olimex,a20-olinuxino-micro-emmc", "allwinner,sun7i-a20"; + + mmc2_pwrseq: pwrseq { + compatible = "mmc-pwrseq-emmc"; + reset-gpios = <&pio 2 16 GPIO_ACTIVE_LOW>; + }; +}; + +&mmc2 { + pinctrl-names = "default"; + pinctrl-0 = <&mmc2_pins_a>; + vmmc-supply = <®_vcc3v3>; + bus-width = <4>; + non-removable; + mmc-pwrseq = <&mmc2_pwrseq>; + status = "okay"; + + emmc: emmc@0 { + reg = <0>; + compatible = "mmc-card"; + broken-hpi; + }; +}; diff --git a/configs/A20-OLinuXino_MICRO-eMMC_defconfig b/configs/A20-OLinuXino_MICRO-eMMC_defconfig new file mode 100644 index 0000000..3e07d00 --- /dev/null +++ b/configs/A20-OLinuXino_MICRO-eMMC_defconfig @@ -0,0 +1,27 @@ +CONFIG_ARM=y +CONFIG_ARCH_SUNXI=y +CONFIG_MACH_SUN7I=y +CONFIG_DRAM_CLK=384 +CONFIG_MMC0_CD_PIN="PH1" +CONFIG_MMC_SUNXI_SLOT_EXTRA=2 +CONFIG_I2C1_ENABLE=y +CONFIG_VIDEO_VGA=y +CONFIG_SATAPWR="PB8" +CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-olinuxino-micro" +CONFIG_AHCI=y +# CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL=y +CONFIG_SPL_I2C_SUPPORT=y +# CONFIG_CMD_IMLS is not set +# CONFIG_CMD_FLASH is not set +# CONFIG_CMD_FPGA is not set +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set +CONFIG_ETH_DESIGNWARE=y +CONFIG_SUN7I_GMAC=y +CONFIG_AXP_ALDO3_VOLT=2800 +CONFIG_AXP_ALDO4_VOLT=2800 +CONFIG_SCSI=y +CONFIG_USB_EHCI_HCD=y +CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y
On Thu, Sep 21, 2017 at 01:00:16PM +0000, Stefan Mavrodiev wrote:
From rev.J A20-OLinuXino-MICRO has eMMC option. For now this is only 4GB, but in the future size may increase.
Applied, thanks! Maxime
Maxime Ripard
Stefan Mavrodiev
